[GRASS-SVN] r43142 - in grass/trunk/gui/wxpython: gui_modules icons
Mon Aug 16 11:22:35 EDT 2010
Author: martinl
Date: 2010-08-16 15:22:35 +0000 (Mon, 16 Aug 2010)
New Revision: 43142
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/icons/icon.py
wxGUI/nviz: set properties from cmd (d.vect)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-08-16 14:44:11 UTC (rev 43141)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-08-16 15:22:35 UTC (rev 43142)
@@ -490,6 +490,24 @@
         Debug.msg(3, "GLWindow.UnloadDataLayers(): time = %f" % (stop-start))
+    def SetVectorFromCmd(self, item, data):
+        """!Set 3D view properties from cmd (d.vect)
+        @param item Layer Tree item
+        @param nviz data
+        cmd = self.tree.GetPyData(item)[0]['cmd']
+        if cmd[0] != 'd.vect':
+            return
+        for opt in cmd[1:]:
+            try:
+                key, value = opt.split('=')
+            except ValueError:
+                continue
+            if key == 'color':
+                data['lines']['color']['value'] = value
+                data['points']['color']['value'] = value
     def SetMapObjProperties(self, item, id, nvizType):
         """!Set map object properties
@@ -516,7 +534,8 @@
             elif type ==  'vector':
                 # reset to default properties (lines/points)
                 data['vector'] = self.nvizDefault.SetVectorDefaultProp()
+                self.SetVectorFromCmd(item, data['vector'])
             elif type ==  '3d-raster':
                 data[nvizType] = self.nvizDefault.SetVolumeDefaultProp()
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2010-08-16 14:44:11 UTC (rev 43141)
+++ grass/trunk/gui/wxpython/icons/icon.py	2010-08-16 15:22:35 UTC (rev 43142)
@@ -339,17 +339,23 @@
                         desc = _('Show help for GCP Manager')),
     # nviz
     "nvizView": MetaIcon (img=Icons["nvizView"],
-                          label=_("Switch to view control page")),
+                          label=_("Switch to view control page"),
+                          desc=_("Change view settings")),
     "nvizSurface": MetaIcon (img=Icons["nvizSurface"],
-                          label=_("Switch to surface (raster) control page")),
+                             label=_("Switch to surface (raster) control page"),
+                             desc=_("Change surface (loaded raster maps) settings")),
     "nvizVector": MetaIcon (img=Icons["nvizVector"],
-                          label=_("Switch to vector (2D/3D) control page")),
+                            label=_("Switch to vector (2D/3D) control page"),
+                            desc=_("Change 2D/3D vector settings")),
     "nvizVolume": MetaIcon (img=Icons["nvizVolume"],
-                          label=_("Switch to volume (3D raster) control page")),
+                            label=_("Switch to volume (3D raster) control page"),
+                            desc=_("Change volume (loaded 3D raster maps) settings")),
     "nvizLight": MetaIcon (img=Icons["nvizLight"],
-                          label=_("Switch to lighting control page")),
+                           label=_("Switch to lighting control page"),
+                           desc=_("Change lighting settings")),
     "nvizFringe": MetaIcon (img=Icons["nvizFringe"],
-                          label=_("Switch to fringe control page")),
+                            label=_("Switch to fringe control page"),
+                            desc=_("Switch on/off fringes")),
     "nvizSettings": MetaIcon (img=Icons["settings"],
                               label=_("3D view mode tools"),
                               desc=_("Show/hide 3D view mode settings dialog")),
