[GRASS-SVN] r43255 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Wed Aug 25 03:21:21 EDT 2010
Author: hamish
Date: 2010-08-25 07:21:21 +0000 (Wed, 25 Aug 2010)
New Revision: 43255
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
just because it didn't build doesn't always mean that it's MS Windows's fault (merge from relbr64)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-08-25 07:17:27 UTC (rev 43254)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-08-25 07:21:21 UTC (rev 43255)
@@ -187,9 +187,10 @@
             from nviz import errorMsg
             log.WriteCmdLog(_('3D view mode not available'))
             log.WriteWarning(_('Reason: %s') % str(errorMsg))
-            log.WriteLog(_('Note that the 3D view mode is currently not working under MS Windows '
+            log.WriteLog(_('Note that the wxGUI\'s 3D view mode is currently disabled '
                            '(hopefully this will be fixed soon). '
-                           'Please keep an eye out for updated versions of GRASS.'), wrap = 60)
+                           'Please keep an eye out for updated versions of GRASS. '
+                           'In the meantime you can use "NVIZ" from the File menu.'), wrap = 60)
             self.toolId['3d'] = -1
         if haveVDigit:
@@ -202,9 +203,10 @@
             from vdigit import errorMsg
             log.WriteCmdLog(_('Vector digitizer not available'))
             log.WriteWarning(_('Reason: %s') % errorMsg)
-            log.WriteLog(_('Note that the vector digitizer is currently not working under MS Windows '
+            log.WriteLog(_('Note that the wxGUI\'s vector digitizer is currently disabled '
+                           'In the meantime you can use "v.digit" from the Develop Vector menu.'), wrap = 60)
             self.toolId['vdigit'] = -1
