[GRASS-SVN] r43336 - grass/trunk/locale/po
Sun Aug 29 06:52:30 EDT 2010
Author: neteler
Date: 2010-08-29 10:52:30 +0000 (Sun, 29 Aug 2010)
New Revision: 43336
   grass/trunk/locale/po/grasslibs_ar.po
   grass/trunk/locale/po/grasslibs_cs.po
   grass/trunk/locale/po/grasslibs_de.po
   grass/trunk/locale/po/grasslibs_el.po
   grass/trunk/locale/po/grasslibs_es.po
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasslibs_hi.po
   grass/trunk/locale/po/grasslibs_it.po
   grass/trunk/locale/po/grasslibs_ja.po
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grasslibs_lv.po
   grass/trunk/locale/po/grasslibs_ml.po
   grass/trunk/locale/po/grasslibs_mr.po
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_pt.po
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_ru.po
   grass/trunk/locale/po/grasslibs_sl.po
   grass/trunk/locale/po/grasslibs_th.po
   grass/trunk/locale/po/grasslibs_tr.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grasslibs_zh.po
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/locale/po/grasswxpy_cs.po
   grass/trunk/locale/po/grasswxpy_de.po
   grass/trunk/locale/po/grasswxpy_el.po
   grass/trunk/locale/po/grasswxpy_es.po
   grass/trunk/locale/po/grasswxpy_fr.po
   grass/trunk/locale/po/grasswxpy_id.po
   grass/trunk/locale/po/grasswxpy_it.po
   grass/trunk/locale/po/grasswxpy_ja.po
   grass/trunk/locale/po/grasswxpy_ml.po
   grass/trunk/locale/po/grasswxpy_pl.po
   grass/trunk/locale/po/grasswxpy_pt.po
   grass/trunk/locale/po/grasswxpy_ru.po
   grass/trunk/locale/po/grasswxpy_tr.po
   grass/trunk/locale/po/grasswxpy_vi.po
   grass/trunk/locale/po/grasswxpy_zh.po
update from template
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_ar.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ar\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2005-03-09 12:50+0100\n"
 "Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
 "Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -60,16 +60,24 @@
 msgid "Unable to write quant rules for raster map <%s>"
 msgstr " [%s] غير قادر على أنشاء ملف عنوان رئيسى ل"
-#: ../lib/raster/set_window.c:46
+#: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
 msgstr ""
-#: ../lib/raster/set_window.c:117
+#: ../lib/raster/set_window.c:123
 msgid ""
 "Rast_set_read_window(): projection/zone differs from that of currently open "
 "raster maps"
 msgstr ""
+#: ../lib/raster/set_window.c:150
+msgid "Input window changed while maps are open for read"
+msgstr ""
+#: ../lib/raster/set_window.c:168
+msgid "Output window changed while maps are open for write"
+msgstr ""
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
@@ -457,25 +465,25 @@
 #: ../lib/raster/opencell.c:779 ../lib/raster/opencell.c:831
 #: ../lib/manage/do_rename.c:53 ../lib/manage/do_remove.c:53
 #: ../lib/gis/legal_name.c:91 ../lib/gis/legal_name.c:94
-#: ../lib/rst/interp_float/output2d.c:228
-#: ../lib/rst/interp_float/output2d.c:309
-#: ../lib/rst/interp_float/output2d.c:393
-#: ../lib/rst/interp_float/output2d.c:457
-#: ../lib/rst/interp_float/output2d.c:485
-#: ../lib/rst/interp_float/output2d.c:513
-#: ../lib/rst/interp_float/output2d.c:543
-#: ../lib/rst/interp_float/resout2d.c:188
-#: ../lib/rst/interp_float/resout2d.c:236
-#: ../lib/rst/interp_float/resout2d.c:279
-#: ../lib/rst/interp_float/resout2d.c:319
-#: ../lib/rst/interp_float/resout2d.c:378
-#: ../lib/rst/interp_float/resout2d.c:405
-#: ../lib/rst/interp_float/resout2d.c:429
-#: ../lib/rst/interp_float/resout2d.c:455 ../lib/ogsf/gsd_legend.c:239
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426 ../lib/ogsf/gsd_legend.c:239
 #: ../lib/ogsf/Gs3.c:127 ../lib/ogsf/Gs3.c:200 ../lib/ogsf/Gs3.c:283
 #: ../lib/ogsf/Gs3.c:356 ../lib/ogsf/Gs3.c:470 ../lib/ogsf/Gs3.c:565
-#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:757
-#: ../lib/ogsf/Gs3.c:826
+#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:758
+#: ../lib/ogsf/Gs3.c:828
 #, fuzzy, c-format
 msgid "Raster map <%s> not found"
 msgstr "غير موجود'%s' الفيكتور"
@@ -728,29 +736,21 @@
 msgid "Unable to open header file for raster map <%s@%s>"
 msgstr "'%s' لم يمكن فتح ملف التاريخ للفيكتور"
-#: ../lib/raster/history.c:115
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, fuzzy, c-format
 msgid "Unable to get history information for <%s@%s>"
-#: ../lib/raster/history.c:143
+#: ../lib/raster/history.c:162
 #, fuzzy, c-format
 msgid "Unable to write history information for <%s>"
-#: ../lib/raster/history.c:184
+#: ../lib/raster/history.c:235
 #, c-format
 msgid "generated by %s"
 msgstr ""
-#: ../lib/raster/history.c:232
-msgid "Not enough room in history file to record command line"
-msgstr ""
-#: ../lib/raster/history.c:254
-msgid "Not enough room in history file for command line (truncated)"
-msgstr ""
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
 #: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
 #: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
@@ -801,7 +801,7 @@
 #: ../lib/manage/do_rename.c:37 ../lib/manage/do_remove.c:37
 #: ../lib/vector/Vlib/legal_vname.c:115 ../lib/vector/Vlib/legal_vname.c:118
-#: ../lib/vector/Vlib/map.c:404 ../lib/vector/Vlib/open.c:197
+#: ../lib/vector/Vlib/map.c:403 ../lib/vector/Vlib/open.c:197
 #: ../lib/ogsf/Gv3.c:58 ../lib/ogsf/Gp3.c:58
 #, fuzzy, c-format
 msgid "Vector map <%s> not found"
@@ -1178,12 +1178,12 @@
 " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
 msgstr ""
-#: ../lib/gis/mapset_msc.c:60
+#: ../lib/gis/mapset_msc.c:61
 #, fuzzy, c-format
 msgid "Unable to make mapset element %s (%s): %s"
 msgstr "لم يتم عمل عنصر مجموعة الخرائط%s (%s)"
-#: ../lib/gis/mapset_msc.c:64
+#: ../lib/gis/mapset_msc.c:65
 #, fuzzy, c-format
 msgid "Unable to access mapset element %s (%s): %s"
@@ -1723,23 +1723,27 @@
 msgid "Field separator"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:455
+#: ../lib/gis/parser_standard_options.c:445
+msgid "Special characters: newline, space, comma, tab"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:456
 msgid "Color"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:456
+#: ../lib/gis/parser_standard_options.c:457
 msgid "Either a standard color name or R:G:B triplet"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:465
+#: ../lib/gis/parser_standard_options.c:466
 msgid "Background color"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:467
+#: ../lib/gis/parser_standard_options.c:468
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:478
+#: ../lib/gis/parser_standard_options.c:479
 msgid "Units"
 msgstr ""
@@ -1775,14 +1779,14 @@
 msgid "SYNOPSIS"
 msgstr ""
-#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:146
+#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:147
 #, fuzzy
 msgid "Flags"
 msgstr ""
 "\n"
 "علامات:\n"
-#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:156
+#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:157
 #, fuzzy
 msgid "Parameters"
 msgstr ""
@@ -2276,29 +2280,29 @@
 msgid "%s complete. %s"
 msgstr "%s تم أنهاء %s\n"
-#: ../lib/gis/gisinit.c:55 ../lib/gis/gisinit.c:90
+#: ../lib/gis/gisinit.c:56 ../lib/gis/gisinit.c:91
 msgid ""
 "Incompatible library version for module. You need to rebuild GRASS or "
 "untangle multiple installations."
 msgstr ""
-#: ../lib/gis/gisinit.c:65
+#: ../lib/gis/gisinit.c:66
 #, c-format
 msgid "MAPSET %s - permission denied"
 msgstr "MAPSET %s - غير مصرح"
-#: ../lib/gis/gisinit.c:68
+#: ../lib/gis/gisinit.c:69
 #, c-format
 msgid "MAPSET %s not found"
 msgstr "MAPSET %s غير موجودة"
-#: ../lib/gis/gisinit.c:107
+#: ../lib/gis/gisinit.c:108
 #, fuzzy
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
 msgstr " خطأ: لم يبدأ النظام. معد البرنامج نسي إستدعاء برنامج بدءالنظام ()\n"
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/vector/Vlib/ascii.c:187 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/ascii.c:200 ../lib/vector/Vlib/line.c:50
 #: ../lib/vector/neta/articulation_point.c:60
 #: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
 #: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
@@ -2495,12 +2499,12 @@
 msgid "Writing to file loaded to memory not supported"
 msgstr ""
-#: ../lib/vector/diglib/file.c:204
+#: ../lib/vector/diglib/file.c:205
 #, fuzzy
 msgid "Unable to load file to memory, file not open"
 msgstr "لم يمكن توفير ذاكرة كافية\n"
-#: ../lib/vector/diglib/file.c:219
+#: ../lib/vector/diglib/file.c:220
 msgid "Vector memory mode not supported, using 'AUTO'"
 msgstr ""
@@ -2565,12 +2569,12 @@
 msgid "%s: Area %d does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:675 ../lib/vector/Vlib/write_ogr.c:298
+#: ../lib/vector/Vlib/write_nat.c:670 ../lib/vector/Vlib/write_ogr.c:298
 #, fuzzy
 msgid "Attempt to delete dead feature"
 msgstr "%s: لم يمكن فتح ملف  الطبوغرافية للكتابة\n"
-#: ../lib/vector/Vlib/write_nat.c:920
+#: ../lib/vector/Vlib/write_nat.c:910
 #, fuzzy
 msgid "Attempt to restore alive feature"
@@ -2706,20 +2710,20 @@
 msgid "Not enough space in vector array"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:313
-#: ../lib/vector/Vlib/map.c:440 ../lib/vector/Vlib/map.c:552
-#: ../lib/vector/Vlib/map.c:670 ../lib/vector/Vlib/map.c:768
+#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:312
+#: ../lib/vector/Vlib/map.c:439 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:669 ../lib/vector/Vlib/map.c:767
 #: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:347
-#: ../lib/vector/Vlib/ascii.c:301 ../lib/vector/Vlib/write_ogr.c:118
+#: ../lib/vector/Vlib/ascii.c:314 ../lib/vector/Vlib/write_ogr.c:118
 #: ../lib/rst/interp_float/vinput2d.c:79
 #, c-format
 msgid "Database connection not defined for layer %d"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:342
-#: ../lib/vector/Vlib/map.c:481 ../lib/vector/Vlib/map.c:703
+#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:341
+#: ../lib/vector/Vlib/map.c:480 ../lib/vector/Vlib/map.c:702
 #: ../lib/vector/Vlib/net.c:182 ../lib/vector/Vlib/net.c:352
-#: ../lib/vector/Vlib/ascii.c:313 ../lib/vector/Vlib/write_ogr.c:375
+#: ../lib/vector/Vlib/ascii.c:326 ../lib/vector/Vlib/write_ogr.c:375
 #: ../lib/vector/neta/utils.c:116 ../lib/vector/neta/timetables.c:133
 #: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/copy_tab.c:105
 #: ../lib/db/dbmi_client/copy_tab.c:126 ../lib/db/dbmi_client/db.c:46
@@ -3120,47 +3124,47 @@
 msgid "Request to find area outside nonexistent isle"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:523
+#: ../lib/vector/Vlib/build_nat.c:525
 #, fuzzy
 msgid "Registering primitives..."
 msgstr ":تسجيل الخطوط"
-#: ../lib/vector/Vlib/build_nat.c:532
+#: ../lib/vector/Vlib/build_nat.c:534
 #, fuzzy
 msgid "Unable to read vector map"
-#: ../lib/vector/Vlib/build_nat.c:576
+#: ../lib/vector/Vlib/build_nat.c:578
 #, c-format
 msgid "%d primitives registered"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:577
+#: ../lib/vector/Vlib/build_nat.c:579
 #, c-format
 msgid "%d vertices registered"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:588
+#: ../lib/vector/Vlib/build_nat.c:590
 #, fuzzy
 msgid "Building areas..."
 msgstr "يتم الان بناء الطبولوجى ...\n"
-#: ../lib/vector/Vlib/build_nat.c:611
+#: ../lib/vector/Vlib/build_nat.c:613
 #, fuzzy, c-format
 msgid "%d areas built"
 msgstr "تم بناء الطبولوجى\n"
-#: ../lib/vector/Vlib/build_nat.c:612
+#: ../lib/vector/Vlib/build_nat.c:614
 #, fuzzy, c-format
 msgid "%d isles built"
-#: ../lib/vector/Vlib/build_nat.c:621
+#: ../lib/vector/Vlib/build_nat.c:623
 #, fuzzy
 msgid "Attaching islands..."
 msgstr ": توصيل الجزر"
-#: ../lib/vector/Vlib/build_nat.c:636
+#: ../lib/vector/Vlib/build_nat.c:638
 #, fuzzy
 msgid "Attaching centroids..."
 msgstr " : توصيل اشباه المراكز"
@@ -3208,91 +3212,91 @@
 msgid "Unable to read vector map <%s>"
-#: ../lib/vector/Vlib/map.c:242 ../lib/vector/Vlib/map.c:386
-#: ../lib/vector/Vlib/open.c:692
+#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:385
+#: ../lib/vector/Vlib/open.c:691
 #, fuzzy, c-format
 msgid "Vector map name is not SQL compliant"
 msgstr "SQL اسم الخريطة غير متوافق مع نظام"
-#: ../lib/vector/Vlib/map.c:246
+#: ../lib/vector/Vlib/map.c:245
 #, fuzzy, c-format
 msgid "Unable to find vector map <%s> in <%s>"
 msgstr "'%s'الى '%s'لم يمكن نسخ فيكتور"
-#: ../lib/vector/Vlib/map.c:258 ../lib/vector/Vlib/map.c:390
-#: ../lib/vector/Vlib/open.c:699
+#: ../lib/vector/Vlib/map.c:257 ../lib/vector/Vlib/map.c:389
+#: ../lib/vector/Vlib/open.c:698
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "موجود ولايمكن تغييره '%s' الفيكتور"
-#: ../lib/vector/Vlib/map.c:262 ../lib/vector/Vlib/open.c:704
+#: ../lib/vector/Vlib/map.c:261 ../lib/vector/Vlib/open.c:703
 #, fuzzy, c-format
 msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:282 ../lib/vector/Vlib/map.c:408
+#: ../lib/vector/Vlib/map.c:281 ../lib/vector/Vlib/map.c:407
 #, fuzzy, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:457
-#: ../lib/vector/Vlib/map.c:695 ../lib/vector/Vlib/map.c:802
+#: ../lib/vector/Vlib/map.c:330 ../lib/vector/Vlib/map.c:456
+#: ../lib/vector/Vlib/map.c:694 ../lib/vector/Vlib/map.c:801
 #, fuzzy, c-format
 msgid "Unable to copy table <%s>"
 msgstr "لم يمكن فتحه %s فى %s"
-#: ../lib/vector/Vlib/map.c:347 ../lib/vector/Vlib/map.c:486
-#: ../lib/vector/Vlib/map.c:708
+#: ../lib/vector/Vlib/map.c:346 ../lib/vector/Vlib/map.c:485
+#: ../lib/vector/Vlib/map.c:707
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 msgstr "[%s فى %s]لم يمكن انشاء ملف العنوان الرئيسى"
-#: ../lib/vector/Vlib/map.c:471 ../lib/vector/Vlib/map.c:572
+#: ../lib/vector/Vlib/map.c:470 ../lib/vector/Vlib/map.c:571
 #, fuzzy, c-format
 msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/map.c:526
+#: ../lib/vector/Vlib/map.c:525
 #, fuzzy, c-format
 msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:540
+#: ../lib/vector/Vlib/map.c:539
 #, fuzzy, c-format
 msgid "Unable to open header file for vector map <%s>"
-#: ../lib/vector/Vlib/map.c:562
+#: ../lib/vector/Vlib/map.c:561
 #, fuzzy, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
-#: ../lib/vector/Vlib/map.c:579
+#: ../lib/vector/Vlib/map.c:578
 #, fuzzy, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:592
+#: ../lib/vector/Vlib/map.c:591
 #, fuzzy, c-format
 msgid "Unable to open directory '%s'"
-#: ../lib/vector/Vlib/map.c:606
+#: ../lib/vector/Vlib/map.c:605
 #, fuzzy, c-format
 msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/map.c:623
+#: ../lib/vector/Vlib/map.c:622
 #, fuzzy, c-format
 msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/map.c:631
+#: ../lib/vector/Vlib/map.c:630
 #, fuzzy, c-format
 msgid "Unable to remove directory '%s'"
-#: ../lib/vector/Vlib/map.c:686 ../lib/vector/Vlib/map.c:787
+#: ../lib/vector/Vlib/map.c:685 ../lib/vector/Vlib/map.c:786
 #, fuzzy, c-format
 msgid "Unable to add database link for vector map <%s>"
@@ -3302,14 +3306,14 @@
 msgid "Unable to open coor file for vector map <%s>"
-#: ../lib/vector/Vlib/open_nat.c:155
+#: ../lib/vector/Vlib/open_nat.c:154
 #, c-format
 msgid ""
 "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
 "excess)"
 msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:159
+#: ../lib/vector/Vlib/open_nat.c:158
 #, c-format
 msgid ""
 "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
@@ -3334,7 +3338,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:204
-#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:488
+#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:501
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr "لم يتم كتابة روابط قاعدة البيانات"
@@ -3488,7 +3492,7 @@
 msgid "Unable to restore feature %d from vector map <%s>"
-#: ../lib/vector/Vlib/close.c:140
+#: ../lib/vector/Vlib/close.c:139
 #, fuzzy, c-format
 msgid "Unable to close vector <%s>"
@@ -3537,7 +3541,7 @@
 msgid "Unable to open spatial index file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:511
+#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:510
 #, fuzzy, c-format
 msgid "Unable to open category index file for vector map <%s>"
@@ -3557,42 +3561,42 @@
 msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:683
+#: ../lib/vector/Vlib/open.c:682
 #, fuzzy, c-format
 msgid "%s is not in the current mapset (%s)"
 msgstr "<%s> فى مجموعة الخريطة <%s>"
-#: ../lib/vector/Vlib/open.c:721
+#: ../lib/vector/Vlib/open.c:720
 #, fuzzy, c-format
 msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/open.c:731
+#: ../lib/vector/Vlib/open.c:730
 #, fuzzy, c-format
 msgid "Unable to open history file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:783
+#: ../lib/vector/Vlib/open.c:782
 #, fuzzy, c-format
 msgid "Unable to stat file <%s>"
-#: ../lib/vector/Vlib/open.c:842
+#: ../lib/vector/Vlib/open.c:841
 #, c-format
 msgid "unknown %d (update Vect_maptype_info)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:918
+#: ../lib/vector/Vlib/open.c:916
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr "حجم ملف الأحداثيات مختلف عن القيم المحفوظة فى ملف الطبوغرافية"
-#: ../lib/vector/Vlib/open.c:929 ../lib/vector/Vlib/open.c:1024
+#: ../lib/vector/Vlib/open.c:927 ../lib/vector/Vlib/open.c:1021
 #, fuzzy, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
-#: ../lib/vector/Vlib/open.c:1013
+#: ../lib/vector/Vlib/open.c:1010
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in sidx file"
@@ -3637,87 +3641,97 @@
 msgid "Vector map <%s> is not open on level >= 2"
-#: ../lib/vector/Vlib/ascii.c:77
+#: ../lib/vector/Vlib/ascii.c:80
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
 msgstr "لم يمكن قراءة ملف النطاف [%s فى %s]"
-#: ../lib/vector/Vlib/ascii.c:115
+#: ../lib/vector/Vlib/ascii.c:118
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
-#: ../lib/vector/Vlib/ascii.c:128
+#: ../lib/vector/Vlib/ascii.c:131
 msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:138
+#: ../lib/vector/Vlib/ascii.c:142
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
-#: ../lib/vector/Vlib/ascii.c:169
+#: ../lib/vector/Vlib/ascii.c:146
+#, fuzzy, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr "لم يمكن فتحه %s فى %s"
+#: ../lib/vector/Vlib/ascii.c:149
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:182
 msgid "End of ASCII file reached before end of categories"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:179
+#: ../lib/vector/Vlib/ascii.c:192
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
-#: ../lib/vector/Vlib/ascii.c:222
+#: ../lib/vector/Vlib/ascii.c:235
 #, c-format
 msgid ""
 "Unexpected data in vector head:\n"
 "[%s]"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:256
+#: ../lib/vector/Vlib/ascii.c:269
 #, fuzzy, c-format
 msgid "Unknown keyword <%s> in vector head"
 msgstr "مسقط غير معروف"
-#: ../lib/vector/Vlib/ascii.c:307 ../lib/db/dbmi_client/copy_tab.c:100
+#: ../lib/vector/Vlib/ascii.c:320 ../lib/db/dbmi_client/copy_tab.c:100
 #: ../lib/db/dbmi_client/copy_tab.c:120 ../lib/db/dbmi_client/db.c:41
 #, fuzzy, c-format
 msgid "Unable to start driver <%s>"
-#: ../lib/vector/Vlib/ascii.c:413
+#: ../lib/vector/Vlib/ascii.c:426
 #, fuzzy, c-format
 msgid "Uknown feature type %d"
-#: ../lib/vector/Vlib/ascii.c:453
+#: ../lib/vector/Vlib/ascii.c:466
 #, c-format
 msgid "Feature has more categories. Only first category (%d) is exported."
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:463
+#: ../lib/vector/Vlib/ascii.c:476
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
-#: ../lib/vector/Vlib/ascii.c:490
+#: ../lib/vector/Vlib/ascii.c:503
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
-#: ../lib/vector/Vlib/ascii.c:570
+#: ../lib/vector/Vlib/ascii.c:583
 #, fuzzy
 msgid "Unknown format"
-#: ../lib/vector/Vlib/ascii.c:579
+#: ../lib/vector/Vlib/ascii.c:592
 msgid "Topology not available, unable to process areas"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:592
+#: ../lib/vector/Vlib/ascii.c:605
 #, fuzzy, c-format
 msgid "Unable to get boundary of area id %d"
 msgstr "لم يمكن فتح ملف مؤقت"
-#: ../lib/vector/Vlib/ascii.c:604
+#: ../lib/vector/Vlib/ascii.c:617
 #, fuzzy, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
@@ -3876,62 +3890,57 @@
 msgid "Unable to open select cursor: %s"
-#: ../lib/nviz/render.c:108
+#: ../lib/nviz/render.c:104
 msgid "Bad server connection"
 msgstr ""
-#: ../lib/nviz/render.c:117
+#: ../lib/nviz/render.c:113
 #, fuzzy
 msgid "Unable to create rendering context"
 msgstr "لم يتم انشاء عملية جديدة"
-#: ../lib/nviz/lights.c:144
+#: ../lib/nviz/lights.c:174
 #, fuzzy
 msgid "Unable to define new light"
-#: ../lib/nviz/position.c:50
+#: ../lib/nviz/position.c:56
 #, fuzzy
 msgid "Unable to set focus"
 msgstr " %s لم يمكن فتح"
-#: ../lib/nviz/nviz.c:78
+#: ../lib/nviz/nviz.c:105
 #, c-format
 msgid "Invalid color (%s), using \"white\" as default"
 msgstr ""
-#: ../lib/nviz/change_view.c:108
-#, c-format
-msgid "Invalid view position coordinates, using %f,%f"
-msgstr ""
-#: ../lib/nviz/map_obj.c:65
+#: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:94
+#: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:103 ../lib/nviz/map_obj.c:134
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, fuzzy, c-format
 msgid "Error loading vector map <%s>"
-#: ../lib/nviz/map_obj.c:122
+#: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:149
+#: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:158
+#: ../lib/nviz/map_obj.c:152
 #, fuzzy, c-format
 msgid "Error loading 3d raster map <%s>"
 msgstr "للخرائط الراسترية الموجودة %d\n"
-#: ../lib/nviz/map_obj.c:166
+#: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
 msgstr ""
@@ -4229,7 +4238,7 @@
 msgid "The total sum of the water budget is significant larger then 0: %g\n"
 msgstr ""
-#: ../lib/init/grass.py:145
+#: ../lib/init/grass.py:146
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4237,94 +4246,94 @@
 "الإستخدام:\n"
-#: ../lib/init/grass.py:147
+#: ../lib/init/grass.py:148
 msgid "print this help message"
 msgstr ""
-#: ../lib/init/grass.py:148
+#: ../lib/init/grass.py:149
 msgid "show version information and exit"
 msgstr ""
-#: ../lib/init/grass.py:149
+#: ../lib/init/grass.py:150
 msgid "create given mapset if it doesn't exist"
 msgstr ""
-#: ../lib/init/grass.py:150
+#: ../lib/init/grass.py:151
 msgid "use text based interface"
 msgstr ""
-#: ../lib/init/grass.py:151 ../lib/init/grass.py:153 ../lib/init/grass.py:155
+#: ../lib/init/grass.py:152 ../lib/init/grass.py:154 ../lib/init/grass.py:156
 #, fuzzy
 msgid "and set as default"
 msgstr "لقبول الأساس المخزن"
-#: ../lib/init/grass.py:152
+#: ../lib/init/grass.py:153
 msgid "use graphical user interface ($DEFAULT_GUI by default)"
 msgstr ""
-#: ../lib/init/grass.py:154
+#: ../lib/init/grass.py:155
 msgid "use wxPython based graphical user interface"
 msgstr ""
-#: ../lib/init/grass.py:157
+#: ../lib/init/grass.py:158
 msgid "initial database (path to GIS data)"
 msgstr ""
-#: ../lib/init/grass.py:158
+#: ../lib/init/grass.py:159
 msgid "initial location"
 msgstr ""
-#: ../lib/init/grass.py:159
+#: ../lib/init/grass.py:160
 msgid "initial mapset"
 msgstr ""
-#: ../lib/init/grass.py:160
+#: ../lib/init/grass.py:161
 msgid "fully qualified initial mapset directory"
 msgstr ""
-#: ../lib/init/grass.py:161
+#: ../lib/init/grass.py:162
 msgid "Environment variables relevant for startup"
 msgstr ""
-#: ../lib/init/grass.py:162
+#: ../lib/init/grass.py:163
 msgid "select GUI (text, gui, wxpython)"
 msgstr ""
-#: ../lib/init/grass.py:163
+#: ../lib/init/grass.py:164
 msgid "set wish shell name to override 'wish'"
 msgstr ""
-#: ../lib/init/grass.py:164
+#: ../lib/init/grass.py:165
 msgid "set html web browser for help pages"
 msgstr ""
-#: ../lib/init/grass.py:165
+#: ../lib/init/grass.py:166
 msgid "set additional path(s) to local GRASS modules"
 msgstr ""
-#: ../lib/init/grass.py:166
+#: ../lib/init/grass.py:167
 msgid "shell script to be processed as batch job"
 msgstr ""
-#: ../lib/init/grass.py:167
+#: ../lib/init/grass.py:168
 msgid "set python shell name to override 'python'"
 msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:188
 #, fuzzy
 msgid "Unable to create temporary directory! Exiting."
-#: ../lib/init/grass.py:357
+#: ../lib/init/grass.py:356
 msgid "Searched for a web browser, but none found"
 msgstr ""
-#: ../lib/init/grass.py:376
+#: ../lib/init/grass.py:375
 #, fuzzy
 msgid "Hit RETURN to continue"
 msgstr "RETURN أضغط   لألغاء الأمر\n"
-#: ../lib/init/grass.py:405
+#: ../lib/init/grass.py:404
 msgid ""
 "The python command does not work as expected!\n"
 "Please check your GRASS_PYTHON environment variable.\n"
@@ -4334,7 +4343,7 @@
 "Hit RETURN to continue.\n"
 msgstr ""
-#: ../lib/init/grass.py:417
+#: ../lib/init/grass.py:416
 msgid ""
 "It appears that the X Windows system is not active.\n"
 "A graphical based user interface is not supported.\n"
@@ -4343,34 +4352,34 @@
 msgstr ""
-#: ../lib/init/grass.py:459 ../lib/init/grass.py:472
+#: ../lib/init/grass.py:458 ../lib/init/grass.py:471
 #, fuzzy, python-format
 msgid "<%s> is not a valid GRASS location"
 msgstr "أسفا<%s> ليس إختيار صحيح\n"
-#: ../lib/init/grass.py:464
+#: ../lib/init/grass.py:463
 #, python-format
 msgid "The location <%s> does not exist. Please create it first."
 msgstr ""
-#: ../lib/init/grass.py:470
+#: ../lib/init/grass.py:469
 msgid "Missing WIND file fixed"
 msgstr ""
-#: ../lib/init/grass.py:484
+#: ../lib/init/grass.py:483
 msgid ""
 "GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
 "Interactive startup needed."
 msgstr ""
-#: ../lib/init/grass.py:498
+#: ../lib/init/grass.py:497
 #, python-format
 msgid ""
 "Invalid user interface specified - <%s>.\n"
 "Use the --help option to see valid interface names."
 msgstr ""
-#: ../lib/init/grass.py:511
+#: ../lib/init/grass.py:510
 msgid ""
 "Error in GUI startup. If necessary, please report this error to the GRASS "
 "developers.\n"
@@ -4379,19 +4388,19 @@
 "Hit RETURN to continue..."
 msgstr ""
-#: ../lib/init/grass.py:521
+#: ../lib/init/grass.py:520
 msgid ""
 "Received EXIT message from GUI.\n"
 "GRASS is not started. Bye."
 msgstr ""
-#: ../lib/init/grass.py:524
+#: ../lib/init/grass.py:523
 msgid ""
 "Invalid return code from GUI startup script.\n"
 "Please advise GRASS developers of this error."
 msgstr ""
-#: ../lib/init/grass.py:534
+#: ../lib/init/grass.py:533
 msgid ""
 "Error reading data path information from g.gisenv.\n"
 "GISDBASE=%(gisbase)s\n"
@@ -4401,31 +4410,31 @@
 "Check the <%s(file)> file."
 msgstr ""
-#: ../lib/init/grass.py:555
+#: ../lib/init/grass.py:554
 #, python-format
 msgid ""
 "%(user)s is currently running GRASS in selected mapset (file %(file)s "
 "found). Concurrent use not allowed."
 msgstr ""
-#: ../lib/init/grass.py:559
+#: ../lib/init/grass.py:558
 #, python-format
 msgid ""
 "Unable to properly access \"%s\"\n"
 "Please notify system personel."
 msgstr ""
-#: ../lib/init/grass.py:570
+#: ../lib/init/grass.py:569
 #, fuzzy
 msgid "Building user fontcap..."
-#: ../lib/init/grass.py:599
+#: ../lib/init/grass.py:598
 #, fuzzy
 msgid "The SHELL variable is not set"
 msgstr "GISRC - المتغير لم يحدد بشكل صحيح"
-#: ../lib/init/grass.py:609
+#: ../lib/init/grass.py:608
 #, python-format
 msgid ""
 "Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -4434,97 +4443,92 @@
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
-#: ../lib/init/grass.py:614
+#: ../lib/init/grass.py:613
 #, python-format
 msgid "Change file permission to 'executable' for '%s'"
 msgstr ""
-#: ../lib/init/grass.py:616
+#: ../lib/init/grass.py:615
 #, python-format
 msgid "Executing '%s' ..."
 msgstr ""
-#: ../lib/init/grass.py:623
+#: ../lib/init/grass.py:620
 #, python-format
+msgid "Execution of '%s' finished."
+msgstr ""
+#: ../lib/init/grass.py:625
+#, python-format
 msgid "GRASS GUI should be '%s'"
 msgstr ""
-#: ../lib/init/grass.py:667
+#: ../lib/init/grass.py:669
 msgid "GRASS homepage:"
 msgstr ""
-#: ../lib/init/grass.py:668
+#: ../lib/init/grass.py:670
 msgid "This version running through:"
 msgstr ""
-#: ../lib/init/grass.py:670
+#: ../lib/init/grass.py:672
 msgid "Help is available with the command:"
 msgstr ""
-#: ../lib/init/grass.py:671
+#: ../lib/init/grass.py:673
 msgid "See the licence terms with:"
 msgstr ""
-#: ../lib/init/grass.py:674
+#: ../lib/init/grass.py:676
 msgid "If required, restart the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:676
+#: ../lib/init/grass.py:678
 msgid "Start the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:678
+#: ../lib/init/grass.py:680
 msgid "When ready to quit enter:"
 msgstr ""
-#: ../lib/init/grass.py:781
+#: ../lib/init/grass.py:783
 msgid "Failed to start shell '%s'"
-#: ../lib/init/grass.py:785
+#: ../lib/init/grass.py:787
 #, python-format
 msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
 msgstr ""
-#: ../lib/init/grass.py:786 ../lib/init/grass.py:791
+#: ../lib/init/grass.py:788 ../lib/init/grass.py:793
 msgid "Goodbye from GRASS GIS"
 msgstr ""
-#: ../lib/init/grass.py:789
+#: ../lib/init/grass.py:791
 #, fuzzy
 msgid "Done."
 msgstr "لاشىء"
-#: ../lib/init/grass.py:795
+#: ../lib/init/grass.py:797
 #, fuzzy
 msgid "Cleaning up temporary files..."
-#: ../lib/init/grass.py:938
+#: ../lib/init/grass.py:940
 msgid "Starting GRASS GIS..."
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:84
+#: ../lib/rst/interp_float/output2d.c:106
 #, c-format
 msgid "First change your rows number to nsizr! %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:91
+#: ../lib/rst/interp_float/output2d.c:113
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:99
-#, c-format
-msgid "Rows changed from %d to %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:105
-#, c-format
-msgid "Cols changed from %d to %d"
-msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:111
 msgid ""
 "Taking too long to find points for interpolation - please change the region "
@@ -4538,25 +4542,25 @@
 "cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:60
+#: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:86
+#: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
 msgid "First change your rows number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:93
+#: ../lib/rst/interp_float/resout2d.c:110
 #, c-format
 msgid "First change your columns number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:247
+#: ../lib/rst/interp_float/resout2d.c:264
 msgid "No color table for input raster map -- will not create color table"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:458
 msgid "Changing the region back to initial..."
 msgstr ""
@@ -4715,7 +4719,7 @@
 msgid "Window replacing the default"
-#: ../lib/g3d/g3dhistory.c:42
+#: ../lib/g3d/g3dhistory.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
 msgstr ""
@@ -4947,12 +4951,12 @@
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
 msgstr ""
-#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:771
+#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:772
 #, fuzzy, c-format
 msgid "Translating colors from raster map <%s>..."
-#: ../lib/ogsf/Gs3.c:1005
+#: ../lib/ogsf/Gs3.c:1007
 msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
@@ -4974,23 +4978,33 @@
 msgid "Bitmap mismatch"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1643
+#: ../lib/ogsf/GS2.c:1198
+#, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1217
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1640
 #, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr "خطأ: محاولة لتحديث خريطة ليست ضمن مجموعة الخرائط الحالية"
-#: ../lib/ogsf/GS2.c:1723 ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1737
-#: ../lib/ogsf/GS2.c:1746 ../lib/ogsf/GS2.c:1754 ../lib/ogsf/GS2.c:1764
-#: ../lib/ogsf/GS2.c:1812
+#: ../lib/ogsf/GS2.c:1720 ../lib/ogsf/GS2.c:1726 ../lib/ogsf/GS2.c:1734
+#: ../lib/ogsf/GS2.c:1743 ../lib/ogsf/GS2.c:1751 ../lib/ogsf/GS2.c:1761
+#: ../lib/ogsf/GS2.c:1809
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1840
+#: ../lib/ogsf/GS2.c:1837
 #, fuzzy
 msgid "Loading failed"
 msgstr "فشل الإتصال\n"
-#: ../lib/ogsf/GS2.c:1844
+#: ../lib/ogsf/GS2.c:1841
 msgid "Error finding range"
 msgstr ""
@@ -5105,7 +5119,7 @@
 msgstr ""
 "غير صالح <%s>  غير مسموح بها و بالتالى اسم الفيكتور المعطى <%c> حروف ك\n"
-#: ../lib/db/dbmi_base/login.c:112
+#: ../lib/db/dbmi_base/login.c:111
 msgid "Login file corrupted"
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_cs.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -14,7 +14,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_cs\n"
 "PO-Revision-Date: 2010-03-07 15:47+0100\n"
 "Last-Translator: \n"
 "Language-Team:  <cs at li.org>\n"
@@ -66,11 +66,11 @@
 msgstr "Nelze èíst rozmezí hodnot rastrové mapy <%s>"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -79,6 +79,14 @@
 "G_set_window(): mapová projekce/zóna se li¹í od aktuálnì otevøených "
 "rastrových souborù"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -466,25 +474,25 @@
 #, c-format
 msgstr "Rastrová mapa <%s> nebyla nalezena"
@@ -743,34 +751,21 @@
 msgstr "Nelze otevøít hlavièkový soubor rastrové mapy <%s@%s>"
 #, fuzzy, c-format
 msgstr "nelze zapsat informace o historii pro [%s]"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr ""
-"V souboru s historií není dostatek místa, aby pøíkazová øádka mohla být "
-"zaznamenána"
-#, fuzzy
-msgstr ""
-"V souboru s historií není dostatek místa pro pøíkazovou øádku (zkráceno)"
@@ -821,7 +816,7 @@
 #, c-format
@@ -1208,12 +1203,12 @@
 msgstr " Pouze %d%% z okna ulo¾eného v \"%s\" pokrývá aktuální okno GRASSu."
 #, c-format
 msgstr "Nelze vytvoøit prvek mapsetu %s (%s): %s"
 #, c-format
 msgstr "Nelze zpøístupnit prvek mapsetu %s(%s): %s"
@@ -1756,23 +1751,27 @@
 msgstr "Oddìlovaè"
+msgstr ""
 msgid "Color"
 msgstr "Barva"
 msgstr "Buï název standardní barvy nebo R:G:B triplet"
 msgstr "Barva pozadí"
 msgstr "Buï standardní GRASS barva, R:G:B triplet nebo \"none\""
 msgid "Units"
 msgstr ""
@@ -1807,11 +1806,11 @@
 msgid "SYNOPSIS"
 msgstr "Synopse"
 msgid "Flags"
 msgstr "Pøepínaèe"
 msgid "Parameters"
 msgstr "Parametry"
@@ -2294,7 +2293,7 @@
 msgstr "%s hotovo. %s"
 msgid ""
@@ -2302,22 +2301,22 @@
 "Neompatibilní verze knihovny pro modul. Je potøeba znovu zkompilovat GRASS "
 "nebo vyøe¹it problém více instalací."
 #, c-format
 msgstr "MAPSET %s - pøístup odepøen"
 #, c-format
 msgstr "MAPSET %s nebyl nalezen"
 msgstr "Systém není inicializován. Programátor zapomnìl zavolat G_gisinit()."
@@ -2506,11 +2505,11 @@
 msgstr "Zapisování do souboru naèteného do pamìti není podporováno"
 msgstr "nelze naèíst soubor do pamìti, sobor není otevøen"
 msgstr "Vemód vektorové pamìti není podporován, pou¾iji 'AUTO'"
@@ -2580,11 +2579,11 @@
 msgstr "%s:Plocha %d neexistuje"
 msgstr "Pokus o odstranìní mrtvé plochy"
 msgstr "Pokus o o¾ivení prvku"
@@ -2719,20 +2718,20 @@
 msgstr "Nedostatek místa ve vektorovém poli"
 #, c-format
 msgstr "Pro vrstvu %d nebylo definováno databázové pøipojení"
@@ -3130,43 +3129,43 @@
 msgstr "Po¾adavek najít plochy mimo neexistující ostrov"
 msgstr "Registrace primitiv..."
 msgstr "Nelze èíst vektorovou vrstvu"
 #, c-format
 msgstr "%d primitiv zaregistrováno"
 #, c-format
 msgstr "%d opìrných bodù zaregistrováno"
 msgstr "Vytváøení ploch..."
 #, c-format
 msgstr "%d ploch vytvoøeno"
 #, c-format
 msgstr "%d ostrovù vytvoøeno"
 msgstr "Pøidávání ostrovù..."
 msgstr "Pøipojování centroidù..."
@@ -3212,91 +3211,91 @@
 msgstr "Nelze èíst vektorovou mapu <%s>"
 #, c-format
 msgstr "Název mapy nevyhovuje podmínkám SQL"
 #, c-format
 msgstr "Nelze najít vektorovou mapu <%s> v <%s>"
 #, c-format
 msgstr "Vektorová mapa <%s> ji¾ existuje a bude pøepsána."
 #, c-format
 msgstr "Nelze smazat vektorovou mapu <%s>"
 #, c-format
 msgstr "Nelze kopírovat vektorovou mapu <%s> do <%s>"
 #, c-format
 msgstr "Nelze kopírovat tabulku <%s>"
 #, c-format
 msgstr "Nelze vytvoøit index pro tabulku <%s>, klíè <%s>"
 #, c-format
 msgstr "Nelze smazat tabulku <%s>"
 #, c-format
 msgstr "Nesprávné jméno vektorové mapy <%s>"
 #, c-format
 msgstr "Nelze otevøít hlavièkový soubor pro vektorovou mapu <%s>"
 #, c-format
 msgstr "Nelze nelézt tabulku <%s> pøipojenou k vektorové mapì <%s>"
 #, c-format
 msgstr "Tabulka <%s> pøipojená k vektorové mapì <%s> neexistuje"
 #, c-format
 msgstr "Nelze otevøít adresáø <%s>"
 #, c-format
 msgstr "Nelze smazat soubor <%s>"
 #, c-format
 msgstr "Nelze pøejmenovat adresáø '%s' na '%s'"
 #, c-format
 msgstr "Nelze smazat adresáø '%s'"
 #, c-format
 msgstr "Nelze pøipojit databázi k vektorové mapì <%s>"
@@ -3306,7 +3305,7 @@
 msgstr "Nelze otevøít soubor s historií pro vektorovou mapu <%s>"
 #, fuzzy, c-format
 msgid ""
@@ -3315,7 +3314,7 @@
 "Soubor se souøadnicemi (Coor) vektorové mapy <%s@%s> je vìt¹í ne¾ by mìl být "
 "(%ld bytù pøebývá)"
 #, fuzzy, c-format
 msgid ""
@@ -3340,7 +3339,7 @@
 msgstr "Arc vrstva < 1"
 #, c-format
 msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
@@ -3495,7 +3494,7 @@
 msgstr "Nelze obnovit prvek %d z vektorové vrstvy <%s>"
 #, c-format
 msgstr "Nelze zavøít vektorovou vrstvu <%s>"
@@ -3546,7 +3545,7 @@
 #, c-format
@@ -3566,42 +3565,42 @@
 #, c-format
 msgstr "%s nenalezeno v souèasném mapsetu (%s)"
 #, c-format
 msgstr "Nelze vytvoøit vektorovou mapu <%s>"
 #, fuzzy, c-format
 #, c-format
 msgstr "Nelze otevøít soubor <%s>"
 #, c-format
 msgstr ""
 msgstr ""
 "Velikost souboru 'coor' se li¹í od hodnot ulo¾ených v souboru s topologií"
 #, c-format
 msgstr "Vytvoøte prosím znovu topologii pro vektorovou mapu <%s@%s>"
 #, fuzzy
 msgstr ""
@@ -3652,87 +3651,97 @@
 msgstr "Vektorová mapa <%s> není otevøena na úrovni >= 2"
 #, fuzzy, c-format
 msgstr "nelze èíst soubor s rozsahem hodnot z [%s v %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Nelze inicializovat pj: %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Neznámé klíèové slovo %s v hlavièce vektorové mapy"
 #, c-format
 msgstr "Nelze spustit ovladaè <%s>"
 #, fuzzy, c-format
 msgstr "Neznámý vektorový typ"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nelze vybrat záznam z tabulky <%s> (klíè %s, where %s)"
 #, fuzzy, c-format
 msgstr "Nviz_new_map_obj(): Nepodporovaný datový typ"
 #, fuzzy
 msgstr "Neznámá Location"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nelze nastavit kategorii %d pro (prvek id %d)"
 #, fuzzy, c-format
@@ -3890,59 +3899,54 @@
 msgstr "Nelze otevøít vybrat kurzor: '%s'"
 msgstr "©patné spojení se serverem"
 msgstr "Nelze vytvoøit obsah robrazení"
 msgstr "Nelze definovat novou linii"
 msgstr "Nelze nastavit zaostøení"
 #, c-format
 msgstr "Nesprávná barva pro symbol: '%s', pou¾ívám \"bílá\" jako výchozí"
-#, c-format
-msgstr "Neplatné souøadnice bodu rozhledu, pou¾iji %f,%f"
 msgstr "Maximum povrchù ji¾ naèteno!"
 msgstr "Maximum vektorových linií ji¾ naèteno!"
 #, c-format
 msgstr "Chyba pøi naèítání vektorové mapy <%s>"
 msgstr "Maximum vektorových bodù ji¾ naèteno!"
 msgstr "Maximum 3D rastrových map ji¾ naèteno!"
 #, c-format
 msgstr "Chyba pøi naèítání 3D rastrové mapy <%s>"
@@ -4294,7 +4298,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4302,97 +4306,97 @@
 "Pou¾ití:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "pou¾ít výchozí"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "neplatná mapová projekce\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Nelze alokovat pamì»"
 msgstr ""
 #, fuzzy
 msgstr "stisknìte RETURN pro pokraèování -->"
 msgid ""
@@ -4402,7 +4406,7 @@
 msgstr ""
 msgid ""
@@ -4411,34 +4415,34 @@
 msgstr ""
 msgstr "Promiòte, ale <%s> není platná volba\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4447,20 +4451,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "Prosím, oznamte tuto chybu vývojáøùm GRASSu.\n"
 msgid ""
@@ -4470,31 +4474,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Vytváøení grafu ..."
 #, fuzzy
 msgstr "GISRC - promìnná není nastavena"
 #, python-format
 msgid ""
@@ -4503,98 +4507,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Nápovìda pro pøíkaz [%s] není dostupná\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "nic"
 #, fuzzy
 msgstr "Nelze otevøít doèasný soubor"
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4611,25 +4610,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4792,7 +4791,7 @@
 msgstr "Výøez zamìní výchozí"
 #, c-format
 msgstr "nelze získat informace o historii pro [%s] v mapsetu [%s]"
@@ -5026,12 +5025,12 @@
 msgstr "Barevná ¹kála neodpovídá datùm (mincol=%d, max col=%d"
 #, c-format
 msgstr "Pøekládám barevnou ¹kálu z rastrové mapy <%s>..."
 msgstr "Pohled nebyl ulo¾en tímto programem, mohou se objevit malé neshody"
@@ -5053,22 +5052,32 @@
 msgstr "Bitmapová neshoda"
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr "Rastrová mapa <%s> je mimo souèasný region. Naèítání selhalo."
 msgstr "GS_load_att_map(): Nelze alokovat pamì». Nelze naèíst mapu."
 msgstr "Naèítání selhalo"
 msgstr "Chyba pøi hledání rozsahu hodnot"
@@ -5173,7 +5182,7 @@
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
 msgstr "Neplatné název tabulky vektorové mapy <%s>. Znak <%c> není povolen.\n"
 msgstr "POru¹en soubor pro pøihlá¹ení"
@@ -5834,6 +5843,20 @@
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
 msgstr "Podskupina <%s>skupiny <%s> okazuja na následující rastrové mapy\n"
+#, fuzzy
+#~ msgid "Not enough room in history file to record command line"
+#~ msgstr ""
+#~ "V souboru s historií není dostatek místa, aby pøíkazová øádka mohla být "
+#~ "zaznamenána"
+#, fuzzy
+#~ msgid "Not enough room in history file for command line (truncated)"
+#~ msgstr ""
+#~ "V souboru s historií není dostatek místa pro pøíkazovou øádku (zkráceno)"
+#~ msgid "Invalid view position coordinates, using %f,%f"
+#~ msgstr "Neplatné souøadnice bodu rozhledu, pou¾iji %f,%f"
 #~ msgid "Unknown Location"
 #~ msgstr "Neznámá Location"
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_de.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -11,7 +11,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_de\n"
 "PO-Revision-Date: 2010-07-17 13:25+0200\n"
 "Last-Translator: Robert Nuske <rnuske gwdg.de>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
@@ -63,11 +63,11 @@
 msgstr "Raster Karte"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -76,6 +76,14 @@
 "G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten "
 "Rasterdateien."
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -468,25 +476,25 @@
 #, c-format
 msgstr "Rasterkarte <%s> wurde nicht gefunden"
@@ -737,34 +745,21 @@
 msgstr "Kann den Header der Rasterkarte <%s@%s> nicht öffnen."
 #, fuzzy, c-format
 msgstr "Kann die History-Informationen der Karte [%s] nicht schreiben."
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr ""
-"Nicht genügend Platz in der History-Datei um die Kommandozeile zu speichern."
-#, fuzzy
-msgstr ""
-"Nicht genügend Platz in der History-Datei für die Kommandozeile "
-"(angeschnitten)."
@@ -815,7 +810,7 @@
 #, c-format
@@ -1203,12 +1198,12 @@
 " Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem "
 "derzeitigen GRASS-Fenster."
 #, c-format
 msgstr "Kann das Mapset Element %s (%s) nicht erzeugen: %s"
 #, c-format
 msgstr "Kann auf das Mapset Element %s (%s) nicht zugreifen: %s"
@@ -1751,23 +1746,27 @@
 msgstr "Feld-Trennzeichen"
+msgstr ""
 msgid "Color"
 msgstr "Farben"
 msgstr "Entweder ein Standardfarbname oder ein R:G:B Tripel."
 msgstr "Hintergrundfarbe"
 msgstr "Entweder eine Standard GRASS-Farbe, ein R:G:B-Tripel oder \"none\"."
 msgid "Units"
 msgstr ""
@@ -1802,11 +1801,11 @@
 msgid "SYNOPSIS"
 msgstr "SYNOPSIS"
 msgid "Flags"
 msgstr "Flags"
 msgid "Parameters"
 msgstr "Parameter"
@@ -2289,7 +2288,7 @@
 msgstr "%s komplett. %s"
 msgid ""
@@ -2297,24 +2296,24 @@
 "Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut "
 "bauen oder verschiedene Installationen entwirren."
 #, c-format
 msgstr "MAPSET %s - Zugriff verweigert"
 #, c-format
 msgstr "MAPSET %s nicht gefunden"
 msgstr ""
 "System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() "
 "aufzurufen."
@@ -2507,11 +2506,11 @@
 msgstr ""
 "Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
 msgstr "Kann Datei nicht in den Speicher laden, Datei ist nicht offen."
 msgstr "Vector memory mode wird nicht unterstützt, verwende 'AUTO'."
@@ -2575,11 +2574,11 @@
 msgstr "%s: Fläche %d existiert nicht."
 msgstr "Versuche ein totes Objekt zu löschen"
 msgstr "Versuche lebendes Objekt wiederherzustellen"
 msgstr "Nicht genung Platz im Vektor-Array."
 #, c-format
 msgstr "Die Datenbankverbindung für den Layer <%d> nicht definiert."
@@ -3128,43 +3127,43 @@
 msgstr "Finde Fläche außerhalb nicht existierender Insel"
 msgstr "Registriere Primitive..."
 msgstr "Kann Vektorkarte nicht lesen."
 #, c-format
 msgstr "%d Primitive registriert"
 #, c-format
 msgstr "%d Vertices registriert "
 msgstr "Erzeuge Flächen..."
 #, c-format
 msgstr "%d Flächen angelegt"
 #, c-format
 msgstr "%d Inseln angelegt"
 msgstr "Füge Inseln hinzu..."
 msgstr "Füge Zentroide hinzu..."
@@ -3210,91 +3209,91 @@
 msgstr "Kann die Vektorkarte <%s> nicht lesen."
 #, c-format
 msgstr "Name der Vektorkarte ist nicht SQL kompatibel."
 #, c-format
 msgstr "Kann die Vektorkarte <%s> in <%s> nicht finden."
 #, c-format
 msgstr "Vektorkarte <%s> existiert bereits und wird überschrieben."
 #, c-format
 msgstr "Kann Vektorkarte <%s> nicht löschen."
 #, c-format
 msgstr "Kann die Vektorkarte <%s> nicht nach <%s> kopieren."
 #, c-format
 msgstr "Kann die Tabelle <%s> nicht kopieren."
 #, c-format
 msgstr "Kann keinen Index für die Tabelle <%s>, Schlüssel <%s> erzeugen."
 #, c-format
 msgstr "Kann Tabelle <%s> nicht löschen."
 #, c-format
 msgstr "Ungültiger Name für Vektorkarte <%s>."
 #, c-format
 msgstr "Kann header Datei der Vektorkarte <%s> nicht öffnen."
 #, c-format
 msgstr "Kann die Tabelle <%s> verknüpft mit Vektorkarte <%s> nicht finden."
 #, c-format
 msgstr "Tabelle <%s> verknüpft mit Vektorkarte <%s> existiert nicht."
 #, c-format
 msgstr "Kann das Verzeichnis '%s' nicht öffnen."
 #, c-format
 msgstr "Kann Datei '%s' nicht löschen."
 #, c-format
 msgstr "Kann das Verzeichnis '%s' nicht in '%s' umbenennen."
 #, c-format
 msgstr "Kann das Verzeichnis '%s' nicht löschen."
 #, c-format
 msgstr "Kann Datenbankverknüpfung für Vektorkarte <%s> nicht hinzufügen."
@@ -3304,7 +3303,7 @@
 msgstr "Vektor Karte"
 #, fuzzy, c-format
 msgid ""
@@ -3313,7 +3312,7 @@
 "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte "
 "Überschuss)."
 #, fuzzy, c-format
 msgid ""
@@ -3338,7 +3337,7 @@
 msgstr "Arc Feld < 1"
 #, c-format
 msgstr "Spalte <%s> in Tabelle <%s> nicht gefunden."
@@ -3497,7 +3496,7 @@
 msgstr "Kann Objekt %d der Vektorkarte <%s> nicht wiederherstellen."
 #, c-format
 msgstr "Kann die Vektorkarte <%s> nicht schliessen."
@@ -3549,7 +3548,7 @@
 #, c-format
 msgstr "Kann die Kategorieindexdatei der Vektorkarte <%s> nicht öffnen."
@@ -3569,43 +3568,43 @@
 msgstr "Kann die History-Datei der Vektorkarte <%s> nicht öffnen."
 #, c-format
 msgstr "%s ist nicht im aktuellen Mapset (%s)."
 #, c-format
 msgstr "Kann die Vektorkarte <%s> nicht anlegen."
 #, fuzzy, c-format
 #, c-format
 msgstr "Unable to stat file <%s>"
 #, c-format
 msgstr ""
 msgstr ""
 "Größe der 'coor' Datei unterscheidet sich von dem in der Topologiedatei "
 "gespeicherten Wert."
 #, c-format
 msgstr "Bitte erneuern Sie die Topologie der Vektorkarte <%s@%s>."
 #, fuzzy
 msgstr "Größe"
@@ -3656,87 +3655,97 @@
 msgstr "Vektorkarte <%s> ist nicht auf einem Level >= 2 geöffnet."
 #, fuzzy, c-format
 msgstr "Kann range Datei für [%s in %s] nicht lesen."
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Kann pj nicht initialisieren, wegen: %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "unbekannt Vektor"
 #, c-format
 msgstr "Kann den Treiber <%s> nicht starten."
 #, fuzzy, c-format
 msgstr "Unbekannter Vektortyp."
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "Kann Header-Datei für [%s in %s] nicht erstellen."
 #, fuzzy, c-format
 msgstr "Karte"
 #, fuzzy
 msgstr "unbekannt"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Kann Datei head nicht lesen"
 #, fuzzy, c-format
@@ -3892,59 +3901,54 @@
 msgstr "Kann den Select-Cursor '%s' nicht öffnen."
 msgstr "Schlechte Serveranbindung."
 msgstr "Kann keinen Rendering Kontext erzeugen."
 msgstr "Kann neues Licht nicht definieren."
 msgstr "Kann Focus nicht setzten."
 #, c-format
 msgstr "Ungültige Farbe: (%s), verwendet \"white\" als Standard."
-#, c-format
-msgstr "Ungültige Koordinaten für den Betrachtungspunkt, verwende %f,%f"
 msgstr "Maximale Oberflächenanzahl geladen!"
 msgstr "Maximal Vektorlinienkarten geladen!"
 #, c-format
 msgstr "Fehler beim Laden der Vektorkarte <%s>."
 msgstr "Maximal Vektorpunktkarten geladen!"
 msgstr "Maximale Volumen geladen!"
 #, c-format
 msgstr "Fehler beim Laden der 3D-Rasterkarte <%s>."
 msgstr "Nviz_new_map_obj(): nicht unterstützter Datentyp."
@@ -4296,7 +4300,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4304,97 +4308,97 @@
 "Benutzung:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Zum Akzeptieren der Standardeinstellung"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "Ungültige Projektion\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Kann keinen Speicher für temporäres Bild belegen."
 msgstr ""
 #, fuzzy
 msgstr "RETURN zum Weitermachen drücken -->"
 msgid ""
@@ -4404,7 +4408,7 @@
 msgstr ""
 msgid ""
@@ -4413,34 +4417,34 @@
 msgstr ""
 msgstr "Tut mir leid, <%s> ist keine gültige Option\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4449,20 +4453,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "Bitte unterrichten Sie die GRASS-Entwickler über diesen Fehler.\n"
 msgid ""
@@ -4472,31 +4476,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Erzeuge Graphen..."
 #, fuzzy
 msgstr "GISRC - Variable nicht gesetzt."
 #, python-format
 msgid ""
@@ -4505,98 +4509,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Leider keine Hilfe für den Befehl [%s] verfügbar.\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "nichts"
 #, fuzzy
 msgstr "Kann temporäre Datei nicht öffnen."
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4614,25 +4613,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4803,7 +4802,7 @@
 msgstr "Fenster ersetzt den Standard."
 #, c-format
 msgstr ""
@@ -5042,12 +5041,12 @@
 msgstr ""
 "Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
 #, c-format
 msgstr "Übersetze Farben der Rasterkarte <%s>..."
 msgstr ""
 "View wurde von diesem Programm nicht gespeichert, es können Inkonsistenzen "
@@ -5072,24 +5071,34 @@
 msgstr "Bitmap mismatch"
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr ""
 "Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
 msgstr ""
 "GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
 msgstr "Laden fehlgeschlagen"
 msgstr "Fehler beim Bestimmen des Wertebereichs."
@@ -5201,7 +5210,7 @@
 msgstr ""
 "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
 msgstr "Logindatei kaputt"
@@ -5869,255 +5878,271 @@
 "Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
 #, fuzzy
-msgid "test, gmath"
-msgstr "test, gpde"
+#~ msgstr ""
+#~ "Nicht genügend Platz in der History-Datei um die Kommandozeile zu "
+#~ "speichern."
 #, fuzzy
-msgid ""
-"\n"
-"Keywords:\n"
-msgstr ""
-"\n"
-"Schlüsselwörter:\n"
+#~ msgstr ""
+#~ "Nicht genügend Platz in der History-Datei für die Kommandozeile "
+#~ "(angeschnitten)."
+#~ msgstr "Ungültige Koordinaten für den Betrachtungspunkt, verwende %f,%f"
 #, fuzzy
-msgid "Error writing floating point format file for map <%s>"
-msgstr "Fehler beim Schreiben der Flißekommakarte %s."
+#~ msgid "test, gmath"
+#~ msgstr "test, gpde"
 #, fuzzy
-msgid "Unable to create a new process!"
-msgstr "Kann keinen neuen Prozess erzeugen."
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Schlüsselwörter:\n"
 #, fuzzy
-msgid ""
-"Region for current mapset %s. Run \"g.region\" to fix the current region."
-msgstr ""
-"Region des gegenwärtigen Mapsets %s\n"
-"Führen Sie \"g.region\" aus"
+#~ msgid "Error writing floating point format file for map <%s>"
+#~ msgstr "Fehler beim Schreiben der Flißekommakarte %s."
 #, fuzzy
-msgid "Default region %s"
-msgstr "Standard Region %s"
+#~ msgid "Unable to create a new process!"
+#~ msgstr "Kann keinen neuen Prozess erzeugen."
 #, fuzzy
-msgid "Unable to set region"
-msgstr "Kann %s nicht öffnen."
+#~ msgid ""
+#~ "Region for current mapset %s. Run \"g.region\" to fix the current region."
+#~ msgstr ""
+#~ "Region des gegenwärtigen Mapsets %s\n"
+#~ "Führen Sie \"g.region\" aus"
 #, fuzzy
-msgid "Raster map <%s> - unable to write row %d"
-msgstr "Karte [%s] - Kann Zeile %d nicht schreiben. "
+#~ msgid "Default region %s"
+#~ msgstr "Standard Region %s"
 #, fuzzy
-msgid "Unable to write feature, OGR layer not defined"
-msgstr "Vektor Karte"
+#~ msgid "Unable to set region"
+#~ msgstr "Kann %s nicht öffnen."
 #, fuzzy
-msgid "Failed writing raster map"
-msgstr "Raster Karte"
+#~ msgid "Raster map <%s> - unable to write row %d"
+#~ msgstr "Karte [%s] - Kann Zeile %d nicht schreiben. "
 #, fuzzy
-msgid "Unable to write color file of raster map <%s>"
+#~ msgid "Unable to write feature, OGR layer not defined"
+#~ msgstr "Vektor Karte"
-msgid "Type"
-msgstr "Typ"
+#, fuzzy
+#~ msgid "Failed writing raster map"
+#~ msgstr "Raster Karte"
-msgid "Cannot get layer info"
-msgstr "Kann die Layer-Informationen nicht abfragen."
+#, fuzzy
+#~ msgid "Unable to write color file of raster map <%s>"
-msgid "Cannot open database %s"
-msgstr "Kann Datenbank '%s' nicht öffnen."
+#~ msgid "Type"
+#~ msgstr "Typ"
+#~ msgid "Cannot get layer info"
+#~ msgstr "Kann die Layer-Informationen nicht abfragen."
+#~ msgid "Cannot open database %s"
+#~ msgstr "Kann Datenbank '%s' nicht öffnen."
 #, fuzzy
-msgid "Unable to query drawable"
-msgstr "Kann Datei %s nicht öffnen."
+#~ msgid "Unable to query drawable"
+#~ msgstr "Kann Datei %s nicht öffnen."
 #, fuzzy
-msgid "Failed to initialize Xlib surface"
-msgstr "Kann Datei %s in %s nicht öffnen"
+#~ msgid "Failed to initialize Xlib surface"
+#~ msgstr "Kann Datei %s in %s nicht öffnen"
 #, fuzzy
-msgid "Registering points"
-msgstr "Registriere Linien..."
+#~ msgid "Registering points"
+#~ msgstr "Registriere Linien..."
 #, fuzzy
-msgid "Registered points"
+#~ msgid "Registered points"
 #, fuzzy
-msgid "Registered points (unique coordinates)"
+#~ msgid "Registered points (unique coordinates)"
 #, fuzzy
-msgid "Duplicates"
-msgstr "Doppeltes Ost-Feld"
+#~ msgid "Duplicates"
+#~ msgstr "Doppeltes Ost-Feld"
-msgid "G_malloc: out of memory"
-msgstr "G_malloc: Kein Speicher mehr da."
+#~ msgid "G_malloc: out of memory"
+#~ msgstr "G_malloc: Kein Speicher mehr da."
-msgid "G_calloc: out of memory"
-msgstr "G_calloc: Kein Speicher mehr da."
+#~ msgid "G_calloc: out of memory"
+#~ msgstr "G_calloc: Kein Speicher mehr da."
-msgid "G_realloc: out of memory"
-msgstr "G_realloc: Kein Speicher mehr da."
+#~ msgid "G_realloc: out of memory"
+#~ msgstr "G_realloc: Kein Speicher mehr da."
 #, fuzzy
-msgid "Cannot describe table <%s>"
-msgstr "Kann Tabelle <%s> nicht beschreiben"
+#~ msgid "Cannot describe table <%s>"
+#~ msgstr "Kann Tabelle <%s> nicht beschreiben"
 #, fuzzy
-msgid "Attempt to delete dead line"
-msgstr "Versuch, eine tote Fläche zu löschen"
+#~ msgid "Attempt to delete dead line"
+#~ msgstr "Versuch, eine tote Fläche zu löschen"
 #, fuzzy
-msgid "Unable to connect lines %d,%d"
-msgstr "Kann Datei head nicht lesen"
+#~ msgid "Unable to connect lines %d,%d"
+#~ msgstr "Kann Datei head nicht lesen"
 #, fuzzy
-msgid "Output name '%s' is not valid rast name."
-msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
+#~ msgid "Output name '%s' is not valid rast name."
+#~ msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
 #, fuzzy
-msgid "Output map '%s' is used as input"
-msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
+#~ msgid "Output map '%s' is used as input"
+#~ msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
 #, fuzzy
-msgid "unable to open raster map [%s in %s]"
-msgstr "Kann nicht zum Verzeichnis %s wechseln."
+#~ msgid "unable to open raster map [%s in %s]"
+#~ msgstr "Kann nicht zum Verzeichnis %s wechseln."
-msgid "Insufficent memory for allocation of gaussian"
-msgstr "Ungenügend Speicher zum Allokieren der Gausschen..."
+#~ msgid "Insufficent memory for allocation of gaussian"
+#~ msgstr "Ungenügend Speicher zum Allokieren der Gausschen..."
 #, fuzzy
-msgid "Cannot read topo for line [%d]"
+#~ msgid "Cannot read topo for line [%d]"
 #, fuzzy
-msgid "Can't read header file for [%s in %s]\n"
-msgstr "Kann range Datei für [%s in %s] nicht lesen."
+#~ msgid "Can't read header file for [%s in %s]\n"
+#~ msgstr "Kann range Datei für [%s in %s] nicht lesen."
 #, fuzzy
-msgid "Can't open header file for [%s in %s]"
+#~ msgid "Can't open header file for [%s in %s]"
 #, fuzzy
-msgid "Cannot get field info"
+#~ msgid "Cannot get field info"
 #, fuzzy
-msgid "Cannot open database"
+#~ msgid "Cannot open database"
 #, fuzzy
-msgid "Building topology ...\n"
-msgstr "Bitte Topologie für Vektorkarte <'%s> neu erzeugen\n"
+#~ msgid "Building topology ...\n"
+#~ msgstr "Bitte Topologie für Vektorkarte <'%s> neu erzeugen\n"
-msgid ""
-"\r%d areas built      \n"
-"%d isles built\n"
-msgstr ""
-"\r%d Flächen erstellt \n"
-"%d Inselflächen erstellt\n"
+#~ msgid ""
+#~ "\r%d areas built      \n"
+#~ "%d isles built\n"
+#~ msgstr ""
+#~ "\r%d Flächen erstellt \n"
+#~ "%d Inselflächen erstellt\n"
 #, fuzzy
-msgid "Cannot get column info"
+#~ msgid "Cannot get column info"
 #, fuzzy
-msgid "OGR feature type [%d] not supported"
-msgstr "OGR Feature Typ %d wird nicht unterstützt."
+#~ msgid "OGR feature type [%d] not supported"
+#~ msgstr "OGR Feature Typ %d wird nicht unterstützt."
 #, fuzzy
-msgid "Vect_rewrite_line() for this format/level not supported"
-msgstr "Vect_write_line() wird für dieses Format/Level nicht unterstützt."
+#~ msgid "Vect_rewrite_line() for this format/level not supported"
+#~ msgstr "Vect_write_line() wird für dieses Format/Level nicht unterstützt."
 #, fuzzy
-msgid "Vect_delete_line() for this format/level not supported"
+#~ msgid "Vect_delete_line() for this format/level not supported"
 #, fuzzy
-msgid "Output name '%s' is not valid vector name."
+#~ msgid "Output name '%s' is not valid vector name."
 #, fuzzy
-msgid "Cannot copy vector '%s' to '%s'"
-msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
+#~ msgid "Cannot copy vector '%s' to '%s'"
+#~ msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
 #, fuzzy
-msgid "Cannot open existing vector map <%s>"
+#~ msgid "Cannot open existing vector map <%s>"
 #, fuzzy
-msgid "Cannot delete existing vector <%s>"
+#~ msgid "Cannot delete existing vector <%s>"
 #, fuzzy
-msgid "Cannot open new vector %s"
-msgstr "Kann die Debug-Datei '%s' nicht öffnen."
+#~ msgid "Cannot open new vector %s"
+#~ msgstr "Kann die Debug-Datei '%s' nicht öffnen."
 #, fuzzy
-msgid "Cannot open history file for vector '%s'"
-msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
+#~ msgid "Cannot open history file for vector '%s'"
+#~ msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
 #, fuzzy
-msgid "Could not stat file '%s'"
+#~ msgid "Could not stat file '%s'"
 #, fuzzy
-msgid "Can't open directory %s"
+#~ msgid "Can't open directory %s"
-msgid "Starting lu solver method"
-msgstr "Starte lu-Solver Methode"
+#~ msgid "Starting lu solver method"
+#~ msgstr "Starte lu-Solver Methode"
 #, fuzzy
-msgid "%s - ** illegal name **"
-msgstr ""
-"\n"
-"**<%s> unerlaubter Name **\n"
+#~ msgid "%s - ** illegal name **"
+#~ msgstr ""
+#~ "\n"
+#~ "**<%s> unerlaubter Name **\n"
 #, fuzzy
-msgid "Gauss-Seidel -- iteration %5i error %g\n"
-msgstr "sparse SOR -- Durchlauf %5i Fehler %g\n"
+#~ msgid "Gauss-Seidel -- iteration %5i error %g\n"
+#~ msgstr "sparse SOR -- Durchlauf %5i Fehler %g\n"
 #, fuzzy
-msgid "No such graphics monitor as <%s>.\n"
-msgstr "Fehler - keine Antwort vom Graphikmonitor <%s>.\n"
+#~ msgid "No such graphics monitor as <%s>.\n"
+#~ msgstr "Fehler - keine Antwort vom Graphikmonitor <%s>.\n"
 #, fuzzy
-msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-msgstr "Bitte benutzen Sie \"d.mon\", um einen Graphik-Monitor auszuwählen."
+#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+#~ msgstr "Bitte benutzen Sie \"d.mon\", um einen Graphik-Monitor auszuwählen."
 #, fuzzy
-msgid "Can't stat %s\n"
-msgstr "eine Liste %s ein."
+#~ msgid "Can't stat %s\n"
+#~ msgstr "eine Liste %s ein."
-msgid "Error - Monitor <%s> is in use.\n"
-msgstr "Fehler - Monitor <%s> wird bereits benutzt.\n"
+#~ msgid "Error - Monitor <%s> is in use.\n"
+#~ msgstr "Fehler - Monitor <%s> wird bereits benutzt.\n"
-msgid "Error - Monitor <%s> is in use by %s.\n"
-msgstr "Fehler - Monitor <%s> wird bereits von %s benutzt.\n"
+#~ msgid "Error - Monitor <%s> is in use by %s.\n"
+#~ msgstr "Fehler - Monitor <%s> wird bereits von %s benutzt.\n"
-msgid "Error - Could not complete locking process for monitor <%s>.\n"
-msgstr "Fehler - Kann den Locking-Prozess für Monitor <%s> nicht beenden.\n"
+#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
+#~ msgstr "Fehler - Kann den Locking-Prozess für Monitor <%s> nicht beenden.\n"
-msgid "Error - Can't set up pipe to graphics device.\n"
-msgstr "Fehler - Kann keine Pipe zum Graphik-Gerät aufbauen.\n"
+#~ msgid "Error - Can't set up pipe to graphics device.\n"
+#~ msgstr "Fehler - Kann keine Pipe zum Graphik-Gerät aufbauen.\n"
-msgid "Error - Graphics monitor <%s> not running!\n"
-msgstr "Fehler - Graphik-Monitor <%s> läuft nicht!\n"
+#~ msgid "Error - Graphics monitor <%s> not running!\n"
+#~ msgstr "Fehler - Graphik-Monitor <%s> läuft nicht!\n"
 #, fuzzy
-msgid "Please start graphics monitor <%s>.\n"
+#~ msgid "Please start graphics monitor <%s>.\n"
-msgid "Not connected...\n"
-msgstr "Nicht verbunden...\n"
+#~ msgid "Not connected...\n"
+#~ msgstr "Nicht verbunden...\n"
-msgid "Couldn't connect to monitor. Will try once more.\n"
-msgstr ""
-"Kann nicht mit einem Monitor verbinden. Versuche es noch ein weiteres Mal.\n"
+#~ msgid "Couldn't connect to monitor. Will try once more.\n"
+#~ msgstr ""
+#~ "Kann nicht mit einem Monitor verbinden. Versuche es noch ein weiteres "
+#~ "Mal.\n"
 #~ msgstr "Unbekannte Location"
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_el.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_el\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2008-10-16 11:25+0300\n"
 "Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
 "Language-Team: Báóßëåéïò Áíôùíßïõ <grass-translations at lists.osgeo.org>\n"
@@ -60,11 +60,11 @@
 msgid "Unable to write quant rules for raster map <%s>"
 msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
-#: ../lib/raster/set_window.c:46
+#: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
 msgstr ""
-#: ../lib/raster/set_window.c:117
+#: ../lib/raster/set_window.c:123
 #, fuzzy
 msgid ""
 "Rast_set_read_window(): projection/zone differs from that of currently open "
@@ -73,6 +73,14 @@
 "G_set_window(): ç ðñïâïëÞ/æþíç äéáöÝñåéò áðü ôïõò õöéóôÜìåíá áíïé÷ôïõ ñáóôåñ "
 "÷Üñôåò"
+#: ../lib/raster/set_window.c:150
+msgid "Input window changed while maps are open for read"
+msgstr ""
+#: ../lib/raster/set_window.c:168
+msgid "Output window changed while maps are open for write"
+msgstr ""
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
@@ -465,25 +473,25 @@
 #: ../lib/raster/opencell.c:779 ../lib/raster/opencell.c:831
 #: ../lib/manage/do_rename.c:53 ../lib/manage/do_remove.c:53
 #: ../lib/gis/legal_name.c:91 ../lib/gis/legal_name.c:94
-#: ../lib/rst/interp_float/output2d.c:228
-#: ../lib/rst/interp_float/output2d.c:309
-#: ../lib/rst/interp_float/output2d.c:393
-#: ../lib/rst/interp_float/output2d.c:457
-#: ../lib/rst/interp_float/output2d.c:485
-#: ../lib/rst/interp_float/output2d.c:513
-#: ../lib/rst/interp_float/output2d.c:543
-#: ../lib/rst/interp_float/resout2d.c:188
-#: ../lib/rst/interp_float/resout2d.c:236
-#: ../lib/rst/interp_float/resout2d.c:279
-#: ../lib/rst/interp_float/resout2d.c:319
-#: ../lib/rst/interp_float/resout2d.c:378
-#: ../lib/rst/interp_float/resout2d.c:405
-#: ../lib/rst/interp_float/resout2d.c:429
-#: ../lib/rst/interp_float/resout2d.c:455 ../lib/ogsf/gsd_legend.c:239
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426 ../lib/ogsf/gsd_legend.c:239
 #: ../lib/ogsf/Gs3.c:127 ../lib/ogsf/Gs3.c:200 ../lib/ogsf/Gs3.c:283
 #: ../lib/ogsf/Gs3.c:356 ../lib/ogsf/Gs3.c:470 ../lib/ogsf/Gs3.c:565
-#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:757
-#: ../lib/ogsf/Gs3.c:826
+#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:758
+#: ../lib/ogsf/Gs3.c:828
 #, c-format
 msgid "Raster map <%s> not found"
 msgstr "Ï ÷Üñôçò raster  <%s> äåí âñÝèçêå"
@@ -749,32 +757,21 @@
 msgstr ""
 "Áäõíáìßá áíïßãìáôïò êåöáëéêïý (header) áñ÷åßïõ ãéá ôïí ñÜóôåñ ÷Üñôç <%s@%s>"
-#: ../lib/raster/history.c:115
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, fuzzy, c-format
 msgid "Unable to get history information for <%s@%s>"
 msgstr "äåí åßíáé äõíáôÞ ç åããñáöÞ ôïõ éóôïñéêïý ãéá [%s]"
-#: ../lib/raster/history.c:143
+#: ../lib/raster/history.c:162
 #, fuzzy, c-format
 msgid "Unable to write history information for <%s>"
-#: ../lib/raster/history.c:184
+#: ../lib/raster/history.c:235
 #, c-format
 msgid "generated by %s"
 msgstr ""
-#: ../lib/raster/history.c:232
-#, fuzzy
-msgid "Not enough room in history file to record command line"
-msgstr ""
-"Äåí õðÜñ÷åé áñêåôüò ÷þñïò óôï áñ÷åßï éóôïñéêïý ãéá åããñáöÞ åíôïëÞò ãñáììÞò"
-#: ../lib/raster/history.c:254
-#, fuzzy
-msgid "Not enough room in history file for command line (truncated)"
-msgstr "Not enough room in history file to record command line (ðåñéêïðÞ)."
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
 #: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
 #: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
@@ -825,7 +822,7 @@
 #: ../lib/manage/do_rename.c:37 ../lib/manage/do_remove.c:37
 #: ../lib/vector/Vlib/legal_vname.c:115 ../lib/vector/Vlib/legal_vname.c:118
-#: ../lib/vector/Vlib/map.c:404 ../lib/vector/Vlib/open.c:197
+#: ../lib/vector/Vlib/map.c:403 ../lib/vector/Vlib/open.c:197
 #: ../lib/ogsf/Gv3.c:58 ../lib/ogsf/Gp3.c:58
 #, c-format
 msgid "Vector map <%s> not found"
@@ -1217,12 +1214,12 @@
 msgstr ""
 " Ìüíï %d%% ôïõ ðáñáèýñïõ óþèçêò \"%s\" åðéêáëýðôåé ôï ôñÝ÷ïí GRASS ðáñÜèõñï."
-#: ../lib/gis/mapset_msc.c:60
+#: ../lib/gis/mapset_msc.c:61
 #, fuzzy, c-format
 msgid "Unable to make mapset element %s (%s): %s"
 msgstr "Áäõíáìßá äçìéïõñãßáò mapset óôïé÷åßïõ %s (%s)"
-#: ../lib/gis/mapset_msc.c:64
+#: ../lib/gis/mapset_msc.c:65
 #, fuzzy, c-format
 msgid "Unable to access mapset element %s (%s): %s"
@@ -1767,23 +1764,27 @@
 msgid "Field separator"
 msgstr "Äéá÷ùñéóôÞò ðåäßùí (ð.÷. , .  tab)"
-#: ../lib/gis/parser_standard_options.c:455
+#: ../lib/gis/parser_standard_options.c:445
+msgid "Special characters: newline, space, comma, tab"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:456
 msgid "Color"
 msgstr "×ñþìá"
-#: ../lib/gis/parser_standard_options.c:456
+#: ../lib/gis/parser_standard_options.c:457
 msgid "Either a standard color name or R:G:B triplet"
 msgstr "Åßôå Ýíá óôáíôáñ üíïìá ÷ñþìáôïò Þ óõíäõáóìüò R:G:B"
-#: ../lib/gis/parser_standard_options.c:465
+#: ../lib/gis/parser_standard_options.c:466
 msgid "Background color"
 msgstr "×ñþìá öüíôïõ"
-#: ../lib/gis/parser_standard_options.c:467
+#: ../lib/gis/parser_standard_options.c:468
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
 msgstr "Äþóôå Ýíá óôáíôáñ ÷ñþìá GRASS, óõíäõáóìü R:G:B Þ \"none\""
-#: ../lib/gis/parser_standard_options.c:478
+#: ../lib/gis/parser_standard_options.c:479
 msgid "Units"
 msgstr ""
@@ -1818,11 +1819,11 @@
 msgid "SYNOPSIS"
 msgstr "ÓÕÍÏØÇ"
-#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:146
+#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:147
 msgid "Flags"
 msgstr ""
-#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:156
+#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:157
 msgid "Parameters"
 msgstr "ÐáñÜìåôñïé"
@@ -2309,30 +2310,30 @@
 msgid "%s complete. %s"
 msgstr "%s óõìðëçñùìÝíï. %s"
-#: ../lib/gis/gisinit.c:55 ../lib/gis/gisinit.c:90
+#: ../lib/gis/gisinit.c:56 ../lib/gis/gisinit.c:91
 msgid ""
 "Incompatible library version for module. You need to rebuild GRASS or "
 "untangle multiple installations."
 msgstr ""
-#: ../lib/gis/gisinit.c:65
+#: ../lib/gis/gisinit.c:66
 #, c-format
 msgid "MAPSET %s - permission denied"
 msgstr "MAPSET %s - äåí åðéôñÝðåôáé ç ðñüóâáóç"
-#: ../lib/gis/gisinit.c:68
+#: ../lib/gis/gisinit.c:69
 #, c-format
 msgid "MAPSET %s not found"
 msgstr "MAPSET %s äåí âñÝèçêå"
-#: ../lib/gis/gisinit.c:107
+#: ../lib/gis/gisinit.c:108
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
 msgstr ""
 "Ôï óýóôçìá äåí Ý÷åé áñ÷éêïðïéçèåß. Ï ðñïãñáììáôéóôÞò îÝ÷áóåé íá êáëÝóåé "
 "G_gisinit()."
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/vector/Vlib/ascii.c:187 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/ascii.c:200 ../lib/vector/Vlib/line.c:50
 #: ../lib/vector/neta/articulation_point.c:60
 #: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
 #: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
@@ -2521,12 +2522,12 @@
 msgid "Writing to file loaded to memory not supported"
 msgstr ""
-#: ../lib/vector/diglib/file.c:204
+#: ../lib/vector/diglib/file.c:205
 #, fuzzy
 msgid "Unable to load file to memory, file not open"
 msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ðñïóùñéíÞ åéêüíá"
-#: ../lib/vector/diglib/file.c:219
+#: ../lib/vector/diglib/file.c:220
 msgid "Vector memory mode not supported, using 'AUTO'"
 msgstr ""
@@ -2590,11 +2591,11 @@
 msgid "%s: Area %d does not exist"
 msgstr "%s: ÅðéäÜíåéá %d äåí õðÜñ÷åé"
-#: ../lib/vector/Vlib/write_nat.c:675 ../lib/vector/Vlib/write_ogr.c:298
+#: ../lib/vector/Vlib/write_nat.c:670 ../lib/vector/Vlib/write_ogr.c:298
 msgid "Attempt to delete dead feature"
 msgstr "ÐñïóðÜèåéá äéáãñáöÞò ëÜèïò óôïé÷åßùí"
-#: ../lib/vector/Vlib/write_nat.c:920
+#: ../lib/vector/Vlib/write_nat.c:910
 msgid "Attempt to restore alive feature"
 msgstr "ÐñïóðÜèåéá áðïêáôÜóôáóçò óùóôþí óôïé÷åßùí"
@@ -2735,21 +2736,21 @@
 msgid "Not enough space in vector array"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:313
-#: ../lib/vector/Vlib/map.c:440 ../lib/vector/Vlib/map.c:552
-#: ../lib/vector/Vlib/map.c:670 ../lib/vector/Vlib/map.c:768
+#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:312
+#: ../lib/vector/Vlib/map.c:439 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:669 ../lib/vector/Vlib/map.c:767
 #: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:347
-#: ../lib/vector/Vlib/ascii.c:301 ../lib/vector/Vlib/write_ogr.c:118
+#: ../lib/vector/Vlib/ascii.c:314 ../lib/vector/Vlib/write_ogr.c:118
 #: ../lib/rst/interp_float/vinput2d.c:79
 #, c-format
 msgid "Database connection not defined for layer %d"
 msgstr ""
 "Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
-#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:342
-#: ../lib/vector/Vlib/map.c:481 ../lib/vector/Vlib/map.c:703
+#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:341
+#: ../lib/vector/Vlib/map.c:480 ../lib/vector/Vlib/map.c:702
 #: ../lib/vector/Vlib/net.c:182 ../lib/vector/Vlib/net.c:352
-#: ../lib/vector/Vlib/ascii.c:313 ../lib/vector/Vlib/write_ogr.c:375
+#: ../lib/vector/Vlib/ascii.c:326 ../lib/vector/Vlib/write_ogr.c:375
 #: ../lib/vector/neta/utils.c:116 ../lib/vector/neta/timetables.c:133
 #: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/copy_tab.c:105
 #: ../lib/db/dbmi_client/copy_tab.c:126 ../lib/db/dbmi_client/db.c:46
@@ -3149,45 +3150,45 @@
 msgid "Request to find area outside nonexistent isle"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:523
+#: ../lib/vector/Vlib/build_nat.c:525
 #, fuzzy
 msgid "Registering primitives..."
 msgstr "ÅããñáöÞ áñ÷éêÜ: "
-#: ../lib/vector/Vlib/build_nat.c:532
+#: ../lib/vector/Vlib/build_nat.c:534
 msgid "Unable to read vector map"
 msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
-#: ../lib/vector/Vlib/build_nat.c:576
+#: ../lib/vector/Vlib/build_nat.c:578
 #, c-format
 msgid "%d primitives registered"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:577
+#: ../lib/vector/Vlib/build_nat.c:579
 #, c-format
 msgid "%d vertices registered"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:588
+#: ../lib/vector/Vlib/build_nat.c:590
 #, fuzzy
 msgid "Building areas..."
 msgstr "Äçìéïõñãßá åðéöáíåéþí"
-#: ../lib/vector/Vlib/build_nat.c:611
+#: ../lib/vector/Vlib/build_nat.c:613
 #, fuzzy, c-format
 msgid "%d areas built"
 msgstr "ÅðéöÜíåéåò äçìéïõñãÞèçêáí"
-#: ../lib/vector/Vlib/build_nat.c:612
+#: ../lib/vector/Vlib/build_nat.c:614
 #, fuzzy, c-format
 msgid "%d isles built"
 msgstr "Íçóßäåò äçìéïõñãÞèçêáí"
-#: ../lib/vector/Vlib/build_nat.c:621
+#: ../lib/vector/Vlib/build_nat.c:623
 msgid "Attaching islands..."
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:636
+#: ../lib/vector/Vlib/build_nat.c:638
 msgid "Attaching centroids..."
 msgstr ""
@@ -3234,96 +3235,96 @@
 msgid "Unable to read vector map <%s>"
 msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/map.c:242 ../lib/vector/Vlib/map.c:386
-#: ../lib/vector/Vlib/open.c:692
+#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:385
+#: ../lib/vector/Vlib/open.c:691
 #, c-format
 msgid "Vector map name is not SQL compliant"
 msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò äåí åßíáé óõìâáôüò ìå SQL"
-#: ../lib/vector/Vlib/map.c:246
+#: ../lib/vector/Vlib/map.c:245
 #, c-format
 msgid "Unable to find vector map <%s> in <%s>"
 msgstr "Áäõíáìßá áíôéãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s> óå <%s>"
-#: ../lib/vector/Vlib/map.c:258 ../lib/vector/Vlib/map.c:390
-#: ../lib/vector/Vlib/open.c:699
+#: ../lib/vector/Vlib/map.c:257 ../lib/vector/Vlib/map.c:389
+#: ../lib/vector/Vlib/open.c:698
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr ""
 "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
-#: ../lib/vector/Vlib/map.c:262 ../lib/vector/Vlib/open.c:704
+#: ../lib/vector/Vlib/map.c:261 ../lib/vector/Vlib/open.c:703
 #, c-format
 msgid "Unable to delete vector map <%s>"
 msgstr "Áäõíáìßá äéáãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/map.c:282 ../lib/vector/Vlib/map.c:408
+#: ../lib/vector/Vlib/map.c:281 ../lib/vector/Vlib/map.c:407
 #, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:457
-#: ../lib/vector/Vlib/map.c:695 ../lib/vector/Vlib/map.c:802
+#: ../lib/vector/Vlib/map.c:330 ../lib/vector/Vlib/map.c:456
+#: ../lib/vector/Vlib/map.c:694 ../lib/vector/Vlib/map.c:801
 #, c-format
 msgid "Unable to copy table <%s>"
 msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
-#: ../lib/vector/Vlib/map.c:347 ../lib/vector/Vlib/map.c:486
-#: ../lib/vector/Vlib/map.c:708
+#: ../lib/vector/Vlib/map.c:346 ../lib/vector/Vlib/map.c:485
+#: ../lib/vector/Vlib/map.c:707
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
-#: ../lib/vector/Vlib/map.c:471 ../lib/vector/Vlib/map.c:572
+#: ../lib/vector/Vlib/map.c:470 ../lib/vector/Vlib/map.c:571
 #, c-format
 msgid "Unable to delete table <%s>"
 msgstr "Áäõíáìßá äéáãñáöÞò ðßíáêá <%s>"
-#: ../lib/vector/Vlib/map.c:526
+#: ../lib/vector/Vlib/map.c:525
 #, c-format
 msgid "Invalid vector map name <%s>"
 msgstr "ËÜèïò üíïìá äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/map.c:540
+#: ../lib/vector/Vlib/map.c:539
 #, c-format
 msgid "Unable to open header file for vector map <%s>"
 msgstr "Áäõíáìßá áíïßãìáôïò header áñ÷åßïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/map.c:562
+#: ../lib/vector/Vlib/map.c:561
 #, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
 msgstr ""
 "Áäõíáìßá åýñåóçò ôïõ ðßíáêá <%s> ðïõ åßíáé óõíäåäåìÝíïò ìå ôïí äéáíõóìáôéêü "
 "÷Üñôç <%s>"
-#: ../lib/vector/Vlib/map.c:579
+#: ../lib/vector/Vlib/map.c:578
 #, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
 msgstr ""
 "Ï ðßíáêáò <%s> ðïõ åßíáé óõíäåäåìÝíïò ìå ôïí äéáíõóìáôéêü ÷Üñôç <%s> äåí "
 "õðÜñ÷åé"
-#: ../lib/vector/Vlib/map.c:592
+#: ../lib/vector/Vlib/map.c:591
 #, c-format
 msgid "Unable to open directory '%s'"
 msgstr "Áäõíáìßá áíïßãìáôïò êáôáëüãïõ óõóôÞìáôïò '%s'"
-#: ../lib/vector/Vlib/map.c:606
+#: ../lib/vector/Vlib/map.c:605
 #, c-format
 msgid "Unable to delete file '%s'"
 msgstr "Áäõíáìßá äéáãñáöÞò áñ÷åßïõ '%s'"
-#: ../lib/vector/Vlib/map.c:623
+#: ../lib/vector/Vlib/map.c:622
 #, c-format
 msgid "Unable to rename directory '%s' to '%s'"
 msgstr "Áäõíáìßá ìåôïíïìáóßáò êáôáëüãïõ óõóôÞìáôïò '%s' óå '%s'"
-#: ../lib/vector/Vlib/map.c:631
+#: ../lib/vector/Vlib/map.c:630
 #, c-format
 msgid "Unable to remove directory '%s'"
 msgstr "Áäõíáìßá ìåôáöïñÜò êáôáëüãïõ óõóôÞìáôïò '%s'"
-#: ../lib/vector/Vlib/map.c:686 ../lib/vector/Vlib/map.c:787
+#: ../lib/vector/Vlib/map.c:685 ../lib/vector/Vlib/map.c:786
 #, c-format
 msgid "Unable to add database link for vector map <%s>"
 msgstr ""
@@ -3334,7 +3335,7 @@
 msgid "Unable to open coor file for vector map <%s>"
 msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/open_nat.c:155
+#: ../lib/vector/Vlib/open_nat.c:154
 #, fuzzy, c-format
 msgid ""
 "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
@@ -3343,7 +3344,7 @@
 "Ôá áñ÷åßá óõíôåôáãìÝíùí (coor) ôùí äéáíõóìáôéêþí ÷áñôþí <%s@%s> åßíáé "
 "ìåãáëýôåñá áðü üóï èá Ýðñåðå (%ld bytes excess)"
-#: ../lib/vector/Vlib/open_nat.c:159
+#: ../lib/vector/Vlib/open_nat.c:158
 #, fuzzy, c-format
 msgid ""
 "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
@@ -3368,7 +3369,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:204
-#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:488
+#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:501
 #, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr ""
@@ -3523,7 +3524,7 @@
 msgid "Unable to restore feature %d from vector map <%s>"
 msgstr "Unable to restore feature %d from vector map <%s>"
-#: ../lib/vector/Vlib/close.c:140
+#: ../lib/vector/Vlib/close.c:139
 #, c-format
 msgid "Unable to close vector <%s>"
 msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ äéáíýóìáôïò <%s>"
@@ -3576,7 +3577,7 @@
 msgid "Unable to open spatial index file for vector map <%s>"
 msgstr "Áäõíáìßá áíïßãìáôïò ôïõ õðïìíÞìáôïò ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:511
+#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:510
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
@@ -3596,41 +3597,41 @@
 msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:683
+#: ../lib/vector/Vlib/open.c:682
 #, c-format
 msgid "%s is not in the current mapset (%s)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:721
+#: ../lib/vector/Vlib/open.c:720
 #, c-format
 msgid "Unable to create vector map <%s>"
 msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/open.c:731
+#: ../lib/vector/Vlib/open.c:730
 #, fuzzy, c-format
 msgid "Unable to open history file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:783
+#: ../lib/vector/Vlib/open.c:782
 #, c-format
 msgid "Unable to stat file <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:842
+#: ../lib/vector/Vlib/open.c:841
 #, c-format
 msgid "unknown %d (update Vect_maptype_info)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:918
+#: ../lib/vector/Vlib/open.c:916
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:929 ../lib/vector/Vlib/open.c:1024
+#: ../lib/vector/Vlib/open.c:927 ../lib/vector/Vlib/open.c:1021
 #, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
 msgstr "Ðáñáêáëþ îáíáöôéÜîôå ôçí ôïðïëïãßá ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s@%s>"
-#: ../lib/vector/Vlib/open.c:1013
+#: ../lib/vector/Vlib/open.c:1010
 msgid "Size of 'coor' file differs from value saved in sidx file"
 msgstr ""
@@ -3675,87 +3676,97 @@
 msgid "Vector map <%s> is not open on level >= 2"
 msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé áíïéêôüò óå åðßðåäï >= 2"
-#: ../lib/vector/Vlib/ascii.c:77
+#: ../lib/vector/Vlib/ascii.c:80
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
 msgstr "Äåí åßíáé äõíáôÞ ç áíÜãíùóç ôïõ åýñïõò ôïõ áñ÷åßïõ ãéá [%s óå %s]"
-#: ../lib/vector/Vlib/ascii.c:115
+#: ../lib/vector/Vlib/ascii.c:118
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
-#: ../lib/vector/Vlib/ascii.c:128
+#: ../lib/vector/Vlib/ascii.c:131
 msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:138
+#: ../lib/vector/Vlib/ascii.c:142
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
-#: ../lib/vector/Vlib/ascii.c:169
+#: ../lib/vector/Vlib/ascii.c:146
+#, fuzzy, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr "Áäýíáìßá Ýíáñîçò pj åîáéôßáò: %s"
+#: ../lib/vector/Vlib/ascii.c:149
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:182
 msgid "End of ASCII file reached before end of categories"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:179
+#: ../lib/vector/Vlib/ascii.c:192
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
-#: ../lib/vector/Vlib/ascii.c:222
+#: ../lib/vector/Vlib/ascii.c:235
 #, c-format
 msgid ""
 "Unexpected data in vector head:\n"
 "[%s]"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:256
+#: ../lib/vector/Vlib/ascii.c:269
 #, c-format
 msgid "Unknown keyword <%s> in vector head"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:307 ../lib/db/dbmi_client/copy_tab.c:100
+#: ../lib/vector/Vlib/ascii.c:320 ../lib/db/dbmi_client/copy_tab.c:100
 #: ../lib/db/dbmi_client/copy_tab.c:120 ../lib/db/dbmi_client/db.c:41
 #, c-format
 msgid "Unable to start driver <%s>"
 msgstr "Áäõíáìßá åêêßíçóçò ôïõ ïäçãïý <%s>"
-#: ../lib/vector/Vlib/ascii.c:413
+#: ../lib/vector/Vlib/ascii.c:426
 #, fuzzy, c-format
 msgid "Uknown feature type %d"
 msgstr "¶ãíùóôï ôýðïò äéáíýóìáôïò"
-#: ../lib/vector/Vlib/ascii.c:453
+#: ../lib/vector/Vlib/ascii.c:466
 #, c-format
 msgid "Feature has more categories. Only first category (%d) is exported."
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:463
+#: ../lib/vector/Vlib/ascii.c:476
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
 msgstr "Áäõíáìßá åðéëïãÞò ôçò åããñáöÞò <%s> (êëåéäß %s, üðïõ %s)"
-#: ../lib/vector/Vlib/ascii.c:490
+#: ../lib/vector/Vlib/ascii.c:503
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
 msgstr "Nviz_new_map_obj(): ï ôýðïò äåäïìÝíùí äåí õðïóôçñßæåôáé"
-#: ../lib/vector/Vlib/ascii.c:570
+#: ../lib/vector/Vlib/ascii.c:583
 #, fuzzy
 msgid "Unknown format"
 msgstr "¶ãíùóôïò ôåëåóôÞò"
-#: ../lib/vector/Vlib/ascii.c:579
+#: ../lib/vector/Vlib/ascii.c:592
 msgid "Topology not available, unable to process areas"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:592
+#: ../lib/vector/Vlib/ascii.c:605
 #, fuzzy, c-format
 msgid "Unable to get boundary of area id %d"
 msgstr "Áäõíáìßá êáèïñéóìïý êáôçãïñßáò %d ãéá ôç ãñáììÞ %d"
-#: ../lib/vector/Vlib/ascii.c:604
+#: ../lib/vector/Vlib/ascii.c:617
 #, fuzzy, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
@@ -3911,59 +3922,54 @@
 msgid "Unable to open select cursor: %s"
 msgstr "Áäõíáìßá áíïßãìáôïò êÝñóïñá '%s'"
-#: ../lib/nviz/render.c:108
+#: ../lib/nviz/render.c:104
 msgid "Bad server connection"
 msgstr "ÊáêÞ óýíäåóç ìå ôïí åîõðçñåôçôÞ"
-#: ../lib/nviz/render.c:117
+#: ../lib/nviz/render.c:113
 msgid "Unable to create rendering context"
 msgstr "Áäõíáìßá äçìéïõñãßáò rendering"
-#: ../lib/nviz/lights.c:144
+#: ../lib/nviz/lights.c:174
 msgid "Unable to define new light"
 msgstr "Áäõíáìßá åýñåóçò íÝïõ öùôüò"
-#: ../lib/nviz/position.c:50
+#: ../lib/nviz/position.c:56
 msgid "Unable to set focus"
 msgstr "Áäõíáìßá focus"
-#: ../lib/nviz/nviz.c:78
+#: ../lib/nviz/nviz.c:105
 #, c-format
 msgid "Invalid color (%s), using \"white\" as default"
 msgstr "ÅóöáëìÝíï ÷ñþìá (%s), ÷ñÞóç \"white\" ùò ðñïåðéëïãÞ"
-#: ../lib/nviz/change_view.c:108
-#, c-format
-msgid "Invalid view position coordinates, using %f,%f"
-msgstr "ËÜèïò óõíôåôáãìÝíåò üøçò, ÷ñÞóç %f,%f"
-#: ../lib/nviz/map_obj.c:65
+#: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
 msgstr "Öïñôþèçêáí ïé ìÝãéóôåò åðéöÜíåéåò!"
-#: ../lib/nviz/map_obj.c:94
+#: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
 msgstr "Öïñôþèçêáí ïé ìÝãéóôïé äéáíõóìáôéêïß ÷Üñôåò!"
-#: ../lib/nviz/map_obj.c:103 ../lib/nviz/map_obj.c:134
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, c-format
 msgid "Error loading vector map <%s>"
 msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/nviz/map_obj.c:122
+#: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
 msgstr "Öïñôþèçêáí ï ìÝãéóôïò áñéèìüò ÷áñôþí óçìåßùí!"
-#: ../lib/nviz/map_obj.c:149
+#: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
 msgstr "Öïñôþèçêáí ï ìÝãéóôïò áñéèìüò üãêùí!"
-#: ../lib/nviz/map_obj.c:158
+#: ../lib/nviz/map_obj.c:152
 #, c-format
 msgid "Error loading 3d raster map <%s>"
 msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ 3Ä ñáóôåñ ÷Üñôç <%s>"
-#: ../lib/nviz/map_obj.c:166
+#: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
@@ -4315,7 +4321,7 @@
 msgid "The total sum of the water budget is significant larger then 0: %g\n"
 msgstr ""
-#: ../lib/init/grass.py:145
+#: ../lib/init/grass.py:146
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4323,97 +4329,97 @@
 "×ñÞóç:\n"
-#: ../lib/init/grass.py:147
+#: ../lib/init/grass.py:148
 msgid "print this help message"
 msgstr ""
-#: ../lib/init/grass.py:148
+#: ../lib/init/grass.py:149
 msgid "show version information and exit"
 msgstr ""
-#: ../lib/init/grass.py:149
+#: ../lib/init/grass.py:150
 msgid "create given mapset if it doesn't exist"
 msgstr ""
-#: ../lib/init/grass.py:150
+#: ../lib/init/grass.py:151
 msgid "use text based interface"
 msgstr ""
-#: ../lib/init/grass.py:151 ../lib/init/grass.py:153 ../lib/init/grass.py:155
+#: ../lib/init/grass.py:152 ../lib/init/grass.py:154 ../lib/init/grass.py:156
 #, fuzzy
 msgid "and set as default"
 msgstr "ãéá íá áðïäåêôåßôå ôï ðñïêáèïñéóìÝíï"
-#: ../lib/init/grass.py:152
+#: ../lib/init/grass.py:153
 msgid "use graphical user interface ($DEFAULT_GUI by default)"
 msgstr ""
-#: ../lib/init/grass.py:154
+#: ../lib/init/grass.py:155
 msgid "use wxPython based graphical user interface"
 msgstr ""
-#: ../lib/init/grass.py:157
+#: ../lib/init/grass.py:158
 msgid "initial database (path to GIS data)"
 msgstr ""
-#: ../lib/init/grass.py:158
+#: ../lib/init/grass.py:159
 #, fuzzy
 msgid "initial location"
 msgstr ""
 "\n"
 "ËáíèáóìÝíç ðñïâïëÞ\n"
-#: ../lib/init/grass.py:159
+#: ../lib/init/grass.py:160
 msgid "initial mapset"
 msgstr ""
-#: ../lib/init/grass.py:160
+#: ../lib/init/grass.py:161
 msgid "fully qualified initial mapset directory"
 msgstr ""
-#: ../lib/init/grass.py:161
+#: ../lib/init/grass.py:162
 msgid "Environment variables relevant for startup"
 msgstr ""
-#: ../lib/init/grass.py:162
+#: ../lib/init/grass.py:163
 msgid "select GUI (text, gui, wxpython)"
 msgstr ""
-#: ../lib/init/grass.py:163
+#: ../lib/init/grass.py:164
 msgid "set wish shell name to override 'wish'"
 msgstr ""
-#: ../lib/init/grass.py:164
+#: ../lib/init/grass.py:165
 msgid "set html web browser for help pages"
 msgstr ""
-#: ../lib/init/grass.py:165
+#: ../lib/init/grass.py:166
 msgid "set additional path(s) to local GRASS modules"
 msgstr ""
-#: ../lib/init/grass.py:166
+#: ../lib/init/grass.py:167
 msgid "shell script to be processed as batch job"
 msgstr ""
-#: ../lib/init/grass.py:167
+#: ../lib/init/grass.py:168
 msgid "set python shell name to override 'python'"
 msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:188
 #, fuzzy
 msgid "Unable to create temporary directory! Exiting."
-#: ../lib/init/grass.py:357
+#: ../lib/init/grass.py:356
 msgid "Searched for a web browser, but none found"
 msgstr ""
-#: ../lib/init/grass.py:376
+#: ../lib/init/grass.py:375
 #, fuzzy
 msgid "Hit RETURN to continue"
 msgstr "ÐáôÞóôå RETURN ãéá óõíÝ÷åéá -->"
-#: ../lib/init/grass.py:405
+#: ../lib/init/grass.py:404
 msgid ""
 "The python command does not work as expected!\n"
 "Please check your GRASS_PYTHON environment variable.\n"
@@ -4423,7 +4429,7 @@
 "Hit RETURN to continue.\n"
 msgstr ""
-#: ../lib/init/grass.py:417
+#: ../lib/init/grass.py:416
 msgid ""
 "It appears that the X Windows system is not active.\n"
 "A graphical based user interface is not supported.\n"
@@ -4432,34 +4438,34 @@
 msgstr ""
-#: ../lib/init/grass.py:459 ../lib/init/grass.py:472
+#: ../lib/init/grass.py:458 ../lib/init/grass.py:471
 #, fuzzy, python-format
 msgid "<%s> is not a valid GRASS location"
 msgstr "Óõãíþìç <%s> äåí åßíáé áðïäåêôÞ åðéëïãÞ\n"
-#: ../lib/init/grass.py:464
+#: ../lib/init/grass.py:463
 #, python-format
 msgid "The location <%s> does not exist. Please create it first."
 msgstr ""
-#: ../lib/init/grass.py:470
+#: ../lib/init/grass.py:469
 msgid "Missing WIND file fixed"
 msgstr ""
-#: ../lib/init/grass.py:484
+#: ../lib/init/grass.py:483
 msgid ""
 "GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
 "Interactive startup needed."
 msgstr ""
-#: ../lib/init/grass.py:498
+#: ../lib/init/grass.py:497
 #, python-format
 msgid ""
 "Invalid user interface specified - <%s>.\n"
 "Use the --help option to see valid interface names."
 msgstr ""
-#: ../lib/init/grass.py:511
+#: ../lib/init/grass.py:510
 msgid ""
 "Error in GUI startup. If necessary, please report this error to the GRASS "
 "developers.\n"
@@ -4468,13 +4474,13 @@
 "Hit RETURN to continue..."
 msgstr ""
-#: ../lib/init/grass.py:521
+#: ../lib/init/grass.py:520
 msgid ""
 "Received EXIT message from GUI.\n"
 "GRASS is not started. Bye."
 msgstr ""
-#: ../lib/init/grass.py:524
+#: ../lib/init/grass.py:523
 #, fuzzy
 msgid ""
 "Invalid return code from GUI startup script.\n"
@@ -4483,7 +4489,7 @@
 "Ðáñáêáëþ åíçìåñþóôå ôïõò ðñïãñáììáôéóôÝò ôïõ GRASS ãéá áõôü ôï ìÞíõìá "
 "ëÜèïõò.\n"
-#: ../lib/init/grass.py:534
+#: ../lib/init/grass.py:533
 msgid ""
 "Error reading data path information from g.gisenv.\n"
 "GISDBASE=%(gisbase)s\n"
@@ -4493,31 +4499,31 @@
 "Check the <%s(file)> file."
 msgstr ""
-#: ../lib/init/grass.py:555
+#: ../lib/init/grass.py:554
 #, python-format
 msgid ""
 "%(user)s is currently running GRASS in selected mapset (file %(file)s "
 "found). Concurrent use not allowed."
 msgstr ""
-#: ../lib/init/grass.py:559
+#: ../lib/init/grass.py:558
 #, python-format
 msgid ""
 "Unable to properly access \"%s\"\n"
 "Please notify system personel."
 msgstr ""
-#: ../lib/init/grass.py:570
+#: ../lib/init/grass.py:569
 #, fuzzy
 msgid "Building user fontcap..."
-#: ../lib/init/grass.py:599
+#: ../lib/init/grass.py:598
 #, fuzzy
 msgid "The SHELL variable is not set"
 msgstr "GISRC - ç ðáñÜìåôñïò äåí Ý÷åé êáèïñéóôåß"
-#: ../lib/init/grass.py:609
+#: ../lib/init/grass.py:608
 #, python-format
 msgid ""
 "Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -4526,97 +4532,92 @@
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
-#: ../lib/init/grass.py:614
+#: ../lib/init/grass.py:613
 #, python-format
 msgid "Change file permission to 'executable' for '%s'"
 msgstr ""
-#: ../lib/init/grass.py:616
+#: ../lib/init/grass.py:615
 #, python-format
 msgid "Executing '%s' ..."
 msgstr ""
-#: ../lib/init/grass.py:623
+#: ../lib/init/grass.py:620
 #, python-format
+msgid "Execution of '%s' finished."
+msgstr ""
+#: ../lib/init/grass.py:625
+#, python-format
 msgid "GRASS GUI should be '%s'"
 msgstr ""
-#: ../lib/init/grass.py:667
+#: ../lib/init/grass.py:669
 msgid "GRASS homepage:"
 msgstr ""
-#: ../lib/init/grass.py:668
+#: ../lib/init/grass.py:670
 msgid "This version running through:"
 msgstr ""
-#: ../lib/init/grass.py:670
+#: ../lib/init/grass.py:672
 #, fuzzy
 msgid "Help is available with the command:"
 msgstr "Äåí õðÜñ÷åé êåßìåíï âïÞèåéáò ãéá ôçí åíôïëÞ [%s]\n"
-#: ../lib/init/grass.py:671
+#: ../lib/init/grass.py:673
 msgid "See the licence terms with:"
 msgstr ""
-#: ../lib/init/grass.py:674
+#: ../lib/init/grass.py:676
 msgid "If required, restart the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:676
+#: ../lib/init/grass.py:678
 msgid "Start the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:678
+#: ../lib/init/grass.py:680
 msgid "When ready to quit enter:"
 msgstr ""
-#: ../lib/init/grass.py:781
+#: ../lib/init/grass.py:783
 msgid "Failed to start shell '%s'"
-#: ../lib/init/grass.py:785
+#: ../lib/init/grass.py:787
 #, python-format
 msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
 msgstr ""
-#: ../lib/init/grass.py:786 ../lib/init/grass.py:791
+#: ../lib/init/grass.py:788 ../lib/init/grass.py:793
 msgid "Goodbye from GRASS GIS"
 msgstr ""
-#: ../lib/init/grass.py:789
+#: ../lib/init/grass.py:791
 #, fuzzy
 msgid "Done."
 msgstr "êáíÝíá"
-#: ../lib/init/grass.py:795
+#: ../lib/init/grass.py:797
 msgid "Cleaning up temporary files..."
 msgstr ""
-#: ../lib/init/grass.py:938
+#: ../lib/init/grass.py:940
 msgid "Starting GRASS GIS..."
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:84
+#: ../lib/rst/interp_float/output2d.c:106
 #, c-format
 msgid "First change your rows number to nsizr! %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:91
+#: ../lib/rst/interp_float/output2d.c:113
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:99
-#, c-format
-msgid "Rows changed from %d to %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:105
-#, c-format
-msgid "Cols changed from %d to %d"
-msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:111
 #, fuzzy
 msgid ""
@@ -4634,25 +4635,25 @@
 "cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:60
+#: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:86
+#: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
 msgid "First change your rows number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:93
+#: ../lib/rst/interp_float/resout2d.c:110
 #, c-format
 msgid "First change your columns number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:247
+#: ../lib/rst/interp_float/resout2d.c:264
 msgid "No color table for input raster map -- will not create color table"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:458
 msgid "Changing the region back to initial..."
 msgstr ""
@@ -4820,7 +4821,7 @@
 msgid "Window replacing the default"
 msgstr "Ôï ðáñÜèõñï áíôéêáèéóôÜ ôï ðñïåðéëåãìÝíï"
-#: ../lib/g3d/g3dhistory.c:42
+#: ../lib/g3d/g3dhistory.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
 msgstr ""
@@ -5056,12 +5057,12 @@
 "Ôï åýñïò ôïõ ÷ñùìáôéêïý ðßíáêá äåí ôáéñéÜæåé ìå ôá äåäïìÝíá (mincol=%d, "
 "maxcol=%d"
-#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:771
+#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:772
 #, c-format
 msgid "Translating colors from raster map <%s>..."
 msgstr "ÌåôáöñÜæïíôáéò ÷ñþìáôá ãéá ôïí ñÜóôåñ ÷Üñôç <%s>..."
-#: ../lib/ogsf/Gs3.c:1005
+#: ../lib/ogsf/Gs3.c:1007
 msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
 "Ç üøç äåí Ý÷åé óùèåß áðü ôï ðñüãñáììá, ìÜëëïí õðÜñ÷ïõí êÜðïéåò áóõíÝ÷åéåò"
@@ -5086,23 +5087,33 @@
 msgid "Bitmap mismatch"
 msgstr "Ôï bitmap äåí ôáéñéÜæåé"
-#: ../lib/ogsf/GS2.c:1643
+#: ../lib/ogsf/GS2.c:1198
 #, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1217
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1640
+#, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr ""
 "Ï ñÜóôåñ ÷Üñôçò <%s> åßíáé Ýîù áðü ôçí ôñÝ÷ïõóá ðåñéï÷Þ. Ç öüñôùóç áðÝôõ÷å."
-#: ../lib/ogsf/GS2.c:1723 ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1737
-#: ../lib/ogsf/GS2.c:1746 ../lib/ogsf/GS2.c:1754 ../lib/ogsf/GS2.c:1764
-#: ../lib/ogsf/GS2.c:1812
+#: ../lib/ogsf/GS2.c:1720 ../lib/ogsf/GS2.c:1726 ../lib/ogsf/GS2.c:1734
+#: ../lib/ogsf/GS2.c:1743 ../lib/ogsf/GS2.c:1751 ../lib/ogsf/GS2.c:1761
+#: ../lib/ogsf/GS2.c:1809
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
 msgstr "GS_load_att_map(): Åêôüò ìíÞìçò. Áäõíáìßá öüñôùóçò ÷Üñôç"
-#: ../lib/ogsf/GS2.c:1840
+#: ../lib/ogsf/GS2.c:1837
 msgid "Loading failed"
 msgstr "Ç öüñôùóç áðÝôõ÷å"
-#: ../lib/ogsf/GS2.c:1844
+#: ../lib/ogsf/GS2.c:1841
 msgid "Error finding range"
 msgstr "ËÜèïò óôçí åýñåóç åýñïõò"
@@ -5214,7 +5225,7 @@
 "Ìç åðéôñåðôÞ ïíïìáóßá ðßíáêá <%s>. Ï ÷áñáêôÞñáò <%c> äåí ðñÝðåé íá "
 "÷ñçóéìïðïéçèåß.\n"
-#: ../lib/db/dbmi_base/login.c:112
+#: ../lib/db/dbmi_base/login.c:111
 msgid "Login file corrupted"
 msgstr ""
@@ -5877,6 +5888,18 @@
 msgstr ""
+#, fuzzy
+#~ msgstr ""
+#~ "Äåí õðÜñ÷åé áñêåôüò ÷þñïò óôï áñ÷åßï éóôïñéêïý ãéá åããñáöÞ åíôïëÞò ãñáììÞò"
+#, fuzzy
+#~ msgstr "Not enough room in history file to record command line (ðåñéêïðÞ)."
+#~ msgstr "ËÜèïò óõíôåôáãìÝíåò üøçò, ÷ñÞóç %f,%f"
 #~ msgstr "¶ãíùóôç ðåñéï÷Þ"
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_es.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_es\n"
 "PO-Revision-Date: 2010-02-19 19:11-0600\n"
 "Last-Translator: Javier García Prieto <fjgarciaprieto at hotmail.com>\n"
 "Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -66,11 +66,11 @@
 msgstr "No se puede leer el rango del mapa ráster <%s>"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -78,6 +78,14 @@
 msgstr ""
 "G_set_window(): la proyección/zona difiere en los archivos ráster abiertos"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -484,25 +492,25 @@
 #, c-format
 msgstr "No se ha encontrado el mapa raster <%s>."
@@ -782,33 +790,21 @@
 msgstr ""
 "No ha sido posible abrir el archivo de cabecera del mapa raster <%s@%s>."
 #, fuzzy, c-format
 msgstr "la información histórica para [%s] no puede escribirse"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr "Memoria insuficiente en el historial para guardar la línea de comando."
-#, fuzzy
-msgstr ""
-"Memoria insuficiente en el historial para guardar la línea de comando "
-"(truncada)."
@@ -859,7 +855,7 @@
 #, c-format
@@ -1259,13 +1255,13 @@
 " Solamente %d%% de la ventana guardada en \"%s\" se sobrepone con la ventana "
 "actual de GRASS."
 #, c-format
 msgstr ""
 "No se puede generar el elemento del directorio de mapas (mapset) %s (%s): %s."
 #, c-format
 msgstr ""
@@ -1835,27 +1831,31 @@
 msgstr "Separador de campos."
+msgstr ""
 msgid "Color"
 msgstr "Color."
 msgstr ""
 "Puede ser un nombre de color estándar o tres valores que definan un color R: "
 "G: B."
 msgstr "Color de fondo."
 msgstr ""
 "Puede ser un color estándar de GRASS, tres valores que definan un color R:G:"
 "B o \"ninguno\"."
 msgid "Units"
 msgstr ""
@@ -1892,11 +1892,11 @@
 msgid "SYNOPSIS"
 msgstr "SINOPSIS"
 msgid "Flags"
 msgstr "Opciones"
 msgid "Parameters"
 msgstr "Parámetros"
@@ -2382,7 +2382,7 @@
 msgstr "%s completo. %s"
 msgid ""
@@ -2390,23 +2390,23 @@
 "Es necesario reconstruir GRASS o desenmarañar varias instalaciones. La "
 "versión de la biblioteca no es compatible con el módulo."
 #, c-format
 msgstr "Permiso denegado - Directorio de mapas (mapset) %s "
 #, c-format
 msgstr "No se ha encontrado el directorio de mapas %s "
 msgstr ""
 "El sistema no ha sido inicializado. EL programador olvidó llamar G_gisinit()."
@@ -2608,12 +2608,12 @@
 msgstr "No está soportada la escritura del archivo cargado en la memoria."
 msgstr ""
 "No se ha abierto el archivo, pues no ha sido posible cargarlo en la memoria."
 msgstr "Modo de memoria vectorial no soportado, utilizando 'AUTO'."
@@ -2686,11 +2686,11 @@
 msgstr "%s: el área %d no existe."
 msgstr "Intento de borrar un razgo u objeto espacial inexistente."
 msgstr "Ha intentado restaurar una razgo u objeto espacial existente."
@@ -2838,20 +2838,20 @@
 msgstr "Espacio insuficiente en la matriz vectorial."
 #, c-format
 msgstr "No se ha definido la conexión a la base de datos para la capa %d."
@@ -3266,43 +3266,43 @@
 msgstr "Solicitud para encontrar un área fuera de una Isla no existente."
 msgstr "Registrando elementos..."
 msgstr "No se puede leer el mapa vectorial."
 #, c-format
 msgstr "%d Elementos registrados."
 #, c-format
 msgstr "%d vertices registrados."
 msgstr "Construyendo áreas."
 #, c-format
 msgstr "%d áreas construidas."
 #, c-format
 msgstr "%d Islas construidas."
 msgstr "Adjuntando islas..."
 msgstr "Adjuntando centróides..."
@@ -3349,96 +3349,96 @@
 msgstr "No se puede leer el mapa vectorial <%s>."
 #, c-format
 msgstr "El nombre del mapa vectorial no se ajusta al estándar SQL."
 #, c-format
 msgstr "No se puede encontrar el mapa vectorial <%s> en <%s>."
 #, c-format
 msgstr "El mapa vectorial <%s> ya existía y será rescrito."
 #, c-format
 msgstr "No se puede borrar el mapa vectorial <%s>."
 #, c-format
 msgstr "No se puede copiar el mapa vectorial <%s> en <%s>."
 #, c-format
 msgstr "No se puede copiar la tabla <%s>."
 #, c-format
 msgstr "No ha sido posible crear el índice para la tabla <%s>, llave <%s>."
 #, c-format
 msgstr "No se puede borrar la tabla <%s>."
 #, c-format
 msgstr "Nombre de mapa vectorial no válido <%s>."
 #, c-format
 msgstr "No se puede abrir el archivo de cabecera del mapa vectorial <%s>."
 #, c-format
 msgstr ""
 "No se puede encontrar la tabla <%s> enlazada con el mapa vectorial <%s>."
 #, c-format
 msgstr "La tabla <%s> enlazada con el mapa vectorial <%s> no existe."
 #, c-format
 msgstr "No se puede abrir el directorio '%s'."
 #, c-format
 msgstr "No se puede borrar el archivo '%s'."
 #, c-format
 msgstr "No se puede cambiar el nombre del directorio de '%s' a '%s'."
 #, c-format
 msgstr "No se puede eliminar el directorio '%s'."
 #, c-format
 msgstr ""
@@ -3450,7 +3450,7 @@
 msgstr "No se puede abrir el archivo histórico para el mapa vectorial <%s>"
 #, fuzzy, c-format
 msgid ""
@@ -3459,7 +3459,7 @@
 "El archivo de coordenadas del mapa vectorial <%s@%s> es mayor de lo que "
 "debiera (%ld bytes de exceso)."
 #, fuzzy, c-format
 msgid ""
@@ -3484,7 +3484,7 @@
 msgstr "Campo de arco < 1."
 #, c-format
 msgstr "No se ha encontrado la columna <%s> en la tabla <%s>."
@@ -3654,7 +3654,7 @@
 msgstr "No se puede restaurar el objeto espacial %d del mapa vectorial <%s>."
 #, c-format
 msgstr "No se puede cerrar el mapa vectorial <%s>."
@@ -3713,7 +3713,7 @@
 "%s>"
 #, c-format
 msgstr ""
@@ -3736,46 +3736,46 @@
 msgstr "No se puede abrir el archivo de historial del mapa vectorial <%s>."
 #, c-format
 msgstr ""
 "%s no se encuentra en el directorio de mapas del usuario actual (current "
 "mapset) (%s)."
 #, c-format
 msgstr "No se puede crear el mapa vectorial <%s>."
 #, fuzzy, c-format
 #, c-format
 msgstr "No se pueden presentar estadísticas del archivo <%s>."
 #, c-format
 msgstr ""
 msgstr ""
 "El tamaño del archivo de coordenadas difiere del valor guardado en el "
 "archivo de topología."
 #, c-format
 msgstr "Por favor, reconstruya la topología del mapa vectorial <%s@%s>."
 #, fuzzy
 msgstr ""
@@ -3829,89 +3829,99 @@
 msgstr "El mapa vectorial <%s> no ha sido abierto en un nivel >= 2"
 #, fuzzy, c-format
 msgstr "no es posible leer el archivo conteniendo los rangos para [%s en %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "No se puede inicializar pj, por la causa: %s."
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Palabra clave %s descconocida en la cabecera"
 #, c-format
 msgstr "No ha sido posible iniciar el controlador <%s>."
 #, fuzzy, c-format
 msgstr "Tipo de vector desconocido."
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 "No se puede seleccionar el registro de la tabla <%s> (clave<%s, donde %s)"
 #, fuzzy, c-format
 msgstr "Nviz_new_map_obj(): tipo de datos no soportado."
 #, fuzzy
 msgstr "operador desconocido"
 msgstr ""
 #, fuzzy, c-format
 msgstr "No se puede reescribir el razgo. %d"
 #, fuzzy, c-format
 msgstr "No es posible establecer la categoría %d para ( id del razgo %d)"
@@ -4073,59 +4083,54 @@
 msgstr ""
 "No ha sido posible abrir el cursor resultado de la instrucción select:'%s'."
 msgstr "Existe una mala conexión con el servidor."
 msgstr "No ha sido posible crear un contexto de creación de la visualización."
 msgstr "No ha sido posible definir una nueva fuente de luz."
 msgstr "No es posible establecer el foco."
 #, c-format
 msgstr "Color no válido (%s), Utilizando el \"blanco\" como preseleccionado."
-#, c-format
-msgstr "Coordenadas de posición de visualización no válidas, utilizando %f,%f."
 msgstr "Se ha cargado el máximo de superficies!"
 msgstr "Se ha cargado el máximo de mapas de líneas vectoriales!"
 #, c-format
 msgstr "Error al cargar el mapa vectorial. <%s>."
 msgstr "Se ha cargado el máximo de mapas vectoriales de puntos!"
 msgstr "Se ha cargado el máximo de volúmenes!"
 #, c-format
 msgstr "Error al cargar el mapa raster 3D <%s>."
 msgstr "Nviz_new_map_obj(): Tipo de datos no soportado."
@@ -4488,7 +4493,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4496,97 +4501,97 @@
 "Uso:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Aceptar el valor predeterminado."
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "Proyección no válida.\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "No se puede asignar una imagen temporal."
 msgstr ""
 #, fuzzy
 msgstr "Presione ENTER para continuar. -->"
 msgid ""
@@ -4596,7 +4601,7 @@
 msgstr ""
 msgid ""
@@ -4605,34 +4610,34 @@
 msgstr ""
 msgstr "Disculpe pero <%s> no es una opción válida.\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4641,13 +4646,13 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
@@ -4655,7 +4660,7 @@
 msgstr ""
 "Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
 msgid ""
@@ -4665,31 +4670,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Construyendo grafica..."
 #, fuzzy
 msgstr "GISRC - variable no establecida."
 #, python-format
 msgid ""
@@ -4698,98 +4703,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "No hay ayuda disponible para el comando [%s].\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "Ninguno."
 #, fuzzy
 msgstr "No se puede abrir el archivo temporal."
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4807,25 +4807,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4994,7 +4994,7 @@
 msgstr "Ventana reemplazando los valores preestablecidos."
 #, c-format
 msgstr ""
@@ -5242,12 +5242,12 @@
 "El rango de la tabla de colores no corresponde con los datos (mincol=%d, "
 "maxcol=%d."
 #, c-format
 msgstr "Traduciendo colores del mapa raster <%s>..."
 msgstr ""
 "La vista no ha sido guardada por este programa, pueden existir algunas "
@@ -5273,25 +5273,35 @@
 msgstr "No concuerda el mapa de bits."
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr ""
 "La carga del mapa raster <%s> ha fallado, por que este se encuentra fuera de "
 "la región actual."
 msgstr ""
 "GS_load_att_map(): Sin memoria disponible. No es posible cargar el mapa."
 msgstr "La carga ha fallado."
 msgstr "Error al encontrar el rango."
@@ -5407,7 +5417,7 @@
 "Nombre no admitido de tabla de mapa <%s>. El uso del caractér <%c> no está "
 "permitido.\n"
 msgstr ""
@@ -6094,6 +6104,21 @@
 "El subgrupo <%s> perteneciente al grupo <%s> hace referencia a los "
 "siguientes mapas raster:\n"
+#, fuzzy
+#~ msgid "Not enough room in history file to record command line"
+#~ msgstr ""
+#~ "Memoria insuficiente en el historial para guardar la línea de comando."
+#, fuzzy
+#~ msgid "Not enough room in history file for command line (truncated)"
+#~ msgstr ""
+#~ "Memoria insuficiente en el historial para guardar la línea de comando "
+#~ "(truncada)."
+#~ msgid "Invalid view position coordinates, using %f,%f"
+#~ msgstr ""
+#~ "Coordenadas de posición de visualización no válidas, utilizando %f,%f."
 #~ msgid "Unknown Location"
 #~ msgstr "Locación desconocida."
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_fr.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_fr\n"
 "PO-Revision-Date: 2008-07-19 22:40+0100\n"
 "Last-Translator: Pascal Obstétar <pascal.obstetar at wanadoo.fr>\n"
 "Language-Team: French <grass-translations at lists.osgeo.org>\n"
@@ -62,11 +62,11 @@
 msgstr "Impossible de lire la couche vectorielle <%s%s>"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -75,6 +75,14 @@
 "G_set_window() : projection/zone diffèrent de ceux présents dans le fichier "
 "matriciel actuellement ouvert"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -485,25 +493,25 @@
 #, fuzzy, c-format
 msgstr "La couche vectorielle <%s> n'a pas été trouvée"
@@ -771,35 +779,21 @@
 "Impossible d'ouvrir le fichier d'index de catégorie pour la couche "
 "vectorielle <%s@%s>"
 #, fuzzy, c-format
 msgstr "impossible d'écrire l'historique pour [%s]"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr ""
-"Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne "
-"de commande"
-#, fuzzy
-msgstr ""
-"de commande (tronquée)"
@@ -850,7 +844,7 @@
 #, c-format
@@ -1246,12 +1240,12 @@
 " Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la "
 "fenêtre GRASS courante."
 #, fuzzy, c-format
 msgstr "ne peut pas fabriquer l'élément %s (%s) du jeu de données (mapset)"
 #, fuzzy, c-format
@@ -1809,23 +1803,27 @@
 msgstr "Séparateur de champ"
+msgstr ""
 msgid "Color"
 msgstr "Couleur"
 msgstr "Soit un nom de couleur standard ou un triplet R:G:B"
 msgstr "Couleur d'arrière-plan"
 msgstr "Soit une couleur standard de GRASS, un triplet R:G:B ou \"none\""
 msgid "Units"
 msgstr ""
@@ -1860,11 +1858,11 @@
 msgid "SYNOPSIS"
 msgstr "SYNOPSIS"
 msgid "Flags"
 msgstr "Drapeaux"
 msgid "Parameters"
 msgstr "Paramètres"
@@ -2347,23 +2345,23 @@
 msgstr "%s terminé. %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "Jeu de données (MAPSET) %s - permission refusée"
 #, c-format
 msgstr "Jeu de données (MAPSET) %s n'a pas été trouvé"
 #, fuzzy
 msgstr ""
@@ -2371,7 +2369,7 @@
 "d'appeler G_gisinit()\n"
@@ -2571,12 +2569,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Impossible d'ouvrir le fichier %s"
 msgstr ""
@@ -2641,12 +2639,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Tentative de supprimer une surface morte"
 #, fuzzy
@@ -2793,20 +2791,20 @@
 msgstr ""
 #, c-format
 msgstr "Connexion à la base de données indéfinie pour la couche %d"
@@ -3218,47 +3216,47 @@
 msgstr ""
 #, fuzzy
 msgstr "Enregistrement des arcs ... "
 #, fuzzy
 #, fuzzy, c-format
 msgstr "\r%d primitives enregistrées      \n"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Construction du graphique ..."
 #, fuzzy, c-format
 msgstr "Le graphique a été construit"
 #, fuzzy, c-format
 msgstr "La topologie a bien été construite.\n"
 #, fuzzy
 msgstr "Rattachement des îles : "
 #, fuzzy
 msgstr "Rattachement des centroïdes : "
@@ -3306,92 +3304,92 @@
 #, c-format
 msgstr "Le nom de la couche  vectorielle n'est pas compatible avec le SQL"
 #, fuzzy, c-format
 msgstr "Impossible de copier la couche vectorielle <%s> vers <%s>"
 #, c-format
 msgstr "La couche vectorielle <%s> existe déjà et va être écrasé"
 #, c-format
 msgstr "Impossible de supprimer la couche vectorielle <%s>"
 #, c-format
 #, c-format
 msgstr "Impossible de copier la table <%s>"
 #, c-format
 msgstr "Impossible de créer l'index de la table <%s>, clef <%s>"
 #, c-format
 msgstr "Impossible de supprimer la table <%s>"
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr ""
 "Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
 #, c-format
 msgstr "Impossible de trouver la table <%s> liée à la couche vectorielle <%s>"
 #, fuzzy, c-format
 #, c-format
 msgstr "Impossible d'ouvrir le répertoire '%s'"
 #, c-format
 msgstr "Impossible de supprimer le fichier <%s>"
 #, c-format
 msgstr "Impossible de renommer le répertoire '%s' en '%s'"
 #, c-format
 msgstr "Impossible de supprimer le répertoire '%s'"
 #, c-format
 msgstr "Impossible de lier la base de données à la carte vectorielle <%s>"
@@ -3402,14 +3400,14 @@
 msgstr ""
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3434,7 +3432,7 @@
 msgstr "Arc < 1"
 #, fuzzy, c-format
 msgstr "Impossible de décrire la table <%s>"
@@ -3604,7 +3602,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Impossible d'ouvrir la couche vectorielle <%s>"
@@ -3659,7 +3657,7 @@
 "Impossible d'ouvrir le fichier des catégories d'index pour la couche "
 "vectorielle <%s>"
 #, c-format
 msgstr ""
@@ -3682,44 +3680,44 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "pas de fichier %s disponible dans le jeu de données actuel\n"
 #, c-format
 msgstr "Impossible de créer la couche vectorielle <%s>"
 #, fuzzy, c-format
 msgstr ""
 #, c-format
 msgstr "Impossible d'ouvrir le fichier statistique <%s>"
 #, c-format
 msgstr ""
 msgstr ""
 "La taille du fichier 'coord' est différente de la valeur sauvegardée dans le "
 "fichier de topologie"
 #, c-format
 msgstr "Veuillez reconstruire la topologie pour la couche vectorielle <%s@%s>"
 #, fuzzy
 msgstr ""
@@ -3769,89 +3767,99 @@
 #, fuzzy, c-format
 msgstr "impossible de lire le fichier de limites pour [%s dans %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Impossible d'initialiser pj cause : %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Type vectoriel inconnu."
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Erreur inconnue"
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 "vectorielle <%s>"
 #, fuzzy, c-format
 msgstr ""
@@ -4013,62 +4021,57 @@
 msgstr ""
 #, fuzzy
 msgstr "Impossible de créer un nouveau processus"
 #, fuzzy
 msgstr "Impossible d'ouvrir le fichier %s dans %s"
 #, fuzzy
 msgstr "Impossible d'ouvrir %s"
 #, fuzzy, c-format
 msgstr "Couleur de symbole incorrect : '%s', on utilise la couleur par défaut"
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "Erreur à l'ouverture de la couche g3d <%s>"
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "Erreur à l'ouverture de la couche matricielle %s"
 msgstr ""
@@ -4420,7 +4423,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4428,97 +4431,97 @@
 "Utilisation :\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "pour accepter le choix par défaut"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "projection invalide\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Allocation mémoire impossible\n"
 msgstr ""
 #, fuzzy
 msgstr "pressez RETOUR pour continuer -->"
 msgid ""
@@ -4528,7 +4531,7 @@
 msgstr ""
 msgid ""
@@ -4537,34 +4540,34 @@
 msgstr ""
 msgstr "Désolé, <%s> n'est pas une option valide\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4573,20 +4576,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 "Please advise GRASS developers of this error."
 msgstr "Veuillez avertir les développeurs GRASS de cette erreur.\n"
 msgid ""
@@ -4596,31 +4599,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy
 msgstr "GISRC - variable sans valeur"
 #, python-format
 msgid ""
@@ -4629,98 +4632,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Aucune aide disponible pour la commande [%s]\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "Aucun"
 #, fuzzy
 msgstr "Impossible d'ouvrir le fichier temporaire"
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4738,25 +4736,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4925,7 +4923,7 @@
 msgstr "Remplace la fenêtre par défaut"
 #, c-format
 msgstr "impossible d'obtenir l'historique pour [%s] dans le mapset [%s]"
@@ -5164,12 +5162,12 @@
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Lignes de lecture de la carte vectorielle..."
 msgstr ""
@@ -5191,25 +5189,35 @@
 msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr ""
 "[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente [%"
 "d] de celle de la région courante [%d]"
 msgstr ""
 #, fuzzy
 msgstr "Echec de la connexion."
 #, fuzzy
@@ -5325,7 +5333,7 @@
 msgstr ""
 "Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
 msgstr ""
@@ -5991,6 +5999,18 @@
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
 msgstr ""
+#, fuzzy
+#~ msgstr ""
+#~ "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la "
+#~ "ligne de commande"
+#, fuzzy
+#~ msgstr ""
+#~ "ligne de commande (tronquée)"
 #~ msgstr "Secteur (Location) inconnu"
Modified: grass/trunk/locale/po/grasslibs_hi.po
--- grass/trunk/locale/po/grasslibs_hi.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_hi.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_hi\n"
 "PO-Revision-Date: 2005-12-22 14:34+0100\n"
 "Last-Translator: Markus Neteler <neteler at itc.it>\n"
 "Language-Team: Hindi <grass-translations at lists.osgeo.org>\n"
@@ -59,17 +59,25 @@
 msgstr "के लिए"
 msgstr ""
 #, fuzzy
 msgid ""
 "raster maps"
 msgstr "जी सेट का"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -458,25 +466,25 @@
 #, fuzzy, c-format
 msgstr "नहीं"
@@ -729,29 +737,21 @@
 msgid "Unable to open header file for raster map <%s@%s>"
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, c-format
 msgstr ""
-msgstr ""
-msgstr ""
@@ -802,7 +802,7 @@
 #, fuzzy, c-format
@@ -1178,12 +1178,12 @@
 " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
 msgstr "का."
 #, fuzzy, c-format
 msgstr "का"
 #, fuzzy, c-format
 msgstr "का"
@@ -1733,23 +1733,27 @@
 msgstr ""
+msgstr ""
 msgid "Color"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Units"
 msgstr ""
@@ -1784,12 +1788,12 @@
 msgid "SYNOPSIS"
 msgstr ""
 #, fuzzy
 msgid "Flags"
 msgstr "n"
 #, fuzzy
 msgid "Parameters"
 msgstr "n"
@@ -2299,29 +2303,29 @@
 msgstr "n"
 msgid ""
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "नहीं"
 #, fuzzy
 msgstr "त्रुटि नहीं जी n"
@@ -2517,12 +2521,12 @@
 msgstr ""
 #, fuzzy
 msgstr "n"
 msgstr ""
@@ -2587,12 +2591,12 @@
 msgstr ""
 #, fuzzy
 msgstr "के लिए"
 #, fuzzy
 msgstr "के लिए"
@@ -2726,20 +2730,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3142,46 +3146,46 @@
 msgstr ""
 #, fuzzy
 msgstr "का n"
 #, fuzzy
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "n"
 #, fuzzy, c-format
 msgstr "n"
 #, fuzzy
 msgstr "n"
 #, fuzzy, c-format
 msgstr "n"
 #, fuzzy, c-format
 msgstr "n"
 msgstr ""
 msgstr ""
@@ -3228,91 +3232,91 @@
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "है नहीं."
 #, fuzzy, c-format
 msgstr "नक़ल"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "नक़ल"
 #, fuzzy, c-format
 msgstr "का"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "का"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "का"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
@@ -3322,14 +3326,14 @@
 msgstr "के लिए"
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3354,7 +3358,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "नहीं के लिए n"
@@ -3507,7 +3511,7 @@
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
@@ -3556,7 +3560,7 @@
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
@@ -3576,42 +3580,42 @@
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "n"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "का"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "का."
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy
 msgstr "का."
@@ -3657,86 +3661,96 @@
 msgstr "नहीं"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "के लिए"
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
+#, fuzzy, c-format
+msgstr "का"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "का"
 #, fuzzy, c-format
 msgstr "का"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए n"
 #, fuzzy, c-format
 msgstr "के लिए n"
@@ -3894,62 +3908,57 @@
 msgstr "के लिए"
 msgstr ""
 #, fuzzy
 msgstr "a"
 #, fuzzy
 msgstr "का"
 #, fuzzy
 msgstr "का"
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
 msgstr ""
@@ -4247,99 +4256,99 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr "n "
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "n"
 msgstr ""
 #, fuzzy
 msgstr "n"
 msgid ""
@@ -4349,7 +4358,7 @@
 msgstr ""
 msgid ""
@@ -4358,34 +4367,34 @@
 msgstr ""
 msgstr "खेद है है नहीं a n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4394,20 +4403,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "का त्रुटि n"
 msgid ""
@@ -4417,31 +4426,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "n"
 #, fuzzy
 msgstr "चर नहीं सेट"
 #, python-format
 msgid ""
@@ -4450,96 +4459,91 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr "का"
 #, python-format
 msgstr ""
 msgstr ""
 msgid "Done."
 msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4554,25 +4558,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4731,7 +4735,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
@@ -4963,12 +4967,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "के लिए"
 msgstr ""
@@ -4990,23 +4994,33 @@
 msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr "है नहीं."
 msgstr ""
 #, fuzzy
 msgstr "n"
 msgstr ""
@@ -5120,7 +5134,7 @@
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
 msgstr "नहीं n"
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_it.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_it\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2007-11-21 12:41+0100\n"
 "Last-Translator: Andrea Giacomelli <pibinko at gmail.com>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -66,11 +66,11 @@
 msgid "Unable to write quant rules for raster map <%s>"
 msgstr "impossibile cambiare la directory %s"
-#: ../lib/raster/set_window.c:46
+#: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
 msgstr ""
-#: ../lib/raster/set_window.c:117
+#: ../lib/raster/set_window.c:123
 #, fuzzy
 msgid ""
 "Rast_set_read_window(): projection/zone differs from that of currently open "
@@ -79,6 +79,14 @@
 "G_set_window(): la proiezione/zona differisce da quella del raster "
 "attualmente aperto"
+#: ../lib/raster/set_window.c:150
+msgid "Input window changed while maps are open for read"
+msgstr ""
+#: ../lib/raster/set_window.c:168
+msgid "Output window changed while maps are open for write"
+msgstr ""
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
@@ -474,25 +482,25 @@
 #: ../lib/raster/opencell.c:779 ../lib/raster/opencell.c:831
 #: ../lib/manage/do_rename.c:53 ../lib/manage/do_remove.c:53
 #: ../lib/gis/legal_name.c:91 ../lib/gis/legal_name.c:94
-#: ../lib/rst/interp_float/output2d.c:228
-#: ../lib/rst/interp_float/output2d.c:309
-#: ../lib/rst/interp_float/output2d.c:393
-#: ../lib/rst/interp_float/output2d.c:457
-#: ../lib/rst/interp_float/output2d.c:485
-#: ../lib/rst/interp_float/output2d.c:513
-#: ../lib/rst/interp_float/output2d.c:543
-#: ../lib/rst/interp_float/resout2d.c:188
-#: ../lib/rst/interp_float/resout2d.c:236
-#: ../lib/rst/interp_float/resout2d.c:279
-#: ../lib/rst/interp_float/resout2d.c:319
-#: ../lib/rst/interp_float/resout2d.c:378
-#: ../lib/rst/interp_float/resout2d.c:405
-#: ../lib/rst/interp_float/resout2d.c:429
-#: ../lib/rst/interp_float/resout2d.c:455 ../lib/ogsf/gsd_legend.c:239
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426 ../lib/ogsf/gsd_legend.c:239
 #: ../lib/ogsf/Gs3.c:127 ../lib/ogsf/Gs3.c:200 ../lib/ogsf/Gs3.c:283
 #: ../lib/ogsf/Gs3.c:356 ../lib/ogsf/Gs3.c:470 ../lib/ogsf/Gs3.c:565
-#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:757
-#: ../lib/ogsf/Gs3.c:826
+#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:758
+#: ../lib/ogsf/Gs3.c:828
 #, fuzzy, c-format
 msgid "Raster map <%s> not found"
 msgstr "Non riesco a trovare il vettore '%s' di input"
@@ -752,29 +760,21 @@
 msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
-#: ../lib/raster/history.c:115
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, fuzzy, c-format
 msgid "Unable to get history information for <%s@%s>"
 msgstr "non riesco a scrivere le informazioni dello storico per [%s]"
-#: ../lib/raster/history.c:143
+#: ../lib/raster/history.c:162
 #, fuzzy, c-format
 msgid "Unable to write history information for <%s>"
-#: ../lib/raster/history.c:184
+#: ../lib/raster/history.c:235
 #, c-format
 msgid "generated by %s"
 msgstr ""
-#: ../lib/raster/history.c:232
-msgid "Not enough room in history file to record command line"
-msgstr ""
-#: ../lib/raster/history.c:254
-msgid "Not enough room in history file for command line (truncated)"
-msgstr ""
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
 #: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
 #: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
@@ -825,7 +825,7 @@
 #: ../lib/manage/do_rename.c:37 ../lib/manage/do_remove.c:37
 #: ../lib/vector/Vlib/legal_vname.c:115 ../lib/vector/Vlib/legal_vname.c:118
-#: ../lib/vector/Vlib/map.c:404 ../lib/vector/Vlib/open.c:197
+#: ../lib/vector/Vlib/map.c:403 ../lib/vector/Vlib/open.c:197
 #: ../lib/ogsf/Gv3.c:58 ../lib/ogsf/Gp3.c:58
 #, fuzzy, c-format
 msgid "Vector map <%s> not found"
@@ -1206,12 +1206,12 @@
 " Solo  %d%% della finestra salvata in \"%s\" si sovrappone con la finestra "
 "GRASS in uso"
-#: ../lib/gis/mapset_msc.c:60
+#: ../lib/gis/mapset_msc.c:61
 #, fuzzy, c-format
 msgid "Unable to make mapset element %s (%s): %s"
 msgstr "Non posso creare l'elemento mapset %s (%s)"
-#: ../lib/gis/mapset_msc.c:64
+#: ../lib/gis/mapset_msc.c:65
 #, fuzzy, c-format
 msgid "Unable to access mapset element %s (%s): %s"
@@ -1770,23 +1770,27 @@
 msgid "Field separator"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:455
+#: ../lib/gis/parser_standard_options.c:445
+msgid "Special characters: newline, space, comma, tab"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:456
 msgid "Color"
 msgstr "Colore"
-#: ../lib/gis/parser_standard_options.c:456
+#: ../lib/gis/parser_standard_options.c:457
 msgid "Either a standard color name or R:G:B triplet"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:465
+#: ../lib/gis/parser_standard_options.c:466
 msgid "Background color"
 msgstr "Colore sfondo"
-#: ../lib/gis/parser_standard_options.c:467
+#: ../lib/gis/parser_standard_options.c:468
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:478
+#: ../lib/gis/parser_standard_options.c:479
 msgid "Units"
 msgstr ""
@@ -1822,14 +1826,14 @@
 msgid "SYNOPSIS"
 msgstr "SINOPSI"
-#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:146
+#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:147
 #, fuzzy
 msgid "Flags"
 msgstr ""
 "\n"
 "Flags:\n"
-#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:156
+#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:157
 msgid "Parameters"
 msgstr "Parametri"
@@ -2312,23 +2316,23 @@
 msgid "%s complete. %s"
-#: ../lib/gis/gisinit.c:55 ../lib/gis/gisinit.c:90
+#: ../lib/gis/gisinit.c:56 ../lib/gis/gisinit.c:91
 msgid ""
 "Incompatible library version for module. You need to rebuild GRASS or "
 "untangle multiple installations."
 msgstr ""
-#: ../lib/gis/gisinit.c:65
+#: ../lib/gis/gisinit.c:66
 #, c-format
 msgid "MAPSET %s - permission denied"
 msgstr "MAPSET %s - permesso negato"
-#: ../lib/gis/gisinit.c:68
+#: ../lib/gis/gisinit.c:69
 #, c-format
 msgid "MAPSET %s not found"
 msgstr "MAPSET %s non trovato"
-#: ../lib/gis/gisinit.c:107
+#: ../lib/gis/gisinit.c:108
 #, fuzzy
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
 msgstr ""
@@ -2336,7 +2340,7 @@
 "la funzione G_gisinit()\n"
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/vector/Vlib/ascii.c:187 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/ascii.c:200 ../lib/vector/Vlib/line.c:50
 #: ../lib/vector/neta/articulation_point.c:60
 #: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
 #: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
@@ -2534,12 +2538,12 @@
 msgid "Writing to file loaded to memory not supported"
 msgstr ""
-#: ../lib/vector/diglib/file.c:204
+#: ../lib/vector/diglib/file.c:205
 #, fuzzy
 msgid "Unable to load file to memory, file not open"
 msgstr "Impossibile aprire il file %s in %s"
-#: ../lib/vector/diglib/file.c:219
+#: ../lib/vector/diglib/file.c:220
 msgid "Vector memory mode not supported, using 'AUTO'"
 msgstr ""
@@ -2604,12 +2608,12 @@
 msgid "%s: Area %d does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:675 ../lib/vector/Vlib/write_ogr.c:298
+#: ../lib/vector/Vlib/write_nat.c:670 ../lib/vector/Vlib/write_ogr.c:298
 #, fuzzy
 msgid "Attempt to delete dead feature"
 msgstr "Impossibile calcolare il centroide dell'area %d"
-#: ../lib/vector/Vlib/write_nat.c:920
+#: ../lib/vector/Vlib/write_nat.c:910
 #, fuzzy
 msgid "Attempt to restore alive feature"
@@ -2750,20 +2754,20 @@
 msgid "Not enough space in vector array"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:313
-#: ../lib/vector/Vlib/map.c:440 ../lib/vector/Vlib/map.c:552
-#: ../lib/vector/Vlib/map.c:670 ../lib/vector/Vlib/map.c:768
+#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:312
+#: ../lib/vector/Vlib/map.c:439 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:669 ../lib/vector/Vlib/map.c:767
 #: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:347
-#: ../lib/vector/Vlib/ascii.c:301 ../lib/vector/Vlib/write_ogr.c:118
+#: ../lib/vector/Vlib/ascii.c:314 ../lib/vector/Vlib/write_ogr.c:118
 #: ../lib/rst/interp_float/vinput2d.c:79
 #, c-format
 msgid "Database connection not defined for layer %d"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:342
-#: ../lib/vector/Vlib/map.c:481 ../lib/vector/Vlib/map.c:703
+#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:341
+#: ../lib/vector/Vlib/map.c:480 ../lib/vector/Vlib/map.c:702
 #: ../lib/vector/Vlib/net.c:182 ../lib/vector/Vlib/net.c:352
-#: ../lib/vector/Vlib/ascii.c:313 ../lib/vector/Vlib/write_ogr.c:375
+#: ../lib/vector/Vlib/ascii.c:326 ../lib/vector/Vlib/write_ogr.c:375
 #: ../lib/vector/neta/utils.c:116 ../lib/vector/neta/timetables.c:133
 #: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/copy_tab.c:105
 #: ../lib/db/dbmi_client/copy_tab.c:126 ../lib/db/dbmi_client/db.c:46
@@ -3171,47 +3175,47 @@
 msgid "Request to find area outside nonexistent isle"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:523
+#: ../lib/vector/Vlib/build_nat.c:525
 #, fuzzy
 msgid "Registering primitives..."
 msgstr "Linee registrate: "
-#: ../lib/vector/Vlib/build_nat.c:532
+#: ../lib/vector/Vlib/build_nat.c:534
 #, fuzzy
 msgid "Unable to read vector map"
-#: ../lib/vector/Vlib/build_nat.c:576
+#: ../lib/vector/Vlib/build_nat.c:578
 #, fuzzy, c-format
 msgid "%d primitives registered"
 msgstr "\r%d primitive registrate      \n"
-#: ../lib/vector/Vlib/build_nat.c:577
+#: ../lib/vector/Vlib/build_nat.c:579
 #, fuzzy, c-format
 msgid "%d vertices registered"
-#: ../lib/vector/Vlib/build_nat.c:588
+#: ../lib/vector/Vlib/build_nat.c:590
 #, fuzzy
 msgid "Building areas..."
 msgstr "Creazione topologia...\n"
-#: ../lib/vector/Vlib/build_nat.c:611
+#: ../lib/vector/Vlib/build_nat.c:613
 #, fuzzy, c-format
 msgid "%d areas built"
 msgstr "La topologia è stata creata.\n"
-#: ../lib/vector/Vlib/build_nat.c:612
+#: ../lib/vector/Vlib/build_nat.c:614
 #, fuzzy, c-format
 msgid "%d isles built"
-#: ../lib/vector/Vlib/build_nat.c:621
+#: ../lib/vector/Vlib/build_nat.c:623
 #, fuzzy
 msgid "Attaching islands..."
 msgstr "Isole allegate: "
-#: ../lib/vector/Vlib/build_nat.c:636
+#: ../lib/vector/Vlib/build_nat.c:638
 #, fuzzy
 msgid "Attaching centroids..."
 msgstr "Centroidi allegati:  "
@@ -3259,91 +3263,91 @@
 msgid "Unable to read vector map <%s>"
-#: ../lib/vector/Vlib/map.c:242 ../lib/vector/Vlib/map.c:386
-#: ../lib/vector/Vlib/open.c:692
+#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:385
+#: ../lib/vector/Vlib/open.c:691
 #, fuzzy, c-format
 msgid "Vector map name is not SQL compliant"
 msgstr "Il non della mappa non è conforme al SQL."
-#: ../lib/vector/Vlib/map.c:246
+#: ../lib/vector/Vlib/map.c:245
 #, fuzzy, c-format
 msgid "Unable to find vector map <%s> in <%s>"
 msgstr "impossibile aprire un raster [%s in %s]"
-#: ../lib/vector/Vlib/map.c:258 ../lib/vector/Vlib/map.c:390
-#: ../lib/vector/Vlib/open.c:699
+#: ../lib/vector/Vlib/map.c:257 ../lib/vector/Vlib/map.c:389
+#: ../lib/vector/Vlib/open.c:698
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Il vettoriale '%s' è già presente e sarà sovrascritto"
-#: ../lib/vector/Vlib/map.c:262 ../lib/vector/Vlib/open.c:704
+#: ../lib/vector/Vlib/map.c:261 ../lib/vector/Vlib/open.c:703
 #, fuzzy, c-format
 msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:282 ../lib/vector/Vlib/map.c:408
+#: ../lib/vector/Vlib/map.c:281 ../lib/vector/Vlib/map.c:407
 #, fuzzy, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:457
-#: ../lib/vector/Vlib/map.c:695 ../lib/vector/Vlib/map.c:802
+#: ../lib/vector/Vlib/map.c:330 ../lib/vector/Vlib/map.c:456
+#: ../lib/vector/Vlib/map.c:694 ../lib/vector/Vlib/map.c:801
 #, fuzzy, c-format
 msgid "Unable to copy table <%s>"
-#: ../lib/vector/Vlib/map.c:347 ../lib/vector/Vlib/map.c:486
-#: ../lib/vector/Vlib/map.c:708
+#: ../lib/vector/Vlib/map.c:346 ../lib/vector/Vlib/map.c:485
+#: ../lib/vector/Vlib/map.c:707
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 msgstr "Impossibile creare il file di intestazione per [%s in %s]"
-#: ../lib/vector/Vlib/map.c:471 ../lib/vector/Vlib/map.c:572
+#: ../lib/vector/Vlib/map.c:470 ../lib/vector/Vlib/map.c:571
 #, fuzzy, c-format
 msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/map.c:526
+#: ../lib/vector/Vlib/map.c:525
 #, fuzzy, c-format
 msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:540
+#: ../lib/vector/Vlib/map.c:539
 #, fuzzy, c-format
 msgid "Unable to open header file for vector map <%s>"
-#: ../lib/vector/Vlib/map.c:562
+#: ../lib/vector/Vlib/map.c:561
 #, fuzzy, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
-#: ../lib/vector/Vlib/map.c:579
+#: ../lib/vector/Vlib/map.c:578
 #, fuzzy, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:592
+#: ../lib/vector/Vlib/map.c:591
 #, fuzzy, c-format
 msgid "Unable to open directory '%s'"
-#: ../lib/vector/Vlib/map.c:606
+#: ../lib/vector/Vlib/map.c:605
 #, fuzzy, c-format
 msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/map.c:623
+#: ../lib/vector/Vlib/map.c:622
 #, fuzzy, c-format
 msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/map.c:631
+#: ../lib/vector/Vlib/map.c:630
 #, fuzzy, c-format
 msgid "Unable to remove directory '%s'"
-#: ../lib/vector/Vlib/map.c:686 ../lib/vector/Vlib/map.c:787
+#: ../lib/vector/Vlib/map.c:685 ../lib/vector/Vlib/map.c:786
 #, fuzzy, c-format
 msgid "Unable to add database link for vector map <%s>"
@@ -3353,14 +3357,14 @@
 msgid "Unable to open coor file for vector map <%s>"
-#: ../lib/vector/Vlib/open_nat.c:155
+#: ../lib/vector/Vlib/open_nat.c:154
 #, c-format
 msgid ""
 "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
 "excess)"
 msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:159
+#: ../lib/vector/Vlib/open_nat.c:158
 #, c-format
 msgid ""
 "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
@@ -3385,7 +3389,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:204
-#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:488
+#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:501
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr "Non posso scrivere i collegamenti del database"
@@ -3546,7 +3550,7 @@
 msgid "Unable to restore feature %d from vector map <%s>"
-#: ../lib/vector/Vlib/close.c:140
+#: ../lib/vector/Vlib/close.c:139
 #, fuzzy, c-format
 msgid "Unable to close vector <%s>"
@@ -3597,7 +3601,7 @@
 msgid "Unable to open spatial index file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:511
+#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:510
 #, fuzzy, c-format
 msgid "Unable to open category index file for vector map <%s>"
@@ -3617,44 +3621,44 @@
 msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:683
+#: ../lib/vector/Vlib/open.c:682
 #, fuzzy, c-format
 msgid "%s is not in the current mapset (%s)"
 msgstr "Nessun file %s disponibile nel mapset in uso\n"
-#: ../lib/vector/Vlib/open.c:721
+#: ../lib/vector/Vlib/open.c:720
 #, fuzzy, c-format
 msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/open.c:731
+#: ../lib/vector/Vlib/open.c:730
 #, fuzzy, c-format
 msgid "Unable to open history file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:783
+#: ../lib/vector/Vlib/open.c:782
 #, fuzzy, c-format
 msgid "Unable to stat file <%s>"
-#: ../lib/vector/Vlib/open.c:842
+#: ../lib/vector/Vlib/open.c:841
 #, c-format
 msgid "unknown %d (update Vect_maptype_info)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:918
+#: ../lib/vector/Vlib/open.c:916
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr ""
 "La dimensione del file 'coor' è diverso dal valore salvato nel file di "
 "topologia"
-#: ../lib/vector/Vlib/open.c:929 ../lib/vector/Vlib/open.c:1024
+#: ../lib/vector/Vlib/open.c:927 ../lib/vector/Vlib/open.c:1021
 #, fuzzy, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
 msgstr "Ricrea la topologia per il vettore '%s@%s'"
-#: ../lib/vector/Vlib/open.c:1013
+#: ../lib/vector/Vlib/open.c:1010
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in sidx file"
 msgstr ""
@@ -3701,87 +3705,97 @@
 msgid "Vector map <%s> is not open on level >= 2"
-#: ../lib/vector/Vlib/ascii.c:77
+#: ../lib/vector/Vlib/ascii.c:80
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
 msgstr "non riesco a leggere l'intervallo del file [%s in %s]"
-#: ../lib/vector/Vlib/ascii.c:115
+#: ../lib/vector/Vlib/ascii.c:118
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
-#: ../lib/vector/Vlib/ascii.c:128
+#: ../lib/vector/Vlib/ascii.c:131
 msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:138
+#: ../lib/vector/Vlib/ascii.c:142
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
-#: ../lib/vector/Vlib/ascii.c:169
+#: ../lib/vector/Vlib/ascii.c:146
+#, fuzzy, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr "Impossibile aprire il file %s in %s"
+#: ../lib/vector/Vlib/ascii.c:149
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:182
 msgid "End of ASCII file reached before end of categories"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:179
+#: ../lib/vector/Vlib/ascii.c:192
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
-#: ../lib/vector/Vlib/ascii.c:222
+#: ../lib/vector/Vlib/ascii.c:235
 #, c-format
 msgid ""
 "Unexpected data in vector head:\n"
 "[%s]"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:256
+#: ../lib/vector/Vlib/ascii.c:269
 #, fuzzy, c-format
 msgid "Unknown keyword <%s> in vector head"
 msgstr "Tipo di interpolazione sconosciuta"
-#: ../lib/vector/Vlib/ascii.c:307 ../lib/db/dbmi_client/copy_tab.c:100
+#: ../lib/vector/Vlib/ascii.c:320 ../lib/db/dbmi_client/copy_tab.c:100
 #: ../lib/db/dbmi_client/copy_tab.c:120 ../lib/db/dbmi_client/db.c:41
 #, fuzzy, c-format
 msgid "Unable to start driver <%s>"
-#: ../lib/vector/Vlib/ascii.c:413
+#: ../lib/vector/Vlib/ascii.c:426
 #, fuzzy, c-format
 msgid "Uknown feature type %d"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr "errore sconosciuto"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Non riesco ad aprire il file temp"
 #, fuzzy, c-format
@@ -3940,62 +3954,57 @@
 msgstr ""
 #, fuzzy
 msgstr "impossibile creare un nuovo processo"
 #, fuzzy
 #, fuzzy
 msgstr "Impossibile aprire %s"
 #, fuzzy, c-format
 msgstr "Colore del simbolo scorretto: '%s', uso quello predefinito."
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "per mappe raster presenti %d\n"
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -4301,7 +4310,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4309,97 +4318,97 @@
 "Uso:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "per accettare i valori predefiniti"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "proiezione non valida\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Impossibile allocare memoria\n"
 msgstr ""
 #, fuzzy
 msgstr "premi INVIO per continuare -->"
 msgid ""
@@ -4409,7 +4418,7 @@
 msgstr ""
 msgid ""
@@ -4418,34 +4427,34 @@
 msgstr ""
 msgstr "Mi spiace <%s> non è una opzione valida\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4454,20 +4463,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "Per piacere avvisa gli sviluppatori GRASS per questo errore\n"
 msgid ""
@@ -4477,31 +4486,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy
 msgstr "GISRC - variabile non impostata"
 #, python-format
 msgid ""
@@ -4510,98 +4519,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Nessun aiuto disponibile per il comando [%s]\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "nessuno"
 #, fuzzy
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 msgid ""
 "Taking too long to find points for interpolation - please change the region "
@@ -4615,25 +4619,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4791,7 +4795,7 @@
 msgstr "Finestra sostituisce il predefinito"
 #, c-format
 msgstr "Non riesco a trovare lo storico per [%s] nel mapset [%s]"
@@ -5026,12 +5030,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -5053,23 +5057,33 @@
 msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr "[%s] nel mapset [%s] - zona [%d] diversa dalla regione in uso [%d]"
 msgstr ""
 #, fuzzy
 msgstr "Connessione fallita.\n"
 #, fuzzy
@@ -5190,7 +5204,7 @@
 "Il nome <%s> non è valido per una mappa vettoriale. Il carattere <%c> non è "
 "permesso.\n"
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_ja.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ja\n"
 "PO-Revision-Date: 2010-02-18 17:47+0900\n"
 "Last-Translator: \n"
 "Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -64,17 +64,25 @@
 msgstr "����� ���� ���\n"
 msgstr ""
 #, fuzzy
 msgid ""
 "raster maps"
 msgstr "G_set_window(): 投影法/領域は現在開いているラスターマップと異なります"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -457,25 +465,25 @@
 #, c-format
 msgstr "ラスターマップ <%s> が見つかりません"
@@ -721,29 +729,21 @@
 msgstr "ラスターマップ <%s@%s>のヘッダーファイルが開きません"
 #, fuzzy, c-format
 msgstr "���"
 #, fuzzy, c-format
 msgstr "���"
 #, c-format
 msgstr ""
-msgstr ""
-msgstr ""
@@ -794,7 +794,7 @@
 #, c-format
@@ -1179,12 +1179,12 @@
 " ウィンドウの %d%% のみ保存できます \"%s\" 現在のGRASSウィンドウと重複してい"
 "ます"
 #, c-format
 msgstr "マップセットの要素が作成できません %s (%s): %s"
 #, c-format
 msgstr "マップセット要素にアクセスできません %s (%s): %s"
@@ -1716,23 +1716,27 @@
 msgstr "フィールドセパレーター"
+msgstr ""
 msgid "Color"
 msgstr "色"
 msgstr "標準色名あるいは赤:緑:青"
 msgstr "背景の色"
 msgstr "標準のGRASSカラー、赤:緑:青、あるいは \"none\""
 msgid "Units"
 msgstr ""
@@ -1767,11 +1771,11 @@
 msgid "SYNOPSIS"
 msgstr "概要"
 msgid "Flags"
 msgstr "フラッグ"
 msgid "Parameters"
 msgstr "パラメータ"
@@ -2254,7 +2258,7 @@
 msgstr "%s 完了. %s"
 msgid ""
@@ -2262,24 +2266,24 @@
 "互換性のないライブラリバージョンです。GRASSを復元するか、複合インストールを解"
 "決する必要があります。"
 #, c-format
 msgstr "マップセット %s - 権限がありません"
 #, c-format
 msgstr "マップセット %s が見つかりません"
 msgstr ""
 "システムが初期化されません。 プログラマーが G_gisinit()を呼び出すのを忘れてい"
 "ます。"
@@ -2471,11 +2475,11 @@
 msgstr "メモリ用にロードされたファイルへの書き込みはサポートされません"
 msgstr "メモリ用にファイルをロードできません, ファイルが開きません"
 msgstr ""
 "ベクトルメモリーモードはサポートされていません。, 'AUTO'を使用してください"
@@ -2540,11 +2544,11 @@
 msgstr "%s: エリア %d は存在しません"
 msgstr "不要なフィーチャを削除しようとしています"
 msgstr "有効なフィーチャを修復しようとしています"
@@ -2678,20 +2682,20 @@
 msgstr "ベクトル 配列に十分なスペースがありません"
 #, c-format
 msgstr "データベース接続はレイヤー %d に定義されていません"
@@ -3086,43 +3090,43 @@
 msgstr "実在しないアイル外でエリアを見つけてください"
 msgstr "プリミティブを登録しています..."
 msgstr "ベクトルマップを読み込めません"
 #, c-format
 msgstr "%d プリミティブは登録されました"
 #, c-format
 msgstr "%d 頂点は登録されました"
 msgstr "領域を作成しています..."
 #, c-format
 msgstr "作成された領域 %d"
 #, c-format
 msgstr "%d アイルは作成されました"
 msgstr "島を接続しています..."
 msgstr "セントロイドを接続しています..."
@@ -3169,91 +3173,91 @@
 msgstr "ベクトルマップ <%s> を読み込めません"
 #, c-format
 msgstr "ベクトルマップ名はSQLに基づいていません"
 #, c-format
 msgstr "<%s> にベクトルマップ <%s> を見つけられません"
 #, c-format
 msgstr "ベクトルマップ <%s> は既に存在し上書きされます"
 #, c-format
 msgstr "ベクトルマップ <%s> を削除できません"
 #, c-format
 msgstr "ベクトルマップ <%s> を <%s> にコピーできません"
 #, c-format
 msgstr "テーブル <%s> をコピーできません"
 #, c-format
 msgstr "テーブル <%s> の索引を作成できません, キー <%s>"
 #, c-format
 msgstr "テーブル <%s> を削除できません"
 #, c-format
 msgstr "無効なベクトルマップ名 <%s>"
 #, c-format
 msgstr "ベクトルマップ <%s> のヘッダーファイルを開けません"
 #, c-format
 msgstr "ベクトルマップ <%s> にリンクするテーブル <%s> が見つかりません"
 #, c-format
 msgstr "ベクトルマップ <%s> にリンクするテーブル <%s> は存在しません"
 #, c-format
 msgstr "ディレクトリ '%s' を開けません"
 #, c-format
 msgstr "ファイル '%s' を削除できません"
 #, c-format
 msgstr "ディレクトリ名を  '%s'  から  '%s' に変更できません"
 #, c-format
 msgstr "ディレクトリ  '%s' を削除できません"
 #, c-format
 msgstr "ベクトルマップ <%s> にデータベースをリンクを追加できません"
@@ -3263,14 +3267,14 @@
 msgstr "���"
 #, fuzzy, c-format
 msgid ""
 "excess)"
 msgstr "ベクトルマップ <%s@%s> の座標ファイルが大きすぎます(%ld バイト超過)"
 #, fuzzy, c-format
 msgid ""
@@ -3294,7 +3298,7 @@
 msgstr "アークフィールド < 1"
 #, c-format
 msgstr "テーブル <%s> に列 <%s> が見つかりません"
@@ -3456,7 +3460,7 @@
 msgstr "ベクトルマップからフィーチャー%d を修復できません <%s>"
 #, c-format
 msgstr "ベクトル <%s> を閉じれません"
@@ -3506,7 +3510,7 @@
 msgstr "���"
 #, c-format
 msgstr "ベクトルマップ <%s> の索引ファイルを開けません"
@@ -3526,41 +3530,41 @@
 msgstr "ベクトルマップ <%s> のヒストリーファイルを開けません"
 #, c-format
 msgstr "%s はこのマップセット (%s) にありません"
 #, c-format
 msgstr "ベクトルマップ <%s> を作成できません"
 #, fuzzy, c-format
 msgstr "���"
 #, c-format
 msgstr "ファイル <%s> をスタートできません"
 #, c-format
 msgstr ""
 msgstr "'coor' ファイルのサイズはトポロジーファイルに保存された値と異なります"
 #, c-format
 msgstr "ベクトルマップ <%s@%s>のためトポロジーを再作成してください"
 msgstr ""
@@ -3608,86 +3612,96 @@
 msgstr "ベクトルマップ <%s> はレベル >= 2 で開かれていません"
 #, fuzzy, c-format
 msgstr "���"
 #, fuzzy, c-format
 msgstr "���"
 msgstr ""
 #, fuzzy, c-format
 msgstr "���"
+#, fuzzy, c-format
+msgstr " pj 原因を初期化できません: %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "���"
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr "ドライバー <%s> をスタートできません"
 #, fuzzy, c-format
 msgstr "���"
-#: ../lib/vector/Vlib/ascii.c:453
+#: ../lib/vector/Vlib/ascii.c:466
 #, c-format
 msgid "Feature has more categories. Only first category (%d) is exported."
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:463
+#: ../lib/vector/Vlib/ascii.c:476
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
 msgstr "�������: ����� �����������n"
-#: ../lib/vector/Vlib/ascii.c:490
+#: ../lib/vector/Vlib/ascii.c:503
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
 msgstr "���"
-#: ../lib/vector/Vlib/ascii.c:570
+#: ../lib/vector/Vlib/ascii.c:583
 msgid "Unknown format"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:579
+#: ../lib/vector/Vlib/ascii.c:592
 msgid "Topology not available, unable to process areas"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:592
+#: ../lib/vector/Vlib/ascii.c:605
 #, fuzzy, c-format
 msgid "Unable to get boundary of area id %d"
 msgstr "���"
-#: ../lib/vector/Vlib/ascii.c:604
+#: ../lib/vector/Vlib/ascii.c:617
 #, fuzzy, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
 msgstr "���"
@@ -3844,59 +3858,54 @@
 msgid "Unable to open select cursor: %s"
 msgstr "選択カーソルを開けません: '%s'"
-#: ../lib/nviz/render.c:108
+#: ../lib/nviz/render.c:104
 msgid "Bad server connection"
 msgstr "サーバ接続がよくありません"
-#: ../lib/nviz/render.c:117
+#: ../lib/nviz/render.c:113
 msgid "Unable to create rendering context"
 msgstr "レンダリングコンテキストを作成できません"
-#: ../lib/nviz/lights.c:144
+#: ../lib/nviz/lights.c:174
 msgid "Unable to define new light"
 msgstr "新しいライトを定義できません"
-#: ../lib/nviz/position.c:50
+#: ../lib/nviz/position.c:56
 msgid "Unable to set focus"
 msgstr "フォーカスを設置できません"
-#: ../lib/nviz/nviz.c:78
+#: ../lib/nviz/nviz.c:105
 #, c-format
 msgid "Invalid color (%s), using \"white\" as default"
 msgstr "不正なカラー (%s), \"白\" をデフォルト値として使用しています"
-#: ../lib/nviz/change_view.c:108
-#, c-format
-msgid "Invalid view position coordinates, using %f,%f"
-msgstr "不正な視点位置座標,用法は %f,%f"
-#: ../lib/nviz/map_obj.c:65
+#: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
 msgstr "これ以上サーフェスをロードできません!"
-#: ../lib/nviz/map_obj.c:94
+#: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
 msgstr "これ以上ベクトルラインマップをロードできません!"
-#: ../lib/nviz/map_obj.c:103 ../lib/nviz/map_obj.c:134
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, c-format
 msgid "Error loading vector map <%s>"
 msgstr "ベクトルマップ <%s> をロードできません"
-#: ../lib/nviz/map_obj.c:122
+#: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
 msgstr "これ以上ベクトルポイントマップをロードできません!"
-#: ../lib/nviz/map_obj.c:149
+#: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
 msgstr "これ以上ロードできません!"
-#: ../lib/nviz/map_obj.c:158
+#: ../lib/nviz/map_obj.c:152
 #, c-format
 msgid "Error loading 3d raster map <%s>"
 msgstr "3D ラスターマップ <%s> をロードできません"
-#: ../lib/nviz/map_obj.c:166
+#: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
 msgstr "Nviz_new_map_obj(): サポートされていないデータタイプ"
@@ -4248,7 +4257,7 @@
 msgid "The total sum of the water budget is significant larger then 0: %g\n"
 msgstr ""
-#: ../lib/init/grass.py:145
+#: ../lib/init/grass.py:146
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4256,97 +4265,97 @@
 "用例:\n"
-#: ../lib/init/grass.py:147
+#: ../lib/init/grass.py:148
 msgid "print this help message"
 msgstr ""
-#: ../lib/init/grass.py:148
+#: ../lib/init/grass.py:149
 msgid "show version information and exit"
 msgstr ""
-#: ../lib/init/grass.py:149
+#: ../lib/init/grass.py:150
 msgid "create given mapset if it doesn't exist"
 msgstr ""
-#: ../lib/init/grass.py:150
+#: ../lib/init/grass.py:151
 msgid "use text based interface"
 msgstr ""
-#: ../lib/init/grass.py:151 ../lib/init/grass.py:153 ../lib/init/grass.py:155
+#: ../lib/init/grass.py:152 ../lib/init/grass.py:154 ../lib/init/grass.py:156
 #, fuzzy
 msgid "and set as default"
 msgstr "デフォルトの許可"
-#: ../lib/init/grass.py:152
+#: ../lib/init/grass.py:153
 msgid "use graphical user interface ($DEFAULT_GUI by default)"
 msgstr ""
-#: ../lib/init/grass.py:154
+#: ../lib/init/grass.py:155
 msgid "use wxPython based graphical user interface"
 msgstr ""
-#: ../lib/init/grass.py:157
+#: ../lib/init/grass.py:158
 msgid "initial database (path to GIS data)"
 msgstr ""
-#: ../lib/init/grass.py:158
+#: ../lib/init/grass.py:159
 #, fuzzy
 msgid "initial location"
 msgstr ""
 "\n"
 "無効な投影法\n"
-#: ../lib/init/grass.py:159
+#: ../lib/init/grass.py:160
 msgid "initial mapset"
 msgstr ""
-#: ../lib/init/grass.py:160
+#: ../lib/init/grass.py:161
 msgid "fully qualified initial mapset directory"
 msgstr ""
-#: ../lib/init/grass.py:161
+#: ../lib/init/grass.py:162
 msgid "Environment variables relevant for startup"
 msgstr ""
-#: ../lib/init/grass.py:162
+#: ../lib/init/grass.py:163
 msgid "select GUI (text, gui, wxpython)"
 msgstr ""
-#: ../lib/init/grass.py:163
+#: ../lib/init/grass.py:164
 msgid "set wish shell name to override 'wish'"
 msgstr ""
-#: ../lib/init/grass.py:164
+#: ../lib/init/grass.py:165
 msgid "set html web browser for help pages"
 msgstr ""
-#: ../lib/init/grass.py:165
+#: ../lib/init/grass.py:166
 msgid "set additional path(s) to local GRASS modules"
 msgstr ""
-#: ../lib/init/grass.py:166
+#: ../lib/init/grass.py:167
 msgid "shell script to be processed as batch job"
 msgstr ""
-#: ../lib/init/grass.py:167
+#: ../lib/init/grass.py:168
 msgid "set python shell name to override 'python'"
 msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:188
 #, fuzzy
 msgid "Unable to create temporary directory! Exiting."
 msgstr "仮の画像を割り当てられません"
-#: ../lib/init/grass.py:357
+#: ../lib/init/grass.py:356
 msgid "Searched for a web browser, but none found"
 msgstr ""
-#: ../lib/init/grass.py:376
+#: ../lib/init/grass.py:375
 #, fuzzy
 msgid "Hit RETURN to continue"
 msgstr "続行のためにリターンを押す -->"
-#: ../lib/init/grass.py:405
+#: ../lib/init/grass.py:404
 msgid ""
 "The python command does not work as expected!\n"
 "Please check your GRASS_PYTHON environment variable.\n"
@@ -4356,7 +4365,7 @@
 "Hit RETURN to continue.\n"
 msgstr ""
-#: ../lib/init/grass.py:417
+#: ../lib/init/grass.py:416
 msgid ""
 "It appears that the X Windows system is not active.\n"
 "A graphical based user interface is not supported.\n"
@@ -4365,34 +4374,34 @@
 msgstr ""
-#: ../lib/init/grass.py:459 ../lib/init/grass.py:472
+#: ../lib/init/grass.py:458 ../lib/init/grass.py:471
 #, fuzzy, python-format
 msgid "<%s> is not a valid GRASS location"
 msgstr "<%s> オプションは無効です\n"
-#: ../lib/init/grass.py:464
+#: ../lib/init/grass.py:463
 #, python-format
 msgid "The location <%s> does not exist. Please create it first."
 msgstr ""
-#: ../lib/init/grass.py:470
+#: ../lib/init/grass.py:469
 msgid "Missing WIND file fixed"
 msgstr ""
-#: ../lib/init/grass.py:484
+#: ../lib/init/grass.py:483
 msgid ""
 "GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
 "Interactive startup needed."
 msgstr ""
-#: ../lib/init/grass.py:498
+#: ../lib/init/grass.py:497
 #, python-format
 msgid ""
 "Invalid user interface specified - <%s>.\n"
 "Use the --help option to see valid interface names."
 msgstr ""
-#: ../lib/init/grass.py:511
+#: ../lib/init/grass.py:510
 msgid ""
 "Error in GUI startup. If necessary, please report this error to the GRASS "
 "developers.\n"
@@ -4401,20 +4410,20 @@
 "Hit RETURN to continue..."
 msgstr ""
-#: ../lib/init/grass.py:521
+#: ../lib/init/grass.py:520
 msgid ""
 "Received EXIT message from GUI.\n"
 "GRASS is not started. Bye."
 msgstr ""
-#: ../lib/init/grass.py:524
+#: ../lib/init/grass.py:523
 #, fuzzy
 msgid ""
 "Invalid return code from GUI startup script.\n"
 msgstr "このエラーをGRASS開発者に報告してください.\n"
-#: ../lib/init/grass.py:534
+#: ../lib/init/grass.py:533
 msgid ""
 "Error reading data path information from g.gisenv.\n"
 "GISDBASE=%(gisbase)s\n"
@@ -4424,31 +4433,31 @@
 "Check the <%s(file)> file."
 msgstr ""
-#: ../lib/init/grass.py:555
+#: ../lib/init/grass.py:554
 #, python-format
 msgid ""
 "%(user)s is currently running GRASS in selected mapset (file %(file)s "
 "found). Concurrent use not allowed."
 msgstr ""
-#: ../lib/init/grass.py:559
+#: ../lib/init/grass.py:558
 #, python-format
 msgid ""
 "Unable to properly access \"%s\"\n"
 "Please notify system personel."
 msgstr ""
-#: ../lib/init/grass.py:570
+#: ../lib/init/grass.py:569
 #, fuzzy
 msgid "Building user fontcap..."
 msgstr "グラフを作成しています..."
-#: ../lib/init/grass.py:599
+#: ../lib/init/grass.py:598
 #, fuzzy
 msgid "The SHELL variable is not set"
 msgstr "GISRC - 変数が設定されていません"
-#: ../lib/init/grass.py:609
+#: ../lib/init/grass.py:608
 #, python-format
 msgid ""
 "Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -4457,98 +4466,93 @@
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
-#: ../lib/init/grass.py:614
+#: ../lib/init/grass.py:613
 #, python-format
 msgid "Change file permission to 'executable' for '%s'"
 msgstr ""
-#: ../lib/init/grass.py:616
+#: ../lib/init/grass.py:615
 #, python-format
 msgid "Executing '%s' ..."
 msgstr ""
-#: ../lib/init/grass.py:623
+#: ../lib/init/grass.py:620
 #, python-format
+msgid "Execution of '%s' finished."
+msgstr ""
+#: ../lib/init/grass.py:625
+#, python-format
 msgid "GRASS GUI should be '%s'"
 msgstr ""
-#: ../lib/init/grass.py:667
+#: ../lib/init/grass.py:669
 msgid "GRASS homepage:"
 msgstr ""
-#: ../lib/init/grass.py:668
+#: ../lib/init/grass.py:670
 msgid "This version running through:"
 msgstr ""
-#: ../lib/init/grass.py:670
+#: ../lib/init/grass.py:672
 #, fuzzy
 msgid "Help is available with the command:"
 msgstr "コマンドのヘルプが利用できません [%s]\n"
-#: ../lib/init/grass.py:671
+#: ../lib/init/grass.py:673
 msgid "See the licence terms with:"
 msgstr ""
-#: ../lib/init/grass.py:674
+#: ../lib/init/grass.py:676
 msgid "If required, restart the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:676
+#: ../lib/init/grass.py:678
 msgid "Start the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:678
+#: ../lib/init/grass.py:680
 msgid "When ready to quit enter:"
 msgstr ""
-#: ../lib/init/grass.py:781
+#: ../lib/init/grass.py:783
 msgid "Failed to start shell '%s'"
-#: ../lib/init/grass.py:785
+#: ../lib/init/grass.py:787
 #, python-format
 msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
 msgstr ""
-#: ../lib/init/grass.py:786 ../lib/init/grass.py:791
+#: ../lib/init/grass.py:788 ../lib/init/grass.py:793
 msgid "Goodbye from GRASS GIS"
 msgstr ""
-#: ../lib/init/grass.py:789
+#: ../lib/init/grass.py:791
 #, fuzzy
 msgid "Done."
 msgstr "無し"
-#: ../lib/init/grass.py:795
+#: ../lib/init/grass.py:797
 #, fuzzy
 msgid "Cleaning up temporary files..."
 msgstr "一時ファイルが開けません"
-#: ../lib/init/grass.py:938
+#: ../lib/init/grass.py:940
 msgid "Starting GRASS GIS..."
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:84
+#: ../lib/rst/interp_float/output2d.c:106
 #, c-format
 msgid "First change your rows number to nsizr! %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:91
+#: ../lib/rst/interp_float/output2d.c:113
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:99
-#, c-format
-msgid "Rows changed from %d to %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:105
-#, c-format
-msgid "Cols changed from %d to %d"
-msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:111
 msgid ""
@@ -4562,25 +4566,25 @@
 "cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:60
+#: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:86
+#: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
 msgid "First change your rows number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:93
+#: ../lib/rst/interp_float/resout2d.c:110
 #, c-format
 msgid "First change your columns number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:247
+#: ../lib/rst/interp_float/resout2d.c:264
 msgid "No color table for input raster map -- will not create color table"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:458
 msgid "Changing the region back to initial..."
 msgstr ""
@@ -4741,7 +4745,7 @@
 msgid "Window replacing the default"
 msgstr "ウインドウはデフォルトを置換しています"
-#: ../lib/g3d/g3dhistory.c:42
+#: ../lib/g3d/g3dhistory.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
 msgstr "マップセット [%s]内から [%s] の履歴を取得出来ません"
@@ -4975,12 +4979,12 @@
 msgstr "カラーテーブルの範囲がデータと一致しません (mincol=%d, maxcol=%d"
-#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:771
+#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:772
 #, c-format
 msgid "Translating colors from raster map <%s>..."
 msgstr "ラスターマップ <%s> からカラーを転換しています..."
-#: ../lib/ogsf/Gs3.c:1005
+#: ../lib/ogsf/Gs3.c:1007
 msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
 "このプログラムにビューは保存されていません, 不一致がある可能性があります"
@@ -5003,22 +5007,32 @@
 msgid "Bitmap mismatch"
 msgstr "ビットマップは不一致です "
-#: ../lib/ogsf/GS2.c:1643
+#: ../lib/ogsf/GS2.c:1198
 #, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1217
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1640
+#, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr "ラスターマップ <%s> はこの領域外です. ロードに失敗しました."
-#: ../lib/ogsf/GS2.c:1723 ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1737
-#: ../lib/ogsf/GS2.c:1746 ../lib/ogsf/GS2.c:1754 ../lib/ogsf/GS2.c:1764
-#: ../lib/ogsf/GS2.c:1812
+#: ../lib/ogsf/GS2.c:1720 ../lib/ogsf/GS2.c:1726 ../lib/ogsf/GS2.c:1734
+#: ../lib/ogsf/GS2.c:1743 ../lib/ogsf/GS2.c:1751 ../lib/ogsf/GS2.c:1761
+#: ../lib/ogsf/GS2.c:1809
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
 msgstr "GS_load_att_map(): メモリ不足. マップをロードできません"
-#: ../lib/ogsf/GS2.c:1840
+#: ../lib/ogsf/GS2.c:1837
 msgid "Loading failed"
 msgstr "読み込みに失敗しました"
-#: ../lib/ogsf/GS2.c:1844
+#: ../lib/ogsf/GS2.c:1841
 msgid "Error finding range"
 msgstr "範囲が見つかりません"
@@ -5124,7 +5138,7 @@
 msgstr "不正なテーブルマップ名 <%s>. 文字 <%c> は許可されていません.\n"
-#: ../lib/db/dbmi_base/login.c:112
+#: ../lib/db/dbmi_base/login.c:111
 msgid "Login file corrupted"
 msgstr ""
@@ -5739,6 +5753,9 @@
 msgstr "グループ <%s> のサブグループ <%s> は次のラスターマップを参照します\n"
+#~ msgstr "不正な視点位置座標,用法は %f,%f"
 #~ msgstr "不明なロケーション"
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_ko.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ko\n"
 "PO-Revision-Date: 2005-12-22 14:49+0100\n"
 "Last-Translator: Huidae Cho\n"
 "Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -59,16 +59,24 @@
 msgstr "Datum %s 테이블파일을 열 수 없습니다"
 msgstr ""
 msgid ""
 "raster maps"
 msgstr ""
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -450,25 +458,25 @@
 #, c-format
 msgstr ""
@@ -714,29 +722,21 @@
 msgstr "임시파일을 열 수 없습니다"
 #, fuzzy, c-format
 msgstr "'%s' 디버그파일을 열 수 없습니다"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-msgstr ""
-msgstr ""
@@ -787,7 +787,7 @@
 #, c-format
@@ -1162,12 +1162,12 @@
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -1688,23 +1688,27 @@
 msgstr ""
+msgstr ""
 msgid "Color"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Units"
 msgstr ""
@@ -1739,11 +1743,11 @@
 msgid "SYNOPSIS"
 msgstr ""
 msgid "Flags"
 msgstr ""
 msgid "Parameters"
 msgstr ""
@@ -2205,28 +2209,28 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -2422,12 +2426,12 @@
 msgstr ""
 #, fuzzy
 msgstr ""
@@ -2492,12 +2496,12 @@
 msgstr ""
 #, fuzzy
 #, fuzzy
@@ -2630,20 +2634,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3038,44 +3042,44 @@
 msgstr ""
 msgstr ""
 #, fuzzy
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -3122,91 +3126,91 @@
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3216,14 +3220,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3247,7 +3251,7 @@
 msgstr ""
 #, fuzzy, c-format
@@ -3395,7 +3399,7 @@
 #, fuzzy, c-format
@@ -3443,7 +3447,7 @@
 #, fuzzy, c-format
@@ -3463,41 +3467,41 @@
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -3541,87 +3545,97 @@
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "알려지지 않은 벡터타입입니다"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3776,62 +3790,57 @@
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -4129,97 +4138,97 @@
 msgstr ""
 msgid "Usage"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 #, fuzzy
 msgstr "취소를 원하시면 RETURN을 누르세요\n"
 msgid ""
@@ -4229,7 +4238,7 @@
 msgstr ""
 msgid ""
@@ -4238,34 +4247,34 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4274,19 +4283,19 @@
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
@@ -4296,29 +4305,29 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgid ""
@@ -4327,95 +4336,90 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 msgid "Done."
 msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 msgid ""
@@ -4429,25 +4433,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4605,7 +4609,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -4836,12 +4840,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -4863,22 +4867,32 @@
 msgstr ""
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4991,7 +5005,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_lv.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_lv\n"
 "PO-Revision-Date: 2006-12-09 01:00+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian <grass-translations at lists.osgeo.org>\n"
@@ -65,11 +65,11 @@
 msgstr "neispējami mainīt direktoriju uz %s"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -78,6 +78,14 @@
 "G_set_window(): projekcija/zona atšķiras no tās kas ir tekoši atverajamajiem "
 "rastra failiem"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -466,25 +474,25 @@
 #, fuzzy, c-format
 msgstr "Ieejas vektors '%s' nav atrasts"
@@ -743,29 +751,21 @@
 msgstr "Nevar atvērt vēsturi vektoram '%s'"
 #, fuzzy, c-format
 msgstr "nevar ierakstīt vēstures informāciju priekš [%s]"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-msgstr ""
-msgstr ""
@@ -816,7 +816,7 @@
 #, fuzzy, c-format
@@ -1193,12 +1193,12 @@
 msgstr ""
 " Tikai %d%% no loga ir saglabāts \"%s\" pārklājuma ar tekošo GRASS logu."
 #, fuzzy, c-format
 msgstr "nevar izvaidot karšu biblotēkas elemntut %s (%s)"
 #, fuzzy, c-format
@@ -1750,23 +1750,27 @@
 msgstr ""
+msgstr ""
 msgid "Color"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Units"
 msgstr ""
@@ -1802,14 +1806,14 @@
 msgid "SYNOPSIS"
 msgstr ""
 #, fuzzy
 msgid "Flags"
 msgstr ""
 "\n"
 "Karogi:\n"
 #, fuzzy
 msgid "Parameters"
 msgstr ""
@@ -2308,23 +2312,23 @@
 msgstr "%s izpildīts. %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "KARÅ U BIBLOTÄ’KA%s - pieeja liegta"
 #, c-format
 msgstr "KARÅ U KOPA %s nav atrasta"
 #, fuzzy
 msgstr ""
@@ -2332,7 +2336,7 @@
 "()\n"
@@ -2529,12 +2533,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Neiespējami atvērt failu %s iekš %s"
 msgstr ""
@@ -2599,12 +2603,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
 #, fuzzy
@@ -2739,20 +2743,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3158,47 +3162,47 @@
 msgstr ""
 #, fuzzy
 msgstr "Saglabājam/reģistrējam līnijas"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "\r%d pirmatnējie dati reģistrēti      \n"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Veidojam topoloģiju... \n"
 #, fuzzy, c-format
 msgstr "Topoloģija tika izveidota.\n"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Pievienot salas"
 #, fuzzy
 msgstr "Pievienot centroīdus"
@@ -3246,91 +3250,91 @@
 #, fuzzy, c-format
 msgstr "Kartes nosaukums nav SQL savietojams."
 #, fuzzy, c-format
 msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
 #, fuzzy, c-format
 msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "Niespējami izveidot atkarību failu [%s iekš %s]"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3340,14 +3344,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3372,7 +3376,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nevar atvērt datubāzi %s"
@@ -3531,7 +3535,7 @@
 #, fuzzy, c-format
@@ -3583,7 +3587,7 @@
 #, fuzzy, c-format
@@ -3603,43 +3607,43 @@
 #, fuzzy, c-format
 msgstr "nav %s faili pieejami pašreizējā karšu biblotēkā\n"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr ""
 "Krāsas paremetru fails atšķiras no vērtībām kuras saglabātas topo failā."
 #, fuzzy, c-format
 msgstr "Lūdzu pārveido topoloģiju vektoram '%s@%s'"
 #, fuzzy
 msgstr ""
@@ -3685,87 +3689,97 @@
 #, fuzzy, c-format
 msgstr "Nederīgs histogrammas fails priekš [%s iekš %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Neiespējami atvērt failu %s iekš %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "nezināns interpolācijas tips"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nevar atvērt 'temp'/pagaidu failu"
 #, fuzzy, c-format
@@ -3924,62 +3938,57 @@
 msgstr ""
 #, fuzzy
 msgstr "neiespējami izveidot jaunu procesu"
 #, fuzzy
 #, fuzzy
 msgstr "Neisespējami atvērt %s"
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "eksistējošām rastra kartēm %d"
 msgstr ""
@@ -4286,7 +4295,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4294,97 +4303,97 @@
 "Pieleitojums:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "lai apstiprinātu noklusēto"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "nederīga projekcija\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Neiespējami piešķirt atmiņu\n"
 msgstr ""
 #, fuzzy
 msgstr "spied ENTER lai turpinātu -->"
 msgid ""
@@ -4394,7 +4403,7 @@
 msgstr ""
 msgid ""
@@ -4403,34 +4412,34 @@
 msgstr ""
 msgstr "Atvainojiet, <%s> ir nedrīgs parametrs\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4439,20 +4448,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "Lūdzu dod ziņu GRASS izstrādātājiem par šo kļūdu.\n"
 msgid ""
@@ -4462,31 +4471,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy
 msgstr "GISRC - mainīgais nav norādīts"
 #, python-format
 msgid ""
@@ -4495,98 +4504,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Nav pieejama palīdzība komandai [%s]\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "neviens"
 #, fuzzy
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 msgid ""
@@ -4600,25 +4604,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4776,7 +4780,7 @@
 msgstr "Logs aizvieto noklusēto"
 #, c-format
 msgstr ""
@@ -5009,12 +5013,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -5036,23 +5040,33 @@
 msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
 msgstr ""
 #, fuzzy
 msgstr "Pieslēgšanās izgāzusies\n"
 msgstr ""
@@ -5167,7 +5181,7 @@
 msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Zīme <%c> nav atļauta.\n"
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_ml.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ml\n"
 "PO-Revision-Date: 2010-08-24 11:31+0530\n"
 "Last-Translator: Mohammed Rashad <rashadkm at gmail.com>\n"
 "Language-Team: GRASS Malayalam Translation Team <rashadkm at gmail.com>\n"
@@ -60,16 +60,24 @@
 msgstr "റാസ്റ്റെർ മാപ്പ് തുറക്കാൻ പറ്റുനില്ല <%s>"
 msgstr ""
 msgid ""
 "raster maps"
 msgstr ""
+msgstr ""
+msgstr ""
 #, c-format
@@ -448,25 +456,25 @@
 #, c-format
 msgstr "റാസ്റ്റെർ മാപ്പ് <%s> കണ്മാനില്ല"
@@ -709,29 +717,21 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "ടേബിലിന്റെ പട്ടിക ഡേറ്റാബേയ്സിൽ നിന്ന് വായിക്കാൻ പട്ടുന്നില്ല <%s>"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-msgstr ""
-msgstr ""
@@ -782,7 +782,7 @@
 #, c-format
@@ -1157,12 +1157,12 @@
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
@@ -1678,23 +1678,27 @@
 msgstr ""
+msgstr ""
 msgid "Color"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Units"
 msgstr ""
@@ -1729,11 +1733,11 @@
 msgid "SYNOPSIS"
 msgstr ""
 msgid "Flags"
 msgstr ""
 msgid "Parameters"
 msgstr ""
@@ -2195,28 +2199,28 @@
 msgstr "%s കഴിഞു. %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -2403,11 +2407,11 @@
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
@@ -2606,20 +2610,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3002,43 +3006,43 @@
 msgstr ""
 msgstr "പ്രാജീനമായത് രേഖപ്പെടുത്തുന്നു..."
 msgstr "വെക്റ്റർ മാപ്പ് വായിക്കാൻ പട്ടുന്നില്ല"
 #, c-format
 msgstr "%d പ്രാജീനമായത് രേഖപ്പെടുത്തി"
 #, c-format
 msgstr "%d അഗ്രങൾ രേഖപ്പെടുത്തി"
 msgstr "ചതുരയളവ് പണിയുന്നു..."
 #, c-format
 msgstr "%d ചതുരയളവ് പണിതു"
 #, c-format
 msgstr "%d ചെറു ദ്വീപുകൾ പണിതു"
 msgstr "ദ്വീപുകൾ കൂട്ടിചേർക്കുന്നു..."
 msgstr ""
@@ -3083,91 +3087,91 @@
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
@@ -3177,14 +3181,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3207,7 +3211,7 @@
 msgstr ""
 #, c-format
 msgstr "കളം <%s> ടേബിളിൽ <%s> കാണ്മനില്ല"
@@ -3351,7 +3355,7 @@
 msgstr ""
 #, c-format
 msgstr "വെക്റ്റർ അടയ്ക്കാൻ പറ്റുന്നില്ല <%s>"
@@ -3399,7 +3403,7 @@
 #, c-format
 msgstr ""
@@ -3419,41 +3423,41 @@
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -3497,86 +3501,96 @@
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
+#, fuzzy, c-format
+msgstr "pj ആരംബിക്കാൻ സധികുന്നില്ല: %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr "ഡ്രയ്വ്വർ തുടങ്ങാൻ സാധിക്കുന്നില്ല <%s>"
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "തിരഞ്ഞെടുത്ത രേഖകൾ ടേബിളിൽ നിന്ന് എടുക്കാൻ സധികുനില്ല <%s>"
 #, fuzzy, c-format
 msgstr "കളം കണ്മനില്ല <%s>"
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "ടേബിൾ നിന്ന് ഡേറ്റ എടുക്കാൻ പറ്റുന്നില്ല <%s>"
 #, c-format
 msgstr ""
@@ -3729,59 +3743,54 @@
 msgstr "ഫയൽ തുറക്കൻ പറ്റുന്നില്ല %s"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -4079,95 +4088,95 @@
 msgstr ""
 msgid "Usage"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid ""
@@ -4177,7 +4186,7 @@
 msgstr ""
 msgid ""
@@ -4186,34 +4195,34 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4222,19 +4231,19 @@
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
 "Please advise GRASS developers of this error."
 msgstr ""
 msgid ""
@@ -4244,30 +4253,30 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr ""
 #, python-format
 msgid ""
@@ -4276,95 +4285,90 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 msgid "Done."
 msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 msgid ""
@@ -4378,25 +4382,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4551,7 +4555,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -4780,12 +4784,12 @@
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -4807,22 +4811,32 @@
 msgstr ""
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4927,7 +4941,7 @@
 msgstr "അസാധുവായ ടേബിൾ മാപ്പിന്റെ പേർ <%s> ഈ അക്ഷരം അനുവദിക്കുന്നതല്ല <%c> \n"
 msgstr "ഗ്രാസ്സിലേക്ക് കയറുന്ന ഫയലിൽ പിശക്"
Modified: grass/trunk/locale/po/grasslibs_mr.po
--- grass/trunk/locale/po/grasslibs_mr.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_mr.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: Grass 6.0\n"
 "PO-Revision-Date: 2005-06-02 18:00+0530\n"
 "Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
 "Language-Team: Marathi <www.janabhaaratii.org.in>\n"
@@ -58,16 +58,24 @@
 msgstr "%s उघडता आले नाही"
 msgstr ""
 msgid ""
 "raster maps"
 msgstr ""
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "%s मिळाले नाही"
@@ -712,29 +720,21 @@
 msgid "Unable to open header file for raster map <%s@%s>"
 msgstr "temp फाइल उघडता आली नाही"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-msgstr ""
-msgstr ""
@@ -785,7 +785,7 @@
 #, fuzzy, c-format
@@ -1159,12 +1159,12 @@
 " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -1687,23 +1687,27 @@
 msgstr ""
+msgstr ""
 msgid "Color"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Units"
 msgstr ""
@@ -1738,11 +1742,11 @@
 msgid "SYNOPSIS"
 msgstr ""
 msgid "Flags"
 msgstr ""
 msgid "Parameters"
 msgstr ""
@@ -2204,28 +2208,28 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -2421,12 +2425,12 @@
 msgstr ""
 #, fuzzy
 msgstr ""
@@ -2491,12 +2495,12 @@
 msgstr ""
 #, fuzzy
 #, fuzzy
@@ -2629,20 +2633,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3036,44 +3040,44 @@
 msgstr ""
 msgstr ""
 #, fuzzy
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -3120,91 +3124,91 @@
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3214,14 +3218,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3245,7 +3249,7 @@
 msgstr ""
 #, fuzzy, c-format
@@ -3393,7 +3397,7 @@
 #, fuzzy, c-format
@@ -3441,7 +3445,7 @@
 #, fuzzy, c-format
@@ -3461,41 +3465,41 @@
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -3539,86 +3543,96 @@
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "%s उघडता आले नाही"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3773,62 +3787,57 @@
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -4126,97 +4135,97 @@
 msgstr ""
 msgid "Usage"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 #, fuzzy
 msgstr "पुढे जाण्यासाठी RETURN टाइप करा -->"
 msgid ""
@@ -4226,7 +4235,7 @@
 msgstr ""
 msgid ""
@@ -4235,34 +4244,34 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4271,19 +4280,19 @@
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
@@ -4293,29 +4302,29 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgid ""
@@ -4324,97 +4333,92 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "[%s] या कमांडसाठी कोणतीही मदत उपलब्ध नाही\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "काही नाही"
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 msgid ""
@@ -4428,25 +4432,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4604,7 +4608,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -4835,12 +4839,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -4862,22 +4866,32 @@
 msgstr ""
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_pl.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pl\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2010-07-17 19:05+0100\n"
 "Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
 "Language-Team: GRASS Translation Team\n"
@@ -63,16 +63,24 @@
 msgid "Unable to write quant rules for raster map <%s>"
 msgstr "Nie można utworzyć mapy rastrowej <%s>"
-#: ../lib/raster/set_window.c:46
+#: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
 msgstr ""
-#: ../lib/raster/set_window.c:117
+#: ../lib/raster/set_window.c:123
 msgid ""
 "Rast_set_read_window(): projection/zone differs from that of currently open "
 "raster maps"
 msgstr ""
+#: ../lib/raster/set_window.c:150
+msgid "Input window changed while maps are open for read"
+msgstr ""
+#: ../lib/raster/set_window.c:168
+msgid "Output window changed while maps are open for write"
+msgstr ""
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
@@ -459,25 +467,25 @@
 #: ../lib/raster/opencell.c:779 ../lib/raster/opencell.c:831
 #: ../lib/manage/do_rename.c:53 ../lib/manage/do_remove.c:53
 #: ../lib/gis/legal_name.c:91 ../lib/gis/legal_name.c:94
-#: ../lib/rst/interp_float/output2d.c:228
-#: ../lib/rst/interp_float/output2d.c:309
-#: ../lib/rst/interp_float/output2d.c:393
-#: ../lib/rst/interp_float/output2d.c:457
-#: ../lib/rst/interp_float/output2d.c:485
-#: ../lib/rst/interp_float/output2d.c:513
-#: ../lib/rst/interp_float/output2d.c:543
-#: ../lib/rst/interp_float/resout2d.c:188
-#: ../lib/rst/interp_float/resout2d.c:236
-#: ../lib/rst/interp_float/resout2d.c:279
-#: ../lib/rst/interp_float/resout2d.c:319
-#: ../lib/rst/interp_float/resout2d.c:378
-#: ../lib/rst/interp_float/resout2d.c:405
-#: ../lib/rst/interp_float/resout2d.c:429
-#: ../lib/rst/interp_float/resout2d.c:455 ../lib/ogsf/gsd_legend.c:239
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426 ../lib/ogsf/gsd_legend.c:239
 #: ../lib/ogsf/Gs3.c:127 ../lib/ogsf/Gs3.c:200 ../lib/ogsf/Gs3.c:283
 #: ../lib/ogsf/Gs3.c:356 ../lib/ogsf/Gs3.c:470 ../lib/ogsf/Gs3.c:565
-#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:757
-#: ../lib/ogsf/Gs3.c:826
+#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:758
+#: ../lib/ogsf/Gs3.c:828
 #, c-format
 msgid "Raster map <%s> not found"
 msgstr "Mapa rastrowa <%s> nie została znaleziona"
@@ -727,35 +735,21 @@
 msgstr "Nie można otworzyć pliku śledzenia błędu '%s'"
-#: ../lib/raster/history.c:115
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, fuzzy, c-format
 msgid "Unable to get history information for <%s@%s>"
 msgstr "Nie można zapisać historii dla [%s]"
-#: ../lib/raster/history.c:143
+#: ../lib/raster/history.c:162
 #, fuzzy, c-format
 msgid "Unable to write history information for <%s>"
-#: ../lib/raster/history.c:184
+#: ../lib/raster/history.c:235
 #, c-format
 msgid "generated by %s"
 msgstr ""
-#: ../lib/raster/history.c:232
-#, fuzzy
-msgid "Not enough room in history file to record command line"
-msgstr ""
-"W pliku historii nie ma wystarczająco dużo miejsca, aby zapisać wiersz "
-"poleceń."
-#: ../lib/raster/history.c:254
-#, fuzzy
-msgid "Not enough room in history file for command line (truncated)"
-msgstr ""
-"poleceń."
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
 #: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
 #: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
@@ -806,7 +800,7 @@
 #: ../lib/manage/do_rename.c:37 ../lib/manage/do_remove.c:37
 #: ../lib/vector/Vlib/legal_vname.c:115 ../lib/vector/Vlib/legal_vname.c:118
-#: ../lib/vector/Vlib/map.c:404 ../lib/vector/Vlib/open.c:197
+#: ../lib/vector/Vlib/map.c:403 ../lib/vector/Vlib/open.c:197
 #: ../lib/ogsf/Gv3.c:58 ../lib/ogsf/Gp3.c:58
 #, c-format
 msgid "Vector map <%s> not found"
@@ -1182,12 +1176,12 @@
 msgstr ""
-#: ../lib/gis/mapset_msc.c:60
+#: ../lib/gis/mapset_msc.c:61
 #, c-format
 msgid "Unable to make mapset element %s (%s): %s"
 msgstr "Nie można utworzyć elementu mapsetu %s (%s): %s"
-#: ../lib/gis/mapset_msc.c:64
+#: ../lib/gis/mapset_msc.c:65
 #, c-format
 msgid "Unable to access mapset element %s (%s): %s"
 msgstr "Nie można uzyskać dostępu do elementu mapsetu %s (%s): %s"
@@ -1731,23 +1725,27 @@
 msgid "Field separator"
 msgstr "Separator pól"
-#: ../lib/gis/parser_standard_options.c:455
+#: ../lib/gis/parser_standard_options.c:445
+msgid "Special characters: newline, space, comma, tab"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:456
 msgid "Color"
 msgstr "Kolor"
-#: ../lib/gis/parser_standard_options.c:456
+#: ../lib/gis/parser_standard_options.c:457
 msgid "Either a standard color name or R:G:B triplet"
 msgstr "Albo standardowa nazwa koloru albo R:G:B"
-#: ../lib/gis/parser_standard_options.c:465
+#: ../lib/gis/parser_standard_options.c:466
 msgid "Background color"
 msgstr "Kolor tła"
-#: ../lib/gis/parser_standard_options.c:467
+#: ../lib/gis/parser_standard_options.c:468
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
 msgstr "Albo standardowy kolor GRASS, R:G:B, lub \"none\""
-#: ../lib/gis/parser_standard_options.c:478
+#: ../lib/gis/parser_standard_options.c:479
 msgid "Units"
 msgstr ""
@@ -1782,11 +1780,11 @@
 msgid "SYNOPSIS"
 msgstr "SKŁADNIA"
-#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:146
+#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:147
 msgid "Flags"
 msgstr "Flagi"
-#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:156
+#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:157
 msgid "Parameters"
 msgstr "Parametry"
@@ -2260,28 +2258,28 @@
 msgid "%s complete. %s"
 msgstr "%s ukończone. %s"
-#: ../lib/gis/gisinit.c:55 ../lib/gis/gisinit.c:90
+#: ../lib/gis/gisinit.c:56 ../lib/gis/gisinit.c:91
 msgid ""
 "Incompatible library version for module. You need to rebuild GRASS or "
 "untangle multiple installations."
 msgstr ""
-#: ../lib/gis/gisinit.c:65
+#: ../lib/gis/gisinit.c:66
 #, c-format
 msgid "MAPSET %s - permission denied"
 msgstr "MAPSET %s - brak dostępu"
-#: ../lib/gis/gisinit.c:68
+#: ../lib/gis/gisinit.c:69
 #, c-format
 msgid "MAPSET %s not found"
 msgstr "MAPSET %s nie został znaleziony"
-#: ../lib/gis/gisinit.c:107
+#: ../lib/gis/gisinit.c:108
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
 msgstr "System nie został zainicjalizowany. Nie wywołano G_gisinit()"
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/vector/Vlib/ascii.c:187 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/ascii.c:200 ../lib/vector/Vlib/line.c:50
 #: ../lib/vector/neta/articulation_point.c:60
 #: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
 #: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
@@ -2469,12 +2467,12 @@
 msgid "Writing to file loaded to memory not supported"
 msgstr ""
-#: ../lib/vector/diglib/file.c:204
+#: ../lib/vector/diglib/file.c:205
 #, fuzzy
 msgid "Unable to load file to memory, file not open"
 msgstr "W %s nie można otworzyć pliku %s"
-#: ../lib/vector/diglib/file.c:219
+#: ../lib/vector/diglib/file.c:220
 msgid "Vector memory mode not supported, using 'AUTO'"
 msgstr ""
@@ -2538,11 +2536,11 @@
 msgid "%s: Area %d does not exist"
 msgstr "%s: Obszar %d nie istnieje"
-#: ../lib/vector/Vlib/write_nat.c:675 ../lib/vector/Vlib/write_ogr.c:298
+#: ../lib/vector/Vlib/write_nat.c:670 ../lib/vector/Vlib/write_ogr.c:298
 msgid "Attempt to delete dead feature"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:920
+#: ../lib/vector/Vlib/write_nat.c:910
 msgid "Attempt to restore alive feature"
 msgstr ""
@@ -2678,20 +2676,20 @@
 msgid "Not enough space in vector array"
 msgstr ""
-#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:313
-#: ../lib/vector/Vlib/map.c:440 ../lib/vector/Vlib/map.c:552
-#: ../lib/vector/Vlib/map.c:670 ../lib/vector/Vlib/map.c:768
+#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:312
+#: ../lib/vector/Vlib/map.c:439 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:669 ../lib/vector/Vlib/map.c:767
 #: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:347
-#: ../lib/vector/Vlib/ascii.c:301 ../lib/vector/Vlib/write_ogr.c:118
+#: ../lib/vector/Vlib/ascii.c:314 ../lib/vector/Vlib/write_ogr.c:118
 #: ../lib/rst/interp_float/vinput2d.c:79
 #, c-format
 msgid "Database connection not defined for layer %d"
 msgstr "Połączenie z bazą danych nie zostało zdefiniowane dla warstwy %d"
-#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:342
-#: ../lib/vector/Vlib/map.c:481 ../lib/vector/Vlib/map.c:703
+#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:341
+#: ../lib/vector/Vlib/map.c:480 ../lib/vector/Vlib/map.c:702
 #: ../lib/vector/Vlib/net.c:182 ../lib/vector/Vlib/net.c:352
-#: ../lib/vector/Vlib/ascii.c:313 ../lib/vector/Vlib/write_ogr.c:375
+#: ../lib/vector/Vlib/ascii.c:326 ../lib/vector/Vlib/write_ogr.c:375
 #: ../lib/vector/neta/utils.c:116 ../lib/vector/neta/timetables.c:133
 #: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/copy_tab.c:105
 #: ../lib/db/dbmi_client/copy_tab.c:126 ../lib/db/dbmi_client/db.c:46
@@ -3081,44 +3079,44 @@
 msgid "Request to find area outside nonexistent isle"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:523
+#: ../lib/vector/Vlib/build_nat.c:525
 #, fuzzy
 msgid "Registering primitives..."
 msgstr "Rejestrowanie prymitywów..."
-#: ../lib/vector/Vlib/build_nat.c:532
+#: ../lib/vector/Vlib/build_nat.c:534
 msgid "Unable to read vector map"
 msgstr "Nie można odczytać mapy wektorowej "
-#: ../lib/vector/Vlib/build_nat.c:576
+#: ../lib/vector/Vlib/build_nat.c:578
 #, c-format
 msgid "%d primitives registered"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:577
+#: ../lib/vector/Vlib/build_nat.c:579
 #, c-format
 msgid "%d vertices registered"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:588
+#: ../lib/vector/Vlib/build_nat.c:590
 msgid "Building areas..."
 msgstr "Tworzenie obszarów..."
-#: ../lib/vector/Vlib/build_nat.c:611
+#: ../lib/vector/Vlib/build_nat.c:613
 #, c-format
 msgid "%d areas built"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:612
+#: ../lib/vector/Vlib/build_nat.c:614
 #, c-format
 msgid "%d isles built"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:621
+#: ../lib/vector/Vlib/build_nat.c:623
 msgid "Attaching islands..."
 msgstr "Dołączanie wysp ..."
-#: ../lib/vector/Vlib/build_nat.c:636
+#: ../lib/vector/Vlib/build_nat.c:638
 msgid "Attaching centroids..."
 msgstr ""
@@ -3164,91 +3162,91 @@
 msgid "Unable to read vector map <%s>"
 msgstr "Nie można odczytać mapy wektorowej <%s>"
-#: ../lib/vector/Vlib/map.c:242 ../lib/vector/Vlib/map.c:386
-#: ../lib/vector/Vlib/open.c:692
+#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:385
+#: ../lib/vector/Vlib/open.c:691
 #, c-format
 msgid "Vector map name is not SQL compliant"
 msgstr "Nazwa mapy wektorowej nie jest zgodna z SQL."
-#: ../lib/vector/Vlib/map.c:246
+#: ../lib/vector/Vlib/map.c:245
 #, c-format
 msgid "Unable to find vector map <%s> in <%s>"
 msgstr "Nie można odnaleźć mapy wektorowej <%s> w <%s>"
-#: ../lib/vector/Vlib/map.c:258 ../lib/vector/Vlib/map.c:390
-#: ../lib/vector/Vlib/open.c:699
+#: ../lib/vector/Vlib/map.c:257 ../lib/vector/Vlib/map.c:389
+#: ../lib/vector/Vlib/open.c:698
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Mapa wektorowa <%s> już istnieje i zostanie nadpisana"
-#: ../lib/vector/Vlib/map.c:262 ../lib/vector/Vlib/open.c:704
+#: ../lib/vector/Vlib/map.c:261 ../lib/vector/Vlib/open.c:703
 #, c-format
 msgid "Unable to delete vector map <%s>"
 msgstr "Nie można usunąć mapy wektorowej <%s>"
-#: ../lib/vector/Vlib/map.c:282 ../lib/vector/Vlib/map.c:408
+#: ../lib/vector/Vlib/map.c:281 ../lib/vector/Vlib/map.c:407
 #, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
 msgstr "Nie można skopiować mapy wektorowej <%s> do <%s>"
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:457
-#: ../lib/vector/Vlib/map.c:695 ../lib/vector/Vlib/map.c:802
+#: ../lib/vector/Vlib/map.c:330 ../lib/vector/Vlib/map.c:456
+#: ../lib/vector/Vlib/map.c:694 ../lib/vector/Vlib/map.c:801
 #, c-format
 msgid "Unable to copy table <%s>"
 msgstr "Nie można skopiować tabeli <%s>"
-#: ../lib/vector/Vlib/map.c:347 ../lib/vector/Vlib/map.c:486
-#: ../lib/vector/Vlib/map.c:708
+#: ../lib/vector/Vlib/map.c:346 ../lib/vector/Vlib/map.c:485
+#: ../lib/vector/Vlib/map.c:707
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 msgstr "Nie można utworzyć indeksu dla tabeli <%s>, klucz <%s>"
-#: ../lib/vector/Vlib/map.c:471 ../lib/vector/Vlib/map.c:572
+#: ../lib/vector/Vlib/map.c:470 ../lib/vector/Vlib/map.c:571
 #, c-format
 msgid "Unable to delete table <%s>"
 msgstr "Nie można usunąć tabeli <%s>"
-#: ../lib/vector/Vlib/map.c:526
+#: ../lib/vector/Vlib/map.c:525
 #, c-format
 msgid "Invalid vector map name <%s>"
 msgstr "Niedozwolona nazwa mapy wektorowej  <%s>"
-#: ../lib/vector/Vlib/map.c:540
+#: ../lib/vector/Vlib/map.c:539
 #, c-format
 msgid "Unable to open header file for vector map <%s>"
 msgstr "Nie można otworzyć pliku nagłówka dla mapy wektorowej <%s>"
-#: ../lib/vector/Vlib/map.c:562
+#: ../lib/vector/Vlib/map.c:561
 #, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
 msgstr "Nie można odnaleźć tabeli <%s> podłączonej do mapy wektorowej <%s>"
-#: ../lib/vector/Vlib/map.c:579
+#: ../lib/vector/Vlib/map.c:578
 #, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
 msgstr "Tabela <%s>podłączona do mapy wektorowej <%s> nie istnieje"
-#: ../lib/vector/Vlib/map.c:592
+#: ../lib/vector/Vlib/map.c:591
 #, c-format
 msgid "Unable to open directory '%s'"
 msgstr "Nie można otworzyć katalogu '%s'"
-#: ../lib/vector/Vlib/map.c:606
+#: ../lib/vector/Vlib/map.c:605
 #, c-format
 msgid "Unable to delete file '%s'"
 msgstr "Nie można usunąć pliku '%s'"
-#: ../lib/vector/Vlib/map.c:623
+#: ../lib/vector/Vlib/map.c:622
 #, c-format
 msgid "Unable to rename directory '%s' to '%s'"
 msgstr "Nie można zmienić nazwy katalogu z '%s' na '%s'"
-#: ../lib/vector/Vlib/map.c:631
+#: ../lib/vector/Vlib/map.c:630
 #, c-format
 msgid "Unable to remove directory '%s'"
 msgstr "Nie można usunąć katalogu '%s'"
-#: ../lib/vector/Vlib/map.c:686 ../lib/vector/Vlib/map.c:787
+#: ../lib/vector/Vlib/map.c:685 ../lib/vector/Vlib/map.c:786
 #, c-format
 msgid "Unable to add database link for vector map <%s>"
 msgstr ""
@@ -3258,14 +3256,14 @@
 msgid "Unable to open coor file for vector map <%s>"
-#: ../lib/vector/Vlib/open_nat.c:155
+#: ../lib/vector/Vlib/open_nat.c:154
 #, c-format
 msgid ""
 "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
 "excess)"
 msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:159
+#: ../lib/vector/Vlib/open_nat.c:158
 #, c-format
 msgid ""
 "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
@@ -3288,7 +3286,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:204
-#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:488
+#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:501
 #, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr "Kolumna <%s> nie została znaleziona w tabeli <%s>"
@@ -3441,7 +3439,7 @@
 msgid "Unable to restore feature %d from vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/close.c:140
+#: ../lib/vector/Vlib/close.c:139
 #, c-format
 msgid "Unable to close vector <%s>"
 msgstr "Nie można zamknąć wektora <%s>"
@@ -3493,7 +3491,7 @@
 msgid "Unable to open spatial index file for vector map <%s>"
 msgstr "Nie można otworzyć pliku indeksu kategorii dla mapy wektorowej <%s>"
-#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:511
+#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:510
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
@@ -3513,41 +3511,41 @@
 msgid "Unable to open history file for vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:683
+#: ../lib/vector/Vlib/open.c:682
 #, c-format
 msgid "%s is not in the current mapset (%s)"
 msgstr "%s nie jest bieżącym mapsetem (%s)"
-#: ../lib/vector/Vlib/open.c:721
+#: ../lib/vector/Vlib/open.c:720
 #, c-format
 msgid "Unable to create vector map <%s>"
 msgstr "Nie można utworzyć mapy wektorowej <%s>"
-#: ../lib/vector/Vlib/open.c:731
+#: ../lib/vector/Vlib/open.c:730
 #, fuzzy, c-format
 msgid "Unable to open history file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:783
+#: ../lib/vector/Vlib/open.c:782
 #, fuzzy, c-format
 msgid "Unable to stat file <%s>"
 msgstr "Nie można otworzyć pliku <%s>"
-#: ../lib/vector/Vlib/open.c:842
+#: ../lib/vector/Vlib/open.c:841
 #, c-format
 msgid "unknown %d (update Vect_maptype_info)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:918
+#: ../lib/vector/Vlib/open.c:916
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:929 ../lib/vector/Vlib/open.c:1024
+#: ../lib/vector/Vlib/open.c:927 ../lib/vector/Vlib/open.c:1021
 #, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
 msgstr "Przebuduj topologiÄ™ dla mapy wektorowej <%s@%s>"
-#: ../lib/vector/Vlib/open.c:1013
+#: ../lib/vector/Vlib/open.c:1010
 msgid "Size of 'coor' file differs from value saved in sidx file"
 msgstr ""
@@ -3592,87 +3590,97 @@
 msgid "Vector map <%s> is not open on level >= 2"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:77
+#: ../lib/vector/Vlib/ascii.c:80
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
 msgstr "Nie można otworzyć nagłówka pliku dla [%s w %s]"
-#: ../lib/vector/Vlib/ascii.c:115
+#: ../lib/vector/Vlib/ascii.c:118
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
-#: ../lib/vector/Vlib/ascii.c:128
+#: ../lib/vector/Vlib/ascii.c:131
 msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:138
+#: ../lib/vector/Vlib/ascii.c:142
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
-#: ../lib/vector/Vlib/ascii.c:169
+#: ../lib/vector/Vlib/ascii.c:146
+#, fuzzy, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr "Nie można zainicjować pj ponieważ: %s"
+#: ../lib/vector/Vlib/ascii.c:149
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:182
 msgid "End of ASCII file reached before end of categories"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:179
+#: ../lib/vector/Vlib/ascii.c:192
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
-#: ../lib/vector/Vlib/ascii.c:222
+#: ../lib/vector/Vlib/ascii.c:235
 #, c-format
 msgid ""
 "Unexpected data in vector head:\n"
 "[%s]"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:256
+#: ../lib/vector/Vlib/ascii.c:269
 #, fuzzy, c-format
 msgid "Unknown keyword <%s> in vector head"
 msgstr "Nieznane słowo kluczowe %s w nagłówku wektora"
-#: ../lib/vector/Vlib/ascii.c:307 ../lib/db/dbmi_client/copy_tab.c:100
+#: ../lib/vector/Vlib/ascii.c:320 ../lib/db/dbmi_client/copy_tab.c:100
 #: ../lib/db/dbmi_client/copy_tab.c:120 ../lib/db/dbmi_client/db.c:41
 #, c-format
 msgid "Unable to start driver <%s>"
 msgstr "Nie można uruchomić sterownika <%s>"
-#: ../lib/vector/Vlib/ascii.c:413
+#: ../lib/vector/Vlib/ascii.c:426
 #, fuzzy, c-format
 msgid "Uknown feature type %d"
 msgstr "nieznany typ interpolacjinieznany typ interpolacji"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nie można wybrać rekordu z tabeli <%s> (klucz %s, gdzie %s)"
 #, fuzzy, c-format
 msgstr "Kolumna <%s> nie została znaleziona"
 #, fuzzy
 msgstr "nieznany operator"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nie można ustawić kategorii %d dla linii (id obiektu %d)"
 #, fuzzy, c-format
@@ -3828,59 +3836,54 @@
 msgstr "Nie można otworzyć kartoteki %s"
 msgstr "Wadliwe połączenie z serwerem"
 msgstr "Nie można utworzyć kontekstu renderowania"
 msgstr "Nie można zdefiniować nowego światła"
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -4178,96 +4181,96 @@
 msgstr ""
 msgid "Usage"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 msgstr ""
 msgid ""
@@ -4277,7 +4280,7 @@
 msgstr ""
 msgid ""
@@ -4286,34 +4289,34 @@
 msgstr ""
 msgstr "<%s> nie jest poprawnÄ… opcjÄ…\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4322,19 +4325,19 @@
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
@@ -4344,31 +4347,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy
 msgstr "GISRC - brak ustawień zmiennych"
 #, python-format
 msgid ""
@@ -4377,96 +4380,91 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "brak"
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4482,25 +4480,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4664,7 +4662,7 @@
 msgstr "aby zaakceptopwać domyślne"
 #, c-format
 msgstr "nie można pobrać informacji historii dla [%s] w mapsecie [%s]"
@@ -4894,12 +4892,12 @@
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -4921,23 +4919,33 @@
 msgstr ""
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr ""
 "Mapa rastrowa <%s> jest poza bieżącym regionem. Załadowanie nie powiodło się."
 msgstr ""
 msgstr "Ładowanie nie powiodło się."
 msgstr ""
@@ -5043,7 +5051,7 @@
 msgstr "Niedozwolona nazwa tabeli mapy <%s>. Znak <%c> jest niedozwolony.\n"
 msgstr "Uszkodzony plik logowania"
@@ -5643,6 +5651,18 @@
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
 msgstr "podgrupa <%s> grupy <%s> odnosi się do następujących map rastrowych\n"
+#, fuzzy
+#~ msgid "Not enough room in history file to record command line"
+#~ msgstr ""
+#~ "W pliku historii nie ma wystarczająco dużo miejsca, aby zapisać wiersz "
+#~ "poleceń."
+#, fuzzy
+#~ msgid "Not enough room in history file for command line (truncated)"
+#~ msgstr ""
+#~ "poleceń."
 #~ msgid "Unknown Location"
 #~ msgstr "Nieznane położenie"
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_pt.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pt\n"
 "PO-Revision-Date: 2007-06-18 22:26-0300\n"
 "Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail dot com>\n"
 "Language-Team: Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -65,11 +65,11 @@
 msgstr "Impossível mudar de diretório para %s"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -77,6 +77,14 @@
 msgstr ""
 "G_set_window(): projeção/zona difere daquela nos arquivos raster abertos"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "Vetor de entrada '%s' não encontrado"
@@ -741,35 +749,21 @@
 msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
 #, fuzzy, c-format
 msgstr "não consegui escrever os dados históricos para [%s]"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr ""
-"Não há espaço suficiente no arquivo de histórico para gravar a linha de "
-"comando."
-#, fuzzy
-msgstr ""
-"Não há espaço suficiente no arquivo de histórico para a linha de comando "
-"(truncada)."
@@ -820,7 +814,7 @@
 #, c-format
@@ -1197,12 +1191,12 @@
 msgstr "Apenas %d%% da janela salva em \"%s\" sobrepõe a janela atual do GRASS"
 #, fuzzy, c-format
 msgstr "não foi possível gerar o elemento  %s (%s) do mapset"
 #, fuzzy, c-format
@@ -1747,23 +1741,27 @@
 msgstr "Separador de Campos"
+msgstr ""
 msgid "Color"
 msgstr "Cor"
 msgstr "Um nome de cor padrão ou tripla R:G:B"
 msgstr "Cor de fundo"
 msgstr "Cor padrão do GRASS, tripla R:G:B ou \"none\""
 msgid "Units"
 msgstr ""
@@ -1798,11 +1796,11 @@
 msgid "SYNOPSIS"
 msgstr "RESUMO"
 msgid "Flags"
 msgstr "Opções"
 msgid "Parameters"
 msgstr "Parâmetros"
@@ -2283,23 +2281,23 @@
 msgstr "%s completo. %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "MAPSET %s - permissão negada"
 #, c-format
 msgstr "MAPSET %s não encontrado"
 #, fuzzy
 msgstr ""
@@ -2307,7 +2305,7 @@
 "()\n"
@@ -2504,12 +2502,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Impossível abrir arquivo %s"
 msgstr ""
@@ -2574,12 +2572,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Tentativa de remover área morta"
 #, fuzzy
@@ -2715,20 +2713,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3134,47 +3132,47 @@
 msgstr ""
 #, fuzzy
 msgstr "Registrando linhas: "
 #, fuzzy
 #, fuzzy, c-format
 msgstr "\r%d primitivas registradas      \n"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Construindo grafo ..."
 #, fuzzy, c-format
 msgstr "Grafo construído"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Anexando ilhas:"
 #, fuzzy
 msgstr "Anexando centróides:"
@@ -3222,91 +3220,91 @@
 #, fuzzy, c-format
 msgstr "Nome do mapa não obedece ao SQL"
 #, fuzzy, c-format
 msgstr "não foi possível abrir o mapa raster [%s em %s]"
 #, fuzzy, c-format
 msgstr "O vetor '%s' já existe e será sobrescrito."
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "Impossível abrir histórico para mapa vetorial %s"
 #, fuzzy, c-format
 msgstr "Impossível abrir topologia para mapa vetorial <%s>"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3316,14 +3314,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3348,7 +3346,7 @@
 msgstr "Campo de arco < 1"
 #, fuzzy, c-format
 msgstr "Impossível descrever tabela <%s>"
@@ -3505,7 +3503,7 @@
 #, fuzzy, c-format
@@ -3555,7 +3553,7 @@
 #, fuzzy, c-format
@@ -3575,42 +3573,42 @@
 #, fuzzy, c-format
 msgstr "não há arquivos <%s> disponíveis no mapset ativo\n"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Tamanho do arquivo 'coor' difere do valor gravado no arquivo topo."
 #, fuzzy, c-format
 msgstr "Favor reconstruir a topologia do vetor '%s@%s'"
 #, fuzzy
@@ -3656,87 +3654,97 @@
 #, fuzzy, c-format
 msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "não foi possível abrir o arquivo %s em %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Tipo de vetor desconhecido"
 #, fuzzy, c-format
 #, fuzzy, c-format
-#: ../lib/vector/Vlib/ascii.c:453
+#: ../lib/vector/Vlib/ascii.c:466
 #, c-format
 msgid "Feature has more categories. Only first category (%d) is exported."
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:463
+#: ../lib/vector/Vlib/ascii.c:476
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
-#: ../lib/vector/Vlib/ascii.c:490
+#: ../lib/vector/Vlib/ascii.c:503
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
-#: ../lib/vector/Vlib/ascii.c:570
+#: ../lib/vector/Vlib/ascii.c:583
 #, fuzzy
 msgid "Unknown format"
 msgstr "Erro desconhecido"
-#: ../lib/vector/Vlib/ascii.c:579
+#: ../lib/vector/Vlib/ascii.c:592
 msgid "Topology not available, unable to process areas"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:592
+#: ../lib/vector/Vlib/ascii.c:605
 #, fuzzy, c-format
 msgid "Unable to get boundary of area id %d"
 msgstr "Impossível ler arquivo de cabeçalho"
-#: ../lib/vector/Vlib/ascii.c:604
+#: ../lib/vector/Vlib/ascii.c:617
 #, fuzzy, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
@@ -3896,62 +3904,57 @@
 msgid "Unable to open select cursor: %s"
-#: ../lib/nviz/render.c:108
+#: ../lib/nviz/render.c:104
 msgid "Bad server connection"
 msgstr ""
-#: ../lib/nviz/render.c:117
+#: ../lib/nviz/render.c:113
 #, fuzzy
 msgid "Unable to create rendering context"
 msgstr "Impossível criar novo processo"
-#: ../lib/nviz/lights.c:144
+#: ../lib/nviz/lights.c:174
 #, fuzzy
 msgid "Unable to define new light"
-#: ../lib/nviz/position.c:50
+#: ../lib/nviz/position.c:56
 #, fuzzy
 msgid "Unable to set focus"
 msgstr "não consegui abrir [%s]"
-#: ../lib/nviz/nviz.c:78
+#: ../lib/nviz/nviz.c:105
 #, fuzzy, c-format
 msgid "Invalid color (%s), using \"white\" as default"
 msgstr "Símbolo de cor incorreto: '%s', usando padrão"
-#: ../lib/nviz/change_view.c:108
-#, c-format
-msgid "Invalid view position coordinates, using %f,%f"
-msgstr ""
-#: ../lib/nviz/map_obj.c:65
+#: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:94
+#: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:103 ../lib/nviz/map_obj.c:134
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, fuzzy, c-format
 msgid "Error loading vector map <%s>"
 msgstr "Erro abrindo mapa g3d <%s>"
-#: ../lib/nviz/map_obj.c:122
+#: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:149
+#: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:158
+#: ../lib/nviz/map_obj.c:152
 #, fuzzy, c-format
 msgid "Error loading 3d raster map <%s>"
 msgstr "ERRO abrindo mapa raster %s"
-#: ../lib/nviz/map_obj.c:166
+#: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
 msgstr ""
@@ -4261,7 +4264,7 @@
 msgid "The total sum of the water budget is significant larger then 0: %g\n"
 msgstr ""
-#: ../lib/init/grass.py:145
+#: ../lib/init/grass.py:146
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4269,97 +4272,97 @@
 "Uso:\n"
-#: ../lib/init/grass.py:147
+#: ../lib/init/grass.py:148
 msgid "print this help message"
 msgstr ""
-#: ../lib/init/grass.py:148
+#: ../lib/init/grass.py:149
 msgid "show version information and exit"
 msgstr ""
-#: ../lib/init/grass.py:149
+#: ../lib/init/grass.py:150
 msgid "create given mapset if it doesn't exist"
 msgstr ""
-#: ../lib/init/grass.py:150
+#: ../lib/init/grass.py:151
 msgid "use text based interface"
 msgstr ""
-#: ../lib/init/grass.py:151 ../lib/init/grass.py:153 ../lib/init/grass.py:155
+#: ../lib/init/grass.py:152 ../lib/init/grass.py:154 ../lib/init/grass.py:156
 #, fuzzy
 msgid "and set as default"
 msgstr "para aceitar os valores padrão"
-#: ../lib/init/grass.py:152
+#: ../lib/init/grass.py:153
 msgid "use graphical user interface ($DEFAULT_GUI by default)"
 msgstr ""
-#: ../lib/init/grass.py:154
+#: ../lib/init/grass.py:155
 msgid "use wxPython based graphical user interface"
 msgstr ""
-#: ../lib/init/grass.py:157
+#: ../lib/init/grass.py:158
 msgid "initial database (path to GIS data)"
 msgstr ""
-#: ../lib/init/grass.py:158
+#: ../lib/init/grass.py:159
 #, fuzzy
 msgid "initial location"
 msgstr ""
 "\n"
 "projeção inválida\n"
-#: ../lib/init/grass.py:159
+#: ../lib/init/grass.py:160
 msgid "initial mapset"
 msgstr ""
-#: ../lib/init/grass.py:160
+#: ../lib/init/grass.py:161
 msgid "fully qualified initial mapset directory"
 msgstr ""
-#: ../lib/init/grass.py:161
+#: ../lib/init/grass.py:162
 msgid "Environment variables relevant for startup"
 msgstr ""
-#: ../lib/init/grass.py:162
+#: ../lib/init/grass.py:163
 msgid "select GUI (text, gui, wxpython)"
 msgstr ""
-#: ../lib/init/grass.py:163
+#: ../lib/init/grass.py:164
 msgid "set wish shell name to override 'wish'"
 msgstr ""
-#: ../lib/init/grass.py:164
+#: ../lib/init/grass.py:165
 msgid "set html web browser for help pages"
 msgstr ""
-#: ../lib/init/grass.py:165
+#: ../lib/init/grass.py:166
 msgid "set additional path(s) to local GRASS modules"
 msgstr ""
-#: ../lib/init/grass.py:166
+#: ../lib/init/grass.py:167
 msgid "shell script to be processed as batch job"
 msgstr ""
-#: ../lib/init/grass.py:167
+#: ../lib/init/grass.py:168
 msgid "set python shell name to override 'python'"
 msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:188
 #, fuzzy
 msgid "Unable to create temporary directory! Exiting."
 msgstr "não consegui alocar memória\n"
-#: ../lib/init/grass.py:357
+#: ../lib/init/grass.py:356
 msgid "Searched for a web browser, but none found"
 msgstr ""
-#: ../lib/init/grass.py:376
+#: ../lib/init/grass.py:375
 #, fuzzy
 msgid "Hit RETURN to continue"
 msgstr "Pressione ENTER para continuar -->"
-#: ../lib/init/grass.py:405
+#: ../lib/init/grass.py:404
 msgid ""
 "The python command does not work as expected!\n"
 "Please check your GRASS_PYTHON environment variable.\n"
@@ -4369,7 +4372,7 @@
 "Hit RETURN to continue.\n"
 msgstr ""
-#: ../lib/init/grass.py:417
+#: ../lib/init/grass.py:416
 msgid ""
 "It appears that the X Windows system is not active.\n"
 "A graphical based user interface is not supported.\n"
@@ -4378,34 +4381,34 @@
 msgstr ""
-#: ../lib/init/grass.py:459 ../lib/init/grass.py:472
+#: ../lib/init/grass.py:458 ../lib/init/grass.py:471
 #, fuzzy, python-format
 msgid "<%s> is not a valid GRASS location"
 msgstr "Desculpe <%s> não é uma opção válida\n"
-#: ../lib/init/grass.py:464
+#: ../lib/init/grass.py:463
 #, python-format
 msgid "The location <%s> does not exist. Please create it first."
 msgstr ""
-#: ../lib/init/grass.py:470
+#: ../lib/init/grass.py:469
 msgid "Missing WIND file fixed"
 msgstr ""
-#: ../lib/init/grass.py:484
+#: ../lib/init/grass.py:483
 msgid ""
 "GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
 "Interactive startup needed."
 msgstr ""
-#: ../lib/init/grass.py:498
+#: ../lib/init/grass.py:497
 #, python-format
 msgid ""
 "Invalid user interface specified - <%s>.\n"
 "Use the --help option to see valid interface names."
 msgstr ""
-#: ../lib/init/grass.py:511
+#: ../lib/init/grass.py:510
 msgid ""
 "Error in GUI startup. If necessary, please report this error to the GRASS "
 "developers.\n"
@@ -4414,20 +4417,20 @@
 "Hit RETURN to continue..."
 msgstr ""
-#: ../lib/init/grass.py:521
+#: ../lib/init/grass.py:520
 msgid ""
 "Received EXIT message from GUI.\n"
 "GRASS is not started. Bye."
 msgstr ""
-#: ../lib/init/grass.py:524
+#: ../lib/init/grass.py:523
 #, fuzzy
 msgid ""
 "Invalid return code from GUI startup script.\n"
 msgstr "Por favor avise aos desenvolvedores do GRASS sobre este erro.\n"
-#: ../lib/init/grass.py:534
+#: ../lib/init/grass.py:533
 msgid ""
 "Error reading data path information from g.gisenv.\n"
 "GISDBASE=%(gisbase)s\n"
@@ -4437,31 +4440,31 @@
 "Check the <%s(file)> file."
 msgstr ""
-#: ../lib/init/grass.py:555
+#: ../lib/init/grass.py:554
 #, python-format
 msgid ""
 "%(user)s is currently running GRASS in selected mapset (file %(file)s "
 "found). Concurrent use not allowed."
 msgstr ""
-#: ../lib/init/grass.py:559
+#: ../lib/init/grass.py:558
 #, python-format
 msgid ""
 "Unable to properly access \"%s\"\n"
 "Please notify system personel."
 msgstr ""
-#: ../lib/init/grass.py:570
+#: ../lib/init/grass.py:569
 #, fuzzy
 msgid "Building user fontcap..."
-#: ../lib/init/grass.py:599
+#: ../lib/init/grass.py:598
 #, fuzzy
 msgid "The SHELL variable is not set"
 msgstr "GISRC - variável não incializada"
-#: ../lib/init/grass.py:609
+#: ../lib/init/grass.py:608
 #, python-format
 msgid ""
 "Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -4470,98 +4473,93 @@
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
-#: ../lib/init/grass.py:614
+#: ../lib/init/grass.py:613
 #, python-format
 msgid "Change file permission to 'executable' for '%s'"
 msgstr ""
-#: ../lib/init/grass.py:616
+#: ../lib/init/grass.py:615
 #, python-format
 msgid "Executing '%s' ..."
 msgstr ""
-#: ../lib/init/grass.py:623
+#: ../lib/init/grass.py:620
 #, python-format
+msgid "Execution of '%s' finished."
+msgstr ""
+#: ../lib/init/grass.py:625
+#, python-format
 msgid "GRASS GUI should be '%s'"
 msgstr ""
-#: ../lib/init/grass.py:667
+#: ../lib/init/grass.py:669
 msgid "GRASS homepage:"
 msgstr ""
-#: ../lib/init/grass.py:668
+#: ../lib/init/grass.py:670
 msgid "This version running through:"
 msgstr ""
-#: ../lib/init/grass.py:670
+#: ../lib/init/grass.py:672
 #, fuzzy
 msgid "Help is available with the command:"
 msgstr "No há ajuda disponível para o comando [%s]\n"
-#: ../lib/init/grass.py:671
+#: ../lib/init/grass.py:673
 msgid "See the licence terms with:"
 msgstr ""
-#: ../lib/init/grass.py:674
+#: ../lib/init/grass.py:676
 msgid "If required, restart the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:676
+#: ../lib/init/grass.py:678
 msgid "Start the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:678
+#: ../lib/init/grass.py:680
 msgid "When ready to quit enter:"
 msgstr ""
-#: ../lib/init/grass.py:781
+#: ../lib/init/grass.py:783
 msgid "Failed to start shell '%s'"
-#: ../lib/init/grass.py:785
+#: ../lib/init/grass.py:787
 #, python-format
 msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
 msgstr ""
-#: ../lib/init/grass.py:786 ../lib/init/grass.py:791
+#: ../lib/init/grass.py:788 ../lib/init/grass.py:793
 msgid "Goodbye from GRASS GIS"
 msgstr ""
-#: ../lib/init/grass.py:789
+#: ../lib/init/grass.py:791
 #, fuzzy
 msgid "Done."
 msgstr "nenhum"
-#: ../lib/init/grass.py:795
+#: ../lib/init/grass.py:797
 #, fuzzy
 msgid "Cleaning up temporary files..."
 msgstr "não consegui abrir arquivo temporário"
-#: ../lib/init/grass.py:938
+#: ../lib/init/grass.py:940
 msgid "Starting GRASS GIS..."
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:84
+#: ../lib/rst/interp_float/output2d.c:106
 #, c-format
 msgid "First change your rows number to nsizr! %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:91
+#: ../lib/rst/interp_float/output2d.c:113
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:99
-#, c-format
-msgid "Rows changed from %d to %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:105
-#, c-format
-msgid "Cols changed from %d to %d"
-msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:111
 #, fuzzy
 msgid ""
@@ -4578,25 +4576,25 @@
 "cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:60
+#: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:86
+#: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
 msgid "First change your rows number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:93
+#: ../lib/rst/interp_float/resout2d.c:110
 #, c-format
 msgid "First change your columns number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:247
+#: ../lib/rst/interp_float/resout2d.c:264
 msgid "No color table for input raster map -- will not create color table"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:458
 msgid "Changing the region back to initial..."
 msgstr ""
@@ -4761,7 +4759,7 @@
 msgid "Window replacing the default"
 msgstr "Janela substituindo o padrão"
-#: ../lib/g3d/g3dhistory.c:42
+#: ../lib/g3d/g3dhistory.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
 msgstr "não consegui obter dados históricos para [%s] no mapset [%s]"
@@ -4993,12 +4991,12 @@
 msgstr ""
-#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:771
+#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:772
 #, fuzzy, c-format
 msgid "Translating colors from raster map <%s>..."
-#: ../lib/ogsf/Gs3.c:1005
+#: ../lib/ogsf/Gs3.c:1007
 msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
@@ -5020,24 +5018,34 @@
 msgid "Bitmap mismatch"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1643
+#: ../lib/ogsf/GS2.c:1198
+#, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1217
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1640
 #, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr ""
 "[%s] no mapset [%s] - está em uma zona diferente [%d] da região atual [%d]"
-#: ../lib/ogsf/GS2.c:1723 ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1737
-#: ../lib/ogsf/GS2.c:1746 ../lib/ogsf/GS2.c:1754 ../lib/ogsf/GS2.c:1764
-#: ../lib/ogsf/GS2.c:1812
+#: ../lib/ogsf/GS2.c:1720 ../lib/ogsf/GS2.c:1726 ../lib/ogsf/GS2.c:1734
+#: ../lib/ogsf/GS2.c:1743 ../lib/ogsf/GS2.c:1751 ../lib/ogsf/GS2.c:1761
+#: ../lib/ogsf/GS2.c:1809
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1840
+#: ../lib/ogsf/GS2.c:1837
 #, fuzzy
 msgid "Loading failed"
 msgstr "Falha na conexão."
-#: ../lib/ogsf/GS2.c:1844
+#: ../lib/ogsf/GS2.c:1841
 #, fuzzy
 msgid "Error finding range"
@@ -5152,7 +5160,7 @@
 msgstr "Nome de tabela de mapa <%s> ilegal. Caractere <%c> não permitido.\n"
-#: ../lib/db/dbmi_base/login.c:112
+#: ../lib/db/dbmi_base/login.c:111
 msgid "Login file corrupted"
 msgstr ""
@@ -5806,6 +5814,18 @@
 msgstr ""
+#, fuzzy
+#~ msgstr ""
+#~ "Não há espaço suficiente no arquivo de histórico para gravar a linha de "
+#~ "comando."
+#, fuzzy
+#~ msgstr ""
+#~ "Não há espaço suficiente no arquivo de histórico para a linha de comando "
+#~ "(truncada)."
 #~ msgstr "Locação desconhecida"
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pt_br\n"
 "PO-Revision-Date: 2007-05-20 10:44-0300\n"
 "Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail.com>\n"
 "Language-Team: Brazilian Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -65,11 +65,11 @@
 msgstr ""
 #, fuzzy
 msgid ""
@@ -77,6 +77,14 @@
 msgstr ""
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "Não consegui abrir histórico para o vetor %s"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr ""
-"comando."
-#, fuzzy
-msgstr ""
-"(truncada)."
@@ -820,7 +814,7 @@
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -1741,23 +1735,27 @@
 msgstr ""
+msgstr ""
 msgid "Color"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Units"
 msgstr ""
@@ -1793,14 +1791,14 @@
 msgid "SYNOPSIS"
 msgstr ""
 #, fuzzy
 msgid "Flags"
 msgstr ""
 "\n"
 "Flags:\n"
 #, fuzzy
 msgid "Parameters"
 msgstr ""
@@ -2296,23 +2294,23 @@
 msgstr "%s completo. %"
 msgid ""
 msgstr ""
 #, c-format
 #, c-format
 #, fuzzy
 msgstr ""
@@ -2320,7 +2318,7 @@
 "()\n"
@@ -2516,12 +2514,12 @@
 msgstr ""
 #, fuzzy
 msgstr ""
@@ -2586,12 +2584,12 @@
 msgstr ""
 #, fuzzy
 msgstr "não consegui calcular centróide para área %d"
 #, fuzzy
@@ -2725,20 +2723,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3144,47 +3142,47 @@
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Criando topologia ...\n"
 #, fuzzy, c-format
 msgstr "A topologia foi criada.\n"
 #, fuzzy, c-format
 #, fuzzy
 #, fuzzy
@@ -3232,91 +3230,91 @@
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3326,14 +3324,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3358,7 +3356,7 @@
 msgstr ""
 #, fuzzy, c-format
@@ -3515,7 +3513,7 @@
 #, fuzzy, c-format
@@ -3565,7 +3563,7 @@
 #, fuzzy, c-format
@@ -3585,42 +3583,42 @@
 #, fuzzy, c-format
 msgstr "não há arquivos %s disponíveis no mapset ativo\n"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy, c-format
 #, fuzzy
@@ -3666,87 +3664,97 @@
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3904,62 +3912,57 @@
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -4266,7 +4269,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4274,97 +4277,97 @@
 "Uso:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 #, fuzzy
 msgid ""
@@ -4374,7 +4377,7 @@
 msgstr ""
 msgid ""
@@ -4383,34 +4386,34 @@
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4419,20 +4422,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgid ""
@@ -4442,31 +4445,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, python-format
 msgid ""
@@ -4475,98 +4478,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "nenhum"
 #, fuzzy
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4583,25 +4581,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4766,7 +4764,7 @@
 #, c-format
@@ -4998,12 +4996,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -5025,24 +5023,34 @@
 msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Falha na conexão.\n"
 #, fuzzy
@@ -5157,7 +5165,7 @@
 msgstr ""
@@ -5765,6 +5773,18 @@
 msgstr ""
+#, fuzzy
+#~ msgstr ""
+#~ "comando."
+#, fuzzy
+#~ msgstr ""
+#~ "(truncada)."
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_ru.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ru\n"
 "PO-Revision-Date: 2009-01-27 22:58-0600\n"
 "Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
 "Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -58,11 +58,11 @@
 msgstr "Невозможно прочитать диапазон растрового слоя <%s>"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -70,6 +70,14 @@
 msgstr ""
 "G_set_window(): проекция/зона отличается от текущих открытых растровых карт"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -457,25 +465,25 @@
 #, c-format
 msgstr "Растровый слой <%s> не найден"
@@ -732,32 +740,21 @@
 msgstr "Невозможно открыть файл заголовка для растрового слоя <%s@%s>"
 #, fuzzy, c-format
 msgstr "невозможно записать историю для [%s]"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr "Недостаточно места в файле истории для записи командной строки"
-#, fuzzy
-msgstr ""
-"Недостаточно места в файле истории для записи командной строки (truncated)"
@@ -808,7 +805,7 @@
 #, c-format
@@ -1191,12 +1188,12 @@
 msgstr ""
 " Только %d%% окна сохранено в \"%s\" пересекается с текущим окном GRASS."
 #, fuzzy, c-format
 msgstr "Невозможно создать элемент набора %s (%s)"
 #, fuzzy, c-format
@@ -1739,23 +1736,27 @@
 msgstr "Разделитель полей"
+msgstr ""
 msgid "Color"
 msgstr "Цвет"
 msgstr "Либо стандратное название цвета, либо триплет R:G:B"
 msgstr "Цвет фона"
 msgstr "Либо стандартный цвет GRASS, либо триплет R:G:B, либо \"none\""
 msgid "Units"
 msgstr ""
@@ -1790,11 +1791,11 @@
 msgid "SYNOPSIS"
 msgstr "Синопсис"
 msgid "Flags"
 msgstr "Флаги"
 msgid "Parameters"
 msgstr "Параметры"
@@ -2277,29 +2278,29 @@
 msgstr "%s завершен. %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "НАБОР %s - доступ запрещен"
 #, c-format
 msgstr "НАБОР %s не найден"
 msgstr ""
 "Система не инициализирована. Программистов не выполнен вызов G_gisinit()."
@@ -2492,12 +2493,12 @@
 msgstr "Невозможно открыть временный файл"
 #, fuzzy
 msgstr ""
@@ -2567,11 +2568,11 @@
 msgstr "%s: Полигон %d не существует"
 msgstr "Попытка удалить уже удаленный объект"
 msgstr "Попытка восстановить нормальный объект"
@@ -2710,20 +2711,20 @@
 msgstr "Недостаточно места в векторном массиве"
 #, c-format
 msgstr "Для слоя %d не определено соединение с базой данных"
@@ -3122,43 +3123,43 @@
 msgstr "Запрос найти полигон вне несуществующего острова"
 msgstr "Регистрируются примитивы..."
 msgstr "Невозможно прочитать векторный слой"
 #, c-format
 msgstr "%d примитивов зарегистрировано"
 #, c-format
 msgstr "%d узлов зарегистрировано"
 msgstr "Построение полигонов..."
 #, c-format
 msgstr "%d полигонов построено"
 #, c-format
 msgstr "%d островов создано"
 msgstr "Назначаются острова..."
 msgstr "Назначаются центроиды..."
@@ -3206,91 +3207,91 @@
 msgstr "Невозможно прочитать векторный слой <%s>"
 #, c-format
 msgstr "Имя векторного слоя не SQL-совместимо"
 #, c-format
 msgstr "Невозможно найти векторный слой <%s> в <%s>"
 #, c-format
 msgstr "Векторный слой <%s> уже существует и будет перезаписан"
 #, c-format
 msgstr "Невозможно удалить векторный слой <%s>"
 #, c-format
 msgstr "Невозможно скопировать векторный слой <%s> в <%s>"
 #, c-format
 msgstr "Невозможно скопировать таблицу <%s>"
 #, c-format
 msgstr "Невозможно создать индекс для таблицы <%s>, ключ <%s>"
 #, c-format
 msgstr "Невозможно удалить таблицу <%s>"
 #, c-format
 msgstr "Неправильное имя векторного слоя <%s>"
 #, c-format
 msgstr "Невозможно открыть файл заголовка для векторного слоя <%s>"
 #, c-format
 msgstr "Невозможно найти таблицу <%s> связанную с векторным слоем <%s>"
 #, c-format
 msgstr "Таблица <%s> связанная с векторным слоем <%s> не существует"
 #, c-format
 msgstr "Невозможно открыть папку '%s'"
 #, c-format
 msgstr "Невозможно удалить файл '%s'"
 #, c-format
 msgstr "Невозможно переименовать папку '%s' в '%s'"
 #, c-format
 msgstr "Невозможно удалить папку '%s'"
 #, c-format
 msgstr "Невозможно добавить связь с базой данных для векторного слоя <%s>"
@@ -3300,7 +3301,7 @@
 msgstr "Невозможно открыть файл истории для векторного слоя <%s>"
 #, fuzzy, c-format
 msgid ""
@@ -3309,7 +3310,7 @@
 "Файлы coor векторного слоя <%s@%s> больше, чем они должны быть (на %ld "
 "байтов)"
 #, fuzzy, c-format
 msgid ""
@@ -3334,7 +3335,7 @@
 msgstr "поле Arc < 1"
 #, c-format
 msgstr "Поле <%s> не найдено в таблице <%s>"
@@ -3489,7 +3490,7 @@
 msgstr "Невозможно восстановить объект %d из векторного слоя <%s>"
 #, c-format
 msgstr "Невозможно закрыть векторный слой <%s>"
@@ -3541,7 +3542,7 @@
 msgstr "Невозможно открыть файл индекса категорий для векторного слоя <%s>"
 #, c-format
@@ -3561,42 +3562,42 @@
 #, c-format
 msgstr "в текущем наборе (%s) файлов %s нет"
 #, c-format
 msgstr "Невозможно создать векторный слой <%s>"
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "Невозможно открыть файл статистики <%s>"
 #, c-format
 msgstr ""
 msgstr ""
 "Размер файла 'coor' отличается от значения сохраненного в файле топологии"
 #, c-format
 msgstr "Пожалуйста, перестройте топологию для векторного слоя <%s@%s>"
 #, fuzzy
 msgstr ""
@@ -3647,87 +3648,97 @@
 msgstr "Векторный слой <%s> не открыт на уровне >= 2"
 #, fuzzy, c-format
 msgstr "невозможно прочитать файл диапазона для [%s в %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Невозможно инициализировать pj причину: %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Неизвестное ключевое слово %s в заголовке вектора"
 #, c-format
 msgstr "Невозможен запуск драйвера <%s>"
 #, fuzzy, c-format
 msgstr "Неизвестный тип вектора."
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "Невозможно выбрать записи из таблицы <%s> (ключ %s, где %s)"
 #, fuzzy, c-format
 msgstr "Nviz_new_map_obj(): тип данных не поддерживается"
 #, fuzzy
 msgstr "неизвестный оператор"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Невозможно перезаписать объект %d"
 #, fuzzy, c-format
 msgstr "Невозможно установить категорию %d для (id объекта %d)"
@@ -3884,59 +3895,54 @@
 msgstr "Невозможно открыть выбранный курсор: '%s'"
 msgstr "Плохое соединение с сервером"
 msgstr "Невозможно создать контекст отрисовки"
 msgstr "Невозможно установить новый источник света"
 msgstr "Невозможно установить фокус"
 #, c-format
 msgstr "Неправильный цвет: (%s), используется \"white\" по умолчанию"
-#, c-format
-msgstr "Неправильные координаты позиции вида, используется %f,%f"
 msgstr "Загружено максимальное количество поверхностей!"
 msgstr "Загружено максимальное количество линейных векторных слоев!"
 #, c-format
 msgstr "Ошибка загрузки векторного слоя <%s>"
 msgstr "Загружено максимальное количество точечных векторных слоев!"
 msgstr "Загружено максимальное количество объемов!"
 #, c-format
 msgstr "Ошибка загрузки растрового 3d слоя <%s>"
@@ -4294,7 +4300,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4302,97 +4308,97 @@
 "Использование:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "чтобы установить по умолчанию"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "неверная проекция\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Невозможно разместить временное изображение"
 msgstr ""
 #, fuzzy
 msgstr "нажмите RETURN для продолжения -->"
 msgid ""
@@ -4402,7 +4408,7 @@
 msgstr ""
 msgid ""
@@ -4411,34 +4417,34 @@
 msgstr ""
 msgstr "Извините, опция <%s> неверна\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4447,20 +4453,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "Сообщите разработчикам GRASS об этой ошибке.\n"
 msgid ""
@@ -4470,31 +4476,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Построение графа..."
 #, fuzzy
 msgstr "GISRC - переменная не установлена"
 #, python-format
 msgid ""
@@ -4503,98 +4509,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Нет справки для команды [%s]\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "нет"
 #, fuzzy
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4612,25 +4613,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4792,7 +4793,7 @@
 msgstr "Окно заменяемое по умолчанию"
 #, c-format
 msgstr "невозможно прочитать историю для [%s] в наборе [%s]"
@@ -5028,12 +5029,12 @@
 msgstr ""
 "Диапазон цветовой таблицы не соответствует данным (mincol=%d, maxcol=%d"
 #, c-format
 msgstr "Трансляция цветов для растрового слоя  <%s>..."
 msgstr "Вид не сохранен этой программой, существуют несостыковки"
@@ -5055,22 +5056,32 @@
 msgstr "Несовпадение битмэпов"
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr "Растровый слой <%s> вне текущего региона. Загрузка прервана."
 msgstr "GS_load_att_map(): Нет памяти. Невозможно загрузить слой"
 msgstr "Загрузка не выполнена"
 msgstr "Ошибка вычисления диапазона"
@@ -5176,7 +5187,7 @@
 msgstr "Неправильное имя таблицы <%s>. Символ <%c> использовать нельзя.\n"
 msgstr ""
@@ -5837,6 +5848,18 @@
 msgstr "подгруппа <%s> группы <%s> ссылается на следующие растровые слои\n"
+#, fuzzy
+#~ msgstr "Недостаточно места в файле истории для записи командной строки"
+#, fuzzy
+#~ msgstr ""
+#~ "Недостаточно места в файле истории для записи командной строки (truncated)"
+#~ msgid "Invalid view position coordinates, using %f,%f"
+#~ msgstr "Неправильные координаты позиции вида, используется %f,%f"
 #~ msgstr "Область неизвестна"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_sl.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_sl\n"
 "PO-Revision-Date: 2005-04-26 09:38+0200\n"
 "Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
 "Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
@@ -61,11 +61,11 @@
 msgstr "ne morem spremeniti direktorija v %s"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -74,6 +74,14 @@
 "G_set_window(): projekcija/cona je razlièna od tiste, ki je doloèena za "
 "trenutno odprte rastrske sloje"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -464,25 +472,25 @@
 #, fuzzy, c-format
 msgstr "Vneseni vektor '%s' ni bil najden"
@@ -743,29 +751,21 @@
 msgid "Unable to open header file for raster map <%s@%s>"
 msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
 #, fuzzy, c-format
 msgstr "ne morem zapisati \"history\" podatkov za [%s]"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-msgstr ""
-msgstr ""
@@ -816,7 +816,7 @@
 #, fuzzy, c-format
@@ -1193,12 +1193,12 @@
 msgstr ""
 " Le %d%% okna shranjenega v \"%s\" se prekriva s trenutnim GRASS oknom."
 #, fuzzy, c-format
 msgstr "ne morem izdelati elementa \"mapset\"-a %s (%s)"
 #, fuzzy, c-format
@@ -1756,23 +1756,27 @@
 msgstr ""
+msgstr ""
 msgid "Color"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgid "Units"
 msgstr ""
@@ -1808,14 +1812,14 @@
 msgid "SYNOPSIS"
 msgstr ""
 #, fuzzy
 msgid "Flags"
 msgstr ""
 "\n"
 "Izbire:\n"
 #, fuzzy
 msgid "Parameters"
 msgstr ""
@@ -2311,24 +2315,24 @@
 msgstr "%s je gotov. %s\n"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "MAPSET %s - dovoljenje odklonjeno"
 # ne morem izdelati elementa "mapset"-a %s (%s)
 #, c-format
 msgstr "ne najdem MAPSET %s"
 #, fuzzy
 msgstr ""
@@ -2336,7 +2340,7 @@
 "()\n"
@@ -2533,12 +2537,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Nezmo¾en odpreti datoteko %s v %s"
 msgstr ""
@@ -2603,12 +2607,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Ne morem prebrati histograma za [%s v %s]"
 #, fuzzy
@@ -2743,20 +2747,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3162,47 +3166,47 @@
 msgstr ""
 #, fuzzy
 msgstr "Registriram linije: "
 #, fuzzy
 #, fuzzy, c-format
 msgstr "\r%d primitivnih enot registriranih      \n"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Gradim topologijo ...\n"
 #, fuzzy, c-format
 msgstr "Topologija je zgrajena. \n"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "Pripajanje otokov: "
 #, fuzzy
 msgstr "Pripajanje centroidov: "
@@ -3250,91 +3254,91 @@
 #, fuzzy, c-format
 msgstr "Ime sloja se ne sklada z SQL pravili."
 #, fuzzy, c-format
 msgstr "ne morem odpreti rastrskega sloja [%s v %s]"
 #, fuzzy, c-format
 msgstr "Vektor '%s' ¾e obstaja in bo prepisan."
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "Nezmo¾en ustvariti datoteko z vzglavjem za [%s v %s]"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -3344,14 +3348,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3376,7 +3380,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Ne morem zapisati povezav z bazo podatkov."
@@ -3531,7 +3535,7 @@
 #, fuzzy, c-format
@@ -3580,7 +3584,7 @@
 #, fuzzy, c-format
@@ -3600,43 +3604,43 @@
 #, fuzzy, c-format
 msgstr "v trenutnem \"mapset\" ni datotek z imenom %s\n"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr ""
 "Velikost datoteke 'coor' je razlièna od vrednosti shranjene v datoteki topo."
 #, fuzzy, c-format
 msgstr "Prosim ponovno izgradi topologijo vektorja '%s@%s'"
 #, fuzzy
 msgstr ""
@@ -3682,87 +3686,97 @@
 #, fuzzy, c-format
 msgstr "ne morem brati range datoteke [%s v %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Nezmo¾en odpreti datoteko %s v %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nepoznan \"location\""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr ""
 #, fuzzy, c-format
 msgstr "Ne morem odpreti temp datoteke"
 #, fuzzy, c-format
@@ -3921,62 +3935,57 @@
 msgstr ""
 #, fuzzy
 msgstr "ne morem ustvariti novega procesa"
 #, fuzzy
 #, fuzzy
 msgstr "Ne morem odpreti %s"
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "za obstojeèe rastrske sloje %d\n"
 msgstr ""
@@ -4283,7 +4292,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4291,97 +4300,97 @@
 "Uporaba:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "za izbrati privzeto"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "neveljavna projekcija\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Nezmo¾en dodeliti spomin\n"
 msgstr ""
 #, fuzzy
 msgstr "pritisnite RETURN za nadaljevanje -->"
 msgid ""
@@ -4391,7 +4400,7 @@
 msgstr ""
 msgid ""
@@ -4400,34 +4409,34 @@
 msgstr ""
 msgstr "Oprostite <%s> ni veljavna mo¾nost\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4436,20 +4445,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 "Please advise GRASS developers of this error."
 msgstr "Prosim sporoèite razvijalcem GRASS-a o tej napaki.\n"
 msgid ""
@@ -4459,31 +4468,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy
 msgstr "GISRC - spremenljivka ni nastavljena"
 #, python-format
 msgid ""
@@ -4492,98 +4501,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Za ukaz [%s] ni na voljo pomoèi\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "ga ni"
 #, fuzzy
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 msgid ""
 "Taking too long to find points for interpolation - please change the region "
@@ -4597,25 +4601,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4774,7 +4778,7 @@
 #, c-format
 msgstr "ne morem dobiti podatka \"history\" za [%s] v \"mapset\" [%s]"
@@ -5006,12 +5010,12 @@
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -5033,23 +5037,33 @@
 msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr "[%s] v \"mapset\" [%s] - v drugi coni [%d] kot trenutna regija [%d]"
 msgstr ""
 #, fuzzy
 msgstr "Povezava ni uspela.\n"
 msgstr ""
@@ -5164,7 +5178,7 @@
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
 msgstr "Neveljavno ime vektorskega sloja <%s>. Znak <%c> ni dovoljen.\n"
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_th.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasstcl_th\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2008-01-05 15:19+0700\n"
 "Last-Translator: man <mansv68 at yahoo.co.th>\n"
 "Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -62,17 +62,25 @@
 msgid "Unable to write quant rules for raster map <%s>"
 msgstr "ไม่สามารถสร้างแผนที่เชิงภาพ <%s> "
-#: ../lib/raster/set_window.c:46
+#: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
 msgstr ""
-#: ../lib/raster/set_window.c:117
+#: ../lib/raster/set_window.c:123
 #, fuzzy
 msgid ""
 "Rast_set_read_window(): projection/zone differs from that of currently open "
 "raster maps"
 msgstr "G_set_window(): การฉาย/โซน แตกต่างจากข้อมูลแผนที่เชิงภาพ"
+#: ../lib/raster/set_window.c:150
+msgid "Input window changed while maps are open for read"
+msgstr ""
+#: ../lib/raster/set_window.c:168
+msgid "Output window changed while maps are open for write"
+msgstr ""
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
@@ -461,25 +469,25 @@
 #: ../lib/raster/opencell.c:779 ../lib/raster/opencell.c:831
 #: ../lib/manage/do_rename.c:53 ../lib/manage/do_remove.c:53
 #: ../lib/gis/legal_name.c:91 ../lib/gis/legal_name.c:94
-#: ../lib/rst/interp_float/output2d.c:228
-#: ../lib/rst/interp_float/output2d.c:309
-#: ../lib/rst/interp_float/output2d.c:393
-#: ../lib/rst/interp_float/output2d.c:457
-#: ../lib/rst/interp_float/output2d.c:485
-#: ../lib/rst/interp_float/output2d.c:513
-#: ../lib/rst/interp_float/output2d.c:543
-#: ../lib/rst/interp_float/resout2d.c:188
-#: ../lib/rst/interp_float/resout2d.c:236
-#: ../lib/rst/interp_float/resout2d.c:279
-#: ../lib/rst/interp_float/resout2d.c:319
-#: ../lib/rst/interp_float/resout2d.c:378
-#: ../lib/rst/interp_float/resout2d.c:405
-#: ../lib/rst/interp_float/resout2d.c:429
-#: ../lib/rst/interp_float/resout2d.c:455 ../lib/ogsf/gsd_legend.c:239
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426 ../lib/ogsf/gsd_legend.c:239
 #: ../lib/ogsf/Gs3.c:127 ../lib/ogsf/Gs3.c:200 ../lib/ogsf/Gs3.c:283
 #: ../lib/ogsf/Gs3.c:356 ../lib/ogsf/Gs3.c:470 ../lib/ogsf/Gs3.c:565
-#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:757
-#: ../lib/ogsf/Gs3.c:826
+#: ../lib/ogsf/Gs3.c:630 ../lib/ogsf/Gs3.c:687 ../lib/ogsf/Gs3.c:758
+#: ../lib/ogsf/Gs3.c:828
 #, c-format
 msgid "Raster map <%s> not found"
 msgstr "ไม่พบแผนที่เชิงภาพ <%s> "
@@ -729,31 +737,21 @@
 msgstr "ไม่สามารถเปิด ไฟล์หมวดดัชนี สำหรับแผนที่เชิงเส้น <%s@%s>"
-#: ../lib/raster/history.c:115
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, fuzzy, c-format
 msgid "Unable to get history information for <%s@%s>"
 msgstr "ไม่สามารถเขียนข้อมูลประวัติ สำหรับ [%s]"
-#: ../lib/raster/history.c:143
+#: ../lib/raster/history.c:162
 #, fuzzy, c-format
 msgid "Unable to write history information for <%s>"
-#: ../lib/raster/history.c:184
+#: ../lib/raster/history.c:235
 #, c-format
 msgid "generated by %s"
 msgstr ""
-#: ../lib/raster/history.c:232
-#, fuzzy
-msgid "Not enough room in history file to record command line"
-msgstr "ไฟล์ประวัติเต็มไม่สามารถบันทึกคำสั่งต่อได้"
-#: ../lib/raster/history.c:254
-#, fuzzy
-msgid "Not enough room in history file for command line (truncated)"
-msgstr "ไฟล์ประวัติเต็มไม่สามารถบันทึกคำสั่งต่อได้(ตัดสั้น)"
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
 #: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
 #: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
@@ -804,7 +802,7 @@
 #: ../lib/manage/do_rename.c:37 ../lib/manage/do_remove.c:37
 #: ../lib/vector/Vlib/legal_vname.c:115 ../lib/vector/Vlib/legal_vname.c:118
-#: ../lib/vector/Vlib/map.c:404 ../lib/vector/Vlib/open.c:197
+#: ../lib/vector/Vlib/map.c:403 ../lib/vector/Vlib/open.c:197
 #: ../lib/ogsf/Gv3.c:58 ../lib/ogsf/Gp3.c:58
 #, c-format
 msgid "Vector map <%s> not found"
@@ -1187,12 +1185,12 @@
 " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
 msgstr "เพียง %d%% หน้าต่าง ถูกบันทึกใน \"%s\" เหลื่อมกับหน้าต่าง GRASS"
-#: ../lib/gis/mapset_msc.c:60
+#: ../lib/gis/mapset_msc.c:61
 #, fuzzy, c-format
 msgid "Unable to make mapset element %s (%s): %s"
 msgstr "ไม่สามารถสร้างส่วนประกอบของแผนที่ได้ %s (%s)"
-#: ../lib/gis/mapset_msc.c:64
+#: ../lib/gis/mapset_msc.c:65
 #, fuzzy, c-format
 msgid "Unable to access mapset element %s (%s): %s"
@@ -1735,23 +1733,27 @@
 msgid "Field separator"
 msgstr "ตัวแยก Field"
-#: ../lib/gis/parser_standard_options.c:455
+#: ../lib/gis/parser_standard_options.c:445
+msgid "Special characters: newline, space, comma, tab"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:456
 msgid "Color"
 msgstr "สี"
-#: ../lib/gis/parser_standard_options.c:456
+#: ../lib/gis/parser_standard_options.c:457
 msgid "Either a standard color name or R:G:B triplet"
 msgstr "ใส่ชื่อสีมาตรฐาน หรือ R:G:B"
-#: ../lib/gis/parser_standard_options.c:465
+#: ../lib/gis/parser_standard_options.c:466
 msgid "Background color"
 msgstr "สีฉากหลัง"
-#: ../lib/gis/parser_standard_options.c:467
+#: ../lib/gis/parser_standard_options.c:468
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
 msgstr "ใส่ชื่อสีมาตรฐานของ GRASS หรือ R:G:B หรือ \"none\""
-#: ../lib/gis/parser_standard_options.c:478
+#: ../lib/gis/parser_standard_options.c:479
 msgid "Units"
 msgstr ""
@@ -1786,11 +1788,11 @@
 msgid "SYNOPSIS"
 msgstr "สาระสำคัญ"
-#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:146
+#: ../lib/gis/parser_html.c:126 ../lib/init/grass.py:147
 msgid "Flags"
 msgstr "ธง"
-#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:156
+#: ../lib/gis/parser_html.c:164 ../lib/init/grass.py:157
 msgid "Parameters"
 msgstr "ตัวแปร"
@@ -2271,29 +2273,29 @@
 msgid "%s complete. %s"
 msgstr "%s เสร็จสิ้น %s"
-#: ../lib/gis/gisinit.c:55 ../lib/gis/gisinit.c:90
+#: ../lib/gis/gisinit.c:56 ../lib/gis/gisinit.c:91
 msgid ""
 "Incompatible library version for module. You need to rebuild GRASS or "
 "untangle multiple installations."
 msgstr ""
-#: ../lib/gis/gisinit.c:65
+#: ../lib/gis/gisinit.c:66
 #, c-format
 msgid "MAPSET %s - permission denied"
 msgstr "ชุดแผนที่ %s - ไม่อนุญาติ"
-#: ../lib/gis/gisinit.c:68
+#: ../lib/gis/gisinit.c:69
 #, c-format
 msgid "MAPSET %s not found"
 msgstr "ชุดแผนที่ %s - ไม่พบ"
-#: ../lib/gis/gisinit.c:107
+#: ../lib/gis/gisinit.c:108
 #, fuzzy
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
 msgstr "\aข้อผิดพลาด: ระบบไม่สามารถเริ่มต้น. Programmer ลืมเรียก G_gisinit()\n"
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/vector/Vlib/ascii.c:187 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/ascii.c:200 ../lib/vector/Vlib/line.c:50
 #: ../lib/vector/neta/articulation_point.c:60
 #: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
 #: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
@@ -2490,12 +2492,12 @@
 msgid "Writing to file loaded to memory not supported"
 msgstr ""
-#: ../lib/vector/diglib/file.c:204
+#: ../lib/vector/diglib/file.c:205
 #, fuzzy
 msgid "Unable to load file to memory, file not open"
 msgstr "ไม่สามารถเปิดไฟล์ %s ได้"
-#: ../lib/vector/diglib/file.c:219
+#: ../lib/vector/diglib/file.c:220
 msgid "Vector memory mode not supported, using 'AUTO'"
 msgstr ""
@@ -2560,12 +2562,12 @@
 msgid "%s: Area %d does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:675 ../lib/vector/Vlib/write_ogr.c:298
+#: ../lib/vector/Vlib/write_nat.c:670 ../lib/vector/Vlib/write_ogr.c:298
 #, fuzzy
 msgid "Attempt to delete dead feature"
 msgstr "ตั้งใจที่จะลบพื้นที่"
-#: ../lib/vector/Vlib/write_nat.c:920
+#: ../lib/vector/Vlib/write_nat.c:910
 #, fuzzy
 msgid "Attempt to restore alive feature"
@@ -2702,20 +2704,20 @@
 msgid "Not enough space in vector array"
 msgstr "กลุ่มข้อมูลแผนที่เชิงเส้น ไม่มีที่ว่างพอ"
-#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:313
-#: ../lib/vector/Vlib/map.c:440 ../lib/vector/Vlib/map.c:552
-#: ../lib/vector/Vlib/map.c:670 ../lib/vector/Vlib/map.c:768
+#: ../lib/vector/Vlib/array.c:278 ../lib/vector/Vlib/map.c:312
+#: ../lib/vector/Vlib/map.c:439 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:669 ../lib/vector/Vlib/map.c:767
 #: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:347
-#: ../lib/vector/Vlib/ascii.c:301 ../lib/vector/Vlib/write_ogr.c:118
+#: ../lib/vector/Vlib/ascii.c:314 ../lib/vector/Vlib/write_ogr.c:118
 #: ../lib/rst/interp_float/vinput2d.c:79
 #, c-format
 msgid "Database connection not defined for layer %d"
 msgstr "การเชื่อมต่อฐานข้อมูลไม่ได้ถูกกำหนด สำหรับชั้นข้อมูลนี้ %d"
-#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:342
-#: ../lib/vector/Vlib/map.c:481 ../lib/vector/Vlib/map.c:703
+#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:341
+#: ../lib/vector/Vlib/map.c:480 ../lib/vector/Vlib/map.c:702
 #: ../lib/vector/Vlib/net.c:182 ../lib/vector/Vlib/net.c:352
-#: ../lib/vector/Vlib/ascii.c:313 ../lib/vector/Vlib/write_ogr.c:375
+#: ../lib/vector/Vlib/ascii.c:326 ../lib/vector/Vlib/write_ogr.c:375
 #: ../lib/vector/neta/utils.c:116 ../lib/vector/neta/timetables.c:133
 #: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/copy_tab.c:105
 #: ../lib/db/dbmi_client/copy_tab.c:126 ../lib/db/dbmi_client/db.c:46
@@ -3119,47 +3121,47 @@
 msgid "Request to find area outside nonexistent isle"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:523
+#: ../lib/vector/Vlib/build_nat.c:525
 #, fuzzy
 msgid "Registering primitives..."
 msgstr "บันทึก บรรทัด: "
-#: ../lib/vector/Vlib/build_nat.c:532
+#: ../lib/vector/Vlib/build_nat.c:534
 #, fuzzy
 msgid "Unable to read vector map"
 msgstr "ไม่สามารถอ่านข้อมูลแผนที่เชิงเส้นได้ <%s%s>"
-#: ../lib/vector/Vlib/build_nat.c:576
+#: ../lib/vector/Vlib/build_nat.c:578
 #, fuzzy, c-format
 msgid "%d primitives registered"
 msgstr "\r%d บันทึกแบบพื้นฐาน      \n"
-#: ../lib/vector/Vlib/build_nat.c:577
+#: ../lib/vector/Vlib/build_nat.c:579
 #, fuzzy, c-format
 msgid "%d vertices registered"
-#: ../lib/vector/Vlib/build_nat.c:588
+#: ../lib/vector/Vlib/build_nat.c:590
 #, fuzzy
 msgid "Building areas..."
 msgstr "สร้าง graph ..."
-#: ../lib/vector/Vlib/build_nat.c:611
+#: ../lib/vector/Vlib/build_nat.c:613
 #, fuzzy, c-format
 msgid "%d areas built"
 msgstr "Graph ถูกสร้าง"
-#: ../lib/vector/Vlib/build_nat.c:612
+#: ../lib/vector/Vlib/build_nat.c:614
 #, fuzzy, c-format
 msgid "%d isles built"
-#: ../lib/vector/Vlib/build_nat.c:621
+#: ../lib/vector/Vlib/build_nat.c:623
 #, fuzzy
 msgid "Attaching islands..."
 msgstr "การแนบรูปเกาะ : "
-#: ../lib/vector/Vlib/build_nat.c:636
+#: ../lib/vector/Vlib/build_nat.c:638
 #, fuzzy
 msgid "Attaching centroids..."
 msgstr "การแนบ จุดศูนย์ถ่วง: "
@@ -3207,91 +3209,91 @@
 msgid "Unable to read vector map <%s>"
-#: ../lib/vector/Vlib/map.c:242 ../lib/vector/Vlib/map.c:386
-#: ../lib/vector/Vlib/open.c:692
+#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:385
+#: ../lib/vector/Vlib/open.c:691
 #, c-format
 msgid "Vector map name is not SQL compliant"
 msgstr "ชื่อแผนที่เชิงเส้น ไม่ใช่ คำสั่ง SQL "
-#: ../lib/vector/Vlib/map.c:246
+#: ../lib/vector/Vlib/map.c:245
 #, fuzzy, c-format
 msgid "Unable to find vector map <%s> in <%s>"
 msgstr "ไม่สามารถคัดลอกแผนที่เชิงเส้น  <%s> ไปเป็น <%s>"
-#: ../lib/vector/Vlib/map.c:258 ../lib/vector/Vlib/map.c:390
-#: ../lib/vector/Vlib/open.c:699
+#: ../lib/vector/Vlib/map.c:257 ../lib/vector/Vlib/map.c:389
+#: ../lib/vector/Vlib/open.c:698
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "แผนที่เชิงเส้น <%s> มีอยู่แล้วและจะถูกเขียนทับ"
-#: ../lib/vector/Vlib/map.c:262 ../lib/vector/Vlib/open.c:704
+#: ../lib/vector/Vlib/map.c:261 ../lib/vector/Vlib/open.c:703
 #, c-format
 msgid "Unable to delete vector map <%s>"
 msgstr "ไม่สามารถลบแผนที่เชิงเส้น  <%s> ได้"
-#: ../lib/vector/Vlib/map.c:282 ../lib/vector/Vlib/map.c:408
+#: ../lib/vector/Vlib/map.c:281 ../lib/vector/Vlib/map.c:407
 #, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:457
-#: ../lib/vector/Vlib/map.c:695 ../lib/vector/Vlib/map.c:802
+#: ../lib/vector/Vlib/map.c:330 ../lib/vector/Vlib/map.c:456
+#: ../lib/vector/Vlib/map.c:694 ../lib/vector/Vlib/map.c:801
 #, c-format
 msgid "Unable to copy table <%s>"
 msgstr "ไม่สามารถคัดลอกตารางได้ <%s>"
-#: ../lib/vector/Vlib/map.c:347 ../lib/vector/Vlib/map.c:486
-#: ../lib/vector/Vlib/map.c:708
+#: ../lib/vector/Vlib/map.c:346 ../lib/vector/Vlib/map.c:485
+#: ../lib/vector/Vlib/map.c:707
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 msgstr "ไม่สามารถสร้างดัชนีสำหรับตาราง <%s> ด้วย key <%s>"
-#: ../lib/vector/Vlib/map.c:471 ../lib/vector/Vlib/map.c:572
+#: ../lib/vector/Vlib/map.c:470 ../lib/vector/Vlib/map.c:571
 #, c-format
 msgid "Unable to delete table <%s>"
 msgstr "ไม่สามารถลบตารางได้ <%s>"
-#: ../lib/vector/Vlib/map.c:526
+#: ../lib/vector/Vlib/map.c:525
 #, fuzzy, c-format
 msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:540
+#: ../lib/vector/Vlib/map.c:539
 #, fuzzy, c-format
 msgid "Unable to open header file for vector map <%s>"
 msgstr "ไม่สามารถเปิด ไฟล์ประวัติ สำหรับแผนที่เชิงเส้น <%s>"
-#: ../lib/vector/Vlib/map.c:562
+#: ../lib/vector/Vlib/map.c:561
 #, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
 msgstr "ไม่สามารถค้นหาตาราง <%s> ที่เชื่อมกับข้อมูลเชิงเส้น <%s>"
-#: ../lib/vector/Vlib/map.c:579
+#: ../lib/vector/Vlib/map.c:578
 #, fuzzy, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:592
+#: ../lib/vector/Vlib/map.c:591
 #, c-format
 msgid "Unable to open directory '%s'"
 msgstr "ไม่สามารถเปิด directory '%s' ได้"
-#: ../lib/vector/Vlib/map.c:606
+#: ../lib/vector/Vlib/map.c:605
 #, c-format
 msgid "Unable to delete file '%s'"
 msgstr "ไม่สามารถลบไฟล์  '%s'"
-#: ../lib/vector/Vlib/map.c:623
+#: ../lib/vector/Vlib/map.c:622
 #, c-format
 msgid "Unable to rename directory '%s' to '%s'"
 msgstr "ไม่สามารถเปลี่ยนชื่อ  directory  '%s' เป็น '%s'"
-#: ../lib/vector/Vlib/map.c:631
+#: ../lib/vector/Vlib/map.c:630
 #, c-format
 msgid "Unable to remove directory '%s'"
 msgstr "ไม่สามารถลบ directory '%s'"
-#: ../lib/vector/Vlib/map.c:686 ../lib/vector/Vlib/map.c:787
+#: ../lib/vector/Vlib/map.c:685 ../lib/vector/Vlib/map.c:786
 #, c-format
 msgid "Unable to add database link for vector map <%s>"
 msgstr "ไม่สามารถเพิ่ม การเชื่อมต่อฐานข้อมูล สำหรับข้อมูลเชิงเส้น <%s>"
@@ -3301,14 +3303,14 @@
 msgid "Unable to open coor file for vector map <%s>"
-#: ../lib/vector/Vlib/open_nat.c:155
+#: ../lib/vector/Vlib/open_nat.c:154
 #, c-format
 msgid ""
 "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
 "excess)"
 msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:159
+#: ../lib/vector/Vlib/open_nat.c:158
 #, c-format
 msgid ""
 "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
@@ -3333,7 +3335,7 @@
 msgstr "Arc field < 1"
 #: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:204
-#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:488
+#: ../lib/vector/Vlib/net.c:357 ../lib/vector/Vlib/ascii.c:501
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr "ไม่สามารถ บรรยายตารางนี้ได้ <%s>"
@@ -3489,7 +3491,7 @@
 msgid "Unable to restore feature %d from vector map <%s>"
-#: ../lib/vector/Vlib/close.c:140
+#: ../lib/vector/Vlib/close.c:139
 #, fuzzy, c-format
 msgid "Unable to close vector <%s>"
 msgstr "ไม่สามารถเปิดแผนที่เชิงเส้นได้ <%s>"
@@ -3537,7 +3539,7 @@
 msgid "Unable to open spatial index file for vector map <%s>"
 msgstr "ไม่สามารถเปิด ไฟล์หมวดดัชนี สำหรับแผนที่เชิงเส้น <%s>"
-#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:511
+#: ../lib/vector/Vlib/open.c:320 ../lib/vector/Vlib/cindex.c:510
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
@@ -3557,41 +3559,41 @@
 msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:683
+#: ../lib/vector/Vlib/open.c:682
 #, fuzzy, c-format
 msgid "%s is not in the current mapset (%s)"
 msgstr "ไม่มีไฟล์ %s อยู่ในชุดแผนที่ปัจจุบัน\n"
-#: ../lib/vector/Vlib/open.c:721
+#: ../lib/vector/Vlib/open.c:720
 #, c-format
 msgid "Unable to create vector map <%s>"
 msgstr "ไม่สามารถสร้างแผนที่เชิงเส้น <%s>"
-#: ../lib/vector/Vlib/open.c:731
+#: ../lib/vector/Vlib/open.c:730
 #, fuzzy, c-format
 msgid "Unable to open history file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:783
+#: ../lib/vector/Vlib/open.c:782
 #, c-format
 msgid "Unable to stat file <%s>"
 msgstr "ไม่สามารถระบุสภาพไฟล์ <%s>"
-#: ../lib/vector/Vlib/open.c:842
+#: ../lib/vector/Vlib/open.c:841
 #, c-format
 msgid "unknown %d (update Vect_maptype_info)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:918
+#: ../lib/vector/Vlib/open.c:916
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr "ขนาดของ ไฟล์ 'coor' แตกต่างจากค่าที่บันทึกไว้ในไฟล์  topology"
-#: ../lib/vector/Vlib/open.c:929 ../lib/vector/Vlib/open.c:1024
+#: ../lib/vector/Vlib/open.c:927 ../lib/vector/Vlib/open.c:1021
 #, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
 msgstr "โปรดสร้าง  topology ของ แผนที่เชิงเส้นใหม่ <%s@%s>"
-#: ../lib/vector/Vlib/open.c:1013
+#: ../lib/vector/Vlib/open.c:1010
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in sidx file"
@@ -3637,87 +3639,97 @@
 msgid "Vector map <%s> is not open on level >= 2"
 msgstr "ไม่พบ ชื่อแผนที่เชิงเส้น <%s>"
-#: ../lib/vector/Vlib/ascii.c:77
+#: ../lib/vector/Vlib/ascii.c:80
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
 msgstr "ไม่สามารถอ่าน range ไฟล์สำหรับ [%s ใน %s]"
-#: ../lib/vector/Vlib/ascii.c:115
+#: ../lib/vector/Vlib/ascii.c:118
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
-#: ../lib/vector/Vlib/ascii.c:128
+#: ../lib/vector/Vlib/ascii.c:131
 msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:138
+#: ../lib/vector/Vlib/ascii.c:142
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
-#: ../lib/vector/Vlib/ascii.c:169
+#: ../lib/vector/Vlib/ascii.c:146
+#, fuzzy, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr "ไม่สามารถระบุ pj เพราะว่า: %s"
+#: ../lib/vector/Vlib/ascii.c:149
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:182
 msgid "End of ASCII file reached before end of categories"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:179
+#: ../lib/vector/Vlib/ascii.c:192
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
-#: ../lib/vector/Vlib/ascii.c:222
+#: ../lib/vector/Vlib/ascii.c:235
 #, c-format
 msgid ""
 "Unexpected data in vector head:\n"
 "[%s]"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:256
+#: ../lib/vector/Vlib/ascii.c:269
 #, fuzzy, c-format
 msgid "Unknown keyword <%s> in vector head"
 msgstr "ไม่ทราบชนิดของข้อมูลเชิงเส้น"
-#: ../lib/vector/Vlib/ascii.c:307 ../lib/db/dbmi_client/copy_tab.c:100
+#: ../lib/vector/Vlib/ascii.c:320 ../lib/db/dbmi_client/copy_tab.c:100
 #: ../lib/db/dbmi_client/copy_tab.c:120 ../lib/db/dbmi_client/db.c:41
 #, fuzzy, c-format
 msgid "Unable to start driver <%s>"
-#: ../lib/vector/Vlib/ascii.c:413
+#: ../lib/vector/Vlib/ascii.c:426
 #, fuzzy, c-format
 msgid "Uknown feature type %d"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr "ไม่ทราบข้อผิดพลาด"
 msgstr ""
 #, fuzzy, c-format
 msgstr "ไม่สามารถอ่าน ส่วนหัวของไฟล์ได้"
 #, fuzzy, c-format
@@ -3875,62 +3887,57 @@
 msgstr ""
 #, fuzzy
 msgstr "ไม่สามารถสร้างการทำงานใหม่ได้"
 #, fuzzy
 #, fuzzy
 msgstr "ไม่สามารถเปิดได้ %s"
 #, fuzzy, c-format
 msgstr "สีสัญลักษณ์ผิด: '%s', ใช้ค่าตั้งต้น"
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "เกิดข้อผิดพลาดระหว่างเปิด แผนที่ g3d <%s>"
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -4282,7 +4289,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4290,97 +4297,97 @@
 "วิธีใช้:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "ใช้ค่าตั้งต้น"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "การฉายภาพไม่ถูกต้อง\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "ไม่สามารถจองหน่วยความจำได้\n"
 msgstr ""
 #, fuzzy
 msgstr "กด RETURN เพื่อดำเนินการต่อ -->"
 msgid ""
@@ -4390,7 +4397,7 @@
 msgstr ""
 msgid ""
@@ -4399,34 +4406,34 @@
 msgstr ""
 msgstr "เสียใจ <%s> ไม่มีอยู่ในเงื่อนไข\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4435,20 +4442,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "โปรดแจ้งขอ้ผิดพลาดให้กับ ทีพัฒนา GRASS\n"
 msgid ""
@@ -4458,31 +4465,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy
 msgstr "GISRC - ไม่ได้กำหนดค่าตัวแปล"
 #, python-format
 msgid ""
@@ -4491,98 +4498,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "ไม่มีความช่วยเหลือสำหรับคำสั่งนี้ [%s]\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "none"
 #, fuzzy
 msgstr "ไม่สามารถเปิด temp ไฟล์"
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4599,25 +4601,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4779,7 +4781,7 @@
 msgstr "หน้าต่งถูกแทนด้วยค่าตั้งต้น"
 #, c-format
 msgstr "ไม่สามารถอ่านข้อมูล ประวัติสำหรับ [%s] ในชุดแผนที่  [%s]"
@@ -5011,12 +5013,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -5039,23 +5041,33 @@
 msgstr "ภาพการบัง ถูกสร้าง"
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr "[%s] ชุดแผนที่ [%s] - ในโซนที่แตกต่าง [%d] จากขอบเขตปัจจุบัน [%d]"
 msgstr ""
 #, fuzzy
 msgstr "การเชื่อมต่อล้มเหลว"
 msgstr ""
@@ -5169,7 +5181,7 @@
 msgstr "ตารางชื่อแผนที่ไม่ถูกต้อง <%s>. ตัวอักษรนี้ <%c> ใช้ไม่ได้.\n"
 msgstr ""
@@ -5830,6 +5842,14 @@
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
 msgstr ""
+#, fuzzy
+#~ msgid "Not enough room in history file to record command line"
+#~ msgstr "ไฟล์ประวัติเต็มไม่สามารถบันทึกคำสั่งต่อได้"
+#, fuzzy
+#~ msgid "Not enough room in history file for command line (truncated)"
+#~ msgstr "ไฟล์ประวัติเต็มไม่สามารถบันทึกคำสั่งต่อได้(ตัดสั้น)"
 #~ msgid "Unknown Location"
 #~ msgstr "ตำแหน่งที่ไม่รู้จัก"
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_tr.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_tr\n"
 "PO-Revision-Date: 2008-11-16 02:32+0200\n"
 "Last-Translator: Osman Yalçın YILMAZ <yilmazy at istanbul.edu.tr>\n"
 "Language-Team: Türkçe <tr at li.org>\n"
@@ -60,16 +60,24 @@
 msgstr "<%s> raster haritası oluşturulamıyor"
 msgstr ""
 msgid ""
 "raster maps"
 msgstr ""
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -455,25 +463,25 @@
 #, c-format
 msgstr "<%s> raster haritası bulunamadı"
@@ -718,32 +726,21 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "[%s] in geçmiş bilgisi yazılamıyor"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr "Komut satırında kaydetmek için geçmiş dosyasında yetersiz alan"
-#, fuzzy
-msgstr ""
-"Komut satırında kaydetmek için geçmiş dosyasında yetersiz alan (kesiliyor)"
@@ -794,7 +791,7 @@
 #, c-format
@@ -1174,12 +1171,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "%s (%s) harita takımı elemanı yapılamıyor"
 #, fuzzy, c-format
@@ -1721,23 +1718,27 @@
 msgstr "Alan ayracı"
+msgstr ""
 msgid "Color"
 msgstr "Renk"
 msgstr "Ya standart renk adı veya K:Y:M üçlemesi"
 msgstr "Arkaplan rengi"
 msgstr "Ya standart GRASS rengi,K:Y:M üçlemesi, yada \"hiçbiri\""
 msgid "Units"
 msgstr ""
@@ -1772,11 +1773,11 @@
 msgid "SYNOPSIS"
 msgstr ""
 msgid "Flags"
 msgstr "Flamalar"
 msgid "Parameters"
 msgstr "Parametreler"
@@ -2257,28 +2258,28 @@
 msgstr "%s tamamlandı. %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "MAPSET %s - eriÅŸim engellendi"
 #, c-format
 msgstr " %s MAPSET'i bulunamadı"
 msgstr ""
@@ -2465,12 +2466,12 @@
 msgstr ""
 #, fuzzy
 msgstr "vektör harita açılamadı"
 msgstr ""
@@ -2534,11 +2535,11 @@
 msgstr "%s: Alan %d mevcut deÄŸil"
 msgstr ""
 msgstr ""
@@ -2669,20 +2670,20 @@
 msgstr ""
 #, c-format
 msgstr "%d katmanının veritabanı bağlantısı belirlenmedi"
@@ -3070,46 +3071,46 @@
 msgstr ""
 #, fuzzy
 msgstr "çizgiler kaydediliyor ..."
 msgstr "Vektör harita okunamıyor"
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Alanlar oluÅŸturuluyor: "
 #, fuzzy, c-format
 msgstr "alanlar oluÅŸturuldu"
 #, fuzzy, c-format
 msgstr "adalar oluÅŸturuldu"
 #, fuzzy
 msgstr "Adalar ekleniyor:"
 #, fuzzy
 msgstr "Alan merkezleri ekleniyor: "
@@ -3156,91 +3157,91 @@
 msgstr ""
 #, c-format
 msgstr "Vektör harita isimleri YSD uyumlu değil"
 #, c-format
 msgstr "<%s> deki <%s> vektör haritası bulunamadı"
 #, c-format
 msgstr "<%s> vektör haritası zaten mevcut ve üzerine yazılacak"
 #, c-format
 msgstr "<%s> vektör haritası silinemiyor"
 #, c-format
 msgstr "Vektör harita <%s> ten <%s> e kopyalanamıyor"
 #, c-format
 msgstr "<%s> tablosuna kopyalanamıyor"
 #, c-format
 msgstr "<%s> tablosu için indeks oluşturulamıyor, anahtar <%s>"
 #, c-format
 msgstr "<%s> tablosu silinemiyor"
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr "'%s' dizini açılamıyor"
 #, c-format
 msgstr "'%s' dosyası silinemiyor"
 #, c-format
 msgstr "'%s' dizini '%s' olarak yeniden adlandırılamıyor"
 #, c-format
 msgstr "'%s' dizini kaldırılamıyor "
 #, c-format
 msgstr "<%s> vektör haritasının veritabanı bağı eklenemiyor"
@@ -3250,14 +3251,14 @@
 msgstr "<%s> vektör haritasının geçmiş dosyası açılamıyor"
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3280,7 +3281,7 @@
 msgstr ""
 #, c-format
 msgstr "<%s> sütunu <%s> tablosunda bulunamıyor"
@@ -3427,7 +3428,7 @@
 #, c-format
 msgstr "<%s> vektörü kapatılamıyor"
@@ -3475,7 +3476,7 @@
 #, c-format
 msgstr ""
@@ -3495,41 +3496,41 @@
 #, c-format
 msgstr "%s dosyası geçerli harita takımında değil (%s)"
 #, c-format
 msgstr "<%s> vektör haritası oluşturulamıyor"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
@@ -3574,87 +3575,97 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "[%s deki %s] in aralık dosyası okunamıyor"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr "<%s> Sürücüsü başlatılamıyor"
 #, fuzzy, c-format
 msgstr "bilinmeyen enterpolasyon tipi"
-#: ../lib/vector/Vlib/ascii.c:453
+#: ../lib/vector/Vlib/ascii.c:466
 #, c-format
 msgid "Feature has more categories. Only first category (%d) is exported."
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:463
+#: ../lib/vector/Vlib/ascii.c:476
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
 msgstr "<%s> tablosundan veri seçilemiyor"
-#: ../lib/vector/Vlib/ascii.c:490
+#: ../lib/vector/Vlib/ascii.c:503
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
 msgstr "<%s> sütunu bulunamıyor"
-#: ../lib/vector/Vlib/ascii.c:570
+#: ../lib/vector/Vlib/ascii.c:583
 #, fuzzy
 msgid "Unknown format"
 msgstr "bilinmeyen iÅŸletmen"
-#: ../lib/vector/Vlib/ascii.c:579
+#: ../lib/vector/Vlib/ascii.c:592
 msgid "Topology not available, unable to process areas"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:592
+#: ../lib/vector/Vlib/ascii.c:605
 #, fuzzy, c-format
 msgid "Unable to get boundary of area id %d"
 msgstr "<%s> raster haritasının kategori dosyası okunamıyor"
-#: ../lib/vector/Vlib/ascii.c:604
+#: ../lib/vector/Vlib/ascii.c:617
 #, fuzzy, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
@@ -3810,59 +3821,54 @@
 msgid "Unable to open select cursor: %s"
 msgstr "Seçme imleci açılamıyor: '%s'"
-#: ../lib/nviz/render.c:108
+#: ../lib/nviz/render.c:104
 msgid "Bad server connection"
 msgstr "Kötü sunucu bağlantısı"
-#: ../lib/nviz/render.c:117
+#: ../lib/nviz/render.c:113
 msgid "Unable to create rendering context"
 msgstr ""
-#: ../lib/nviz/lights.c:144
+#: ../lib/nviz/lights.c:174
 msgid "Unable to define new light"
 msgstr ""
-#: ../lib/nviz/position.c:50
+#: ../lib/nviz/position.c:56
 msgid "Unable to set focus"
 msgstr ""
-#: ../lib/nviz/nviz.c:78
+#: ../lib/nviz/nviz.c:105
 #, c-format
 msgid "Invalid color (%s), using \"white\" as default"
 msgstr "Yanlış renk (%s), \"beyaz\" varsayılan olarak kullanılıyor"
-#: ../lib/nviz/change_view.c:108
-#, c-format
-msgid "Invalid view position coordinates, using %f,%f"
-msgstr ""
-#: ../lib/nviz/map_obj.c:65
+#: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:94
+#: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:103 ../lib/nviz/map_obj.c:134
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, c-format
 msgid "Error loading vector map <%s>"
 msgstr ""
-#: ../lib/nviz/map_obj.c:122
+#: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:149
+#: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
 msgstr ""
-#: ../lib/nviz/map_obj.c:158
+#: ../lib/nviz/map_obj.c:152
 #, c-format
 msgid "Error loading 3d raster map <%s>"
 msgstr ""
-#: ../lib/nviz/map_obj.c:166
+#: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
 msgstr ""
@@ -4160,7 +4166,7 @@
 msgid "The total sum of the water budget is significant larger then 0: %g\n"
 msgstr ""
-#: ../lib/init/grass.py:145
+#: ../lib/init/grass.py:146
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4168,97 +4174,97 @@
 "Kullanım:\n"
-#: ../lib/init/grass.py:147
+#: ../lib/init/grass.py:148
 msgid "print this help message"
 msgstr ""
-#: ../lib/init/grass.py:148
+#: ../lib/init/grass.py:149
 msgid "show version information and exit"
 msgstr ""
-#: ../lib/init/grass.py:149
+#: ../lib/init/grass.py:150
 msgid "create given mapset if it doesn't exist"
 msgstr ""
-#: ../lib/init/grass.py:150
+#: ../lib/init/grass.py:151
 msgid "use text based interface"
 msgstr ""
-#: ../lib/init/grass.py:151 ../lib/init/grass.py:153 ../lib/init/grass.py:155
+#: ../lib/init/grass.py:152 ../lib/init/grass.py:154 ../lib/init/grass.py:156
 #, fuzzy
 msgid "and set as default"
 msgstr "varsayılanı kabul et"
-#: ../lib/init/grass.py:152
+#: ../lib/init/grass.py:153
 msgid "use graphical user interface ($DEFAULT_GUI by default)"
 msgstr ""
-#: ../lib/init/grass.py:154
+#: ../lib/init/grass.py:155
 msgid "use wxPython based graphical user interface"
 msgstr ""
-#: ../lib/init/grass.py:157
+#: ../lib/init/grass.py:158
 msgid "initial database (path to GIS data)"
 msgstr ""
-#: ../lib/init/grass.py:158
+#: ../lib/init/grass.py:159
 #, fuzzy
 msgid "initial location"
 msgstr ""
 "\n"
 "geçersiz projeksiyon\n"
-#: ../lib/init/grass.py:159
+#: ../lib/init/grass.py:160
 msgid "initial mapset"
 msgstr ""
-#: ../lib/init/grass.py:160
+#: ../lib/init/grass.py:161
 msgid "fully qualified initial mapset directory"
 msgstr ""
-#: ../lib/init/grass.py:161
+#: ../lib/init/grass.py:162
 msgid "Environment variables relevant for startup"
 msgstr ""
-#: ../lib/init/grass.py:162
+#: ../lib/init/grass.py:163
 msgid "select GUI (text, gui, wxpython)"
 msgstr ""
-#: ../lib/init/grass.py:163
+#: ../lib/init/grass.py:164
 msgid "set wish shell name to override 'wish'"
 msgstr ""
-#: ../lib/init/grass.py:164
+#: ../lib/init/grass.py:165
 msgid "set html web browser for help pages"
 msgstr ""
-#: ../lib/init/grass.py:165
+#: ../lib/init/grass.py:166
 msgid "set additional path(s) to local GRASS modules"
 msgstr ""
-#: ../lib/init/grass.py:166
+#: ../lib/init/grass.py:167
 msgid "shell script to be processed as batch job"
 msgstr ""
-#: ../lib/init/grass.py:167
+#: ../lib/init/grass.py:168
 msgid "set python shell name to override 'python'"
 msgstr ""
-#: ../lib/init/grass.py:187
+#: ../lib/init/grass.py:188
 #, fuzzy
 msgid "Unable to create temporary directory! Exiting."
-#: ../lib/init/grass.py:357
+#: ../lib/init/grass.py:356
 msgid "Searched for a web browser, but none found"
 msgstr ""
-#: ../lib/init/grass.py:376
+#: ../lib/init/grass.py:375
 #, fuzzy
 msgid "Hit RETURN to continue"
 msgstr "Devam etmek için ENTER'a basın -->"
-#: ../lib/init/grass.py:405
+#: ../lib/init/grass.py:404
 msgid ""
 "The python command does not work as expected!\n"
 "Please check your GRASS_PYTHON environment variable.\n"
@@ -4268,7 +4274,7 @@
 "Hit RETURN to continue.\n"
 msgstr ""
-#: ../lib/init/grass.py:417
+#: ../lib/init/grass.py:416
 msgid ""
 "It appears that the X Windows system is not active.\n"
 "A graphical based user interface is not supported.\n"
@@ -4277,34 +4283,34 @@
 msgstr ""
-#: ../lib/init/grass.py:459 ../lib/init/grass.py:472
+#: ../lib/init/grass.py:458 ../lib/init/grass.py:471
 #, fuzzy, python-format
 msgid "<%s> is not a valid GRASS location"
 msgstr "Üzgünüm <%s> geçerli bir seçenek değil\n"
-#: ../lib/init/grass.py:464
+#: ../lib/init/grass.py:463
 #, python-format
 msgid "The location <%s> does not exist. Please create it first."
 msgstr ""
-#: ../lib/init/grass.py:470
+#: ../lib/init/grass.py:469
 msgid "Missing WIND file fixed"
 msgstr ""
-#: ../lib/init/grass.py:484
+#: ../lib/init/grass.py:483
 msgid ""
 "GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
 "Interactive startup needed."
 msgstr ""
-#: ../lib/init/grass.py:498
+#: ../lib/init/grass.py:497
 #, python-format
 msgid ""
 "Invalid user interface specified - <%s>.\n"
 "Use the --help option to see valid interface names."
 msgstr ""
-#: ../lib/init/grass.py:511
+#: ../lib/init/grass.py:510
 msgid ""
 "Error in GUI startup. If necessary, please report this error to the GRASS "
 "developers.\n"
@@ -4313,19 +4319,19 @@
 "Hit RETURN to continue..."
 msgstr ""
-#: ../lib/init/grass.py:521
+#: ../lib/init/grass.py:520
 msgid ""
 "Received EXIT message from GUI.\n"
 "GRASS is not started. Bye."
 msgstr ""
-#: ../lib/init/grass.py:524
+#: ../lib/init/grass.py:523
 msgid ""
 "Invalid return code from GUI startup script.\n"
 msgstr ""
-#: ../lib/init/grass.py:534
+#: ../lib/init/grass.py:533
 msgid ""
 "Error reading data path information from g.gisenv.\n"
 "GISDBASE=%(gisbase)s\n"
@@ -4335,31 +4341,31 @@
 "Check the <%s(file)> file."
 msgstr ""
-#: ../lib/init/grass.py:555
+#: ../lib/init/grass.py:554
 #, python-format
 msgid ""
 "%(user)s is currently running GRASS in selected mapset (file %(file)s "
 "found). Concurrent use not allowed."
 msgstr ""
-#: ../lib/init/grass.py:559
+#: ../lib/init/grass.py:558
 #, python-format
 msgid ""
 "Unable to properly access \"%s\"\n"
 "Please notify system personel."
 msgstr ""
-#: ../lib/init/grass.py:570
+#: ../lib/init/grass.py:569
 #, fuzzy
 msgid "Building user fontcap..."
 msgstr "Grafik oluÅŸturuluyor..."
-#: ../lib/init/grass.py:599
+#: ../lib/init/grass.py:598
 #, fuzzy
 msgid "The SHELL variable is not set"
 msgstr "GISRC - değişken ayarlanmadı"
-#: ../lib/init/grass.py:609
+#: ../lib/init/grass.py:608
 #, python-format
 msgid ""
 "Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
@@ -4368,98 +4374,93 @@
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
-#: ../lib/init/grass.py:614
+#: ../lib/init/grass.py:613
 #, python-format
 msgid "Change file permission to 'executable' for '%s'"
 msgstr ""
-#: ../lib/init/grass.py:616
+#: ../lib/init/grass.py:615
 #, python-format
 msgid "Executing '%s' ..."
 msgstr ""
-#: ../lib/init/grass.py:623
+#: ../lib/init/grass.py:620
 #, python-format
+msgid "Execution of '%s' finished."
+msgstr ""
+#: ../lib/init/grass.py:625
+#, python-format
 msgid "GRASS GUI should be '%s'"
 msgstr ""
-#: ../lib/init/grass.py:667
+#: ../lib/init/grass.py:669
 msgid "GRASS homepage:"
 msgstr ""
-#: ../lib/init/grass.py:668
+#: ../lib/init/grass.py:670
 msgid "This version running through:"
 msgstr ""
-#: ../lib/init/grass.py:670
+#: ../lib/init/grass.py:672
 #, fuzzy
 msgid "Help is available with the command:"
 msgstr "[%s] komutu için yardım yoktur\n"
-#: ../lib/init/grass.py:671
+#: ../lib/init/grass.py:673
 msgid "See the licence terms with:"
 msgstr ""
-#: ../lib/init/grass.py:674
+#: ../lib/init/grass.py:676
 msgid "If required, restart the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:676
+#: ../lib/init/grass.py:678
 msgid "Start the GUI with:"
 msgstr ""
-#: ../lib/init/grass.py:678
+#: ../lib/init/grass.py:680
 msgid "When ready to quit enter:"
 msgstr ""
-#: ../lib/init/grass.py:781
+#: ../lib/init/grass.py:783
 msgid "Failed to start shell '%s'"
-#: ../lib/init/grass.py:785
+#: ../lib/init/grass.py:787
 #, python-format
 msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
 msgstr ""
-#: ../lib/init/grass.py:786 ../lib/init/grass.py:791
+#: ../lib/init/grass.py:788 ../lib/init/grass.py:793
 msgid "Goodbye from GRASS GIS"
 msgstr ""
-#: ../lib/init/grass.py:789
+#: ../lib/init/grass.py:791
 #, fuzzy
 msgid "Done."
 msgstr "hiçbiri"
-#: ../lib/init/grass.py:795
+#: ../lib/init/grass.py:797
 #, fuzzy
 msgid "Cleaning up temporary files..."
 msgstr "Geçici dosya açılamıyor"
-#: ../lib/init/grass.py:938
+#: ../lib/init/grass.py:940
 msgid "Starting GRASS GIS..."
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:84
+#: ../lib/rst/interp_float/output2d.c:106
 #, c-format
 msgid "First change your rows number to nsizr! %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:91
+#: ../lib/rst/interp_float/output2d.c:113
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
 msgstr ""
-#: ../lib/rst/interp_float/output2d.c:99
-#, c-format
-msgid "Rows changed from %d to %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:105
-#, c-format
-msgid "Cols changed from %d to %d"
-msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:111
 #, fuzzy
 msgid ""
@@ -4476,25 +4477,25 @@
 "cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:60
+#: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:86
+#: ../lib/rst/interp_float/resout2d.c:103
 #, c-format
 msgid "First change your rows number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:93
+#: ../lib/rst/interp_float/resout2d.c:110
 #, c-format
 msgid "First change your columns number(%d) to %d"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:247
+#: ../lib/rst/interp_float/resout2d.c:264
 msgid "No color table for input raster map -- will not create color table"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:458
 msgid "Changing the region back to initial..."
 msgstr ""
@@ -4655,7 +4656,7 @@
 msgid "Window replacing the default"
 msgstr ""
-#: ../lib/g3d/g3dhistory.c:42
+#: ../lib/g3d/g3dhistory.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
 msgstr "[%s] harita takımındaki [%s] in geçmiş bilgisi alınamıyor"
@@ -4884,12 +4885,12 @@
 msgstr ""
-#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:771
+#: ../lib/ogsf/Gs3.c:700 ../lib/ogsf/Gs3.c:772
 #, c-format
 msgid "Translating colors from raster map <%s>..."
 msgstr ""
-#: ../lib/ogsf/Gs3.c:1005
+#: ../lib/ogsf/Gs3.c:1007
 msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
@@ -4911,22 +4912,32 @@
 msgid "Bitmap mismatch"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1643
+#: ../lib/ogsf/GS2.c:1198
 #, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1217
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1640
+#, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr ""
-#: ../lib/ogsf/GS2.c:1723 ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1737
-#: ../lib/ogsf/GS2.c:1746 ../lib/ogsf/GS2.c:1754 ../lib/ogsf/GS2.c:1764
-#: ../lib/ogsf/GS2.c:1812
+#: ../lib/ogsf/GS2.c:1720 ../lib/ogsf/GS2.c:1726 ../lib/ogsf/GS2.c:1734
+#: ../lib/ogsf/GS2.c:1743 ../lib/ogsf/GS2.c:1751 ../lib/ogsf/GS2.c:1761
+#: ../lib/ogsf/GS2.c:1809
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1840
+#: ../lib/ogsf/GS2.c:1837
 msgid "Loading failed"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1844
+#: ../lib/ogsf/GS2.c:1841
 msgid "Error finding range"
 msgstr ""
@@ -5032,7 +5043,7 @@
 msgstr ""
 "Uygun olmayan tablo ad yazımı <%s>. <%c> karakteri kullanılmamalıdır.\n"
-#: ../lib/db/dbmi_base/login.c:112
+#: ../lib/db/dbmi_base/login.c:111
 msgid "Login file corrupted"
 msgstr ""
@@ -5633,6 +5644,15 @@
 msgstr ""
+#, fuzzy
+#~ msgstr "Komut satırında kaydetmek için geçmiş dosyasında yetersiz alan"
+#, fuzzy
+#~ msgstr ""
+#~ "Komut satırında kaydetmek için geçmiş dosyasında yetersiz alan (kesiliyor)"
 #~ msgstr "Bilinmeyen Mevki"
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_vi.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_vi\n"
 "PO-Revision-Date: 2009-09-11 09:54+0700\n"
 "Last-Translator: \n"
 "Language-Team: American English <kde-i18n-doc at lists.kde.org>\n"
@@ -61,11 +61,11 @@
 msgstr "Không thể đọc miền của bản đồ raster <%s>"
 msgstr ""
 #, fuzzy
 msgid ""
@@ -73,6 +73,14 @@
 msgstr ""
 "G_set_window(): phép chiếu/múi khác với của các bản đồ raster hiện đang mở"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgstr "Không tìm thấy bản đồ raster <%s>"
@@ -737,32 +745,21 @@
 msgstr "Không thể mở tập tin header của bản đồ raster <%s@%s>"
 #, fuzzy, c-format
 msgstr "không thể ghi thông tin lịch sử cho [%s]"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr "Không đủ không gian trong tập tin lịch sử để lưu dòng lệnh."
-#, fuzzy
-msgstr ""
-"Không đủ không gian trong tập tin lịch sử để chứa dòng lệnh (bị cắt bớt)."
@@ -813,7 +810,7 @@
 #, c-format
@@ -1197,12 +1194,12 @@
 "Chỉ có %d%% của cửa sổ được lưu trong \"%s\" trùng với cửa sổ GRASS hiện "
 "tại. "
 #, fuzzy, c-format
 msgstr "Không thể tạo thành phần %s (%s) cho bộ bản đồ"
 #, fuzzy, c-format
@@ -1753,23 +1750,27 @@
 msgstr "Dấu phân cách trường"
+msgstr ""
 msgid "Color"
 msgstr "Màu"
 msgstr "Hoặc là một màu chuẩn hoặc là bộ ba R:G:B"
 msgstr "Màu nền"
 msgstr "Hoặc là một màu GRASS chuẩn, bộ ba R:G:B, hoặc \"none\""
 msgid "Units"
 msgstr ""
@@ -1804,11 +1805,11 @@
 msgid "SYNOPSIS"
 msgstr "TÓM TẮT"
 msgid "Flags"
 msgstr "Các cờ"
 msgid "Parameters"
 msgstr "Các tham số"
@@ -2291,28 +2292,28 @@
 msgstr "%s hoàn tất. %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "BỘ BẢN ĐỒ %s - không được phép "
 #, c-format
 msgstr "không tìm thấy BỘ BẢN ĐỒ %s "
 msgstr "Hệ thống không được khởi chạy. Lập trình viên quên gọi G_gisinit()."
@@ -2499,12 +2500,12 @@
 msgstr ""
 #, fuzzy
 msgstr "Không thể mở tập tin tạm"
 msgstr ""
@@ -2575,11 +2576,11 @@
 msgstr "%s: Vùng %d không tồn tại"
 msgstr "Cố gắng xoá đối tượng chết"
 msgstr "Cố gắng phục hồi lại đối tượng sống"
@@ -2712,20 +2713,20 @@
 msgstr "Không đủ không gian trong mảng vec-tơ"
 #, c-format
 msgstr "Kết nối CSDL không được định nghĩa cho lớp %d"
@@ -3123,43 +3124,43 @@
 msgstr "Yêu cầu tìm kiếm vùng nằm ngoài đảo không tồn tại"
 msgstr "Đang đăng ký các đối tượng nguyên thủy..."
 msgstr "Không thể đọc bản đồ vec-tơ"
 #, c-format
 msgstr "%d đối tượng nguyên thủy được đăng ký"
 #, c-format
 msgstr "%d đỉnh được đăng ký"
 msgstr "Đang xây dựng các vùng..."
 #, c-format
 msgstr "%d vùng được xây dựng"
 #, c-format
 msgstr "%d đảo được xây dựng"
 msgstr "Đang gắn các đảo..."
 msgstr "Đang gắn các trọng tâm..."
 msgstr "Không thể đọc bản đồ vec-tơ <%s>"
 #, c-format
 msgstr "Tên bản đồ vec-tơ không tương thích SQL"
 #, c-format
 msgstr "Không thể tìm thấy bản đồ vec-tơ <%s> trongg <%s>"
 #, c-format
 msgstr "Bản đồ vec-tơ <%s> đã có và sẽ bị ghi đè"
 #, c-format
 msgstr "Không thể xoá bản đồ vec-tơ <%s>"
 #, c-format
 msgstr "Không thể sao chép bản đồ vec-tơ <%s> vào <%s>"
 #, c-format
 msgstr "Không thể sao chép bảng <%s>"
 #, c-format
 msgstr "Không thể tạo chỉ mục cho bảng <%s>, khoá <%s>"
 #, c-format
 msgstr "Không thể xoá bảng <%s>"
 #, c-format
 msgstr "Tên bản đồ vec-tơ không hợp lệ <%s>"
 #, c-format
 msgstr "Không thể mở tập tin header của bản đồ vec-tơ <%s>"
 #, c-format
 msgstr "Không thể tìm thấy bảng <%s> được liên kết vào bản đồ vec-tơ <%s>"
 #, c-format
 msgstr "Bảng <%s> được liên kết vào bản đồ vec-tơ <%s> không tồn tại"
 #, c-format
 msgstr "Không thể mở thư mục '%s'"
 #, c-format
 msgstr "Không thể xoá tập tin '%s'"
 #, c-format
 msgstr "Không thể đổi tên thư mục '%s' thành '%s'"
 #, c-format
 msgstr "Không thể loại bỏ thư mục '%s'"
 #, c-format
 msgstr "Không thể thêm liên kết csdl cho bản đồ vec-tơ '%s'"
 msgstr "Không thể mở tập tin lịch sử của bản đồ vec-tơ <%s>"
 #, fuzzy, c-format
 msgid ""
 "Các tập tin coor của bản đồ vec-tơ <%s@%s> lớn hơn cỡ đúng của nó (quá %ld "
 "byte)"
 #, fuzzy, c-format
 msgid ""
 msgstr "Trường Arc < 1"
 #, c-format
 msgstr "Không tìm thấy cột <%s> trong bảng <%s>"
@@ -3487,7 +3488,7 @@
 msgstr "Không thể phục hồi lại đối tượng %d từ bản đồ vec-tơ <%s>"
 #, c-format
 msgstr "Không thể đóng vec-tơ <%s>"
@@ -3539,7 +3540,7 @@
 msgstr "Không thể mở tập tin chỉ mục phạm trù của bản đồ vec-tơ <%s>"
 #, c-format
@@ -3559,41 +3560,41 @@
 #, c-format
 msgstr "%s không ở trong bộ bản đồ hiện tại (%s)"
 #, c-format
 msgstr "Không thể tạo bản đồ vec-tơ <%s>"
 #, fuzzy, c-format
 #, c-format
 msgstr "Không thể khởi động tập tin <%s>"
 #, c-format
 msgstr ""
 msgstr "Kích thước của tập tin 'coor' khác với giá trị lưu trong tập tin tôpô."
 #, c-format
 msgstr "Vui lòng xây dựng lại tôpô cho bản đồ vec-tơ <%s@%s>"
 #, fuzzy
@@ -3644,87 +3645,97 @@
 msgstr "Bản đồ vec-tơ <%s> không mở được ở cấp >=2"
 #, fuzzy, c-format
 msgstr "Không thể đọc tập tin range cho [%s ở %s]"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Không thể khởi tạo pj nguyên nhân: %s"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Không hiểu từ khoá %s trong tiêu đề vec-tơ"
 #, c-format
 msgstr "Không thể khởi động trình điều khiển <%s>"
 #, fuzzy, c-format
 msgstr "Kiểu vec-tơ không biết."
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "Không thể chọn bản ghi từ bảng <%s> (khoá %s, tại %s)"
 #, fuzzy, c-format
 msgstr "Nviz_new_map_obj(): kiểu dữ liệu không được hỗ trợ"
 #, fuzzy
 msgstr "toán tử không hiểu"
 msgstr ""
 #, fuzzy, c-format
 msgstr "Không thể thiết lập phạm trù %d cho (đối tượng có id %d)"
 #, fuzzy, c-format
@@ -3883,59 +3894,54 @@
 msgstr "Không thể mở con trỏ chọn: '%s'"
 msgstr "Kết nối với máy chủ kém"
 msgstr "Không thể tạo ngữ cảnh kết xuất"
 msgstr "Không thể định nghĩa nguồn sáng mới"
 msgstr "Không thể thiết lập tiêu điểm"
 #, c-format
 msgstr "Màu không hợp lệ (%s), dùng \"white\" (trắng) làm mặc định"
-#, c-format
-msgstr "Tọa độ vị trí xem không hợp lệ, đang dùng %f,%f"
 msgstr "Số bề mặt nhiều nhất đã được nạp!"
 msgstr "Số bản đồ đường vec-tơ nhiều nhất đã được nạp!"
 #, c-format
 msgstr "Lỗi khi đang nạp bản đồ vec-tơ <%s>"
 msgstr "Số bản đồ vec-tơ kiểu điểm nhiều nhất đã được nạp!"
 msgstr "Số thể tích nhiều nhất đã được nạp!"
 #, c-format
 msgstr "Lỗi khi đang nạp bản đồ raster 3d <%s>"
@@ -4287,7 +4293,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4295,97 +4301,97 @@
 "Cách dùng:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "để chấp nhận mặc định"
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr ""
 "\n"
 "phép chiếu không hợp lệ\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Không thể cấp phát hình ảnh tạm"
 msgstr ""
 #, fuzzy
 msgstr "bấm RETURN để tiếp tục -->"
 msgid ""
@@ -4395,7 +4401,7 @@
 msgstr ""
 msgid ""
@@ -4404,34 +4410,34 @@
 msgstr ""
 msgstr "Xin lỗi <%s> không phải là tùy chọn hợp lệ\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4440,20 +4446,20 @@
 msgstr ""
 msgid ""
 msgstr ""
 #, fuzzy
 msgid ""
 msgstr "Vui lòng báo cho các nhà phát triển GRASS về lỗi này.\n"
 msgid ""
@@ -4463,31 +4469,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Đang xây dựng biểu đồ..."
 #, fuzzy
 msgstr "GISRC - biến không được thiết lập"
 #, python-format
 msgid ""
@@ -4496,98 +4502,93 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Không có trợ giúp cho lệnh [%s]\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "không có"
 #, fuzzy
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4604,25 +4605,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4787,7 +4788,7 @@
 msgstr "Cửa sổ thay thế cho mặc định"
 #, c-format
 msgstr "không thể lấy thông tin lịch sử cho [%s] trong bộ bản đồ [%s] "
@@ -5022,12 +5023,12 @@
 msgstr "Miền bảng màu không khớp với dữ liệu (mincol=%d, maxcol=%d) "
 #, c-format
 msgstr "Đang dịch các màu từ bản đồ raster <%s>..."
 msgstr ""
 "Vùng xem không được chương trình này lưu, có thể có một số sự không nhất quán"
@@ -5051,22 +5052,32 @@
 msgstr "Bitmap không khớp"
 #, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
+#, c-format
 msgstr "Bản đồ raster <%s> nằm ngoài vùng hiện tại. Việc nạp thất bại."
 msgstr "GS_load_att_map(): Hết bộ nhớ. Không thể nạp bản đồ"
 msgstr "Việc nạp thất bại"
 msgstr "Lỗi khi đang tìm miền"
@@ -5171,7 +5182,7 @@
 msgstr "Tên bản đồ bảng không hợp lệ <%s>. Ký tự <%c> không được phép.\n"
 msgstr ""
@@ -5834,6 +5845,18 @@
 msgstr "nhóm phụ <%s> của nhóm <%s> tham chiếu các bản đồ raster sau\n"
+#, fuzzy
+#~ msgstr "Không đủ không gian trong tập tin lịch sử để lưu dòng lệnh."
+#, fuzzy
+#~ msgstr ""
+#~ "Không đủ không gian trong tập tin lịch sử để chứa dòng lệnh (bị cắt bớt)."
+#~ msgstr "Tọa độ vị trí xem không hợp lệ, đang dùng %f,%f"
 #~ msgstr "Vị trí không biết"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grasslibs_zh.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_zh\n"
 "PO-Revision-Date: 2007-12-13 16:42+0100\n"
 "Last-Translator: Su Yongheng <night2008 at gmail.com>\n"
 "Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
@@ -63,17 +63,25 @@
 msgstr "无法将目录改变到%s"
 msgstr ""
 #, fuzzy
 msgid ""
 "raster maps"
 msgstr "G_set_window():投影/区域与当前打开的栅格文件不同"
+msgstr ""
+msgstr ""
 #, fuzzy, c-format
@@ -462,25 +470,25 @@
 #, fuzzy, c-format
 msgstr "输入矢量'%s'未找到"
@@ -737,31 +745,21 @@
 msgstr "无法打开矢量'%s'的历史记录"
 #, fuzzy, c-format
 msgstr "无法写入[%s]的历史信息"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
-#, fuzzy
-msgstr "历史信息文件没有足够的空间来记录命令行。"
-#, fuzzy
-msgstr "历史信息文件没有足够的空间来记录命令行(截取的)。"
@@ -812,7 +810,7 @@
 #, fuzzy, c-format
@@ -1195,12 +1193,12 @@
 msgstr "只有 %d %%的窗口(存储于\"%s\"中)与当前GRASS窗口重叠。"
 #, fuzzy, c-format
 msgstr "无法生成地图集元素 %s (%s)"
 #, fuzzy, c-format
@@ -1756,23 +1754,27 @@
 msgstr "字段分隔符"
+msgstr ""
 msgid "Color"
 msgstr "颜色"
 msgstr "使用一个标准的颜色名或R:G:B三元组"
 msgstr "背景颜色"
 msgstr "选用标准GRASS颜色,R:G:B三元组或是\"空\""
 msgid "Units"
 msgstr ""
@@ -1807,11 +1809,11 @@
 msgid "SYNOPSIS"
 msgstr "提要"
 msgid "Flags"
 msgstr "标记:"
 msgid "Parameters"
 msgstr "参数:"
@@ -2292,29 +2294,29 @@
 msgstr "%s 完成。 %s"
 msgid ""
 msgstr ""
 #, c-format
 msgstr "地图集%s - 权限拒绝"
 #, c-format
 msgstr "未找到地图集%s"
 #, fuzzy
 msgstr "\a错误:系统没有初始化。程序员忘记调用 G_gisinit()\n"
@@ -2511,12 +2513,12 @@
 msgstr ""
 #, fuzzy
 msgstr "无法打开文件 %s 在 %s 中"
 msgstr ""
@@ -2581,12 +2583,12 @@
 msgstr ""
 #, fuzzy
 msgstr "无法为区域 %d 计算质心"
 #, fuzzy
@@ -2722,20 +2724,20 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -3139,47 +3141,47 @@
 msgstr ""
 #, fuzzy
 msgstr "注册线: "
 #, fuzzy
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 msgstr "\r%d 条原始线被注册      \n"
 #, fuzzy, c-format
 #, fuzzy
 msgstr "建立拓扑...\n"
 #, fuzzy, c-format
 msgstr "拓扑建立完成。\n"
 #, fuzzy, c-format
 msgstr "拓扑建立完成。\n"
 #, fuzzy
 msgstr "附加岛:"
 #, fuzzy
 msgstr "附加质心:"
@@ -3227,91 +3229,91 @@
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 msgstr "地图名称不适应SQL"
 #, fuzzy, c-format
 msgstr "无法打开栅格图[%s在%s中]"
 #, fuzzy, c-format
 msgstr "矢量'%s'已经存在,它将会被覆盖。"
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "无法为[%s在%s中]创建头文件"
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
@@ -3321,14 +3323,14 @@
 #, c-format
 msgid ""
 "excess)"
 msgstr ""
 #, c-format
 msgid ""
@@ -3353,7 +3355,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "无法打开数据库表 <%s>"
@@ -3508,7 +3510,7 @@
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
@@ -3557,7 +3559,7 @@
 #, fuzzy, c-format
@@ -3577,42 +3579,42 @@
 #, fuzzy, c-format
 msgstr "当前地图集中没有 %s 文件\n"
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "'coor'文件的大小与拓扑文件中保存的值不同。"
 #, fuzzy, c-format
 msgstr "请为矢量'%s@%s'重建拓扑"
 #, fuzzy
@@ -3658,87 +3660,97 @@
 #, fuzzy, c-format
 msgstr "无法为[%s在%s中]读取范围文件"
 #, fuzzy, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "无法打开文件 %s 在 %s 中"
+#, c-format
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
 #, c-format
 msgid ""
 "[%s]"
 msgstr ""
 #, fuzzy, c-format
 msgstr "未知矢量类型"
 #, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "未知矢量类型"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy
 msgstr "未知区域"
 msgstr ""
 #, fuzzy, c-format
 msgstr "无法打开临时文件"
 #, fuzzy, c-format
 msgstr "无法打开临时文件"
@@ -3898,62 +3910,57 @@
 msgstr "无法将目录改变到%s"
 msgstr ""
 #, fuzzy
 msgstr "不能创建新进程"
 #, fuzzy
 #, fuzzy
 msgstr "无法打开%s"
 #, fuzzy, c-format
 msgstr "不正确的符号颜色:'%s',使用默认值。"
-#, c-format
-msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "打开g3d地图 <%s>错误"
 msgstr ""
 msgstr ""
 #, fuzzy, c-format
 msgstr "已有栅格地图 %d"
 msgstr ""
@@ -4306,7 +4313,7 @@
 msgstr ""
 #, fuzzy
 msgid "Usage"
 msgstr ""
@@ -4314,92 +4321,92 @@
 "用法:\n"
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "无法分配内存\n"
 msgstr ""
 msgstr ""
 msgid ""
@@ -4409,7 +4416,7 @@
 msgstr ""
 msgid ""
@@ -4418,34 +4425,34 @@
 msgstr ""
 msgstr "对不起,<%s>不是有效的选项\n"
 #, python-format
 msgstr ""
 msgstr ""
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 msgid ""
 "developers.\n"
@@ -4454,19 +4461,19 @@
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
 msgstr ""
 msgid ""
@@ -4476,31 +4483,31 @@
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, python-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "建立拓扑...\n"
 #, fuzzy
 msgstr "GISRC - 变量未设置"
 #, python-format
 msgid ""
@@ -4509,96 +4516,91 @@
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
+msgstr ""
+#, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid "Done."
 msgstr "æ— "
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
 msgid ""
@@ -4614,25 +4616,25 @@
 msgstr ""
 msgstr ""
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
 msgstr ""
 msgstr ""
@@ -4794,7 +4796,7 @@
 msgstr "替换默认窗口"
 #, c-format
 msgstr "无法得到[%s](在地图集[%s]中)的历史信息"
@@ -5026,12 +5028,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
@@ -5053,23 +5055,33 @@
 msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgid "no data"
+msgstr ""
 #, fuzzy, c-format
 msgstr "[%s]在地图集[%s]中 - 区域[%d]与当前的范围[%d]不同"
 msgstr ""
 #, fuzzy
 msgstr "连接失败。\n"
 #, fuzzy
 msgstr "已有栅格地图 %d"
@@ -5184,7 +5196,7 @@
 msgstr "非法的表格名称 <%s> 。不允许有字符 <%c> 。\n"
 msgstr ""
@@ -5849,6 +5861,14 @@
 msgstr ""
+#, fuzzy
+#~ msgstr "历史信息文件没有足够的空间来记录命令行。"
+#, fuzzy
+#~ msgstr "历史信息文件没有足够的空间来记录命令行(截取的)。"
 #~ msgstr "未知区域"
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_ar.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ar\n"
 "PO-Revision-Date: 2005-03-09 12:50+0100\n"
 "Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
 "Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -17,7 +17,7 @@
 "X-Generator: KBabel 1.11.2\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 msgid "Error closing 3d raster map"
@@ -61,7 +61,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "اسم الخريطة الراسترية"
@@ -81,7 +81,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -177,7 +177,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -192,40 +191,40 @@
 msgid "Error opening grid3 file [%s]"
 msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 #, fuzzy
 msgid "Cannot allocate memory for string"
 msgstr "لم يتم حساب شبه مركز المساحة"
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, c-format
 msgid "Error reading range for [%s]"
 msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 msgid "Error while reading history file"
 msgstr ""
@@ -257,7 +256,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -285,7 +284,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "dig عطل فى فتح ملف المدخل"
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 #, fuzzy
 msgid "Error closing ascii file"
 msgstr "خطا فى محاولة قراءة ملف قاعدة البيانات dbmscap\n"
@@ -1097,7 +1096,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1112,7 +1111,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1145,17 +1144,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1209,7 +1207,7 @@
 msgstr "مضاهاة"
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 #, fuzzy
 msgid "List supported formats and exit"
 msgstr "عرض الهيئات المدعمة والخروج"
@@ -1223,22 +1221,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1287,7 +1285,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 msgid "Name of input raster map"
@@ -1591,12 +1588,27 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr "عدد الصفوف التى تحفظ فى الذاكرة"
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
+#, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "!تم تحديد إحداثى شمال فارغ"
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr ""
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 #, fuzzy
 msgid "Writing raster map..."
@@ -1616,12 +1628,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1651,7 +1663,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1661,7 +1673,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1731,13 +1743,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1753,7 +1765,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1763,8 +1775,8 @@
 msgid "Unable to open database <%s> by driver <%s>"
 msgstr "%s بالمشغل %s لم يمكن فتح قاعدة البيانات"
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1775,7 +1787,7 @@
 msgid "Unable to create table: '%s'"
 msgstr "[%s]لم يتم فتح ملف الخلية ل "
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1785,8 +1797,8 @@
 msgstr "<%s> لم يمكن فتح"
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2076,7 +2088,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, fuzzy, c-format
@@ -2161,10 +2173,10 @@
 msgid "Output world file"
 msgstr "اسم ملف الإنحدار المخرج"
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, c-format
 msgid "[%s]: No such color"
 msgstr ""
@@ -2184,12 +2196,12 @@
 msgid "Writing world file"
 msgstr "كتابة ملف جديد...\n"
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 #, fuzzy
 msgid "Got null file name"
 msgstr "اسم ااملف المخرج"
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr ""
@@ -2357,7 +2369,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2482,8 +2494,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 #, fuzzy
 msgid "Required"
 msgstr "خروج"
@@ -2504,7 +2516,7 @@
 msgid "Metadata"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 msgid "Name for new location to create"
 msgstr "اسم المقع الجديد"
@@ -2513,7 +2525,7 @@
 msgstr "تغلب على الإسقاط مستخدما إسقاط الموقع"
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 msgid "Extend location extents based on new dataset"
 msgstr "مد حدود الموقع معتمدا على مجموعة البيانات الجديدة"
@@ -2554,7 +2566,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2597,13 +2609,13 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, fuzzy, c-format
 msgid "Location <%s> created"
 msgstr "%s لم يمكن فتح "
@@ -2615,13 +2627,13 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 #, fuzzy
 msgid "Over-riding projection check"
 msgstr "طباعة نوع الملف الراسترى فقط"
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 #, fuzzy
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
@@ -2638,7 +2650,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 #, fuzzy
 msgid "Import dataset PROJ_INFO is:\n"
@@ -2657,7 +2669,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 #, fuzzy
 msgid "Projection of input dataset and current location appear to match"
 msgstr "إعادة توقيع خريطة راسترية من مكان إلى المكان الحالى"
@@ -2787,30 +2799,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr ""
@@ -3001,12 +3010,14 @@
 msgstr "المخرج هو خطأ الإستيفاء"
 #: ../raster/r.resamp.bspline/main.c:92
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:100
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -3050,7 +3061,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -3058,7 +3069,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -3087,7 +3098,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3105,7 +3116,7 @@
 msgstr "اسم الخريطة الراسترية الناتجة"
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3117,7 +3128,7 @@
 msgid "No data within this subregion. Consider increasing the spline step."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 #, fuzzy
 msgid "Writing output..."
@@ -3330,7 +3341,7 @@
 msgstr ""
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 #, fuzzy
 msgid "metadata"
 msgstr "عدم انشاء جدول الخواص"
@@ -3400,7 +3411,7 @@
 msgid "Raster map <%s> not found in current mapset"
 msgstr "لم توجد<%s>الخريطة الفيكتورية"
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3411,37 +3422,33 @@
 msgid "Unable to open input file <%s>"
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-msgid "Not enough room in history file"
-msgstr ""
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "%s لم يمكن فتح ملف المدى ل"
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, c-format
 msgid "cats table for [%s] set to %s"
 msgstr ""
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr ""
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, fuzzy, c-format
 msgid "Writing new null file for [%s]... "
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr ""
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 #, fuzzy
 msgid "Done."
 msgstr "انتهى\n"
@@ -4430,12 +4437,10 @@
 msgstr "اسم الخريطة الراسترية المخرجة"
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 msgid "Format for reporting the slope"
 msgstr "طريقة تقرير الإنحدار"
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 msgid "Type of output aspect and slope maps"
 msgstr "نوع خرائط الإنحدار واتجاهه"
@@ -4479,17 +4484,14 @@
 msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه السينى ااصادى"
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr "عامل المضاعفة لتحويل وحدات الارتفاعات الي امتار"
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr " القيمة الصغري للانحدار (نسبية) المحسوب اتجاه الانحدار لها"
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 msgid "Do not align the current region to the elevation layer"
 msgstr "لاتضبط المنطقة الحالية على ابعاد خريطة الارتفاعات"
@@ -4532,58 +4534,56 @@
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, fuzzy, c-format
 msgid "Aspect raster map <%s> complete"
 msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, fuzzy, c-format
 msgid "Slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, fuzzy, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr "اسم ملف انحناء التضاريس"
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, fuzzy, c-format
 msgid "Tangential curve raster map <%s> complete"
 msgstr "%s:لم يتم إنشاء الجدول"
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, fuzzy, c-format
 msgid "E-W slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, fuzzy, c-format
 msgid "N-S slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, fuzzy, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr "غير موجودة <%s> الخريطة الراسترية "
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, fuzzy, c-format
 msgid "Dyy raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, fuzzy, c-format
 msgid "Dxy raster map <%s> complete"
@@ -4677,7 +4677,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -4872,7 +4872,6 @@
 msgstr "اسم الخريطة المخرجة"
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr ""
@@ -5368,66 +5367,66 @@
 msgid "Filter <%s> not found"
 msgstr "غير موجود <%s> الراستر"
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 #, fuzzy
 msgid "resample"
 msgstr "الخريطة الراسترية المطلوب تسجيلها"
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr "انشاء خريطة راسترية موضحة الأحواض التحتية لمحددات المياه"
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 msgid "Filter radius (horizontal)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr "انتشار القيم المنعدمة"
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, c-format
 msgid "Too many filters (max: %d)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "طبقتين يجب تحديدهم"
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, fuzzy, c-format
 msgid "Unable to read color table for %s"
@@ -5999,7 +5998,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr ""
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, fuzzy, c-format
 msgid "Unknown method <%s>"
 msgstr "%c :نوع غير معروف"
@@ -6019,7 +6018,7 @@
 msgid "Aggregate operation"
 msgstr "عملية التجميع"
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
@@ -7884,6 +7883,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr ""
@@ -8247,59 +8247,59 @@
 msgid "Pass %d..."
 msgstr ""
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "binary MAT-File تحويل راستر جراسى الى ملف بينرى من نوع"
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 #, fuzzy
 msgid "Name for new TIFF file"
 msgstr "اسم الخريطة الراسترية الجديدة"
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 #, fuzzy
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr "(مخرج راسي (بدلا من الافقي"
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 #, fuzzy
 msgid "Output TIFF world file"
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 #, fuzzy
 msgid "Output Tiled TIFF"
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
 "to integer"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, fuzzy, c-format
 msgid "Unable to open TIFF file <%s>"
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 #, fuzzy
 msgid "Writing TIFF World file"
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 #, fuzzy
 msgid "Unable to open TIFF world file for writing"
@@ -8412,7 +8412,7 @@
 msgstr "التوقيع ..."
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -8420,21 +8420,21 @@
 "[%s]"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
@@ -8444,16 +8444,16 @@
 msgid "Writing to map ..."
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, fuzzy, c-format
 msgid "%lu points found in region."
 msgstr "%d نقاط تم تحميلها\n"
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 msgid "Scanning data ..."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr ""
@@ -8986,70 +8986,70 @@
 msgid "unable to open <%s> mask ... continuing without!"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 #, fuzzy
 msgid "Cannot create random access file"
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr "لم يتم انشاء الدليل"
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 #, fuzzy
 msgid "Cannot read setup file"
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 msgid "Irregular maskedoverlay areas definition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 #, fuzzy
 msgid "Illegal configuration file (sample area)"
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 msgid "Too many units to place"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 #, fuzzy
 msgid "Too many strats for raster map"
 msgstr "خريطة الراستر الاساس"
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 #, fuzzy
 msgid "Cannot make lseek"
@@ -9377,8 +9377,8 @@
 #: ../raster/r.out.gdal/export_band.c:201
 #, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:241
@@ -9557,7 +9557,7 @@
 msgid "Name of color file"
 msgstr "اسم ملف المرشح"
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 #, fuzzy
 msgid "Vertical exaggeration"
 msgstr "عامل المقياس الرأسى"
@@ -9616,16 +9616,20 @@
 msgid "File containing expression(s) to evaluate"
 msgstr "dig_att عطل فى فتح ملف المدخل"
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:145
+msgid "file= and expression= are mutually exclusive"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:155
 #, fuzzy
 msgid "parse error"
 msgstr "الملف الراسترى المدخل"
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr ""
@@ -9932,8 +9936,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 msgid "Position"
 msgstr ""
@@ -10531,8 +10535,8 @@
 msgstr "أستخدام القيم الراسترية كفئات بدلا من توالى فريد,خلية فقط"
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 #, fuzzy
 msgid "Attributes"
@@ -10578,7 +10582,7 @@
 msgstr "%s:لم يتم الحشر بالجدول"
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "لم يمكن حشر صف جديد: %s"
@@ -10985,19 +10989,19 @@
 "or 'latin' option!"
 msgstr ""
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -11013,7 +11017,7 @@
 msgid "Error in pj_do_proj"
 msgstr ""
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr "بدء بالقيم فى الخريطة الراسترية"
@@ -11401,7 +11405,7 @@
 msgid "Raster map(s) to report on"
 msgstr "الخريطة الراسترية المطلوب التقرير معتمدا عليها"
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr ""
@@ -11440,7 +11444,6 @@
 msgstr "اسم ملف التقرير"
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 msgid "Quiet"
 msgstr "خروج"
@@ -11935,13 +11938,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr ""
@@ -12152,17 +12148,17 @@
 msgid "Writing topographic index map..."
 msgstr "خريطة الدليل الطبوغرافى"
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 #, fuzzy
 msgid "Resamples raster map layers to a coarser grid using aggregation."
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 #, fuzzy
 msgid "Aggregation method"
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 msgid "Weight according to area (slower)"
 msgstr ""
@@ -12580,13 +12576,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -12623,15 +12619,66 @@
 msgid "Access for others"
 msgstr ""
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr ""
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 #, fuzzy
 msgid "Unable to determine mapset permissions"
 msgstr "اسم الخريطة الراسترية الموجودة"
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "اسم الخريطة الراسترية الموجودة"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+#, fuzzy
+msgid "read "
+msgstr "المساحة\n"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 msgid "Error reading WKT projection description"
 msgstr ""
@@ -13278,47 +13325,47 @@
 msgid "Error conducting transform (%d)"
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr ""
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr ""
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 #, fuzzy
 msgid "Parameter error"
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 #, fuzzy
 msgid "No active control points"
 msgstr "اسم الطبقة المستخدمة كدرجة لون"
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
 msgstr "%s:منطقة غير صالحة"
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 #, fuzzy
 msgid "transformation"
 msgstr "عدد نقاط الإستيفاء"
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 msgid "Computes a coordinate transformation based on the control points."
 msgstr ""
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 msgid "Rectification polynomial order"
 msgstr ""
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -13326,35 +13373,35 @@
 "difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 #, fuzzy
 msgid "Output format"
 msgstr "الخريطة المخرجة"
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 msgid "Display summary information"
 msgstr ""
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr "الملف  الأسكى الراسترى المطلوب ادخاله"
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 #, fuzzy
 msgid "Local x,y coordinates to target east,north"
 msgstr "طباعة احداثيات الشبكة - الشرق والشمال"
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr ""
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 #, fuzzy
 msgid "Target east,north coordinates to local x,y"
 msgstr "استخدام احداثيات مركز الخريطة\n"
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 msgid "Display transform matrix coefficients"
 msgstr ""
@@ -13368,91 +13415,95 @@
 msgid "Change current mapset."
 msgstr "ضبط من المنطقة الحالية"
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
 msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "خريطة مخرجة حيث ستكتب النقاط"
+#: ../general/g.mapset/main.c:63
+msgid "Location name (not location path)"
 msgstr ""
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr ""
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 #, fuzzy
 msgid "Create mapset if it doesn't exist"
 msgstr "dig_att لم يمكن العثور على ملف"
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
 #, fuzzy
+msgid "Create"
+msgstr "مضاهاة"
+#: ../general/g.mapset/main.c:86
+#, fuzzy
 msgid "List available mapsets"
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 #, fuzzy
 msgid "Either mapset= or -l must be used"
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, fuzzy, c-format
 msgid "<%s> is already the current mapset"
 msgstr "<%s>فى<%s>لم يمكن فتح الملف الفيكتورى"
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 msgid "You don't have permission to use this mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr ""
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 #, fuzzy
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr "لم يمكن وصف الجدول"
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
 "checked"
 msgstr ""
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 #, fuzzy
 msgid "Cleaning up temporary files..."
 msgstr "لم يتم تحديث الحدود"
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 msgid "Your shell continues to use the history for the old mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
 msgstr ""
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
 msgstr ""
-#: ../general/g.mapsets/dsply_path.c:19
-#, fuzzy, c-format
-msgid "Your mapset search list:\n"
-msgstr "طباعة إحداثيات الإتصال الحلى و الخروج"
-#: ../general/g.mapsets/dsply_path.c:29
-#, fuzzy, c-format
-msgid "<%s> not found in mapset list"
-msgstr "غير موجودة <%s> المنطقة"
 #: ../general/g.mapsets/main.c:62
 msgid ""
 "Modifies the user's current mapset search path, affecting the user's access "
@@ -13507,15 +13558,15 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr ""
-#: ../general/g.mapsets/dsply_maps.c:23
-#, fuzzy, c-format
+#: ../general/g.mapsets/list.c:10
+#, fuzzy
 msgid "Available mapsets:"
-#: ../general/g.mapsets/dsply_maps.c:33
-#, c-format
-msgid "** no mapsets **\n"
-msgstr ""
+#: ../general/g.mapsets/list.c:35
+#, fuzzy
+msgid "Accessible mapsets:"
+msgstr "عرض الهيئات المدعمة والخروج"
 #: ../general/g.copy/main.c:43
 msgid ""
@@ -14061,40 +14112,40 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "%s لم يتم فتح قاعدة البيانات"
@@ -14117,13 +14168,12 @@
 msgstr ""
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-#, fuzzy
-msgid "Name of workspace file"
-msgstr "اسم ملف المرشح"
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
 #: ../general/g.gui/main.c:57
 msgid "Update default GUI setting"
@@ -14138,6 +14188,11 @@
 msgid "<%s> is now the default GUI"
 msgstr ""
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 msgid "Force remove"
 msgstr ""
@@ -14177,7 +14232,7 @@
 msgid "Unable to read FP range for %s"
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -14192,7 +14247,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -14221,7 +14276,7 @@
 msgid "At least two points are required"
 msgstr "الإحداثيات للإستفهام"
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -14234,7 +14289,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -14242,47 +14297,47 @@
 msgid "No graphics device selected"
 msgstr "لم يتم اختيار شاشة العرض"
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
 msgstr "اختيار الخط الذى سيعرض به النص على الشاشة"
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 #, fuzzy
 msgid "Choose new current font"
 msgstr "استخدام المنطقة الحالية"
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 #, fuzzy
 msgid "Path to Freetype-compatible font including file name"
 msgstr "استخدام خط ذو نوع حقيقى بما في ذلك اسم الملف "
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr "تكويد الحروف"
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 #, fuzzy
 msgid "List fonts"
 msgstr "عرض قائمة مستويات الكنتور"
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 #, fuzzy
 msgid "List fonts verbosely"
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, fuzzy, c-format
 msgid "Unable to access font path %s: %s"
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, c-format
 msgid "Font path %s is not a file"
 msgstr ""
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -14750,6 +14805,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 msgid "Name of raster map"
 msgstr "اسم الخريطة الراسترية"
@@ -14926,8 +14982,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -15162,33 +15218,33 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 #, fuzzy
 msgid "Selection"
 msgstr "الصفر قيمة حقيقية"
@@ -15232,15 +15288,15 @@
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, fuzzy, c-format
 msgid "Database connection not defined"
 msgstr "لم يتم الإتصال بقاعدة البيانات\n"
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -16001,43 +16057,47 @@
 msgid "Error: %s\n"
 msgstr "%s:خطا \n"
-#: ../display/d.rast/main.c:55
+#: ../display/d.rast/main.c:54
 #, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr "اختيار الخط الذى سيعرض به النص على الشاشة"
+msgid "Displays raster map layer."
+msgstr "تقرير الإحصائيات للخرائط الراسترية"
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 #, fuzzy
 msgid "Raster map to be displayed"
-#: ../display/d.rast/main.c:67
-msgid "List of categories to be displayed (INT maps)"
-msgstr ""
+#: ../display/d.rast/main.c:66
+#, fuzzy
+msgid "List of categories or values to be displayed"
+msgstr "اسم الخريطة الراسترية  للعرض كخلفية"
-#: ../display/d.rast/main.c:76
-msgid "List of values to be displayed (FP maps)"
+#: ../display/d.rast/main.c:72
+msgid "Background color (for null)"
 msgstr ""
-#: ../display/d.rast/main.c:85
-msgid "Background color (for null)"
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+msgid "Either a standard color name or R:G:B triplet"
 msgstr ""
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
-msgstr ""
+#: ../display/d.rast/main.c:81
+#, fuzzy
+msgid "Invert value list"
+msgstr "عرض القيم مفصولة بفاصلة"
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "طبقتين يجب تحديدهم"
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr ""
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
+msgstr "اسم ااملف المخرج"
 #: ../display/d.rast.num/main.c:73
 #, fuzzy
@@ -16377,10 +16437,6 @@
 msgid "Label color"
 msgstr "لون    قيمة\n"
-#: ../display/d.vect/main.c:263
-msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr ""
@@ -16636,7 +16692,7 @@
 msgstr "نوع العمود غير مدعم"
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -16658,7 +16714,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
@@ -16676,7 +16732,7 @@
 msgstr "cat = %d لا يوجد تسجيل للخط"
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -16689,7 +16745,7 @@
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -16717,7 +16773,7 @@
 msgstr "اسم قاعدة البيانات"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -16789,7 +16845,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -17042,7 +17098,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, fuzzy, c-format
@@ -17175,10 +17231,8 @@
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 #, fuzzy
 msgid "Query"
 msgstr "بهدوء"
@@ -17555,306 +17609,311 @@
 msgid "Unable to build topology for <%s>"
 msgstr "%s لم يتم العثور على الخريطة الراسترية"
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "ادخال ملف راسترى ثنائى كطبقة خريطة راسترية جراسية"
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 #, fuzzy
 msgid "OGR datasource name"
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: directory containing shapefiles\n"
 "\t\tMapInfo File: directory containing mapinfo files"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: shapefile name\n"
 "\t\tMapInfo File: mapinfo file name"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 #, fuzzy
 msgid "Import subregion only"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 msgid "Subregion"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 #, fuzzy
 msgid "Optionally change default input type"
 msgstr "اسم خريطة الراستر المخرجة"
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
 "boundary;import lines as area boundaries;centroid;import points as centroids"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 msgid "Snapping threshold for boundaries"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 #, fuzzy
 msgid "List available layers in data source and exit"
 msgstr "عرض ملفات الراستر للموقع والخروج"
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 msgid "Do not clean polygons (not recommended)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 #, fuzzy
 msgid "Create 3D output"
 msgstr "مخرج متبادل البيتات"
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 #, fuzzy
 msgid "Do not create attribute table"
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 #, fuzzy
 msgid "Override dataset projection (use location's projection)"
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 #, fuzzy
 msgid "Limit import to the current region"
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, fuzzy, c-format
 msgid "Unable to open data source <%s>"
 msgstr "<%s> لم يمكن فتح"
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists"
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, fuzzy, c-format
 msgid "Layer <%s> not available"
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 msgid "4 parameters required for 'spatial' parameter"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 #, fuzzy
 msgid "GRASS LOCATION PROJ_INFO is:\n"
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, c-format
 msgid ""
 "\n"
 "You can use the -o flag to %s to override this projection check.\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
 "set.\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "خطا فى محاولة قراءة ملف قاعدة البيانات dbmscap\n"
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, c-format
 msgid "Layer: %s"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
 "be truncated!"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, fuzzy, c-format
 msgid "Column type not supported (%s)"
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "%s بالمشغل %s لم يمكن فتح قاعدة البيانات"
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
 #, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "dig قراءة ملف...\n"
+#: ../vector/v.in.ogr/main.c:854
+#, fuzzy, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr "المسافة العظمى بين النقاط بوحدات الخريطة"
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 msgid "Break polygons:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 #, fuzzy
 msgid "Remove duplicates:"
 msgstr "لم يتم حساب شبه مركز المساحة"
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 #, fuzzy
 msgid "Merge boundaries:"
 msgstr "وصل الفئات...\n"
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, c-format
 msgid "Find centroids for layer: %s"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 #, fuzzy
 msgid "Write centroids:"
 msgstr "كتابة رؤوس قمم الخطوط"
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -17862,92 +17921,87 @@
 "The number of features for those areas is stored as category in layer %d"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, c-format
 msgid "%d input polygons\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, c-format
 msgid "%d input polygons"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
 msgstr "%-5d تم تخطى فئات النقط الميت\n"
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
 "import 3D vector"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "%s:لم يتم إنشاء الجدول"
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 #, fuzzy
 msgid "Cannot calculate centroid"
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 #, fuzzy
 msgid "Cannot write part of geometry"
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 #, fuzzy
 msgid "Unknown geometry type"
 msgstr "نوع غير معروف"
@@ -18130,6 +18184,9 @@
 msgstr "اسم قاعدة بيانات المدخل"
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 #, fuzzy
 msgid "Connection"
 msgstr "مضاهاة"
@@ -18165,12 +18222,12 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, fuzzy, c-format
 msgid "Missing column <%s> in table <%s>"
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 #, fuzzy
 msgid "Data type of key column must be integer"
@@ -18388,8 +18445,8 @@
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 #, fuzzy
 msgid "From"
 msgstr "نوع المظهر"
@@ -18410,8 +18467,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 msgid "To"
 msgstr ""
@@ -18437,13 +18494,13 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr "%s لم يتم منح الإمتياز على الجدول"
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
 msgstr ""
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 #, fuzzy
 msgid "Name of existing vector map (from)"
 msgstr ""
@@ -18452,17 +18509,17 @@
 "#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
 "اسم الملف الراسترى الموجود"
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 #, fuzzy
 msgid "Feature type (from)"
 msgstr "نوع المظهر"
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 #, fuzzy
 msgid "Name of existing vector map (to)"
 msgstr ""
@@ -18471,36 +18528,36 @@
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 #, fuzzy
 msgid "Feature type (to)"
 msgstr "نوع المظهر"
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 #, fuzzy
 msgid "Name for output vector map containing lines connecting nearest elements"
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 #, fuzzy
 msgid "Maximum distance or -1 for no limit"
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 #, fuzzy
 msgid "Minimum distance or -1 for no limit"
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr ""
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
 "to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
@@ -18512,141 +18569,146 @@
 "attribute of nearest feature given by to_column option"
 msgstr ""
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr ""
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 #, fuzzy
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr "اسم الخريطة المدخلة"
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr ""
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr ""
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
 msgstr ""
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr ""
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 msgid "Too many column names"
 msgstr ""
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 msgid "Not enough column names"
 msgstr ""
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, fuzzy, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr "%d نقطة كتبت للمخرج\n"
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 #, fuzzy
 msgid "Unable to open default database"
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 #, fuzzy
 msgid "Incompatible column types"
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 #, fuzzy
 msgid "Finding nearest areas..."
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr ""
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, fuzzy, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr "%d فئات محملة من الفيكتور\n"
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, fuzzy, c-format
 msgid "%d categories - no nearest feature found"
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr ""
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, fuzzy, c-format
 msgid "%d records inserted"
 msgstr "%d حدثت من التسجيلات\n"
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, fuzzy, c-format
 msgid "%d insert errors"
 msgstr "%d تحديث الخطا\n"
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, fuzzy, c-format
 msgid "%d categories read from the map"
 msgstr "%d فئات محملة من الجدول\n"
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, fuzzy, c-format
 msgid "%d categories exist in the table"
 msgstr "%d فئات من الفيكتور مفقودة من الجدول\n"
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, fuzzy, c-format
 msgid "%d categories read from the map exist in the table"
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, fuzzy, c-format
 msgid "%d categories read from the map don't exist in the table"
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, fuzzy, c-format
 msgid "%d records updated"
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, fuzzy, c-format
 msgid "%d update errors"
@@ -19018,7 +19080,7 @@
 msgstr "[%s]لم يتم فتح ملف الخلية ل "
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -19038,7 +19100,7 @@
 msgstr "غير موجود <%s> الراستر"
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> at the topological level"
@@ -19072,13 +19134,12 @@
 msgid "Outlier detection"
 msgstr " nv لون\n"
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 #, fuzzy
@@ -20615,51 +20676,58 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:273
-#, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:279
+#: ../vector/v.surf.bspline/main.c:274
 #, fuzzy, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
 "a raster output or other driver."
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+#: ../vector/v.surf.bspline/main.c:332
 msgid "Cannot read field info"
 msgstr "لم بمكن قراءة معلومات الحقل"
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, fuzzy, c-format
 msgid "[%d] records selected from table"
 msgstr "%d التسجيلات اختيرت من الجدول"
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, fuzzy, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 #, fuzzy
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, fuzzy, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
+#: ../vector/v.surf.bspline/main.c:712
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -23063,8 +23131,9 @@
 msgstr "عدم انشاء جدول الخواص"
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
-msgstr ""
+#, fuzzy
+msgid "Area without centroid (OK for island)"
+msgstr "%-5d تم تخطى فئات النقط الميت\n"
 #: ../vector/v.to.rast/do_areas.c:126
 #, fuzzy
@@ -24176,11 +24245,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr ""
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr "اخراج المعلومات الأساسية لخرائط راسترية يحددها المستخدم"
@@ -24198,7 +24267,7 @@
 msgid "Print topology information only"
 msgstr "طباعة نوع الملف الراسترى فقط"
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, fuzzy, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
@@ -24786,31 +24855,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, fuzzy, c-format
 msgid "Performing map %s + %s"
 msgstr "خريطة الإرتفاعات"
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr ""
@@ -24969,79 +25038,79 @@
 #: ../vector/v.db.connect/main.c:89
 #, fuzzy
-msgid "Print all map connection parameters and exit in shell script style"
+msgid "Print all map connection parameters in shell script style and exit"
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 #, fuzzy
 msgid "Overwrite connection parameter for certain layer"
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 msgid "Delete connection for certain layer (not the table)"
 msgstr ""
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 msgid "Please choose only one print style"
 msgstr ""
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 #, fuzzy
 msgid "Unable to modify vector map stored in other mapset"
-#: ../vector/v.db.connect/main.c:165
+#: ../vector/v.db.connect/main.c:164
 #, fuzzy, c-format
-msgid "Vector map <%s> is connected by:"
+msgid "Vector map <%s> is connected by:\n"
 msgstr "لم توجد<%s>الخريطة الفيكتورية"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr ""
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr ""
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
 "overwritten by GRASS modules"
 msgstr ""
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, c-format
 msgid "Cannot grant privileges on table %s"
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr ""
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -25443,40 +25512,40 @@
 msgid "Name of Arc cost column"
 msgstr "عدد الأعمدة"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr ""
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 msgid "measurement"
 msgstr ""
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 #, fuzzy
 msgid "Default: location map units"
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
 msgstr "طباعة الأحصاء فى صورة شل سكربت"
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 #, fuzzy
 msgid "Length:"
 msgstr "%f : الطول\n"
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 #, fuzzy
 msgid "Area:"
 msgstr "المساحة\n"
@@ -25530,7 +25599,7 @@
 msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 #, fuzzy
 msgid "visualization"
@@ -25609,296 +25678,346 @@
 msgid "Loading data failed"
 msgstr "التوقيع ..."
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 #, fuzzy
 msgid "Unsupported output format"
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, fuzzy, c-format
 msgid "File <%s> created."
 msgstr "%s لم يمكن فتح "
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
 msgstr "تباين المجموع"
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 #, fuzzy
 msgid "Image"
 msgstr "ملف المدخل"
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 #, fuzzy
 msgid "Graphics file format"
 msgstr "ملف المدخل"
-#: ../visualization/nviz2/cmd/args.c:96
-msgid "Width and height of output image"
+#: ../visualization/nviz2/cmd/args.c:104
+msgid "Size (width, height) of output image"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 #, fuzzy
 msgid "Name of raster map(s) for elevation"
 msgstr "اسم الملف الراسترى الموجود"
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 #, fuzzy
 msgid "Elevation value(s)"
 msgstr "انحياز الإرتفاعات"
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 #, fuzzy
 msgid "Name of raster map(s) for color"
 msgstr "اسم الخريطة الراسترية الناتجة"
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 msgid "Color value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 #, fuzzy
 msgid "Name of raster map(s) for mask"
 msgstr "اسم ملف القناع"
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 #, fuzzy
 msgid "Name of raster map(s) for transparency"
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 #, fuzzy
 msgid "Name of raster map(s) for shininess"
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 #, fuzzy
 msgid "Name of raster map(s) for emission"
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 msgid "Emission value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 msgid "Draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 #, fuzzy
 msgid "Fine resolution"
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 #, fuzzy
 msgid "Coarse resolution"
 msgstr "مضاهاة"
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 #, fuzzy
 msgid "Draw style"
 msgstr "نوع المظهر"
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 #, fuzzy
 msgid "Wire color"
 msgstr " nv لون\n"
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 #, fuzzy
 msgid "Name of line vector overlay map(s)"
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 #, fuzzy
 msgid "Vector lines"
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 #, fuzzy
 msgid "Vector line width"
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 #, fuzzy
 msgid "Vector line color"
 msgstr " nv لون\n"
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 msgid "Vector line display mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 #, fuzzy
 msgid "Name of point vector overlay map(s)"
 msgstr "اسم الخريطة الراسترية المدخلة"
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 #, fuzzy
 msgid "Vector points"
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 msgid "Icon size"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 msgid "Icon width"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 #, fuzzy
 msgid "Icon color"
 msgstr " nv لون\n"
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 msgid "Icon marker"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 #, fuzzy
 msgid "Viewpoint position (x,y model coordinates)"
 msgstr "الإحداثى الشمالى للخريطة\n"
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 #, fuzzy
 msgid "Viewpoint height (in map units)"
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 #, fuzzy
 msgid "Viewpoint twist angle (in degrees)"
 msgstr "Anisotropy زاوية تباين الخواص فى صورة درجات"
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 msgid "Volumes"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 msgid "Volume position"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 #, fuzzy
 msgid "Volume resolution"
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 #, fuzzy
 msgid "Isosurface level"
 msgstr "مستوى الكنتور الأصغر"
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+#, fuzzy
+msgid "Light position (x,y,z model coordinates)"
+msgstr "الإحداثى الشمالى للخريطة\n"
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+#, fuzzy
+msgid "Lighting"
+msgstr "كتابة ملف جديد...\n"
+#: ../visualization/nviz2/cmd/args.c:584
+#, fuzzy
+msgid "Light color"
+msgstr " nv لون\n"
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+msgstr "كتابة رؤوس قمم الخطوط"
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+#, fuzzy
+msgid "Fringe"
+msgstr "اسم الجدول"
+#: ../visualization/nviz2/cmd/args.c:625
+#, fuzzy
+msgid "Fringe color"
+msgstr " nv لون\n"
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "الصفر قيمة حقيقية"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr ""
@@ -26046,130 +26165,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, fuzzy, c-format
-msgid "Failed in attempt to open %s"
-msgstr "اسم الملف الفيكتورى المخرج"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr "تعيين خواص تضاريسية كالإنحدار واتجاهة والإنحناءات بانواعها"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr "اسم ملف الإرتفاعات الراستري"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-#, fuzzy
-msgid "Output slope filename"
-msgstr "اسم ملف الإنحدار المخرج"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-#, fuzzy
-msgid "Output aspect filename"
-msgstr "اسم خريطة اتجاه الإنحدار"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-#, fuzzy
-msgid "Output profile curvature filename"
-msgstr "اسم ملف انحناء التضاريس"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-#, fuzzy
-msgid "Output tangential curvature filename"
-msgstr "اسم ملف الإنحناء المماسى"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr ""
-"(اسم ملف المشتق الجزئى من الرتبة الاولى في الاتجاه السينى (انحدار شرق-غرب "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr ""
-"(اسم ملف المشتق الجزئى من الرتبة الاولى في الاتجاه الصادى (انحدار شمال-جنوب"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-msgid "Output second order partial derivative dxx filename"
-msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه السينى"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-msgid "Output second order partial derivative dyy filename"
-msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه ااصادى "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-msgid "Output second order partial derivative dxy filename"
-msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه السينى ااصادى"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, fuzzy, c-format
-msgid "wrong type: %s"
-msgstr "%c :نوع غير معروف"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-#, fuzzy
-msgid "Creating support files..."
-msgstr "%s لم يمكن فتح ملف المدى ل"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, fuzzy, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr "<%s> لم يمكن فتح"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr ""
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 #, fuzzy
@@ -26447,35 +26442,46 @@
 msgstr "من فضلك اضبط الأوضاع"
 #: ../db/db.connect/main.c:49
-msgid "Prints/sets general DB connection for current mapset and exits."
+msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 #, fuzzy
 msgid "Print current connection parameters and exit"
 msgstr "طباعة إحداثيات الإتصال الحلى و الخروج"
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 #, fuzzy
 msgid "Check connection parameters, set if uninitialized, and exit"
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 msgid "Set"
 msgstr ""
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
 #, fuzzy
+msgid "Set from default settings and exit"
+msgstr "ضبط من المنطقة االاساس"
+#: ../db/db.connect/main.c:65
+#, fuzzy
+msgid "Overwrite current settings if initialized"
+#: ../db/db.connect/main.c:87
+#, fuzzy
 msgid "Default group of database users to which select privilege is granted"
 msgstr "المجموعة الأساس لمستخدمى قاعدة البيانات الممنوحة حق  إختيار الإمتياز"
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 #, fuzzy
 msgid "Database connection not defined. Run db.connect."
 msgstr "db.connect إتصل مستخدما<%s>لم يتم تعريف مشغل الإتصال بقاعدة البيانات"
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -26483,11 +26489,11 @@
 "database: %s"
 msgstr ""
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr ""
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 #, fuzzy
 msgid "Default database is not set"
@@ -26745,7 +26751,7 @@
 msgid "'-' to read from standard input"
 msgstr "الملف  الأسكى الراسترى المطلوب ادخاله"
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 #, fuzzy
 msgid "Ignore SQL errors and continue"
 msgstr "اهمال اخطاء اس.كيو.ال والاستمرار"
@@ -26811,17 +26817,17 @@
 msgid "succeeded"
 msgstr ""
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr ""
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr ""
-#: ../db/db.select/main.c:215
+#: ../db/db.select/main.c:201
 #, fuzzy
-msgid "Name of file with sql statement"
+msgid "Name of file with SQL select statement(s)"
 msgstr "اسم الملف بتعبير اس.كيو.ال"
 #: ../db/db.select/main.c:247
@@ -27038,7 +27044,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:6
@@ -27146,48 +27152,66 @@
 msgstr "إدخال خريطة راسترية بينرية "
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
 #, fuzzy
+msgid "Files & format"
+msgstr "الخريطة المخرجة"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
 msgid "Output coordinate file (omit to send to stdout)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 #, fuzzy
 msgid "Field separator (format: input[,output])"
 msgstr "الفاصل الحقلي للمخرج"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
 #, fuzzy
+msgid "Projections"
+msgstr "التوقيع ..."
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#, fuzzy
 msgid "Output projection parameters (PROJ.4 style)"
 msgstr "خريطة الإتجاه المخرجة"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
 msgstr "اسم الملف المخرج"
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "لاتشمل اسماء الأعمدة في المخرج"
@@ -27447,6 +27471,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr "طباعة الجداول والخروج"
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 msgid "Prints a graph of the correlation between data layers (in pairs)."
 msgstr ""
@@ -27745,13 +27773,6 @@
 msgid "Raster map to use as mask"
 msgstr "الخرائط الراسترية المطلوب قرائتها"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Create"
-msgstr "مضاهاة"
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
 msgstr ""
@@ -27957,6 +27978,7 @@
 msgstr "عرض الهيئات المدعمة والخروج"
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -27970,7 +27992,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
@@ -28303,19 +28325,22 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
 #, fuzzy
-msgid "Vector map for which to edit attribute table"
+msgid "Name of vector map for which to edit attribute table"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
 #, fuzzy
-msgid "Layer where to add column"
+msgid "Layer number where to add column(s)"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -28461,7 +28486,7 @@
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -28870,19 +28895,24 @@
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 #, fuzzy
+msgid "Print stats in shell script style"
+msgstr "طباعة الأحصاء فى صورة شل سكربت"
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#, fuzzy
 msgid "Name of data table"
 msgstr "اسم الخريطة الراسترية الجديدة"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 #, fuzzy
 msgid "Database/directory for table"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 #, fuzzy
 msgid "Database driver"
 msgstr ":اسم قاعدة البيانات"
@@ -28949,6 +28979,11 @@
 msgid "Signature file <%s> is invalid"
 msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
+#: ../imagery/i.smap/read_sig.c:30
+#, fuzzy, c-format
+msgid "Signature file <%s> is empty"
+msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 #, fuzzy
 msgid "Name of file containing signatures"
@@ -29522,19 +29557,19 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr ""
-#: ../imagery/i.rectify/main.c:202
+#: ../imagery/i.rectify/main.c:204
 #, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr ""
-#: ../imagery/i.rectify/main.c:216
+#: ../imagery/i.rectify/main.c:218
 #, fuzzy, c-format
 msgid ""
 "Input raster map <%s> does not exist in group <%s>.\n"
 " Try:\n"
 msgstr "الخريطة الراسترية المطلوب الضبط عليها"
-#: ../imagery/i.rectify/main.c:222
+#: ../imagery/i.rectify/main.c:224
 msgid "Exit!"
 msgstr ""
@@ -29626,7 +29661,7 @@
 msgid "Error while writing to temp file"
-#: ../imagery/i.rectify/write.c:54
+#: ../imagery/i.rectify/write.c:55
 #, fuzzy, c-format
 msgid "Error writing row %d"
 msgstr "تغلب على الخريطة المخرجة"
@@ -29636,12 +29671,12 @@
 msgid "Rectified input raster map <%s> will be saved as <%s>"
 msgstr "<%s>فى<%s>لم يمكن فتح الملف الفيكتورى"
-#: ../imagery/i.rectify/rectify.c:91
+#: ../imagery/i.rectify/rectify.c:90
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-#: ../imagery/i.rectify/rectify.c:97
+#: ../imagery/i.rectify/rectify.c:96
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
@@ -30147,7 +30182,7 @@
 msgid "Name of input raster map (image fft, imaginary part"
-#: ../imagery/i.ifft/main.c:119
+#: ../imagery/i.ifft/main.c:115
 msgid "The real and imaginary original windows did not match"
 msgstr ""
@@ -31219,6 +31254,81 @@
 msgstr ""
 #, fuzzy
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "طباعة إحداثيات الإتصال الحلى و الخروج"
+#, fuzzy
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "غير موجودة <%s> المنطقة"
+#, fuzzy
+#~ msgid "Name of workspace file"
+#~ msgstr "اسم ملف المرشح"
+#, fuzzy
+#~ msgid "Displays raster map layer in the active map display window."
+#~ msgstr "اختيار الخط الذى سيعرض به النص على الشاشة"
+#, fuzzy
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "اسم الملف الفيكتورى المخرج"
+#~ msgid ""
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr "تعيين خواص تضاريسية كالإنحدار واتجاهة والإنحناءات بانواعها"
+#~ msgid "Raster elevation file name"
+#~ msgstr "اسم ملف الإرتفاعات الراستري"
+#, fuzzy
+#~ msgid "Output slope filename"
+#~ msgstr "اسم ملف الإنحدار المخرج"
+#, fuzzy
+#~ msgid "Output aspect filename"
+#~ msgstr "اسم خريطة اتجاه الإنحدار"
+#, fuzzy
+#~ msgid "Output profile curvature filename"
+#~ msgstr "اسم ملف انحناء التضاريس"
+#, fuzzy
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "اسم ملف الإنحناء المماسى"
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr ""
+#~ "(اسم ملف المشتق الجزئى من الرتبة الاولى في الاتجاه السينى (انحدار شرق-غرب "
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#~ msgstr ""
+#~ "(اسم ملف المشتق الجزئى من الرتبة الاولى في الاتجاه الصادى (انحدار شمال-"
+#~ "جنوب"
+#~ msgid "Output second order partial derivative dxx filename"
+#~ msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه السينى"
+#~ msgid "Output second order partial derivative dyy filename"
+#~ msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه ااصادى "
+#~ msgid "Output second order partial derivative dxy filename"
+#~ msgstr "اسم ملف المشتق الجزئى من الرتبة الثانية في الاتجاه السينى ااصادى"
+#, fuzzy
+#~ msgid "wrong type: %s"
+#~ msgstr "%c :نوع غير معروف"
+#, fuzzy
+#~ msgid "Creating support files..."
+#~ msgstr "%s لم يمكن فتح ملف المدى ل"
+#, fuzzy
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "<%s> لم يمكن فتح"
+#, fuzzy
 #~ msgid "Input elevation map"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_cs.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_cs\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2010-03-07 15:38+0100\n"
 "Last-Translator: \n"
 "Language-Team:  <cs at li.org>\n"
@@ -23,7 +23,7 @@
 "X-Generator: KBabel 1.11.4\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 msgid "Error closing 3d raster map"
@@ -65,7 +65,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "rastr"
@@ -85,7 +85,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -177,7 +177,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -192,39 +191,39 @@
 msgid "Error opening grid3 file [%s]"
 msgstr "Chyba pøi otevírání souboru grid3 [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 msgid "Cannot allocate memory for string"
 msgstr "Nelze alokovat pro øetìzec pamì»"
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, c-format
 msgid "Error reading range for [%s]"
 msgstr "Chyba pøi ètení rozsahu pro [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 msgid "Error while reading history file"
 msgstr "Chyba pøi ètení souboru s historií"
@@ -259,7 +258,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -288,7 +287,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "Chyba pøi zavírání 3d rastru"
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 msgid "Error closing ascii file"
 msgstr "Chyba pøi zavírání souboru ASCII"
@@ -1121,7 +1120,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1136,7 +1135,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1169,17 +1168,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1234,7 +1232,7 @@
 msgstr "GeoTIFF mo¾nosti vytvoøení"
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 msgid "List supported formats and exit"
 msgstr "Vypi¹ podporované formáty a ukonèi se"
@@ -1247,22 +1245,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1310,7 +1308,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 msgid "Name of input raster map"
@@ -1603,12 +1600,27 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr "Minimální poèet øádkù, který má být uchován v pamìti je 1"
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
+#, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "Neplatná souøadnice x <%s>"
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr "Neplatná severní souøadnice <%s>"
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr "Neplatná východní souøadnice <%s>"
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "Prùchod #%d (z %d) ..."
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 msgid "Writing raster map..."
 msgstr "Zapisuji rastrovou mapu..."
@@ -1627,12 +1639,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1662,7 +1674,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1672,7 +1684,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1741,13 +1753,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1763,7 +1775,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1773,8 +1785,8 @@
 msgid "Unable to open database <%s> by driver <%s>"
 msgstr "Nelze otevøít databázi <%s> ovladaèem <%s>"
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1785,7 +1797,7 @@
 msgid "Unable to create table: '%s'"
 msgstr "Nelze vytvoøit tabulku : '%s'"
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1795,8 +1807,8 @@
 msgstr "Nelze vytvoøit index pro tabulku <%s>, klíè <%s>"
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2084,7 +2096,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, c-format
@@ -2170,10 +2182,10 @@
 msgid "Output world file"
 msgstr "Vytvoø TIFF world file (tfw)"
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, c-format
 msgid "[%s]: No such color"
 msgstr "[%s]: ®ádná taková barva"
@@ -2193,11 +2205,11 @@
 msgid "Writing world file"
 msgstr "Zapisuji tfw ... "
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 msgid "Got null file name"
 msgstr "Dostal jsem prázdné jméno rastru"
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr "Mám strukturu prázdného regionu"
@@ -2370,7 +2382,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2495,8 +2507,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 msgid "Required"
 msgstr "Po¾adováno"
@@ -2517,7 +2529,7 @@
 msgid "Metadata"
 msgstr "Metadata"
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 msgid "Name for new location to create"
 msgstr "Název nové location, která má být vytvoøena"
@@ -2526,7 +2538,7 @@
 msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 msgid "Extend location extents based on new dataset"
 msgstr "Hranice location se zvìt¹í podle nového datasetu"
@@ -2568,7 +2580,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2616,7 +2628,7 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
@@ -2624,7 +2636,7 @@
 "Nelze pøevést vstupní mapovou projekci do formátu GRASSu; nelze vytvoøit "
 "novou location."
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, c-format
 msgid "Location <%s> created"
 msgstr "Location <%s> vytvoøena"
@@ -2638,12 +2650,12 @@
 "kontrolu)"
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 msgid "Over-riding projection check"
 msgstr "Pøeskakuji kontrolu projekce."
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -2660,7 +2672,7 @@
 msgstr "PROJ_INFO datasetu je:\n"
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "iMPORT PROJ_INFO datasetu je:\n"
@@ -2682,7 +2694,7 @@
 "datasetu.\n"
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 msgid "Projection of input dataset and current location appear to match"
 msgstr "Mapová projekce vstupního datasetu a aktuální location souhlasí."
@@ -2808,30 +2820,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr "Nastavení"
@@ -3027,13 +3036,15 @@
 #: ../raster/r.resamp.bspline/main.c:92
 #, fuzzy
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr "Hodnota kroku spline ve v-z smìru"
 #: ../raster/r.resamp.bspline/main.c:100
 #, fuzzy
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr "Hodnota kroku spline ve s-j severním smìru"
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -3078,7 +3089,7 @@
 msgstr "Hodnota kroku spline interpolace v východním smìru"
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -3086,7 +3097,7 @@
 msgstr "Upravené V-Z køivky %d"
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -3116,7 +3127,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3134,7 +3145,7 @@
 msgstr "Nelze vytvoøit vektorovou mapu <%s>"
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3147,7 +3158,7 @@
 msgid "No data within this subregion. Consider increasing the spline step."
 msgstr "Subregion neosahuje ¾ádná data. zva¾e zmìnu kroku køivosti"
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 msgid "Writing output..."
 msgstr "Zapisuji výstupní vrstvu..."
@@ -3353,7 +3364,7 @@
 msgstr ""
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 #, fuzzy
 msgid "metadata"
 msgstr "Metadata"
@@ -3421,7 +3432,7 @@
 msgid "Raster map <%s> not found in current mapset"
 msgstr "Rastrová mapa <%s> nebyla v aktuálním mapsetu nalezena"
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3432,37 +3443,33 @@
 msgid "Unable to open input file <%s>"
 msgstr "Nelze otevøít vstupní soubor <%s>"
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-msgid "Not enough room in history file"
-msgstr "Pro soubor s historií není dost místa"
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "Nelze èíst soubor s kategoriemi rastrové mapy <%s@%s>"
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, c-format
 msgid "cats table for [%s] set to %s"
 msgstr "Tabulka kategorií pro <%s> nastavena na %s"
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr "[%s] je reklasifikací jiné mapy. Ukonèuji se."
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, c-format
 msgid "Writing new null file for [%s]... "
 msgstr "Zapisuji nový soubor \"null\" pro [%s]... "
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr "Odstraòuji soubor \"null\" pro [%s]...\n"
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 msgid "Done."
 msgstr "Dokonáno jest."
@@ -4473,12 +4480,10 @@
 msgstr "Název výstupní rastrové mapy orientace"
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 msgid "Format for reporting the slope"
 msgstr "Formát sklonu svahu"
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 msgid "Type of output aspect and slope maps"
 msgstr "Typ výstupních map expozice a sklonu svahu"
@@ -4517,19 +4522,16 @@
 msgstr "Název výstupní rastrové mapy parciálních derivací druhého øádu dxy"
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr "Koeficient pro pøevod jednotek vý¹ky na metry"
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr ""
 "Minimální hodnota sklonu svahu (v procentech), pro kterou je poèítána "
 "expozice"
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 msgid "Do not align the current region to the elevation layer"
 msgstr "Nenastavuj aktuální region podle mapy vý¹ek "
@@ -4573,58 +4575,56 @@
 msgstr "Vý¹kové produkty pro mapset <%s> v <%s>"
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr "Min vypoètená expozice %.4f, max vypoètená expozice %.4f"
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, c-format
 msgid "Aspect raster map <%s> complete"
 msgstr "Rastrová mapa orientace <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr "Min vypoètený sklon svahu %.4f, max vypoètený sklon svahu %.4f"
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, c-format
 msgid "Slope raster map <%s> complete"
 msgstr "Rastrová mapa sklonu <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr "Rastrová mapa profilových køivostí <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, c-format
 msgid "Tangential curve raster map <%s> complete"
 msgstr "Rastrová mapa tangenciálních køivostí <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, c-format
 msgid "E-W slope raster map <%s> complete"
 msgstr "Rastrová mapa V-Z sklonu <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, c-format
 msgid "N-S slope raster map <%s> complete"
 msgstr "Rasztrová mapa S-J sklonu <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr "Rastrová mapa druhé derivace Dxx <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, c-format
 msgid "Dyy raster map <%s> complete"
 msgstr "Rastrová mapa druhé derivace Dyy <%s> je hotova"
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, c-format
 msgid "Dxy raster map <%s> complete"
 msgstr "Rastrová mapa druhé derivace Dxy <%s> je hotova"
@@ -4706,7 +4706,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -4886,7 +4886,6 @@
 msgstr "Název výstupní vrstvy"
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr "Hotovo procent:"
@@ -5383,68 +5382,68 @@
 msgid "Filter <%s> not found"
 msgstr "Soubor <%s> nebyl nalezen"
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 #, fuzzy
 msgid "resample"
 msgstr "rastr, pøevzorkování"
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr "Pøevzorkovat rastrovou vrstvu s vyu¾itím agregace."
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 #, fuzzy
 msgid "Filter radius (horizontal)"
 msgstr "Rozdìleno horizontálnì, ne vertikálnì."
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr "Vytváøej hodnoty NULL"
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 #, fuzzy
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr "weight= a -c se navzájem vyluèují"
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, fuzzy, c-format
 msgid "Too many filters (max: %d)"
 msgstr "<%s> obsahuje pøíli¹ mnoho pøíznakù (limit je 255)"
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "Musí být zadána alespoò jedna volba z %s"
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, c-format
 msgid "Unable to read color table for %s"
 msgstr "Nelze èíst barevnou tabulku pro %s"
@@ -6028,7 +6027,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr "%s: %s - neplatná specifikace vzdálenosti"
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, c-format
 msgid "Unknown method <%s>"
 msgstr "Neznámá metoda <%s>."
@@ -6050,7 +6049,7 @@
 msgid "Aggregate operation"
 msgstr "Agregace"
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
@@ -8015,6 +8014,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr ""
 "Percentil, který se má spoèítat (vy¾aduje pøepínaè roz¹íøení statistiky)"
@@ -8364,32 +8364,32 @@
 msgid "Pass %d..."
 msgstr "Prùchod %d..."
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "Exportuje rastrový soubor GRASSu do binárního souboru MAT."
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 msgid "Name for new TIFF file"
 msgstr "Jméno nového rastrového TIFF souboru."
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr "Komprese TIFFu"
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr "Paleta výstupního TIFFu (8bit místo 24bit)."
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 msgid "Output TIFF world file"
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 msgid "Output Tiled TIFF"
 msgstr "Vytvoø dla¾dicový TIFF"
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, fuzzy, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
@@ -8398,22 +8398,22 @@
 "Mapa <%s> v mapsetu <%s> obsahuje hodnoty s plovoucí desetinnou èárkou. Tyto "
 "hodnoty budou zaokrouhleny na celé èíslo!"
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
 msgstr "Barevná mapa palety musí mít ménì ne¾ 256 barev pro tento rozsah dat."
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, c-format
 msgid "Unable to open TIFF file <%s>"
 msgstr "Nelze otevøít soubor TIFF <%s>"
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 msgid "Writing TIFF World file"
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 msgid "Unable to open TIFF world file for writing"
 msgstr "Nelze otevøít soubor tfw pro zápis"
@@ -8524,7 +8524,7 @@
 msgstr "Ètu data... "
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -8535,21 +8535,21 @@
 "Nalezeny tyto znaky v øádku %lu:\n"
 "[%s]"
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr "LInie vynechány dle po¾adavku"
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr "©patná souøadnice y linie %lu sloupec %d <%s>"
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr "©patná souøadnice x linie %lu sloupec %d <%s>"
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr "©patná souøadnice z linie %lu sloupec %d <%s>"
@@ -8558,16 +8558,16 @@
 msgid "Writing to map ..."
 msgstr "Zapisuji do vrstvy ..."
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, c-format
 msgid "%lu points found in region."
 msgstr "%lu bodù nalezeno v regionu."
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 msgid "Scanning data ..."
 msgstr "Prohledávání dat ..."
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr "Rozsah:     min         max\n"
@@ -9098,67 +9098,67 @@
 "DCEØINÝ PROCES[pid = %i]: nelze otevøít soubor s maskou %s ... pokraèuji bez "
 "ní!"
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 msgid "Cannot create random access file"
 msgstr "Nelze vytvoøit soubor náhodného pøístupu"
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr "Nelze vytvoøit adresáø %s/r.li/"
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
 msgstr "Nelze vytvoøit adresáø %s/r.li/output/"
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
 msgstr "Nelze vytvoøit statistiku pro konfiguraèní soubor %s"
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 msgid "Cannot read setup file"
 msgstr "Nelze èíst soubor s nastavením"
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 msgid "Irregular maskedoverlay areas definition"
 msgstr "Nepravidelná definice pøekryvných maskovacích ploch"
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
 "Konfiguraèní soubor mù¾e být pou¾it pouze s \t\t\t%s rastrovým souborem"
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 msgid "Illegal configuration file (sample area)"
 msgstr "Neplatný konfiguraèní soubor (vzorková plocha)"
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 msgid "Too many units to place"
 msgstr "Pøíli¹ mnoho jednotek k umístìní"
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 msgid "Too many strats for raster map"
 msgstr "Pøíli¹ mnoho strats pro rastrovou mapu"
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr "Nesprávné dispozice ploch"
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 msgid "Cannot make lseek"
 msgstr "Nelze provést lseek"
@@ -9484,8 +9484,8 @@
 #: ../raster/r.out.gdal/export_band.c:201
 #, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:241
@@ -9661,7 +9661,7 @@
 msgid "Name of color file"
 msgstr "Jméno souboru s barvou"
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 msgid "Vertical exaggeration"
 msgstr "Vertikální mìøítko"
@@ -9717,16 +9717,21 @@
 msgid "File containing expression(s) to evaluate"
 msgstr "Soubor obsahující pravidla reklasifikace"
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:145
 #, fuzzy
+msgid "file= and expression= are mutually exclusive"
+msgstr "input= a source= se vzájemnì vyluèují"
+#: ../raster/r.mapcalc/main.c:155
+#, fuzzy
 msgid "parse error"
 msgstr "Chyba prametru"
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr "Chyba ve výpoètu èísel s plovoucí desetinnou èárkou"
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr "Pøeteèení je zapoèítáno ve výpoètu"
@@ -10033,8 +10038,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 msgid "Position"
 msgstr "Umístìní"
@@ -10631,8 +10636,8 @@
 "Pou¾ij rastrové hodnoty jako kategorie místo jedineèné sekvence (pouze CELL)"
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 msgid "Attributes"
 msgstr "Atributy"
@@ -10683,7 +10688,7 @@
 msgstr "Nelze vlo¾it do tabulky: %s"
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "Nelze vlo¾it nový øádek: %s"
@@ -11107,19 +11112,19 @@
 "Nelze získat informaci o mapové projekci aktuální location: prosím, nastavte "
 "¹íøkupomocí volby 'lat' nebo 'latin'!"
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr "JÉMINÁNKU: øádky se zmìnily z %d na %d"
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr "JÉMINÁNKU: sloupce se zmìnily z %d na %d"
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -11135,7 +11140,7 @@
 msgid "Error in pj_do_proj"
 msgstr "Chyba v pj_do_proj"
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr "Výpoèet mapy %01d z %01d (úhel %lf, rastrová mapa <%s>)"
@@ -11530,7 +11535,7 @@
 msgid "Raster map(s) to report on"
 msgstr "Rastrové mapy, pro které má být vytvoøena zpráva"
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr "Jednotky"
@@ -11567,7 +11572,6 @@
 msgstr "Název výstupního souboru, pro ulo¾ení zprávy"
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 msgid "Quiet"
 msgstr "Potichu"
@@ -12059,13 +12063,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr "Pokroèilé"
@@ -12285,15 +12282,15 @@
 msgid "Writing topographic index map..."
 msgstr "Zapisuji mapu topografického indexu..."
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 msgid "Resamples raster map layers to a coarser grid using aggregation."
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 msgid "Aggregation method"
 msgstr "Agregaèní metoda"
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 msgid "Weight according to area (slower)"
 msgstr "Váha podle plochy (pomalej¹í)"
@@ -12701,13 +12698,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -12743,14 +12740,65 @@
 msgid "Access for others"
 msgstr "Pøístup pro ostatní"
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr "Pøístup pro mapset PERMANENT musí být otevøený, nic nemìním."
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 msgid "Unable to determine mapset permissions"
 msgstr "Nelze zjistit práva k mapsetu"
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "Nelze zjistit práva k mapsetu"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+#, fuzzy
+msgid "read "
+msgstr "Plocha"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 msgid "Error reading WKT projection description"
 msgstr "Chyba pøi ètení popisu projekce ve formátu WKT"
@@ -13425,45 +13473,45 @@
 msgid "Error conducting transform (%d)"
 msgstr "Chyba pøi pøevodu"
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr "Mizernì umístìné kontrolní body"
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr "Nedostatek pamìti"
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 msgid "Parameter error"
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 msgid "No active control points"
 msgstr "®ádné aktivní kontrolní body"
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
 msgstr "Neplatné souøadnice %s %s"
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 #, fuzzy
 msgid "transformation"
 msgstr "vektor, transformace"
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 msgid "Computes a coordinate transformation based on the control points."
 msgstr "Souøadná transformace na základì vlícovacích bodù"
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 msgid "Rectification polynomial order"
 msgstr "Stupeò polynomu rektifikace"
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -13471,35 +13519,35 @@
 "difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 msgid "Output format"
 msgstr "Výstupní formát"
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 msgid "Display summary information"
 msgstr "Zobrazit souhrnnou informaci"
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr "Soubor obsahující pravidla pro ¹tíky kategorií (nebo \"-\" pro stdin)"
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 #, fuzzy
 msgid "Local x,y coordinates to target east,north"
 msgstr "Souøadnice støedu (východ, sever)"
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 #, fuzzy
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr "Zpìtná transformave, 3Dvektorové prvky na 2D"
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 #, fuzzy
 msgid "Target east,north coordinates to local x,y"
 msgstr "východní a severní souøadnice spodního levého rohu mapy"
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 #, fuzzy
 msgid "Display transform matrix coefficients"
 msgstr "Mapa koeficientu x"
@@ -13513,48 +13561,64 @@
 msgid "Change current mapset."
 msgstr "Zmìnit souèasný mapset"
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
-msgstr "Nové jméno MAPSETU"
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
+msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "Výstupní mapa, do které budou zapsány chyby"
+#: ../general/g.mapset/main.c:63
+#, fuzzy
+msgid "Location name (not location path)"
 msgstr "nové jméno LOCATION (ne cesta k location)"
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+#, fuzzy
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr "nová GISDBASE (celá cesta k adre¹áøi, kde je ulo¾ena nová location)"
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 msgid "Create mapset if it doesn't exist"
 msgstr "Vytvoøí nový mapset, pokud neexistuje."
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
+#, fuzzy
+msgid "Create"
+msgstr "Vytvoøení"
+#: ../general/g.mapset/main.c:86
 msgid "List available mapsets"
 msgstr "Vypi¹ v¹echny dostupné mapsety"
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 msgid "Either mapset= or -l must be used"
 msgstr "Buï  mapset= nebo -l musí být zadáno"
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, c-format
 msgid "<%s> is already the current mapset"
 msgstr "<%s> ji¾ existuje v souèasném mapsetu "
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 msgid "You don't have permission to use this mapset"
 msgstr "Nemáte povolení pou¾ívat tento mapset."
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr "Mapset neexistuje. Pøidejte pøepínaè -c pro vytvoøení nového mapsetu."
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr "Nelze èíst promìnnou prostøedí GIS_LOCK"
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
@@ -13563,15 +13627,15 @@
 "%s právì pou¾ívá GRASS s daným mapsetem nebo uzamykací soubor nelze "
 "zkontrolovat."
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 msgid "Cleaning up temporary files..."
 msgstr "Ma¾u doèasné soubory..."
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 msgid "Your shell continues to use the history for the old mapset"
 msgstr "Vá¹ shell pokraèuje v pou¾ívání historie pro starý mapset."
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
@@ -13580,7 +13644,7 @@
 "Mù¾ete zmìnit historii pøíkazy:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
@@ -13589,16 +13653,6 @@
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
-#: ../general/g.mapsets/dsply_path.c:19
-#, fuzzy, c-format
-msgid "Your mapset search list:\n"
-msgstr "Vypi¹ aktuální cestu k mapsetùm"
-#: ../general/g.mapsets/dsply_path.c:29
-#, fuzzy, c-format
-msgid "<%s> not found in mapset list"
-msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
 #: ../general/g.mapsets/main.c:62
 msgid ""
 "Modifies the user's current mapset search path, affecting the user's access "
@@ -13651,15 +13705,15 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr "Nelze otevøít SEARCH_PATH pro zápis"
-#: ../general/g.mapsets/dsply_maps.c:23
-#, fuzzy, c-format
+#: ../general/g.mapsets/list.c:10
+#, fuzzy
 msgid "Available mapsets:"
-#: ../general/g.mapsets/dsply_maps.c:33
-#, fuzzy, c-format
-msgid "** no mapsets **\n"
-msgstr "**¾ádné %s soubory nenalezeny **\n"
+#: ../general/g.mapsets/list.c:35
+#, fuzzy
+msgid "Accessible mapsets:"
+msgstr "Vypi¹ v¹echny dostupné mapsety"
 #: ../general/g.copy/main.c:43
 msgid ""
@@ -14189,40 +14243,40 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr "output= a method= musí mít stejný poèet hodnot"
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, fuzzy, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "Soubor '%s' ji¾ existuje a bude pøepsán."
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "Otevírám %s pro zápis..."
@@ -14245,12 +14299,12 @@
 msgstr "Výchozí hodnota: GRASS_GUI pokud není jinak definováno tcltk"
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-msgid "Name of workspace file"
-msgstr "Jméno souboru pracovního prostøedí"
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
 #: ../general/g.gui/main.c:57
 msgid "Update default GUI setting"
@@ -14266,6 +14320,11 @@
 msgid "<%s> is now the default GUI"
 msgstr "<%s> je nyní nastaveno jako základní grafické prostøedí"
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 msgid "Force remove"
 msgstr "Násilné vyjmutí"
@@ -14305,7 +14364,7 @@
 msgid "Unable to read FP range for %s"
 msgstr "Nemohu èíst rozsah pro <%s>"
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -14320,7 +14379,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -14348,7 +14407,7 @@
 msgid "At least two points are required"
 msgstr "Nedostatek bodù, je po¾adováno %d"
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -14361,7 +14420,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -14369,43 +14428,43 @@
 msgid "No graphics device selected"
 msgstr "®ádné grafické zaøízení nebylo vybráno"
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
 msgstr "Vybere písmo, kterým bude zobrazen text na u¾ivatelském monitoru."
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 msgid "Choose new current font"
 msgstr "Pou¾ijte nový aktuální font"
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 msgid "Path to Freetype-compatible font including file name"
 msgstr "Cesta k TrueType fontùm vèetnì jména souboru"
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr "Kódování znakù"
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 msgid "List fonts"
 msgstr "Seznam v¹ech fontù"
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 msgid "List fonts verbosely"
 msgstr "Seznam v¹ech fontù (upovídaný re¾im)"
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, c-format
 msgid "Unable to access font path %s: %s"
 msgstr "Nelze zjistit cestu k fontu %s: %s"
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, c-format
 msgid "Font path %s is not a file"
 msgstr "Cesta k fontu %s není soubor"
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -14866,6 +14925,7 @@
 "Zobrazí legendu pro rastrovou mapu v aktivním rámci grafického monitoru."
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 msgid "Name of raster map"
 msgstr "Název rastrové mapy"
@@ -15037,8 +15097,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -15277,33 +15337,33 @@
 msgstr "Èíslo vrstvy. Pokud -1, jsou zobrazeny v¹echny vrstvy."
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 msgid "Selection"
 msgstr "Výbìr"
@@ -15343,15 +15403,15 @@
 msgstr "'layer' musí být > 0"
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, c-format
 msgid "Database connection not defined"
 msgstr "Spojení s databází nebylo definováno"
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -16124,47 +16184,46 @@
 msgid "Error: %s\n"
 msgstr "Chyba: %s\n"
-#: ../display/d.rast/main.c:55
+#: ../display/d.rast/main.c:54
 #, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr "Zobrazí a pøekryje rastrovou mapu v aktivním rámu GRASS monitoru"
+msgid "Displays raster map layer."
+msgstr "Zji¹»uje barvy rastrové mapové vrstvy."
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 msgid "Raster map to be displayed"
 msgstr "Rastrová mapa, která má být zobrazena"
-#: ../display/d.rast/main.c:67
-msgid "List of categories to be displayed (INT maps)"
+#: ../display/d.rast/main.c:66
+#, fuzzy
+msgid "List of categories or values to be displayed"
 msgstr "Seznam kategorií, které budou zobrazeny (celoèíselné mapy)"
-#: ../display/d.rast/main.c:76
-msgid "List of values to be displayed (FP maps)"
-msgstr ""
-"Seznam hodnot, které mají být vykresleny (mapy s plovoucí desetinnou èárkou)"
-#: ../display/d.rast/main.c:85
+#: ../display/d.rast/main.c:72
 msgid "Background color (for null)"
 msgstr "Barva pozadí (pro hodnoty null)"
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+msgid "Either a standard color name or R:G:B triplet"
+msgstr "Buï standardní GRASS barva nebo trojice R:G:B"
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
+#: ../display/d.rast/main.c:81
+#, fuzzy
+msgid "Invert value list"
 msgstr "Obrácený seznam kategorií"
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
-"Ignoruji seznam kategorií: mapa obsahuje hodnoty s plovoucí desetinnou "
-"èárkou (prosím, pou¾ijte volbu 'val=')"
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "%s: neplatná hodnota pro spec"
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr ""
-"Ignoruji seznam hodnot: mapa obsahuje celoèíselné hodnoty (prosím, pou¾ijte "
-"volbu 'cat=')"
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
 #: ../display/d.rast.num/main.c:73
 msgid ""
@@ -16500,10 +16559,6 @@
 msgid "Label color"
 msgstr "Barva popiskù"
-#: ../display/d.vect/main.c:263
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "Buï standardní GRASS barva nebo trojice R:G:B"
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr "Barva pozadí popiskù"
@@ -16769,7 +16824,7 @@
 "Typ sloupce <%s> není podporován (musí být integer nebo double precision)"
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -16790,7 +16845,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
 msgstr "Nelze vytvoøit index"
@@ -16808,7 +16863,7 @@
 msgstr "Pro kategorii %d není ¾ádný záznam v tabulce <%s>"
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -16821,7 +16876,7 @@
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -16849,7 +16904,7 @@
 msgstr "databáze, SQL"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -16918,7 +16973,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -17172,7 +17227,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, c-format
@@ -17301,10 +17356,8 @@
 msgstr "Èíslo dotazované vrstvy (pro naètení)"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 msgid "Query"
 msgstr "Dotaz"
@@ -17679,16 +17732,16 @@
 msgid "Unable to build topology for <%s>"
 msgstr "Nelze nalézt koncový vektor <%s> "
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "Konvertuje vektorové vrstvy OGR na GRASS vektorové mapy."
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 msgid "OGR datasource name"
 msgstr "Jmono zdroje dat OGR"
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: directory containing shapefiles\n"
@@ -17698,12 +17751,12 @@
 "\t\tESRI ShapeFile: adresáø obsahující soubory ShapeFile\n"
 "\t\tSoubory MapInfo: adresáø obsahující soubory MapInfo"
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
 "Jméno OGR vrstvy, pokud není zadán, jsou pouze vyti¹tìny pøítomné vrstvy"
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: shapefile name\n"
@@ -17713,35 +17766,35 @@
 "\t\tESRI ShapeFile: název souboru ShapeFile\n"
 "\t\tSoubor MapInfo: název souboru MapInfo"
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 msgid "Import subregion only"
 msgstr "Importuj pouze subregion"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 msgid "Subregion"
 msgstr "Subegion"
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr "Formát: xmin,ymin,xmax,ymax - obvykle Z,J,V,S"
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr "Minimální importovaná plocha (plo¹né jednotky)"
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr "Min.plocha & snap"
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr "Men¹í plochy a ostrovy budou ignorovány. Mìla by být vìt¹í ne¾ snap^2"
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 msgid "Optionally change default input type"
 msgstr "Volitelnì zmìnit základní vstupní typ"
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
 "boundary;import lines as area boundaries;centroid;import points as centroids"
@@ -17750,15 +17803,15 @@
 "jako linie;boundary;Importovat linie jako hranice ploch;centroid;Importovat "
 "body jako centroidy"
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 msgid "Snapping threshold for boundaries"
 msgstr "Práh navázaní pro hranice"
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr "'-1' pro ¾ádný snap"
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
@@ -17766,80 +17819,80 @@
 "Seznam názvù sloupcù, které budou pou¾ity namísto originálních názvù, první "
 "je po¾it pro sloupce s kategoriemi"
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 msgid "List available layers in data source and exit"
 msgstr "Vypi¹ dostupné vrstvy z datového zdroje a ukonèi se"
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 msgid "Do not clean polygons (not recommended)"
 msgstr "Neproèistit polygony (nedoporuèuje se)"
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 msgid "Create 3D output"
 msgstr "Vytvoøit 3D výstup"
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 msgid "Do not create attribute table"
 msgstr "Nevytváøet atributovou tabulku"
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 msgid "Override dataset projection (use location's projection)"
 msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 msgid "Limit import to the current region"
 msgstr "Limit pøi importu do souèasného regionu"
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr "Zmìnit mázev sloupce na malé písmo"
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr "Pou¾itelné OGR ovladaèe:"
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, c-format
 msgid "Unable to open data source <%s>"
 msgstr "Nelze otevøítzdroj dat <%s>"
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr "Zdroj dat obsahuje %d vrstev:"
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Vektorová mapa '%s' ji¾ existuje a bude pøepsána."
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, c-format
 msgid "Vector map <%s> already exists"
 msgstr "Vektorová mapa <%s> ji¾ existuje"
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, c-format
 msgid "Layer <%s> not available"
 msgstr "Vrstva <%s> není dostupná"
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr "Vyberte souèasné nastavení regionu nebo prostorové volby, ne oboje"
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 msgid "4 parameters required for 'spatial' parameter"
 msgstr " 4 parametry vy¾adovány pro 'prostorový' parametr."
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
@@ -17847,11 +17900,11 @@
 "Nelze pøevést informace o vstupní mapové projekci do formátu GRASSu (pro "
 "kontrolu)"
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr "GRASS LOCATION PROJ_INFO  je:\n"
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, c-format
 msgid ""
 "\n"
@@ -17860,7 +17913,7 @@
 "\n"
 "Mù¾ete pou¾ít pøepínaè -o pro %s a pøeskoèit toto ovìøení.\n"
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
 "set.\n"
@@ -17868,27 +17921,27 @@
 "Zva¾te vytvoøení nové location s parametry 'location' ze vstupního "
 "datasetu.\n"
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "%s: Chyba pøi zapisování do doèasného souboru"
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, c-format
 msgid "Layer: %s"
 msgstr "Vrstva: %s"
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr "Název sloupce zmìnìn: '%s' -> '%s'"
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr "Zápis sloupce <%s> s pevnou délkou %d znakù (mù¾e být zkrácen)"
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
@@ -17897,98 +17950,103 @@
 "Délka pro sloupec '%s' nastavena na 255 (nebyla specifikována OGR), nìkteré "
 "øetìzce mohou být zkráceny!"
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, c-format
 msgid "Column type not supported (%s)"
 msgstr "Typ sloupce není podporován (%s)"
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "Nelze otevøít databázi <%s> ovladaèem <%s>"
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
 #, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "Importuji prvky mapy %d..."
+#: ../vector/v.in.ogr/main.c:854
+#, fuzzy, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr "Vzdálenost bufferu v mapových jednotkách"
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr "%d %s bez geometrie"
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr "Proèi¹tìní polygonù, výsledek není zaruèen!"
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr "rozdìlit hranice (mezní hodnota =%.3e)"
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 msgid "Break polygons:"
 msgstr "Zlom polygonù:"
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 msgid "Remove duplicates:"
 msgstr "Mazání duplicit:"
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr "Zlomit hranice:"
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr "Vyèistit hranice na uzlech:"
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 msgid "Change boundary dangles to lines:"
 msgstr "Mìním hranice pøívìskù  na linie:"
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change dangles to lines:"
 msgstr "Zmìnit pøívìsky na linie:"
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr "Mìním hranice mostù na linie:        "
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr "Mazání mostù:"
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 #, fuzzy
 msgid "Merge boundaries:"
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
 msgstr "Nelze spoèítat centroid oblasti"
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, fuzzy, c-format
 msgid "Find centroids for layer: %s"
 msgstr "©patná hodnota násobitele: %s"
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 #, fuzzy
 msgid "Write centroids:"
 msgstr "Zapisuji centroidy ..."
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -18000,47 +18058,47 @@
 "atributové tabulce. Èíslo prvkù pro tyto plochy jsou ulo¾eny jako kategorie "
 "ve vrstvì %d"
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, fuzzy, c-format
 msgid "%d input polygons\n"
 msgstr "%d vstupních polygonù"
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, c-format
 msgid "%d input polygons"
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
 msgstr "Celkem ploch: %e (%d ploch)"
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
 msgstr "Pøekrytí plochy: %e (%d ploch)"
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
 msgstr "PPlochy bez kategorie:%e (%d ploch)"
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
 "import 3D vector"
@@ -18048,44 +18106,39 @@
 "Vstupní data obsahují 3D prvky. Vytvoøená vektorová mapa je pouze 2D, pro "
 "import 3D vektorové mapy pou¾ijte pøepínaè -z."
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "Nelze zapsat èást geometrie "
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr "Pøeskakuji prvky bez geometrie"
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr "Rozklad polygonu ([%d] lomových bodù)"
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr "Velikost plochy [%.1e] plocha nebude importována"
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr "Rozklad ostrova ([%d] lomových bodù)"
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr "Velikost ostrova [%.1e] ostrov nebude importován"
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 msgid "Cannot calculate centroid"
 msgstr "Nelze spoèítat centroid plochy"
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr "Není vlo¾en ¾ádný centroid pro polygon s ¾ádným záchytným bodem"
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 msgid "Cannot write part of geometry"
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 msgid "Unknown geometry type"
 msgstr "Neznámý typ geometrie"
@@ -18275,6 +18328,9 @@
 msgstr "Jméno vstupní tabulky"
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 msgid "Connection"
 msgstr "Spojení"
@@ -18306,12 +18362,12 @@
 "Výstupní vektorová tabulka <%s> (ovladaè: <%s>, databáze: <%s>) ji¾ existuje"
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, c-format
 msgid "Missing column <%s> in table <%s>"
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 msgid "Data type of key column must be integer"
 msgstr "Sloupec s klíèem musí být typu integer"
@@ -18526,8 +18582,8 @@
 msgstr "Èíslo vrstvy (from)"
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 msgid "From"
 msgstr "From (z_mapy)"
@@ -18548,8 +18604,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 msgid "To"
 msgstr "To (do_mapy)"
@@ -18576,7 +18632,7 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr "Nelze poskytnou práva na tabulku <%s>"
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
@@ -18584,50 +18640,50 @@
 "najít nejbli¾¹í prvek ve vektorové vrstvì 'do_mapy' pro prvky ve vektorové "
 "vrstvì 'z_mapy'"
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 msgid "Name of existing vector map (from)"
 msgstr "Jméno existující vektorové mapy (from)"
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 msgid "Feature type (from)"
 msgstr "Typ prvku (from)"
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 msgid "Name of existing vector map (to)"
 msgstr "Jméno existující vektorové mapy (to)"
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
 msgstr "Èíslo vrstvy (to)"
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 msgid "Feature type (to)"
 msgstr "Typ prvku (to)"
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
 "Nová vektorová mapa obsahující linie spojující linie s nejbli¾¹ímy prvky"
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 msgid "Maximum distance or -1 for no limit"
 msgstr "Maximální vzdálenost nebo -1 bez limitu"
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 msgid "Minimum distance or -1 for no limit"
 msgstr "Minimální vzdálenost nebo -1 bez limitu"
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr "Hodnoty popisující vztahy mezi dvìma nejbli¾¹ími prvky"
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
 "to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
@@ -18646,39 +18702,39 @@
 "radiánech, co¾ je mezi -Pí a Pí vèetnì;to_attr;attribute nejbli¾¹ího prvku "
 "daný volbou to_column"
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 "Jméno(a) sloupcù, kde hodnoty specifikované volbou 'upload' budou ulo¾eny"
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr "z_mapy"
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr "Jméno sloupce nejbli¾¹ího prvku (k pou¾ití spolu s upload=to_attr)"
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr ""
 "Název tabulky vytvoøené pro výstup, pokud je udán pøepínaè -a (vzdálenost ke "
 "v¹em prvkùm)"
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr "Vytiskni na standardní výstup, nemìò atributovou tabulku."
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr "První sloupec je v¾dy kategorie prvku 'from' zavolaná from_cat"
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr "vypoèítá vzdálenost ke v¹em prvùm v mezní vzdálenosti"
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
@@ -18687,102 +18743,107 @@
 "atributové tabulky vytvoøené tímto modulem. Kategorie 'from' mohou být "
 "víceèetné."
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr "volba to_column chybí"
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 msgid "Too many column names"
 msgstr "Pøíli¹ mnoho názvù sloupcù"
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 msgid "Not enough column names"
 msgstr "Nedostatek názvù sloupcù"
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, fuzzy, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr "%d z %d prvkù vybráno pro vektorovou mapu <%s>"
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, c-format
 msgid "Column <%s> not found in table <%s>"
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 msgid "Unable to open default database"
 msgstr "Nelze otevøít výchozí databázi"
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 msgid "Incompatible column types"
 msgstr "Nekompatibilní typy sloupcù"
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
 msgstr "Hledám nejbli¾¹í plochy ... "
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 msgid "Finding nearest areas..."
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr "Nalezeno více kategorií ve do_vrstvy (plocha=%d)"
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr "DATETIME type zatím není podporovaný, ¾ádné atributy nebudou ulo¾eny"
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr "%d kategorií s více ne¾ jedním prvkem ve vektorové mapì <%s>"
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, c-format
 msgid "%d categories - no nearest feature found"
 msgstr "%d kategorií - nebyl nalezen nejbli¾¹í prvek"
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr "%d vzdáleností spoèítáno"
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, c-format
 msgid "%d records inserted"
 msgstr "vlo¾eno %d záznamù"
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, c-format
 msgid "%d insert errors"
 msgstr "%d chyb pøi aktualizaci"
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, c-format
 msgid "%d categories read from the map"
 msgstr "naèteno %d kategorií z mapové vrstvy"
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, c-format
 msgid "%d categories exist in the table"
 msgstr "v tabulce existuje %d kategorií "
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, c-format
 msgid "%d categories read from the map exist in the table"
 msgstr "%d kategorií naètených z mapové vrstvy existuje v tabulce"
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, c-format
 msgid "%d categories read from the map don't exist in the table"
 msgstr "%d kategorií naètených z mapové vrstvy neexistuje v tabulce"
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, c-format
 msgid "%d records updated"
 msgstr "%d záznamù aktualizováno"
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, c-format
 msgid "%d update errors"
@@ -19154,7 +19215,7 @@
 msgstr "Nelze èíst jméno ovladaèe"
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -19174,7 +19235,7 @@
 msgstr "Nemohla být odstranìna pomocná tabulka"
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr "Vektorová mapa <%s> nemohla být otevøena na úrovní topologie"
@@ -19205,13 +19266,12 @@
 msgid "Outlier detection"
 msgstr "Zji¹tìní bodù mimo region"
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr "Subregion neosahuje ¾ádná data. zva¾e zmìnu kroku køivosti"
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 msgid "Auxiliar table could not be dropped"
@@ -20747,21 +20807,12 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr "Køí¾ová validace skonèila pro sie = %f a pro sin = %f"
-#: ../vector/v.surf.bspline/main.c:273
+#: ../vector/v.surf.bspline/main.c:274
 #, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-"®ádná vektorová mapa pro interpolaci. Interpolace bude aplikována na "
-"vektorové mapì <%s>"
-#: ../vector/v.surf.bspline/main.c:279
-#, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr "vektorová mapa <%s> bude interpolována"
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
@@ -20770,32 +20821,47 @@
 "Promiòte, ovladaè <%s> není pro vektorový výstup tohoto modul povolen. "
 "Vyzkou¹ejte rastrový výstup nebo jiný ovladaè."
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr "vektorová mapa <%s> bude interpolována"
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+#: ../vector/v.surf.bspline/main.c:332
 msgid "Cannot read field info"
 msgstr "Nelze èíst informace o vrstvì"
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, c-format
 msgid "[%d] records selected from table"
 msgstr "[%d] záznamù bylo vybráno z tabulky"
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr "Interpolation: Vytváøím tabulku: Nebylo mo¾no vytvoøit tabulku <%s>."
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
 msgstr ""
 "Nelze alokovat pamì« pro podpùrnou matici. Zva¾uji zmìnu rozli¹ení regionu "
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr "Interpolation: (%d,%d): Pro bod (cat = %d) ¾ádný záznam nenalezen"
+#: ../vector/v.surf.bspline/main.c:712
+#, fuzzy
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr "Subregion neosahuje ¾ádná data. zva¾e zmìnu kroku køivosti"
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -23198,7 +23264,8 @@
 msgstr "Selhalo získávání plochy %d"
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
+#, fuzzy
+msgid "Area without centroid (OK for island)"
 msgstr "Plochy bez centroidù (mù¾e být v poøádku pro ostrovy)"
 #: ../vector/v.to.rast/do_areas.c:126
@@ -24352,11 +24419,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr "Vrstva musí být > 0 pro 'where'"
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr "Vypí¹e základní informace o u¾ivatelem vybrané vektorové mapì."
@@ -24374,7 +24441,7 @@
 msgid "Print topology information only"
 msgstr "Vytiskni pouze informace o topologii"
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
 msgstr "Spojení s databází pro mapu <%s>nebylo definováno v DB souboru"
@@ -24970,31 +25037,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr "Chybné argumenty pro anyfunc %s (argc = %d)"
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr "Vykonávám funkci s 1 argumentem na mapì %s"
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr "Vykonávám funkci s 2 argumenty na mapách %s a %s"
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, c-format
 msgid "Performing map %s + %s"
 msgstr "Vykonávání mapa %s + %s"
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr "Nelze volat ¹patnou mapovou funkci"
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr "©patné argumenty mapové funkce %s (argc = %d)"
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr "Není definována ¾ádná funkce pro vykonání mapa %c mapa"
@@ -25150,63 +25217,64 @@
 msgstr "Vypi¹ parametry souèasného pøipojení a ukonèi se"
 #: ../vector/v.db.connect/main.c:89
-msgid "Print all map connection parameters and exit in shell script style"
+#, fuzzy
+msgid "Print all map connection parameters in shell script style and exit"
 msgstr "Vypi¹ parametry souèasného pøipojení ve stylu shellu a ukonèi se."
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr "Formát: vrstva[/jméno vrstvy] tabulka klíè databáze ovladaè"
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr "Vypi¹ typy/názvy sloupcù tabulky pro specifikovanou vrstvu a ukonèi se"
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 msgid "Overwrite connection parameter for certain layer"
 msgstr "Pøepi¹ parametry pøipojení pro danou vrstvu"
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 msgid "Delete connection for certain layer (not the table)"
 msgstr "Vyma¾ pøipojení pro danou vrstvu (nikoliv tabulku)"
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 msgid "Please choose only one print style"
 msgstr "Prosím, vyberte pouze jeden zpùsob výstupu"
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 msgid "Unable to modify vector map stored in other mapset"
 msgstr "Nelze editovat vektorovou vrstvu ulo¾enou v jiném mapsetu."
-#: ../vector/v.db.connect/main.c:165
-#, c-format
-msgid "Vector map <%s> is connected by:"
+#: ../vector/v.db.connect/main.c:164
+#, fuzzy, c-format
+msgid "Vector map <%s> is connected by:\n"
 msgstr "Vektorová mapa <%s> je spojena:"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, fuzzy, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 "vrstva <%d> tabulka<%s> v databázi <%s> pøes ovladaè <%s> s klíèem <%s>\n"
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr "Pou¾ijte -o k pøepsání existujícího spojení pro vrstvu <%d>"
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr "Tabulka <%s> v databázi <%s> neexistuje"
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
@@ -25215,16 +25283,16 @@
 "Tabulka <%s> je nyní souèástí vektorové mapy <%s> a mù¾e být smazána "
 "nebopøepsána nìkterým z modulù GRASSu"
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, c-format
 msgid "Cannot grant privileges on table %s"
 msgstr "Nelze poskytnou práva na tabulku %s"
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr "Vyberete práva pro tuto tabulku"
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -25623,41 +25691,41 @@
 msgid "Name of Arc cost column"
 msgstr "Jméno sloupce"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr "rùzné"
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 #, fuzzy
 msgid "measurement"
 msgstr "Umístìní"
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
 msgstr "Jedna nebo více souøadnic"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 #, fuzzy
 msgid "Default: location map units"
 msgstr "Chyba pøi pøevodu na diskrétní hodnoty v jednotkách mapy"
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
 msgstr "Vypi¹ ve stylu pro shell skript."
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 #, fuzzy
 msgid "Length:"
 msgstr "Délka: %f\n"
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 #, fuzzy
 msgid "Area:"
 msgstr "Plocha\n"
@@ -25709,7 +25777,7 @@
 msgstr "Vstupní chyba parzování na øádku %d"
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 #, fuzzy
 msgid "visualization"
 msgstr "Vyrovnání histogramu"
@@ -25781,279 +25849,330 @@
 msgid "Loading data failed"
 msgstr "Naèítání dat selhalo"
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 msgid "Unsupported output format"
 msgstr "Nepodporovaný výstupní formát"
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, c-format
 msgid "File <%s> created."
 msgstr "Soubor <%s> byl vytvoøen"
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr "Po¾ít vykreslovací mód pro v¹echny naètené povrchy"
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
 msgstr "Povrch"
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
 msgstr "Jménovýstupního souboru (NEpøidávejte koncovku)"
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 msgid "Image"
 msgstr "Obrázek"
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 msgid "Graphics file format"
 msgstr "Výstupní formát "
-#: ../visualization/nviz2/cmd/args.c:96
-msgid "Width and height of output image"
+#: ../visualization/nviz2/cmd/args.c:104
+#, fuzzy
+msgid "Size (width, height) of output image"
 msgstr "©íøka a vý¹ka výstupního obrazu"
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 msgid "Name of raster map(s) for elevation"
 msgstr "Jméno rastrové mapy s vý¹kami"
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 msgid "Elevation value(s)"
 msgstr "Hodnoty vý¹ek"
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 msgid "Name of raster map(s) for color"
 msgstr "Jméno rastrové mapy pro barvy"
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 msgid "Color value(s)"
 msgstr "Barevné hodnoty"
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 msgid "Name of raster map(s) for mask"
 msgstr "Jméno rastrové mapy pro maskování"
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 msgid "Name of raster map(s) for transparency"
 msgstr "Jméno rastrové mapy pro prùhlednost"
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr "Prùhlednost"
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 msgid "Name of raster map(s) for shininess"
 msgstr "Jméno rastrové mapy pro osvìtlení"
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr "Hodnoty osvìtlení"
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 #, fuzzy
 msgid "Name of raster map(s) for emission"
 msgstr "Jméno rastrové mapy pro vý¹ku"
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 #, fuzzy
 msgid "Emission value(s)"
 msgstr "Eigen hodnoty:"
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 msgid "Draw mode"
 msgstr "Mód vykreslení"
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr "Kreslit"
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 #, fuzzy
 msgid "Fine resolution"
 msgstr "Pou¾ívám rozli¹ení [%g]"
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 #, fuzzy
 msgid "Coarse resolution"
 msgstr "Korelace"
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 msgid "Draw style"
 msgstr "Styl vykreslení"
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr "stínování"
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 msgid "Wire color"
 msgstr "Barva sítì"
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 #, fuzzy
 msgid "Name of line vector overlay map(s)"
 msgstr "Vektorové mapy s liniemi/plochami pro zobrazení na terénu"
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 msgid "Vector lines"
 msgstr "Vektorové linie"
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 msgid "Vector line width"
 msgstr "©íøka vektorové linie"
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 msgid "Vector line color"
 msgstr "Barva vektorové linie"
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 #, fuzzy
 msgid "Vector line display mode"
 msgstr "Otevøi formuláø v editaèním módu"
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
 msgstr "Vý¹ka vektorové linie"
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 msgid "Name of point vector overlay map(s)"
 msgstr "Jméno vektorové mapy pro pøekryv"
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 msgid "Vector points"
 msgstr "Vektorové body"
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 msgid "Icon size"
 msgstr "Velikost ikon"
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 msgid "Icon width"
 msgstr "©íøka ikony"
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 msgid "Icon color"
 msgstr "Barva ikony"
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 msgid "Icon marker"
 msgstr "Symbol ikony"
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 msgid "Viewpoint position (x,y model coordinates)"
 msgstr "Pozice pohledu (x,y souøadnice modelu)"
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr "stanovisko"
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 msgid "Viewpoint height (in map units)"
 msgstr "Vý¹ka pohledu (v mapových jednotkách)"
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr "Smìr pohledu (ve stupních)"
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 msgid "Viewpoint twist angle (in degrees)"
 msgstr "otáèení výhledu (ve stupních)"
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 #, fuzzy
 msgid "Volumes"
 msgstr "sloupec(ce)"
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 #, fuzzy
 msgid "Volume position"
 msgstr "Zdrojová projekce"
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 #, fuzzy
 msgid "Volume resolution"
 msgstr "Rozli¹ení"
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 msgid "Isosurface level"
 msgstr "vý¹ka rovinného povrchu"
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+#, fuzzy
+msgid "Light position (x,y,z model coordinates)"
+msgstr "Pozice pohledu (x,y souøadnice modelu)"
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+#, fuzzy
+msgid "Lighting"
+msgstr "Nastavení"
+#: ../visualization/nviz2/cmd/args.c:584
+#, fuzzy
+msgid "Light color"
+msgstr "Barva zvýraznìní"
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+msgstr "Zapisuji body ..."
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+#, fuzzy
+msgid "Fringe"
+msgstr "Formátuji"
+#: ../visualization/nviz2/cmd/args.c:625
+#, fuzzy
+msgid "Fringe color"
+msgstr "Barva linie"
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "Sleduj terén"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr "Nejménì <%s> nebo <%s> je po¾adován"
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr "Nesprávný poèet atributù (<%s/%s> %d: <%s> %d)"
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr "Nesprávný poèet atributù (<%s/%s> %d: <%s> %d"
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr "Nesprávný poèet atributù (<%s> %d: <%s> %d)"
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr "Nesprávný poèet atributù (<%s> %d: <%s> %d"
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr "Nesprávný poèet atributù (<%s/%s> %d: <%s> %d, <%s> %d"
@@ -26191,132 +26310,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
 msgstr "Nelze kopírovat atributovou tabulku do vektorové mapy <%s>"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, c-format
-msgid "Failed in attempt to open %s"
-msgstr "Chyba pøi otevírání %s"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr ""
-"Vytvoøí rastrovou mapu sklonu, expozice, køivosti a parciálních derivací "
-"odvozenou z digitálního modelu terénu. Expozice je poèítána proti smìru "
-"hodinových ruèièek s poèátkem na východì."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr "Název rastrového souboru s digitálním modelem terénu"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-msgid "Output slope filename"
-msgstr "Název výstupního souboru sklonù svahù"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-msgid "Output aspect filename"
-msgstr "Název výstupního souboru expozic svahù"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-msgid "Output profile curvature filename"
-msgstr "Název výstupního souboru profilových køivostí"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-msgid "Output tangential curvature filename"
-msgstr "Název výstupního souboru tangenciálních køivostí"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr ""
-"Název výstupního souboru parciálních derivací prvního øádu dx (V - Z sklon "
-"svahu)"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr ""
-"Název výstupního souboru parciálních derivací prvního øádu dy (S - J sklon "
-"svahu)"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-msgid "Output second order partial derivative dxx filename"
-msgstr "Název výstupního souboru parciálních derivací druhého øádu dxx"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-msgid "Output second order partial derivative dyy filename"
-msgstr "Název výstupního souboru parciálních derivací druhého øádu dyy"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-msgid "Output second order partial derivative dxy filename"
-msgstr "Název výstupního soubor parciálních derivací druhého øádu dxy"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte "
-"pøepínaè '--quiet'."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, c-format
-msgid "wrong type: %s"
-msgstr "chybný typ: %s"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-msgid "Creating support files..."
-msgstr "Vytváøím podpùrné soubory..."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr "Výsledky z elevace mapsetu [%s] v [%s]"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr "MAPA EXPOZICE [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr "MAPA SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr "PROFILOVÁ KØIVOST [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr "TANGENCIÁLNÍ KØIVOST [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "MAPA V-Z SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr "MAPA S-J SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr "MAPA DXX [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr "MAPA DYY [%s] DOKONÈENA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr "MAPA DXY [%s] DOKONÈENA"
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 msgid "Cannot load data from table"
@@ -26602,35 +26595,47 @@
 msgstr "Opravte prosím nastavení."
 #: ../db/db.connect/main.c:49
-msgid "Prints/sets general DB connection for current mapset and exits."
+#, fuzzy
+msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
 "Vytisknout/nastavit obecné DB pøipojení aktuálního mapsetu a ukonèit se."
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 msgid "Print current connection parameters and exit"
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 msgid "Check connection parameters, set if uninitialized, and exit"
 msgstr ""
 "Zkontrolovat nastavení parametrù souèasného pøipojení, nastavit je pokud "
 "nejsou, a ukonèit se"
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 msgid "Set"
 msgstr ""
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
+#, fuzzy
+msgid "Set from default settings and exit"
+msgstr "Nastav z výchozího regionu"
+#: ../db/db.connect/main.c:65
+#, fuzzy
+msgid "Overwrite current settings if initialized"
+msgstr "Pøepi¹ existující MASKu"
+#: ../db/db.connect/main.c:87
 msgid "Default group of database users to which select privilege is granted"
 msgstr ""
 "Výchozí skupina u¾ivatelù databáze, které jsou pøiøazeny práva na select."
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 msgid "Database connection not defined. Run db.connect."
 msgstr "Spojení s databází nebylo pro ovladaè definováno. Spus»te db.connect"
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -26641,11 +26646,11 @@
 "ovladaè: %s\n"
 "databáze: %s"
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr "Základní ovladaè není nastaven"
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 msgid "Default database is not set"
 msgstr "Název vstupní databáze není nastaven"
@@ -26891,7 +26896,7 @@
 msgid "'-' to read from standard input"
 msgstr "Pokud není zadáno '-' ète se standardní vstup"
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
 msgstr "Ignoruj chyby SQL a pokraèuj"
@@ -26948,17 +26953,18 @@
 msgid "succeeded"
 msgstr "úspìch"
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr "SQL povel  pro výbìr (select)"
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr ""
 "Pøíkaz SQL select, napø.: 'select * from rybniky where kapri  = 'hodne'"
-#: ../db/db.select/main.c:215
-msgid "Name of file with sql statement"
+#: ../db/db.select/main.c:201
+#, fuzzy
+msgid "Name of file with SQL select statement(s)"
 msgstr "Název souboru s pøíkazy sql"
 #: ../db/db.select/main.c:247
@@ -27164,7 +27170,8 @@
 msgstr "Poèítá lineární regresi pro dvì rastrové mapy: y = a + b*x"
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+#, fuzzy
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr ""
 "Pomalej¹í, ale pøesnìj¹í (pou¾itelné pouze pro mapy s desetinným èíslem)"
@@ -27274,49 +27281,68 @@
 "vstupu)"
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#, fuzzy
+msgid "Files & format"
+msgstr "Formát tabulky"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
 msgid "Output coordinate file (omit to send to stdout)"
 msgstr ""
 "Výstup souøadnicového souboru (vynechává se pøi výpisu na standardní výstup)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 #, fuzzy
 msgid "Field separator (format: input[,output])"
 msgstr "Oddìlovaè sloupcù (bodový mód)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr "Parametry vstupní projekce (ve stylu PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#, fuzzy
+msgid "Projections"
+msgstr "Pøevádím..."
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Output projection parameters (PROJ.4 style)"
 msgstr "Parametry výstupní projekce (ve stylu PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr "Jako vstup pou¾ij LL WGS84 a aktuální location jako výstupní projekci"
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr "Pou¾ij aktuální location jako vstup a LL WGS84 jako výstupní projekci"
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+#, fuzzy
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
 "Výstup lat/long v decimálních stupních nebo jiné projekce s mnoha "
 "desetinnými místy"
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
 msgstr "Èíslo sloupeèku pro souøadnice y ve vstupním souboru"
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "Nezahrnuj jména sloupcù do výstupu"
@@ -27572,6 +27598,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr "Vypi¹ dostupná pravidla barev a ukonèi se"
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 msgid "Prints a graph of the correlation between data layers (in pairs)."
 msgstr "Vytiskne graf korelace mezi datovými vrstvami (v párech)"
@@ -27876,13 +27906,6 @@
 msgid "Raster map to use as mask"
 msgstr "Rastrová mapa pou¾itá jako MASKa"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Create"
-msgstr "Vytvoøení"
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 #, fuzzy
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
@@ -28085,6 +28108,7 @@
 msgstr "GpsBabel podporované výstupní formáty"
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -28100,7 +28124,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr "Podmínka SQL WHERE ov¹em bez slova 'where'"
@@ -28436,19 +28460,24 @@
 "vektorové mapì."
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-msgid "Vector map for which to edit attribute table"
+#, fuzzy
+msgid "Name of vector map for which to edit attribute table"
 msgstr "Vektorová mapa, její¾ atributová tabulka má být editována"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Layer where to add column"
+#, fuzzy
+msgid "Layer number where to add column(s)"
 msgstr "Vrstva, kam pøidat sloupec"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 #, fuzzy
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 "Jména a typ nového(ých) sloupeèku(ù) (typ závisí na pou¾ité databázi, ale "
 "v¹echny podporují VARCHAR(), INT, DOUBLE PRECISION a DATE)"
@@ -28592,7 +28621,8 @@
 msgstr "Vy¾aduje volbu pro seznam pou¾itelných vrstev"
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+#, fuzzy
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr ""
 "Nastavit pravidla barev podle smìrodatné odchylky z prùmìrné hodnoty mapy"
@@ -28969,18 +28999,23 @@
 msgstr "Roz¹íøený výstup (kvartily a 90-té procentily)"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+#, fuzzy
+msgid "Print stats in shell script style"
+msgstr "Vypi¹ statistiku ve stylu pro shell skript"
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
 msgid "Name of data table"
 msgstr "Jméno tabulky"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr "Sloupec na kterém se bude poèítat statistika (musí být èíselného typu)"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 msgid "Database/directory for table"
 msgstr "Databáze nebo adresáø s tabulkou"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 msgid "Database driver"
 msgstr "Ovladaè databáze"
@@ -29050,6 +29085,11 @@
 msgid "Signature file <%s> is invalid"
 msgstr "Soubor s pøíznaky <%s> je neplatný."
+#: ../imagery/i.smap/read_sig.c:30
+#, fuzzy, c-format
+msgid "Signature file <%s> is empty"
+msgstr "Soubor s pøíznaky <%s> je neplatný."
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 msgid "Name of file containing signatures"
 msgstr "Soubor obsahující pøíkazy SQL"
@@ -29607,12 +29647,12 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr "Skupina <%s> neobsahuje ¾ádné mapové vrstvy. Spus»te i.group"
-#: ../imagery/i.rectify/main.c:202
+#: ../imagery/i.rectify/main.c:204
 #, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr "Pou¾ívám region: S=%f J=%f V=%f Z=%f"
-#: ../imagery/i.rectify/main.c:216
+#: ../imagery/i.rectify/main.c:218
 #, c-format
 msgid ""
 "Input raster map <%s> does not exist in group <%s>.\n"
@@ -29621,7 +29661,7 @@
 "Vstupní rastrová mapa <%s> neexistuje ve skupinì <%s>.\n"
 " Zkuste:\n"
-#: ../imagery/i.rectify/main.c:222
+#: ../imagery/i.rectify/main.c:224
 msgid "Exit!"
 msgstr "Konec!"
@@ -29709,7 +29749,7 @@
 msgid "Error while writing to temp file"
 msgstr "Chyba pøi zápisu doèasného souboru"
-#: ../imagery/i.rectify/write.c:54
+#: ../imagery/i.rectify/write.c:55
 #, c-format
 msgid "Error writing row %d"
 msgstr "Chyba pøi zápisu øádky %d."
@@ -29719,12 +29759,12 @@
 msgid "Rectified input raster map <%s> will be saved as <%s>"
 msgstr "Vstupní rastrová mapy <%s> vbyla rektifikována a ulo¾ena jako <%s>"
-#: ../imagery/i.rectify/rectify.c:91
+#: ../imagery/i.rectify/rectify.c:90
 #, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
 msgstr "Rastrová mapa <%s@%s>: Projekce neodpovídá souèasnému nastavení"
-#: ../imagery/i.rectify/rectify.c:97
+#: ../imagery/i.rectify/rectify.c:96
 #, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
 msgstr "Rastrová mapa <%s@%s>: zóna neodpovídá souèasnému nastavení"
@@ -30218,7 +30258,7 @@
 msgid "Name of input raster map (image fft, imaginary part"
 msgstr "Jméno vstupní rastrové mapy (obraz fft, imaginární èást)"
-#: ../imagery/i.ifft/main.c:119
+#: ../imagery/i.ifft/main.c:115
 msgid "The real and imaginary original windows did not match"
 msgstr "Reálná a imaginární originální okna nesouhlasí."
@@ -31298,6 +31338,157 @@
 msgid "Can't mark another point.  Only %d points allowed.  Sorry."
 msgstr "Nelze oznaèit dal¹í bod. Promiòte, je povoleno pouze %d bodù."
+#~ msgid "Not enough room in history file"
+#~ msgstr "Pro soubor s historií není dost místa"
+#~ msgid "New MAPSET name"
+#~ msgstr "Nové jméno MAPSETU"
+#, fuzzy
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "Vypi¹ aktuální cestu k mapsetùm"
+#, fuzzy
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "Sloupec <%s> nebyl nalezen v tabulce <%s>"
+#, fuzzy
+#~ msgid "** no mapsets **\n"
+#~ msgstr "**¾ádné %s soubory nenalezeny **\n"
+#~ msgid "Name of workspace file"
+#~ msgstr "Jméno souboru pracovního prostøedí"
+#, fuzzy
+#~ msgid "Displays raster map layer in the active map display window."
+#~ msgstr "Zobrazí a pøekryje rastrovou mapu v aktivním rámu GRASS monitoru"
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr ""
+#~ "Seznam hodnot, které mají být vykresleny (mapy s plovoucí desetinnou "
+#~ "èárkou)"
+#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
+#~ msgstr ""
+#~ "Ignoruji seznam kategorií: mapa obsahuje hodnoty s plovoucí desetinnou "
+#~ "èárkou (prosím, pou¾ijte volbu 'val=')"
+#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
+#~ msgstr ""
+#~ "Ignoruji seznam hodnot: mapa obsahuje celoèíselné hodnoty (prosím, "
+#~ "pou¾ijte volbu 'cat=')"
+#~ msgid "Area size [%.1e], area not imported"
+#~ msgstr "Velikost plochy [%.1e] plocha nebude importována"
+#~ msgid "Island size [%.1e], island not imported"
+#~ msgstr "Velikost ostrova [%.1e] ostrov nebude importován"
+#~ msgid ""
+#~ "No vector map of sparse points to interpolate was specified. "
+#~ "Interpolation will be done with <%s> vector map"
+#~ msgstr ""
+#~ "®ádná vektorová mapa pro interpolaci. Interpolace bude aplikována na "
+#~ "vektorové mapì <%s>"
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "Chyba pøi otevírání %s"
+#~ msgid ""
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr ""
+#~ "Vytvoøí rastrovou mapu sklonu, expozice, køivosti a parciálních derivací "
+#~ "odvozenou z digitálního modelu terénu. Expozice je poèítána proti smìru "
+#~ "hodinových ruèièek s poèátkem na východì."
+#~ msgid "Raster elevation file name"
+#~ msgstr "Název rastrového souboru s digitálním modelem terénu"
+#~ msgid "Output slope filename"
+#~ msgstr "Název výstupního souboru sklonù svahù"
+#~ msgid "Output aspect filename"
+#~ msgstr "Název výstupního souboru expozic svahù"
+#~ msgid "Output profile curvature filename"
+#~ msgstr "Název výstupního souboru profilových køivostí"
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "Název výstupního souboru tangenciálních køivostí"
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr ""
+#~ "Název výstupního souboru parciálních derivací prvního øádu dx (V - Z "
+#~ "sklon svahu)"
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#~ msgstr ""
+#~ "Název výstupního souboru parciálních derivací prvního øádu dy (S - J "
+#~ "sklon svahu)"
+#~ msgid "Output second order partial derivative dxx filename"
+#~ msgstr "Název výstupního souboru parciálních derivací druhého øádu dxx"
+#~ msgid "Output second order partial derivative dyy filename"
+#~ msgstr "Název výstupního souboru parciálních derivací druhého øádu dyy"
+#~ msgid "Output second order partial derivative dxy filename"
+#~ msgstr "Název výstupního soubor parciálních derivací druhého øádu dxy"
+#~ msgid ""
+#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
+#~ "quiet' instead."
+#~ msgstr ""
+#~ "Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, "
+#~ "peou¾ijte pøepínaè '--quiet'."
+#~ msgid "wrong type: %s"
+#~ msgstr "chybný typ: %s"
+#~ msgid "Creating support files..."
+#~ msgstr "Vytváøím podpùrné soubory..."
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "Výsledky z elevace mapsetu [%s] v [%s]"
+#~ msgid "ASPECT [%s] COMPLETE"
+#~ msgstr "MAPA EXPOZICE [%s] DOKONÈENA"
+#~ msgid "SLOPE [%s] COMPLETE"
+#~ msgstr "MAPA SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+#~ msgid "PROFILE CURVE [%s] COMPLETE"
+#~ msgstr "PROFILOVÁ KØIVOST [%s] DOKONÈENA"
+#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
+#~ msgstr "TANGENCIÁLNÍ KØIVOST [%s] DOKONÈENA"
+#~ msgid "E-W SLOPE [%s] COMPLETE"
+#~ msgstr "MAPA V-Z SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+#~ msgid "N-S SLOPE [%s] COMPLETE"
+#~ msgstr "MAPA S-J SKLONOVÝCH POMÌRÙ [%s] DOKONÈENA"
+#~ msgid "DXX [%s] COMPLETE"
+#~ msgstr "MAPA DXX [%s] DOKONÈENA"
+#~ msgid "DYY [%s] COMPLETE"
+#~ msgstr "MAPA DYY [%s] DOKONÈENA"
+#~ msgid "DXY [%s] COMPLETE"
+#~ msgstr "MAPA DXY [%s] DOKONÈENA"
+#, fuzzy
+#~ msgid ""
+#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
+#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
+#~ "PRECISION and DATE)"
+#~ msgstr ""
+#~ "Jména a typ nového(ých) sloupeèku(ù) (typ závisí na pou¾ité databázi, ale "
+#~ "v¹echny podporují VARCHAR(), INT, DOUBLE PRECISION a DATE)"
 #~ msgid "Sources and sinks in [m^3/s]"
 #~ msgstr "Prameny a jezera v [m^3/s]"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_de.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_de\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2010-08-25 16:32+0200\n"
 "Last-Translator: Robert Nuske <rnuske gwdg.de>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
@@ -19,7 +19,7 @@
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 msgid "Error closing 3d raster map"
@@ -61,7 +61,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "Raster"
@@ -81,7 +81,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -175,7 +175,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -190,39 +189,39 @@
 msgid "Error opening grid3 file [%s]"
 msgstr "Fehler beim Öffnen der Grid3-Datei [%s]."
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 msgid "Cannot allocate memory for string"
 msgstr "Kann kein Speicherplatz für Zeichenkette bekommen."
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, c-format
 msgid "Error reading range for [%s]"
 msgstr "Fehler beim Lesen der Datenspanne für [%s]."
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 msgid "Error while reading history file"
 msgstr "Fehler beim Lesen der 'history'-Datei."
@@ -257,7 +256,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -285,7 +284,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "Fehler beim Schließen der neuen 3D-Rasterkarte."
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 msgid "Error closing ascii file"
 msgstr "Fehler beim Schließen der ASCII-Datei."
@@ -1126,7 +1125,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1141,7 +1140,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1174,17 +1173,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1237,7 +1235,7 @@
 msgstr "GeoTIFF Erzeugungsoption(en)"
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 msgid "List supported formats and exit"
 msgstr "Zeige unterstützte Formate an und Schluß."
@@ -1250,22 +1248,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1313,7 +1311,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 msgid "Name of input raster map"
@@ -1607,12 +1604,27 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr "Minimale Anzahl der im Hauptspeicher zu haltenden Zeile ist 1."
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
+#, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "Illegale X-Koordinate <%s>."
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr "Ungültige Nord-Koordinate <%s>."
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr "Ungültige Ost-Koordinate <%s>."
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "Durchlauf %d (von %d) ..."
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 msgid "Writing raster map..."
 msgstr "Schreibe Rasterkarte..."
@@ -1631,12 +1643,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1666,7 +1678,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1676,7 +1688,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1746,13 +1758,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1768,7 +1780,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1778,8 +1790,8 @@
 msgid "Unable to open database <%s> by driver <%s>"
 msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1790,7 +1802,7 @@
 msgid "Unable to create table: '%s'"
 msgstr "Kann Tabelle nicht erzeugen: '%s'"
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1800,8 +1812,8 @@
 msgstr "Kann keinen Index für die Tabelle <%s>, Schlüssel <%s> erzeugen."
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2091,7 +2103,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, c-format
@@ -2176,10 +2188,10 @@
 msgid "Output world file"
 msgstr "WORLD-File für das TIFF erzeugen."
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, c-format
 msgid "[%s]: No such color"
 msgstr "[%s]: Diese Farbe gibt es nicht."
@@ -2199,11 +2211,11 @@
 msgid "Writing world file"
 msgstr "Schreibe TIFF-Worldfile."
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 msgid "Got null file name"
 msgstr "Habe keinen Dateinamen erhalten."
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr "Habe NULL-Region struct erhalten."
@@ -2379,7 +2391,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2503,8 +2515,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 msgid "Required"
 msgstr "Benötigt"
@@ -2526,7 +2538,7 @@
 msgid "Metadata"
 msgstr "Metadaten"
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 msgid "Name for new location to create"
 msgstr "Name der neu zu erstellenden Location."
@@ -2535,7 +2547,7 @@
 msgstr "Übersteuere die Projektion (verwende Projektion der Location)."
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 msgid "Extend location extents based on new dataset"
 msgstr "Vergrößere die Location basierend auf dem neuen Datensatz."
@@ -2578,7 +2590,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2627,7 +2639,7 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
@@ -2635,7 +2647,7 @@
 "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
 "erstelle daher keine neue Location."
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, c-format
 msgid "Location <%s> created"
 msgstr "Location <%s> erstellt."
@@ -2649,12 +2661,12 @@
 "konvertieren, zwecks Überprüfung."
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 msgid "Over-riding projection check"
 msgstr "Übersteuere die Überprüfung der Projektion."
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -2672,7 +2684,7 @@
 msgstr "Datensatz PROJ_INFO:\n"
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "Zu importierender Datensatz PROJ_INFO:\n"
@@ -2697,7 +2709,7 @@
 "erzeugen.\n"
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 msgid "Projection of input dataset and current location appear to match"
 msgstr ""
 "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
@@ -2820,30 +2832,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr "Einstellungen"
@@ -3040,13 +3049,15 @@
 #: ../raster/r.resamp.bspline/main.c:92
 #, fuzzy
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr "Spline-Interpolations-Schrittweite in Ost-West-Richtung."
 #: ../raster/r.resamp.bspline/main.c:100
 #, fuzzy
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr "Spline-Interpolations-Schrittweite in Nord-Süd-Richtung"
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -3091,7 +3102,7 @@
 msgstr "Spline-Interpolations-Schrittweite in Ost-Richtung."
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -3099,7 +3110,7 @@
 msgstr "Adjustiere OW Splines %d"
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -3130,7 +3141,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3148,7 +3159,7 @@
 msgstr "Kann die Vektorkarte <%s> nicht erzeugen."
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3163,7 +3174,7 @@
 "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
 "ändern."
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 msgid "Writing output..."
 msgstr "Schreibe Ausgabe..."
@@ -3378,7 +3389,7 @@
 msgstr "Richtung gelesen: %lf, Nachbar gefunden: %i"
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 #, fuzzy
 msgid "metadata"
 msgstr "Metadaten"
@@ -3450,7 +3461,7 @@
 msgid "Raster map <%s> not found in current mapset"
 msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3461,37 +3472,33 @@
 msgid "Unable to open input file <%s>"
 msgstr "Kann die Eingabedatei <%s> nicht öffnen."
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-msgid "Not enough room in history file"
-msgstr "Nicht genug Platz in der History-Datei."
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "Kann die Kategorie-Datei der Rasterkarte <%s@%s> nicht lesen."
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, c-format
 msgid "cats table for [%s] set to %s"
 msgstr "cats Tabelle für [%s] ist auf %s gesetzt."
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr "[%s] ist eine reklassifizierte Karte einer anderen Karte. Beende mich."
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, c-format
 msgid "Writing new null file for [%s]... "
 msgstr "Schreibe neue NULL-Datei für Karte [%s]... "
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr "Entferne NULL-Datei für [%s]...\n"
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 msgid "Done."
 msgstr "Fertig."
@@ -4535,12 +4542,10 @@
 msgstr "Name der Ausgabe-Expositions-Rasterkarte."
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 msgid "Format for reporting the slope"
 msgstr "Format für die Hangneigung."
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 msgid "Type of output aspect and slope maps"
 msgstr "Typ für die Ausgabe von Hangneigung und -ausrichtung."
@@ -4579,19 +4584,16 @@
 msgstr "Name der Ausgabe-Rasterkarte der zweiten partiellen Ableitung dxy."
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr "Multiplikator, um Höheneinheiten in Meter umzurechnen."
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr ""
 "Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet "
 "werden soll."
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 msgid "Do not align the current region to the elevation layer"
 msgstr ""
 "Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen "
@@ -4637,59 +4639,57 @@
 msgstr "Höhen-Ergebnisse für Mapset <%s> in <%s>."
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr "Min berechnete Exposition%.4f, max berechnete Exposition %.4f."
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, c-format
 msgid "Aspect raster map <%s> complete"
 msgstr "Expositions-Rasterkarte <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr ""
 "minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, c-format
 msgid "Slope raster map <%s> complete"
 msgstr "Neigungs-Rasterkarte <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr "Rasterkarte mit vertikaler Wölbung <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, c-format
 msgid "Tangential curve raster map <%s> complete"
 msgstr "Rasterkarte mit horizontaler Wölbung <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, c-format
 msgid "E-W slope raster map <%s> complete"
 msgstr "O-W Neigungs-Rasterkarte <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, c-format
 msgid "N-S slope raster map <%s> complete"
 msgstr "N-S Neigungs-Rasterkarte <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr "Dxx Rasterkarte <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, c-format
 msgid "Dyy raster map <%s> complete"
 msgstr "Dyy Rasterkarte <%s> komplett."
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, c-format
 msgid "Dxy raster map <%s> complete"
 msgstr "Dxy Rasterkarte <%s> komplett."
@@ -4772,7 +4772,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -4951,7 +4951,6 @@
 msgstr "Name der Ausgabekarte"
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr "Prozent fertig: "
@@ -5452,68 +5451,68 @@
 msgid "Filter <%s> not found"
 msgstr "Datei <%s> nicht gefunden."
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 #, fuzzy
 msgid "resample"
 msgstr "Raster, Resamplen"
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr "Erzeugt eine neue Rasterkarte gröberer Auflösung mittels Aggregation."
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 #, fuzzy
 msgid "Filter radius (horizontal)"
 msgstr "Teile horizontal und nicht vertikal."
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr "Reiche NULLs durch"
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 #, fuzzy
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr "weight= und -c schließen sich gegenseitig aus."
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, fuzzy, c-format
 msgid "Too many filters (max: %d)"
 msgstr "<%s> hat zu viele Signaturen (Limit ist 255)"
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "Zumindest eine Option von %s muss angegeben werden."
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, c-format
 msgid "Unable to read color table for %s"
 msgstr "Kann die Farbtabelle für %s nicht lesen."
@@ -6101,7 +6100,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr "%s: %s - ungültige Entfernungsangabe."
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, c-format
 msgid "Unknown method <%s>"
 msgstr "Unbekannte Methode <%s>."
@@ -6123,7 +6122,7 @@
 msgid "Aggregate operation"
 msgstr "Aggregationsverfahren"
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
@@ -8156,6 +8155,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr ""
 "zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
@@ -8515,32 +8515,32 @@
 msgid "Pass %d..."
 msgstr "Durchgang %d..."
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "Exportiere eine GRASS Rasterkarte als binäre MAT-Datei."
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 msgid "Name for new TIFF file"
 msgstr "Name für neue TIFF-Datei."
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr "TIFF Dateikompression."
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr "TIFF Palettenausgabe (8 anstelle von 24 bit)."
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 msgid "Output TIFF world file"
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 msgid "Output Tiled TIFF"
 msgstr "Ausgabe als gekacheltes (tiled) TIFF."
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, fuzzy, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
@@ -8549,23 +8549,23 @@
 "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. "
 "Nachkommastellen werden auf ganze Zahlen gerundet!"
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
 msgstr ""
 "Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, c-format
 msgid "Unable to open TIFF file <%s>"
 msgstr "Kann die TIFF-Datei <%s> nicht öffnen."
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 msgid "Writing TIFF World file"
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 msgid "Unable to open TIFF world file for writing"
 msgstr "Kann das TIFF-Worldfile nicht zum Schreiben öffnen."
@@ -8678,7 +8678,7 @@
 msgstr "Lese Daten..."
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -8689,21 +8689,21 @@
 "die folgenden Zeichen in Zeile %lu gefunden:\n"
 "[%s]"
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr "Zeile, wie gefordert, ignoriert."
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr "Schlechte Y-Koordinate in Zeile %lu Spalte %d. <%s>"
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr "Schlechte X-Koordinate in Zeile %lu Spalte %d. <%s>"
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr "Schlechte Z-Koordinate in Zeile %lu Spalte %d. <%s>"
@@ -8712,16 +8712,16 @@
 msgid "Writing to map ..."
 msgstr "Schreibe in die Karte ..."
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, c-format
 msgid "%lu points found in region."
 msgstr "%lu Punkte in der Region gefunden."
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 msgid "Scanning data ..."
 msgstr "Lese Daten ..."
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr "Bereich:     min         max\n"
@@ -9255,67 +9255,67 @@
 msgid "unable to open <%s> mask ... continuing without!"
 msgstr "CHILD[pid = %i]: kann %s Maske nicht öffnen ... mache ohne weiter !!!"
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 msgid "Cannot create random access file"
 msgstr "Kann die Direktzugriffsdatei nicht erzeugen. "
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr "Kann das Verzeichnis %s/.r.li/ nicht erzeugen."
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
 msgstr "Kann das Verzeichnis %s/.r.li/output/ nicht erzeugen."
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
 msgstr "Kann stat von %s Konfigurationsdatei nicht erzeugen."
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 msgid "Cannot read setup file"
 msgstr "Kann Setup Datei nicht lesen."
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 msgid "Irregular maskedoverlay areas definition"
 msgstr "Unregelmäßige maskedoverlay Flächen Definition."
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
 "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 msgid "Illegal configuration file (sample area)"
 msgstr "Ungültige Konfigurationsdatei (Stichprobenfläche)."
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 msgid "Too many units to place"
 msgstr "Zu viele Einheiten zu platzieren."
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 msgid "Too many strats for raster map"
 msgstr "Zu viele Straten für diese Rasterkarte."
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr "Ungültige Anordnung der Flächen."
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 msgid "Cannot make lseek"
 msgstr "Kann lseek nicht ausführen."
@@ -9649,10 +9649,10 @@
 "Parameter %s an."
 #: ../raster/r.out.gdal/export_band.c:201
-#, c-format
+#, fuzzy, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 "Der gewählte NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
 "Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
@@ -9839,7 +9839,7 @@
 msgid "Name of color file"
 msgstr "Name der Farb-Datei."
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 msgid "Vertical exaggeration"
 msgstr "Vertikale Überhöhung."
@@ -9899,16 +9899,21 @@
 msgid "File containing expression(s) to evaluate"
 msgstr "Datei mit Reklassifizierungsregeln."
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:145
 #, fuzzy
+msgid "file= and expression= are mutually exclusive"
+msgstr "'input=' und 'source=' schließen sich gegenseitig aus."
+#: ../raster/r.mapcalc/main.c:155
+#, fuzzy
 msgid "parse error"
 msgstr "Parameterfehler"
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr "Während der Berechnung sind Fließkomma-Fehler aufgetreten."
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr "Überlauf während der Berechnung."
@@ -10217,8 +10222,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 msgid "Position"
 msgstr "Position"
@@ -10820,8 +10825,8 @@
 "Sequenzen (nur bei CELL-Karten)."
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 msgid "Attributes"
 msgstr "Attribute"
@@ -10872,7 +10877,7 @@
 msgstr "Kann nicht in Tabelle <%s> einfügen."
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "Kann neue Zeile %s nicht einfügen."
@@ -11309,19 +11314,19 @@
 "Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte "
 "setzen Sie geog. Länge via 'lat' oder 'latin'!"
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr "UPS: Die Zeilen haben sich von %d auf %d geändert."
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr "OOPS: Spalten haben sich von %d auf %d verändert."
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -11337,7 +11342,7 @@
 msgid "Error in pj_do_proj"
 msgstr "Error in pj_do_proj"
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr "Berechne Karte %01d von %01d (Winkel %lf, Rasterkarte <%s>)."
@@ -11730,7 +11735,7 @@
 msgid "Raster map(s) to report on"
 msgstr "Rasterkarte(n), für die ein Report erstellt werden soll."
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr "Einheiten"
@@ -11766,7 +11771,6 @@
 msgstr "Name der Ausgabedatei zum Speichern des Reports."
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 msgid "Quiet"
 msgstr "schweigsam"
@@ -12268,13 +12272,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr "Fortgeschritten"
@@ -12497,15 +12494,15 @@
 msgid "Writing topographic index map..."
 msgstr "Schreibe Karte mit topographischem Index."
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 msgid "Resamples raster map layers to a coarser grid using aggregation."
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 msgid "Aggregation method"
 msgstr "Aggregationsmethode."
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 msgid "Weight according to area (slower)"
 msgstr "Gewichte in Bezug auf die Fläche (langsamer)."
@@ -12919,13 +12916,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -12961,15 +12958,68 @@
 msgid "Access for others"
 msgstr "Zugang für Andere."
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+"Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht "
+"unterstützt."
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr ""
 "Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 msgid "Unable to determine mapset permissions"
 msgstr "Kann die Zugriffsrechte des Mapsets nicht ermitteln."
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "Kann die Zugriffsrechte des Mapsets nicht ermitteln."
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+#, fuzzy
+msgid "read "
+msgstr "Fläche"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 msgid "Error reading WKT projection description"
 msgstr "Fehler beim Lesen der WKT Projektionsangaben."
@@ -13629,46 +13679,46 @@
 msgid "Error conducting transform (%d)"
 msgstr "Fehler beim Erzeugen der Transformation."
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr "Schlecht platzierte Kontrollpunkte."
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr "Ungenügend Speicher."
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 msgid "Parameter error"
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 msgid "No active control points"
 msgstr "Keine aktiven Kontrollpunkte."
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
 msgstr "Ungültige Koordinaten %s %s."
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 #, fuzzy
 msgid "transformation"
 msgstr "Vektor, Transformation"
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 msgid "Computes a coordinate transformation based on the control points."
 msgstr ""
 "Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 msgid "Rectification polynomial order"
 msgstr "Polynomgrad der Entzerrung."
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -13680,36 +13730,36 @@
 "Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);fd;"
 "Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 msgid "Output format"
 msgstr "Ausgabeformat."
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 msgid "Display summary information"
 msgstr "Zeige Zusammenfassung."
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr ""
 "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 #, fuzzy
 msgid "Local x,y coordinates to target east,north"
 msgstr "Die Koordinate des Zentrums (Ostenn Norden)."
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 #, fuzzy
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr "Umgekehrte Transformation; 3D Vektorfeature nach 2D."
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 #, fuzzy
 msgid "Target east,north coordinates to local x,y"
 msgstr "Untere Linke Ost- und Nord-Koordinaten der Karte."
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 #, fuzzy
 msgid "Display transform matrix coefficients"
 msgstr "Karte mit Werten für X-Koeffizienten."
@@ -13723,51 +13773,67 @@
 msgid "Change current mapset."
 msgstr "Ändere aktuelles Mapset."
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
-msgstr "Neuer Mapset Name."
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
+msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "Name der Ausgabekarte, in die die Fehler geschrieben werden sollen."
+#: ../general/g.mapset/main.c:63
+#, fuzzy
+msgid "Location name (not location path)"
 msgstr "Neuer LOCATION Name (nicht der Pfad zur Location)."
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+#, fuzzy
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr ""
 "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue "
 "L0cation befindet)."
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 msgid "Create mapset if it doesn't exist"
 msgstr "Erzeuge das Mapset, wenn es nicht existiert."
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
+#, fuzzy
+msgid "Create"
+msgstr "Erzeugung"
+#: ../general/g.mapset/main.c:86
 msgid "List available mapsets"
 msgstr "Zeige alle verfügbaren Mapsets."
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 msgid "Either mapset= or -l must be used"
 msgstr "Entweder mapset= oder -l muss angegeben werden."
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, c-format
 msgid "<%s> is already the current mapset"
 msgstr "<%s> ist bereits das aktuelle Mapset."
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 msgid "You don't have permission to use this mapset"
 msgstr "Sie haben nicht die Berechtigung dieses Mapset zu verwenden."
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr ""
 "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr "Kann die Umgebungsvariable GIS_LOCK nicht lesen."
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
@@ -13776,15 +13842,15 @@
 "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann "
 "nicht überprüft werden."
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 msgid "Cleaning up temporary files..."
 msgstr "Räume temporäre Dateien auf..."
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 msgid "Your shell continues to use the history for the old mapset"
 msgstr "Ihre Shell verwendet weiterhin die History des alten Mapsets."
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
@@ -13793,7 +13859,7 @@
 "Sie können die History mit folgenden Befehlen umschalten:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
@@ -13802,16 +13868,6 @@
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
-#: ../general/g.mapsets/dsply_path.c:19
-#, c-format
-msgid "Your mapset search list:\n"
-msgstr "Ihr Mapset Suchpfad:\n"
-#: ../general/g.mapsets/dsply_path.c:29
-#, c-format
-msgid "<%s> not found in mapset list"
-msgstr "<%s> nicht in der Mapset-Liste gefunden."
 #: ../general/g.mapsets/main.c:62
 msgid ""
 "Modifies the user's current mapset search path, affecting the user's access "
@@ -13865,15 +13921,14 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr "Kann SEARCH_PATH nicht zum Schreiben öffnen."
-#: ../general/g.mapsets/dsply_maps.c:23
-#, c-format
+#: ../general/g.mapsets/list.c:10
 msgid "Available mapsets:"
 msgstr "Verfügbaren Mapsets:"
-#: ../general/g.mapsets/dsply_maps.c:33
-#, c-format
-msgid "** no mapsets **\n"
-msgstr "** keine Mapsets **\n"
+#: ../general/g.mapsets/list.c:35
+#, fuzzy
+msgid "Accessible mapsets:"
+msgstr "Verfügbaren Mapsets:"
 #: ../general/g.copy/main.c:43
 msgid ""
@@ -14416,40 +14471,40 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr "output= und method= müssen die selbe Anzahl von Werten haben."
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, fuzzy, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "Die Datei '%s' existiert bereits und wird überschrieben."
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "Öffne %s zum Schreiben... "
@@ -14472,12 +14527,12 @@
 msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten tcltk"
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-msgid "Name of workspace file"
-msgstr "Name der Workspace-Datei."
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
 #: ../general/g.gui/main.c:57
 msgid "Update default GUI setting"
@@ -14494,6 +14549,11 @@
 msgid "<%s> is now the default GUI"
 msgstr "<%s> ist jetzt das Standard-GUI."
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 msgid "Force remove"
 msgstr "Erzwinge das Löschen"
@@ -14533,7 +14593,7 @@
 msgid "Unable to read FP range for %s"
 msgstr "Kann die fp Spanne für <%s> nicht lesen."
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -14548,7 +14608,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -14576,7 +14636,7 @@
 msgid "At least two points are required"
 msgstr "Nicht genügend Punkte, %d werden benötigt."
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -14589,7 +14649,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -14597,7 +14657,7 @@
 msgid "No graphics device selected"
 msgstr "Keine Graphik-Ausgabe ausgewählt."
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
@@ -14605,37 +14665,37 @@
 "Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt "
 "wird."
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 msgid "Choose new current font"
 msgstr "Wähle neuen Font."
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 msgid "Path to Freetype-compatible font including file name"
 msgstr "Pfad zu den TrueType-Schriften (inklusive Dateiname)."
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr "Zeichenkodierung"
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 msgid "List fonts"
 msgstr "Gebe Fonts aus."
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 msgid "List fonts verbosely"
 msgstr "Gebe die Fonts ausführlich aus."
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, c-format
 msgid "Unable to access font path %s: %s"
 msgstr "Kann auf den Font-Pfad %s: %s nicht zugreifen."
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, c-format
 msgid "Font path %s is not a file"
 msgstr "Font-Pfad %s ist keine Datei."
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -15107,6 +15167,7 @@
 "Zeichnet eine Legende für eine Rasterkarte in dem aktiven Grafikfenster."
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 msgid "Name of raster map"
 msgstr "Name der Rasterkarte"
@@ -15288,8 +15349,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -15536,33 +15597,33 @@
 msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer dargestellt."
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 msgid "Selection"
 msgstr "Selektion"
@@ -15608,15 +15669,15 @@
 msgstr "'layer' muss > 0 sein."
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, c-format
 msgid "Database connection not defined"
 msgstr "Datenbankverbindung nicht definiert."
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -16398,47 +16459,46 @@
 msgid "Error: %s\n"
 msgstr "Fehler: %s\n"
-#: ../display/d.rast/main.c:55
+#: ../display/d.rast/main.c:54
 #, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr ""
-"Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
-"möglich."
+msgid "Displays raster map layer."
+msgstr "Fragt Farben einer Rasterkarte ab."
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 msgid "Raster map to be displayed"
 msgstr "Rasterkarte, die angezeigt werden soll."
-#: ../display/d.rast/main.c:67
-msgid "List of categories to be displayed (INT maps)"
+#: ../display/d.rast/main.c:66
+#, fuzzy
+msgid "List of categories or values to be displayed"
 msgstr "Liste der Werte die angezeigt werden sollen (INT-Karten)."
-#: ../display/d.rast/main.c:76
-msgid "List of values to be displayed (FP maps)"
-msgstr "Liste der Werte die angezeigt werden sollen (FP-Karten)."
-#: ../display/d.rast/main.c:85
+#: ../display/d.rast/main.c:72
 msgid "Background color (for null)"
 msgstr "Hintergrundfarbe (für NULL)."
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+msgid "Either a standard color name or R:G:B triplet"
+msgstr "Entweder ein Standardfarbname oder ein R:G:B Tripel."
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
+#: ../display/d.rast/main.c:81
+#, fuzzy
+msgid "Invert value list"
 msgstr "Invertiere Kategorieliste."
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
-"Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen Sie "
-"'val=')."
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "%s: ungültiger Wert."
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr ""
-"Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
 #: ../display/d.rast.num/main.c:73
 msgid ""
@@ -16782,10 +16842,6 @@
 msgid "Label color"
 msgstr "Label Farbe"
-#: ../display/d.vect/main.c:263
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "Entweder ein Standardfarbname oder ein R:G:B Tripel."
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr "Label Hintergrundfarbe"
@@ -17059,7 +17115,7 @@
 "Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -17080,7 +17136,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
 msgstr "Kann keinen Index erstellen."
@@ -17098,7 +17154,7 @@
 msgstr "Kein Eintrag für die Kategorie %d in der Tabelle <%s>."
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -17111,7 +17167,7 @@
 msgstr "Kann Zeile nicht einfügen: %s"
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -17139,7 +17195,7 @@
 msgstr "Datenbank, SQL"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -17209,7 +17265,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -17467,7 +17523,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, c-format
@@ -17597,10 +17653,8 @@
 msgstr "Abfragelayernummer (lesen)"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 msgid "Query"
 msgstr "Abfrage"
@@ -17992,16 +18046,16 @@
 msgid "Unable to build topology for <%s>"
 msgstr "Kann den Stoppvektor <%s> nicht finden."
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "Konvertiere OGR Vektorlayer in das GRASS Vektorkarten."
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 msgid "OGR datasource name"
 msgstr "Name der OGR Datenquelle"
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: directory containing shapefiles\n"
@@ -18011,13 +18065,13 @@
 "\t\tESRI Shapefile: Verzeichnis, welches die Shapefiles beinhaltet.\n"
 "\t\tMapInfo Datei: Verzeichnis, welches die MapInfo-Dateien enthält."
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
 "Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer "
 "importiert."
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: shapefile name\n"
@@ -18027,36 +18081,36 @@
 " \t\tESRI Shapefile: Name des Shapefiles\n"
 "\t\tMapInfo Datei: Mapinfo-Dateiname."
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 msgid "Import subregion only"
 msgstr "Importiere nur einen Ausschnitt."
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 msgid "Subregion"
 msgstr "Ausschnitt"
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr "Format: xmin,ymin,xmax,ymax - gewöhnlich W,S,O,N"
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr "Kleinste zu importierende Fläche (in Flächeneinheiten)"
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr "Min-Fläche & snap"
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
 "Kleinere Flächen und Inseln werden ignoriert. Sollte größer sein als snap^2."
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 msgid "Optionally change default input type"
 msgstr "Optionalerweise: Ändere den Standard Input-Typ."
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
 "boundary;import lines as area boundaries;centroid;import points as centroids"
@@ -18065,15 +18119,15 @@
 "boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als "
 "Zentroide"
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 msgid "Snapping threshold for boundaries"
 msgstr "Schwellenwert für Snapping der Grenzen."
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr "'-1' für kein snapping"
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
@@ -18081,84 +18135,84 @@
 "Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der "
 "Erste entspricht der Kategoriespalte."
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 msgid "List available layers in data source and exit"
 msgstr "Zeigt die vorhandenen Layer in der Datenquelle und beendet sich."
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 msgid "Do not clean polygons (not recommended)"
 msgstr "Polygone nicht säubern (clean) (nicht empfehlenswert)."
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 msgid "Create 3D output"
 msgstr "Erzeuge eine 3D-Ausgabe."
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 msgid "Do not create attribute table"
 msgstr "Keine Attributtabelle erzeugen."
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 msgid "Override dataset projection (use location's projection)"
 msgstr ""
 "Übersteuere die Projektion des Datensatzes (verwende Projektion der "
 "Location)."
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 msgid "Limit import to the current region"
 msgstr "Begrenze den Import auf die aktuelle Region."
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr "Ändere Spaltenname zu Kleinbuchstaben"
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr "Vorhandene OGR-Treiber:"
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, c-format
 msgid "Unable to open data source <%s>"
 msgstr "Kann die Datenquelle <%s> nicht öffnen."
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr "Datenquelle enthält %d Layer:"
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Die Vektorkarte <%s> existiert bereits und wird überschrieben."
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, c-format
 msgid "Vector map <%s> already exists"
 msgstr "Vektorkarte <%s> existiert bereits."
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, c-format
 msgid "Layer <%s> not available"
 msgstr "Layer <%s> ist nicht vorhanden."
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
 "Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option "
 "'spatial' aber nicht beide."
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 msgid "4 parameters required for 'spatial' parameter"
 msgstr "4 Werte sind für den Parameter 'spatial' nötig."
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
@@ -18166,11 +18220,11 @@
 "Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
 "konvertieren, zwecks Überprüfung."
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr "GRASS LOCATION PROJ_INFO:\n"
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, c-format
 msgid ""
 "\n"
@@ -18180,7 +18234,7 @@
 "Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
 "übersteuern.\n"
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
 "set.\n"
@@ -18188,29 +18242,29 @@
 "Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der "
 "Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "%s: Fehler beim Schreiben der temporären Datei."
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, c-format
 msgid "Layer: %s"
 msgstr "Layer: %s"
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr "Spaltenname wurde geändert: '%s' -> '%s'"
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
 "Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas "
 "abgeschnitten worden sein). "
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
@@ -18219,100 +18273,105 @@
 "Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR "
 "bestimmt). Einige Texte können abgeschnitten worden sein!"
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
 "Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas "
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, c-format
 msgid "Column type not supported (%s)"
 msgstr "Spaltentyp (%s) wird nicht unterstützt."
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
 #, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "Importiere %d Objekte der Karte..."
+#: ../vector/v.in.ogr/main.c:854
+#, fuzzy, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr "Bufferdistanz in Karteneinheiten."
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr "%d %s ohne Geometrie."
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr "Säubere Polygone; für das Resultat wird nicht garantiert!"
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr "Snappe Grenzen (Schwellwert = %.3e):"
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 msgid "Break polygons:"
 msgstr "Zerlege Polygone:"
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 msgid "Remove duplicates:"
 msgstr "Lösche Doppelte:"
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr "Zerlege Grenzen:"
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr "Säubere Grenzen an den Knoten:"
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 msgid "Change boundary dangles to lines:"
 msgstr "Ändere Grenzüberstände zu Linien:"
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change dangles to lines:"
 msgstr "Ändere Überstände zu Linien:"
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr "Ändere Brücken der Grenzen zu Linien:"
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr "Lösche Brücken:"
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 #, fuzzy
 msgid "Merge boundaries:"
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
 msgstr "Kann den Flächenzentroiden nicht berechnen."
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, fuzzy, c-format
 msgid "Find centroids for layer: %s"
 msgstr "Falscher Eintrag für Faktor %s."
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 #, fuzzy
 msgid "Write centroids:"
 msgstr "Schreibe Zentroide..."
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -18324,47 +18383,47 @@
 "der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist "
 "als Kategoriewert im Layer %d abgelegt."
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, fuzzy, c-format
 msgid "%d input polygons\n"
 msgstr "%d Eingabepolygone"
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, c-format
 msgid "%d input polygons"
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
 msgstr "Gesamtfläche: %e (%d Flächen)"
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
 msgstr "Überlappende Fläche: %e (%d Flächen)"
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
 msgstr "Fläche ohne Kategorien: %e (%d Flächen)"
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
 "import 3D vector"
@@ -18372,44 +18431,39 @@
 "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur "
 "2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "Kann Teil der Geometrie nicht schreiben."
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr "Überspringe leere Geometrieobjekte"
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr "Degeneriere Polygon ([%d] Vertices)"
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr "Flächengröße [%.1e], Fläche nicht importiert."
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr "Degeneriere Insel ([%d] Vertices)"
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr "Inselgröße [%.1e], Insel nicht importiert."
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 msgid "Cannot calculate centroid"
 msgstr "Kann Zentroid nicht berechnen."
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr "Kein Zentroid für Polygone mit 0 Vertices geschrieben."
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 msgid "Cannot write part of geometry"
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 msgid "Unknown geometry type"
 msgstr "Unbekannter Geometrie-Typ."
@@ -18602,6 +18656,9 @@
 msgstr "Eingabetabelle"
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 msgid "Connection"
 msgstr "Verbindung"
@@ -18634,12 +18691,12 @@
 "bereits."
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, c-format
 msgid "Missing column <%s> in table <%s>"
 msgstr "Vermisse Spalte <%s> in der Tabelle <%s>."
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 msgid "Data type of key column must be integer"
 msgstr "Datentyp der Schlüssel-Spalte (key column) muss ein integer sein."
@@ -18859,8 +18916,8 @@
 msgstr "Layer-Nummer (from)."
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 msgid "From"
 msgstr "From"
@@ -18881,8 +18938,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 msgid "To"
 msgstr "To"
@@ -18909,7 +18966,7 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr "Kann keine Rechte für die Tabelle <%s> setzen."
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
@@ -18917,53 +18974,53 @@
 "Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
 "Vektorkarte 'from'. "
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 msgid "Name of existing vector map (from)"
 msgstr "Name einer existierenden Vektorkarte (from)."
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 msgid "Feature type (from)"
 msgstr "Art des Vektorobjekts (from)."
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 msgid "Name of existing vector map (to)"
 msgstr "Name einer existierenden Vektorkarte (to)."
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
 msgstr "Layer-Nummer (to)."
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 msgid "Feature type (to)"
 msgstr "Art des Vektorobjekts (to)."
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
 "Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen "
 "Elementen."
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 msgid "Maximum distance or -1 for no limit"
 msgstr "Maximale Distanz oder -1 für unbegrenzt."
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 msgid "Minimum distance or -1 for no limit"
 msgstr "Minimale Distanz oder -1 für unbegrenzt."
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr ""
 "Werte, die die Verbindung zwischen zwei nächstgelegenen Featuren "
 "beschreiben. "
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
 "to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
@@ -18984,44 +19041,44 @@
 "(zwischen -PI und PI);to_attr;Attribut des nächsten Features gegeben durch "
 "die Option to_column"
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 "Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte "
 "gespeichert werden."
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr "From_map"
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
 "Spaltenname der nächstgelegenen Feature (verwendet mit upload=to_attr)."
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr ""
 "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' "
 "gesetzt wurde."
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr ""
 "Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
 "Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' "
 "benannt."
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr "Berechne Distanzen zu allen Features innerhalb des Schwellwertes."
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
@@ -19030,105 +19087,110 @@
 "Tabelle geschrieben werden, die von diesem Modul erzeugt wird. Es kann "
 "mehrere 'from' Kategorien geben."
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr "Option to_column fehlt."
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 msgid "Too many column names"
 msgstr "Zu viele Spaltennamen."
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 msgid "Not enough column names"
 msgstr "Nicht ausreichend Spaltennamen."
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, fuzzy, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr "%d von %d Objekten selektiert in der Vektorkarte <%s>."
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr "Spalte <%s> in der Tabelle <%s>nicht gefunden."
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 msgid "Unable to open default database"
 msgstr "Kann die Standard-Datenbank nicht öffnen."
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 msgid "Incompatible column types"
 msgstr "Inkompatible Spaltentypen."
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
 msgstr "Finde nächste Flächen..."
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 msgid "Finding nearest areas..."
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr "Mehr Kategorien gefunden im to_layer (area=%d)"
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr ""
 "Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute "
 "geschrieben."
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr "%d Kategorien mit mehr als einem Feature in der Vektorkarte <%s>."
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, c-format
 msgid "%d categories - no nearest feature found"
 msgstr "%d Kategorien - kein nächstes Feature gefunden."
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr "%d Entfernungen berechnet."
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, c-format
 msgid "%d records inserted"
 msgstr "%d Einträge eingefügt."
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, c-format
 msgid "%d insert errors"
 msgstr "%d 'insert' Fehler."
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, c-format
 msgid "%d categories read from the map"
 msgstr "%d Kategorien aus der Karte gelesen."
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, c-format
 msgid "%d categories exist in the table"
 msgstr "%d Kategorien existieren in der Tabelle"
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, c-format
 msgid "%d categories read from the map exist in the table"
 msgstr ""
 "%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, c-format
 msgid "%d categories read from the map don't exist in the table"
 msgstr "%d aus der Karte gelesene Kategorien existieren nicht in der Tabelle."
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, c-format
 msgid "%d records updated"
 msgstr "%d Einträge aktualisiert."
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, c-format
 msgid "%d update errors"
 msgstr "%d Aktualisier-Fehler."
@@ -19504,7 +19566,7 @@
 msgstr "Kann den Namen des Treibers nicht lesen"
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -19525,7 +19587,7 @@
 msgstr "Alte Hilfstabelle konnte nicht gelöscht werden."
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr "Kann Vektorkarte <%s> nicht im topologischen Modus öffnen"
@@ -19556,15 +19618,14 @@
 msgid "Outlier detection"
 msgstr "Erkennung von Ausreißern"
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
 "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
 "ändern."
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 msgid "Auxiliar table could not be dropped"
@@ -21152,21 +21213,12 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr "Kreuzvalidierung fertig für sie = %f und sin = %f"
-#: ../vector/v.surf.bspline/main.c:273
+#: ../vector/v.surf.bspline/main.c:274
 #, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-"Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die "
-"Interpolation erfolgt mit der <%s> Vektorkarte"
-#: ../vector/v.surf.bspline/main.c:279
-#, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr "Die Vektorkarte <%s> mit wenigen Punkten wird interpoliert."
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
@@ -21175,23 +21227,33 @@
 "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul "
 "erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr "Die Vektorkarte <%s> mit wenigen Punkten wird interpoliert."
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+#: ../vector/v.surf.bspline/main.c:332
 msgid "Cannot read field info"
 msgstr "Kann Feld-Information nicht lesen."
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, c-format
 msgid "[%d] records selected from table"
 msgstr "[%d] Datensätze aus der Tabelle selektiert."
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr ""
 "Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu "
 "erstellen."
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
@@ -21199,11 +21261,18 @@
 "Speicher für Hilfmatrix kann nicht bereitgestellt werden. Erwägen Sie die "
 "Auflösung der Region zu ändern."
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr "Interpolation: (%d,%d): Kein Eintrag für den Punkt (cat = %d)."
+#: ../vector/v.surf.bspline/main.c:712
+#, fuzzy
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
+"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
+"ändern."
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -23651,7 +23720,8 @@
 msgstr "Holen der Fläche %d fehlgeschlagen."
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
+#, fuzzy
+msgid "Area without centroid (OK for island)"
 msgstr "Fläche ohne Zentroid (kann für Inseln OK sein)."
 #: ../vector/v.to.rast/do_areas.c:126
@@ -24822,11 +24892,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr "Layer muss > 0 sein für 'where'."
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr "Gibt grundlegende Informationen einer bestimmten Vektorkarte aus."
@@ -24844,7 +24914,7 @@
 msgid "Print topology information only"
 msgstr "Gebe nur Informationen zur Topologie aus."
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
 msgstr ""
@@ -25453,31 +25523,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr "Schlechte Argumente für anyfunc %s (argc = %d)."
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr "Führe 1-Argumentkartenfunktion auf der Karte <%s> aus."
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr "Führe 2-Argumentekartenfunktion auf den Karten <%s> und <%s> aus."
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, c-format
 msgid "Performing map %s + %s"
 msgstr "Führe Karte <%s> + <%s> aus."
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr "Kann schlechte Kartenfunktion nicht aufrufen."
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr "Schlechte Argumente für mapfunc %s (argc = %d)."
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr "Keine Funktion definiert, um \"Karte %c Karte\" auszuführen."
@@ -25635,43 +25705,44 @@
 msgstr "Gibt alle Verbindungsparameter aus und beendet sich."
 #: ../vector/v.db.connect/main.c:89
-msgid "Print all map connection parameters and exit in shell script style"
+#, fuzzy
+msgid "Print all map connection parameters in shell script style and exit"
 msgstr ""
 "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
 "Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
 "Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und "
 "beendet sich. "
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 msgid "Overwrite connection parameter for certain layer"
 msgstr "Überschreibe die Verbindungsparameter für den angegebenen Layer."
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 msgid "Delete connection for certain layer (not the table)"
 msgstr "Lösche die Verbindung zur Tabelle (nicht aber die Tabelle)."
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 msgid "Please choose only one print style"
 msgstr "Bitte nur einen Druck-Stil auswählen."
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 msgid "Unable to modify vector map stored in other mapset"
 msgstr "Nicht in der Lage Vektorkarte in anderem Mapset zu ändern."
-#: ../vector/v.db.connect/main.c:165
-#, c-format
-msgid "Vector map <%s> is connected by:"
+#: ../vector/v.db.connect/main.c:164
+#, fuzzy, c-format
+msgid "Vector map <%s> is connected by:\n"
 msgstr "Vectorkarte <%s> ist verbunden durch:"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, fuzzy, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
@@ -25679,7 +25750,7 @@
 "Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der "
 "Schlüsselspalte <%s>\n"
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
@@ -25687,19 +25758,19 @@
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr ""
 "Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu "
 "überschreiben."
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr "Die Tabelle <%s> existiert nicht in der Datenbank <%s>."
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
@@ -25708,16 +25779,16 @@
 "Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS "
 "Modulen gelöscht und überschrieben werden."
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, c-format
 msgid "Cannot grant privileges on table %s"
 msgstr "Kann Privilegien für die Tabelle '%s' nicht zuweisen."
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr "Select-Privilegien wurden für die Tabelle gewährt."
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -26126,41 +26197,41 @@
 msgid "Name of Arc cost column"
 msgstr "Name der Spalte"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr "Verschiedenes"
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 #, fuzzy
 msgid "measurement"
 msgstr "Platzierung"
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
 msgstr "Eine oder mehrere Koordinaten"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 #, fuzzy
 msgid "Default: location map units"
 msgstr "Diskretisierfehler in der Karteneinheit."
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
 msgstr "Gebe im Shell-Skript-Style aus."
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 #, fuzzy
 msgid "Length:"
 msgstr "Länge: %f\n"
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 #, fuzzy
 msgid "Area:"
 msgstr "Fläche:\n"
@@ -26213,7 +26284,7 @@
 msgstr "Fehler beim Parsen der Eingabe in der Zeile %d"
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 #, fuzzy
 msgid "visualization"
 msgstr "Histogram Equalization (histogrammbasierte nichtlinearen Streckung)"
@@ -26288,274 +26359,325 @@
 msgid "Loading data failed"
 msgstr "Laden der Daten fehlgeschlagen."
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
 "Vertikale Überhöhung wurde nicht spezifiziert, verwende den berechneten Wert "
 "%.0f."
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
 "Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 msgid "Unsupported output format"
 msgstr "Nicht unterstütztes Dateiformat."
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, c-format
 msgid "File <%s> created."
 msgstr "Datei <%s> erstellt."
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr "Verwende Zeichen-Modus für alle geladenen Oberflächen."
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
 msgstr "Oberfläche"
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
 msgstr "Name der Ausgabedatei (Fügen Sie keine Dateiendung an)."
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 msgid "Image"
 msgstr "Bild"
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 msgid "Graphics file format"
 msgstr "Grafikdateiformat"
-#: ../visualization/nviz2/cmd/args.c:96
-msgid "Width and height of output image"
+#: ../visualization/nviz2/cmd/args.c:104
+#, fuzzy
+msgid "Size (width, height) of output image"
 msgstr "Breite und Höhe des Ausgabe-Bildes."
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 msgid "Name of raster map(s) for elevation"
 msgstr "Name der Rasterkarte(n) mit Höhenwerten"
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 msgid "Elevation value(s)"
 msgstr "Höhenwert(e)"
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 msgid "Name of raster map(s) for color"
 msgstr "Name der Rasterkarte(n) mit Farbwerten"
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 msgid "Color value(s)"
 msgstr "Farbwert(e)"
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 msgid "Name of raster map(s) for mask"
 msgstr "Name der Rasterkarte(n) mit der Maske"
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 msgid "Name of raster map(s) for transparency"
 msgstr "Name der Rasterkarte(n) mit Transparenzwerten"
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr "Transparenz Wert(e)"
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 msgid "Name of raster map(s) for shininess"
 msgstr "Name der Rasterkarte(n) mit Glanzwerten"
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr "Glanz Wert(e)"
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 msgid "Name of raster map(s) for emission"
 msgstr "Name der Rasterkarte(n) für Emissionen."
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 msgid "Emission value(s)"
 msgstr "Emissionswert(e)"
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 msgid "Draw mode"
 msgstr "Zeichen-Modus"
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr "Zeichnen"
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 msgid "Fine resolution"
 msgstr "Feine Auflösung"
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 msgid "Coarse resolution"
 msgstr "Grobe Auflösung"
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 msgid "Draw style"
 msgstr "Zeichenstil"
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr "Shading"
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 msgid "Wire color"
 msgstr "Gitternetzfarbe"
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 msgid "Name of line vector overlay map(s)"
 msgstr "Vektordatei(en) mit Linien zum Überlagern."
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 msgid "Vector lines"
 msgstr "Vektorlinien"
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 msgid "Vector line width"
 msgstr "Linienbreite"
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 msgid "Vector line color"
 msgstr "Linienfarbe"
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 msgid "Vector line display mode"
 msgstr "Anzeigemodus für Vektorlinien."
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
 msgstr "Linienhöhe"
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 msgid "Name of point vector overlay map(s)"
 msgstr "Vektordatei(en) mit Punkten zum Überlagern."
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 msgid "Vector points"
 msgstr "Vektorpunkte"
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 msgid "Icon size"
 msgstr "Symbolgröße"
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 msgid "Icon width"
 msgstr "Symbolbreite"
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 msgid "Icon color"
 msgstr "Symbolfarbe"
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 msgid "Icon marker"
 msgstr "Symbolmarker"
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 msgid "Viewpoint position (x,y model coordinates)"
 msgstr "Position des Blickpunktes (x,y Modelkoordinaten)."
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr "Blickpunkt"
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 msgid "Viewpoint height (in map units)"
 msgstr "Höhe des Betrachters (in Karteneinheiten)."
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr "Sichtfeld des Betrachters (in Grad)."
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 msgid "Viewpoint twist angle (in degrees)"
 msgstr "Drehwinkel des Betrachters (in Grad)."
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 #, fuzzy
 msgid "Volumes"
 msgstr "Volumen"
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
 msgstr "Volumen-Zeichnen-Modus"
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr "Volumen shading"
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 msgid "Volume position"
 msgstr "Volumen Position"
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 msgid "Volume resolution"
 msgstr "Volumen Auflösung"
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 msgid "Isosurface level"
 msgstr "Isoflächen-Level"
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+#, fuzzy
+msgid "Light position (x,y,z model coordinates)"
+msgstr "Position des Blickpunktes (x,y Modelkoordinaten)."
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+#, fuzzy
+msgid "Lighting"
+msgstr "Einstellungen"
+#: ../visualization/nviz2/cmd/args.c:584
+#, fuzzy
+msgid "Light color"
+msgstr "Farbe zum Hervorheben"
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+msgstr "Schreibe Kanten..."
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+#, fuzzy
+msgid "Fringe"
+msgstr "Formatiere"
+#: ../visualization/nviz2/cmd/args.c:625
+#, fuzzy
+msgid "Fringe color"
+msgstr "Linien-Farbe"
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "Zeichne die Höhen nach"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr "Zumindest einer von <%s> oder <%s> ist notwendig."
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d)."
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d."
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr "Inkonsistente Attributanzahl (<%s> %d: <%s> %d)."
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr "Inkonsistente Attributanzahl (<%s> %d: <%s> %d."
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d, <%s> %d."
@@ -26693,130 +26815,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
 msgstr "Kann die Attributtabelle nicht in die Vektorkarte <%s> kopieren."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, c-format
-msgid "Failed in attempt to open %s"
-msgstr "Fehlschlag beim Versuch '%s' zu öffnen."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr ""
-"Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
-"Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition "
-"werden vom Osten gegen den Uhrzeigersinn berechnet."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr "Rasterkarte mit Höheninformationen."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-msgid "Output slope filename"
-msgstr "Ausgabekarte mit Hangneigung."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-msgid "Output aspect filename"
-msgstr "Name der Ausgabe-Expositionskarte."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-msgid "Output profile curvature filename"
-msgstr "Dateiname für Ausgabekarte mit vertikaler Wölbung."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-msgid "Output tangential curvature filename"
-msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr ""
-"Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr ""
-"Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-msgid "Output second order partial derivative dxx filename"
-msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-msgid "Output second order partial derivative dyy filename"
-msgstr "Ausgabekarte der zweiten partiellen Ableitung dyy."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-msgid "Output second order partial derivative dxy filename"
-msgstr "Ausgabekarte der zweiten partiellen Ableitung dxy."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
-"ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, c-format
-msgid "wrong type: %s"
-msgstr "Falscher Typ: %s"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-msgid "Creating support files..."
-msgstr "Erzeuge Supportdateien..."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr "Höhenprodukte für Mapset [%s] in [%s]."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr "EXPOSITION [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr "NEIGUNG [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr "VERTIKALE WÖLBUNG [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr "HORIZONTALE WÖLBUNG [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "O-W NEIGUNG [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr "N-S NEIGUNG [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr "DXX [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr "DYY [%s] KOMPLETT"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr "DXY [%s] KOMPLETT"
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 msgid "Cannot load data from table"
@@ -27107,36 +27105,48 @@
 msgstr "Bitte korrigieren Sie die Einstellungen."
 #: ../db/db.connect/main.c:49
-msgid "Prints/sets general DB connection for current mapset and exits."
+#, fuzzy
+msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
 "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
 "beendet sich."
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 msgid "Print current connection parameters and exit"
 msgstr "Gibt derzeitige Verbindungsparameter aus und beendet sich."
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 msgid "Check connection parameters, set if uninitialized, and exit"
 msgstr ""
 "Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet "
 "sich."
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 #, fuzzy
 msgid "Set"
 msgstr "Subset"
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
+#, fuzzy
+msgid "Set from default settings and exit"
+msgstr "Übernehme von der Standard-Region."
+#: ../db/db.connect/main.c:65
+#, fuzzy
+msgid "Overwrite current settings if initialized"
+msgstr "Überschreibe existierende Maske (MASK)."
+#: ../db/db.connect/main.c:87
 msgid "Default group of database users to which select privilege is granted"
 msgstr "Standardgruppe der Datenbankbenutzer mit 'SELECT'-Privilegien."
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 msgid "Database connection not defined. Run db.connect."
 msgstr "Datenbankverbindung nicht definiert. Führen sie db.connect aus."
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -27147,11 +27157,11 @@
 "Treiber: %s\n"
 "Datenbank: %s"
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr "Standard-Treiber wurde nicht angegeben."
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 msgid "Default database is not set"
 msgstr "Standard-Datenbank ist nicht angegeben."
@@ -27402,7 +27412,7 @@
 msgid "'-' to read from standard input"
 msgstr "Wenn '-' angegeben wird von Standardeingabe gelesen."
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
 msgstr "Ignoriere SQL-Fehler und fahre fort."
@@ -27459,16 +27469,17 @@
 msgid "succeeded"
 msgstr "erfolgreich beendet"
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr "SQL SELECT Befehl"
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr "Beispiel: 'select * from wald where baum = 'Buche'"
-#: ../db/db.select/main.c:215
-msgid "Name of file with sql statement"
+#: ../db/db.select/main.c:201
+#, fuzzy
+msgid "Name of file with SQL select statement(s)"
 msgstr "Name der Datei, die SQL-Befehle enthält"
 #: ../db/db.select/main.c:247
@@ -27678,7 +27689,8 @@
 msgstr "Berechnet eine lineare Regression von zwei Rasterkarten: y = a + b*x"
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+#, fuzzy
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr "Langsamer aber genau (gilt nur für Fließkomma-Karten)."
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:6
@@ -27787,52 +27799,71 @@
 msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#, fuzzy
+msgid "Files & format"
+msgstr "Tabellenformat"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
 msgid "Output coordinate file (omit to send to stdout)"
 msgstr ""
 "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
 "soll)."
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 #, fuzzy
 msgid "Field separator (format: input[,output])"
 msgstr "Trennzeichen (Punkt-Modus)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr "Eingabe-Projektionsparameter (PROJ.4 Stil)."
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#, fuzzy
+msgid "Projections"
+msgstr "Projeziere... "
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Output projection parameters (PROJ.4 style)"
 msgstr "Ausgabe-Projektionsparameter (PROJ.4 Stil)."
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr ""
 "Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-"
 "Projektion."
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr "Verwende LL WGS84 als Eingabe-Projektion und Ausgabe-Projektion."
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+#, fuzzy
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
 "Gebe long/lat in Dezimalgrad oder einer anderen Projektion mit vielen "
 "Dezimalstellen aus."
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
 msgstr "Spaltenummer der Y-Koordinate in der Eingabedatei."
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "In der Ausgabe kein Spaltennamen ausgeben."
@@ -28092,6 +28123,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr "Zeigt die vorhandenen Regelsätze und Schluß."
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 msgid "Prints a graph of the correlation between data layers (in pairs)."
 msgstr "Gibt eine Graphik der Korrelation zweier Karten (paarweise) aus."
@@ -28392,13 +28427,6 @@
 msgid "Raster map to use as mask"
 msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Create"
-msgstr "Erzeugung"
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 #, fuzzy
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
@@ -28601,6 +28629,7 @@
 msgstr "GpsBabel unterstütze Ausgabeformate. "
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -28616,7 +28645,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
@@ -28951,19 +28980,24 @@
 "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-msgid "Vector map for which to edit attribute table"
+#, fuzzy
+msgid "Name of vector map for which to edit attribute table"
 msgstr "Vektorkarte deren Attributtabelle editiert werden soll."
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Layer where to add column"
+#, fuzzy
+msgid "Layer number where to add column(s)"
 msgstr "Layer, in dem eine Spalte hinzugefügt werden soll."
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 #, fuzzy
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, "
 "aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
@@ -29107,7 +29141,8 @@
 msgstr "Erfordert den Schalter 'Liste verfügbare Layer'."
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+#, fuzzy
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr "Bestimme Farbregeln basierend auf den Standardabweichungen."
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -29496,19 +29531,24 @@
 msgstr "Mehr statistische Kennzahlen (Quartile und 90% Perzentil)."
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+#, fuzzy
+msgid "Print stats in shell script style"
+msgstr "Gebe die Statistik im Shell-Skript-Stil aus."
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
 msgid "Name of data table"
 msgstr "Name der Datentabelle"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr ""
 "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 msgid "Database/directory for table"
 msgstr "Datenbank/Verzeichnis welches die Tabelle enthält."
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 msgid "Database driver"
 msgstr "Datenbanktreiber"
@@ -29579,6 +29619,11 @@
 msgid "Signature file <%s> is invalid"
 msgstr "Signaturdatei <%s> ist ungültig."
+#: ../imagery/i.smap/read_sig.c:30
+#, c-format
+msgid "Signature file <%s> is empty"
+msgstr "Signaturdatei <%s> ist leer."
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 msgid "Name of file containing signatures"
 msgstr "Name der Datei mit den Signaturen."
@@ -30141,12 +30186,12 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr "Gruppe <%s> enthält keine Dateien; führen Sie i.group aus."
-#: ../imagery/i.rectify/main.c:202
+#: ../imagery/i.rectify/main.c:204
 #, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr "Verwende die Region: N=%f S=%f, O=%f W=%f"
-#: ../imagery/i.rectify/main.c:216
+#: ../imagery/i.rectify/main.c:218
 #, c-format
 msgid ""
 "Input raster map <%s> does not exist in group <%s>.\n"
@@ -30155,7 +30200,7 @@
 "Eingabe-Rasterkarte <%s> existiert nicht in der Gruppe <%s>.\n"
 " Versuche:\n"
-#: ../imagery/i.rectify/main.c:222
+#: ../imagery/i.rectify/main.c:224
 msgid "Exit!"
 msgstr "Ende!"
@@ -30243,7 +30288,7 @@
 msgid "Error while writing to temp file"
 msgstr "Fehler beim Schreiben in die temp-Datei."
-#: ../imagery/i.rectify/write.c:54
+#: ../imagery/i.rectify/write.c:55
 #, c-format
 msgid "Error writing row %d"
 msgstr "Fehler beim Schreiben der Zeile %d."
@@ -30255,13 +30300,13 @@
 "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> "
 "gespeichert."
-#: ../imagery/i.rectify/rectify.c:91
+#: ../imagery/i.rectify/rectify.c:90
 #, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
 msgstr ""
 "Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
-#: ../imagery/i.rectify/rectify.c:97
+#: ../imagery/i.rectify/rectify.c:96
 #, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
 msgstr "Rasterkarte <%s@%s>: Zone passt nicht zu den aktuellen Einstellungen."
@@ -30756,7 +30801,7 @@
 msgid "Name of input raster map (image fft, imaginary part"
 msgstr "Name der Eingabe-Rasterkarte (fft Bild, imaginärer Teil)."
-#: ../imagery/i.ifft/main.c:119
+#: ../imagery/i.ifft/main.c:115
 msgid "The real and imaginary original windows did not match"
 msgstr "Die originalen real und imaginär Fenster stimmen nicht überein."
@@ -31846,71 +31891,228 @@
 msgstr ""
 "Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
-"und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+#~ msgid "Not enough room in history file"
+#~ msgstr "Nicht genug Platz in der History-Datei."
+#~ msgid ""
+#~ "The given nodata value is present in rasterband <%s> and would lead to "
+#~ "data loss. Please specify a different nodata value with the %s parameter."
+#~ msgstr ""
+#~ "Der gewählte NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
+#~ "Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
+#~ "Parameter %s an."
+#~ msgid "New MAPSET name"
+#~ msgstr "Neuer Mapset Name."
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "Ihr Mapset Suchpfad:\n"
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "<%s> nicht in der Mapset-Liste gefunden."
+#~ msgid "** no mapsets **\n"
+#~ msgstr "** keine Mapsets **\n"
+#~ msgid "Name of workspace file"
+#~ msgstr "Name der Workspace-Datei."
 #, fuzzy
-msgid "Raster file to be converted."
-msgstr "Zu importierende Rasterdatei."
+#~ msgid "Displays raster map layer in the active map display window."
+#~ msgstr ""
+#~ "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
+#~ "möglich."
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr "Liste der Werte die angezeigt werden sollen (FP-Karten)."
+#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
+#~ msgstr ""
+#~ "Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen "
+#~ "Sie 'val=')."
+#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
+#~ msgstr ""
+#~ "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie "
+#~ "'cat=')."
+#~ msgid "Area size [%.1e], area not imported"
+#~ msgstr "Flächengröße [%.1e], Fläche nicht importiert."
+#~ msgid "Island size [%.1e], island not imported"
+#~ msgstr "Inselgröße [%.1e], Insel nicht importiert."
+#~ msgid ""
+#~ "No vector map of sparse points to interpolate was specified. "
+#~ "Interpolation will be done with <%s> vector map"
+#~ msgstr ""
+#~ "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die "
+#~ "Interpolation erfolgt mit der <%s> Vektorkarte"
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "Fehlschlag beim Versuch '%s' zu öffnen."
+#~ msgid ""
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr ""
+#~ "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
+#~ "Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition "
+#~ "werden vom Osten gegen den Uhrzeigersinn berechnet."
+#~ msgid "Raster elevation file name"
+#~ msgstr "Rasterkarte mit Höheninformationen."
+#~ msgid "Output slope filename"
+#~ msgstr "Ausgabekarte mit Hangneigung."
+#~ msgid "Output aspect filename"
+#~ msgstr "Name der Ausgabe-Expositionskarte."
+#~ msgid "Output profile curvature filename"
+#~ msgstr "Dateiname für Ausgabekarte mit vertikaler Wölbung."
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr ""
+#~ "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#~ msgstr ""
+#~ "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
+#~ msgid "Output second order partial derivative dxx filename"
+#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
+#~ msgid "Output second order partial derivative dyy filename"
+#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dyy."
+#~ msgid "Output second order partial derivative dxy filename"
+#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxy."
+#~ msgid ""
+#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
+#~ "quiet' instead."
+#~ msgstr ""
+#~ "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
+#~ "ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid "wrong type: %s"
+#~ msgstr "Falscher Typ: %s"
+#~ msgid "Creating support files..."
+#~ msgstr "Erzeuge Supportdateien..."
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "Höhenprodukte für Mapset [%s] in [%s]."
+#~ msgid "ASPECT [%s] COMPLETE"
+#~ msgstr "EXPOSITION [%s] KOMPLETT"
+#~ msgid "SLOPE [%s] COMPLETE"
+#~ msgstr "NEIGUNG [%s] KOMPLETT"
+#~ msgid "PROFILE CURVE [%s] COMPLETE"
+#~ msgstr "VERTIKALE WÖLBUNG [%s] KOMPLETT"
+#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
+#~ msgstr "HORIZONTALE WÖLBUNG [%s] KOMPLETT"
+#~ msgid "E-W SLOPE [%s] COMPLETE"
+#~ msgstr "O-W NEIGUNG [%s] KOMPLETT"
+#~ msgid "N-S SLOPE [%s] COMPLETE"
+#~ msgstr "N-S NEIGUNG [%s] KOMPLETT"
+#~ msgid "DXX [%s] COMPLETE"
+#~ msgstr "DXX [%s] KOMPLETT"
+#~ msgid "DYY [%s] COMPLETE"
+#~ msgstr "DYY [%s] KOMPLETT"
+#~ msgid "DXY [%s] COMPLETE"
+#~ msgstr "DXY [%s] KOMPLETT"
 #, fuzzy
-msgid "File containing reclass rules; \"-\" to read from stdin"
-msgstr ""
-"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+#~ msgid ""
+#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
+#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
+#~ "PRECISION and DATE)"
+#~ msgstr ""
+#~ "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank "
+#~ "ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
+#~ "und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
 #, fuzzy
-msgid "terrain analysis"
-msgstr "Raster, Geländeanalyse"
+#~ msgid "Raster file to be converted."
+#~ msgstr "Zu importierende Rasterdatei."
 #, fuzzy
-msgid "Unable to open vector map <%s> on level 2"
-msgstr "Kann die Vektorkarte <%s> auf dem Topologischen Level %d nicht öffnen."
+#~ msgid "File containing reclass rules; \"-\" to read from stdin"
+#~ msgstr ""
+#~ "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu "
+#~ "lesen)."
 #, fuzzy
-msgid "Open vector map without topology (level 1)"
+#~ msgid "terrain analysis"
+#~ msgstr "Raster, Geländeanalyse"
 #, fuzzy
-msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
-msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
+#~ msgid "Unable to open vector map <%s> on level 2"
+#~ msgstr ""
+#~ "Kann die Vektorkarte <%s> auf dem Topologischen Level %d nicht öffnen."
-msgid "Do not export long colortable"
-msgstr "Exportiere keine langen Farbtabellen."
+#, fuzzy
+#~ msgid "Open vector map without topology (level 1)"
+#~ msgstr ""
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d was "
-"used to represent no-data values in the input map. You can specify nodata "
-"value by %s parameter."
-msgstr ""
-"Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
-"%d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie "
-"können Nodata-Wert mit dem Parameter %s bestimmen."
+#, fuzzy
+#~ msgid "miles,feet,meters,kilometers,acres,hectares,radians,degrees"
+#~ msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
-msgid ""
-"Sorry, if any of the following options are set:\n"
-"    basin, stream, half.basin, slope, or lS\n"
-"    you MUST provide a value for the basin threshold parameter."
-msgstr ""
-"Wenn eine der folgenden Optionen gesetzt wurde:\n"
-"    basin, stream, half.basin, slope oder lS\n"
-"    MÜSSEN Sie ein Wert für den Parameter 'basin threshold' angegeben."
+#~ msgid "Do not export long colortable"
+#~ msgstr "Exportiere keine langen Farbtabellen."
-msgid "Writes Z data to column instead of 3D vector"
-msgstr "Schreibt Z Werte in eine Spalte anstelle der 3D Vektorkarte."
+#~ msgid ""
+#~ "Input raster map contains cells with NULL-value (no-data). The value %d "
+#~ "was used to represent no-data values in the input map. You can specify "
+#~ "nodata value by %s parameter."
+#~ msgstr ""
+#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
+#~ "Wert %d wurde verwendet um Nodata-Werte in der Eingabekarte zu "
+#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
-msgid "Convex hull calculation requires at least three points"
-msgstr "Die Berechnung der konvexen Hülle erfordert zumindest drei Punkte."
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ "    basin, stream, half.basin, slope, or lS\n"
+#~ "    you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "Wenn eine der folgenden Optionen gesetzt wurde:\n"
+#~ "    basin, stream, half.basin, slope oder lS\n"
+#~ "    MÜSSEN Sie ein Wert für den Parameter 'basin threshold' angegeben."
-msgid "enable MFD flow (default is SFD (D8))"
-msgstr "Aktiviere MFD-Fluss (Standard ist SFD (D8))."
+#~ msgid "Writes Z data to column instead of 3D vector"
+#~ msgstr "Schreibt Z Werte in eine Spalte anstelle der 3D Vektorkarte."
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr "Importiert Mapgen oder Matlab Vektorkarten nach GRASS."
+#~ msgid "Convex hull calculation requires at least three points"
+#~ msgstr "Die Berechnung der konvexen Hülle erfordert zumindest drei Punkte."
+#~ msgid "enable MFD flow (default is SFD (D8))"
+#~ msgstr "Aktiviere MFD-Fluss (Standard ist SFD (D8))."
+#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
+#~ msgstr "Importiert Mapgen oder Matlab Vektorkarten nach GRASS."
 #~ msgid "Sources and sinks in [m^3/s]"
 #~ msgstr "Quellen und Senken in [m^3/s]"
@@ -36891,20 +37093,6 @@
 #~ "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als "
 #~ "echte Hindernis aufgefasst."
-#~ msgid ""
-#~ "The user given nodata value %g is present in rasterband <%s> and would "
-#~ "lead to data loss. Please specify a different nodata value with the %s "
-#~ "parameter."
-#~ msgstr ""
-#~ "Der gewählte NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
-#~ "Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
-#~ "Parameter %s an."
-#~ msgid "UNIX filesystem access controls are not supported by MS-Windows"
-#~ msgstr ""
-#~ "Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht "
-#~ "unterstützt."
 #~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
 #~ msgstr ""
 #~ "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu "
@@ -36925,6 +37113,3 @@
 #~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
 #~ msgstr "Importiert Mapgen oder Matlab-ASCII Vektorkarten nach GRASS."
-#~ msgid "Signature file <%s> is empty"
-#~ msgstr "Signaturdatei <%s> ist leer."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_el.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_el\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2009-02-19 10:29+0200\n"
 "Last-Translator: Vasilios Antoniou <vantoniou at gmail.com>\n"
 "Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -20,7 +20,7 @@
 "X-Generator: KBabel 1.11.4\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 msgid "Error closing 3d raster map"
@@ -62,7 +62,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "ñÜóôåñ 3Ä, voxel"
@@ -82,7 +82,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -171,7 +171,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -186,39 +185,39 @@
 msgid "Error opening grid3 file [%s]"
 msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ áñ÷åßïõ grid3 [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 msgid "Cannot allocate memory for string"
 msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, c-format
 msgid "Error reading range for [%s]"
 msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 msgid "Error while reading history file"
 msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ áñ÷åßïõ éóôïñéêïý"
@@ -253,7 +252,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -279,7 +278,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "ÓöÜëìá êáôÜ ôï êëåßóåéìï 3Ä ñÜóôåñ ÷Üñôç"
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 msgid "Error closing ascii file"
 msgstr "ÓöÜëìá êáôÜ ôï êëåßóïìï ascii áñ÷åßïõ"
@@ -1078,7 +1077,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1093,7 +1092,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1126,17 +1125,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1188,7 +1186,7 @@
 msgstr ""
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 msgid "List supported formats and exit"
 msgstr ""
@@ -1201,22 +1199,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1263,7 +1261,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 msgid "Name of input raster map"
@@ -1548,12 +1545,27 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr ""
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
+#, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "ËÜèïò óõíôåôáãìÝíåò"
+#: ../raster/r.in.poly/get_item.c:81
 #, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
+#, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr ""
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 msgid "Writing raster map..."
 msgstr ""
@@ -1571,12 +1583,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1606,7 +1618,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1616,7 +1628,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1685,13 +1697,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1707,7 +1719,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1717,8 +1729,8 @@
 msgid "Unable to open database <%s> by driver <%s>"
 msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1729,7 +1741,7 @@
 msgid "Unable to create table: '%s'"
 msgstr ""
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1739,8 +1751,8 @@
 msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2017,7 +2029,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, c-format
@@ -2095,10 +2107,10 @@
 msgid "Output world file"
 msgstr "ÅîáãùãÞ ïíüìáôïò ðßíáêá"
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, c-format
 msgid "[%s]: No such color"
 msgstr "[%s]: Äåí õðÜñ÷åé ôÝôïéï ÷ñþìá"
@@ -2118,11 +2130,11 @@
 msgid "Writing world file"
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 msgid "Got null file name"
 msgstr ""
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr ""
@@ -2285,7 +2297,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2406,8 +2418,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 msgid "Required"
 msgstr ""
@@ -2427,7 +2439,7 @@
 msgid "Metadata"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 msgid "Name for new location to create"
 msgstr ""
@@ -2436,7 +2448,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 msgid "Extend location extents based on new dataset"
 msgstr ""
@@ -2476,7 +2488,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2518,13 +2530,13 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, c-format
 msgid "Location <%s> created"
 msgstr ""
@@ -2536,12 +2548,12 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 msgid "Over-riding projection check"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -2556,7 +2568,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr ""
@@ -2574,7 +2586,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 msgid "Projection of input dataset and current location appear to match"
 msgstr ""
@@ -2693,30 +2705,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr ""
@@ -2900,12 +2909,14 @@
 #: ../raster/r.resamp.bspline/main.c:92
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:100
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -2946,7 +2957,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -2954,7 +2965,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -2982,7 +2993,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3000,7 +3011,7 @@
 msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3012,7 +3023,7 @@
 msgid "No data within this subregion. Consider increasing the spline step."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 #, fuzzy
 msgid "Writing output..."
 msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
@@ -3216,7 +3227,7 @@
 msgstr ""
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 msgid "metadata"
 msgstr ""
@@ -3281,7 +3292,7 @@
 msgid "Raster map <%s> not found in current mapset"
 msgstr ""
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3292,37 +3303,33 @@
 msgid "Unable to open input file <%s>"
 msgstr ""
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-msgid "Not enough room in history file"
-msgstr ""
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, c-format
 msgid "cats table for [%s] set to %s"
 msgstr ""
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr ""
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, c-format
 msgid "Writing new null file for [%s]... "
 msgstr ""
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr ""
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 msgid "Done."
 msgstr ""
@@ -4266,12 +4273,10 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 msgid "Format for reporting the slope"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 #, fuzzy
 msgid "Type of output aspect and slope maps"
 msgstr "Ôýðïò"
@@ -4307,17 +4312,14 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 msgid "Do not align the current region to the elevation layer"
 msgstr ""
@@ -4359,58 +4361,56 @@
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, c-format
 msgid "Aspect raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, c-format
 msgid "Slope raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, c-format
 msgid "Tangential curve raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, c-format
 msgid "E-W slope raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, c-format
 msgid "N-S slope raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, c-format
 msgid "Dyy raster map <%s> complete"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, c-format
 msgid "Dxy raster map <%s> complete"
 msgstr ""
@@ -4492,7 +4492,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -4671,7 +4671,6 @@
 msgstr ""
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr ""
@@ -5144,64 +5143,64 @@
 msgid "Filter <%s> not found"
 msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 msgid "resample"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 msgid "Filter radius (horizontal)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, c-format
 msgid "Too many filters (max: %d)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, c-format
 msgid "Unable to read color table for %s"
 msgstr ""
@@ -5756,7 +5755,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr ""
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, c-format
 msgid "Unknown method <%s>"
 msgstr ""
@@ -5775,7 +5774,7 @@
 msgid "Aggregate operation"
 msgstr ""
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 msgid "Quantile to calculate for method=quantile"
 msgstr ""
@@ -7573,6 +7572,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr ""
@@ -7913,55 +7913,55 @@
 msgid "Pass %d..."
 msgstr ""
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "ÅîáãùãÞ ôïõ GRASS 3Ä ñÜóôåñ ÷Üñôç óå 3 äéÜóôáôï Vis5D áñ÷åßï"
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 msgid "Name for new TIFF file"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr ""
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 msgid "Output TIFF world file"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 msgid "Output Tiled TIFF"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
 "to integer"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 #, fuzzy
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
 msgstr "×ñþìá"
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, c-format
 msgid "Unable to open TIFF file <%s>"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 msgid "Writing TIFF World file"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 msgid "Unable to open TIFF world file for writing"
 msgstr ""
@@ -8068,7 +8068,7 @@
 msgstr "×Üñôçò åðáíáöüñôéóçò óå  m^3/s"
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -8076,21 +8076,21 @@
 "[%s]"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
@@ -8099,16 +8099,16 @@
 msgid "Writing to map ..."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, c-format
 msgid "%lu points found in region."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 msgid "Scanning data ..."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr ""
@@ -8605,66 +8605,66 @@
 msgid "unable to open <%s> mask ... continuing without!"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 msgid "Cannot create random access file"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
 msgstr "Äåí ìðïñþ íá äù ëßóôá ôùí ðéíÜêùí:\n"
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 msgid "Cannot read setup file"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
 msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 msgid "Irregular maskedoverlay areas definition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 msgid "Illegal configuration file (sample area)"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 msgid "Too many units to place"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 msgid "Too many strats for raster map"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 msgid "Cannot make lseek"
 msgstr ""
@@ -8976,8 +8976,8 @@
 #: ../raster/r.out.gdal/export_band.c:201
 #, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:241
@@ -9149,7 +9149,7 @@
 msgid "Name of color file"
 msgstr ""
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 msgid "Vertical exaggeration"
 msgstr ""
@@ -9201,15 +9201,19 @@
 msgid "File containing expression(s) to evaluate"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:145
+msgid "file= and expression= are mutually exclusive"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:155
 msgid "parse error"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr ""
@@ -9505,8 +9509,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 msgid "Position"
 msgstr ""
@@ -10079,8 +10083,8 @@
 msgstr ""
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 msgid "Attributes"
 msgstr ""
@@ -10124,7 +10128,7 @@
 msgstr ""
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr ""
@@ -10507,19 +10511,19 @@
 "or 'latin' option!"
 msgstr ""
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -10535,7 +10539,7 @@
 msgid "Error in pj_do_proj"
 msgstr ""
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
@@ -10910,7 +10914,7 @@
 msgid "Raster map(s) to report on"
 msgstr ""
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr ""
@@ -10946,7 +10950,6 @@
 msgstr ""
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 msgid "Quiet"
 msgstr ""
@@ -11412,13 +11415,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr ""
@@ -11619,15 +11615,15 @@
 msgid "Writing topographic index map..."
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 msgid "Aggregation method"
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 msgid "Weight according to area (slower)"
 msgstr ""
@@ -12024,13 +12020,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -12066,14 +12062,64 @@
 msgid "Access for others"
 msgstr ""
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr ""
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 msgid "Unable to determine mapset permissions"
 msgstr ""
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+msgid "read "
+msgstr ""
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 msgid "Error reading WKT projection description"
 msgstr ""
@@ -12693,44 +12739,44 @@
 msgid "Error conducting transform (%d)"
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr ""
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr ""
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 msgid "Parameter error"
 msgstr ""
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 msgid "No active control points"
 msgstr ""
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 msgid "transformation"
 msgstr ""
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 msgid "Computes a coordinate transformation based on the control points."
 msgstr ""
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 msgid "Rectification polynomial order"
 msgstr ""
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -12738,32 +12784,32 @@
 "difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 msgid "Output format"
 msgstr ""
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 msgid "Display summary information"
 msgstr ""
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr "¼íïìá åéóáãþìåíïõ äéáíõóìáôéêïý ÷Üñôç "
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 msgid "Local x,y coordinates to target east,north"
 msgstr ""
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr ""
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 msgid "Target east,north coordinates to local x,y"
 msgstr ""
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 msgid "Display transform matrix coefficients"
 msgstr ""
@@ -12775,86 +12821,89 @@
 msgid "Change current mapset."
 msgstr ""
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
 msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "×ñþìá"
+#: ../general/g.mapset/main.c:63
+msgid "Location name (not location path)"
 msgstr ""
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr ""
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 msgid "Create mapset if it doesn't exist"
 msgstr ""
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
+msgid "Create"
+msgstr ""
+#: ../general/g.mapset/main.c:86
 msgid "List available mapsets"
 msgstr ""
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 msgid "Either mapset= or -l must be used"
 msgstr ""
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, c-format
 msgid "<%s> is already the current mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 msgid "You don't have permission to use this mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr ""
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr ""
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
 "checked"
 msgstr ""
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 msgid "Cleaning up temporary files..."
 msgstr ""
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 msgid "Your shell continues to use the history for the old mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
 msgstr ""
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
 msgstr ""
-#: ../general/g.mapsets/dsply_path.c:19
-#, c-format
-msgid "Your mapset search list:\n"
-msgstr ""
-#: ../general/g.mapsets/dsply_path.c:29
-#, c-format
-msgid "<%s> not found in mapset list"
-msgstr ""
 #: ../general/g.mapsets/main.c:62
 msgid ""
 "Modifies the user's current mapset search path, affecting the user's access "
@@ -12904,14 +12953,12 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr ""
-#: ../general/g.mapsets/dsply_maps.c:23
-#, c-format
+#: ../general/g.mapsets/list.c:10
 msgid "Available mapsets:"
 msgstr ""
-#: ../general/g.mapsets/dsply_maps.c:33
-#, c-format
-msgid "** no mapsets **\n"
+#: ../general/g.mapsets/list.c:35
+msgid "Accessible mapsets:"
 msgstr ""
 #: ../general/g.copy/main.c:43
@@ -13423,40 +13470,40 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ <%s> ãéá åããñáöÞ"
@@ -13479,11 +13526,11 @@
 msgstr "ÐñïåðéëïãÞ"
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-msgid "Name of workspace file"
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
 msgstr ""
 #: ../general/g.gui/main.c:57
@@ -13499,6 +13546,11 @@
 msgid "<%s> is now the default GUI"
 msgstr ""
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 msgid "Force remove"
 msgstr ""
@@ -13536,7 +13588,7 @@
 msgid "Unable to read FP range for %s"
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -13551,7 +13603,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -13579,7 +13631,7 @@
 msgid "At least two points are required"
 msgstr "Ôýðùìá ôçò äïìÞ ôïõ ðßíáêá"
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -13592,7 +13644,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -13600,43 +13652,43 @@
 msgid "No graphics device selected"
 msgstr ""
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
 msgstr ""
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 msgid "Choose new current font"
 msgstr ""
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 msgid "Path to Freetype-compatible font including file name"
 msgstr ""
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr ""
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 msgid "List fonts"
 msgstr ""
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 msgid "List fonts verbosely"
 msgstr ""
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, c-format
 msgid "Unable to access font path %s: %s"
 msgstr ""
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, c-format
 msgid "Font path %s is not a file"
 msgstr ""
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -14084,6 +14136,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 msgid "Name of raster map"
 msgstr ""
@@ -14255,8 +14308,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -14477,33 +14530,33 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 msgid "Selection"
 msgstr ""
@@ -14543,15 +14596,15 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, c-format
 msgid "Database connection not defined"
 msgstr ""
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -15280,41 +15333,46 @@
 msgid "Error: %s\n"
 msgstr ""
-#: ../display/d.rast/main.c:55
-msgid "Displays raster map layer in the active map display window."
-msgstr ""
+#: ../display/d.rast/main.c:54
+#, fuzzy
+msgid "Displays raster map layer."
+msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 msgid "Raster map to be displayed"
 msgstr ""
-#: ../display/d.rast/main.c:67
-msgid "List of categories to be displayed (INT maps)"
-msgstr ""
+#: ../display/d.rast/main.c:66
+#, fuzzy
+msgid "List of categories or values to be displayed"
+msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
-#: ../display/d.rast/main.c:76
-msgid "List of values to be displayed (FP maps)"
-msgstr ""
-#: ../display/d.rast/main.c:85
+#: ../display/d.rast/main.c:72
 msgid "Background color (for null)"
 msgstr ""
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+#, fuzzy
+msgid "Either a standard color name or R:G:B triplet"
+msgstr "Åßôå Ýíá óôáíôáñ üíïìá ÷ñþìáôïò Þ óõíäõáóìüò R:G:B"
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
+#: ../display/d.rast/main.c:81
+msgid "Invert value list"
 msgstr ""
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr ""
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
 #: ../display/d.rast.num/main.c:73
 msgid ""
@@ -15638,11 +15696,6 @@
 msgid "Label color"
 msgstr ""
-#: ../display/d.vect/main.c:263
-#, fuzzy
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "Åßôå Ýíá óôáíôáñ üíïìá ÷ñþìáôïò Þ óõíäõáóìüò R:G:B"
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr ""
@@ -15894,7 +15947,7 @@
 msgstr ""
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -15915,7 +15968,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
 msgstr ""
@@ -15933,7 +15986,7 @@
 msgstr ""
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -15946,7 +15999,7 @@
 msgstr ""
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -15974,7 +16027,7 @@
 msgstr "ÂÜóç äåäïìÝíùí, SQL"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -16040,7 +16093,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -16280,7 +16333,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, c-format
@@ -16409,10 +16462,8 @@
 msgstr "Íïýìåñï åðéðÝäïõ"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 msgid "Query"
 msgstr ""
@@ -16761,295 +16812,300 @@
 msgid "Unable to build topology for <%s>"
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 msgid "OGR datasource name"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: directory containing shapefiles\n"
 "\t\tMapInfo File: directory containing mapinfo files"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: shapefile name\n"
 "\t\tMapInfo File: mapinfo file name"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 msgid "Import subregion only"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 msgid "Subregion"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 msgid "Optionally change default input type"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
 "boundary;import lines as area boundaries;centroid;import points as centroids"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 msgid "Snapping threshold for boundaries"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 msgid "List available layers in data source and exit"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 msgid "Do not clean polygons (not recommended)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 msgid "Create 3D output"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 msgid "Do not create attribute table"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 msgid "Override dataset projection (use location's projection)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 msgid "Limit import to the current region"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, c-format
 msgid "Unable to open data source <%s>"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr ""
 "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, c-format
 msgid "Vector map <%s> already exists"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, c-format
 msgid "Layer <%s> not available"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 msgid "4 parameters required for 'spatial' parameter"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, c-format
 msgid ""
 "\n"
 "You can use the -o flag to %s to override this projection check.\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
 "set.\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ grid. Äßóêïò ãåìÜôïò;"
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, c-format
 msgid "Layer: %s"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
 "be truncated!"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, c-format
 msgid "Column type not supported (%s)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
+#, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "ÅããñáöÞ %s áðü %s..."
+#: ../vector/v.in.ogr/main.c:854
 #, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 msgid "Break polygons:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 msgid "Remove duplicates:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 msgid "Merge boundaries:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, c-format
 msgid "Find centroids for layer: %s"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 msgid "Write centroids:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -17057,90 +17113,85 @@
 "The number of features for those areas is stored as category in layer %d"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, c-format
 msgid "%d input polygons\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, c-format
 msgid "%d input polygons"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, c-format
 msgid "Total area: %G (%d areas)\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, c-format
 msgid "Total area: %G (%d areas)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, c-format
 msgid "Overlapping area: %G (%d areas)\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, c-format
 msgid "Overlapping area: %G (%d areas)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, c-format
 msgid "Area without category: %G (%d areas)\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, c-format
 msgid "Area without category: %G (%d areas)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
 "import 3D vector"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 msgid "Cannot calculate centroid"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 msgid "Cannot write part of geometry"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 msgid "Unknown geometry type"
 msgstr ""
@@ -17308,6 +17359,9 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 msgid "Connection"
 msgstr ""
@@ -17338,12 +17392,12 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, c-format
 msgid "Missing column <%s> in table <%s>"
 msgstr ""
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 msgid "Data type of key column must be integer"
 msgstr ""
@@ -17545,8 +17599,8 @@
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 msgid "From"
 msgstr ""
@@ -17565,8 +17619,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 msgid "To"
 msgstr ""
@@ -17592,57 +17646,57 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr ""
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
 msgstr ""
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 #, fuzzy
 msgid "Name of existing vector map (from)"
 msgstr "¼íïìá õðÜñ÷ïíôùò 3Ä ñÜóôåñ ÷Üñôç"
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 msgid "Feature type (from)"
 msgstr ""
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 #, fuzzy
 msgid "Name of existing vector map (to)"
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 msgid "Feature type (to)"
 msgstr ""
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 msgid "Maximum distance or -1 for no limit"
 msgstr ""
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 msgid "Minimum distance or -1 for no limit"
 msgstr ""
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr ""
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
 "to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
@@ -17654,137 +17708,142 @@
 "attribute of nearest feature given by to_column option"
 msgstr ""
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr ""
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr ""
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr ""
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr ""
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
 msgstr ""
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr ""
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 msgid "Too many column names"
 msgstr ""
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 msgid "Not enough column names"
 msgstr ""
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr ""
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr ""
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 msgid "Unable to open default database"
 msgstr ""
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 msgid "Incompatible column types"
 msgstr ""
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 msgid "Finding nearest areas..."
 msgstr ""
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr ""
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr ""
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, c-format
 msgid "%d categories - no nearest feature found"
 msgstr ""
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr ""
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, c-format
 msgid "%d records inserted"
 msgstr ""
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, c-format
 msgid "%d insert errors"
 msgstr ""
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, c-format
 msgid "%d categories read from the map"
 msgstr ""
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, c-format
 msgid "%d categories exist in the table"
 msgstr ""
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, c-format
 msgid "%d categories read from the map exist in the table"
 msgstr ""
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, c-format
 msgid "%d categories read from the map don't exist in the table"
 msgstr ""
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, c-format
 msgid "%d records updated"
 msgstr ""
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, c-format
 msgid "%d update errors"
 msgstr ""
@@ -18133,7 +18192,7 @@
 msgstr ""
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -18152,7 +18211,7 @@
 msgstr ""
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr ""
@@ -18183,13 +18242,12 @@
 msgid "Outlier detection"
 msgstr ""
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 msgid "Auxiliar table could not be dropped"
@@ -19627,51 +19685,60 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:273
-#, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:279
+#: ../vector/v.surf.bspline/main.c:274
 #, fuzzy, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
 "a raster output or other driver."
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr ""
+"Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:332
 msgid "Cannot read field info"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, c-format
 msgid "[%d] records selected from table"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr ""
+#: ../vector/v.surf.bspline/main.c:712
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -21954,7 +22021,7 @@
 msgstr ""
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
+msgid "Area without centroid (OK for island)"
 msgstr ""
 #: ../vector/v.to.rast/do_areas.c:126
@@ -22994,11 +23061,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr ""
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
@@ -23015,7 +23082,7 @@
 msgid "Print topology information only"
 msgstr ""
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
 msgstr ""
@@ -23558,31 +23625,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, c-format
 msgid "Performing map %s + %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr ""
@@ -23728,77 +23795,78 @@
 msgstr ""
 #: ../vector/v.db.connect/main.c:89
-msgid "Print all map connection parameters and exit in shell script style"
-msgstr ""
+#, fuzzy
+msgid "Print all map connection parameters in shell script style and exit"
+msgstr "Åêôõðþíåé ôéò ôñÝ÷ïõóåò ðáñáìÝôñïõò óýíäåóçò êáé êëåßíåé"
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 msgid "Overwrite connection parameter for certain layer"
 msgstr ""
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 msgid "Delete connection for certain layer (not the table)"
 msgstr ""
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 msgid "Please choose only one print style"
 msgstr ""
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 msgid "Unable to modify vector map stored in other mapset"
 msgstr ""
-#: ../vector/v.db.connect/main.c:165
-#, c-format
-msgid "Vector map <%s> is connected by:"
-msgstr ""
+#: ../vector/v.db.connect/main.c:164
+#, fuzzy, c-format
+msgid "Vector map <%s> is connected by:\n"
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr ""
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr ""
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
 "overwritten by GRASS modules"
 msgstr ""
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, c-format
 msgid "Cannot grant privileges on table %s"
 msgstr ""
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr ""
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -24173,37 +24241,37 @@
 msgid "Name of Arc cost column"
 msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr ""
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 msgid "measurement"
 msgstr ""
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
 msgstr "ËÜèïò óõíôåôáãìÝíåò"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 msgid "Default: location map units"
 msgstr ""
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 msgid "Shell script style"
 msgstr ""
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 msgid "Length:"
 msgstr ""
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 msgid "Area:"
 msgstr ""
@@ -24253,7 +24321,7 @@
 msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 msgid "visualization"
 msgstr ""
@@ -24325,270 +24393,315 @@
 msgid "Loading data failed"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 msgid "Unsupported output format"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, c-format
 msgid "File <%s> created."
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 msgid "Surfaces"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
 msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò (ÌÇÍ ðñïóèÝóåôå åðÝêôáóç áñ÷åßïõ)"
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 msgid "Image"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 msgid "Graphics file format"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:96
-msgid "Width and height of output image"
+#: ../visualization/nviz2/cmd/args.c:104
+msgid "Size (width, height) of output image"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 msgid "Name of raster map(s) for elevation"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 msgid "Elevation value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 msgid "Name of raster map(s) for color"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 #, fuzzy
 msgid "Color value(s)"
 msgstr "×ñþìá"
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 msgid "Name of raster map(s) for mask"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 msgid "Name of raster map(s) for transparency"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 msgid "Name of raster map(s) for shininess"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 msgid "Name of raster map(s) for emission"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 msgid "Emission value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 msgid "Draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 msgid "Fine resolution"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 msgid "Coarse resolution"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 msgid "Draw style"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 msgid "Wire color"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 msgid "Name of line vector overlay map(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 msgid "Vector lines"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 msgid "Vector line width"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 msgid "Vector line color"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 msgid "Vector line display mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 msgid "Name of point vector overlay map(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 msgid "Vector points"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 msgid "Icon size"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 msgid "Icon width"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 msgid "Icon color"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 msgid "Icon marker"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 msgid "Viewpoint position (x,y model coordinates)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 msgid "Viewpoint height (in map units)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 msgid "Viewpoint twist angle (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 msgid "Volumes"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 msgid "Volume position"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 msgid "Volume resolution"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 msgid "Isosurface level"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+msgid "Light position (x,y,z model coordinates)"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+msgid "Lighting"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:584
+msgid "Light color"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+msgid "Fringe"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:625
+msgid "Fringe color"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "ñÜóôåñ 3Ä, voxel"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr ""
@@ -24726,123 +24839,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
 msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, c-format
-msgid "Failed in attempt to open %s"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-msgid "Output slope filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-msgid "Output aspect filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-msgid "Output profile curvature filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-msgid "Output tangential curvature filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-msgid "Output second order partial derivative dxx filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-msgid "Output second order partial derivative dyy filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-msgid "Output second order partial derivative dxy filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, c-format
-msgid "wrong type: %s"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-msgid "Creating support files..."
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr ""
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 msgid "Cannot load data from table"
@@ -25106,35 +25102,45 @@
 msgstr ""
 #: ../db/db.connect/main.c:49
-msgid "Prints/sets general DB connection for current mapset and exits."
+#, fuzzy
+msgid "Prints/sets general DB connection for current mapset."
 msgstr "Åêôõðþíåé/óåôÜñåé ãåíéêÞ DB óýíäåóç ãéá ôï ôñÝ÷ùí maps êáé êëåßíåé"
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 msgid "Print current connection parameters and exit"
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 msgid "Check connection parameters, set if uninitialized, and exit"
 msgstr ""
 "ÅëÝã÷åéò ôéò ôñÝ÷ïõóåò ðáñáìÝôñïõò óýíäåóçò, óåôÜñåéò Üí äåí Ý÷ïõí "
 "îåêéíÞóåéò êáé êëåßíåé"
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 msgid "Set"
 msgstr ""
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
+msgid "Set from default settings and exit"
+msgstr ""
+#: ../db/db.connect/main.c:65
+msgid "Overwrite current settings if initialized"
+msgstr ""
+#: ../db/db.connect/main.c:87
 msgid "Default group of database users to which select privilege is granted"
 msgstr ""
 "ÐñïåðéëåãìÝíï ãêñïõð ÷ñçóôþí âÜóçò äåäïìÝíùí óôï ïðïßï Ý÷ïõí ôá äéêáéþìáôá"
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 msgid "Database connection not defined. Run db.connect."
 msgstr ""
 "Äåí Ý÷åé êáèïñéóèåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí. ÔñÝîôå ôï db.connect."
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -25145,11 +25151,11 @@
 "driver: %s\n"
 "database: %s"
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr "Ï ðñïåðéëåãìÝíïò ïäçãüò äåí Ý÷åé êáèïñéóôåß"
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 msgid "Default database is not set"
 msgstr "Ç ðñïåðéëåãìÝíç âÜóç äåäïìÝíùí äåí Ý÷åé êáèïñéóôåß"
@@ -25393,7 +25399,7 @@
 msgid "'-' to read from standard input"
 msgstr ""
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
 msgstr "Áãíïåß ôá SQL ëÜèç êáé óõíå÷ßæåé"
@@ -25450,16 +25456,17 @@
 msgid "succeeded"
 msgstr ""
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr "SQL select åíôïëÞ"
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr "Ãéá ðáñÜäåéãìá: 'select * from rybniky where kapri = 'hodne'"
-#: ../db/db.select/main.c:215
-msgid "Name of file with sql statement"
+#: ../db/db.select/main.c:201
+#, fuzzy
+msgid "Name of file with SQL select statement(s)"
 msgstr "¼íïìá áñ÷åßïõ ìå sql åíôïëÞ"
 #: ../db/db.select/main.c:247
@@ -25663,7 +25670,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:6
@@ -25764,45 +25771,63 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#, fuzzy
+msgid "Files & format"
+msgstr "Äéáìüñöùóç"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
 msgid "Output coordinate file (omit to send to stdout)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 msgid "Field separator (format: input[,output])"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#, fuzzy
+msgid "Projections"
+msgstr "¼íïìá ôïðïèåóßá"
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Output projection parameters (PROJ.4 style)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
 msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "Ìçí óõìðåñéëÜâåôáé ôá ïíüìáôá ôùí óôçëþí óôçí Ýîïäï"
@@ -26045,6 +26070,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 msgid "Prints a graph of the correlation between data layers (in pairs)."
 msgstr ""
@@ -26318,12 +26347,6 @@
 msgid "Raster map to use as mask"
 msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-msgid "Create"
-msgstr ""
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
 msgstr ""
@@ -26517,6 +26540,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -26530,7 +26554,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
@@ -26850,18 +26874,23 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-msgid "Vector map for which to edit attribute table"
-msgstr ""
+#, fuzzy
+msgid "Name of vector map for which to edit attribute table"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Layer where to add column"
+#, fuzzy
+msgid "Layer number where to add column(s)"
+msgstr "Íïýìåñï åðéðÝäïõ"
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
 msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -27000,7 +27029,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -27360,18 +27389,22 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+msgid "Print stats in shell script style"
+msgstr ""
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
 msgid "Name of data table"
 msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 msgid "Database/directory for table"
 msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 #, fuzzy
 msgid "Database driver"
 msgstr "Äßíåé ôç ëßóôá ãéá üëïõò ôïõò ïäçãïýò âÜóåùí äåäïìÝíùí"
@@ -27436,6 +27469,11 @@
 msgid "Signature file <%s> is invalid"
 msgstr ""
+#: ../imagery/i.smap/read_sig.c:30
+#, fuzzy, c-format
+msgid "Signature file <%s> is empty"
+msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 msgid "Name of file containing signatures"
 msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé õðïãñáöÝò (signatures)"
@@ -27972,19 +28010,19 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr ""
-#: ../imagery/i.rectify/main.c:202
+#: ../imagery/i.rectify/main.c:204
 #, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr ""
-#: ../imagery/i.rectify/main.c:216
+#: ../imagery/i.rectify/main.c:218
 #, c-format
 msgid ""
 "Input raster map <%s> does not exist in group <%s>.\n"
 " Try:\n"
 msgstr ""
-#: ../imagery/i.rectify/main.c:222
+#: ../imagery/i.rectify/main.c:224
 msgid "Exit!"
 msgstr ""
@@ -28072,7 +28110,7 @@
 msgid "Error while writing to temp file"
-#: ../imagery/i.rectify/write.c:54
+#: ../imagery/i.rectify/write.c:55
 #, fuzzy, c-format
 msgid "Error writing row %d"
 msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
@@ -28082,12 +28120,12 @@
 msgid "Rectified input raster map <%s> will be saved as <%s>"
 msgstr ""
-#: ../imagery/i.rectify/rectify.c:91
+#: ../imagery/i.rectify/rectify.c:90
 #, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
 msgstr ""
-#: ../imagery/i.rectify/rectify.c:97
+#: ../imagery/i.rectify/rectify.c:96
 #, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
 msgstr ""
@@ -28565,7 +28603,7 @@
 msgid "Name of input raster map (image fft, imaginary part"
 msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
-#: ../imagery/i.ifft/main.c:119
+#: ../imagery/i.ifft/main.c:115
 msgid "The real and imaginary original windows did not match"
 msgstr ""
@@ -29645,9 +29683,6 @@
 #~ msgid "Unable to open elevation map"
 #~ msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
-#~ msgid "Unable to create raster map"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
 #~ msgid "Unable to close elevation map"
 #~ msgstr "Áäõíáìßá êëåéóßìáôïò ÷Üñôç õøïìÝôñùí"
@@ -29879,10 +29914,6 @@
 #~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
 #, fuzzy
-#~ msgid "Cannot read file header of [%s]"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
-#, fuzzy
 #~ msgid "Unable to select record from table <%s> (key %s, column %s)"
 #~ msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
@@ -30170,10 +30201,6 @@
 #~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (MIR; tm5 | qbird_red | spot3)"
 #, fuzzy
-#~ msgid "Data range of raster map <%s> is empty"
-#~ msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
-#, fuzzy
 #~ msgid "Integer data range of raster map <%s> is empty"
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_es.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -14,7 +14,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_es\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2008-01-11 19:44+0100\n"
 "Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
 "Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -27,7 +27,7 @@
 "Plural-Forms:  nplurals=2; plural=(n != 1);\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 msgid "Error closing 3d raster map"
@@ -69,7 +69,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "ráster"
@@ -89,7 +89,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -184,7 +184,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -199,39 +198,39 @@
 msgid "Error opening grid3 file [%s]"
 msgstr "Error al abrir el archivo grid3 [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 msgid "Cannot allocate memory for string"
 msgstr "No se puede asignar memoria para la cadena"
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, c-format
 msgid "Error reading range for [%s]"
 msgstr "Error al leer rango para [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 msgid "Error while reading history file"
 msgstr "Error mientras se leía archivo de historia"
@@ -266,7 +265,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -295,7 +294,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "Error al cerrar el nuevo mapa ráster 3D"
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 msgid "Error closing ascii file"
 msgstr "Error al cerrar archivo ASCII"
@@ -1122,7 +1121,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1137,7 +1136,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1170,17 +1169,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1235,7 +1233,7 @@
 msgstr "Correlación"
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 msgid "List supported formats and exit"
 msgstr "Listar los formatos soportados y salir"
@@ -1248,22 +1246,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1311,7 +1309,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 msgid "Name of input raster map"
@@ -1608,12 +1605,27 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr "El número mínimo de filas a mantener en memoria es 1"
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
+#, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "Coordenada X no admitida <%s>"
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr "Coordenada Norte <%s> no admitida"
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr "Coordenada Este <%s> no admitida"
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "Pase #%d (de %d)..."
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 msgid "Writing raster map..."
 msgstr "Escribiendo mapa ráster..."
@@ -1632,12 +1644,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1667,7 +1679,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1677,7 +1689,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1749,13 +1761,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1771,7 +1783,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1781,8 +1793,8 @@
 msgid "Unable to open database <%s> by driver <%s>"
 msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1793,7 +1805,7 @@
 msgid "Unable to create table: '%s'"
 msgstr "No se puede crear la tabla: '%s'"
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1803,8 +1815,8 @@
 msgstr "No se puede crear el índice para la tabla <%s>, clave <%s>"
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2098,7 +2110,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, c-format
@@ -2182,10 +2194,10 @@
 msgid "Output world file"
 msgstr "Producir archivo de referenciación TIFF"
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, c-format
 msgid "[%s]: No such color"
 msgstr "[%s]: No hay tal color"
@@ -2205,11 +2217,11 @@
 msgid "Writing world file"
 msgstr "Escribiendo archivo TIFF World"
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 msgid "Got null file name"
 msgstr "Se obtuvo un nombre de archivo nulo"
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr "Se obtuvo una estructura de región nula"
@@ -2388,7 +2400,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2513,8 +2525,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 msgid "Required"
 msgstr "Requerido"
@@ -2536,7 +2548,7 @@
 msgid "Metadata"
 msgstr "Metadatos"
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 msgid "Name for new location to create"
 msgstr "Nombre de la nueva localización a crear"
@@ -2545,7 +2557,7 @@
 msgstr "Ignorar proyección (usar proyección de la localización)"
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 msgid "Extend location extents based on new dataset"
 msgstr ""
 "Ampliar la extensión de la localización en base a nuevo conjunto de datos"
@@ -2590,7 +2602,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2635,7 +2647,7 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
@@ -2643,7 +2655,7 @@
 "No se puede convertir la proyección del mapa de entrada a formato GRASS; no "
 "se puede crear la nueva localización."
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, c-format
 msgid "Location <%s> created"
 msgstr "Localización <%s> creada"
@@ -2657,12 +2669,12 @@
 "formato de GRASS para comprobar"
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 msgid "Over-riding projection check"
 msgstr "Ignorando comprobación de proyección"
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -2680,7 +2692,7 @@
 msgstr "La PROJ_INFO del conjunto de datos es:\n"
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr ""
 "La información de proyección (PROJ_INFO) del conjunto de datos a importar "
@@ -2705,7 +2717,7 @@
 "entrada usando el parámetro 'localización'.\n"
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 msgid "Projection of input dataset and current location appear to match"
 msgstr ""
 "Las proyecciones del conjunto de datos de entrada y de la localización "
@@ -2836,30 +2848,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr "Configuraciones"
@@ -3055,13 +3064,15 @@
 #: ../raster/r.resamp.bspline/main.c:92
 #, fuzzy
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr "Valor de paso spline de interpolación en dirección Este"
 #: ../raster/r.resamp.bspline/main.c:100
 #, fuzzy
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr "Valor de paso spline de interpolación en dirección Norte"
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -3108,7 +3119,7 @@
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -3116,7 +3127,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -3145,7 +3156,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3163,7 +3174,7 @@
 msgstr "No se puede crear el mapa vectorial <%s>"
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3175,7 +3186,7 @@
 msgid "No data within this subregion. Consider increasing the spline step."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 #, fuzzy
 msgid "Writing output..."
 msgstr "Escribiendo mapa..."
@@ -3397,7 +3408,7 @@
 msgstr "Escribiendo mapa ráster <%s>"
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 #, fuzzy
 msgid "metadata"
 msgstr "Metadatos"
@@ -3469,7 +3480,7 @@
 msgstr ""
 "No se ha encontrado el mapa ráster <%s> en el directorio de mapas actual"
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3480,37 +3491,33 @@
 msgid "Unable to open input file <%s>"
 msgstr "No se puede abrir el archivo de entrada <%s>"
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-msgid "Not enough room in history file"
-msgstr "Espacio insuficiente en archivo histórico"
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "No se puede leer el archivo de categorías del mapa ráster <%s@%s>"
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, c-format
 msgid "cats table for [%s] set to %s"
 msgstr "Tabla de categorías de [%s] establecida a %s"
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr "[%s] es una reclasificación de otro mapa. Saliendo."
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, c-format
 msgid "Writing new null file for [%s]... "
 msgstr "Escribiendo nuevo archivo de nulos para [%s]... "
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr "Eliminando archivo de nulos de [%s]...\n"
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 msgid "Done."
 msgstr "Terminado."
@@ -4553,12 +4560,10 @@
 msgstr "Nombre para el mapa ráster de salida"
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 msgid "Format for reporting the slope"
 msgstr "Formato para informar la pendiente"
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 msgid "Type of output aspect and slope maps"
 msgstr "Tipo de mapas de orientación y pendiente"
@@ -4604,19 +4609,16 @@
 msgstr "Nombre de archivo de derivada dxy parcial de segundo orden de salida"
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr "Factor de multiplicación para convertir unidades de elevación a metros"
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr ""
 "Valor de pendiente mínimo (en porcentaje) para el que se procesa la "
 "orientación"
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 msgid "Do not align the current region to the elevation layer"
 msgstr "No alinear la región actual con la capa de elevación"
@@ -4658,58 +4660,56 @@
 msgstr "Productos de elevación para el directorio de mapas [%s] en [%s]"
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr "Orientación mínima procesada %.4f  orientación máxima procesada %.4f"
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, fuzzy, c-format
 msgid "Aspect raster map <%s> complete"
 msgstr "No se encuentra el mapa ráster de base <%s>"
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr "Pendiente mínima procesada %.4f  pendiente máxima procesada %.4f"
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, fuzzy, c-format
 msgid "Slope raster map <%s> complete"
 msgstr "No se encuentra el mapa ráster de pendiente de entada <%s>"
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, fuzzy, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr "Producir mapa ráster de curvatura de perfil"
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, fuzzy, c-format
 msgid "Tangential curve raster map <%s> complete"
 msgstr "No se puede crear el mapa ráster <%s>"
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, fuzzy, c-format
 msgid "E-W slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, fuzzy, c-format
 msgid "N-S slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, fuzzy, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr "Mapa ráster 3D <%s> no encontrado"
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, fuzzy, c-format
 msgid "Dyy raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, fuzzy, c-format
 msgid "Dxy raster map <%s> complete"
@@ -4801,7 +4801,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -4981,7 +4981,6 @@
 msgstr "Nombre de una capa de salida"
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr "Porcentaje completado: "
@@ -5486,67 +5485,67 @@
 msgid "Filter <%s> not found"
 msgstr "Archivo <%s> no encontrado"
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 #, fuzzy
 msgid "resample"
 msgstr "ráster, remuestrear"
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr "Vuelve a muestrear capas de mapa ráster usando agregación."
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 msgid "Filter radius (horizontal)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr "Propagar NULOS"
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 #, fuzzy
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr "weight= y -c son excluyentes mutuamente"
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, fuzzy, c-format
 msgid "Too many filters (max: %d)"
 msgstr "** <%s> tiene demasiadas firmas (el límite es 255)"
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "Se debe especificar al menos una opción de %s"
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, c-format
 msgid "Unable to read color table for %s"
 msgstr "No se puede leer la tabla de color para %s"
@@ -6137,7 +6136,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr "%s: %s - especificación de distancia no admitida"
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, c-format
 msgid "Unknown method <%s>"
 msgstr "Método <%s> desconocido"
@@ -6159,7 +6158,7 @@
 msgid "Aggregate operation"
 msgstr "Agregar operación"
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
@@ -8154,6 +8153,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr "Percentil a calcular (requiere la opción de estadísticas ampliadas)"
@@ -8516,32 +8516,32 @@
 msgid "Pass %d..."
 msgstr "Pase: %d\n"
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "Exporta un ráster de GRASS a un archivo MAT binario."
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 msgid "Name for new TIFF file"
 msgstr "Nombre para el nuevo archivo TIFF"
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr "Compresión del archivo TIFF"
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr "Salida de paleta TIFF (8bits en vez de 24 bits)."
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 msgid "Output TIFF world file"
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 msgid "Output Tiled TIFF"
 msgstr "TIFF teselado de salida"
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, fuzzy, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
@@ -8550,7 +8550,7 @@
 "El mapa ráster <%s> en el directorio de mapas <%s> es de coma flotante. ¡Los "
 "valores decimales se redondearán a entero!"
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
@@ -8558,16 +8558,16 @@
 "El mapa de color para paleta debe tener menos de 256 colores para el rango "
 "disponible de datos"
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, c-format
 msgid "Unable to open TIFF file <%s>"
 msgstr "No se puede abrir el archivo TIFF <%s>"
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 msgid "Writing TIFF World file"
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 msgid "Unable to open TIFF world file for writing"
 msgstr "No se puede abrir el archivo de referenciación TIFF para escritura"
@@ -8684,7 +8684,7 @@
 msgstr "Leyendo datos..."
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, fuzzy, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -8695,21 +8695,21 @@
 "incorrecto? Se encontró el siguiente carácter(es) en la fila %d:\n"
 "[%s]"
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, fuzzy, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr "Coordenada Y incorrecta línea %d columna %d. <%s>"
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, fuzzy, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr "Coordenada X incorrecta línea %d columna %d. <%s>"
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, fuzzy, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr "Coordenada Z incorrecta línea %d columna %d. <%s>"
@@ -8718,16 +8718,16 @@
 msgid "Writing to map ..."
 msgstr "Escribiendo al mapa..."
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, fuzzy, c-format
 msgid "%lu points found in region."
 msgstr "%d puntos encontrados en la región."
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 msgid "Scanning data ..."
 msgstr "Escaneando datos..."
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr "Rango:     mínimo          máximo\n"
@@ -9268,68 +9268,68 @@
 "CHILD[pid = %i]: no se puede abrir la máscara %s ... ¡¡¡Se continúa sin "
 "ella!!!"
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 msgid "Cannot create random access file"
 msgstr "No se puede crear el archivo de acceso aleatorio"
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr "No se puede crear el directorio %s/.r.li/"
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
 msgstr "No se puede crear el directorio %s/.r.li/output/"
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
 msgstr "No se puede la estadística del archivo de configuración %s"
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 msgid "Cannot read setup file"
 msgstr "No se puede leer el archivo de configuración"
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 #, fuzzy
 msgid "Irregular maskedoverlay areas definition"
 msgstr "Definición de áreas irregular"
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
 "El archivo de configuración se puede usar sólo con el archivo ráster \t\t%s "
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 msgid "Illegal configuration file (sample area)"
 msgstr "Archivo de configuración no admitido (área de muestreo)"
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 msgid "Too many units to place"
 msgstr "Demasiadas unidades a situar"
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 msgid "Too many strats for raster map"
 msgstr "Demasiadas estrategias para mapa ráster"
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr "Disposición de áreas no admitida"
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 msgid "Cannot make lseek"
 msgstr "No se puede hacer lseek"
@@ -9659,8 +9659,8 @@
 #: ../raster/r.out.gdal/export_band.c:201
 #, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:241
@@ -9841,7 +9841,7 @@
 msgid "Name of color file"
 msgstr "Nombre de archivo de color"
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 msgid "Vertical exaggeration"
 msgstr "Exageración vertical"
@@ -9897,16 +9897,21 @@
 msgid "File containing expression(s) to evaluate"
 msgstr "Archivo que contiene las reglas de reclasificación"
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:145
 #, fuzzy
+msgid "file= and expression= are mutually exclusive"
+msgstr "weight= y -c son excluyentes mutuamente"
+#: ../raster/r.mapcalc/main.c:155
+#, fuzzy
 msgid "parse error"
 msgstr "Parámetros"
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr "Hubo error(es) de coma flotante en el cálculo"
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr "Hubo desbordamiento en el cálculo"
@@ -10214,8 +10219,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 #, fuzzy
 msgid "Position"
 msgstr "Por posición"
@@ -10821,8 +10826,8 @@
 "Usar valores ráster como categorías en vez de secuencia única (sólo CELL)"
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 #, fuzzy
 msgid "Attributes"
@@ -10874,7 +10879,7 @@
 msgstr "No se puede insertar en la tabla: %s"
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "No se puede insertar nueva línea: %s"
@@ -11297,19 +11302,19 @@
 "No se puede obtener información de proyección de la localización actual: "
 "¡por favor establezca la latitud via opción 'lat' o 'latin'!"
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr "OOPS: cambiadas filas desde %d hasta %d"
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr "OOPS: cambiadas columnas desde %d hasta %d"
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -11325,7 +11330,7 @@
 msgid "Error in pj_do_proj"
 msgstr "Error en pj_do_proj"
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr "No se puede leer el intervalo fp del mapa ráster <%s>"
@@ -11729,7 +11734,7 @@
 msgid "Raster map(s) to report on"
 msgstr "Mapa(s) ráster sobre el que informar"
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr "Unidades"
@@ -11768,7 +11773,6 @@
 msgstr "Nombre de un archivo de salida para albergar el informe"
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 msgid "Quiet"
 msgstr "Silencioso"
@@ -12275,13 +12279,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr "Avanzado"
@@ -12499,16 +12496,16 @@
 msgid "Writing topographic index map..."
 msgstr "Escribiendo mapa de índice topográfico..."
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 #, fuzzy
 msgid "Resamples raster map layers to a coarser grid using aggregation."
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 msgid "Aggregation method"
 msgstr "Método de agregación"
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 #, fuzzy
 msgid "Weight according to area (slower)"
 msgstr "a"
@@ -12923,13 +12920,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -12967,17 +12964,68 @@
 msgid "Access for others"
 msgstr "Acceso para otros"
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr ""
 "El acceso al directorio de mapas PERMANENT debe estar abierto, no se cambia "
 "nada"
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 #, fuzzy
 msgid "Unable to determine mapset permissions"
 msgstr "No se pueden determinar los permisos del directorio de mapas"
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "No se pueden determinar los permisos del directorio de mapas"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+#, fuzzy
+msgid "read "
+msgstr "Romper"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 msgid "Error reading WKT projection description"
 msgstr "Error al leer la descripción de la proyección WKT"
@@ -13670,49 +13718,49 @@
 msgid "Error conducting transform (%d)"
 msgstr "Haciendo transformación del registro"
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr ""
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr ""
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 #, fuzzy
 msgid "Parameter error"
 msgstr "Parámetros"
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 #, fuzzy
 msgid "No active control points"
 msgstr "Ningún punto de inicio"
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
 msgstr "Coordenadas no válidas %s %s"
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 #, fuzzy
 msgid "transformation"
 msgstr "vectorial, transformación"
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 #, fuzzy
 msgid "Computes a coordinate transformation based on the control points."
 msgstr ""
 "Procesa una transformación de coordenadas basada en los puntos de control"
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 msgid "Rectification polynomial order"
 msgstr "Orden polinómica de rectificación"
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -13720,37 +13768,37 @@
 "difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 msgid "Output format"
 msgstr "Formato de salida"
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 msgid "Display summary information"
 msgstr "Mostrar información de resumen"
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr ""
 "Archivo que contiene reglas de etiquetas de categorías (o \"-\" para leer de "
 "stdin)"
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 #, fuzzy
 msgid "Local x,y coordinates to target east,north"
 msgstr "La coordenada del centro (Este, Norte)"
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 #, fuzzy
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr "usar reglas de transformación para LANDSAT-4"
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 #, fuzzy
 msgid "Target east,north coordinates to local x,y"
 msgstr "Coordenadas inferior izquierda Este y Norte del mapa"
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 #, fuzzy
 msgid "Display transform matrix coefficients"
 msgstr "Mapa para el coeficiente X"
@@ -13765,54 +13813,70 @@
 msgid "Change current mapset."
 msgstr "Cambiar directorio de mapas actual"
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
-msgstr "Nombre del nuevo DIRECTORIO DE MAPAS"
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
+msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "Nombre del mapa de salida donde se escriben los errores"
+#: ../general/g.mapset/main.c:63
+#, fuzzy
+msgid "Location name (not location path)"
 msgstr "Nombre de la nueva LOCALIZACIÓN (no ruta de la localización)"
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+#, fuzzy
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr ""
 "Nueva BASE DE DATOS (ruta completa al directorio donde se encuentra la nueva "
 "localización)"
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 msgid "Create mapset if it doesn't exist"
 msgstr "Crear directorio de mapas si no existe"
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
 #, fuzzy
+msgid "Create"
+msgstr "Correlación"
+#: ../general/g.mapset/main.c:86
+#, fuzzy
 msgid "List available mapsets"
 msgstr "Listar todos los directorios de mapas disponibles"
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 #, fuzzy
 msgid "Either mapset= or -l must be used"
 msgstr "Se debe especificar el valor umbral"
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, fuzzy, c-format
 msgid "<%s> is already the current mapset"
 msgstr "%s ya es el directorio de mapas actual"
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 #, fuzzy
 msgid "You don't have permission to use this mapset"
 msgstr "No tiene permiso para usar este directorio de mapas."
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr "El directorio de mapas no existe. Use la opción -c para crearlo."
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 #, fuzzy
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr "No se puede leer la variable de entorno GIS_LOCK."
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, fuzzy, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
@@ -13821,18 +13885,18 @@
 "%s está ejecutando actualmente GRASS en el directorio de mapas seleccionado "
 "o no se puede comprobar el archivo de bloqueo."
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 #, fuzzy
 msgid "Cleaning up temporary files..."
 msgstr "Limpiando archivos temporales..."
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 #, fuzzy
 msgid "Your shell continues to use the history for the old mapset"
 msgstr ""
 "Su consola continúa usando el histórico para el directorio de mapas antiguo."
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
@@ -13841,7 +13905,7 @@
 "Puede cambiar el histórico mediante comandos:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
@@ -13850,16 +13914,6 @@
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
-#: ../general/g.mapsets/dsply_path.c:19
-#, fuzzy, c-format
-msgid "Your mapset search list:\n"
-msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
-#: ../general/g.mapsets/dsply_path.c:29
-#, fuzzy, c-format
-msgid "<%s> not found in mapset list"
-msgstr "Columna <%s> no encontrada en la tabla <%s>"
 #: ../general/g.mapsets/main.c:62
 msgid ""
 "Modifies the user's current mapset search path, affecting the user's access "
@@ -13913,15 +13967,15 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr "No se puede abrir SEARCH_PATH para escritura"
-#: ../general/g.mapsets/dsply_maps.c:23
-#, fuzzy, c-format
+#: ../general/g.mapsets/list.c:10
+#, fuzzy
 msgid "Available mapsets:"
-#: ../general/g.mapsets/dsply_maps.c:33
-#, c-format
-msgid "** no mapsets **\n"
-msgstr ""
+#: ../general/g.mapsets/list.c:35
+#, fuzzy
+msgid "Accessible mapsets:"
+msgstr "Listar todos los directorios de mapas disponibles"
 #: ../general/g.copy/main.c:43
 msgid ""
@@ -14476,40 +14530,40 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, fuzzy, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "El archivo '%s'ya existe y se sobrescribirá."
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "Abriendo %s para escritura... "
@@ -14532,13 +14586,12 @@
 msgstr ""
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-#, fuzzy
-msgid "Name of workspace file"
-msgstr "Nombre de archivo de color"
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
 #: ../general/g.gui/main.c:57
 msgid "Update default GUI setting"
@@ -14553,6 +14606,11 @@
 msgid "<%s> is now the default GUI"
 msgstr ""
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 msgid "Force remove"
 msgstr "Forzar eliminar"
@@ -14594,7 +14652,7 @@
 msgid "Unable to read FP range for %s"
 msgstr "No se puede leer f_range para el mapa %s"
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -14609,7 +14667,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -14637,7 +14695,7 @@
 msgid "At least two points are required"
 msgstr "Atributo no encontrado"
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -14650,7 +14708,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -14658,45 +14716,45 @@
 msgid "No graphics device selected"
 msgstr "Ningún dispositivo de gráficos seleccionado"
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
 msgstr ""
 "Seleccione el tipo de letra que será mostrado en la pantalla del usuario."
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 msgid "Choose new current font"
 msgstr "Elegir nueva fuente actual"
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 msgid "Path to Freetype-compatible font including file name"
 msgstr ""
 "Ruta a las fuentes compatibles con FreeType, incluyendo el nombre de archivo"
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr "Codificación de caracteres"
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 msgid "List fonts"
 msgstr "Listar fuentes"
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 msgid "List fonts verbosely"
 msgstr "Listar fuentes de forma verbosa"
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, fuzzy, c-format
 msgid "Unable to access font path %s: %s"
 msgstr "No se puede leer la entrada: %s"
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, fuzzy, c-format
 msgid "Font path %s is not a file"
 msgstr "%s no es una regla válida"
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -15170,6 +15228,7 @@
 "Mostrar una leyenda para un mapa ráster en el marco activo de la pantalla."
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 msgid "Name of raster map"
 msgstr "Nombre del mapa ráster"
@@ -15354,8 +15413,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -15603,33 +15662,33 @@
 msgstr "Número de capa. Si es -1 se muestran todas las capas."
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 #, fuzzy
 msgid "Selection"
 msgstr "Resolución"
@@ -15675,15 +15734,15 @@
 msgstr "'layer' (capa) debe ser > 0 para 'cats' (categorías)."
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, c-format
 msgid "Database connection not defined"
 msgstr "Conexión a la base de datos no definida"
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -16461,46 +16520,47 @@
 msgid "Error: %s\n"
 msgstr "Error: %s\n"
-#: ../display/d.rast/main.c:55
+#: ../display/d.rast/main.c:54
 #, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr ""
-"Muestra y superpone las capas del mapa ráster en el marco activo de la "
-"pantalla."
+msgid "Displays raster map layer."
+msgstr "Consulta colores de una capa da mapa ráster."
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 msgid "Raster map to be displayed"
 msgstr "Mapa ráster a mostrar"
-#: ../display/d.rast/main.c:67
-msgid "List of categories to be displayed (INT maps)"
+#: ../display/d.rast/main.c:66
+#, fuzzy
+msgid "List of categories or values to be displayed"
 msgstr "Lista de categorías para mostrar (mapas INT)"
-#: ../display/d.rast/main.c:76
-msgid "List of values to be displayed (FP maps)"
-msgstr "Lista de valores a mostrar (mapas FP)"
-#: ../display/d.rast/main.c:85
+#: ../display/d.rast/main.c:72
 msgid "Background color (for null)"
 msgstr "Color de fondo (para nulo)"
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+#, fuzzy
+msgid "Either a standard color name or R:G:B triplet"
+msgstr "Color de texto: color estándar de GRASS o triplete R:G:B"
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
+#: ../display/d.rast/main.c:81
+#, fuzzy
+msgid "Invert value list"
 msgstr "Invertir lista de categorías"
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
-"Ignorando lista de categorías: el mapa es coma flotante (por favor use "
-"'val=')"
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "%s: especificación de valor no admitida"
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr "Ignorando lista de valores: el mapa es entero (por favor user 'cat=')"
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
 #: ../display/d.rast.num/main.c:73
 msgid ""
@@ -16851,11 +16911,6 @@
 msgid "Label color"
 msgstr "Color de etiqueta"
-#: ../display/d.vect/main.c:263
-#, fuzzy
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "Color de texto: color estándar de GRASS o triplete R:G:B"
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr "Color de fondo de etiqueta"
@@ -17131,7 +17186,7 @@
 "El tipo de columna <%s> no está soportado (debe ser entero o precisión doble)"
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -17152,7 +17207,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
 msgstr "No se puede crear el índice"
@@ -17170,7 +17225,7 @@
 msgstr "No hay registro para la categoría %d en la tabla <%s>"
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -17183,7 +17238,7 @@
 msgstr "No se puede insertar la fila: %s"
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -17211,7 +17266,7 @@
 msgstr "base de datos, SQL"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -17278,7 +17333,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -17538,7 +17593,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, c-format
@@ -17672,10 +17727,8 @@
 msgstr "Número de capa"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 msgid "Query"
 msgstr "Consulta"
@@ -18052,16 +18105,16 @@
 msgid "Unable to build topology for <%s>"
 msgstr "No se puede encontrar el vector de fin <%s>"
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "Convertir capas vectoriales OGR a mapas vectoriales de GRASS."
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 msgid "OGR datasource name"
 msgstr "Nombre del origen de datos OGR"
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: directory containing shapefiles\n"
@@ -18071,12 +18124,12 @@
 "\tShapefile de ESRI: directorio que contiene shapefiles\n"
 "\tArchivo MapInfo: directorio que contiene archivos MapInfo"
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
 "Nombre de capa OGR. Si no se indica, se importan todas las capas disponibles."
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: shapefile name\n"
@@ -18086,37 +18139,37 @@
 "\t\tShapefile ESRI: nombre del shapefile\n"
 "\t\tArchivo MapInfo: nombre del archivo MapInfo"
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 msgid "Import subregion only"
 msgstr "Importar sólo la subregión"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 msgid "Subregion"
 msgstr "Subregión"
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr "Formato: xmin,ymin,xmax,ymax - normalmente W,S,E,N"
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr "Tamaño mínimo del área a importar (unidades cuadradas)"
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
 "Las áreas más pequeñas y las islas se ignorarán. Debería ser mayor que snap²"
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 #, fuzzy
 msgid "Optionally change default input type"
 msgstr "Cambiar opcionalmente el tipo de entrada por omisión"
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
 "boundary;import lines as area boundaries;centroid;import points as centroids"
@@ -18125,15 +18178,15 @@
 "área como líneas;boundary;importar líneas como contornos de área;centroid;"
 "importar puntos como centroides"
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 msgid "Snapping threshold for boundaries"
 msgstr "Umbral de salto para contornos"
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr "'-1' para sin autoensamblaje"
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
@@ -18141,81 +18194,81 @@
 "Lista de nombres de columna a usar en vez de los originales. El primero se "
 "usa para la columna de categoría"
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 msgid "List available layers in data source and exit"
 msgstr "Listar las capas disponibles en la fuente de datos y salir"
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 msgid "Do not clean polygons (not recommended)"
 msgstr "No limpiar polígonos (no recomendado)"
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 msgid "Create 3D output"
 msgstr "Crear salida 3D"
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 msgid "Do not create attribute table"
 msgstr "No crear la tabla de atributos"
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 msgid "Override dataset projection (use location's projection)"
 msgstr ""
 "Ignorar proyección del conjunto de datos (usar proyección de la localización)"
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 msgid "Limit import to the current region"
 msgstr "Limitar importación a la región actual"
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr "Cambiar nombres de columna a minúsculas"
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr "Controladores OGR disponibles:"
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, c-format
 msgid "Unable to open data source <%s>"
 msgstr "No se puede abrir el origen de datos <%s>"
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr "El origen de datos contiene %d capas:"
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "El vectorial <%s> ya existe y será sobrescrito"
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, c-format
 msgid "Vector map <%s> already exists"
 msgstr "El mapa vectorial <%s> ya existe"
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, c-format
 msgid "Layer <%s> not available"
 msgstr "Capa <%s> no disponible"
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr "Seleccionar la opción región actual o la opción espacial, no ambas"
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 msgid "4 parameters required for 'spatial' parameter"
 msgstr " Se requieren 4.parámetros para el parámetro 'espacial'"
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
@@ -18223,11 +18276,11 @@
 "No se puede convertir información de la proyección del mapa de entrada a "
 "formato GRASS para comprobar"
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr "La información de proyección (PROJ_INFO) de la localización es:\n"
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, c-format
 msgid ""
 "\n"
@@ -18237,7 +18290,7 @@
 "Puede usar la opción -o para que %s ignore la comprobación de esta "
 "proyección.\n"
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 #, fuzzy
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
@@ -18246,29 +18299,29 @@
 "Considere generar una nueva localización con el parámetro 'localización' del "
 "conjunto de datos de entrada.\n"
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "%s: error al escribir el archivo temporal"
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, c-format
 msgid "Layer: %s"
 msgstr "Capa: %s"
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr "Nombre de columna cambiado: '%s' -> '%s'"
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
 "Escribiendo columna <%s> con longitud fija de %d caracteres (puede quedar "
 "truncada)"
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
@@ -18277,102 +18330,107 @@
 "Anchura para la columna %s establecida a 255 (no fue especificada por OGR). "
 "¡Algunas cadenas pueden quedar truncadas!"
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
 "Escribiendo la columna %s con longitud fija de %d caracteres (puede quedar "
 "truncada)"
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, c-format
 msgid "Column type not supported (%s)"
 msgstr "Tipo de columna no soportado (%s)"
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
 #, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "Importando elementos %d del mapa..."
+#: ../vector/v.in.ogr/main.c:854
+#, fuzzy, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr "Distancia de buffer en unidades de mapa"
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr "%d %s sin geometría"
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr "Limpiando polígonos. ¡El resultado no está garantizado!"
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr "Ajustar contornos (umbral = %.3e):"
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 msgid "Break polygons:"
 msgstr "Romper polígonos:"
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 msgid "Remove duplicates:"
 msgstr "Eliminar duplicados:"
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr "Romper contornos:"
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr "Limpiar contornos en los nodos:"
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 #, fuzzy
 msgid "Change boundary dangles to lines:"
 msgstr "Cambiar de contornos a líneas:"
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 #, fuzzy
 msgid "Change dangles to lines:"
 msgstr "a líneas:"
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr "Cambiar puentes de contornos a líneas:"
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr "Eliminar puentes:"
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 #, fuzzy
 msgid "Merge boundaries:"
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
 msgstr "Imposible calcular el centroide del área"
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, fuzzy, c-format
 msgid "Find centroids for layer: %s"
 msgstr "Entrada incorrecta para el multiplicador: %s"
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 #, fuzzy
 msgid "Write centroids:"
 msgstr "Escribiendo centroides..."
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -18384,47 +18442,47 @@
 "la tabla de atributos. El número de elementos para estas áreas se guarda "
 "como categoría en la capa %d"
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, fuzzy, c-format
 msgid "%d input polygons\n"
 msgstr "%d polígonos de entrada"
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, c-format
 msgid "%d input polygons"
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
 msgstr "Áreas total: %e (%d áreas)"
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
 msgstr "Área solapada: %e (%d áreas)"
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
 msgstr "Área sin categoría: %e (%d áreas)"
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
 "import 3D vector"
@@ -18432,44 +18490,39 @@
 "Los datos de entrada contienen elementos 3D. El vectorial creado es 2D. Use "
 "la opción -z para importar vectoriales 3D."
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "No se puede escribir parte de la geometría"
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr "Degenerar polígono ([%d] vértices)"
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr "Tamaño de área [%.1e]. Área no importada"
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr "Degenerar isla ([%d] vértices)"
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr "Tamaño de isla [%.1e]. Isla no importada"
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 msgid "Cannot calculate centroid"
 msgstr "No se puede calcular el centroide"
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr "Ningún centroide escrito para polígonos con 0 vértices"
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 msgid "Cannot write part of geometry"
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 msgid "Unknown geometry type"
 msgstr "Tipo de geometría desconocido"
@@ -18656,6 +18709,9 @@
 msgstr "Nombre de tabla de entrada"
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 #, fuzzy
 msgid "Connection"
@@ -18689,12 +18745,12 @@
 "datos: <%s>) ya existe"
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, c-format
 msgid "Missing column <%s> in table <%s>"
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 msgid "Data type of key column must be integer"
 msgstr "El tipo de datos de la columna clave debe ser entero"
@@ -18917,8 +18973,8 @@
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 #, fuzzy
 msgid "From"
 msgstr "Desde_mapa"
@@ -18940,8 +18996,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 #, fuzzy
 msgid "To"
 msgstr "Herramienta"
@@ -18969,62 +19025,62 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr "No se pueden otorgar privilegios sobre la tabla <%s>"
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
 msgstr ""
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 #, fuzzy
 msgid "Name of existing vector map (from)"
 msgstr "Nombre del mapa vectorial existente"
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 #, fuzzy
 msgid "Feature type (from)"
 msgstr "Tipo de elemento"
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 #, fuzzy
 msgid "Name of existing vector map (to)"
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 #, fuzzy
 msgid "Feature type (to)"
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr ""
 "Nombre para el mapa vectorial de salida que contiene líneas que conectan los "
 "elementos más cercanos"
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 msgid "Maximum distance or -1 for no limit"
 msgstr "Distancia máxima o -1 para sin límite"
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 #, fuzzy
 msgid "Minimum distance or -1 for no limit"
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr "Valores que describen la relación entre los dos elementos más próximos"
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 #, fuzzy
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
@@ -19045,43 +19101,43 @@
 "y PI inclusive:to_attr:atributos del elemento más cercano dados por la "
 "opción to_column"
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 "Nombre(s) de columna donde se cargarán los valores especificados por la "
 "opción 'upload'"
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr "Desde_mapa"
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
 "Nombre de la columna del elemento más cercano (usada con upload=to_attr)"
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr ""
 "Nombre de la tabla creada para la salida cuando se usa la opción distancia a "
 "todos"
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr "Imprimir la salida a stdout, no actualizar tabla de atributos"
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
 "La primera columna es siempre la categoría del elemento 'desde' llamada "
 "from_cat"
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr "Calcular distancias a todos los elementos dentro del umbral"
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
@@ -19089,104 +19145,109 @@
 "La salida se escribe a stdout pero puede se puede cargar a una nueva tabla "
 "creada por este módulo. Las categorías 'desde' pueden ser múltiples."
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr "falta la opción to_column (a_columna)"
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 msgid "Too many column names"
 msgstr "Demasiados nombres de columna"
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 msgid "Not enough column names"
 msgstr "Nombres de columnas insuficientes"
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, fuzzy, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr "%d de %d elementos seleccionados del mapa vectorial <%s>"
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, c-format
 msgid "Column <%s> not found in table <%s>"
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 msgid "Unable to open default database"
 msgstr "No se puede abrir la base de datos predeterminada"
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 #, fuzzy
 msgid "Incompatible column types"
 msgstr "Tipos de columna incompatibles"
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
 msgstr "Imprimiendo ... "
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 #, fuzzy
 msgid "Finding nearest areas..."
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, fuzzy, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr "Más categorías de capa_a (to_layer)"
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr "Formato de fecha aún no soportado. No se cargará ningún atributo."
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr "%d categorías con más de un elemento en el mapa vectorial <%s>"
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, c-format
 msgid "%d categories - no nearest feature found"
 msgstr "%d categorías - ningún elemento más cercano encontrado"
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr "%d distancias calculadas"
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, c-format
 msgid "%d records inserted"
 msgstr "%d registros insertados"
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, c-format
 msgid "%d insert errors"
 msgstr "%d errores al insertar"
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, c-format
 msgid "%d categories read from the map"
 msgstr "%d categorías leídas del mapa"
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, c-format
 msgid "%d categories exist in the table"
 msgstr "%d categorías existen en la tabla"
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, c-format
 msgid "%d categories read from the map exist in the table"
 msgstr "%d categorías leídas del mapa existen en la tabla"
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, c-format
 msgid "%d categories read from the map don't exist in the table"
 msgstr "%d categorías leídas del mapa no existen en la tabla"
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, c-format
 msgid "%d records updated"
 msgstr "%d registros actualizados"
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, c-format
 msgid "%d update errors"
 msgstr "%d errores al actualizar"
@@ -19560,7 +19621,7 @@
 msgstr "No se puede leer el nombre del controlador"
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -19582,7 +19643,7 @@
 msgstr "La tabla auxiliar no se pudo eliminar"
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr "No se puede abrir el mapa vectorial <%s> al nivel topológico"
@@ -19615,13 +19676,12 @@
 msgid "Outlier detection"
 msgstr "Color de contorno"
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 msgid "Auxiliar table could not be dropped"
@@ -21211,21 +21271,12 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:273
+#: ../vector/v.surf.bspline/main.c:274
 #, fuzzy, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-"Ningún mapa vectorial a interpolar. La interpolación se hará con el mapa "
-"vectorial <%s>"
-#: ../vector/v.surf.bspline/main.c:279
-#, fuzzy, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr "El mapa vectorial <%s> se interpolará"
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
@@ -21234,32 +21285,46 @@
 "Lo siento, el controlador <%s> no está permitido para salida vectorial en "
 "este módulo. Pruebe con una salida ráster u otro controlador."
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr "No se creará ningún dato vectorial."
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+#: ../vector/v.surf.bspline/main.c:332
 msgid "Cannot read field info"
 msgstr "No se puede leer la información del campo"
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, c-format
 msgid "[%d] records selected from table"
 msgstr "[%d] registros seleccionados de la tabla"
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr "Interpolación: creando tabla: no se pudo crear la tabla <%s>."
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 #, fuzzy
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
 msgstr "No se puede asignar memoria para la cadena"
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr "Interpolación: (%d,%d): Ningún registro para el punto (cat = %d)"
+#: ../vector/v.surf.bspline/main.c:712
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, fuzzy, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -23733,7 +23798,8 @@
 msgstr "Fallo al obtener el área [%d]"
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
+#, fuzzy
+msgid "Area without centroid (OK for island)"
 msgstr "Área sin centroide (puede ser correcto para islas)"
 #: ../vector/v.to.rast/do_areas.c:126
@@ -24915,11 +24981,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr "La capa debe ser >0 para 'where' (donde)"
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr ""
@@ -24940,7 +25006,7 @@
 msgid "Print topology information only"
 msgstr "Imprimir sólo información de topología"
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
 msgstr ""
@@ -25550,31 +25616,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr "Argumentos no válidos para anyfunc %s (argc = %d)"
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr "Realizando la función de mapa de un argumento en el mapa %s"
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr "Realizando la función de mapa de dos argumentos en los mapas %s y %s"
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, c-format
 msgid "Performing map %s + %s"
 msgstr "Realizando mapa %s + %s"
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr "No se puede llamar a map-function incorrecta"
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr "Argumentos no válidos para mapfunc %s (argc = %d)"
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr "NInguna función definida para realizar mapa %c mapa"
@@ -25739,44 +25805,45 @@
 msgstr "Imprimir todos los parámetros de conexión del mapa y salir"
 #: ../vector/v.db.connect/main.c:89
-msgid "Print all map connection parameters and exit in shell script style"
+#, fuzzy
+msgid "Print all map connection parameters in shell script style and exit"
 msgstr ""
 "Imprimir todos los parámetros de conexión del mapa y salir en estilo de "
 "script de consola"
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr "Formato: capa[/nombre de capa] tabla clave base de datos controlador"
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
 "Imprimir tipos/nombre de columnas de la tabla para capas especificadas y "
 "salir"
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 msgid "Overwrite connection parameter for certain layer"
 msgstr "Sobrescribir los parámetros de conexión para cierta capa"
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 msgid "Delete connection for certain layer (not the table)"
 msgstr "Borrar conexión para cierta capa (no la tabla)"
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 msgid "Please choose only one print style"
 msgstr "Por favor, elija sólo un estilo de impresión"
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 msgid "Unable to modify vector map stored in other mapset"
 msgstr ""
 "No se pueden editar mapas vectoriales guardados en otro directorio de mapas"
-#: ../vector/v.db.connect/main.c:165
-#, c-format
-msgid "Vector map <%s> is connected by:"
+#: ../vector/v.db.connect/main.c:164
+#, fuzzy, c-format
+msgid "Vector map <%s> is connected by:\n"
 msgstr "El mapa vectorial <%s> está conectado por:"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, fuzzy, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
@@ -25784,7 +25851,7 @@
 "capa <%d> tabla <%s> en la base de datos <%s> a través del controlador <%s> "
 "con clave <%s>\n"
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
@@ -25792,17 +25859,17 @@
 "con clave <%s>\n"
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr "Usar -o para sobrescribir el enlace existente para la capa <%d>"
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr "La tabla <%s> no existe en la base de datos <%s>"
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
@@ -25811,16 +25878,16 @@
 "La tabla <%s> ahora es parte del mapa vectorial <%s> y se puede borrar o "
 "sobrescribir por los módulos de GRASS"
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, c-format
 msgid "Cannot grant privileges on table %s"
 msgstr "No se pueden otorgar privilegios sobre la tabla %s"
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr "Los privilegios seleccionados fueron asignados sobre la tabla"
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -26232,41 +26299,41 @@
 msgid "Name of Arc cost column"
 msgstr "Nombre de la columna"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr "miscelánea"
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 #, fuzzy
 msgid "measurement"
 msgstr "Situación"
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
 msgstr "Una o más coordenadas"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 #, fuzzy
 msgid "Default: location map units"
 msgstr "Error de discretización en unidades de mapa"
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
 msgstr "Imprimir en estilo de script de consola"
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 #, fuzzy
 msgid "Length:"
 msgstr "Longitud: %f\n"
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 #, fuzzy
 msgid "Area:"
 msgstr "Área\n"
@@ -26319,7 +26386,7 @@
 msgstr "Error de análisis en la entrada en la línea %d"
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 #, fuzzy
 msgid "visualization"
 msgstr "Ecualización de histograma"
@@ -26402,306 +26469,356 @@
 msgid "Loading data failed"
 msgstr "Leyendo datos: "
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 #, fuzzy
 msgid "Unsupported output format"
 msgstr "Listar formatos de salida soportados"
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, fuzzy, c-format
 msgid "File <%s> created."
 msgstr "Archivo %s creado"
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
 msgstr "Varianza de la suma"
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
 msgstr "Nombre para el archivo de salida (NO añadir extensión)"
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 #, fuzzy
 msgid "Image"
 msgstr "Imágenes"
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 msgid "Graphics file format"
 msgstr "Formato de archivo gráfico"
-#: ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:104
 #, fuzzy
-msgid "Width and height of output image"
+msgid "Size (width, height) of output image"
 msgstr "Anchura y altura de cuadros en la cuadrícula"
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 #, fuzzy
 msgid "Name of raster map(s) for elevation"
 msgstr "Nombre del primer mapa ráster a mezclar"
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 #, fuzzy
 msgid "Elevation value(s)"
 msgstr "Valores Eigen:"
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 #, fuzzy
 msgid "Name of raster map(s) for color"
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 #, fuzzy
 msgid "Color value(s)"
 msgstr "Valores ID"
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 #, fuzzy
 msgid "Name of raster map(s) for mask"
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 #, fuzzy
 msgid "Name of raster map(s) for transparency"
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 #, fuzzy
 msgid "Name of raster map(s) for shininess"
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 #, fuzzy
 msgid "Name of raster map(s) for emission"
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 #, fuzzy
 msgid "Emission value(s)"
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 #, fuzzy
 msgid "Draw mode"
 msgstr "Modo panorámica"
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 #, fuzzy
 msgid "Fine resolution"
 msgstr "Usando resolución [%g]"
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 #, fuzzy
 msgid "Coarse resolution"
 msgstr "Correlación"
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 #, fuzzy
 msgid "Draw style"
 msgstr "Tipo de datos"
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 #, fuzzy
 msgid "Wire color"
 msgstr "Color de línea"
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 #, fuzzy
 msgid "Name of line vector overlay map(s)"
 msgstr "Las líneas/áreas vectoriales solapan el archivo(s)"
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 #, fuzzy
 msgid "Vector lines"
 msgstr "vectorial"
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 #, fuzzy
 msgid "Vector line width"
 msgstr "Ancho de línea"
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 #, fuzzy
 msgid "Vector line color"
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 #, fuzzy
 msgid "Vector line display mode"
 msgstr "Abrir formulario en modo edición"
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 #, fuzzy
 msgid "Vector line height"
 msgstr "vectorial, densidad de kernel"
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 #, fuzzy
 msgid "Name of point vector overlay map(s)"
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 #, fuzzy
 msgid "Vector points"
 msgstr "El vectorial no es 3D"
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 #, fuzzy
 msgid "Icon size"
 msgstr "Tamaño de símbolo"
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 #, fuzzy
 msgid "Icon width"
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 #, fuzzy
 msgid "Icon color"
 msgstr " nv color\n"
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 msgid "Icon marker"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 #, fuzzy
 msgid "Viewpoint position (x,y model coordinates)"
 msgstr "Posición de pantalla en coordenadas geográficas"
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 #, fuzzy
 msgid "Viewpoint height (in map units)"
 msgstr "Tamaño de icono para elementos punto (en unidades de mapa)"
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 #, fuzzy
 msgid "Viewpoint twist angle (in degrees)"
 msgstr "Ángulo de anisotropía (en grados)"
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 #, fuzzy
 msgid "Volumes"
 msgstr "Columnas"
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 #, fuzzy
 msgid "Volume draw mode"
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 #, fuzzy
 msgid "Volume position"
 msgstr "Proyeccion del origen"
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 #, fuzzy
 msgid "Volume resolution"
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 #, fuzzy
 msgid "Isosurface level"
 msgstr "Nivel mínimo de isosuperficies"
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+#, fuzzy
+msgid "Light position (x,y,z model coordinates)"
+msgstr "Posición de pantalla en coordenadas geográficas"
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+#, fuzzy
+msgid "Lighting"
+msgstr "Configuraciones"
+#: ../visualization/nviz2/cmd/args.c:584
+#, fuzzy
+msgid "Light color"
+msgstr "Color de selección"
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+msgstr "Escribiendo vértices..."
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+#, fuzzy
+msgid "Fringe"
+msgstr "Formateando"
+#: ../visualization/nviz2/cmd/args.c:625
+#, fuzzy
+msgid "Fringe color"
+msgstr "Color de línea"
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "Trazar elevación"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr ""
@@ -26841,132 +26958,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
 msgstr "No se pueden copuar elementos del mapa vectorial <%s>"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, c-format
-msgid "Failed in attempt to open %s"
-msgstr "Fallo al intentar de abrir %s"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr ""
-"Genera capas de mapa ráster de pendiente, orientación, curvaturas y "
-"derivadas parciales a partir de una capa de mapa ráster de valores reales de "
-"elevación. La orientación se calcula en sentido horario desde el Este."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr "Nombre del archivo de elevación ráster"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-msgid "Output slope filename"
-msgstr "Nombre de archivo de pendiente de salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-msgid "Output aspect filename"
-msgstr "Nombre de archivo de orientación de salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-msgid "Output profile curvature filename"
-msgstr "Nombre de archivo de curvatura de perfil de salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-msgid "Output tangential curvature filename"
-msgstr "Nombre de archivo de curvatura tangencial de salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr ""
-"Nombre de archivo de derivada dx (pendiente E-W) parcial de primer orden de "
-"salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr ""
-"Nombre de archivo de derivada dy (pendiente N-S) parcial de primer orden de "
-"salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-msgid "Output second order partial derivative dxx filename"
-msgstr "Nombre de archivo de derivada dxx parcial de segundo orden de salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-msgid "Output second order partial derivative dyy filename"
-msgstr "Nombre de archivo de derivada dyy parcial de segundo orden de salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-msgid "Output second order partial derivative dxy filename"
-msgstr "Nombre de archivo de derivada dxy parcial de segundo orden de salida"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"La opción -q está suplantada y se eliminará en el futuro. Por favor, use '--"
-"quiet' en su lugar."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, c-format
-msgid "wrong type: %s"
-msgstr "tipo incorrecto: %s"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-msgid "Creating support files..."
-msgstr "Creando archivos de soporte..."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr "Productos de elevación para el directorio de mapas [%s] en [%s]"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr "ORIENTACIÓN [%s] COMPLETA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr "PENDIENTE [%s] COMPLETA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr "CURVA DE PERFIL [%s] COMPLETA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr "CURVA TANGENCIAL [%s] COMPLETA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "PENDIENTE E-W [%s] COMPLETA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr "PENDIENTE N-S [%s] COMPLETA"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr "DXX [%s] COMPLETO"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr "DYY [%s] COMPLETO"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr "DXY [%s] COMPLETO"
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 msgid "Cannot load data from table"
@@ -27259,34 +27250,46 @@
 msgstr "Por favor, corrija la configuración"
 #: ../db/db.connect/main.c:49
-msgid "Prints/sets general DB connection for current mapset and exits."
+#, fuzzy
+msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
 "Imprime/establece la conexión general a la base de datos para el directorio "
 "de mapas actual y sale."
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 msgid "Print current connection parameters and exit"
 msgstr "Imprimir los parámetros de la conexión actual y salir"
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 #, fuzzy
 msgid "Check connection parameters, set if uninitialized, and exit"
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 msgid "Set"
 msgstr ""
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
+#, fuzzy
+msgid "Set from default settings and exit"
+msgstr "Establecido de la región predeterminada"
+#: ../db/db.connect/main.c:65
+#, fuzzy
+msgid "Overwrite current settings if initialized"
+msgstr "Sobrescribir MÁSCARA existente"
+#: ../db/db.connect/main.c:87
 msgid "Default group of database users to which select privilege is granted"
 msgstr "Grupo de usuarios por omisión que tiene privilegios de selección"
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 msgid "Database connection not defined. Run db.connect."
 msgstr "Conexión a base de datos no definida. Ejecute db.connect."
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -27294,11 +27297,11 @@
 "database: %s"
 msgstr ""
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr ""
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 #, fuzzy
 msgid "Default database is not set"
 msgstr "Nombre de la base de datos de entrada"
@@ -27553,7 +27556,7 @@
 msgid "'-' to read from standard input"
 msgstr "Si se da '-' lee de la entrada estándar"
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
 msgstr "Ignorar errores SQL y continuar"
@@ -27612,16 +27615,17 @@
 msgid "succeeded"
 msgstr "...conseguido."
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr "Sentencias de selección SQL"
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr "Por ejemplo: 'select * from rybniky where kapri = 'hodne'"
-#: ../db/db.select/main.c:215
-msgid "Name of file with sql statement"
+#: ../db/db.select/main.c:201
+#, fuzzy
+msgid "Name of file with SQL select statement(s)"
 msgstr "Nombre de archivo con sentencia SQL"
 #: ../db/db.select/main.c:247
@@ -27839,7 +27843,7 @@
 msgstr "Calcula la regresión lineal de dos mapas ráster: y = a + b*x"
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:6
@@ -27946,50 +27950,69 @@
 msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#, fuzzy
+msgid "Files & format"
+msgstr "Formato de la tabla"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
 msgid "Output coordinate file (omit to send to stdout)"
 msgstr "Archivo de coordenadas de salida (omitir para enviar a stdout)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 #, fuzzy
 msgid "Field separator (format: input[,output])"
 msgstr "Separador de campos (modo de puntos)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr "Parámetros de la proyección de entrada (en estilo PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#, fuzzy
+msgid "Projections"
+msgstr "Proyectando..."
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Output projection parameters (PROJ.4 style)"
 msgstr "Parámetros de la proyección de salida (en estilo PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr ""
 "Usar LL WGS84 como entrada y la localización actual como proyección de salida"
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr ""
 "Usar la localización actual como entrada y LL WGS84 como proyección de salida"
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+#, fuzzy
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
 "Producir latitud/longitud en grados decimales u otras proyecciones con "
 "muchos decimales"
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
 msgstr "Número de columna de las coordenadas Y en el archivo de entrada"
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "No incluir nombres de columna en la salida"
@@ -28251,6 +28274,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr "Listar reglas disponibles y salir"
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 #, fuzzy
 msgid "Prints a graph of the correlation between data layers (in pairs)."
@@ -28565,13 +28592,6 @@
 msgid "Raster map to use as mask"
 msgstr "Mapa ráster a usar como MÁSCARA"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Create"
-msgstr "Correlación"
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 #, fuzzy
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
@@ -28782,6 +28802,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -28795,7 +28816,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr "Condiciones WHERE de sentencia SQL sin palabra clave 'where'"
@@ -29176,19 +29197,24 @@
 "vectorial dado."
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-msgid "Vector map for which to edit attribute table"
+#, fuzzy
+msgid "Name of vector map for which to edit attribute table"
 msgstr "Mapa vectorial para el que editar la tabla de atributos"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Layer where to add column"
+#, fuzzy
+msgid "Layer number where to add column(s)"
 msgstr "Capa a la que añadir la columna"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 #, fuzzy
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 "Nombre y tipo de la nueva columna(s) (los tipos dependen de la base de datos "
 "de destino, pero todas soportan VARCHAR(), ENTERO, DOBLE Y FECHA)"
@@ -29335,7 +29361,7 @@
 msgstr "Listar las capas disponibles y salir"
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -29725,18 +29751,23 @@
 msgstr "Estadísticas ampliadas (cuartiles y percentiles 90)"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+#, fuzzy
+msgid "Print stats in shell script style"
+msgstr "Imprimir las estadísticas en estilo de script de consola"
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
 msgid "Name of data table"
 msgstr "Nombre de la tabla de datos"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr "Columna sobre la que calcular las estadísticas (debe ser numérica)"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 msgid "Database/directory for table"
 msgstr "Base de datos/directorio para la tabla"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 msgid "Database driver"
 msgstr "Controlador de base de datos"
@@ -29810,6 +29841,11 @@
 msgid "Signature file <%s> is invalid"
 msgstr "El archuvo de firma [%s] no es válido."
+#: ../imagery/i.smap/read_sig.c:30
+#, fuzzy, c-format
+msgid "Signature file <%s> is empty"
+msgstr "El archuvo de firma [%s] no es válido."
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 #, fuzzy
 msgid "Name of file containing signatures"
@@ -30391,19 +30427,19 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr "El grupo <%s> no contiene mapas. Ejecute i.group"
-#: ../imagery/i.rectify/main.c:202
+#: ../imagery/i.rectify/main.c:204
 #, fuzzy, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr "Usando la región: N=%f S=%f E=%f O=%f"
-#: ../imagery/i.rectify/main.c:216
+#: ../imagery/i.rectify/main.c:218
 #, fuzzy, c-format
 msgid ""
 "Input raster map <%s> does not exist in group <%s>.\n"
 " Try:\n"
 msgstr "El mapa ráster [%s] existe en el grupo."
-#: ../imagery/i.rectify/main.c:222
+#: ../imagery/i.rectify/main.c:224
 #, fuzzy
 msgid "Exit!"
 msgstr "Ya existe"
@@ -30497,7 +30533,7 @@
 msgid "Error while writing to temp file"
 msgstr "Error mientras se leía archivo de historia"
-#: ../imagery/i.rectify/write.c:54
+#: ../imagery/i.rectify/write.c:55
 #, fuzzy, c-format
 msgid "Error writing row %d"
 msgstr "Error al escribir la fila nula [%d]."
@@ -30507,13 +30543,13 @@
 msgid "Rectified input raster map <%s> will be saved as <%s>"
 msgstr "No se puede abrir el mapa ráster <%s> en el directorio de mapas <%s>"
-#: ../imagery/i.rectify/rectify.c:91
+#: ../imagery/i.rectify/rectify.c:90
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
 msgstr ""
 "No se ha encontrado el mapa ráster <%s> en el directorio de mapas actual"
-#: ../imagery/i.rectify/rectify.c:97
+#: ../imagery/i.rectify/rectify.c:96
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
 msgstr ""
@@ -31025,7 +31061,7 @@
 msgid "Name of input raster map (image fft, imaginary part"
 msgstr "Mapa ráster de entrada (imagen fft, parte imaginaria)"
-#: ../imagery/i.ifft/main.c:119
+#: ../imagery/i.ifft/main.c:115
 #, fuzzy
 msgid "The real and imaginary original windows did not match"
 msgstr "Las ventanas real e imaginaria original no coinciden."
@@ -32157,6 +32193,157 @@
 msgstr ""
 "No se puede marcar otro punto. Sólo se permiten puntos %d. Lo sentimos."
+#~ msgid "Not enough room in history file"
+#~ msgstr "Espacio insuficiente en archivo histórico"
+#~ msgid "New MAPSET name"
+#~ msgstr "Nombre del nuevo DIRECTORIO DE MAPAS"
+#, fuzzy
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
+#, fuzzy
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "Columna <%s> no encontrada en la tabla <%s>"
+#, fuzzy
+#~ msgid "Name of workspace file"
+#~ msgstr "Nombre de archivo de color"
+#, fuzzy
+#~ msgid "Displays raster map layer in the active map display window."
+#~ msgstr ""
+#~ "Muestra y superpone las capas del mapa ráster en el marco activo de la "
+#~ "pantalla."
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr "Lista de valores a mostrar (mapas FP)"
+#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
+#~ msgstr ""
+#~ "Ignorando lista de categorías: el mapa es coma flotante (por favor use "
+#~ "'val=')"
+#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
+#~ msgstr ""
+#~ "Ignorando lista de valores: el mapa es entero (por favor user 'cat=')"
+#~ msgid "Area size [%.1e], area not imported"
+#~ msgstr "Tamaño de área [%.1e]. Área no importada"
+#~ msgid "Island size [%.1e], island not imported"
+#~ msgstr "Tamaño de isla [%.1e]. Isla no importada"
+#, fuzzy
+#~ msgid ""
+#~ "No vector map of sparse points to interpolate was specified. "
+#~ "Interpolation will be done with <%s> vector map"
+#~ msgstr ""
+#~ "Ningún mapa vectorial a interpolar. La interpolación se hará con el mapa "
+#~ "vectorial <%s>"
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "Fallo al intentar de abrir %s"
+#~ msgid ""
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr ""
+#~ "Genera capas de mapa ráster de pendiente, orientación, curvaturas y "
+#~ "derivadas parciales a partir de una capa de mapa ráster de valores reales "
+#~ "de elevación. La orientación se calcula en sentido horario desde el Este."
+#~ msgid "Raster elevation file name"
+#~ msgstr "Nombre del archivo de elevación ráster"
+#~ msgid "Output slope filename"
+#~ msgstr "Nombre de archivo de pendiente de salida"
+#~ msgid "Output aspect filename"
+#~ msgstr "Nombre de archivo de orientación de salida"
+#~ msgid "Output profile curvature filename"
+#~ msgstr "Nombre de archivo de curvatura de perfil de salida"
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "Nombre de archivo de curvatura tangencial de salida"
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr ""
+#~ "Nombre de archivo de derivada dx (pendiente E-W) parcial de primer orden "
+#~ "de salida"
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#~ msgstr ""
+#~ "Nombre de archivo de derivada dy (pendiente N-S) parcial de primer orden "
+#~ "de salida"
+#~ msgid "Output second order partial derivative dxx filename"
+#~ msgstr ""
+#~ "Nombre de archivo de derivada dxx parcial de segundo orden de salida"
+#~ msgid "Output second order partial derivative dyy filename"
+#~ msgstr ""
+#~ "Nombre de archivo de derivada dyy parcial de segundo orden de salida"
+#~ msgid "Output second order partial derivative dxy filename"
+#~ msgstr ""
+#~ "Nombre de archivo de derivada dxy parcial de segundo orden de salida"
+#~ msgid ""
+#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
+#~ "quiet' instead."
+#~ msgstr ""
+#~ "La opción -q está suplantada y se eliminará en el futuro. Por favor, use "
+#~ "'--quiet' en su lugar."
+#~ msgid "wrong type: %s"
+#~ msgstr "tipo incorrecto: %s"
+#~ msgid "Creating support files..."
+#~ msgstr "Creando archivos de soporte..."
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "Productos de elevación para el directorio de mapas [%s] en [%s]"
+#~ msgid "ASPECT [%s] COMPLETE"
+#~ msgstr "ORIENTACIÓN [%s] COMPLETA"
+#~ msgid "SLOPE [%s] COMPLETE"
+#~ msgstr "PENDIENTE [%s] COMPLETA"
+#~ msgid "PROFILE CURVE [%s] COMPLETE"
+#~ msgstr "CURVA DE PERFIL [%s] COMPLETA"
+#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
+#~ msgstr "CURVA TANGENCIAL [%s] COMPLETA"
+#~ msgid "E-W SLOPE [%s] COMPLETE"
+#~ msgstr "PENDIENTE E-W [%s] COMPLETA"
+#~ msgid "N-S SLOPE [%s] COMPLETE"
+#~ msgstr "PENDIENTE N-S [%s] COMPLETA"
+#~ msgid "DXX [%s] COMPLETE"
+#~ msgstr "DXX [%s] COMPLETO"
+#~ msgid "DYY [%s] COMPLETE"
+#~ msgstr "DYY [%s] COMPLETO"
+#~ msgid "DXY [%s] COMPLETE"
+#~ msgstr "DXY [%s] COMPLETO"
+#, fuzzy
+#~ msgid ""
+#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
+#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
+#~ "PRECISION and DATE)"
+#~ msgstr ""
+#~ "Nombre y tipo de la nueva columna(s) (los tipos dependen de la base de "
+#~ "datos de destino, pero todas soportan VARCHAR(), ENTERO, DOBLE Y FECHA)"
 #~ msgid "Sources and sinks in [m^3/s]"
 #~ msgstr "Fuentes y sumideros en [m³/s]"
@@ -33948,10 +34135,6 @@
 #~ "vectorial <%s>"
-#, fuzzy
-#~ msgid "<%s> vector map will be interpolated"
-#~ msgstr "No se creará ningún dato vectorial."
 #~ msgid "vector, LIDAR, edges"
 #~ msgstr "vectorial, LIDAR, bordes"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_fr.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -11,7 +11,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_fr\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2008-07-19 23:20+0100\n"
 "Last-Translator: Pascal Obstétar <pascal.obstetar at wanadoo.fr>\n"
 "Language-Team: Français <grass-translations at lists.osgeo.org>\n"
@@ -21,7 +21,7 @@
 "X-Generator: KBabel 1.10.2\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 msgid "Error closing 3d raster map"
@@ -63,7 +63,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "Valeur raster"
@@ -83,7 +83,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -181,7 +181,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -196,41 +195,41 @@
 msgid "Error opening grid3 file [%s]"
 msgstr "Erreur d'ouverture du fichier de cellules 3D [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 msgid "Cannot allocate memory for string"
 msgstr ""
 "Impossible de calculer le centroïde de la surface (problème d'allocation "
 "mémoire)"
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, c-format
 msgid "Error reading range for [%s]"
 msgstr "Erreur de lecture de l'intervalle pour [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 #, fuzzy
 msgid "Error while reading history file"
 msgstr "Erreur à la lecture du fichier de signatures."
@@ -264,7 +263,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -292,7 +291,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "Erreur de fermeture du fichier raster 3D"
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 #, fuzzy
 msgid "Error closing ascii file"
 msgstr "Erreur de fermeture du fichier VTK-ASCII"
@@ -1170,7 +1169,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1185,7 +1184,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1218,17 +1217,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1283,7 +1281,7 @@
 msgstr "impossible d'ouvrir le fichier pour %s"
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 #, fuzzy
 msgid "List supported formats and exit"
 msgstr "Lister les formats gérés et quitter"
@@ -1297,22 +1295,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1363,7 +1361,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 msgid "Name of input raster map"
@@ -1683,13 +1680,29 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr "Nombre de lignes à garder en mémoire"
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
 #, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "Coordonnée x illégale <%s>"
+# c-format
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr "Coordonnée Nord <%s> illégale"
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr "Coordonnées Est <%s> illégale"
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
+#, fuzzy, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "classe %d (%d)\n"
 # c-format
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 #, fuzzy
 msgid "Writing raster map..."
@@ -1711,12 +1724,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1746,7 +1759,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1756,7 +1769,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1828,13 +1841,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1850,7 +1863,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1861,8 +1874,8 @@
 msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
 # c-format
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1874,7 +1887,7 @@
 msgstr "Impossible de créer le fichier de cellules pour [%s]"
 # c-format
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1884,8 +1897,8 @@
 msgstr "impossible de créer la sortie <%s>"
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2186,7 +2199,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, fuzzy, c-format
@@ -2276,10 +2289,10 @@
 msgid "Output world file"
 msgstr "Sortie du fichier TIFF world"
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, c-format
 msgid "[%s]: No such color"
 msgstr "[%s] ne correspond pas à une couleur connue"
@@ -2300,11 +2313,11 @@
 msgid "Writing world file"
 msgstr "Écriture du fichier TIFF World..."
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 msgid "Got null file name"
 msgstr "Reçu un nom de fichier null"
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr "Reçu une structure de région null"
@@ -2481,7 +2494,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2615,8 +2628,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 #, fuzzy
 msgid "Required"
 msgstr "Requête"
@@ -2640,7 +2653,7 @@
 msgid "Metadata"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 msgid "Name for new location to create"
 msgstr "Nom du nouveau Secteur (location) à créer"
@@ -2649,7 +2662,7 @@
 msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 msgid "Extend location extents based on new dataset"
 msgstr "Étendre le Secteur actuel en fonction des données importés"
@@ -2693,7 +2706,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2740,7 +2753,7 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
@@ -2749,7 +2762,7 @@
 "GRASS ; impossible de créer le nouveau Secteur"
 # c-format
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, fuzzy, c-format
 msgid "Location <%s> created"
 msgstr "Secteur %s créé!"
@@ -2764,13 +2777,13 @@
 "au format GRASS pour vérification"
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 #, fuzzy
 msgid "Over-riding projection check"
 msgstr "Projection source"
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 #, fuzzy
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
@@ -2792,7 +2805,7 @@
 # c-format
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 #, fuzzy
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "Secteur : %s\n"
@@ -2817,7 +2830,7 @@
 "des données en entrée.\n"
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 #, fuzzy
 msgid "Projection of input dataset and current location appear to match"
 msgstr ""
@@ -2961,30 +2974,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr ""
@@ -3187,12 +3197,14 @@
 msgstr "La valeur en sortie est l'erreur d'interpolation"
 #: ../raster/r.resamp.bspline/main.c:92
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:100
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -3236,7 +3248,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -3244,7 +3256,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -3274,7 +3286,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3292,7 +3304,7 @@
 msgstr "Impossible de créer la couche raster <%s>"
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3305,7 +3317,7 @@
 msgstr ""
 # c-format
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 #, fuzzy
 msgid "Writing output..."
 msgstr "Écriture %s..."
@@ -3525,7 +3537,7 @@
 msgstr ""
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 #, fuzzy
 msgid "metadata"
 msgstr "Importation vecteur complète"
@@ -3604,7 +3616,7 @@
 msgstr "couche vecteur <%s> introuvable"
 # c-format
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3615,39 +3627,34 @@
 msgid "Unable to open input file <%s>"
 msgstr "impossible d'ouvrir le fichier en entrée <%s>"
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-#, fuzzy
-msgid "Not enough room in history file"
-msgstr "Pas assez de place dans le fichier historique"
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "Editer le fichier de catégorie de [%s]?"
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, fuzzy, c-format
 msgid "cats table for [%s] set to %s"
 msgstr "Table de couleur de [%s] mise à jour à %s"
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr "[%s] est la reclassification d'une autre couche. Sortie."
 # c-format
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, c-format
 msgid "Writing new null file for [%s]... "
 msgstr "Écriture du nouveau fichier null de [%s]..."
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr "Suppression du fichier null pour [%s]...\n"
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 msgid "Done."
 msgstr "Terminé."
@@ -4743,12 +4750,10 @@
 "Nom de la couche raster de sortie"
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 msgid "Format for reporting the slope"
 msgstr "Format de sortie pour la pente"
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 msgid "Type of output aspect and slope maps"
 msgstr "Type de sortie pour les couches d'aspect et de pente"
@@ -4794,19 +4799,16 @@
 msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxy"
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr "Facteur multiplicatif pour convertir les unités d'altitude en mètres"
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr ""
 "Valeur de pente minimale (en pourcentage) pour laquelle l'aspect doit être "
 "calculé"
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 msgid "Do not align the current region to the elevation layer"
 msgstr "Ne pas aligner la région actuelle sur la couche d'altitude"
@@ -4850,63 +4852,61 @@
 msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, fuzzy, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr "aspect minimum calculé %.4f aspect maximum calculé %.4f"
 # c-format
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, fuzzy, c-format
 msgid "Aspect raster map <%s> complete"
 msgstr "fichier de cellules slopein <%s> non trouvé"
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, fuzzy, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr "pente minimum calculée %.4f pente maximum calculée %.4f"
 # c-format
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, fuzzy, c-format
 msgid "Slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, fuzzy, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr "Nom du fichier raster en sortie pour la courbure de profil"
 # c-format
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, fuzzy, c-format
 msgid "Tangential curve raster map <%s> complete"
 msgstr "Impossible de créer la couche raster %s"
 # c-format
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, fuzzy, c-format
 msgid "E-W slope raster map <%s> complete"
 # c-format
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, fuzzy, c-format
 msgid "N-S slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, fuzzy, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr "couche raster 3D <%s> non trouvée"
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, fuzzy, c-format
 msgid "Dyy raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, fuzzy, c-format
 msgid "Dxy raster map <%s> complete"
@@ -5008,7 +5008,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -5211,7 +5211,6 @@
 msgstr "Nom de la couche cible"
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr "Pourcentage complet :"
@@ -5728,69 +5727,69 @@
 msgid "Filter <%s> not found"
 msgstr "raster <%s> non trouvé"
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 #, fuzzy
 msgid "resample"
 msgstr "couche raster à échantillonner"
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr "Génère une couche raster montrant les sous-bassins versants."
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 msgid "Filter radius (horizontal)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr "Propager les valeurs NULL"
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 #, fuzzy
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr ""
 "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
 "qu'un seul."
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, fuzzy, c-format
 msgid "Too many filters (max: %d)"
 msgstr "** <%s> a trop de signatures (le plafond est 255)"
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "2 couches doivent être spécifiées"
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, c-format
 msgid "Unable to read color table for %s"
 msgstr "Impossible de lire la table de couleur %s"
@@ -6397,7 +6396,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr "%s: %s - unités illégales"
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, c-format
 msgid "Unknown method <%s>"
 msgstr "Méthode inconnue <%s>"
@@ -6419,7 +6418,7 @@
 msgid "Aggregate operation"
 msgstr "Opération d'agrégation"
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
@@ -8546,6 +8545,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 #, fuzzy
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr "Centile à calculer (requiert le drapeau -e)"
@@ -8918,34 +8918,34 @@
 msgid "Pass %d..."
 msgstr "Masque: %s\n"
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr ""
 "Exporte une couche raster GRASS vers un fichier binaire au format MAT-File"
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 #, fuzzy
 msgid "Name for new TIFF file"
 msgstr "Nom du nouveau fichier TIFF"
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr "compression du fichier TIFF"
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr "sortie de Palette TIFF (8 bit à la place de 24 bit)"
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 msgid "Output TIFF world file"
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 msgid "Output Tiled TIFF"
 msgstr "Fichier de sortie Tiled TIFF"
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, fuzzy, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
@@ -8954,7 +8954,7 @@
 "La couche <%s> du jeu de données <%s> est une couche en point flottant. Les "
 "valeurs décimales seront arrondies à l'entier!"
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
@@ -8963,17 +8963,17 @@
 "l'intervalle disponible de données"
 # c-format
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, fuzzy, c-format
 msgid "Unable to open TIFF file <%s>"
 msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 #, fuzzy
 msgid "Writing TIFF World file"
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 #, fuzzy
 msgid "Unable to open TIFF world file for writing"
 msgstr "Impossible d'ouvrir le fichier TIFF world pour l'écriture"
@@ -9091,7 +9091,7 @@
 msgstr "Rotation des données ... "
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -9099,21 +9099,21 @@
 "[%s]"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
@@ -9125,17 +9125,17 @@
 # c-format
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, fuzzy, c-format
 msgid "%lu points found in region."
 msgstr "%d points en dehors de la région courante"
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 #, fuzzy
 msgid "Scanning data ..."
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr ""
@@ -9702,73 +9702,73 @@
 msgid "unable to open <%s> mask ... continuing without!"
 msgstr "CHILD[pid = %i] : impossible d'ouvrir le mask %s... continuer sans!!!"
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 #, fuzzy
 msgid "Cannot create random access file"
 msgstr "Impossible de créer le fichier d'accès aléatoire\n"
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr "Impossible de créer le répertoire .r.li"
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
 msgstr "Impossible de créer le répertoire .r/li/en sortie"
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
 msgstr "Impossible de faire les stats du fichier de configuration %s"
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 msgid "Cannot read setup file"
 msgstr "Impossible de lire le fichier de configuration"
 # c-format
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 msgid "Irregular maskedoverlay areas definition"
 msgstr "Définitions de zones irrégulières maskedoverlay"
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
 "Le fichier de configuration peut seulement être utilisé avec les fichiers "
 "raster \t\t\t%s"
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 msgid "Illegal configuration file (sample area)"
 msgstr "Nom du fichier de configuration illégal (zone d'échantillonnage)"
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 #, fuzzy
 msgid "Too many units to place"
 msgstr "Beaucoup trop d'unités à placer"
 # c-format
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 #, fuzzy
 msgid "Too many strats for raster map"
 msgstr "Beaucoup trop de stats pour le fichier raster\n"
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr "Disposition de zones illégale"
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 #, fuzzy
 msgid "Cannot make lseek"
 msgstr "Impossible d'exécuter lseek\n"
@@ -10117,8 +10117,8 @@
 #: ../raster/r.out.gdal/export_band.c:201
 #, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 # c-format
@@ -10307,7 +10307,7 @@
 msgid "Name of color file"
 msgstr "Nom du fichier d'étiquettes"
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 #, fuzzy
 msgid "Vertical exaggeration"
 msgstr "Facteur d'échelle vertical"
@@ -10369,17 +10369,24 @@
 msgid "File containing expression(s) to evaluate"
 msgstr "Fichier contenant les signatures initiales"
+#: ../raster/r.mapcalc/main.c:145
+#, fuzzy
+msgid "file= and expression= are mutually exclusive"
+msgstr ""
+"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
+"qu'un seul."
 # c-format
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:155
 #, fuzzy
 msgid "parse error"
 msgstr "%d erreurs de mise à jour"
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr ""
@@ -10724,8 +10731,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 #, fuzzy
 msgid "Position"
@@ -11360,8 +11367,8 @@
 "unique (uniquement pour les CELL)"
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 #, fuzzy
 msgid "Attributes"
@@ -11412,7 +11419,7 @@
 msgstr "Impossible d'insérer dans la table: %s"
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "Impossible d'insérer une nouvelle ligne : %s"
@@ -11832,19 +11839,19 @@
 "Impossible de récupérer les infos de projection du Secteur courant : "
 "veuillez régler la latitude grâce à 'lat' ou à l'option 'latin'!"
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr "OOPS : lignes changées de %d vers %d"
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr "OOPS : colonnes changées de %d vers %d"
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -11861,7 +11868,7 @@
 msgstr "Erreur dans pj_do_proj"
 # c-format
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr "Impossible d'écrire la couche raster lac <%s>!"
@@ -12273,7 +12280,7 @@
 msgid "Raster map(s) to report on"
 msgstr "couche(s) raster à analyser"
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr ""
@@ -12313,7 +12320,6 @@
 msgstr "Nom du fichier où stocker le résultat"
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 msgid "Quiet"
 msgstr "Silencieux"
@@ -12850,13 +12856,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr ""
@@ -13080,17 +13079,17 @@
 msgid "Writing topographic index map..."
 msgstr "couche d'indice topographique ln(a/tan(beta))"
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 #, fuzzy
 msgid "Resamples raster map layers to a coarser grid using aggregation."
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 #, fuzzy
 msgid "Aggregation method"
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 msgid "Weight according to area (slower)"
 msgstr ""
@@ -13529,13 +13528,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -13573,15 +13572,66 @@
 msgid "Access for others"
 msgstr ""
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr ""
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 #, fuzzy
 msgid "Unable to determine mapset permissions"
 msgstr "Impossible de déterminer le type de cellule raster"
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "Impossible de déterminer le type de cellule raster"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+#, fuzzy
+msgid "read "
+msgstr "Entité surfacique\n"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 #, fuzzy
 msgid "Error reading WKT projection description"
@@ -14280,52 +14330,52 @@
 msgid "Error conducting transform (%d)"
 msgstr "Erreur de lecture des cellules de données"
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr ""
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr ""
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 #, fuzzy
 msgid "Parameter error"
 msgstr "Paramètres du cluster\n"
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 #, fuzzy
 msgid "No active control points"
 msgstr "Pas de points de départ"
 # c-format
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
 msgstr "Coordonnées invalides : %s %s"
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 #, fuzzy
 msgid "transformation"
 msgstr "Nombre de points d'interpolation"
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 #, fuzzy
 msgid "Computes a coordinate transformation based on the control points."
 msgstr ""
 "Recale une image en calculer la transformation de coordonnées pour chaque "
 "pixel de l'image basée sur des points d'amer"
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 #, fuzzy
 msgid "Rectification polynomial order"
 msgstr "Ordre du polynome de recalage (1-3)"
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -14333,36 +14383,36 @@
 "difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 msgid "Output format"
 msgstr "Format de sortie"
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 #, fuzzy
 msgid "Display summary information"
 msgstr "Afficher la position de référence"
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr "Fichier ascii contenant les signatures spectrales"
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 #, fuzzy
 msgid "Local x,y coordinates to target east,north"
 msgstr "Coordonnées du centre (E et N)"
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 #, fuzzy
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr "utiliser les règles de transformation pour LANDSAT-4"
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 #, fuzzy
 msgid "Target east,north coordinates to local x,y"
 msgstr "Utiliser les coordonnées du centre de la couche\n"
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 #, fuzzy
 msgid "Display transform matrix coefficients"
 msgstr "Couche pour le coefficient x"
@@ -14377,94 +14427,97 @@
 msgid "Change current mapset."
 msgstr "Sauvegarder cadre graphique actif"
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
 msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "Nom de la couche en sortie où les erreurs seront écrites"
+#: ../general/g.mapset/main.c:63
+msgid "Location name (not location path)"
 msgstr ""
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr ""
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 #, fuzzy
 msgid "Create mapset if it doesn't exist"
 msgstr "Créer le nouveau fichier s'il n'existe pas."
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
 #, fuzzy
+msgid "Create"
+msgstr "Corrélation"
+#: ../general/g.mapset/main.c:86
+#, fuzzy
 msgid "List available mapsets"
 msgstr "Lister les formats disponibles et quitter"
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 #, fuzzy
 msgid "Either mapset= or -l must be used"
 msgstr "L'une des options, soit texte soit -c, doit être sélectionnée."
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, fuzzy, c-format
 msgid "<%s> is already the current mapset"
 msgstr "ERREUR: <%s> existe déjà dans le jeu de données <%s>\n"
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 msgid "You don't have permission to use this mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 #, fuzzy
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr ""
 "La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 #, fuzzy
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr "Impossible de lire la valeur ew_res"
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
 "checked"
 msgstr ""
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 #, fuzzy
 msgid "Cleaning up temporary files..."
 msgstr "Création de fichiers temporaires..."
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 msgid "Your shell continues to use the history for the old mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
 msgstr ""
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
 msgstr ""
-#: ../general/g.mapsets/dsply_path.c:19
-#, fuzzy, c-format
-msgid "Your mapset search list:\n"
-msgstr "Jeu(x) de données à lister (par défaut le jeu de données courant)"
-# c-format
-#: ../general/g.mapsets/dsply_path.c:29
-#, fuzzy, c-format
-msgid "<%s> not found in mapset list"
-msgstr "Colonne <%s> non trouvée"
 #: ../general/g.mapsets/main.c:62
 #, fuzzy
 msgid ""
@@ -14523,15 +14576,15 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr ""
-#: ../general/g.mapsets/dsply_maps.c:23
-#, fuzzy, c-format
+#: ../general/g.mapsets/list.c:10
+#, fuzzy
 msgid "Available mapsets:"
-#: ../general/g.mapsets/dsply_maps.c:33
-#, c-format
-msgid "** no mapsets **\n"
-msgstr ""
+#: ../general/g.mapsets/list.c:35
+#, fuzzy
+msgid "Accessible mapsets:"
+msgstr "Lister les formats disponibles et quitter"
 #: ../general/g.copy/main.c:43
 msgid ""
@@ -15124,28 +15177,28 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, fuzzy, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
@@ -15153,14 +15206,14 @@
 "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être "
 "écrasé!\n"
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
 # c-format
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "Impossible d'ouvrir le fichier [%s]"
@@ -15183,13 +15236,12 @@
 msgstr ""
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-#, fuzzy
-msgid "Name of workspace file"
-msgstr "Nom du fichier d'étiquettes"
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
 #: ../general/g.gui/main.c:57
 msgid "Update default GUI setting"
@@ -15204,6 +15256,11 @@
 msgid "<%s> is now the default GUI"
 msgstr ""
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 #, fuzzy
 msgid "Force remove"
@@ -15246,7 +15303,7 @@
 msgid "Unable to read FP range for %s"
 msgstr "%s: impossible de lire l'intervalle pour [%s]"
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -15261,7 +15318,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -15291,7 +15348,7 @@
 msgid "At least two points are required"
 msgstr "Coordonnées pour la requête"
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -15304,7 +15361,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -15312,7 +15369,7 @@
 msgid "No graphics device selected"
 msgstr "Aucune sortie graphique n'est sélectionnée"
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
@@ -15320,41 +15377,41 @@
 "Sélectionnez la police à utiliser pour afficher le texte sur le moniteur "
 "graphique."
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 #, fuzzy
 msgid "Choose new current font"
 msgstr "Utiliser la région courante"
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 #, fuzzy
 msgid "Path to Freetype-compatible font including file name"
 msgstr "Chemin pour la police TrueType (nom de fichier inclus)"
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr "Encodage du caractère"
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 #, fuzzy
 msgid "List fonts"
 msgstr "Lister tous les moniteurs"
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 #, fuzzy
 msgid "List fonts verbosely"
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, fuzzy, c-format
 msgid "Unable to access font path %s: %s"
 msgstr "Impossible de lire la ligne %i\n"
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, fuzzy, c-format
 msgid "Font path %s is not a file"
 msgstr "<%s> n'est pas un nom valide pour une couche GRASS"
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -15850,6 +15907,7 @@
 msgstr "Affiche la légende de la couche raster du moniteur actif."
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 msgid "Name of raster map"
 msgstr "Nom de la couche raster"
@@ -16047,8 +16105,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -16300,33 +16358,33 @@
 msgstr "Code de couche. Si fixé à -1, toutes les couches sont affichées."
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 #, fuzzy
 msgid "Selection"
 msgstr "Résolution"
@@ -16372,7 +16430,7 @@
 msgstr "'layer' doit être >0 pour 'cats'."
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, c-format
 msgid "Database connection not defined"
 msgstr "La connexion à la base de données n'a pas été définie"
@@ -16380,8 +16438,8 @@
 # c-format
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -17195,44 +17253,51 @@
 msgid "Error: %s\n"
 msgstr "Erreur: %s\n"
-#: ../display/d.rast/main.c:55
+#: ../display/d.rast/main.c:54
 #, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
+msgid "Displays raster map layer."
+msgstr "Statistique de couches raster."
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 msgid "Raster map to be displayed"
 msgstr "couche raster à afficher"
-#: ../display/d.rast/main.c:67
-msgid "List of categories to be displayed (INT maps)"
+#: ../display/d.rast/main.c:66
+#, fuzzy
+msgid "List of categories or values to be displayed"
 msgstr "Liste de catégories à afficher (couche en entiers INT)"
-#: ../display/d.rast/main.c:76
-msgid "List of values to be displayed (FP maps)"
-msgstr "Liste de valeurs à afficher (couche en flottants FP)"
-#: ../display/d.rast/main.c:85
+#: ../display/d.rast/main.c:72
 msgid "Background color (for null)"
 msgstr "Couleur de fond (pour null)"
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+#, fuzzy
+msgid "Either a standard color name or R:G:B triplet"
+msgstr "Couleur du texte, une couleur GRASS standard ou triplet R:G:B"
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
+#: ../display/d.rast/main.c:81
+#, fuzzy
+msgid "Invert value list"
 msgstr "Inverser la catlist"
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
 msgstr ""
-"Catlist ignorée : la couche est en valeurs flottantes (veuillez utiliser "
-"'val=')"
+"\n"
+"<%s> -- valeur illégale de min_size"
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr "Vallist ignorée : la couche est en entier (veuillez utiliser 'cat=')"
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
+msgstr ""
+"\n"
 #: ../display/d.rast.num/main.c:73
 msgid ""
@@ -17587,11 +17652,6 @@
 msgid "Label color"
 msgstr "Couleur d'étiquette"
-#: ../display/d.vect/main.c:263
-#, fuzzy
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "Couleur du texte, une couleur GRASS standard ou triplet R:G:B"
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr "Couleur de fond d'étiquette"
@@ -17880,7 +17940,7 @@
 msgstr "Type de colonne (%s) non géré"
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -17903,7 +17963,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
 msgstr "Impossible de créer l'index"
@@ -17922,7 +17982,7 @@
 msgstr "Pas d'enregistrement pour la catégorie '%d' dans la table"
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -17935,7 +17995,7 @@
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -17963,7 +18023,7 @@
 msgstr "nom de la base de donnée"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -18031,7 +18091,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -18295,7 +18355,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, fuzzy, c-format
@@ -18443,10 +18503,8 @@
 msgstr "Code de couche"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 #, fuzzy
 msgid "Query"
 msgstr "Silencieux"
@@ -18847,17 +18905,17 @@
 msgid "Unable to build topology for <%s>"
 msgstr "Vecteur d'arrivée introuvable %s"
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "Convertit des fichiers vecteurs OGR dans GRASS. Pilotes disponibles:\n"
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 #, fuzzy
 msgid "OGR datasource name"
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 #, fuzzy
 msgid ""
 "Examples:\n"
@@ -18868,14 +18926,14 @@
 "\t\t Shapefile ESRI : répertoire contenant des shapefiles\n"
 "\t\tFichier MapInfo : répertoire contenant des fichiers mapinfo"
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 #, fuzzy
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
 "Couche vectorielle cible, si elle n'est pas indiquée, les couches "
 "disponibles seront seulement affichées"
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 #, fuzzy
 msgid ""
 "Examples:\n"
@@ -18886,32 +18944,32 @@
 "\t\tShapefile ESRI : nom du shapefile\n"
 "\t\tFichier MapInfo : nom du fichier mapinfo"
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 #, fuzzy
 msgid "Import subregion only"
 msgstr "Afficher seulement la région de la couche raster"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 #, fuzzy
 msgid "Subregion"
 msgstr "Région\n"
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 #, fuzzy
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr ""
 "Importer la sous-région seulement (xmin,ymin,xmax,ymax  - habituellement O,S,"
 "E,N)"
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 #, fuzzy
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
@@ -18919,12 +18977,12 @@
 "entités plus petites et les îles sont ignorées. Elle doit être supérieure à "
 "snap^2"
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 #, fuzzy
 msgid "Optionally change default input type"
 msgstr "Titre du fichier raster de sortie"
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 #, fuzzy
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
@@ -18936,16 +18994,16 @@
 "\t boundary -> importe les lignes comme contours\n"
 "\t centroid -> importe les points comme centroïdes"
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 #, fuzzy
 msgid "Snapping threshold for boundaries"
 msgstr "Seuil de capture pour les contours. -1 pour 'pas de capture'"
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
@@ -18953,84 +19011,84 @@
 "Liste de noms de colonnes à utiliser à la place des noms originaux, le "
 "premier correspondà la colonne de catégorie"
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 msgid "List available layers in data source and exit"
 msgstr "Lister les couches disponibles dans l'emplacement source et quitter"
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 msgid "Do not clean polygons (not recommended)"
 msgstr "Ne pas nettoyer les polygones (non recommandé)"
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 msgid "Create 3D output"
 msgstr "Crée une sortie 3D"
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 msgid "Do not create attribute table"
 msgstr "Ne pas créer de table attributaire"
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 #, fuzzy
 msgid "Override dataset projection (use location's projection)"
 msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 #, fuzzy
 msgid "Limit import to the current region"
 msgstr "Ne pas modifier la région courante"
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr ""
 # c-format
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, fuzzy, c-format
 msgid "Unable to open data source <%s>"
 msgstr "Impossible d'ouvrir la couche raster <%s>"
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Le vecteur '%s' existe déjà."
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists"
 msgstr "ERREUR: <%s> existe déjà\n"
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, fuzzy, c-format
 msgid "Layer <%s> not available"
 msgstr "La couche '%s' n'est pas disponible"
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 #, fuzzy
 msgid "4 parameters required for 'spatial' parameter"
 msgstr "4 paramètres sont requis pour le paramètre 'spatial'"
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
@@ -19039,12 +19097,12 @@
 "au format GRASS pour vérification"
 # c-format
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 #, fuzzy
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr "Secteur : %s\n"
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, fuzzy, c-format
 msgid ""
 "\n"
@@ -19053,7 +19111,7 @@
 "\n"
 "Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 #, fuzzy
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
@@ -19062,29 +19120,29 @@
 "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
 "des données en entrée.\n"
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "Erreur lors de la lecture du fichier dbmscap\n"
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, fuzzy, c-format
 msgid "Layer: %s"
 msgstr "couche %d"
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr "Nom de colonne modifié : '%s' -> '%s'"
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, fuzzy, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
 "Ecriture de la colonne <%s> de longueur fixée à 40 caractères (possible "
 "troncature des données)"
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, fuzzy, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
@@ -19093,7 +19151,7 @@
 "Largeur de la colonne '%s' fixée à 255 (non spécifiée par OGR), des chaînes "
 "risquent d'être tronquées"
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, fuzzy, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
@@ -19101,96 +19159,101 @@
 # c-format
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, c-format
 msgid "Column type not supported (%s)"
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
 #, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "Importation des objets de la couche %d..."
+#: ../vector/v.in.ogr/main.c:854
+#, fuzzy, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr "Distance de zone-tampon en unités carte."
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr "%d %s sans géométrie"
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 #, fuzzy
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr "Nettoyage des polygones, le résultat n'est pas garanti!\n"
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 #, fuzzy
 msgid "Break polygons:"
 msgstr "Exporter les lignes en tant que polygones"
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 #, fuzzy
 msgid "Remove duplicates:"
 msgstr "Suppression des centroïdes en doublons..."
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 #, fuzzy
 msgid "Merge boundaries:"
 msgstr "impossible de mettre à jour les limites"
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
 msgstr "Impossible de calculer le centroïde de la surface"
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, fuzzy, c-format
 msgid "Find centroids for layer: %s"
 msgstr "Fausse entrée pour le multiplicateur: %s"
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 #, fuzzy
 msgid "Write centroids:"
 msgstr "Écrire les sommets de lignes."
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -19202,53 +19265,53 @@
 "entités sont liées à plus d'un tuple de la table attributaire. Le nombre "
 "d'objets de ces entités est stocké comme une catégorie de la couche %d"
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, fuzzy, c-format
 msgid "%d input polygons\n"
 msgstr "%d polygones en entrée\n"
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, fuzzy, c-format
 msgid "%d input polygons"
 # c-format
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
 msgstr "Écriture %s..."
 # c-format
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
 # c-format
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
 # c-format
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
 # c-format
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
 msgstr "%d points sans catégorie"
 # c-format
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 #, fuzzy
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
@@ -19258,47 +19321,43 @@
 "sont uniquement 2D utilisez le drapeau -z pour importer des objets "
 "vectoriels 3D"
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+# c-format
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "Impossible d'écrire dans : %s"
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 #, fuzzy
 msgid "Cannot calculate centroid"
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr ""
 # c-format
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 #, fuzzy
 msgid "Cannot write part of geometry"
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 #, fuzzy
 msgid "Unknown geometry type"
 msgstr "Type de colonne inconnu"
@@ -19497,6 +19556,9 @@
 msgstr "Nom de la table source"
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 #, fuzzy
 msgid "Connection"
@@ -19534,12 +19596,12 @@
 # c-format
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, fuzzy, c-format
 msgid "Missing column <%s> in table <%s>"
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 #, fuzzy
 msgid "Data type of key column must be integer"
 msgstr "La clef primaire doit être un entier"
@@ -19760,8 +19822,8 @@
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 #, fuzzy
 msgid "From"
 msgstr "Type de donnée vectorielle"
@@ -19783,8 +19845,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 msgid "To"
 msgstr ""
@@ -19811,62 +19873,62 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr "Impossible d'accorder des privilèges sur la table : %s"
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
 msgstr ""
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 #, fuzzy
 msgid "Name of existing vector map (from)"
 msgstr "Nom de la couche vectorielle existante"
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 #, fuzzy
 msgid "Feature type (from)"
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 #, fuzzy
 msgid "Name of existing vector map (to)"
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 #, fuzzy
 msgid "Feature type (to)"
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 #, fuzzy
 msgid "Name for output vector map containing lines connecting nearest elements"
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 #, fuzzy
 msgid "Maximum distance or -1 for no limit"
 msgstr "Distance maximale du point au réseau"
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 #, fuzzy
 msgid "Minimum distance or -1 for no limit"
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr ""
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
 "to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
@@ -19878,154 +19940,160 @@
 "attribute of nearest feature given by to_column option"
 msgstr ""
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr ""
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 #, fuzzy
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr "Nom de la couche raster dont on veut rééchelonner les valeurs"
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr ""
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr ""
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
 msgstr ""
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr ""
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 #, fuzzy
 msgid "Too many column names"
 msgstr "Nom de la colonne y"
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 #, fuzzy
 msgid "Not enough column names"
 msgstr "Nom de colonne de catégorie"
 # c-format
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, fuzzy, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr "%d points  écrits dans la couche vecteur"
+# c-format
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 #, fuzzy
 msgid "Unable to open default database"
 msgstr "Impossible d'ouvrir la base de données %s"
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 #, fuzzy
 msgid "Incompatible column types"
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
 msgstr "Recherche des classes d'apprentissage..."
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 #, fuzzy
 msgid "Finding nearest areas..."
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr ""
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr ""
 # c-format
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, fuzzy, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr "%d catégories chargées depuis la couche vecteur"
 # c-format
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, fuzzy, c-format
 msgid "%d categories - no nearest feature found"
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr ""
 # c-format
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, fuzzy, c-format
 msgid "%d records inserted"
 msgstr "%d enregistrements mis à jour"
 # c-format
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, fuzzy, c-format
 msgid "%d insert errors"
 # c-format
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, fuzzy, c-format
 msgid "%d categories read from the map"
 msgstr "%d catégories chargées depuis la table"
 # c-format
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, fuzzy, c-format
 msgid "%d categories exist in the table"
 msgstr "%d catégories de la couche vecteur manquantes dans la table"
 # c-format
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, fuzzy, c-format
 msgid "%d categories read from the map exist in the table"
 # c-format
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, fuzzy, c-format
 msgid "%d categories read from the map don't exist in the table"
 # c-format
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, c-format
 msgid "%d records updated"
 # c-format
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, c-format
 msgid "%d update errors"
@@ -20416,7 +20484,7 @@
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -20437,7 +20505,7 @@
 msgstr "couche vecteur <%s> introuvable"
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
@@ -20473,14 +20541,13 @@
 msgid "Outlier detection"
 msgstr "Couleur de mise en valeur"
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
 # c-format
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 #, fuzzy
@@ -22167,52 +22234,59 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:273
-#, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:279
+#: ../vector/v.surf.bspline/main.c:274
 #, fuzzy, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr "Couche vecteur à requêter"
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
 "a raster output or other driver."
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr "Couche vecteur à requêter"
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+#: ../vector/v.surf.bspline/main.c:332
 msgid "Cannot read field info"
 msgstr "Impossible de lire les informations du champ"
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, fuzzy, c-format
 msgid "[%d] records selected from table"
 msgstr "%d enregistrements sélectionnés dans le tableau"
 # c-format
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, fuzzy, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr "impossible de créer la sortie <%s>"
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 #, fuzzy
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
 msgstr "Impossible d'allouer de la mémoire"
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, fuzzy, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr "Aucun enregistrement pour la ligne (cat = %d)"
+#: ../vector/v.surf.bspline/main.c:712
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -24771,9 +24845,11 @@
 msgid "Get area %d failed"
 msgstr "Importation vecteur complète"
+# c-format
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
-msgstr ""
+#, fuzzy
+msgid "Area without centroid (OK for island)"
+msgstr "%d points sans catégorie"
 # c-format
 #: ../vector/v.to.rast/do_areas.c:126
@@ -25978,11 +26054,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr "'layer' doit être > 0 pour 'where'."
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr ""
@@ -26004,7 +26080,7 @@
 msgid "Print topology information only"
 msgstr "Affiche l'information topologique (déboguage)"
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
 msgstr ""
@@ -26619,31 +26695,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, fuzzy, c-format
 msgid "Performing map %s + %s"
 msgstr "Erreur de lecture de la couche %s"
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr ""
@@ -26809,64 +26885,64 @@
 #: ../vector/v.db.connect/main.c:89
 #, fuzzy
-msgid "Print all map connection parameters and exit in shell script style"
+msgid "Print all map connection parameters in shell script style and exit"
 msgstr "Affiche les paramètres de connexion courants et quitte"
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
 "Affiche les types/noms des colonnes de la table pour une couche spécifiée et "
 "quitte"
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 msgid "Overwrite connection parameter for certain layer"
 msgstr "Ecrase les paramètres de connexion pour une couche donnée"
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 msgid "Delete connection for certain layer (not the table)"
 msgstr "Efface la connexion pour une couche donnée (mais n'efface pas la table"
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 msgid "Please choose only one print style"
 msgstr "Veuillez choisir une et un seul style d'affichage"
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 #, fuzzy
 msgid "Unable to modify vector map stored in other mapset"
 msgstr "Afficher des couches vecteur plutôt que des couches raster"
-#: ../vector/v.db.connect/main.c:165
+#: ../vector/v.db.connect/main.c:164
 #, fuzzy, c-format
-msgid "Vector map <%s> is connected by:"
+msgid "Vector map <%s> is connected by:\n"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr "Utilisez -o pour écraser le lien existant pour la couche <%d>"
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr "La table <%s> n'existe pas dans la base de données <%s>"
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
@@ -26875,16 +26951,16 @@
 "La table <%s> fait à présent partie de la couche vectorielle <%s> et risque "
 "d'être effacée ou écrasée par les modules GRASS"
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, c-format
 msgid "Cannot grant privileges on table %s"
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr "Des droits de sélection ont été accordés sur cette table"
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -27322,40 +27398,40 @@
 msgid "Name of Arc cost column"
 msgstr "Nombre de colonnes"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr ""
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 msgid "measurement"
 msgstr ""
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
 msgstr "Facteur d'échelle pour les coordonnées x"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 #, fuzzy
 msgid "Default: location map units"
 msgstr "Erreur de discrétisation en unités carte"
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
 msgstr "Produit les statistiques à la façon d'un script shell"
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 #, fuzzy
 msgid "Length:"
 msgstr "Longueur: %f\n"
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 #, fuzzy
 msgid "Area:"
@@ -27410,7 +27486,7 @@
 msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 #, fuzzy
 msgid "visualization"
@@ -27491,305 +27567,355 @@
 msgid "Loading data failed"
 msgstr "Rotation des données ... "
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 #, fuzzy
 msgid "Unsupported output format"
 msgstr "Lister les formats gérés en sor"
 # c-format
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, fuzzy, c-format
 msgid "File <%s> created."
 msgstr "Secteur %s créé!"
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
 msgstr "Variance de la somme"
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
 msgstr "Nom du fichier en sortie (ne PAS ajouter l'extension)"
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 #, fuzzy
 msgid "Image"
 msgstr "Groupe de fichiers image"
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 msgid "Graphics file format"
 msgstr "Format de fichier graphique"
-#: ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:104
 #, fuzzy
-msgid "Width and height of output image"
+msgid "Size (width, height) of output image"
 msgstr "Largeur de la couleur de mise en valeur"
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 #, fuzzy
 msgid "Name of raster map(s) for elevation"
 msgstr "Nom de la première couche raster pour le mélange"
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 #, fuzzy
 msgid "Elevation value(s)"
 msgstr "Erreur altimétrique"
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 #, fuzzy
 msgid "Name of raster map(s) for color"
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 #, fuzzy
 msgid "Color value(s)"
 msgstr "Valeur de la chaîne de bit"
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 #, fuzzy
 msgid "Name of raster map(s) for mask"
 msgstr "Nom de la couche raster utilisée comme masque (MASK)"
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 #, fuzzy
 msgid "Name of raster map(s) for transparency"
 msgstr "Nom de la couche raster d'aspect à afficher"
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 #, fuzzy
 msgid "Name of raster map(s) for shininess"
 msgstr "Nom de la couche raster qui contiendra les résultats"
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 #, fuzzy
 msgid "Name of raster map(s) for emission"
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 #, fuzzy
 msgid "Emission value(s)"
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 #, fuzzy
 msgid "Draw mode"
 msgstr "Mode Pan"
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 #, fuzzy
 msgid "Fine resolution"
 msgstr "Résolution"
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 #, fuzzy
 msgid "Coarse resolution"
 msgstr "Corrélation"
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 #, fuzzy
 msgid "Draw style"
 msgstr "Type de données"
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 #, fuzzy
 msgid "Wire color"
 msgstr "Couleur de ligne"
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 #, fuzzy
 msgid "Name of line vector overlay map(s)"
 msgstr "Nom de la couche vecteur"
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 #, fuzzy
 msgid "Vector lines"
 msgstr "Type de couche vecteur"
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 #, fuzzy
 msgid "Vector line width"
 msgstr "Epaisseur de ligne"
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 #, fuzzy
 msgid "Vector line color"
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 #, fuzzy
 msgid "Vector line display mode"
 msgstr "Ouvrir le formulaire en mode édition"
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 #, fuzzy
 msgid "Name of point vector overlay map(s)"
 msgstr "Nom de la couche vecteur 2D source"
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 #, fuzzy
 msgid "Vector points"
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 msgid "Icon size"
 msgstr "Taille d'icone"
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 #, fuzzy
 msgid "Icon width"
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 #, fuzzy
 msgid "Icon color"
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 #, fuzzy
 msgid "Icon marker"
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 #, fuzzy
 msgid "Viewpoint position (x,y model coordinates)"
 msgstr "Coordonnées du point germe"
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 #, fuzzy
 msgid "Viewpoint height (in map units)"
 msgstr "Ecart type minimum en unités carte"
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 #, fuzzy
 msgid "Viewpoint twist angle (in degrees)"
 msgstr "Angle d'anisotropie (en degrés)"
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 #, fuzzy
 msgid "Volumes"
 msgstr "colonne(s)"
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 #, fuzzy
 msgid "Volume position"
 msgstr "Projection source"
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 #, fuzzy
 msgid "Volume resolution"
 msgstr "Résolution"
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 #, fuzzy
 msgid "Isosurface level"
 msgstr "Altitude minimale de l'iso-surface"
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+#, fuzzy
+msgid "Light position (x,y,z model coordinates)"
+msgstr "Coordonnées du point germe"
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+#, fuzzy
+msgid "Lighting"
+msgstr "Existant"
+#: ../visualization/nviz2/cmd/args.c:584
+#, fuzzy
+msgid "Light color"
+msgstr "Couleur de mise en valeur du texte"
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+msgstr "Écrire les sommets de lignes."
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+#, fuzzy
+msgid "Fringe"
+msgstr "Abandon."
+#: ../visualization/nviz2/cmd/args.c:625
+#, fuzzy
+msgid "Fringe color"
+msgstr "Couleur de ligne"
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "Tracer le relief"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr ""
@@ -27943,134 +28069,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
 msgstr "Impossible de créer la couche raster <%s>"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, fuzzy, c-format
-msgid "Failed in attempt to open %s"
-msgstr "Nom du fichier vecteur de sortie"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr ""
-"Produit des couches raster de pente, aspect, courbures et dérivées "
-"partielles à partir d'une couche raster de valeurs réelles d'altitude. "
-"L'aspect est calculé dans le sens contraire des aiguilles d'une montre à "
-"partir de l'est."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr "Fichier raster d'altitude"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-msgid "Output slope filename"
-msgstr "Fichier sortie pour la pente"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-msgid "Output aspect filename"
-msgstr "Nom de fichier de sortie pour l'aspect"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-msgid "Output profile curvature filename"
-msgstr "Nom de fichier de sortie pour la courbure du profil"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-msgid "Output tangential curvature filename"
-msgstr "Nom de fichier de sortie pour la courbure tangentielle"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx "
-"(gradient E-W)"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy "
-"(gradient N-S)"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-msgid "Output second order partial derivative dxx filename"
-msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxx"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-msgid "Output second order partial derivative dyy filename"
-msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dyy"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-msgid "Output second order partial derivative dxy filename"
-msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxy"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-# c-format
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, c-format
-msgid "wrong type: %s"
-msgstr "Type erroné: %s"
-# c-format
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-#, fuzzy
-msgid "Creating support files..."
-msgstr "impossible d'ouvrir le fichier pour %s"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, fuzzy, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr "ASPECT [%s] TERMINE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr "PENTE [%s] TERMINEE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr "COURBE DE PROFIL [%s] TERMINEE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr "COURBE TANGENTIELLE [%s] TERMINEE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "PENTE E-W [%s] TERMINEE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr "PENTE N-S [%s] TERMINEE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr "DXX [%s] TERMINEE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr "DYY [%s] TERMINEE"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr "DXY [%s] TERMINEE"
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 #, fuzzy
@@ -28381,38 +28379,49 @@
 #: ../db/db.connect/main.c:49
 #, fuzzy
-msgid "Prints/sets general DB connection for current mapset and exits."
+msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
 "Affiche/configure la connexion à la base de données du jeu de données courant"
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 #, fuzzy
 msgid "Print current connection parameters and exit"
 msgstr "affiche les paramètres de connexion courants et quitte"
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 #, fuzzy
 msgid "Check connection parameters, set if uninitialized, and exit"
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 msgid "Set"
 msgstr ""
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
 #, fuzzy
+msgid "Set from default settings and exit"
+msgstr "Définir à partir de la région par défaut"
+#: ../db/db.connect/main.c:65
+#, fuzzy
+msgid "Overwrite current settings if initialized"
+msgstr "Ecraser le MASK existant"
+#: ../db/db.connect/main.c:87
+#, fuzzy
 msgid "Default group of database users to which select privilege is granted"
 msgstr ""
 "Groupe d'utilisateurs par défaut de la base de données qui ont le privilège "
 "SELECT."
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 #, fuzzy
 msgid "Database connection not defined. Run db.connect."
 msgstr "Pas de connexion définie pour le pilote <%s>. Exécutez db.connect"
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -28420,11 +28429,11 @@
 "database: %s"
 msgstr ""
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr ""
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 #, fuzzy
 msgid "Default database is not set"
 msgstr "Nom de la base de données source"
@@ -28689,7 +28698,7 @@
 "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
 "prendreles paramètres saisis en ligne de commande"
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
 msgstr "ignore les erreurs SQL et poursuit"
@@ -28754,20 +28763,20 @@
 msgid "succeeded"
 msgstr "...réussi."
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr "déclaration SELECT SQL"
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 #, fuzzy
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr ""
 "Clause SQL 'select', par exemple: 'select * from rybniky where kapri = "
 "'hodne''"
-#: ../db/db.select/main.c:215
+#: ../db/db.select/main.c:201
 #, fuzzy
-msgid "Name of file with sql statement"
+msgid "Name of file with SQL select statement(s)"
 msgstr "nom du fichier contenant une commande SQL"
 #: ../db/db.select/main.c:247
@@ -29001,7 +29010,7 @@
 msgstr "Calcule la régression linéaire pour deux couches raster : y = a + b*x"
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:6
@@ -29119,50 +29128,69 @@
 msgstr "Fichier de coordonnées en entrée (ne pas lire à partir de stdin)"
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#, fuzzy
+msgid "Files & format"
+msgstr "format OGR"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
 msgid "Output coordinate file (omit to send to stdout)"
 msgstr "Fichier de coordonnées en sortie (ne pas envoyer vers stdout)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 #, fuzzy
 msgid "Field separator (format: input[,output])"
 msgstr "Caractère de séparation de champs (en mode 'terse' seulement)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr "Paramètres de projection en entrée (style PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#, fuzzy
+msgid "Projections"
+msgstr "Traçage ... "
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Output projection parameters (PROJ.4 style)"
 msgstr "Paramètres de projection en sortie (style PROJ.4)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr ""
 "Utiliser LL WGS84 en entrée et le secteur courant comme projection en sortie"
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr ""
 "Utiliser le secteur courant en entrée et LL WGS84 comme projection en sortie"
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+#, fuzzy
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
 "Sortie long/lat en degrés décimaux et les autres projections avec beaucoup "
 "de décimales"
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
 msgstr "Coordonnées de la carte"
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "Ne pas inclure de nom de colonnes en sortie"
@@ -29433,6 +29461,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr "Lister les couches disponibles et quitter"
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 #, fuzzy
 msgid "Prints a graph of the correlation between data layers (in pairs)."
@@ -29765,13 +29797,6 @@
 msgid "Raster map to use as mask"
 msgstr "couche raster à utiliser comme MASK"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Create"
-msgstr "Corrélation"
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 #, fuzzy
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
@@ -29996,6 +30021,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -30009,7 +30035,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr "Conditions WHERE de la requête SQL sans le mot clef 'where'"
@@ -30405,21 +30431,25 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
 #, fuzzy
-msgid "Vector map for which to edit attribute table"
+msgid "Name of vector map for which to edit attribute table"
 msgstr ""
 "Nom de la couche de points vecteurs en entrée pour laquelle éditer la table "
 "attributaire"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Layer where to add column"
+#, fuzzy
+msgid "Layer number where to add column(s)"
 msgstr "Couche à laquelle ajouter la colonne"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 #, fuzzy
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de "
 "données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
@@ -30577,7 +30607,7 @@
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -31009,10 +31039,15 @@
 msgstr "Statistiques étendues (quartiles et 90ème centile)"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+#, fuzzy
+msgid "Print stats in shell script style"
+msgstr "Produit les statistiques à la façon d'un script shell"
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
 msgid "Name of data table"
 msgstr "Nom de la table de données"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 #, fuzzy
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr ""
@@ -31020,11 +31055,11 @@
 "numérique)"
 # c-format
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 msgid "Database/directory for table"
 msgstr "Base de données/répertoire d la table"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 msgid "Database driver"
 msgstr "Pilote de la base de donnée"
@@ -31098,6 +31133,11 @@
 msgid "Signature file <%s> is invalid"
 msgstr "Fichier signature [%s] invalide"
+#: ../imagery/i.smap/read_sig.c:30
+#, fuzzy, c-format
+msgid "Signature file <%s> is empty"
+msgstr "Fichier signature [%s] invalide"
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 #, fuzzy
 msgid "Name of file containing signatures"
@@ -31702,20 +31742,20 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr "Groupe [%s] ne contient pas de fichier"
-#: ../imagery/i.rectify/main.c:202
+#: ../imagery/i.rectify/main.c:204
 #, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr ""
 # c-format
-#: ../imagery/i.rectify/main.c:216
+#: ../imagery/i.rectify/main.c:218
 #, fuzzy, c-format
 msgid ""
 "Input raster map <%s> does not exist in group <%s>.\n"
 " Try:\n"
 msgstr "La couche raster [%s] existe dans le groupe."
-#: ../imagery/i.rectify/main.c:222
+#: ../imagery/i.rectify/main.c:224
 #, fuzzy
 msgid "Exit!"
 msgstr "Existant"
@@ -31814,7 +31854,7 @@
 msgid "Error while writing to temp file"
 msgstr "Erreur à la lecture du fichier de signatures."
-#: ../imagery/i.rectify/write.c:54
+#: ../imagery/i.rectify/write.c:55
 #, fuzzy, c-format
 msgid "Error writing row %d"
 msgstr "Erreur d'écriture de la ligne null [%d]"
@@ -31824,12 +31864,12 @@
 msgid "Rectified input raster map <%s> will be saved as <%s>"
-#: ../imagery/i.rectify/rectify.c:91
+#: ../imagery/i.rectify/rectify.c:90
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-#: ../imagery/i.rectify/rectify.c:97
+#: ../imagery/i.rectify/rectify.c:96
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
@@ -32384,7 +32424,7 @@
 msgid "Name of input raster map (image fft, imaginary part"
 msgstr "Fichier raster en entrée (image fft, partie imaginaire)"
-#: ../imagery/i.ifft/main.c:119
+#: ../imagery/i.ifft/main.c:115
 #, fuzzy
 msgid "The real and imaginary original windows did not match"
 msgstr "Les fenêtres réelles et imaginaires ne correspondent pas."
@@ -33583,6 +33623,140 @@
 "Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
 #, fuzzy
+#~ msgid "Not enough room in history file"
+#~ msgstr "Pas assez de place dans le fichier historique"
+#, fuzzy
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "Jeu(x) de données à lister (par défaut le jeu de données courant)"
+# c-format
+#, fuzzy
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "Colonne <%s> non trouvée"
+#, fuzzy
+#~ msgid "Name of workspace file"
+#~ msgstr "Nom du fichier d'étiquettes"
+#, fuzzy
+#~ msgid "Displays raster map layer in the active map display window."
+#~ msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr "Liste de valeurs à afficher (couche en flottants FP)"
+#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
+#~ msgstr ""
+#~ "Catlist ignorée : la couche est en valeurs flottantes (veuillez utiliser "
+#~ "'val=')"
+#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
+#~ msgstr ""
+#~ "Vallist ignorée : la couche est en entier (veuillez utiliser 'cat=')"
+#, fuzzy
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "Nom du fichier vecteur de sortie"
+#~ msgid ""
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr ""
+#~ "Produit des couches raster de pente, aspect, courbures et dérivées "
+#~ "partielles à partir d'une couche raster de valeurs réelles d'altitude. "
+#~ "L'aspect est calculé dans le sens contraire des aiguilles d'une montre à "
+#~ "partir de l'est."
+#~ msgid "Raster elevation file name"
+#~ msgstr "Fichier raster d'altitude"
+#~ msgid "Output slope filename"
+#~ msgstr "Fichier sortie pour la pente"
+#~ msgid "Output aspect filename"
+#~ msgstr "Nom de fichier de sortie pour l'aspect"
+#~ msgid "Output profile curvature filename"
+#~ msgstr "Nom de fichier de sortie pour la courbure du profil"
+#~ msgid "Output tangential curvature filename"
+#~ msgstr "Nom de fichier de sortie pour la courbure tangentielle"
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr ""
+#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx "
+#~ "(gradient E-W)"
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#~ msgstr ""
+#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy "
+#~ "(gradient N-S)"
+#~ msgid "Output second order partial derivative dxx filename"
+#~ msgstr ""
+#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxx"
+#~ msgid "Output second order partial derivative dyy filename"
+#~ msgstr ""
+#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dyy"
+#~ msgid "Output second order partial derivative dxy filename"
+#~ msgstr ""
+#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxy"
+# c-format
+#~ msgid "wrong type: %s"
+#~ msgstr "Type erroné: %s"
+# c-format
+#, fuzzy
+#~ msgid "Creating support files..."
+#~ msgstr "impossible d'ouvrir le fichier pour %s"
+#, fuzzy
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
+#~ msgid "ASPECT [%s] COMPLETE"
+#~ msgstr "ASPECT [%s] TERMINE"
+#~ msgid "SLOPE [%s] COMPLETE"
+#~ msgstr "PENTE [%s] TERMINEE"
+#~ msgid "PROFILE CURVE [%s] COMPLETE"
+#~ msgstr "COURBE DE PROFIL [%s] TERMINEE"
+#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
+#~ msgstr "COURBE TANGENTIELLE [%s] TERMINEE"
+#~ msgid "E-W SLOPE [%s] COMPLETE"
+#~ msgstr "PENTE E-W [%s] TERMINEE"
+#~ msgid "N-S SLOPE [%s] COMPLETE"
+#~ msgstr "PENTE N-S [%s] TERMINEE"
+#~ msgid "DXX [%s] COMPLETE"
+#~ msgstr "DXX [%s] TERMINEE"
+#~ msgid "DYY [%s] COMPLETE"
+#~ msgstr "DYY [%s] TERMINEE"
+#~ msgid "DXY [%s] COMPLETE"
+#~ msgstr "DXY [%s] TERMINEE"
+#, fuzzy
+#~ msgid ""
+#~ "Name and type of the new column(s) ('name type [,name type, ...]' - types "
+#~ "depend on database backend, but all support VARCHAR(), INT, DOUBLE "
+#~ "PRECISION and DATE)"
+#~ msgstr ""
+#~ "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base "
+#~ "de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et "
+#~ "DATE)"
+#, fuzzy
 #~ msgid "Input elevation map"
 #~ msgstr "Fichier d'altitude en entrée"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_hi.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_hi\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2005-12-20 22:29+0100\n"
 "Last-Translator: Markus Neteler <neteler at itc.it>\n"
 "Language-Team: Hindi <grass-translations at lists.osgeo.org>\n"
@@ -17,7 +17,7 @@
 "X-Generator: KBabel 1.10.2\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 #, fuzzy
@@ -63,7 +63,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "का"
@@ -83,7 +83,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -183,7 +183,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -198,40 +197,40 @@
 msgid "Error opening grid3 file [%s]"
 msgstr "त्रुटि"
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 #, fuzzy
 msgid "Cannot allocate memory for string"
 msgstr "के लिए"
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, fuzzy, c-format
 msgid "Error reading range for [%s]"
 msgstr "त्रुटि के लिए"
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 #, fuzzy
 msgid "Error while reading history file"
 msgstr "त्रुटि."
@@ -263,7 +262,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -291,7 +290,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "त्रुटि"
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 #, fuzzy
 msgid "Error closing ascii file"
 msgstr "त्रुटि"
@@ -1147,7 +1146,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1162,7 +1161,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1195,17 +1194,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1259,7 +1257,7 @@
 msgstr "का"
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 msgid "List supported formats and exit"
 msgstr ""
@@ -1272,22 +1270,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1337,7 +1335,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 #, fuzzy
@@ -1651,12 +1648,27 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr "संख्या का"
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
 #, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "पूर्व"
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr "उत्तर"
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr "पूर्व"
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
+#, fuzzy, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "n"
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 #, fuzzy
 msgid "Writing raster map..."
@@ -1675,12 +1687,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1710,7 +1722,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1720,7 +1732,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1792,13 +1804,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1814,7 +1826,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1824,8 +1836,8 @@
 msgid "Unable to open database <%s> by driver <%s>"
 msgstr "स्रोत"
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1836,7 +1848,7 @@
 msgid "Unable to create table: '%s'"
 msgstr "के लिए"
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1846,8 +1858,8 @@
 msgstr "i n"
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2147,7 +2159,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, fuzzy, c-format
@@ -2232,10 +2244,10 @@
 msgid "Output world file"
 msgstr "ढाल फ़ाइलनाम "
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, fuzzy, c-format
 msgid "[%s]: No such color"
 msgstr "नहीं"
@@ -2255,12 +2267,12 @@
 msgid "Writing world file"
 msgstr "n"
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 #, fuzzy
 msgid "Got null file name"
 msgstr "फ़ाइलनाम "
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr ""
@@ -2437,7 +2449,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2564,8 +2576,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 msgid "Required"
 msgstr ""
@@ -2588,7 +2600,7 @@
 msgid "Metadata"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 #, fuzzy
 msgid "Name for new location to create"
 msgstr "के लिए"
@@ -2598,7 +2610,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 #, fuzzy
 msgid "Extend location extents based on new dataset"
 msgstr "चालू"
@@ -2641,7 +2653,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2684,13 +2696,13 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, fuzzy, c-format
 msgid "Location <%s> created"
 msgstr "n"
@@ -2703,13 +2715,13 @@
 msgstr "के लिए"
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 #, fuzzy
 msgid "Over-riding projection check"
 msgstr "नहीं n"
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 #, fuzzy
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
@@ -2726,7 +2738,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 #, fuzzy
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "n"
@@ -2747,7 +2759,7 @@
 msgstr "a सेट n"
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 #, fuzzy
 msgid "Projection of input dataset and current location appear to match"
 msgstr "का जोड़ा n"
@@ -2877,30 +2889,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr ""
@@ -3101,12 +3110,14 @@
 msgstr "है त्रुटि"
 #: ../raster/r.resamp.bspline/main.c:92
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:100
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -3150,7 +3161,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -3158,7 +3169,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -3187,7 +3198,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3205,7 +3216,7 @@
 msgstr "के लिए."
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3217,7 +3228,7 @@
 msgid "No data within this subregion. Consider increasing the spline step."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 #, fuzzy
 msgid "Writing output..."
 msgstr "n"
@@ -3431,7 +3442,7 @@
 msgstr ""
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 #, fuzzy
 msgid "metadata"
 msgstr "चालू"
@@ -3507,7 +3518,7 @@
 msgid "Raster map <%s> not found in current mapset"
 msgstr "नहीं"
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3518,38 +3529,33 @@
 msgid "Unable to open input file <%s>"
 msgstr "के लिए"
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-#, fuzzy
-msgid "Not enough room in history file"
-msgstr "के लिए"
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "संपादन के लिए "
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, fuzzy, c-format
 msgid "cats table for [%s] set to %s"
 msgstr "के लिए."
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, fuzzy, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr "है a का."
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, fuzzy, c-format
 msgid "Writing new null file for [%s]... "
 msgstr "के लिए "
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, fuzzy, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr "के लिए n"
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 msgid "Done."
 msgstr ""
@@ -4585,13 +4591,11 @@
 msgstr "का"
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 #, fuzzy
 msgid "Format for reporting the slope"
 msgstr "के लिए ढाल"
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 #, fuzzy
 msgid "Type of output aspect and slope maps"
 msgstr "का ढाल"
@@ -4634,19 +4638,16 @@
 msgstr "फ़ाइलनाम "
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 #, fuzzy
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr "मीटर्स"
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 #, fuzzy
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr "ढाल के लिए है"
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 #, fuzzy
 msgid "Do not align the current region to the elevation layer"
 msgstr "नहीं"
@@ -4690,58 +4691,56 @@
 msgstr "के लिए"
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, fuzzy, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr "ढाल ढाल"
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, fuzzy, c-format
 msgid "Aspect raster map <%s> complete"
 msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, fuzzy, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr "ढाल ढाल"
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, fuzzy, c-format
 msgid "Slope raster map <%s> complete"
 msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, fuzzy, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr "के लिए."
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, fuzzy, c-format
 msgid "Tangential curve raster map <%s> complete"
 msgstr "डाटाटाइप."
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, fuzzy, c-format
 msgid "E-W slope raster map <%s> complete"
 msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, fuzzy, c-format
 msgid "N-S slope raster map <%s> complete"
 msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, fuzzy, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, fuzzy, c-format
 msgid "Dyy raster map <%s> complete"
 msgstr "नहीं"
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, fuzzy, c-format
 msgid "Dxy raster map <%s> complete"
 msgstr "नहीं"
@@ -4828,7 +4827,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -5025,7 +5024,6 @@
 msgstr "का"
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr ""
@@ -5524,66 +5522,66 @@
 msgid "Filter <%s> not found"
 msgstr "नहीं"
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 #, fuzzy
 msgid "resample"
 msgstr "का"
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr "a."
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 msgid "Filter radius (horizontal)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, fuzzy, c-format
 msgid "Too many filters (max: %d)"
 msgstr "है"
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "थीटा"
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, fuzzy, c-format
 msgid "Unable to read color table for %s"
 msgstr "के लिए"
@@ -6168,7 +6166,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr "है"
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, c-format
 msgid "Unknown method <%s>"
 msgstr ""
@@ -6189,7 +6187,7 @@
 msgid "Aggregate operation"
 msgstr ""
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
@@ -8093,6 +8091,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 #, fuzzy
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr "छापें"
@@ -8464,57 +8463,57 @@
 msgid "Pass %d..."
 msgstr "n"
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "a a फ़ाइल."
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 #, fuzzy
 msgid "Name for new TIFF file"
 msgstr "फ़ाइल के लिए."
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 #, fuzzy
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr "का."
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 msgid "Output TIFF world file"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 msgid "Output Tiled TIFF"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
 "to integer"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, fuzzy, c-format
 msgid "Unable to open TIFF file <%s>"
 msgstr "का"
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 #, fuzzy
 msgid "Writing TIFF World file"
 msgstr "n"
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 #, fuzzy
 msgid "Unable to open TIFF world file for writing"
 msgstr "के लिए"
@@ -8632,7 +8631,7 @@
 msgstr "n"
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -8640,21 +8639,21 @@
 "[%s]"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
@@ -8664,17 +8663,17 @@
 msgid "Writing to map ..."
 msgstr "n"
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, fuzzy, c-format
 msgid "%lu points found in region."
 msgstr "नहीं"
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 #, fuzzy
 msgid "Scanning data ..."
 msgstr "n"
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr ""
@@ -9214,70 +9213,70 @@
 msgid "unable to open <%s> mask ... continuing without!"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 #, fuzzy
 msgid "Cannot create random access file"
 msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr "का"
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
 msgstr "का"
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
 msgstr "का"
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
 msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 #, fuzzy
 msgid "Cannot read setup file"
 msgstr "फ़ाइल"
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
 msgstr "के लिए"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 msgid "Irregular maskedoverlay areas definition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 msgid "Illegal configuration file (sample area)"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 #, fuzzy
 msgid "Too many units to place"
 msgstr "ज़ेड"
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 #, fuzzy
 msgid "Too many strats for raster map"
 msgstr "n"
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 #, fuzzy
 msgid "Cannot make lseek"
 msgstr "के लिए"
@@ -9604,8 +9603,8 @@
 #: ../raster/r.out.gdal/export_band.c:201
 #, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:241
@@ -9786,7 +9785,7 @@
 msgid "Name of color file"
 msgstr "का"
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 #, fuzzy
 msgid "Vertical exaggeration"
 msgstr "खड़ा"
@@ -9845,16 +9844,20 @@
 msgid "File containing expression(s) to evaluate"
 msgstr "फ़ाइल"
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:145
+msgid "file= and expression= are mutually exclusive"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:155
 #, fuzzy
 msgid "parse error"
 msgstr "n"
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr ""
@@ -10163,8 +10166,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 #, fuzzy
 msgid "Position"
 msgstr "नहीं n"
@@ -10769,8 +10772,8 @@
 msgstr "का"
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 #, fuzzy
 msgid "Attributes"
@@ -10817,7 +10820,7 @@
 msgstr "i n"
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr ""
@@ -11224,19 +11227,19 @@
 "or 'latin' option!"
 msgstr "का"
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -11253,7 +11256,7 @@
 msgid "Error in pj_do_proj"
 msgstr "त्रुटि"
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 msgstr "डाटाटाइप."
@@ -11648,7 +11651,7 @@
 msgid "Raster map(s) to report on"
 msgstr "चालू"
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr ""
@@ -11686,7 +11689,6 @@
 msgstr "का"
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 #, fuzzy
 msgid "Quiet"
 msgstr "शांत"
@@ -12199,13 +12201,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr ""
@@ -12424,17 +12419,17 @@
 msgid "Writing topographic index map..."
 msgstr "a"
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 #, fuzzy
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr "a."
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 #, fuzzy
 msgid "Aggregation method"
 msgstr "पद्धति"
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 msgid "Weight according to area (slower)"
 msgstr ""
@@ -12874,13 +12869,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -12918,15 +12913,66 @@
 msgid "Access for others"
 msgstr ""
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr ""
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 #, fuzzy
 msgid "Unable to determine mapset permissions"
 msgstr "का a"
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "का a"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+#, fuzzy
+msgid "read "
+msgstr "n"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 #, fuzzy
 msgid "Error reading WKT projection description"
@@ -13587,49 +13633,49 @@
 msgid "Error conducting transform (%d)"
 msgstr "संख्या के लिए"
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr ""
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr ""
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 #, fuzzy
 msgid "Parameter error"
 msgstr "n"
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 #, fuzzy
 msgid "No active control points"
 msgstr "घुमाएँ"
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
 msgstr "के लिए"
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 #, fuzzy
 msgid "transformation"
 msgstr "का"
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 #, fuzzy
 msgid "Computes a coordinate transformation based on the control points."
 msgstr "छवि a के लिए छवि चालू"
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 #, fuzzy
 msgid "Rectification polynomial order"
 msgstr "पॉलीनॉम"
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -13637,36 +13683,36 @@
 "difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 msgid "Output format"
 msgstr ""
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 #, fuzzy
 msgid "Display summary information"
 msgstr "जानकारी"
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr "उत्तर पूर्व"
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 #, fuzzy
 msgid "Local x,y coordinates to target east,north"
 msgstr "पूर्व उत्तर"
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 #, fuzzy
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr "ऊंचाई के लिए"
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 #, fuzzy
 msgid "Target east,north coordinates to local x,y"
 msgstr "बायाँ का"
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 msgid "Display transform matrix coefficients"
 msgstr ""
@@ -13680,91 +13726,95 @@
 msgid "Change current mapset."
 msgstr "नहीं"
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
 msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "का"
+#: ../general/g.mapset/main.c:63
+msgid "Location name (not location path)"
 msgstr ""
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr ""
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 #, fuzzy
 msgid "Create mapset if it doesn't exist"
 msgstr "नहीं"
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
 #, fuzzy
+msgid "Create"
+msgstr "का"
+#: ../general/g.mapset/main.c:86
+#, fuzzy
 msgid "List available mapsets"
 msgstr "सभी"
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 #, fuzzy
 msgid "Either mapset= or -l must be used"
 msgstr "का."
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, fuzzy, c-format
 msgid "<%s> is already the current mapset"
 msgstr "के लिए."
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 msgid "You don't have permission to use this mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr ""
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 #, fuzzy
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr "का"
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
 "checked"
 msgstr ""
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 #, fuzzy
 msgid "Cleaning up temporary files..."
 msgstr "बनाया जा रहा है."
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 msgid "Your shell continues to use the history for the old mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
 msgstr ""
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
 msgstr ""
-#: ../general/g.mapsets/dsply_path.c:19
-#, fuzzy, c-format
-msgid "Your mapset search list:\n"
-msgstr "छापें"
-#: ../general/g.mapsets/dsply_path.c:29
-#, fuzzy, c-format
-msgid "<%s> not found in mapset list"
-msgstr "नहीं"
 #: ../general/g.mapsets/main.c:62
 #, fuzzy
 msgid ""
@@ -13820,15 +13870,15 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr ""
-#: ../general/g.mapsets/dsply_maps.c:23
-#, fuzzy, c-format
+#: ../general/g.mapsets/list.c:10
+#, fuzzy
 msgid "Available mapsets:"
 msgstr "सभी"
-#: ../general/g.mapsets/dsply_maps.c:33
-#, c-format
-msgid "** no mapsets **\n"
-msgstr ""
+#: ../general/g.mapsets/list.c:35
+#, fuzzy
+msgid "Accessible mapsets:"
+msgstr "सभी"
 #: ../general/g.copy/main.c:43
 #, fuzzy
@@ -14390,40 +14440,40 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, fuzzy, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "i n"
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "फ़ाइल"
@@ -14446,13 +14496,12 @@
 msgstr ""
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-#, fuzzy
-msgid "Name of workspace file"
-msgstr "का"
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
 #: ../general/g.gui/main.c:57
 msgid "Update default GUI setting"
@@ -14467,6 +14516,11 @@
 msgid "<%s> is now the default GUI"
 msgstr ""
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 #, fuzzy
 msgid "Force remove"
@@ -14507,7 +14561,7 @@
 msgid "Unable to read FP range for %s"
 msgstr "के लिए"
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -14522,7 +14576,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -14551,7 +14605,7 @@
 msgid "At least two points are required"
 msgstr "के लिए"
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -14564,7 +14618,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -14573,46 +14627,46 @@
 msgid "No graphics device selected"
 msgstr "नहीं"
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 #, fuzzy
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
 msgstr "पाठ चालू."
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 msgid "Choose new current font"
 msgstr ""
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 msgid "Path to Freetype-compatible font including file name"
 msgstr ""
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr ""
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 #, fuzzy
 msgid "List fonts"
 msgstr "सभी"
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 #, fuzzy
 msgid "List fonts verbosely"
 msgstr "सभी"
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, fuzzy, c-format
 msgid "Unable to access font path %s: %s"
 msgstr "i n"
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, fuzzy, c-format
 msgid "Font path %s is not a file"
 msgstr "सीमा कम के बराबर नहीं."
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -15109,6 +15163,7 @@
 msgstr "a के लिए a का."
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #, fuzzy
 msgid "Name of raster map"
 msgstr "का"
@@ -15300,8 +15355,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -15547,33 +15602,33 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 #, fuzzy
 msgid "Selection"
 msgstr "नहीं n"
@@ -15618,15 +15673,15 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, fuzzy, c-format
 msgid "Database connection not defined"
 msgstr "नहीं"
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -16412,45 +16467,48 @@
 msgid "Error: %s\n"
 msgstr "त्रुटि n"
-#: ../display/d.rast/main.c:55
+#: ../display/d.rast/main.c:54
 #, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr "चालू."
+msgid "Displays raster map layer."
+msgstr "के लिए."
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 msgid "Raster map to be displayed"
 msgstr ""
-#: ../display/d.rast/main.c:67
+#: ../display/d.rast/main.c:66
 #, fuzzy
-msgid "List of categories to be displayed (INT maps)"
+msgid "List of categories or values to be displayed"
 msgstr "का"
-#: ../display/d.rast/main.c:76
+#: ../display/d.rast/main.c:72
 #, fuzzy
-msgid "List of values to be displayed (FP maps)"
-msgstr "का"
-#: ../display/d.rast/main.c:85
-#, fuzzy
 msgid "Background color (for null)"
 msgstr "के लिए"
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+#, fuzzy
+msgid "Either a standard color name or R:G:B triplet"
+msgstr "a R जी"
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
-msgstr ""
+#: ../display/d.rast/main.c:81
+#, fuzzy
+msgid "Invert value list"
+msgstr "विराम चिह्न जी 13"
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "है"
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr ""
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
+msgstr "है"
 #: ../display/d.rast.num/main.c:73
 #, fuzzy
@@ -16805,11 +16863,6 @@
 msgid "Label color"
 msgstr ""
-#: ../display/d.vect/main.c:263
-#, fuzzy
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "a R जी"
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr ""
@@ -17070,7 +17123,7 @@
 msgstr "नहीं"
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -17092,7 +17145,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
 msgstr ""
@@ -17110,7 +17163,7 @@
 msgstr "नहीं के लिए"
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -17124,7 +17177,7 @@
 msgstr "i n"
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -17152,7 +17205,7 @@
 msgstr "डाटाबेस नाम"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -17223,7 +17276,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -17476,7 +17529,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, fuzzy, c-format
@@ -17610,10 +17663,8 @@
 msgstr "नहीं"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 msgid "Query"
 msgstr ""
@@ -17999,17 +18050,17 @@
 msgid "Unable to build topology for <%s>"
 msgstr "के लिए."
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 #, fuzzy
 msgid "OGR datasource name"
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 #, fuzzy
 msgid ""
 "Examples:\n"
@@ -18017,12 +18068,12 @@
 "\t\tMapInfo File: directory containing mapinfo files"
 msgstr "n n फ़ाइल"
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 #, fuzzy
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr "नहीं सभी n n फ़ाइल"
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 #, fuzzy
 msgid ""
 "Examples:\n"
@@ -18030,288 +18081,293 @@
 "\t\tMapInfo File: mapinfo file name"
 msgstr "n n फ़ाइल"
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 #, fuzzy
 msgid "Import subregion only"
 msgstr "छापें"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 #, fuzzy
 msgid "Subregion"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 #, fuzzy
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr "आयात प"
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 #, fuzzy
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr "आकार  का छोटा"
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 #, fuzzy
 msgid "Optionally change default input type"
 msgstr "शीर्षक"
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 #, fuzzy
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
 "boundary;import lines as area boundaries;centroid;import points as centroids"
 msgstr "n बिन्दु n n n"
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 #, fuzzy
 msgid "Snapping threshold for boundaries"
 msgstr "के लिए के लिए"
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 #, fuzzy
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
 msgstr "का का असली है के लिए"
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 #, fuzzy
 msgid "List available layers in data source and exit"
 msgstr "स्रोत"
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 #, fuzzy
 msgid "Do not clean polygons (not recommended)"
 msgstr "नहीं नहीं"
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 msgid "Create 3D output"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 #, fuzzy
 msgid "Do not create attribute table"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 msgid "Override dataset projection (use location's projection)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 #, fuzzy
 msgid "Limit import to the current region"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, fuzzy, c-format
 msgid "Unable to open data source <%s>"
 msgstr "के लिए."
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "i n"
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, fuzzy, c-format
 msgid "Layer <%s> not available"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 #, fuzzy
 msgid "4 parameters required for 'spatial' parameter"
 msgstr "के लिए."
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 #, fuzzy
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
 msgstr "के लिए"
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 #, fuzzy
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, fuzzy, c-format
 msgid ""
 "\n"
 "You can use the -o flag to %s to override this projection check.\n"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 #, fuzzy
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
 "set.\n"
 msgstr "a सेट n"
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "त्रुटि n"
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, fuzzy, c-format
 msgid "Layer: %s"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, fuzzy, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr "बदला"
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, fuzzy, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr "स्थिर"
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, fuzzy, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
 "be truncated!"
 msgstr "चौड़ाई के लिए सेट नहीं!"
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, fuzzy, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr "स्थिर"
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, fuzzy, c-format
 msgid "Column type not supported (%s)"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "स्रोत"
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
 #, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "n"
+#: ../vector/v.in.ogr/main.c:854
+#, fuzzy, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr "f"
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 #, fuzzy
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr "है नहीं n"
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 #, fuzzy
 msgid "Break polygons:"
 msgstr "प्लाट"
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 #, fuzzy
 msgid "Remove duplicates:"
 msgstr "के लिए n"
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 #, fuzzy
 msgid "Merge boundaries:"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, c-format
 msgid "Find centroids for layer: %s"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 #, fuzzy
 msgid "Write centroids:"
 msgstr "छापें"
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, fuzzy, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -18319,93 +18375,88 @@
 "The number of features for those areas is stored as category in layer %d"
 msgstr "अधिक अधिक संख्या का के लिए है"
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, fuzzy, c-format
 msgid "%d input polygons\n"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, fuzzy, c-format
 msgid "%d input polygons"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 #, fuzzy
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
 "import 3D vector"
 msgstr "है ज़ेड."
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "डाटाटाइप."
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 #, fuzzy
 msgid "Cannot calculate centroid"
 msgstr "के लिए"
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 #, fuzzy
 msgid "Cannot write part of geometry"
 msgstr "डाटाटाइप."
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 #, fuzzy
 msgid "Unknown geometry type"
 msgstr "अज्ञात क़िस्म"
@@ -18590,6 +18641,9 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 #, fuzzy
 msgid "Connection"
 msgstr "का"
@@ -18625,12 +18679,12 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, fuzzy, c-format
 msgid "Missing column <%s> in table <%s>"
 msgstr "नहीं"
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 #, fuzzy
 msgid "Data type of key column must be integer"
 msgstr "ज़ेड"
@@ -18843,8 +18897,8 @@
 msgstr "नहीं"
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 #, fuzzy
 msgid "From"
 msgstr "विशेषता"
@@ -18865,8 +18919,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 msgid "To"
 msgstr ""
@@ -18892,62 +18946,62 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr "चालू"
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
 msgstr ""
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 #, fuzzy
 msgid "Name of existing vector map (from)"
 msgstr "का"
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
 msgstr "नहीं"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 #, fuzzy
 msgid "Feature type (from)"
 msgstr "विशेषता"
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 #, fuzzy
 msgid "Name of existing vector map (to)"
 msgstr "का"
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
 msgstr "नहीं"
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 #, fuzzy
 msgid "Feature type (to)"
 msgstr "विशेषता"
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 #, fuzzy
 msgid "Name for output vector map containing lines connecting nearest elements"
 msgstr "का"
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 #, fuzzy
 msgid "Maximum distance or -1 for no limit"
 msgstr "बिन्दु"
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 #, fuzzy
 msgid "Minimum distance or -1 for no limit"
 msgstr "बिन्दु"
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr ""
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
 "to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
@@ -18959,143 +19013,148 @@
 "attribute of nearest feature given by to_column option"
 msgstr ""
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr ""
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 #, fuzzy
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr "का"
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr ""
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr ""
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
 msgstr ""
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr ""
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 #, fuzzy
 msgid "Too many column names"
 msgstr "ज़ेड"
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 #, fuzzy
 msgid "Not enough column names"
 msgstr "ज़ेड"
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, fuzzy, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr "n"
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
 msgstr "नहीं"
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 #, fuzzy
 msgid "Unable to open default database"
 msgstr "स्रोत"
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 #, fuzzy
 msgid "Incompatible column types"
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
 msgstr "n"
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 #, fuzzy
 msgid "Finding nearest areas..."
 msgstr "n"
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr ""
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, fuzzy, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr "लोड हो गया"
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, fuzzy, c-format
 msgid "%d categories - no nearest feature found"
 msgstr "लोड हो गया"
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr ""
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, c-format
 msgid "%d records inserted"
 msgstr ""
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, c-format
 msgid "%d insert errors"
 msgstr ""
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, fuzzy, c-format
 msgid "%d categories read from the map"
 msgstr "लोड हो गया"
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, fuzzy, c-format
 msgid "%d categories exist in the table"
 msgstr "लोड हो गया"
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, fuzzy, c-format
 msgid "%d categories read from the map exist in the table"
 msgstr "लोड हो गया"
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, fuzzy, c-format
 msgid "%d categories read from the map don't exist in the table"
 msgstr "लोड हो गया"
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, c-format
 msgid "%d records updated"
 msgstr ""
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, c-format
 msgid "%d update errors"
 msgstr ""
@@ -19467,7 +19526,7 @@
 msgstr "i n"
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -19487,7 +19546,7 @@
 msgstr "नहीं"
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr "के लिए."
@@ -19521,13 +19580,12 @@
 msgid "Outlier detection"
 msgstr "सेट"
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 #, fuzzy
@@ -21088,52 +21146,59 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:273
-#, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:279
+#: ../vector/v.surf.bspline/main.c:274
 #, fuzzy, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr "का."
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
 "a raster output or other driver."
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr "का."
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+msgstr "का."
+#: ../vector/v.surf.bspline/main.c:332
 #, fuzzy
 msgid "Cannot read field info"
 msgstr "फील्ड"
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, fuzzy, c-format
 msgid "[%d] records selected from table"
 msgstr "नहीं"
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, fuzzy, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr "i n"
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 #, fuzzy
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
 msgstr "के लिए"
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, fuzzy, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
+#: ../vector/v.surf.bspline/main.c:712
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -23553,8 +23618,9 @@
 msgstr "चालू"
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
-msgstr ""
+#, fuzzy
+msgid "Area without centroid (OK for island)"
+msgstr "संपादन के लिए "
 #: ../vector/v.to.rast/do_areas.c:126
 msgid "Area centroid without category"
@@ -24681,11 +24747,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr ""
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr "a."
@@ -24705,7 +24771,7 @@
 msgid "Print topology information only"
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, fuzzy, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
 msgstr "नहीं"
@@ -25301,31 +25367,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, fuzzy, c-format
 msgid "Performing map %s + %s"
 msgstr "त्रुटि के लिए"
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr ""
@@ -25487,82 +25553,82 @@
 #: ../vector/v.db.connect/main.c:89
 #, fuzzy
-msgid "Print all map connection parameters and exit in shell script style"
+msgid "Print all map connection parameters in shell script style and exit"
 msgstr "छापें"
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 #, fuzzy
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr "छापें का के लिए"
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 #, fuzzy
 msgid "Overwrite connection parameter for certain layer"
 msgstr "के लिए"
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 #, fuzzy
 msgid "Delete connection for certain layer (not the table)"
 msgstr "मिटाएँ के लिए नहीं"
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 #, fuzzy
 msgid "Please choose only one print style"
 msgstr "एक पद्धति"
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 #, fuzzy
 msgid "Unable to modify vector map stored in other mapset"
 msgstr "सेट जोड़ा"
-#: ../vector/v.db.connect/main.c:165
+#: ../vector/v.db.connect/main.c:164
 #, fuzzy, c-format
-msgid "Vector map <%s> is connected by:"
+msgid "Vector map <%s> is connected by:\n"
 msgstr "नहीं"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr ""
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr ""
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
 "overwritten by GRASS modules"
 msgstr ""
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, fuzzy, c-format
 msgid "Cannot grant privileges on table %s"
 msgstr "चालू"
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr ""
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -25964,40 +26030,40 @@
 msgid "Name of Arc cost column"
 msgstr "का"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr ""
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 msgid "measurement"
 msgstr ""
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
 msgstr "के लिए ज़ेड"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 #, fuzzy
 msgid "Default: location map units"
 msgstr "त्रुटि"
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
 msgstr "छापें"
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 #, fuzzy
 msgid "Length:"
 msgstr "f n"
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 #, fuzzy
 msgid "Area:"
 msgstr "n"
@@ -26050,7 +26116,7 @@
 msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 #, fuzzy
 msgid "visualization"
 msgstr "का"
@@ -26133,303 +26199,353 @@
 msgid "Loading data failed"
 msgstr "n"
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 #, fuzzy
 msgid "Unsupported output format"
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, fuzzy, c-format
 msgid "File <%s> created."
 msgstr "n"
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
 msgstr "आइसोसरफेस"
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 #, fuzzy
 msgid "Image"
 msgstr "समूह"
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 #, fuzzy
 msgid "Graphics file format"
 msgstr "है n"
-#: ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:104
 #, fuzzy
-msgid "Width and height of output image"
+msgid "Size (width, height) of output image"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 #, fuzzy
 msgid "Name of raster map(s) for elevation"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 #, fuzzy
 msgid "Elevation value(s)"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 #, fuzzy
 msgid "Name of raster map(s) for color"
 msgstr "का समूह"
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 #, fuzzy
 msgid "Color value(s)"
 msgstr "नहीं"
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 #, fuzzy
 msgid "Name of raster map(s) for mask"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 #, fuzzy
 msgid "Name of raster map(s) for transparency"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 #, fuzzy
 msgid "Name of raster map(s) for shininess"
 msgstr "का रखे हुए"
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 #, fuzzy
 msgid "Name of raster map(s) for emission"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 msgid "Emission value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 #, fuzzy
 msgid "Draw mode"
 msgstr "हैंडहेल्ड"
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 #, fuzzy
 msgid "Fine resolution"
 msgstr "पूर्व पश्चिम "
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 #, fuzzy
 msgid "Coarse resolution"
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 #, fuzzy
 msgid "Draw style"
 msgstr "विशेषता"
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 #, fuzzy
 msgid "Wire color"
 msgstr "किनारा"
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 #, fuzzy
 msgid "Name of line vector overlay map(s)"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 #, fuzzy
 msgid "Vector lines"
 msgstr "नहीं"
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 #, fuzzy
 msgid "Vector line width"
 msgstr "लकीर की चौड़ाई"
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 #, fuzzy
 msgid "Vector line color"
 msgstr "सेट"
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 msgid "Vector line display mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 #, fuzzy
 msgid "Name of point vector overlay map(s)"
 msgstr "का"
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 #, fuzzy
 msgid "Vector points"
 msgstr "नहीं"
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 #, fuzzy
 msgid "Icon size"
 msgstr "आकार "
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 #, fuzzy
 msgid "Icon width"
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 #, fuzzy
 msgid "Icon color"
 msgstr "n"
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 #, fuzzy
 msgid "Icon marker"
 msgstr "आकार "
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 #, fuzzy
 msgid "Viewpoint position (x,y model coordinates)"
 msgstr "ज़ेड"
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 #, fuzzy
 msgid "Viewpoint height (in map units)"
 msgstr "त्रुटि"
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 #, fuzzy
 msgid "Viewpoint twist angle (in degrees)"
 msgstr "कोण कोण"
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 #, fuzzy
 msgid "Volumes"
 msgstr "नहीं"
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 #, fuzzy
 msgid "Volume position"
 msgstr "नहीं n"
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 msgid "Volume resolution"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 #, fuzzy
 msgid "Isosurface level"
 msgstr "आइसोसरफेस"
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+#, fuzzy
+msgid "Light position (x,y,z model coordinates)"
+msgstr "ज़ेड"
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+#, fuzzy
+msgid "Lighting"
+msgstr "n"
+#: ../visualization/nviz2/cmd/args.c:584
+#, fuzzy
+msgid "Light color"
+msgstr "उभारें के लिए पाठ के लिए"
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+msgstr "छापें"
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+#, fuzzy
+msgid "Fringe"
+msgstr "n"
+#: ../visualization/nviz2/cmd/args.c:625
+#, fuzzy
+msgid "Fringe color"
+msgstr "सेट"
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "ट्रेस"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr ""
@@ -26578,134 +26694,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
 msgstr "के लिए"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, fuzzy, c-format
-msgid "Failed in attempt to open %s"
-msgstr "का"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-#, fuzzy
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr "का ढाल a का है पूर्व."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-#, fuzzy
-msgid "Output slope filename"
-msgstr "ढाल फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-#, fuzzy
-msgid "Output aspect filename"
-msgstr "फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-#, fuzzy
-msgid "Output profile curvature filename"
-msgstr "फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-#, fuzzy
-msgid "Output tangential curvature filename"
-msgstr "फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-#, fuzzy
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr "प ढाल फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-#, fuzzy
-msgid "Output first order partial derivative dy (N-S slope) filename"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-#, fuzzy
-msgid "Output second order partial derivative dxx filename"
-msgstr "फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-#, fuzzy
-msgid "Output second order partial derivative dyy filename"
-msgstr "फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-#, fuzzy
-msgid "Output second order partial derivative dxy filename"
-msgstr "फ़ाइलनाम "
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, c-format
-msgid "wrong type: %s"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-#, fuzzy
-msgid "Creating support files..."
-msgstr "बनाया जा रहा है के लिए"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, fuzzy, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-msgstr "के लिए"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, fuzzy, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "प"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr ""
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 #, fuzzy
@@ -26991,35 +26979,46 @@
 #: ../db/db.connect/main.c:49
 #, fuzzy
-msgid "Prints/sets general DB connection for current mapset and exits."
+msgid "Prints/sets general DB connection for current mapset."
 msgstr "के लिए a"
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 #, fuzzy
 msgid "Print current connection parameters and exit"
 msgstr "छापें"
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 #, fuzzy
 msgid "Check connection parameters, set if uninitialized, and exit"
 msgstr "छापें"
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 msgid "Set"
 msgstr ""
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
 #, fuzzy
+msgid "Set from default settings and exit"
+msgstr "सेट"
+#: ../db/db.connect/main.c:65
+#, fuzzy
+msgid "Overwrite current settings if initialized"
+msgstr "डाटाटाइप."
+#: ../db/db.connect/main.c:87
+#, fuzzy
 msgid "Default group of database users to which select privilege is granted"
 msgstr "डिफ़ॉल्ट समूह का है."
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 #, fuzzy
 msgid "Database connection not defined. Run db.connect."
 msgstr "नहीं"
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -27027,11 +27026,11 @@
 "database: %s"
 msgstr ""
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr ""
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 #, fuzzy
 msgid "Default database is not set"
 msgstr "का a"
@@ -27285,7 +27284,7 @@
 msgid "'-' to read from standard input"
 msgstr "नहीं"
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
 msgstr ""
@@ -27351,18 +27350,18 @@
 msgid "succeeded"
 msgstr ""
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr ""
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 #, fuzzy
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr "के लिए"
-#: ../db/db.select/main.c:215
+#: ../db/db.select/main.c:201
 #, fuzzy
-msgid "Name of file with sql statement"
+msgid "Name of file with SQL select statement(s)"
 msgstr "फ़ाइलनाम "
 #: ../db/db.select/main.c:247
@@ -27580,7 +27579,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:6
@@ -27688,46 +27687,64 @@
 msgstr "उत्तर पूर्व"
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#, fuzzy
+msgid "Files & format"
+msgstr "के लिए"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
 msgid "Output coordinate file (omit to send to stdout)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 #, fuzzy
 msgid "Field separator (format: input[,output])"
 msgstr "फील्ड"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#, fuzzy
+msgid "Projections"
+msgstr "नक़ल"
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Output projection parameters (PROJ.4 style)"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
 msgstr "का"
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "नहीं"
@@ -27986,6 +28003,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr "स्रोत"
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 msgid "Prints a graph of the correlation between data layers (in pairs)."
 msgstr ""
@@ -28287,13 +28308,6 @@
 msgid "Raster map to use as mask"
 msgstr "का"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Create"
-msgstr "का"
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
 msgstr ""
@@ -28499,6 +28513,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -28512,7 +28527,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
@@ -28851,19 +28866,22 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
 #, fuzzy
-msgid "Vector map for which to edit attribute table"
+msgid "Name of vector map for which to edit attribute table"
 msgstr "का के लिए संपादन (_E)"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
 #, fuzzy
-msgid "Layer where to add column"
+msgid "Layer number where to add column(s)"
 msgstr "नहीं"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -29008,7 +29026,7 @@
 msgstr "स्रोत"
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -29413,20 +29431,25 @@
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 #, fuzzy
+msgid "Print stats in shell script style"
+msgstr "छापें"
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#, fuzzy
 msgid "Name of data table"
 msgstr "का a"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 #, fuzzy
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr "के लिए"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 #, fuzzy
 msgid "Database/directory for table"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 #, fuzzy
 msgid "Database driver"
@@ -29494,6 +29517,11 @@
 msgid "Signature file <%s> is invalid"
 msgstr "हस्ताक्षर है अवैध."
+#: ../imagery/i.smap/read_sig.c:30
+#, fuzzy, c-format
+msgid "Signature file <%s> is empty"
+msgstr "हस्ताक्षर है अवैध."
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 #, fuzzy
 msgid "Name of file containing signatures"
@@ -30074,19 +30102,19 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr ""
-#: ../imagery/i.rectify/main.c:202
+#: ../imagery/i.rectify/main.c:204
 #, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
 msgstr ""
-#: ../imagery/i.rectify/main.c:216
+#: ../imagery/i.rectify/main.c:218
 #, fuzzy, c-format
 msgid ""
 "Input raster map <%s> does not exist in group <%s>.\n"
 " Try:\n"
 msgstr "समूह."
-#: ../imagery/i.rectify/main.c:222
+#: ../imagery/i.rectify/main.c:224
 msgid "Exit!"
 msgstr ""
@@ -30178,7 +30206,7 @@
 msgid "Error while writing to temp file"
 msgstr "त्रुटि."
-#: ../imagery/i.rectify/write.c:54
+#: ../imagery/i.rectify/write.c:55
 #, fuzzy, c-format
 msgid "Error writing row %d"
 msgstr "त्रुटि."
@@ -30188,12 +30216,12 @@
 msgid "Rectified input raster map <%s> will be saved as <%s>"
 msgstr "के लिए."
-#: ../imagery/i.rectify/rectify.c:91
+#: ../imagery/i.rectify/rectify.c:90
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
 msgstr "नहीं"
-#: ../imagery/i.rectify/rectify.c:97
+#: ../imagery/i.rectify/rectify.c:96
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
 msgstr "नहीं"
@@ -30702,7 +30730,7 @@
 msgid "Name of input raster map (image fft, imaginary part"
 msgstr "छवि भाग"
-#: ../imagery/i.ifft/main.c:119
+#: ../imagery/i.ifft/main.c:115
 #, fuzzy
 msgid "The real and imaginary original windows did not match"
 msgstr "असली नहीं जोड़ा."
@@ -31796,6 +31824,89 @@
 msgstr "बिन्दु खेद है."
 #, fuzzy
+#~ msgid "Not enough room in history file"
+#~ msgstr "के लिए"
+#, fuzzy
+#~ msgid "Your mapset search list:\n"
+#~ msgstr "छापें"
+#, fuzzy
+#~ msgid "<%s> not found in mapset list"
+#~ msgstr "नहीं"
+#, fuzzy
+#~ msgid "Name of workspace file"
+#~ msgstr "का"
+#, fuzzy
+#~ msgid "Displays raster map layer in the active map display window."
+#~ msgstr "चालू."
+#, fuzzy
+#~ msgid "List of values to be displayed (FP maps)"
+#~ msgstr "का"
+#, fuzzy
+#~ msgid "Failed in attempt to open %s"
+#~ msgstr "का"
+#, fuzzy
+#~ msgid ""
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr "का ढाल a का है पूर्व."
+#, fuzzy
+#~ msgid "Output slope filename"
+#~ msgstr "ढाल फ़ाइलनाम "
+#, fuzzy
+#~ msgid "Output aspect filename"
+#~ msgstr "फ़ाइलनाम "
+#, fuzzy
+#~ msgid "Output profile curvature filename"
+#, fuzzy
+#~ msgid "Output tangential curvature filename"
+#, fuzzy
+#~ msgid "Output first order partial derivative dx (E-W slope) filename"
+#~ msgstr "प ढाल फ़ाइलनाम "
+#, fuzzy
+#~ msgid "Output first order partial derivative dy (N-S slope) filename"
+#, fuzzy
+#~ msgid "Output second order partial derivative dxx filename"
+#, fuzzy
+#~ msgid "Output second order partial derivative dyy filename"
+#, fuzzy
+#~ msgid "Output second order partial derivative dxy filename"
+#, fuzzy
+#~ msgid "Creating support files..."
+#~ msgstr "बनाया जा रहा है के लिए"
+#, fuzzy
+#~ msgid "Elevation products for mapset [%s] in [%s]"
+#~ msgstr "के लिए"
+#, fuzzy
+#~ msgid "E-W SLOPE [%s] COMPLETE"
+#~ msgstr "प"
+#, fuzzy
 #~ msgid "Input elevation map"
 #~ msgstr "ज़ेड"
@@ -38303,10 +38414,6 @@
 #~ msgstr "के लिए"
 #, fuzzy
-#~ msgid "Name of spheroid to use"
-#~ msgstr "का"
-#, fuzzy
 #~ msgid ""
 #~ "Provides a terse description of USGS Digital Elevation Model (DEM) data "
 #~ "files stored on 1/2-inch magnetic tape."
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2010-08-29 10:34:45 UTC (rev 43335)
+++ grass/trunk/locale/po/grassmods_it.po	2010-08-29 10:52:30 UTC (rev 43336)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_it\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2010-06-02 22:57+0200\n"
+"POT-Creation-Date: 2010-08-29 12:41+0200\n"
 "PO-Revision-Date: 2008-03-26 17:32+0100\n"
 "Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -23,7 +23,7 @@
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
 #: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.info/r3.info.main.c:426 ../raster3d/r3.to.rast/main.c:374
+#: ../raster3d/r3.info/r3.info.main.c:422 ../raster3d/r3.to.rast/main.c:372
 #: ../raster3d/r3.in.v5d/main.c:222 ../raster3d/r3.out.v5d/main.c:331
 #: ../raster/r.to.rast3elev/main.c:486 ../raster/r.to.rast3/main.c:328
 msgid "Error closing 3d raster map"
@@ -65,7 +65,7 @@
 #: ../raster3d/r3.stats/main.c:568 ../raster3d/base/r3.null.main.c:202
 #: ../raster3d/base/r3.mask.main.c:133 ../raster3d/r3.out.v5d/main.c:289
 #: ../raster/r.to.rast3elev/main.c:348 ../raster/r.univar/r3.univar_main.c:77
-#: ../visualization/nviz2/cmd/main.c:49
+#: ../visualization/nviz2/cmd/main.c:51
 #, fuzzy
 msgid "raster3d"
 msgstr "Valore del raster"
@@ -85,7 +85,7 @@
 #: ../raster3d/r3.out.v5d/main.c:290 ../raster/r.out.mat/main.c:63
 #: ../raster/r.out.ascii/main.c:60 ../raster/r.out.png/main.c:113
 #: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.tiff/main.c:92 ../raster/r.out.gdal/main.c:130
 #: ../raster/r.out.vrml/main.c:48 ../vector/v.out.svg/main.c:74
 #: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ascii/main.c:44
 #: ../vector/v.out.ogr/main.c:81 ../vector/v.out.pov/main.c:47
@@ -183,7 +183,6 @@
 #: ../display/d.what.rast/main.c:115 ../display/d.what.rast/opencell.c:13
 #: ../vector/v.vol.rst/main.c:645 ../visualization/nviz2/cmd/surface.c:54
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
 #: ../imagery/i.evapo.time_integration/main.c:163
 #: ../imagery/i.evapo.time_integration/main.c:189
 #: ../imagery/i.evapo.time_integration/main.c:221
@@ -198,39 +197,39 @@
 msgid "Error opening grid3 file [%s]"
 msgstr "Errore nell'aperura del file grid3 [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:159
-#: ../raster3d/r3.info/r3.info.main.c:167
-#: ../raster3d/r3.info/r3.info.main.c:173
-#: ../raster3d/r3.info/r3.info.main.c:178
-#: ../raster3d/r3.info/r3.info.main.c:185
-#: ../raster3d/r3.info/r3.info.main.c:196
-#: ../raster3d/r3.info/r3.info.main.c:202
-#: ../raster3d/r3.info/r3.info.main.c:218
-#: ../raster3d/r3.info/r3.info.main.c:225
-#: ../raster3d/r3.info/r3.info.main.c:232
-#: ../raster3d/r3.info/r3.info.main.c:237
-#: ../raster3d/r3.info/r3.info.main.c:242
-#: ../raster3d/r3.info/r3.info.main.c:249
-#: ../raster3d/r3.info/r3.info.main.c:256
-#: ../raster3d/r3.info/r3.info.main.c:266
-#: ../raster3d/r3.info/r3.info.main.c:276
-#: ../raster3d/r3.info/r3.info.main.c:286
-#: ../raster3d/r3.info/r3.info.main.c:299
-#: ../raster3d/r3.info/r3.info.main.c:309
-#: ../raster3d/r3.info/r3.info.main.c:314
-#: ../raster3d/r3.info/r3.info.main.c:322
-#: ../raster3d/r3.info/r3.info.main.c:335 ../raster/r.info/main.c:307
-#: ../raster/r.info/main.c:437
+#: ../raster3d/r3.info/r3.info.main.c:158
+#: ../raster3d/r3.info/r3.info.main.c:165
+#: ../raster3d/r3.info/r3.info.main.c:171
+#: ../raster3d/r3.info/r3.info.main.c:176
+#: ../raster3d/r3.info/r3.info.main.c:182
+#: ../raster3d/r3.info/r3.info.main.c:193
+#: ../raster3d/r3.info/r3.info.main.c:199
+#: ../raster3d/r3.info/r3.info.main.c:214
+#: ../raster3d/r3.info/r3.info.main.c:221
+#: ../raster3d/r3.info/r3.info.main.c:228
+#: ../raster3d/r3.info/r3.info.main.c:233
+#: ../raster3d/r3.info/r3.info.main.c:238
+#: ../raster3d/r3.info/r3.info.main.c:245
+#: ../raster3d/r3.info/r3.info.main.c:252
+#: ../raster3d/r3.info/r3.info.main.c:262
+#: ../raster3d/r3.info/r3.info.main.c:272
+#: ../raster3d/r3.info/r3.info.main.c:282
+#: ../raster3d/r3.info/r3.info.main.c:295
+#: ../raster3d/r3.info/r3.info.main.c:305
+#: ../raster3d/r3.info/r3.info.main.c:310
+#: ../raster3d/r3.info/r3.info.main.c:318
+#: ../raster3d/r3.info/r3.info.main.c:331 ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
 msgid "Cannot allocate memory for string"
 msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:288
-#: ../raster3d/r3.info/r3.info.main.c:350 ../raster3d/r3.mkdspf/main.c:172
+#: ../raster3d/r3.info/r3.info.main.c:284
+#: ../raster3d/r3.info/r3.info.main.c:346 ../raster3d/r3.mkdspf/main.c:172
 #, c-format
 msgid "Error reading range for [%s]"
 msgstr "Errore nel leggere il range di [%s]"
-#: ../raster3d/r3.info/r3.info.main.c:405
+#: ../raster3d/r3.info/r3.info.main.c:401
 #, fuzzy
 msgid "Error while reading history file"
 msgstr "Non riesco a trovare il file raster %s"
@@ -263,7 +262,7 @@
 #: ../raster/r.in.poly/main.c:30 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:161
 #: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
-#: ../vector/v.in.ogr/main.c:104 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
 #: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
 #: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
 #: ../vector/v.in.ascii/main.c:49
@@ -292,7 +291,7 @@
 msgid "Error closing new 3d raster map"
 msgstr "Errore nell'apertura del file g3d"
-#: ../raster3d/r3.in.ascii/main.c:286
+#: ../raster3d/r3.in.ascii/main.c:285
 #, fuzzy
 msgid "Error closing ascii file"
@@ -1119,7 +1118,7 @@
 #: ../raster/r.mfilter/main.c:56 ../raster/r.resample/main.c:54
 #: ../raster/r.patch/main.c:52 ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/simwe/r.sim.water/main.c:119 ../raster/r.to.rast3elev/main.c:347
-#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:387
+#: ../raster/r.out.ppm/main.c:53 ../raster/r.resamp.filter/main.c:384
 #: ../raster/r.out.ppm3/main.c:56 ../raster/r.transect/main.c:103
 #: ../raster/r.random/main.c:51 ../raster/r.los/main.c:93
 #: ../raster/r.gwflow/main.c:205 ../raster/r.statistics2/main.c:101
@@ -1134,7 +1133,7 @@
 #: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:72
 #: ../raster/r.univar/r.univar_main.c:73 ../raster/r.cross/main.c:73
 #: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
-#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
 #: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
 #: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
 #: ../raster/r.surf.contour/main.c:59 ../raster/r.colors/main.c:158
@@ -1167,17 +1166,16 @@
 #: ../raster/r.flow/main.c:421 ../raster/r.what.color/main.c:88
 #: ../raster/r.in.ascii/main.c:69 ../raster/r.what/main.c:91
 #: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:211
-#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:262
+#: ../raster/r.topidx/main.c:39 ../raster/r.resamp.stats/main.c:256
 #: ../raster/r.region/main.c:51 ../raster/r.in.mat/main.c:91
 #: ../raster/r.param.scale/interface.c:54 ../raster/r.in.arc/main.c:60
 #: ../raster/r.support.stats/main.c:38 ../raster/r.neighbors/main.c:116
 #: ../raster/r.bitpattern/main.c:63 ../raster/r.quantile/main.c:255
-#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:54
+#: ../display/d.colortable/main.c:61 ../display/d.rast/main.c:53
 #: ../vector/v.sample/main.c:76 ../vector/v.to.rast/main.c:41
 #: ../vector/v.neighbors/main.c:50 ../vector/v.what.rast/main.c:81
 #: ../visualization/nviz/src/nvizMain.c:71
-#: ../visualization/nviz2/cmd/main.c:47 ../doc/raster/r.example/main.c:83
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
+#: ../visualization/nviz2/cmd/main.c:49 ../doc/raster/r.example/main.c:83
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.buffer_to_translate.c:2
@@ -1230,7 +1228,7 @@
 msgstr "Campo separatore in output"
 #: ../raster/r.external.out/main.c:247 ../raster/r.in.gdal/main.c:142
-#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:202
+#: ../raster/r.external/main.c:572 ../vector/v.in.ogr/main.c:203
 #, fuzzy
 msgid "List supported formats and exit"
 msgstr "Visualizza i formati supportati ed esci"
@@ -1244,22 +1242,22 @@
 #: ../raster/r.external/main.c:573 ../general/g.proj/main.c:75
 #: ../general/g.proj/main.c:81 ../general/g.proj/main.c:87
 #: ../general/g.proj/main.c:93 ../general/g.proj/main.c:104
-#: ../general/g.proj/main.c:109 ../general/g.region/main.c:81
-#: ../general/g.region/main.c:87 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:104
-#: ../general/g.region/main.c:110 ../general/g.region/main.c:116
-#: ../general/g.region/main.c:124 ../general/g.region/main.c:129
-#: ../general/g.region/main.c:135 ../general/g.region/main.c:140
-#: ../vector/v.to.db/parse.c:94 ../vector/v.to.db/parse.c:99
-#: ../vector/v.to.db/parse.c:105 ../vector/v.what/main.c:82
-#: ../vector/v.what/main.c:87 ../vector/v.what/main.c:92
-#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:46
-#: ../vector/v.info/parse.c:20 ../vector/v.info/parse.c:26
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.db.connect/main.c:80
-#: ../vector/v.db.connect/main.c:85 ../vector/v.db.connect/main.c:93
-#: ../vector/v.db.connect/main.c:100 ../db/db.connect/main.c:55
-#: ../db/db.connect/main.c:61
+#: ../general/g.proj/main.c:109 ../general/g.mapset/main.c:87
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
+#: ../general/g.region/main.c:92 ../general/g.region/main.c:98
+#: ../general/g.region/main.c:104 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:116 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:129 ../general/g.region/main.c:135
+#: ../general/g.region/main.c:140 ../vector/v.to.db/parse.c:94
+#: ../vector/v.to.db/parse.c:99 ../vector/v.to.db/parse.c:105
+#: ../vector/v.what/main.c:82 ../vector/v.what/main.c:87
+#: ../vector/v.what/main.c:92 ../vector/v.external/args.c:41
+#: ../vector/v.external/args.c:46 ../vector/v.info/parse.c:20
+#: ../vector/v.info/parse.c:26 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.db.connect/main.c:80 ../vector/v.db.connect/main.c:85
+#: ../vector/v.db.connect/main.c:92 ../vector/v.db.connect/main.c:99
+#: ../db/db.connect/main.c:54
 #: ../locale/scriptstrings/g.extension_to_translate.c:13
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
@@ -1308,7 +1306,6 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
 #: ../imagery/i.zc/main.c:64
 msgid "Name of input raster map"
@@ -1609,12 +1606,27 @@
 msgid "Minimum number of rows to hold in memory is 1"
 msgstr "Nume di righe da tenere in memoria"
-#: ../raster/r.in.poly/poly2rast.c:50 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/get_item.c:76
+#, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "Utilizzando le coordinate del centro della mappa\n"
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr "Coordinate nord non validi <%s>"
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr "Coordinate est non validi <%s>"
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr ""
-#: ../raster/r.in.poly/poly2rast.c:72 ../raster/r.carve/raster.c:33
+#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
 #: ../vector/v.to.rast/vect2rast.c:175
 #, fuzzy
 msgid "Writing raster map..."
@@ -1634,12 +1646,12 @@
 #: ../vector/v.net.alloc/main.c:60 ../vector/v.net/main.c:45
 #: ../vector/v.out.svg/main.c:73 ../vector/v.net.visibility/main.c:45
 #: ../vector/v.to.db/main.c:36 ../vector/v.generalize/main.c:78
-#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:103
+#: ../vector/v.build/main.c:35 ../vector/v.in.ogr/main.c:105
 #: ../vector/v.to.rast3/main.c:48 ../vector/v.extract/main.c:91
 #: ../vector/v.in.db/main.c:52 ../vector/v.net.iso/main.c:72
 #: ../vector/v.net.salesman/main.c:96 ../vector/v.perturb/main.c:60
 #: ../vector/v.in.region/main.c:38 ../vector/v.net.distance/main.c:60
-#: ../vector/v.distance/main.c:115 ../vector/v.in.sites/main.c:57
+#: ../vector/v.distance/main.c:118 ../vector/v.in.sites/main.c:57
 #: ../vector/v.random/main.c:84 ../vector/v.out.vtk/main.c:47
 #: ../vector/v.out.ascii/main.c:43 ../vector/v.net.allpairs/main.c:54
 #: ../vector/v.outlier/main.c:69 ../vector/v.label.sa/main.c:38
@@ -1669,7 +1681,7 @@
 #: ../vector/v.clean/main.c:45 ../vector/v.clean/test/topocheck.c:42
 #: ../vector/v.surf.idw/main.c:85 ../vector/v.parallel/main.c:46
 #: ../vector/v.buffer/main.c:146 ../vector/v.edit/main.c:53
-#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:226
+#: ../vector/v.info/main.c:38 ../vector/v.info/print.c:226
 #: ../vector/v.extrude/main.c:69 ../vector/v.category/main.c:71
 #: ../vector/v.surf.rst/main.c:142 ../vector/v.lidar.correction/main.c:69
 #: ../vector/v.net.centrality/main.c:95 ../vector/v.db.connect/main.c:49
@@ -1679,7 +1691,7 @@
 #: ../vector/v.to.3d/main.c:37 ../vector/v.out.dxf/main.c:56
 #: ../vector/v.net.spanningtree/main.c:46
 #: ../visualization/nviz/src/nvizMain.c:72
-#: ../visualization/nviz2/cmd/main.c:48 ../doc/vector/v.example/main.c:50
+#: ../visualization/nviz2/cmd/main.c:50 ../doc/vector/v.example/main.c:50
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:2
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:2
@@ -1748,13 +1760,13 @@
 #: ../vector/v.to.db/update.c:46 ../vector/v.to.db/query.c:89
 #: ../vector/v.to.rast3/main.c:81 ../vector/v.extract/main.c:274
 #: ../vector/v.in.db/main.c:122 ../vector/v.net.distance/main.c:198
-#: ../vector/v.distance/main.c:361 ../vector/v.distance/main.c:398
+#: ../vector/v.distance/main.c:419 ../vector/v.distance/main.c:455
 #: ../vector/v.in.sites/main.c:165 ../vector/v.random/main.c:172
 #: ../vector/v.net.allpairs/main.c:139 ../vector/v.label.sa/labels.c:77
 #: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.mkgrid/main.c:225
 #: ../vector/v.lrs/v.lrs.create/main.c:288
 #: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:337
+#: ../vector/v.out.ogr/main.c:369 ../vector/v.surf.bspline/main.c:338
 #: ../vector/v.surf.bspline/crosscorr.c:119 ../vector/v.in.dwg/main.c:212
 #: ../vector/v.vol.rst/main.c:629 ../vector/v.vol.rst/user1.c:100
 #: ../vector/v.net.timetable/main.c:93 ../vector/v.patch/main.c:133
@@ -1770,7 +1782,7 @@
 #: ../vector/v.buffer/main.c:293 ../vector/v.edit/select.c:520
 #: ../vector/v.info/print.c:145 ../vector/v.extrude/main.c:168
 #: ../vector/v.surf.rst/main.c:573 ../vector/v.net.centrality/main.c:222
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:324
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
 #: ../vector/v.net.components/main.c:139 ../vector/v.drape/main.c:250
 #: ../vector/v.what.rast/main.c:131 ../vector/v.to.3d/trans3.c:55
 #: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:130
@@ -1780,8 +1792,8 @@
 msgid "Unable to open database <%s> by driver <%s>"
 msgstr "Non riesco ad aprire il database %s col driver %s"
-#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:801
-#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:819
+#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:802
+#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:454
 #: ../vector/v.convert/att.c:81 ../vector/v.net.flow/main.c:170
@@ -1792,7 +1804,7 @@
 msgid "Unable to create table: '%s'"
 msgstr "Non riesco ad aprire il cellfile per [%s]"
-#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:806
+#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:807
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
 #: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
@@ -1802,8 +1814,8 @@
 msgstr "Nome della mappa raster risultante"
 #: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:210
-#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:812
-#: ../vector/v.distance/main.c:824 ../vector/v.in.sites/main.c:181
+#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:813
+#: ../vector/v.distance/main.c:986 ../vector/v.in.sites/main.c:181
 #: ../vector/v.random/main.c:201 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:464
@@ -2093,7 +2105,7 @@
 #: ../raster/r.out.ascii/main.c:167 ../raster/r.out.ppm3/main.c:126
 #: ../raster/r.profile/main.c:145 ../raster/r.category/main.c:177
 #: ../raster/r.out.arc/main.c:136 ../general/g.pnmcomp/main.c:241
-#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:278
+#: ../general/g.pnmcomp/main.c:258 ../general/g.transform/main.c:281
 #: ../display/d.nviz/main.c:196 ../vector/v.net/main.c:97
 #: ../vector/v.out.vtk/main.c:167 ../vector/v.out.ascii/main.c:96
 #, fuzzy, c-format
@@ -2176,10 +2188,10 @@
 msgid "Output world file"
 msgstr "Mostra il titolo del file raster"
-#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:108
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
-#: ../display/d.rast/display.c:27
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:163
+#: ../display/d.graph/main.c:108 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
 #, c-format
 msgid "[%s]: No such color"
 msgstr ""
@@ -2199,12 +2211,12 @@
 msgid "Writing world file"
 msgstr "Nome del raster map esistente"
-#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:389
+#: ../raster/r.out.png/main.c:428 ../raster/r.out.tiff/main.c:422
 #, fuzzy
 msgid "Got null file name"
 msgstr "Nome del file di output"
-#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:391
+#: ../raster/r.out.png/main.c:430 ../raster/r.out.tiff/main.c:424
 msgid "Got null region struct"
 msgstr ""
@@ -2372,7 +2384,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:258
 #: ../vector/v.lrs/v.lrs.label/main.c:287
 #: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:283
+#: ../vector/v.surf.bspline/main.c:218 ../vector/v.surf.bspline/main.c:278
 #: ../vector/v.lidar.edgedetection/main.c:214
 #: ../vector/v.lidar.growing/main.c:127 ../vector/v.convert/old2new.c:26
 #: ../vector/v.convert/att.c:31 ../vector/v.edit/main.c:127
@@ -2500,8 +2512,8 @@
 #: ../raster/r.in.gdal/main.c:92 ../raster/r.in.gdal/main.c:96
 #: ../raster/r.colors/main.c:165 ../raster/r.out.gdal/main.c:150
 #: ../raster/r.out.gdal/main.c:186 ../raster/r.external/main.c:531
-#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.dxf/main.c:107
+#: ../raster/r.external/main.c:541 ../vector/v.in.ogr/main.c:117
+#: ../vector/v.in.ogr/main.c:121 ../vector/v.in.dxf/main.c:107
 msgid "Required"
 msgstr "Richiesto"
@@ -2521,7 +2533,7 @@
 msgid "Metadata"
 msgstr "Metadati"
-#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:129 ../vector/v.in.ogr/main.c:184
 msgid "Name for new location to create"
 msgstr "Nome della nuova locazione da creare"
@@ -2530,7 +2542,7 @@
 msgstr "Sovrascrivi proiezione (usa proiezione della location)"
 #: ../raster/r.in.gdal/main.c:138 ../raster/r.external/main.c:564
-#: ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:232
 msgid "Extend location extents based on new dataset"
 msgstr ""
@@ -2571,7 +2583,7 @@
 #: ../raster/r.out.gdal/main.c:232 ../vector/v.net/args.c:109
 #: ../vector/v.net/args.c:115 ../vector/v.net/args.c:121
 #: ../vector/v.net/args.c:125 ../vector/v.net/args.c:135
-#: ../vector/v.in.ogr/main.c:280 ../vector/v.in.ogr/main.c:329
+#: ../vector/v.in.ogr/main.c:281 ../vector/v.in.ogr/main.c:330
 #: ../vector/v.proj/main.c:164 ../vector/v.select/main.c:92
 #: ../vector/v.external/main.c:66 ../vector/v.external/main.c:72
 #: ../vector/v.external/main.c:75
@@ -2614,13 +2626,13 @@
 "with r.region before going any further."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:484
+#: ../raster/r.in.gdal/main.c:332 ../vector/v.in.ogr/main.c:485
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
 msgstr ""
-#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:490
+#: ../raster/r.in.gdal/main.c:338 ../vector/v.in.ogr/main.c:491
 #, c-format
 msgid "Location <%s> created"
 msgstr "Location <%s> creata!"
@@ -2632,13 +2644,13 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:367 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:520
+#: ../vector/v.in.ogr/main.c:521
 #, fuzzy
 msgid "Over-riding projection check"
 msgstr "Nome del raster"
 #: ../raster/r.in.gdal/main.c:378 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:529
+#: ../vector/v.in.ogr/main.c:530
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -2654,7 +2666,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:421 ../raster/r.external/main.c:156
-#: ../vector/v.in.ogr/main.c:545 ../vector/v.in.ogr/main.c:552
+#: ../vector/v.in.ogr/main.c:546 ../vector/v.in.ogr/main.c:553
 #, fuzzy
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "Errore durante la scrittura di PROJ_INFO"
@@ -2673,7 +2685,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:451 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:603
+#: ../vector/v.in.ogr/main.c:604
 msgid "Projection of input dataset and current location appear to match"
 msgstr ""
@@ -2803,30 +2815,27 @@
 #: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
 #: ../raster/r.resamp.rst/main.c:223 ../raster/r.resamp.rst/main.c:231
 #: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
-#: ../raster/r.resamp.rst/main.c:255 ../vector/v.surf.bspline/main.c:100
-#: ../vector/v.surf.bspline/main.c:124 ../vector/v.surf.bspline/main.c:133
-#: ../vector/v.surf.bspline/main.c:142 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:154 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.vol.rst/main.c:274 ../vector/v.vol.rst/main.c:282
-#: ../vector/v.vol.rst/main.c:290 ../vector/v.vol.rst/main.c:323
-#: ../vector/v.vol.rst/main.c:332 ../vector/v.vol.rst/main.c:341
-#: ../vector/v.vol.rst/main.c:349 ../vector/v.vol.rst/main.c:358
-#: ../vector/v.vol.rst/main.c:366 ../vector/v.lidar.edgedetection/main.c:96
+#: ../raster/r.resamp.rst/main.c:255 ../general/g.mapset/main.c:56
+#: ../general/g.mapset/main.c:64 ../general/g.mapset/main.c:75
+#: ../vector/v.surf.bspline/main.c:100 ../vector/v.surf.bspline/main.c:124
+#: ../vector/v.surf.bspline/main.c:133 ../vector/v.surf.bspline/main.c:142
+#: ../vector/v.surf.bspline/main.c:150 ../vector/v.surf.bspline/main.c:154
+#: ../vector/v.surf.bspline/main.c:161 ../vector/v.vol.rst/main.c:274
+#: ../vector/v.vol.rst/main.c:282 ../vector/v.vol.rst/main.c:290
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:341 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:358 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.lidar.edgedetection/main.c:96
 #: ../vector/v.lidar.edgedetection/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:114
 #: ../vector/v.lidar.edgedetection/main.c:123
 #: ../vector/v.lidar.edgedetection/main.c:132
 #: ../vector/v.lidar.edgedetection/main.c:140
 #: ../vector/v.lidar.edgedetection/main.c:149 ../vector/v.db.connect/main.c:60
-#: ../vector/v.db.connect/main.c:64
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:189
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:199
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:276
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:296
-#: ../imagery/i.cluster/main.c:102 ../imagery/i.cluster/main.c:118
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.cluster/main.c:135
-#: ../imagery/i.cluster/main.c:143 ../imagery/i.cluster/main.c:151
+#: ../vector/v.db.connect/main.c:64 ../imagery/i.cluster/main.c:102
+#: ../imagery/i.cluster/main.c:118 ../imagery/i.cluster/main.c:126
+#: ../imagery/i.cluster/main.c:135 ../imagery/i.cluster/main.c:143
+#: ../imagery/i.cluster/main.c:151
 msgid "Settings"
 msgstr "Impostazioni"
@@ -3016,12 +3025,14 @@
 #: ../raster/r.resamp.bspline/main.c:92
-msgid "Length of each spline step in the east-west direction. Default: ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:100
 msgid ""
-"Length of each spline step in the north-south direction. Default: nsres."
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:107 ../vector/v.surf.bspline/main.c:139
@@ -3065,7 +3076,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:198 ../vector/v.outlier/main.c:273
-#: ../vector/v.surf.bspline/main.c:418
+#: ../vector/v.surf.bspline/main.c:419
 #: ../vector/v.lidar.edgedetection/main.c:295
 #: ../vector/v.lidar.correction/main.c:275
 #, c-format
@@ -3073,7 +3084,7 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:199 ../vector/v.outlier/main.c:274
-#: ../vector/v.surf.bspline/main.c:419
+#: ../vector/v.surf.bspline/main.c:420
 #: ../vector/v.lidar.edgedetection/main.c:296
 #: ../vector/v.lidar.correction/main.c:276
 #, c-format
@@ -3101,7 +3112,7 @@
 #: ../vector/v.net.allpairs/main.c:114 ../vector/v.outlier/main.c:202
 #: ../vector/v.outlier/main.c:207 ../vector/v.outlier/main.c:213
 #: ../vector/v.in.dxf/main.c:149 ../vector/v.mkgrid/main.c:211
-#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:303
+#: ../vector/v.delaunay/main.c:125 ../vector/v.surf.bspline/main.c:298
 #: ../vector/v.hull/main.c:106 ../vector/v.lidar.edgedetection/main.c:242
 #: ../vector/v.net.timetable/main.c:325 ../vector/v.net.bridge/main.c:88
 #: ../vector/v.net.connectivity/main.c:123 ../vector/v.voronoi/main.c:157
@@ -3119,7 +3130,7 @@
 #: ../raster/r.resamp.bspline/main.c:409 ../vector/v.outlier/main.c:329
-#: ../vector/v.surf.bspline/main.c:487
+#: ../vector/v.surf.bspline/main.c:488
 #: ../vector/v.lidar.edgedetection/main.c:351
 #: ../vector/v.lidar.growing/main.c:247
 #: ../vector/v.lidar.correction/main.c:331
@@ -3131,7 +3142,7 @@
 msgid "No data within this subregion. Consider increasing the spline step."
 msgstr ""
-#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:716
+#: ../raster/r.resamp.bspline/main.c:595 ../vector/v.surf.bspline/main.c:718
 #, fuzzy
 msgid "Writing output..."
 msgstr "Sto disegnando ..."
@@ -3342,7 +3353,7 @@
 msgstr ""
 #: ../raster/r.support/main.c:56 ../raster/r.info/main.c:71
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:39
 #, fuzzy
 msgid "metadata"
 msgstr "File di input"
@@ -3414,7 +3425,7 @@
 msgid "Raster map <%s> not found in current mapset"
 msgstr "raster <%s> non trovato"
-#: ../raster/r.support/main.c:181 ../raster/r.in.xyz/main.c:475
+#: ../raster/r.support/main.c:180 ../raster/r.in.xyz/main.c:475
 #: ../raster/r.in.mat/main.c:129 ../raster/r.in.arc/main.c:124
 #: ../general/g.cairocomp/main.c:45 ../display/d.where/main.c:160
 #: ../display/d.linegraph/main.c:199 ../display/d.linegraph/main.c:210
@@ -3425,38 +3436,33 @@
 msgid "Unable to open input file <%s>"
 msgstr "impossibile aprire <%s>"
-#: ../raster/r.support/main.c:187 ../raster/r.support/main.c:205
-#, fuzzy
-msgid "Not enough room in history file"
-msgstr "Non riesco a trovare il file raster %s"
-#: ../raster/r.support/main.c:287 ../raster/r.statistics/main.c:98
+#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:98
 #: ../display/d.title/main.c:109
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 msgstr "Impossibile salvare la region <%s>"
-#: ../raster/r.support/main.c:291
+#: ../raster/r.support/main.c:253
 #, c-format
 msgid "cats table for [%s] set to %s"
 msgstr ""
-#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:343
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
 msgstr ""
-#: ../raster/r.support/main.c:326
+#: ../raster/r.support/main.c:288
 #, c-format
 msgid "Writing new null file for [%s]... "
 msgstr ""
-#: ../raster/r.support/main.c:347
+#: ../raster/r.support/main.c:309
 #, c-format
 msgid "Removing null file for [%s]...\n"
 msgstr ""
-#: ../raster/r.support/main.c:354 ../display/d.what.vect/main.c:153
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:153
 msgid "Done."
 msgstr "Fatto."
@@ -4431,12 +4437,10 @@
 msgstr "Nome di un file vettoriale in output"
 #: ../raster/r.slope.aspect/main.c:178
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
 msgid "Format for reporting the slope"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:188
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
 #, fuzzy
 msgid "Type of output aspect and slope maps"
 msgstr "Tipo"
@@ -4477,17 +4481,14 @@
 msgstr "Nome del file raster in input"
 #: ../raster/r.slope.aspect/main.c:243
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
 msgid "Multiplicative factor to convert elevation units to meters"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:252
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
 msgid "Minimum slope val. (in percent) for which aspect is computed"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:261
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:295
 msgid "Do not align the current region to the elevation layer"
 msgstr ""
@@ -4529,58 +4530,56 @@
 #: ../raster/r.slope.aspect/main.c:987
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
 #, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1051
+#: ../raster/r.slope.aspect/main.c:1050
 #, fuzzy, c-format
 msgid "Aspect raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1161
+#: ../raster/r.slope.aspect/main.c:1107
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
 msgstr ""
-#: ../raster/r.slope.aspect/main.c:1161
+#: ../raster/r.slope.aspect/main.c:1159
 #, fuzzy, c-format
 msgid "Slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1233
+#: ../raster/r.slope.aspect/main.c:1230
 #, fuzzy, c-format
 msgid "Profile curve raster map <%s> complete"
 msgstr "Nome del driver in output"
-#: ../raster/r.slope.aspect/main.c:1260
+#: ../raster/r.slope.aspect/main.c:1256
 #, fuzzy, c-format
 msgid "Tangential curve raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1285
+#: ../raster/r.slope.aspect/main.c:1280
 #, fuzzy, c-format
 msgid "E-W slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1310
+#: ../raster/r.slope.aspect/main.c:1304
 #, fuzzy, c-format
 msgid "N-S slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1335
+#: ../raster/r.slope.aspect/main.c:1328
 #, fuzzy, c-format
 msgid "Dxx raster map <%s> complete"
 msgstr "Mappa raster 3D <%s> non trovata"
-#: ../raster/r.slope.aspect/main.c:1360
+#: ../raster/r.slope.aspect/main.c:1352
 #, fuzzy, c-format
 msgid "Dyy raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1385
+#: ../raster/r.slope.aspect/main.c:1376
 #, fuzzy, c-format
 msgid "Dxy raster map <%s> complete"
@@ -4673,7 +4672,7 @@
 #: ../vector/v.net.connectivity/main.c:117 ../vector/v.support/main.c:130
 #: ../vector/v.lidar.growing/main.c:139 ../vector/v.lidar.growing/main.c:143
 #: ../vector/v.net.flow/main.c:134 ../vector/v.buffer/main.c:273
-#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:54
+#: ../vector/v.edit/main.c:142 ../vector/v.info/main.c:57
 #: ../vector/v.surf.rst/main.c:535 ../vector/v.surf.rst/main.c:618
 #: ../vector/v.lidar.correction/main.c:183
 #: ../vector/v.net.centrality/main.c:190 ../vector/v.net.components/main.c:110
@@ -4865,7 +4864,6 @@
 msgstr ""
 #: ../raster/r.resample/main.c:111 ../raster/r.resamp.rst/main.c:476
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:600
 msgid "Percent complete: "
 msgstr "Percentuale completa:"
@@ -5360,65 +5358,65 @@
 msgid "Filter <%s> not found"
 msgstr "File <%s> non trovato"
-#: ../raster/r.resamp.filter/main.c:388 ../raster/r.resamp.interp/main.c:73
-#: ../raster/r.resamp.stats/main.c:263 ../vector/v.sample/main.c:77
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.interp/main.c:73
+#: ../raster/r.resamp.stats/main.c:257 ../vector/v.sample/main.c:77
 #, fuzzy
 msgid "resample"
 msgstr "Mappa(e) raster da leggere"
-#: ../raster/r.resamp.filter/main.c:390
+#: ../raster/r.resamp.filter/main.c:387
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:401
+#: ../raster/r.resamp.filter/main.c:398
 msgid "Filter kernel(s)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:409
+#: ../raster/r.resamp.filter/main.c:406
 msgid "Filter radius"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:416
+#: ../raster/r.resamp.filter/main.c:413
 msgid "Filter radius (horizontal)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:423
+#: ../raster/r.resamp.filter/main.c:420
 msgid "Filter radius (vertical)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:427 ../raster/r.series/main.c:175
-#: ../raster/r.resamp.stats/main.c:289
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.series/main.c:175
+#: ../raster/r.resamp.stats/main.c:283
 msgid "Propagate NULLs"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:434
+#: ../raster/r.resamp.filter/main.c:431
 msgid "radius= and x_radius=/y_radius= are mutually exclusive"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:438
+#: ../raster/r.resamp.filter/main.c:435
 msgid "Either radius= or x_radius=/y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:440
+#: ../raster/r.resamp.filter/main.c:437
 msgid "Both x_radius= and y_radius= required"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.resamp.filter/main.c:459
 msgid "Differing number of values for filter= and [xy_]radius="
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:465
+#: ../raster/r.resamp.filter/main.c:462
 #, c-format
 msgid "Too many filters (max: %d)"
 msgstr ""
-#: ../raster/r.resamp.filter/main.c:483
+#: ../raster/r.resamp.filter/main.c:480
 #, fuzzy
 msgid "At least one filter must be finite"
 msgstr "file vettoriale da creare"
-#: ../raster/r.resamp.filter/main.c:559 ../raster/r.resamp.interp/main.c:313
-#: ../raster/r.resamp.stats/main.c:381
+#: ../raster/r.resamp.filter/main.c:552 ../raster/r.resamp.interp/main.c:304
+#: ../raster/r.resamp.stats/main.c:370
 #, fuzzy, c-format
 msgid "Unable to read color table for %s"
@@ -5996,7 +5994,7 @@
 msgid "%s: %s - illegal distance specification"
 msgstr "Nome del raster map in output"
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:302
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
 #, fuzzy, c-format
 msgid "Unknown method <%s>"
 msgstr "%s - colore sconosciuto\n"
@@ -6016,7 +6014,7 @@
 msgid "Aggregate operation"
 msgstr ""
-#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:283
+#: ../raster/r.series/main.c:156 ../raster/r.resamp.stats/main.c:277
 #: ../raster/r.neighbors/main.c:179
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
@@ -7884,6 +7882,7 @@
 #: ../raster/r.univar/r.univar_main.c:38
 #: ../raster/r.univar/r3.univar_main.c:37 ../vector/v.univar/main.c:89
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:11
 msgid "Percentile to calculate (requires extended statistics flag)"
 msgstr ""
@@ -8238,59 +8237,59 @@
 msgid "Pass %d..."
 msgstr ""
-#: ../raster/r.out.tiff/main.c:95
+#: ../raster/r.out.tiff/main.c:94
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "Esporta a raster GRASS in un MAT-File binario"
-#: ../raster/r.out.tiff/main.c:104
+#: ../raster/r.out.tiff/main.c:103
 #, fuzzy
 msgid "Name for new TIFF file"
 msgstr "Nome di un nuovo file raster"
-#: ../raster/r.out.tiff/main.c:111
+#: ../raster/r.out.tiff/main.c:110
 msgid "TIFF file compression"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:116
+#: ../raster/r.out.tiff/main.c:115
 #, fuzzy
 msgid "TIFF Palette output (8bit instead of 24bit)."
 msgstr "output verticale (invece che orizzontale)"
-#: ../raster/r.out.tiff/main.c:125
+#: ../raster/r.out.tiff/main.c:124
 #, fuzzy
 msgid "Output TIFF world file"
-#: ../raster/r.out.tiff/main.c:129
+#: ../raster/r.out.tiff/main.c:128
 #, fuzzy
 msgid "Output Tiled TIFF"
-#: ../raster/r.out.tiff/main.c:153
+#: ../raster/r.out.tiff/main.c:176
 #, c-format
 msgid ""
 "Raster map <%s>> is a floating point map. Fractional values will be rounded "
 "to integer"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:159
+#: ../raster/r.out.tiff/main.c:182
 msgid ""
 "Color map for palette must have less than 256 colors for the available range "
 "of data"
 msgstr ""
-#: ../raster/r.out.tiff/main.c:173
+#: ../raster/r.out.tiff/main.c:196
 #, fuzzy, c-format
 msgid "Unable to open TIFF file <%s>"
-#: ../raster/r.out.tiff/main.c:386
+#: ../raster/r.out.tiff/main.c:419
 #, fuzzy
 msgid "Writing TIFF World file"
-#: ../raster/r.out.tiff/main.c:394
+#: ../raster/r.out.tiff/main.c:427
 #, fuzzy
 msgid "Unable to open TIFF world file for writing"
@@ -8406,7 +8405,7 @@
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
-#: ../raster/r.in.xyz/main.c:1102 ../raster/r.in.xyz/main.c:1110
+#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
 "Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -8414,21 +8413,21 @@
 "[%s]"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1106
+#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
 msgid "Line ignored as requested"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1140
+#: ../raster/r.in.xyz/main.c:625 ../raster/r.in.xyz/main.c:1139
 #, c-format
 msgid "Bad y-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1125
+#: ../raster/r.in.xyz/main.c:632 ../raster/r.in.xyz/main.c:1124
 #, c-format
 msgid "Bad x-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1155
+#: ../raster/r.in.xyz/main.c:639 ../raster/r.in.xyz/main.c:1154
 #, c-format
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
@@ -8438,17 +8437,17 @@
 msgid "Writing to map ..."
-#: ../raster/r.in.xyz/main.c:1060
+#: ../raster/r.in.xyz/main.c:1059
 #, fuzzy, c-format
 msgid "%lu points found in region."
 msgstr "Utilizza la regione corrente"
-#: ../raster/r.in.xyz/main.c:1087
+#: ../raster/r.in.xyz/main.c:1086
 #, fuzzy
 msgid "Scanning data ..."
-#: ../raster/r.in.xyz/main.c:1175
+#: ../raster/r.in.xyz/main.c:1174
 #, c-format
 msgid "Range:     min         max\n"
 msgstr ""
@@ -8967,71 +8966,71 @@
 msgid "unable to open <%s> mask ... continuing without!"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:95
+#: ../raster/r.li/r.li.daemon/daemon.c:96
 #, fuzzy
 msgid "Cannot create random access file"
-#: ../raster/r.li/r.li.daemon/daemon.c:102
+#: ../raster/r.li/r.li.daemon/daemon.c:103
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/ directory"
 msgstr "Non riesco a descrivere la tabella"
-#: ../raster/r.li/r.li.daemon/daemon.c:109
+#: ../raster/r.li/r.li.daemon/daemon.c:110
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/ directory"
-#: ../raster/r.li/r.li.daemon/daemon.c:116
+#: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s/.grass7/r.li/output/ directory"
 msgstr "Nome della mappa di output"
-#: ../raster/r.li/r.li.daemon/daemon.c:193
+#: ../raster/r.li/r.li.daemon/daemon.c:194
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
-#: ../raster/r.li/r.li.daemon/daemon.c:200
-#: ../raster/r.li/r.li.daemon/daemon.c:204
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#: ../raster/r.li/r.li.daemon/daemon.c:205
 #, fuzzy
 msgid "Cannot read setup file"
-#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:209
 #, fuzzy
 msgid "Unable to parse configuration file"
-#: ../raster/r.li/r.li.daemon/daemon.c:359
+#: ../raster/r.li/r.li.daemon/daemon.c:360
 msgid "Irregular maskedoverlay areas definition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:362
+#: ../raster/r.li/r.li.daemon/daemon.c:363
 #, c-format
 msgid "The configuration file can be used only with \t\t\t%s rasterfile"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:369
+#: ../raster/r.li/r.li.daemon/daemon.c:370
 #, fuzzy
 msgid "Illegal configuration file (sample area)"
-#: ../raster/r.li/r.li.daemon/daemon.c:403
+#: ../raster/r.li/r.li.daemon/daemon.c:404
 #, fuzzy
 msgid "Too many units to place"
 msgstr "nome tabella"
-#: ../raster/r.li/r.li.daemon/daemon.c:472
+#: ../raster/r.li/r.li.daemon/daemon.c:473
 #, fuzzy
 msgid "Too many strats for raster map"
-#: ../raster/r.li/r.li.daemon/daemon.c:506
+#: ../raster/r.li/r.li.daemon/daemon.c:507
 msgid "Illegal areas disposition"
 msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:575
+#: ../raster/r.li/r.li.daemon/daemon.c:576
 #, fuzzy
 msgid "Cannot make lseek"
@@ -9356,8 +9355,8 @@
 #: ../raster/r.out.gdal/export_band.c:201
 #, c-format
 msgid ""
-"The given nodata value is present in rasterband <%s> and would lead to data "
-"loss. Please specify a different nodata value with the %s parameter."
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:241
@@ -9537,7 +9536,7 @@
 msgid "Name of color file"
 msgstr "Nome del filtro file"
-#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:491
+#: ../raster/r.out.vrml/main.c:72 ../visualization/nviz2/cmd/args.c:498
 msgid "Vertical exaggeration"
 msgstr ""
@@ -9595,16 +9594,20 @@
 msgid "File containing expression(s) to evaluate"
 msgstr "File contenente le direttive SQL"
-#: ../raster/r.mapcalc/main.c:152
+#: ../raster/r.mapcalc/main.c:145
+msgid "file= and expression= are mutually exclusive"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:155
 #, fuzzy
 msgid "parse error"
 msgstr "Parametri"
-#: ../raster/r.mapcalc/main.c:161
+#: ../raster/r.mapcalc/main.c:164
 msgid "Floating point error(s) occured in the calculation"
 msgstr ""
-#: ../raster/r.mapcalc/main.c:166
+#: ../raster/r.mapcalc/main.c:169
 msgid "Overflow occured in the calculation"
 msgstr ""
@@ -9907,8 +9910,8 @@
 #: ../raster/r.sunmask/main.c:142 ../raster/r.sunmask/main.c:151
 #: ../raster/r.sunmask/main.c:218 ../raster/r.sunmask/main.c:228
-#: ../visualization/nviz2/cmd/args.c:292 ../visualization/nviz2/cmd/args.c:360
-#: ../visualization/nviz2/cmd/args.c:429
+#: ../visualization/nviz2/cmd/args.c:299 ../visualization/nviz2/cmd/args.c:367
+#: ../visualization/nviz2/cmd/args.c:436
 msgid "Position"
 msgstr "Posizione"
@@ -10498,8 +10501,8 @@
 msgstr ""
 #: ../raster/r.to.vect/main.c:96 ../raster/r.to.vect/main.c:103
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.to.rast/main.c:72
+#: ../vector/v.in.ogr/main.c:194 ../vector/v.in.ogr/main.c:217
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.to.rast/main.c:72
 #: ../vector/v.to.rast/main.c:86 ../vector/v.to.rast/main.c:92
 msgid "Attributes"
 msgstr "Attributi"
@@ -10545,7 +10548,7 @@
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
-#: ../vector/v.in.ogr/main.c:913 ../vector/v.random/main.c:296
+#: ../vector/v.in.ogr/main.c:938 ../vector/v.random/main.c:296
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr ""
@@ -10950,19 +10953,19 @@
 "or 'latin' option!"
 msgstr ""
-#: ../raster/r.horizon/main.c:598 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:134
 #, c-format
 msgid "OOPS: rows changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:602 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:600 ../raster/r.in.ascii/main.c:198
 #: ../raster/r.in.arc/main.c:137
 #, c-format
 msgid "OOPS: cols changed from %d to %d"
 msgstr ""
-#: ../raster/r.horizon/main.c:790 ../raster/r.horizon/main.c:808
+#: ../raster/r.horizon/main.c:788 ../raster/r.horizon/main.c:806
 #: ../display/d.grid/plot.c:187 ../display/d.grid/plot.c:193
 #: ../display/d.grid/plot.c:238 ../display/d.grid/plot.c:244
 #: ../display/d.grid/plot.c:373 ../display/d.grid/plot.c:389
@@ -10978,7 +10981,7 @@
 msgid "Error in pj_do_proj"
 msgstr ""
-#: ../raster/r.horizon/main.c:1110
+#: ../raster/r.horizon/main.c:1108
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
@@ -11367,7 +11370,7 @@
 msgid "Raster map(s) to report on"
 msgstr ""
-#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:59
+#: ../raster/r.report/parse.c:45 ../misc/m.measure/main.c:58
 #: ../locale/scriptstrings/v.report_to_translate.c:12
 msgid "Units"
 msgstr ""
@@ -11407,7 +11410,6 @@
 msgstr ""
 #: ../raster/r.report/parse.c:96 ../raster/r.bitpattern/main.c:88
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:290
 msgid "Quiet"
 msgstr "Silenzioso"
@@ -11906,13 +11908,6 @@
 #: ../display/d.legend/main.c:154 ../display/d.legend/main.c:160
 #: ../display/d.legend/main.c:165 ../display/d.legend/main.c:170
 #: ../display/d.legend/main.c:175 ../display/d.legend/main.c:180
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:208
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:217
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:227
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:237
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:247
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:257
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:267
 msgid "Advanced"
 msgstr "Avanzato"
@@ -12120,15 +12115,15 @@
 msgid "Writing topographic index map..."
-#: ../raster/r.resamp.stats/main.c:265
+#: ../raster/r.resamp.stats/main.c:259
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:275
+#: ../raster/r.resamp.stats/main.c:269
 msgid "Aggregation method"
 msgstr ""
-#: ../raster/r.resamp.stats/main.c:293
+#: ../raster/r.resamp.stats/main.c:287
 msgid "Weight according to area (slower)"
 msgstr ""
@@ -12536,13 +12531,13 @@
 #: ../general/g.pnmcomp/main.c:281 ../general/g.message/main.c:33
 #: ../general/g.tempfile/main.c:36 ../general/g.pnmcat/main.c:121
 #: ../general/g.setproj/main.c:78 ../general/g.list/main.c:45
-#: ../general/g.transform/main.c:317 ../general/g.mapset/main.c:45
+#: ../general/g.transform/main.c:320 ../general/g.mapset/main.c:45
 #: ../general/g.mapsets/main.c:59 ../general/g.copy/main.c:40
 #: ../general/g.mremove/main.c:59 ../general/g.findetc/main.c:28
 #: ../general/g.ppmtopng/main.c:117 ../general/g.gisenv/main.c:38
 #: ../general/g.rename/main.c:43 ../general/g.filename/main.c:39
 #: ../general/g.mlist/main.c:63 ../general/g.region/main.c:62
-#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:71
+#: ../general/g.cairocomp/main.c:193 ../general/g.mkfontcap/main.c:70
 #: ../general/g.gui/main.c:36 ../general/g.remove/main.c:101
 #: ../general/g.findfile/main.c:35
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -12579,15 +12574,66 @@
 msgid "Access for others"
 msgstr ""
-#: ../general/g.access/main.c:63
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
 msgstr ""
-#: ../general/g.access/main.c:67
+#: ../general/g.access/main.c:71
 #, fuzzy
 msgid "Unable to determine mapset permissions"
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "Nome del raster map esistente"
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+#, fuzzy
+msgid "read "
+msgstr "area"
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
 #: ../general/g.proj/input.c:91
 #, fuzzy
 msgid "Error reading WKT projection description"
@@ -13269,46 +13315,46 @@
 msgid "Error conducting transform (%d)"
 msgstr "Stampa solo il tipo di mappa raster"
-#: ../general/g.transform/main.c:196
+#: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
 msgstr ""
-#: ../general/g.transform/main.c:198
+#: ../general/g.transform/main.c:201
 msgid "Insufficient memory"
 msgstr ""
-#: ../general/g.transform/main.c:200
+#: ../general/g.transform/main.c:203
 #, fuzzy
 msgid "Parameter error"
 msgstr "Parametri"
-#: ../general/g.transform/main.c:202
+#: ../general/g.transform/main.c:205
 msgid "No active control points"
 msgstr ""
-#: ../general/g.transform/main.c:297
+#: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
-#: ../general/g.transform/main.c:318 ../vector/v.transform/main.c:84
+#: ../general/g.transform/main.c:321 ../vector/v.transform/main.c:84
 #, fuzzy
 msgid "transformation"
-#: ../general/g.transform/main.c:319
+#: ../general/g.transform/main.c:322
 msgid "GCP"
 msgstr ""
-#: ../general/g.transform/main.c:321
+#: ../general/g.transform/main.c:324
 msgid "Computes a coordinate transformation based on the control points."
 msgstr ""
-#: ../general/g.transform/main.c:330
+#: ../general/g.transform/main.c:333
 msgid "Rectification polynomial order"
 msgstr ""
-#: ../general/g.transform/main.c:338
+#: ../general/g.transform/main.c:341
 msgid ""
 "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
 "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
@@ -13316,38 +13362,38 @@
 "difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
-#: ../general/g.transform/main.c:348 ../vector/v.out.ascii/args.c:44
+#: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
 #, fuzzy
 msgid "Output format"
 msgstr "Mappa in output"
-#: ../general/g.transform/main.c:352
+#: ../general/g.transform/main.c:355
 #, fuzzy
 msgid "Display summary information"
 msgstr "Mostra le informazioni sulla versione ed il copyright"
-#: ../general/g.transform/main.c:358
+#: ../general/g.transform/main.c:361
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
 msgstr ""
 "File ASCII contenente la singola linea descrivente la proiezione WKT (- per "
 "stdin)"
-#: ../general/g.transform/main.c:359
+#: ../general/g.transform/main.c:362
 #, fuzzy
 msgid "Local x,y coordinates to target east,north"
 msgstr "Le coordinate del centro (est,nord)"
-#: ../general/g.transform/main.c:363
+#: ../general/g.transform/main.c:366
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr ""
-#: ../general/g.transform/main.c:364
+#: ../general/g.transform/main.c:367
 #, fuzzy
 msgid "Target east,north coordinates to local x,y"
-#: ../general/g.transform/main.c:368
+#: ../general/g.transform/main.c:371
 msgid "Display transform matrix coefficients"
 msgstr ""
@@ -13360,94 +13406,100 @@
 msgid "Change current mapset."
 msgstr "Cambia il mapset corrente."
-#: ../general/g.mapset/main.c:54
-msgid "New MAPSET name"
-msgstr "Nome del nuovo MAPSET"
+#: ../general/g.mapset/main.c:48
+msgid "Optionally create new mapset or list available mapsets."
+msgstr ""
-#: ../general/g.mapset/main.c:61
-msgid "New LOCATION name (not location path)"
+#: ../general/g.mapset/main.c:55
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "Nome di un file vettoriale in output"
+#: ../general/g.mapset/main.c:63
+#, fuzzy
+msgid "Location name (not location path)"
 msgstr "Nome della nuova LOCATION (non il percorso della location)"
-#: ../general/g.mapset/main.c:69
-msgid "New GISDBASE (full path to the directory where the new location is)"
+#: ../general/g.mapset/main.c:74
+#, fuzzy
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
 msgstr ""
 "Nuovo GISDBASE (percorso intero della directory dove la nuova location è "
 "situata)"
-#: ../general/g.mapset/main.c:73
+#: ../general/g.mapset/main.c:80
 #, fuzzy
 msgid "Create mapset if it doesn't exist"
-#: ../general/g.mapset/main.c:78
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
 #, fuzzy
+msgid "Create"
+msgstr "Campo separatore in output"
+#: ../general/g.mapset/main.c:86
+#, fuzzy
 msgid "List available mapsets"
-#: ../general/g.mapset/main.c:84
+#: ../general/g.mapset/main.c:93
 #, fuzzy
 msgid "Either mapset= or -l must be used"
-#: ../general/g.mapset/main.c:129
+#: ../general/g.mapset/main.c:138
 #, fuzzy, c-format
 msgid "<%s> is already the current mapset"
 msgstr "ERRORE: <%s> esiste già nel mapset <%s>\n"
-#: ../general/g.mapset/main.c:137
+#: ../general/g.mapset/main.c:146
 #, fuzzy
 msgid "You don't have permission to use this mapset"
 msgstr "Non hai i permessi per usare questo mapset"
-#: ../general/g.mapset/main.c:146
+#: ../general/g.mapset/main.c:155
 msgid "The mapset does not exist. Use -c flag to create it."
 msgstr "Il mapset non esiste. Usa l'opzione -c per crearla"
-#: ../general/g.mapset/main.c:155
+#: ../general/g.mapset/main.c:164
 #, fuzzy
 msgid "Unable to read GIS_LOCK environment variable"
-#: ../general/g.mapset/main.c:169
+#: ../general/g.mapset/main.c:178
 #, c-format
 msgid ""
 "%s is currently running GRASS in selected mapset or lock file cannot be "
 "checked"
 msgstr ""
-#: ../general/g.mapset/main.c:174
+#: ../general/g.mapset/main.c:183
 #, fuzzy
 msgid "Cleaning up temporary files..."
-#: ../general/g.mapset/main.c:188
+#: ../general/g.mapset/main.c:197
 msgid "Your shell continues to use the history for the old mapset"
 msgstr ""
-#: ../general/g.mapset/main.c:192
+#: ../general/g.mapset/main.c:201
 #, c-format
 msgid ""
 "You can switch the history by commands:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
 msgstr ""
-#: ../general/g.mapset/main.c:197
+#: ../general/g.mapset/main.c:206
 #, c-format
 msgid ""
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
 msgstr ""
-#: ../general/g.mapsets/dsply_path.c:19
-#, fuzzy, c-format
-msgid "Your mapset search list:\n"
-msgstr "mostra i parametri della connessione in uso ed esce"
-#: ../general/g.mapsets/dsply_path.c:29
-#, fuzzy, c-format
-msgid "<%s> not found in mapset list"
-msgstr "raster <%s> non trovato"
 #: ../general/g.mapsets/main.c:62
 #, fuzzy
 msgid ""
@@ -13505,15 +13557,15 @@
 msgid "Cannot open SEARCH_PATH for write"
 msgstr ""
-#: ../general/g.mapsets/dsply_maps.c:23
-#, fuzzy, c-format
+#: ../general/g.mapsets/list.c:10
+#, fuzzy
 msgid "Available mapsets:"
-#: ../general/g.mapsets/dsply_maps.c:33
-#, c-format
-msgid "** no mapsets **\n"
-msgstr ""
+#: ../general/g.mapsets/list.c:35
+#, fuzzy
+msgid "Accessible mapsets:"
+msgstr "Visualizza i formati supportati ed esci"
 #: ../general/g.copy/main.c:43
 msgid ""
@@ -14057,40 +14109,40 @@
 msgid "input= and opacity= must have the same number of values"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:73
+#: ../general/g.mkfontcap/main.c:72
 msgid ""
 "Generates the font configuration file by scanning various directories for "
 "fonts"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:79
+#: ../general/g.mkfontcap/main.c:78
 msgid "Overwrite font configuration file if already existing"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:84
+#: ../general/g.mkfontcap/main.c:83
 msgid ""
 "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:92
+#: ../general/g.mkfontcap/main.c:91
 msgid ""
 "Comma-separated list of extra directories to scan for Freetype-compatible "
 "fonts as well as the defaults (see documentation)"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:109
+#: ../general/g.mkfontcap/main.c:108
 #, fuzzy, c-format
 msgid ""
 "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
-#: ../general/g.mkfontcap/main.c:121
+#: ../general/g.mkfontcap/main.c:120
 msgid ""
 "This GRASS installation was compiled without Freetype support, extradirs "
 "parameter ignored"
 msgstr ""
-#: ../general/g.mkfontcap/main.c:148
+#: ../general/g.mkfontcap/main.c:147
 #, fuzzy, c-format
 msgid "Cannot open %s for writing: %s"
 msgstr "Non riesco ad impostare user/password"
@@ -14113,13 +14165,12 @@
 msgstr ""
 #: ../general/g.gui/main.c:46
-msgid "wxpython;wxPython based GUI;text;command line interface only"
+msgid "wxpython;wxPython based GUI (wxGUI);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:53
-#, fuzzy
-msgid "Name of workspace file"
-msgstr "Nome del filtro file"
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
 #: ../general/g.gui/main.c:57
 msgid "Update default GUI setting"
@@ -14134,6 +14185,11 @@
 msgid "<%s> is now the default GUI"
 msgstr ""
+#: ../general/g.gui/main.c:104
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
 #: ../general/g.remove/main.c:109
 #, fuzzy
 msgid "Force remove"
@@ -14174,7 +14230,7 @@
 msgid "Unable to read FP range for %s"
-#: ../display/d.profile/main.c:191 ../display/d.font/main.c:45
+#: ../display/d.profile/main.c:191 ../display/d.font/main.c:46
 #: ../display/d.rast.arrow/main.c:95 ../display/d.grid/main.c:51
 #: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:43
 #: ../display/d.path/main.c:48 ../display/d.colorlist/main.c:35
@@ -14189,7 +14245,7 @@
 #: ../display/d.linegraph/main.c:119 ../display/d.title/main.c:49
 #: ../display/d.graph/main.c:58 ../display/d.what.vect/main.c:56
 #: ../display/d.text/main.c:139 ../display/d.labels/main.c:43
-#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:71
+#: ../display/d.rast/main.c:52 ../display/d.rast.num/main.c:71
 #: ../display/d.nviz/main.c:68 ../display/d.zoom/main.c:61
 #: ../display/d.vect/main.c:117 ../visualization/ximgview/main.c:290
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -14218,7 +14274,7 @@
 msgid "At least two points are required"
-#: ../display/d.profile/main.c:261 ../display/d.font/main.c:85
+#: ../display/d.profile/main.c:261 ../display/d.font/main.c:86
 #: ../display/d.rast.arrow/main.c:223 ../display/d.grid/main.c:210
 #: ../display/d.erase/main.c:50 ../display/d.geodesic/main.c:95
 #: ../display/d.path/main.c:153 ../display/d.fontlist/main.c:53
@@ -14231,7 +14287,7 @@
 #: ../display/d.extract/main.c:78 ../display/d.histogram/main.c:188
 #: ../display/d.linegraph/main.c:257 ../display/d.graph/main.c:101
 #: ../display/d.what.vect/main.c:142 ../display/d.text/main.c:290
-#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:104
+#: ../display/d.labels/main.c:116 ../display/d.rast/main.c:92
 #: ../display/d.rast.num/main.c:192 ../display/d.zoom/main.c:217
 #: ../display/d.zoom/redraw.c:38 ../display/d.vect/main.c:376
 #: ../vector/v.label/main.c:233 ../imagery/i.points/main.c:123
@@ -14239,7 +14295,7 @@
 msgid "No graphics device selected"
 msgstr "Nessun device grafico selezionato"
-#: ../display/d.font/main.c:47
+#: ../display/d.font/main.c:48
 msgid ""
 "Selects the font in which text will be displayed on the user's graphics "
 "monitor."
@@ -14247,41 +14303,41 @@
 "Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
 "nel monitor grafico dell'utente."
-#: ../display/d.font/main.c:55
+#: ../display/d.font/main.c:56
 #, fuzzy
 msgid "Choose new current font"
-#: ../display/d.font/main.c:62
+#: ../display/d.font/main.c:63
 #, fuzzy
 msgid "Path to Freetype-compatible font including file name"
 msgstr "Percorso del carattere TrueType (nome del file incluso)"
-#: ../display/d.font/main.c:70
+#: ../display/d.font/main.c:71
 msgid "Character encoding"
 msgstr "Codifica carattere"
-#: ../display/d.font/main.c:74
+#: ../display/d.font/main.c:75
 #, fuzzy
 msgid "List fonts"
 msgstr "List dei livelli di contorno"
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:47
+#: ../display/d.font/main.c:79 ../display/d.fontlist/main.c:47
 #, fuzzy
 msgid "List fonts verbosely"
-#: ../display/d.font/main.c:104
+#: ../display/d.font/main.c:105
 #, fuzzy, c-format
 msgid "Unable to access font path %s: %s"
 msgstr "Impossibile leggere l'input: %s"
-#: ../display/d.font/main.c:108
+#: ../display/d.font/main.c:109
 #, c-format
 msgid "Font path %s is not a file"
 msgstr ""
-#: ../display/d.font/main.c:125
+#: ../display/d.font/main.c:126
 #, c-format
 msgid ""
 "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
@@ -14751,6 +14807,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:75
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
 msgid "Name of raster map"
 msgstr "Nome della mappa raster"
@@ -14926,8 +14983,8 @@
 #: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
 #: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:113
-#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:356
-#: ../vector/v.distance/main.c:392 ../vector/v.surf.bspline/crosscorr.c:110
+#: ../vector/v.generalize/misc.c:160 ../vector/v.distance/main.c:414
+#: ../vector/v.distance/main.c:449 ../vector/v.surf.bspline/crosscorr.c:110
 #: ../vector/v.overlay/main.c:277 ../vector/v.to.rast/support.c:127
 #: ../vector/v.to.rast/support.c:278 ../vector/v.buffer/main.c:288
 #: ../vector/v.edit/select.c:506 ../vector/v.extrude/main.c:163
@@ -15167,33 +15224,33 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:129 ../display/d.thematic.area/main.c:132
-#: ../display/d.rast/main.c:68 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:141
-#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:147
-#: ../display/d.vect/main.c:353 ../vector/v.in.ogr/main.c:132
-#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
-#: ../vector/v.extract/main.c:108 ../vector/v.extract/main.c:113
-#: ../vector/v.extract/main.c:119 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:126 ../vector/v.extract/main.c:136
-#: ../vector/v.extract/main.c:146 ../vector/v.out.ascii/args.c:21
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.net.allpairs/main.c:65
-#: ../vector/v.net.allpairs/main.c:67 ../vector/v.net.allpairs/main.c:69
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:83 ../vector/v.to.points/main.c:184
-#: ../vector/v.to.points/main.c:188 ../vector/v.clean/main.c:52
-#: ../vector/v.clean/main.c:54 ../vector/v.buffer/main.c:155
-#: ../vector/v.buffer/main.c:160 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.category/main.c:80
-#: ../vector/v.category/main.c:83 ../vector/v.category/main.c:87
-#: ../vector/v.surf.rst/main.c:177 ../vector/v.surf.rst/main.c:187
-#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.centrality/main.c:111
-#: ../vector/v.to.3d/args.c:20 ../vector/v.to.3d/args.c:25
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:82
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:353
+#: ../vector/v.in.ogr/main.c:133 ../vector/v.in.ogr/main.c:147
+#: ../vector/v.in.ogr/main.c:169 ../vector/v.extract/main.c:108
+#: ../vector/v.extract/main.c:113 ../vector/v.extract/main.c:119
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:126
+#: ../vector/v.extract/main.c:136 ../vector/v.extract/main.c:146
+#: ../vector/v.out.ascii/args.c:21 ../vector/v.out.ascii/args.c:35
+#: ../vector/v.net.allpairs/main.c:65 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.reclass/main.c:77
+#: ../vector/v.reclass/main.c:82 ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21 ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35 ../vector/v.select/args.c:83
+#: ../vector/v.to.points/main.c:184 ../vector/v.to.points/main.c:188
+#: ../vector/v.clean/main.c:52 ../vector/v.clean/main.c:54
+#: ../vector/v.buffer/main.c:155 ../vector/v.buffer/main.c:160
+#: ../vector/v.edit/args.c:42 ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138 ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156 ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173 ../vector/v.edit/args.c:202
+#: ../vector/v.category/main.c:80 ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:87 ../vector/v.surf.rst/main.c:177
+#: ../vector/v.surf.rst/main.c:187 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net.centrality/main.c:111 ../vector/v.to.3d/args.c:20
+#: ../vector/v.to.3d/args.c:25
 #, fuzzy
 msgid "Selection"
 msgstr "Risoluzione"
@@ -15237,15 +15294,15 @@
 msgstr "'%s' dev'essere > 0 per '%s'"
 #: ../display/d.thematic.area/main.c:195 ../display/d.what.vect/what.c:409
-#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:170
+#: ../display/d.vect/main.c:457 ../vector/v.db.connect/main.c:169
 #, fuzzy, c-format
 msgid "Database connection not defined"
 msgstr "Connessione al database non definita\n"
 #: ../display/d.thematic.area/main.c:199 ../display/d.vect/main.c:461
 #: ../vector/v.out.svg/main.c:137 ../vector/v.in.sites/main.c:160
-#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:210
-#: ../vector/v.db.connect/main.c:276 ../vector/v.drape/main.c:245
+#: ../vector/v.edit/select.c:513 ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278 ../vector/v.drape/main.c:245
 #: ../doc/vector/v.example/main.c:125 ../db/db.execute/main.c:63
 #: ../db/db.tables/main.c:46 ../db/db.droptable/main.c:44
 #: ../db/db.createdb/main.c:43 ../db/db.columns/main.c:45
@@ -16011,46 +16068,48 @@
 msgid "Error: %s\n"
 msgstr "Errore: %s\n"
-#: ../display/d.rast/main.c:55
+#: ../display/d.rast/main.c:54
 #, fuzzy
-msgid "Displays raster map layer in the active map display window."
-msgstr ""
-"Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-"nel monitor grafico dell'utente."
+msgid "Displays raster map layer."
+msgstr "Statistiche per raster"
-#: ../display/d.rast/main.c:59
+#: ../display/d.rast/main.c:58
 #, fuzzy
 msgid "Raster map to be displayed"
-#: ../display/d.rast/main.c:67
-msgid "List of categories to be displayed (INT maps)"
-msgstr ""
-#: ../display/d.rast/main.c:76
+#: ../display/d.rast/main.c:66
 #, fuzzy
-msgid "List of values to be displayed (FP maps)"
+msgid "List of categories or values to be displayed"
-#: ../display/d.rast/main.c:85
+#: ../display/d.rast/main.c:72
 msgid "Background color (for null)"
 msgstr ""
-#: ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:73 ../display/d.vect/main.c:263
+#, fuzzy
+msgid "Either a standard color name or R:G:B triplet"
+msgstr "nessuno"
+#: ../display/d.rast/main.c:77
 msgid "Make null cells opaque"
 msgstr ""
-#: ../display/d.rast/main.c:93
-msgid "Invert catlist"
-msgstr ""
+#: ../display/d.rast/main.c:81
+#, fuzzy
+msgid "Invert value list"
+msgstr "Lista di valori separati da virgola: es. 1.4,3.8,13"
-#: ../display/d.rast/main.c:109
-msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
+#: ../display/d.rast/main.c:203
+#, fuzzy, c-format
+msgid "[%s]: illegal category specified"
+msgstr "Nome del raster map in output"
-#: ../display/d.rast/main.c:115
-msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr ""
+#: ../display/d.rast/main.c:234
+#, fuzzy, c-format
+msgid "[%s]: illegal value specified"
 #: ../display/d.rast.num/main.c:73
 #, fuzzy
@@ -16401,11 +16460,6 @@
 msgid "Label color"
 msgstr " val colore\n"
-#: ../display/d.vect/main.c:263
-#, fuzzy
-msgid "Either a standard color name or R:G:B triplet"
-msgstr "nessuno"
 #: ../display/d.vect/main.c:270
 msgid "Label background color"
 msgstr ""
@@ -16660,7 +16714,7 @@
 msgstr "driver pg: colonna '%s', di tipo %d non supportata"
 #: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:91
-#: ../vector/v.surf.bspline/main.c:350 ../vector/v.class/main.c:121
+#: ../vector/v.surf.bspline/main.c:351 ../vector/v.class/main.c:121
 #: ../vector/v.normal/main.c:133 ../vector/v.univar/main.c:154
 #: ../vector/v.surf.idw/read_sites.c:54 ../ps/ps.map/catval.c:67
 #: ../ps/ps.map/catval.c:132 ../ps/ps.map/catval.c:199
@@ -16682,7 +16736,7 @@
 #: ../vector/v.sample/main.c:192 ../vector/v.net.distance/main.c:214
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:174
 #: ../vector/v.net.path/path.c:113 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.db.connect/main.c:329 ../vector/v.net.components/main.c:153
+#: ../vector/v.db.connect/main.c:331 ../vector/v.net.components/main.c:153
 msgid "Cannot create index"
 msgstr "Impossibile creare l'indice"
@@ -16700,7 +16754,7 @@
 msgstr "Nessun record di categoria '%d' nella tabella"
 #: ../vector/v.sample/main.c:239 ../vector/v.to.rast3/main.c:95
-#: ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.surf.bspline/main.c:348
 #: ../vector/v.surf.bspline/crosscorr.c:129 ../vector/v.class/main.c:118
 #: ../vector/v.univar/main.c:151 ../vector/v.surf.idw/read_sites.c:51
 #: ../vector/v.buffer/main.c:309 ../vector/v.what.rast/main.c:153
@@ -16713,7 +16767,7 @@
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:37
-#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:116
+#: ../vector/v.in.db/main.c:54 ../vector/v.distance/main.c:119
 #: ../vector/v.db.connect/main.c:50 ../db/db.connect/main.c:45
 #: ../db/db.execute/main.c:109 ../db/db.drivers/main.c:74
 #: ../db/db.tables/main.c:95 ../db/db.droptable/main.c:78
@@ -16741,7 +16795,7 @@
 msgstr "database, SQL"
 #: ../vector/v.db.select/main.c:54 ../vector/v.to.db/main.c:38
-#: ../vector/v.distance/main.c:117 ../vector/v.db.connect/main.c:51
+#: ../vector/v.distance/main.c:120 ../vector/v.db.connect/main.c:51
 #: ../vector/v.what.rast/main.c:82 ../db/db.connect/main.c:46
 #: ../db/db.execute/main.c:110 ../db/db.drivers/main.c:75
 #: ../db/db.tables/main.c:96 ../db/db.columns/main.c:93
@@ -16811,7 +16865,7 @@
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
 #: ../vector/v.extract/main.c:266 ../vector/v.to.rast/vect2rast.c:48
-#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:206
+#: ../vector/v.info/print.c:136 ../vector/v.db.connect/main.c:208
 #: ../vector/v.to.3d/trans3.c:48 ../vector/v.to.3d/trans2.c:47
 #, fuzzy, c-format
 msgid "Database connection not defined for layer <%s>"
@@ -17061,7 +17115,7 @@
 #: ../vector/v.out.svg/main.c:150 ../vector/v.random/main.c:211
 #: ../vector/v.out.ogr/main.c:374 ../vector/v.patch/main.c:140
 #: ../vector/v.patch/main.c:178 ../vector/v.in.ascii/main.c:407
-#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:221
+#: ../vector/v.info/print.c:150 ../vector/v.db.connect/main.c:223
 #: ../vector/v.drape/main.c:256 ../doc/vector/v.example/main.c:136
 #: ../db/db.describe/main.c:63
 #, c-format
@@ -17194,10 +17248,8 @@
 msgstr "Numero di layer"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:89
-#: ../db/db.select/main.c:191 ../db/db.select/main.c:196
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:211
-#: ../db/db.select/main.c:216 ../db/db.select/main.c:248
-#: ../db/db.select/main.c:258
+#: ../db/db.select/main.c:197 ../db/db.select/main.c:202
+#: ../db/db.select/main.c:248 ../db/db.select/main.c:258
 msgid "Query"
 msgstr "Interroga"
@@ -17568,303 +17620,308 @@
 msgid "Unable to build topology for <%s>"
-#: ../vector/v.in.ogr/main.c:105
+#: ../vector/v.in.ogr/main.c:107
 #, fuzzy
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "Converte vettore OGR in vettore GRASS"
-#: ../vector/v.in.ogr/main.c:112
+#: ../vector/v.in.ogr/main.c:113
 #, fuzzy
 msgid "OGR datasource name"
 msgstr "nome database"
-#: ../vector/v.in.ogr/main.c:113
+#: ../vector/v.in.ogr/main.c:114
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: directory containing shapefiles\n"
 "\t\tMapInfo File: directory containing mapinfo files"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:128
+#: ../vector/v.in.ogr/main.c:129
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:130
+#: ../vector/v.in.ogr/main.c:131
 msgid ""
 "Examples:\n"
 "\t\tESRI Shapefile: shapefile name\n"
 "\t\tMapInfo File: mapinfo file name"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:140
+#: ../vector/v.in.ogr/main.c:141
 #, fuzzy
 msgid "Import subregion only"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:142 ../vector/v.in.ogr/main.c:226
 msgid "Subregion"
 msgstr "Sottoregione"
-#: ../vector/v.in.ogr/main.c:143
+#: ../vector/v.in.ogr/main.c:144
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:154
+#: ../vector/v.in.ogr/main.c:155
 msgid "Minimum size of area to be imported (square units)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:156 ../vector/v.in.ogr/main.c:177
 msgid "Min-area & snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:156
+#: ../vector/v.in.ogr/main.c:157
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:162
+#: ../vector/v.in.ogr/main.c:163
 #, fuzzy
 msgid "Optionally change default input type"
-#: ../vector/v.in.ogr/main.c:164
+#: ../vector/v.in.ogr/main.c:165
 msgid ""
 "point;import area centroids as points;line;import area boundaries as lines;"
 "boundary;import lines as area boundaries;centroid;import points as centroids"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:176
 #, fuzzy
 msgid "Snapping threshold for boundaries"
 msgstr "Lista delle soglie per le isosuperfici."
-#: ../vector/v.in.ogr/main.c:177
+#: ../vector/v.in.ogr/main.c:178
 msgid "'-1' for no snap"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:191
+#: ../vector/v.in.ogr/main.c:192
 msgid ""
 "List of column names to be used instead of original names, first is used for "
 "category column"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:198
+#: ../vector/v.in.ogr/main.c:199
 msgid "List available layers in data source and exit"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:207
+#: ../vector/v.in.ogr/main.c:208
 msgid "Do not clean polygons (not recommended)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:133
+#: ../vector/v.in.ogr/main.c:212 ../vector/v.random/main.c:133
 msgid "Create 3D output"
 msgstr "Crea output 3D"
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:78
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:78
 #: ../vector/v.voronoi/main.c:136 ../vector/v.overlay/main.c:123
 #: ../vector/v.to.points/main.c:215
 #, fuzzy
 msgid "Do not create attribute table"
-#: ../vector/v.in.ogr/main.c:221
+#: ../vector/v.in.ogr/main.c:222
 #, fuzzy
 msgid "Override dataset projection (use location's projection)"
 msgstr "Sovrascrivi la proiezione (utilizza quella della locazione)"
-#: ../vector/v.in.ogr/main.c:226
+#: ../vector/v.in.ogr/main.c:227
 #, fuzzy
 msgid "Limit import to the current region"
-#: ../vector/v.in.ogr/main.c:236
+#: ../vector/v.in.ogr/main.c:237
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:242
+#: ../vector/v.in.ogr/main.c:243
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:261
+#: ../vector/v.in.ogr/main.c:262
 msgid "Available OGR Drivers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:301
+#: ../vector/v.in.ogr/main.c:302
 #, fuzzy, c-format
 msgid "Unable to open data source <%s>"
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.external/list.c:41
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.external/list.c:41
 #, c-format
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:335
+#: ../vector/v.in.ogr/main.c:336
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "La mappa vettoriale <%s> esiste già e sarà sovrascritta"
-#: ../vector/v.in.ogr/main.c:338 ../vector/v.edit/main.c:88
+#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:88
 #, c-format
 msgid "Vector map <%s> already exists"
 msgstr "La mappa vettoriale <%s> esiste già"
-#: ../vector/v.in.ogr/main.c:363 ../vector/v.external/main.c:80
+#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:80
 #, fuzzy, c-format
 msgid "Layer <%s> not available"
 msgstr "file raster per la Vista%d"
-#: ../vector/v.in.ogr/main.c:379
+#: ../vector/v.in.ogr/main.c:380
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:407
+#: ../vector/v.in.ogr/main.c:408
 msgid "4 parameters required for 'spatial' parameter"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:505
+#: ../vector/v.in.ogr/main.c:506
 msgid ""
 "Unable to convert input map projection information to GRASS format for "
 "checking"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:535
+#: ../vector/v.in.ogr/main.c:536
 msgid "GRASS LOCATION PROJ_INFO is:\n"
 msgstr "GRASS LOCATION PROJ_INFO è:\n"
-#: ../vector/v.in.ogr/main.c:595
+#: ../vector/v.in.ogr/main.c:596
 #, c-format
 msgid ""
 "\n"
 "You can use the -o flag to %s to override this projection check.\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:598
+#: ../vector/v.in.ogr/main.c:599
 msgid ""
 "Consider generating a new location with 'location' parameter from input data "
 "set.\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:621
+#: ../vector/v.in.ogr/main.c:622
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
 msgstr "Errore nella lettura del file dbmscap\n"
-#: ../vector/v.in.ogr/main.c:640
+#: ../vector/v.in.ogr/main.c:641
 #, c-format
 msgid "Layer: %s"
 msgstr "Layer: %s"
-#: ../vector/v.in.ogr/main.c:704
+#: ../vector/v.in.ogr/main.c:705
 #, c-format
 msgid "Column name changed: '%s' -> '%s'"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:740
+#: ../vector/v.in.ogr/main.c:741
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:763
+#: ../vector/v.in.ogr/main.c:764
 #, c-format
 msgid ""
 "Width for column %s set to 255 (was not specified by OGR), some strings may "
 "be truncated!"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:775
+#: ../vector/v.in.ogr/main.c:776
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:779
+#: ../vector/v.in.ogr/main.c:780
 #, c-format
 msgid "Column type not supported (%s)"
 msgstr "Tipo di colonna non supportato (%s)"
-#: ../vector/v.in.ogr/main.c:794
+#: ../vector/v.in.ogr/main.c:795
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "Non riesco ad aprire il database %s col driver %s"
-#: ../vector/v.in.ogr/main.c:831
+#: ../vector/v.in.ogr/main.c:832
 #, fuzzy, c-format
+msgid "Counting polygons for %d features..."
+msgstr "Sto disegnando ..."
+#: ../vector/v.in.ogr/main.c:854
+#, fuzzy, c-format
 msgid "Boundary splitting distance in map units: %G"
 msgstr "Uso la massima distanza tra punti. %f"
-#: ../vector/v.in.ogr/main.c:834
+#: ../vector/v.in.ogr/main.c:859
 #, c-format
 msgid "Importing map %d features..."
 msgstr ""
-#: ../vector/v.in.ogr/main.c:929
+#: ../vector/v.in.ogr/main.c:954
 #, c-format
 msgid "%d %s without geometry"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:955
+#: ../vector/v.in.ogr/main.c:980
 msgid "Cleaning polygons, result is not guaranteed!"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:959
+#: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "Snap boundaries (threshold = %.3e):"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:973
+#: ../vector/v.in.ogr/main.c:998
 msgid "Break polygons:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.in.ogr/main.c:992
+#: ../vector/v.in.ogr/main.c:1003 ../vector/v.in.ogr/main.c:1017
 msgid "Remove duplicates:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1013
 msgid "Break boundaries:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:996
+#: ../vector/v.in.ogr/main.c:1021
 msgid "Clean boundaries at nodes:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1003
+#: ../vector/v.in.ogr/main.c:1028
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1007
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1013
+#: ../vector/v.in.ogr/main.c:1038
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1017
+#: ../vector/v.in.ogr/main.c:1042
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1023
+#: ../vector/v.in.ogr/main.c:1048
 #, fuzzy
 msgid "Merge boundaries:"
 msgstr "Non riesco a copiare la tabella"
-#: ../vector/v.in.ogr/main.c:1041 ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1066 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:517 ../vector/v.buffer/main.c:594
 msgid "Cannot calculate area centroid"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1057
+#: ../vector/v.in.ogr/main.c:1082
 #, c-format
 msgid "Find centroids for layer: %s"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1078
+#: ../vector/v.in.ogr/main.c:1103
 #, fuzzy
 msgid "Write centroids:"
 msgstr "Sto scrivendo i centroidi..."
-#: ../vector/v.in.ogr/main.c:1128
+#: ../vector/v.in.ogr/main.c:1153
 #, c-format
 msgid ""
 "%d areas represent more (overlapping) features, because polygons overlap in "
@@ -17872,90 +17929,85 @@
 "The number of features for those areas is stored as category in layer %d"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1138
+#: ../vector/v.in.ogr/main.c:1163
 #, c-format
 msgid "%d input polygons\n"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1139
+#: ../vector/v.in.ogr/main.c:1164
 #, c-format
 msgid "%d input polygons"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1142
+#: ../vector/v.in.ogr/main.c:1167
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
 msgstr "Area totale: %e (%d areas)"
-#: ../vector/v.in.ogr/main.c:1143
+#: ../vector/v.in.ogr/main.c:1168
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1146
+#: ../vector/v.in.ogr/main.c:1171
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
-#: ../vector/v.in.ogr/main.c:1148
+#: ../vector/v.in.ogr/main.c:1173
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1152
+#: ../vector/v.in.ogr/main.c:1177
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
 msgstr "Aree senza categoria: %e (%d areas)"
-#: ../vector/v.in.ogr/main.c:1154
+#: ../vector/v.in.ogr/main.c:1179
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
-#: ../vector/v.in.ogr/main.c:1195
+#: ../vector/v.in.ogr/main.c:1220
 msgid ""
 "Input data contains 3D features. Created vector is 2D only, use -z flag to "
 "import 3D vector"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:206
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:280
+#: ../vector/v.in.ogr/geom.c:193
+#, fuzzy
+msgid "Cannot read part of geometry"
+msgstr "Non posso scrivere parte della geometria"
+#: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
+#: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
 msgid "Skipping empty geometry feature"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:250
+#: ../vector/v.in.ogr/geom.c:289
 #, c-format
 msgid "Degenerate polygon ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:255
+#: ../vector/v.in.ogr/geom.c:332
 #, c-format
-msgid "Area size [%.1e], area not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:291
-#, c-format
 msgid "Degenerate island ([%d] vertices)"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:296
-#, c-format
-msgid "Island size [%.1e], island not imported"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:320
+#: ../vector/v.in.ogr/geom.c:366
 msgid "Cannot calculate centroid"
 msgstr "Non posso calcolare i centroidi"
-#: ../vector/v.in.ogr/geom.c:351
+#: ../vector/v.in.ogr/geom.c:397
 msgid "No centroid written for polygon with 0 vertices"
 msgstr ""
-#: ../vector/v.in.ogr/geom.c:372
+#: ../vector/v.in.ogr/geom.c:418
 msgid "Cannot write part of geometry"
-#: ../vector/v.in.ogr/geom.c:378
+#: ../vector/v.in.ogr/geom.c:424
 #, fuzzy
 msgid "Unknown geometry type"
 msgstr "Tipo sconosciuto"
@@ -18139,6 +18191,9 @@
 msgstr "Nome della tabella di input"
 #: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#: ../db/db.execute/main.c:120 ../db/db.execute/main.c:125
+#: ../db/db.execute/main.c:130 ../db/db.select/main.c:205
+#: ../db/db.select/main.c:210 ../db/db.select/main.c:216
 #, fuzzy
 msgid "Connection"
@@ -18171,12 +18226,12 @@
 msgstr ""
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:96
-#: ../vector/v.db.connect/main.c:282
+#: ../vector/v.db.connect/main.c:284
 #, fuzzy, c-format
 msgid "Missing column <%s> in table <%s>"
-#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:288
+#: ../vector/v.in.db/main.c:144 ../vector/v.db.connect/main.c:290
 #, fuzzy
 msgid "Data type of key column must be integer"
 msgstr "Nessuna mappa in input specificata"
@@ -18387,8 +18442,8 @@
 #: ../vector/v.net.distance/main.c:76 ../vector/v.net.distance/main.c:81
-#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:124
-#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:136
+#: ../vector/v.net.distance/main.c:87 ../vector/v.distance/main.c:127
+#: ../vector/v.distance/main.c:132 ../vector/v.distance/main.c:139
 #, fuzzy
 msgid "From"
 msgstr "Tipo di grafico"
@@ -18409,8 +18464,8 @@
 #: ../vector/v.net.distance/main.c:92 ../vector/v.net.distance/main.c:97
 #: ../vector/v.net.distance/main.c:103 ../vector/v.net.distance/main.c:110
-#: ../vector/v.distance/main.c:141 ../vector/v.distance/main.c:146
-#: ../vector/v.distance/main.c:153 ../vector/v.distance/main.c:209
+#: ../vector/v.distance/main.c:144 ../vector/v.distance/main.c:149
+#: ../vector/v.distance/main.c:156 ../vector/v.distance/main.c:212
 msgid "To"
 msgstr "A"
@@ -18436,7 +18491,7 @@
 msgid "Cannot grant privileges on table <%s>"
 msgstr "Permessi non sufficienti per accedere alla tabella %s"
-#: ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:122
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
@@ -18444,56 +18499,56 @@
 "Trova l'elemento più vicino nel vettoriale 'to' per gli elementi nel "
 "vettoriale 'from'."
-#: ../vector/v.distance/main.c:123
+#: ../vector/v.distance/main.c:126
 #, fuzzy
 msgid "Name of existing vector map (from)"
-#: ../vector/v.distance/main.c:128
+#: ../vector/v.distance/main.c:131
 #, fuzzy
 msgid "Layer number or name (from)"
-#: ../vector/v.distance/main.c:135
+#: ../vector/v.distance/main.c:138
 #, fuzzy
 msgid "Feature type (from)"
-#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:143
 #, fuzzy
 msgid "Name of existing vector map (to)"
-#: ../vector/v.distance/main.c:145
+#: ../vector/v.distance/main.c:148
 #, fuzzy
 msgid "Layer number or name (to)"
-#: ../vector/v.distance/main.c:152
+#: ../vector/v.distance/main.c:155
 #, fuzzy
 msgid "Feature type (to)"
-#: ../vector/v.distance/main.c:158
+#: ../vector/v.distance/main.c:161
 #, fuzzy
 msgid "Name for output vector map containing lines connecting nearest elements"
-#: ../vector/v.distance/main.c:166
+#: ../vector/v.distance/main.c:169
 #, fuzzy
 msgid "Maximum distance or -1 for no limit"
 msgstr "Distanza massima dal punto visualizzato (metri)"
-#: ../vector/v.distance/main.c:173
+#: ../vector/v.distance/main.c:176
 #, fuzzy
 msgid "Minimum distance or -1 for no limit"
-#: ../vector/v.distance/main.c:182
+#: ../vector/v.distance/main.c:185
 msgid "Values describing the relation between two nearest features"
 msgstr ""
-#: ../vector/v.distance/main.c:184
+#: ../vector/v.distance/main.c:187
 msgid ""
 "cat;category of the nearest feature;dist;minimum distance to nearest feature;"
 "to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
@@ -18505,142 +18560,147 @@
 "attribute of nearest feature given by to_column option"
 msgstr ""
-#: ../vector/v.distance/main.c:202
+#: ../vector/v.distance/main.c:205
 msgid ""
 "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:203
+#: ../vector/v.distance/main.c:206
 msgid "From_map"
 msgstr ""
-#: ../vector/v.distance/main.c:208
+#: ../vector/v.distance/main.c:211
 msgid "Column name of nearest feature (used with upload=to_attr)"
 msgstr ""
-#: ../vector/v.distance/main.c:214
+#: ../vector/v.distance/main.c:217
 msgid "Name of table created for output when the distance to all flag is used"
 msgstr ""
-#: ../vector/v.distance/main.c:219
+#: ../vector/v.distance/main.c:222
 msgid "Print output to stdout, don't update attribute table"
 msgstr ""
-#: ../vector/v.distance/main.c:221
+#: ../vector/v.distance/main.c:224
 msgid "First column is always category of 'from' feature called from_cat"
 msgstr ""
-#: ../vector/v.distance/main.c:226
+#: ../vector/v.distance/main.c:229
 msgid "Calculate distances to all features within the threshold"
 msgstr ""
-#: ../vector/v.distance/main.c:227
+#: ../vector/v.distance/main.c:230
 msgid ""
 "The output is written to stdout but may be uploaded to a new table created "
 "by this module. From categories are may be multiple."
 msgstr ""
-#: ../vector/v.distance/main.c:283
+#: ../vector/v.distance/main.c:288
 msgid "to_column option missing"
 msgstr ""
-#: ../vector/v.distance/main.c:295
+#: ../vector/v.distance/main.c:300
 #, fuzzy
 msgid "Too many column names"
-#: ../vector/v.distance/main.c:302
+#: ../vector/v.distance/main.c:307
 #, fuzzy
 msgid "Not enough column names"
 msgstr "Nome mappa raster"
-#: ../vector/v.distance/main.c:374 ../vector/v.distance/main.c:408
+#: ../vector/v.distance/main.c:367
+#, fuzzy, c-format
+msgid "No features of selected type in To vector <%s>"
+msgstr "%d categorie duplicate nel vettoriale"
+#: ../vector/v.distance/main.c:432 ../vector/v.distance/main.c:465
 #: ../vector/v.reclass/main.c:141 ../vector/v.to.3d/trans3.c:63
 #: ../vector/v.to.3d/trans2.c:62
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
-#: ../vector/v.distance/main.c:384
+#: ../vector/v.distance/main.c:441
 #, fuzzy
 msgid "Unable to open default database"
 msgstr "Non posso scrivere i collegamenti del database"
-#: ../vector/v.distance/main.c:440
+#: ../vector/v.distance/main.c:497
 #, fuzzy
 msgid "Incompatible column types"
-#: ../vector/v.distance/main.c:513
+#: ../vector/v.distance/main.c:570
 #, fuzzy
 msgid "Finding nearest feature..."
-#: ../vector/v.distance/main.c:643
+#: ../vector/v.distance/main.c:754
 #, fuzzy
 msgid "Finding nearest areas..."
-#: ../vector/v.distance/main.c:715
+#: ../vector/v.distance/main.c:863
 #, c-format
 msgid "More cats found in to_layer (area=%d)"
 msgstr ""
-#: ../vector/v.distance/main.c:856
+#: ../vector/v.distance/main.c:1018
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
 msgstr ""
-#: ../vector/v.distance/main.c:1105
+#: ../vector/v.distance/main.c:1274
 #, fuzzy, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
 msgstr "%d categorie caricate dal vettoriale"
-#: ../vector/v.distance/main.c:1108
+#: ../vector/v.distance/main.c:1277
 #, fuzzy, c-format
 msgid "%d categories - no nearest feature found"
-#: ../vector/v.distance/main.c:1117
+#: ../vector/v.distance/main.c:1286
 #, c-format
 msgid "%d distances calculated"
 msgstr ""
-#: ../vector/v.distance/main.c:1118
+#: ../vector/v.distance/main.c:1287
 #, fuzzy, c-format
 msgid "%d records inserted"
 msgstr "%d records aggiornati"
-#: ../vector/v.distance/main.c:1120
+#: ../vector/v.distance/main.c:1289
 #, fuzzy, c-format
 msgid "%d insert errors"
 msgstr "%s errori di aggiornamento\n"
-#: ../vector/v.distance/main.c:1124
+#: ../vector/v.distance/main.c:1293
 #, fuzzy, c-format
 msgid "%d categories read from the map"
 msgstr "%d categrie caricate dalla tabella"
-#: ../vector/v.distance/main.c:1126
+#: ../vector/v.distance/main.c:1295
 #, fuzzy, c-format
 msgid "%d categories exist in the table"
 msgstr "%d categorie dal vettoriale mancano nella tabella"
-#: ../vector/v.distance/main.c:1128
+#: ../vector/v.distance/main.c:1297
 #, fuzzy, c-format
 msgid "%d categories read from the map exist in the table"
-#: ../vector/v.distance/main.c:1131
+#: ../vector/v.distance/main.c:1300
 #, fuzzy, c-format
 msgid "%d categories read from the map don't exist in the table"
-#: ../vector/v.distance/main.c:1133 ../vector/v.what.rast/main.c:361
+#: ../vector/v.distance/main.c:1302 ../vector/v.what.rast/main.c:361
 #, c-format
 msgid "%d records updated"
-#: ../vector/v.distance/main.c:1135 ../vector/v.what.rast/main.c:362
+#: ../vector/v.distance/main.c:1304 ../vector/v.what.rast/main.c:362
 #, fuzzy, c-format
 msgid "%d update errors"
@@ -19014,7 +19074,7 @@
 msgstr "Nome del raster"
 #: ../vector/v.outlier/main.c:168 ../vector/v.outlier/main.c:234
-#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:364
+#: ../vector/v.surf.bspline/main.c:209 ../vector/v.surf.bspline/main.c:365
 #: ../vector/v.lidar.edgedetection/main.c:190
 #: ../vector/v.lidar.edgedetection/main.c:202
 #: ../vector/v.lidar.edgedetection/main.c:252
@@ -19034,7 +19094,7 @@
 #: ../vector/v.outlier/main.c:178 ../vector/v.surf.bspline/main.c:222
-#: ../vector/v.surf.bspline/main.c:287
+#: ../vector/v.surf.bspline/main.c:282
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr "impossibile aprire <%s>"
@@ -19067,13 +19127,12 @@
 msgid "Outlier detection"
 msgstr "Colore del bordo"
-#: ../vector/v.outlier/main.c:420 ../vector/v.surf.bspline/main.c:710
-#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.outlier/main.c:420 ../vector/v.lidar.edgedetection/main.c:457
 #: ../vector/v.lidar.correction/main.c:426
 msgid "No data within this subregion. Consider changing the spline step."
 msgstr ""
-#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:732
+#: ../vector/v.outlier/main.c:430 ../vector/v.surf.bspline/main.c:734
 #: ../vector/v.lidar.edgedetection/main.c:467
 #: ../vector/v.lidar.correction/main.c:437
 #, fuzzy
@@ -20626,50 +20685,57 @@
 msgid "Cross validation finished for sie = %f and sin = %f"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:273
-#, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:279
+#: ../vector/v.surf.bspline/main.c:274
 #, fuzzy, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
-#: ../vector/v.surf.bspline/main.c:295
+#: ../vector/v.surf.bspline/main.c:290
 #, c-format
 msgid ""
 "Sorry, <%s> driver is not allowed for vector output in this module. Try with "
 "a raster output or other driver."
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:331
+#: ../vector/v.surf.bspline/main.c:312
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr "raster <%s> non trovato"
+#: ../vector/v.surf.bspline/main.c:323
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+#: ../vector/v.surf.bspline/main.c:332
 msgid "Cannot read field info"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:352
+#: ../vector/v.surf.bspline/main.c:353
 #, fuzzy, c-format
 msgid "[%d] records selected from table"
-#: ../vector/v.surf.bspline/main.c:371
+#: ../vector/v.surf.bspline/main.c:372
 #, fuzzy, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
 msgstr "Nome della mappa raster risultante"
-#: ../vector/v.surf.bspline/main.c:394
+#: ../vector/v.surf.bspline/main.c:395
 msgid ""
 "Cannot allocate memory for auxiliar matrix.Consider changing region "
 "resolution"
 msgstr ""
-#: ../vector/v.surf.bspline/main.c:591
+#: ../vector/v.surf.bspline/main.c:593
 #, fuzzy, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr "Nessun record per la cat = %d"
+#: ../vector/v.surf.bspline/main.c:712
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:73
 #, c-format
 msgid "%d are too many points. The cross validation would take too much time."
@@ -23071,8 +23137,9 @@
 msgstr "File di input"
 #: ../vector/v.to.rast/do_areas.c:119
-msgid "Area without centroid (may be OK for island)"
-msgstr ""
+#, fuzzy
+msgid "Area without centroid (OK for island)"
+msgstr "Aree senza categoria: %e (%d areas)"
 #: ../vector/v.to.rast/do_areas.c:126
 msgid "Area centroid without category"
@@ -24159,11 +24226,11 @@
 msgid "Layer must be > 0 for 'where'"
 msgstr ""
-#: ../vector/v.info/main.c:39
+#: ../vector/v.info/main.c:40
 msgid "history"
 msgstr ""
-#: ../vector/v.info/main.c:41
+#: ../vector/v.info/main.c:42
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr ""
@@ -24184,7 +24251,7 @@
 msgid "Print topology information only"
-#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:159
+#: ../vector/v.info/print.c:128 ../vector/v.db.connect/main.c:158
 #, fuzzy, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
@@ -24771,31 +24838,31 @@
 msgid "Bad arguments to anyfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:67
+#: ../vector/v.mapcalc/map.c:68
 #, c-format
 msgid "Performing 1 arg map function on map %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:78
+#: ../vector/v.mapcalc/map.c:79
 #, c-format
 msgid "Performing 2 arg map function on maps %s and %s"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:90
+#: ../vector/v.mapcalc/map.c:91
 #, fuzzy, c-format
 msgid "Performing map %s + %s"
 msgstr "Non riesco a trovare il file raster %s"
-#: ../vector/v.mapcalc/map.c:264
+#: ../vector/v.mapcalc/map.c:265
 msgid "Can't call bad map-function"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:276
+#: ../vector/v.mapcalc/map.c:277
 #, c-format
 msgid "Bad arguments to mapfunc %s (argc = %d)"
 msgstr ""
-#: ../vector/v.mapcalc/map.c:300
+#: ../vector/v.mapcalc/map.c:301
 #, c-format
 msgid "No function defined to perform map %c map"
 msgstr ""
@@ -24957,64 +25024,64 @@
 #: ../vector/v.db.connect/main.c:89
 #, fuzzy
-msgid "Print all map connection parameters and exit in shell script style"
+msgid "Print all map connection parameters in shell script style and exit"
-#: ../vector/v.db.connect/main.c:92
+#: ../vector/v.db.connect/main.c:91
 msgid "Format: layer[/layer name] table key database driver"
 msgstr ""
-#: ../vector/v.db.connect/main.c:98
+#: ../vector/v.db.connect/main.c:97
 msgid "Print types/names of table columns for specified layer and exit"
 msgstr ""
 "Stampa i tipi/nomi delle colonne della tabella del layer selezionato ed esce"
-#: ../vector/v.db.connect/main.c:105
+#: ../vector/v.db.connect/main.c:104
 #, fuzzy
 msgid "Overwrite connection parameter for certain layer"
-#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.db.connect/main.c:109
 msgid "Delete connection for certain layer (not the table)"
 msgstr "Cancella la connessione al database del layer (ma non la tabella)"
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:143
 msgid "Please choose only one print style"
 msgstr "Per favore scegli un solo stile di output"
-#: ../vector/v.db.connect/main.c:152
+#: ../vector/v.db.connect/main.c:151
 #, fuzzy
 msgid "Unable to modify vector map stored in other mapset"
 msgstr "Converti una mappa raster in file height field per POVRAY"
-#: ../vector/v.db.connect/main.c:165
+#: ../vector/v.db.connect/main.c:164
 #, fuzzy, c-format
-msgid "Vector map <%s> is connected by:"
+msgid "Vector map <%s> is connected by:\n"
-#: ../vector/v.db.connect/main.c:190
+#: ../vector/v.db.connect/main.c:192
 #, c-format
 msgid ""
 "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:196
+#: ../vector/v.db.connect/main.c:198
 #, c-format
 msgid ""
 "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
-#: ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
 msgstr "Usa il flag -o per sovrascrivere il link esistente del layer <%d>"
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:307
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
 msgid "Table <%s> does not exist in database <%s>"
 msgstr "La tabella <%s> non esiste nel database <%s>"
-#: ../vector/v.db.connect/main.c:295 ../vector/v.db.connect/main.c:313
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
 msgid ""
 "The table <%s> is now part of vector map <%s> and may be deleted or "
@@ -25023,16 +25090,16 @@
 "La tabella <%s> è ora parte del vettoriale <%s> e può essere cancellata o "
 "sovrascritta dai moduli GRASS"
-#: ../vector/v.db.connect/main.c:334
+#: ../vector/v.db.connect/main.c:336
 #, c-format
 msgid "Cannot grant privileges on table %s"
-#: ../vector/v.db.connect/main.c:337
+#: ../vector/v.db.connect/main.c:339
 msgid "Select privileges were granted on the table"
 msgstr "Permessi selezionati concessi alla tabella"
-#: ../vector/v.db.connect/main.c:344
+#: ../vector/v.db.connect/main.c:346
 msgid ""
 "For defining a new connection you have to specify these parameters: driver, "
 "database, table [, key [, layer]]"
@@ -25433,41 +25500,41 @@
 msgid "Name of Arc cost column"
 msgstr "Numero di colonne"
-#: ../misc/m.measure/main.c:46
+#: ../misc/m.measure/main.c:45
 msgid "Measures the lengths and areas of features."
 msgstr ""
-#: ../misc/m.measure/main.c:47 ../misc/m.cogo/main.c:225
+#: ../misc/m.measure/main.c:46 ../misc/m.cogo/main.c:225
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous"
 msgstr ""
-#: ../misc/m.measure/main.c:48
+#: ../misc/m.measure/main.c:47
 msgid "measurement"
 msgstr ""
-#: ../misc/m.measure/main.c:52
+#: ../misc/m.measure/main.c:51
 #, fuzzy
 msgid "Vertex coordinates"
 msgstr "Utilizzando le coordinate del centro della mappa\n"
-#: ../misc/m.measure/main.c:60
+#: ../misc/m.measure/main.c:59
 #, fuzzy
 msgid "Default: location map units"
 msgstr "Errore di discretizzazione in unità di mappa"
-#: ../misc/m.measure/main.c:64
+#: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
 msgstr ""
 "Stampa le impostazioni della region corrente (in stile script per la shell)"
-#: ../misc/m.measure/main.c:107
+#: ../misc/m.measure/main.c:106
 #, fuzzy
 msgid "Length:"
 msgstr "Lunghezza: %f\n"
-#: ../misc/m.measure/main.c:118
+#: ../misc/m.measure/main.c:117
 #, fuzzy
 msgid "Area:"
 msgstr "Area\n"
@@ -25520,7 +25587,7 @@
 msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:73
-#: ../visualization/nviz2/cmd/main.c:46
+#: ../visualization/nviz2/cmd/main.c:48
 msgid "visualization"
 msgstr "visualizzazione"
@@ -25597,297 +25664,347 @@
 msgid "Loading data failed"
-#: ../visualization/nviz2/cmd/main.c:50
+#: ../visualization/nviz2/cmd/main.c:52
 msgid "Allows rendering GIS data is a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:51
+#: ../visualization/nviz2/cmd/main.c:53
 msgid ""
 "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
 "data) in a 3D space."
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:139
+#: ../visualization/nviz2/cmd/main.c:131
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:149
+#: ../visualization/nviz2/cmd/main.c:143
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
 msgstr ""
-#: ../visualization/nviz2/cmd/main.c:174
+#: ../visualization/nviz2/cmd/main.c:204
 #, fuzzy
 msgid "Unsupported output format"
-#: ../visualization/nviz2/cmd/main.c:176 ../imagery/i.cluster/main.c:335
+#: ../visualization/nviz2/cmd/main.c:206 ../imagery/i.cluster/main.c:335
 #, fuzzy, c-format
 msgid "File <%s> created."
 msgstr "Location %s creata!"
-#: ../visualization/nviz2/cmd/args.c:47
+#: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:48 ../visualization/nviz2/cmd/args.c:114
-#: ../visualization/nviz2/cmd/args.c:123 ../visualization/nviz2/cmd/args.c:130
-#: ../visualization/nviz2/cmd/args.c:136 ../visualization/nviz2/cmd/args.c:145
-#: ../visualization/nviz2/cmd/args.c:154 ../visualization/nviz2/cmd/args.c:164
-#: ../visualization/nviz2/cmd/args.c:172 ../visualization/nviz2/cmd/args.c:182
-#: ../visualization/nviz2/cmd/args.c:190 ../visualization/nviz2/cmd/args.c:200
+#: ../visualization/nviz2/cmd/args.c:50 ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:131 ../visualization/nviz2/cmd/args.c:138
+#: ../visualization/nviz2/cmd/args.c:144 ../visualization/nviz2/cmd/args.c:152
+#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
 msgstr "Superficie"
-#: ../visualization/nviz2/cmd/args.c:73
+#: ../visualization/nviz2/cmd/args.c:81
 #, fuzzy
-msgid "Name for output file (without extension)"
+msgid "Name for output image file (without extension)"
-#: ../visualization/nviz2/cmd/args.c:74 ../visualization/nviz2/cmd/args.c:88
-#: ../visualization/nviz2/cmd/args.c:98
+#: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:106
 #, fuzzy
 msgid "Image"
-#: ../visualization/nviz2/cmd/args.c:86
+#: ../visualization/nviz2/cmd/args.c:94
 #, fuzzy
 msgid "Graphics file format"
-#: ../visualization/nviz2/cmd/args.c:96
+#: ../visualization/nviz2/cmd/args.c:104
 #, fuzzy
-msgid "Width and height of output image"
+msgid "Size (width, height) of output image"
 msgstr "Spessore dell'evidenziazione"
-#: ../visualization/nviz2/cmd/args.c:113
+#: ../visualization/nviz2/cmd/args.c:121
 #, fuzzy
 msgid "Name of raster map(s) for elevation"
 msgstr "Nome di una mappa raster esistente"
-#: ../visualization/nviz2/cmd/args.c:122
+#: ../visualization/nviz2/cmd/args.c:130
 #, fuzzy
 msgid "Elevation value(s)"
 msgstr "Mappa raster risultante"
-#: ../visualization/nviz2/cmd/args.c:129
+#: ../visualization/nviz2/cmd/args.c:137
 #, fuzzy
 msgid "Name of raster map(s) for color"
 msgstr "Nome della mappa raster che contiene i risultati"
-#: ../visualization/nviz2/cmd/args.c:135
+#: ../visualization/nviz2/cmd/args.c:143
 #, fuzzy
 msgid "Color value(s)"
 msgstr "colonne: %d"
-#: ../visualization/nviz2/cmd/args.c:144
+#: ../visualization/nviz2/cmd/args.c:151
 #, fuzzy
 msgid "Name of raster map(s) for mask"
-#: ../visualization/nviz2/cmd/args.c:153
+#: ../visualization/nviz2/cmd/args.c:160
 #, fuzzy
 msgid "Name of raster map(s) for transparency"
 msgstr "Nome della mappa raster da mostrare"
-#: ../visualization/nviz2/cmd/args.c:163
+#: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:171
+#: ../visualization/nviz2/cmd/args.c:178
 #, fuzzy
 msgid "Name of raster map(s) for shininess"
-#: ../visualization/nviz2/cmd/args.c:181
+#: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:189
+#: ../visualization/nviz2/cmd/args.c:196
 #, fuzzy
 msgid "Name of raster map(s) for emission"
-#: ../visualization/nviz2/cmd/args.c:199
+#: ../visualization/nviz2/cmd/args.c:206
 msgid "Emission value(s)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:213
+#: ../visualization/nviz2/cmd/args.c:220
 msgid "Draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:216 ../visualization/nviz2/cmd/args.c:227
-#: ../visualization/nviz2/cmd/args.c:238 ../visualization/nviz2/cmd/args.c:250
-#: ../visualization/nviz2/cmd/args.c:262 ../visualization/nviz2/cmd/args.c:271
-#: ../visualization/nviz2/cmd/args.c:283 ../visualization/nviz2/cmd/args.c:293
-#: ../visualization/nviz2/cmd/args.c:513 ../visualization/nviz2/cmd/args.c:525
+#: ../visualization/nviz2/cmd/args.c:223 ../visualization/nviz2/cmd/args.c:234
+#: ../visualization/nviz2/cmd/args.c:245 ../visualization/nviz2/cmd/args.c:257
+#: ../visualization/nviz2/cmd/args.c:269 ../visualization/nviz2/cmd/args.c:278
+#: ../visualization/nviz2/cmd/args.c:290 ../visualization/nviz2/cmd/args.c:300
+#: ../visualization/nviz2/cmd/args.c:520 ../visualization/nviz2/cmd/args.c:532
 msgid "Draw"
 msgstr "Disegna"
-#: ../visualization/nviz2/cmd/args.c:225
+#: ../visualization/nviz2/cmd/args.c:232
 #, fuzzy
 msgid "Fine resolution"
-#: ../visualization/nviz2/cmd/args.c:236
+#: ../visualization/nviz2/cmd/args.c:243
 #, fuzzy
 msgid "Coarse resolution"
-#: ../visualization/nviz2/cmd/args.c:247
+#: ../visualization/nviz2/cmd/args.c:254
 #, fuzzy
 msgid "Draw style"
-#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:280
+#: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:268
+#: ../visualization/nviz2/cmd/args.c:275
 #, fuzzy
 msgid "Wire color"
 msgstr " nv colore\n"
-#: ../visualization/nviz2/cmd/args.c:304
+#: ../visualization/nviz2/cmd/args.c:311
 #, fuzzy
 msgid "Name of line vector overlay map(s)"
-#: ../visualization/nviz2/cmd/args.c:305 ../visualization/nviz2/cmd/args.c:316
-#: ../visualization/nviz2/cmd/args.c:327 ../visualization/nviz2/cmd/args.c:339
-#: ../visualization/nviz2/cmd/args.c:349 ../visualization/nviz2/cmd/args.c:361
+#: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
+#: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
+#: ../visualization/nviz2/cmd/args.c:356 ../visualization/nviz2/cmd/args.c:368
 msgid "Vector lines"
 msgstr "Linee vettoriali"
-#: ../visualization/nviz2/cmd/args.c:315
+#: ../visualization/nviz2/cmd/args.c:322
 #, fuzzy
 msgid "Vector line width"
 msgstr "Il vettore non è 3D"
-#: ../visualization/nviz2/cmd/args.c:324
+#: ../visualization/nviz2/cmd/args.c:331
 #, fuzzy
 msgid "Vector line color"
-#: ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:343
 msgid "Vector line display mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:348
+#: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:372
+#: ../visualization/nviz2/cmd/args.c:379
 #, fuzzy
 msgid "Name of point vector overlay map(s)"
 msgstr "Nome della mappa di input"
-#: ../visualization/nviz2/cmd/args.c:373 ../visualization/nviz2/cmd/args.c:384
-#: ../visualization/nviz2/cmd/args.c:396 ../visualization/nviz2/cmd/args.c:407
-#: ../visualization/nviz2/cmd/args.c:420 ../visualization/nviz2/cmd/args.c:430
+#: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
+#: ../visualization/nviz2/cmd/args.c:427 ../visualization/nviz2/cmd/args.c:437
 msgid "Vector points"
 msgstr "Punti vettoriale"
-#: ../visualization/nviz2/cmd/args.c:383
+#: ../visualization/nviz2/cmd/args.c:390
 msgid "Icon size"
 msgstr " Grandezza icona"
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:402
 msgid "Icon width"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:411
 #, fuzzy
 msgid "Icon color"
-#: ../visualization/nviz2/cmd/args.c:416
+#: ../visualization/nviz2/cmd/args.c:423
 msgid "Icon marker"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:446
+#: ../visualization/nviz2/cmd/args.c:453
 #, fuzzy
 msgid "Viewpoint position (x,y model coordinates)"
-#: ../visualization/nviz2/cmd/args.c:447 ../visualization/nviz2/cmd/args.c:458
-#: ../visualization/nviz2/cmd/args.c:468 ../visualization/nviz2/cmd/args.c:480
+#: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
+#: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
 msgid "Viewpoint"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:457
+#: ../visualization/nviz2/cmd/args.c:464
 #, fuzzy
 msgid "Viewpoint height (in map units)"
 msgstr "Dimensione delle etichette (in unità della mappa)"
-#: ../visualization/nviz2/cmd/args.c:467
+#: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:479
+#: ../visualization/nviz2/cmd/args.c:486
 msgid "Viewpoint twist angle (in degrees)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:500 ../visualization/nviz2/cmd/args.c:535
-#: ../visualization/nviz2/cmd/args.c:547 ../visualization/nviz2/cmd/args.c:557
+#: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
+#: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
 #, fuzzy
 msgid "Volumes"
-#: ../visualization/nviz2/cmd/args.c:510
+#: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:522
+#: ../visualization/nviz2/cmd/args.c:529
 msgid "Volume shading"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:534
+#: ../visualization/nviz2/cmd/args.c:541
 #, fuzzy
 msgid "Volume position"
-#: ../visualization/nviz2/cmd/args.c:545
+#: ../visualization/nviz2/cmd/args.c:552
 #, fuzzy
 msgid "Volume resolution"
-#: ../visualization/nviz2/cmd/args.c:556
+#: ../visualization/nviz2/cmd/args.c:563
 #, fuzzy
 msgid "Isosurface level"
 msgstr "Livello minimo di contorno"
-#: ../visualization/nviz2/cmd/args.c:602
+#: ../visualization/nviz2/cmd/args.c:578
+#, fuzzy
+msgid "Light position (x,y,z model coordinates)"
+msgstr "Utilizzando le coordinate del centro della mappa\n"
+#: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
+#: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
+#, fuzzy
+msgid "Lighting"
+msgstr "Esistente"
+#: ../visualization/nviz2/cmd/args.c:584
+#, fuzzy
+msgid "Light color"
+msgstr "Colore di evidenziazione del testo"
+#: ../visualization/nviz2/cmd/args.c:593
+msgid "Light brightness"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:603
+msgid "Light ambient"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:615
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:619
+#, fuzzy
+msgid "Fringe edges"
+#: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
+#: ../visualization/nviz2/cmd/args.c:635
+#, fuzzy
+msgid "Fringe"
+msgstr "Interrotto."
+#: ../visualization/nviz2/cmd/args.c:625
+#, fuzzy
+msgid "Fringe color"
+msgstr "Colore della linea"
+#: ../visualization/nviz2/cmd/args.c:634
+#, fuzzy
+msgid "Fringe elevation"
+msgstr "Mappa(e) raster da leggere"
+#: ../visualization/nviz2/cmd/args.c:679
 #, c-format
 msgid "At least one <%s> or <%s> required"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:616 ../visualization/nviz2/cmd/args.c:646
-#: ../visualization/nviz2/cmd/args.c:658 ../visualization/nviz2/cmd/args.c:664
-#: ../visualization/nviz2/cmd/args.c:670 ../visualization/nviz2/cmd/args.c:676
+#: ../visualization/nviz2/cmd/args.c:693 ../visualization/nviz2/cmd/args.c:723
+#: ../visualization/nviz2/cmd/args.c:735 ../visualization/nviz2/cmd/args.c:741
+#: ../visualization/nviz2/cmd/args.c:747 ../visualization/nviz2/cmd/args.c:753
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:652
+#: ../visualization/nviz2/cmd/args.c:729
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:689 ../visualization/nviz2/cmd/args.c:703
-#: ../visualization/nviz2/cmd/args.c:710
+#: ../visualization/nviz2/cmd/args.c:766 ../visualization/nviz2/cmd/args.c:780
+#: ../visualization/nviz2/cmd/args.c:787
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:696
+#: ../visualization/nviz2/cmd/args.c:773
 #, c-format
 msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
 msgstr ""
-#: ../visualization/nviz2/cmd/args.c:722
+#: ../visualization/nviz2/cmd/args.c:799
 #, c-format
 msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
 msgstr ""
@@ -26035,131 +26152,6 @@
 msgid "Unable to copy attribute table to vector map <%s>"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
-#, fuzzy, c-format
-msgid "Failed in attempt to open %s"
-msgstr "impossibile aprire <%s>"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
-msgid ""
-"Generates raster map layers of slope, aspect, curvatures and partial "
-"derivatives from a raster map layer of true elevation values. Aspect is "
-"calculated counterclockwise from east."
-msgstr ""
-"Genera raster della pendenza, esposizione, curvature e le derivate parziali "
-"da un raster con valori dell'elevazione. Esposizione è calcolata in senso "
-"antiorario partendo dall'est."
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:164
-msgid "Raster elevation file name"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:172
-#, fuzzy
-msgid "Output slope filename"
-msgstr "Nome della tabella in output"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:180
-#, fuzzy
-msgid "Output aspect filename"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
-#, fuzzy
-msgid "Output profile curvature filename"
-msgstr "Nome del driver in output"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
-#, fuzzy
-msgid "Output tangential curvature filename"
-msgstr "Nome del database in output"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
-msgid "Output first order partial derivative dx (E-W slope) filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:236
-msgid "Output first order partial derivative dy (N-S slope) filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:246
-msgid "Output second order partial derivative dxx filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:256
-msgid "Output second order partial derivative dyy filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:266
-msgid "Output second order partial derivative dxy filename"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:412
-#, c-format
-msgid "wrong type: %s"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1021
-#, fuzzy
-msgid "Creating support files..."
-msgstr "Errore nella lettura del file dbmscap\n"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
-#, fuzzy, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1212
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1283
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1309
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1333
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1357
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1381
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1405
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr ""
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1429
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr ""
 #: ../ps/ps.map/ps_vlines.c:57 ../ps/ps.map/ps_vpoints.c:73
 #: ../ps/ps.map/ps_vareas.c:165
 msgid "Cannot load data from table"
@@ -26451,36 +26443,47 @@
 msgstr "Nome di un file MAT-File(v4) esistente"
 #: ../db/db.connect/main.c:49
-msgid "Prints/sets general DB connection for current mapset and exits."
+#, fuzzy
+msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
 "Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
-#: ../db/db.connect/main.c:54
+#: ../db/db.connect/main.c:53
 msgid "Print current connection parameters and exit"
 msgstr "Mostra i parametri della connessione in uso ed esce"
-#: ../db/db.connect/main.c:60
+#: ../db/db.connect/main.c:59
 #, fuzzy
 msgid "Check connection parameters, set if uninitialized, and exit"
-#: ../db/db.connect/main.c:66 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:74 ../db/db.connect/main.c:84
+#: ../db/db.connect/main.c:60 ../db/db.connect/main.c:66
+#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:89
 msgid "Set"
 msgstr ""
-#: ../db/db.connect/main.c:82
+#: ../db/db.connect/main.c:64
+msgid "Set from default settings and exit"
+msgstr ""
+#: ../db/db.connect/main.c:65
 #, fuzzy
+msgid "Overwrite current settings if initialized"
+msgstr "Sovrascrivi la MASK esistente"
+#: ../db/db.connect/main.c:87
+#, fuzzy
 msgid "Default group of database users to which select privilege is granted"
 msgstr ""
 "Gruppo utenti predefinito del database per il quale i privilegi sono "
 "garantiti"
-#: ../db/db.connect/main.c:118
+#: ../db/db.connect/main.c:122
 msgid "Database connection not defined. Run db.connect."
 msgstr "Connessione al database non definita. Esegui db.connect"
-#: ../db/db.connect/main.c:138
+#: ../db/db.connect/main.c:141 ../db/db.connect/main.c:163
 #, c-format
 msgid ""
 "Default driver / database set to:\n"
@@ -26488,11 +26491,11 @@
 "database: %s"
 msgstr ""
-#: ../db/db.connect/main.c:145
+#: ../db/db.connect/main.c:148
 msgid "Default driver is not set"
 msgstr ""
-#: ../db/db.connect/main.c:148
+#: ../db/db.connect/main.c:151
 #, fuzzy
 msgid "Default database is not set"
 msgstr "Nome del database in input"
@@ -26752,7 +26755,7 @@
 msgid "'-' to read from standard input"
 msgstr "File raster ascii da importare"
-#: ../db/db.execute/main.c:133
+#: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
 msgstr "Ignora gli errori SQL e continua"
@@ -26812,19 +26815,20 @@
 msgid "succeeded"
 msgstr "....successo!"
-#: ../db/db.select/main.c:208
+#: ../db/db.select/main.c:194
 msgid "SQL select statement"
 msgstr "Comando SQL select"
-#: ../db/db.select/main.c:210
+#: ../db/db.select/main.c:196
 #, fuzzy
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr ""
 "istruzione SQL select, ad esempio: 'select * from rybniky where kapri = "
 "'hodne'"
-#: ../db/db.select/main.c:215
-msgid "Name of file with sql statement"
+#: ../db/db.select/main.c:201
+#, fuzzy
+msgid "Name of file with SQL select statement(s)"
 msgstr "Nome del file con comandi sql"
 #: ../db/db.select/main.c:247
@@ -27037,7 +27041,7 @@
 msgstr "Calcola la regressione lineare per due raster: y = a + b*x"
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Slower but accurate (applies to FP maps only)"
+msgid "Slower but more accurate (applies to FP maps only)"
 msgstr ""
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:6
@@ -27146,49 +27150,67 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
 #, fuzzy
+msgid "Files & format"
+msgstr "Mappa in output"
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
 msgid "Output coordinate file (omit to send to stdout)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
 #, fuzzy
 msgid "Field separator (format: input[,output])"
 msgstr "campo separatore in output"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
 #, fuzzy
 msgid "Input projection parameters (PROJ.4 style)"
 msgstr "Visualizza il raster della direzione"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
 #, fuzzy
+msgid "Projections"
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#, fuzzy
 msgid "Output projection parameters (PROJ.4 style)"
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use LL WGS84 as input and current location as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
 msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
+"Output long/lat in decimal degrees, or other projections with many decimal "
 "places"
 msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
 #, fuzzy
 msgid "Include input coordinates in output file"
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
 #, fuzzy
 msgid "Include column names in output file"
 msgstr "non includere i nomi delle colonne nell'output"
@@ -27452,6 +27474,10 @@
 msgid "List available modules in the add-ons repository in shell script style"
 msgstr "Visualizza i formati supportati ed esci"
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "Don't deleted downloaded source code when installing new extension"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 msgid "Prints a graph of the correlation between data layers (in pairs)."
 msgstr ""
@@ -27762,13 +27788,6 @@
 msgid "Raster map to use as mask"
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-#, fuzzy
-msgid "Create"
-msgstr "Campo separatore in output"
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 #, fuzzy
 msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
@@ -27979,6 +27998,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
@@ -27992,7 +28012,7 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:15
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:10
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
@@ -28330,19 +28350,22 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
 #, fuzzy
-msgid "Vector map for which to edit attribute table"
+msgid "Name of vector map for which to edit attribute table"
 msgstr "Non riesco a descrivere la tabella"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
 #, fuzzy
-msgid "Layer where to add column"
+msgid "Layer number where to add column(s)"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:8
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 msgid ""
-"Name and type of the new column(s) ('name type [,name type, ...]' - types "
-"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
-"and DATE)"
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -28490,7 +28513,7 @@
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Set color rules based on stddev from a map's mean value."
+msgid "Set color rules based on stddev from a raster map's mean value."
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -28895,20 +28918,26 @@
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 #, fuzzy
+msgid "Print stats in shell script style"
+msgstr ""
+"Stampa le impostazioni della region corrente (in stile script per la shell)"
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#, fuzzy
 msgid "Name of data table"
 msgstr "Nome del filtro file"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 #, fuzzy
 msgid "Column on which to calculate statistics (must be numeric)"
 msgstr "Nome della mappa raster da utilizzare per <%s>"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 #, fuzzy
 msgid "Database/directory for table"
 msgstr "Nessun record nel database per la categoria %d"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:9
 #, fuzzy
 msgid "Database driver"
 msgstr "Nome del database:"
@@ -28975,6 +29004,11 @@
 msgid "Signature file <%s> is invalid"
+#: ../imagery/i.smap/read_sig.c:30
+#, fuzzy, c-format
+msgid "Signature file <%s> is empty"
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
 #, fuzzy
 msgid "Name of file containing signatures"
@@ -29540,19 +29574,19 @@
 msgid "Group <%s> contains no raster maps; run i.group"
 msgstr "Gruppo [%s] non contiene mappe, avvia i.group"
-#: ../image
