[GRASS-SVN] r43351 - grass/branches/develbranch_6/vector/v.surf.idw
svn_grass at osgeo.org
Mon Aug 30 05:27:15 EDT 2010
Author: martinl
Date: 2010-08-30 09:27:15 +0000 (Mon, 30 Aug 2010)
New Revision: 43351
grass/branches/develbranch_6/vector/v.surf.idw/main.c
v.surf.idw: more guisections
Modified: grass/branches/develbranch_6/vector/v.surf.idw/main.c
--- grass/branches/develbranch_6/vector/v.surf.idw/main.c 2010-08-30 09:17:59 UTC (rev 43350)
+++ grass/branches/develbranch_6/vector/v.surf.idw/main.c 2010-08-30 09:27:15 UTC (rev 43351)
@@ -90,6 +90,21 @@
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
+ parm.dfield = G_define_standard_option(G_OPT_V_FIELD);
+ parm.dfield->description =
+ _("If set to 0, z coordinates are used (3D vector only)");
+ parm.dfield->answer = "1";
+ parm.dfield->gisprompt = "old_layer,layer,layer_zero";
+ parm.dfield->guisection = _("Values");
+ parm.col = G_define_option();
+ parm.col->key = "column";
+ parm.col->type = TYPE_STRING;
+ parm.col->required = NO;
+ parm.col->label = _("Attribute table column with values to interpolate");
+ parm.col->description = _("Required if layer > 0");
+ parm.col->guisection = _("Values");
parm.npoints = G_define_option();
parm.npoints->key = "npoints";
parm.npoints->key_desc = "count";
@@ -97,6 +112,7 @@
parm.npoints->required = NO;
parm.npoints->description = _("Number of interpolation points");
parm.npoints->answer = "12";
+ parm.npoints->guisection = _("Settings");
parm.power = G_define_option();
parm.power->key = "power";
@@ -104,26 +120,15 @@
parm.power->answer = "2.0";
parm.power->description =
_("Power parameter; greater values assign greater influence to closer points");
+ parm.power->guisection = _("Settings");
- parm.dfield = G_define_standard_option(G_OPT_V_FIELD);
- parm.dfield->description =
- _("If set to 0, z coordinates are used (3D vector only)");
- parm.dfield->answer = "1";
- parm.dfield->gisprompt = "old_layer,layer,layer_zero";
- parm.col = G_define_option();
- parm.col->key = "column";
- parm.col->type = TYPE_STRING;
- parm.col->required = NO;
- parm.col->label = _("Attribute table column with values to interpolate");
- parm.col->description = _("Required if layer > 0");
noindex = G_define_flag();
noindex->key = 'n';
noindex->label = _("Don't index points by raster cell");
noindex->description = _("Slower but uses"
" less memory and includes points from outside region"
" in the interpolation");
+ noindex->guisection = _("Settings");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
