[GRASS-SVN] r43354 - grass/trunk/gui/wxpython/gui_modules
Mon Aug 30 08:23:11 EDT 2010
Author: martinl
Date: 2010-08-30 12:23:11 +0000 (Mon, 30 Aug 2010)
New Revision: 43354
   grass/trunk/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: improvements in if-else statements
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-08-30 11:32:15 UTC (rev 43353)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2010-08-30 12:23:11 UTC (rev 43354)
@@ -157,10 +157,12 @@
     def RemoveItem(self, item):
         """!Remove item from model
-        @return list of related items
+        @return list of related items to remove/update
         relList = list()
+        upList = list()
         if not isinstance(item, ModelData):
             self.items.remove(item)
@@ -168,8 +170,11 @@
             for rel in item.GetRelations():
                 relList.append(rel)
                 data = rel.GetData()
-                relList.append(data)
+                if len(data.GetRelations()) < 2:
+                    relList.append(data)
+                else:
+                    upList.append(data)
         elif isinstance(item, ModelData):
                 relList.append(rel)
@@ -178,7 +183,7 @@
                 else:
                     relList.append(rel.GetFrom())
-        return relList
+        return relList, upList
     def FindAction(self, aId):
         """!Find action by id"""
@@ -418,12 +423,9 @@
     def Update(self):
         """!Update model"""
-        for action in self.actions:
-            action.Update()
+        for item in self.items:
+            item.Update()
-        for data in self.data:
-            data.Update()
     def IsParameterized(self):
         """!Return True if model is parameterized"""
         if self.Parameterize():
@@ -1633,11 +1635,16 @@
         for shape in diagram.GetShapeList():
             if not shape.Selected():
                 continue
-            remList = self.parent.GetModel().RemoveItem(shape)
+            remList, upList = self.parent.GetModel().RemoveItem(shape)
             shape.Select(False)
             diagram.RemoveShape(shape)
+            del shape
             for item in remList:
                 diagram.RemoveShape(item)
+                item.__del__()
+            for item in upList:
+                item.Update()
         self.Refresh()
@@ -1649,6 +1656,9 @@
         self.isEnabled = True
         self.inBlock   = None
+    def __del__(self):
+        pass
     def GetId(self):
         """!Get id"""
         return self.id
@@ -1895,9 +1905,10 @@
     def FindData(self, name):
         """!Find data item by name"""
-        for d in self.data:
-            if name in d.GetName():
-                return d
+        for rel in self.GetRelations():
+            data = rel.GetData()
+            if name == rel.GetName() and name in data.GetName():
+                return data
         return None
@@ -1918,7 +1929,7 @@
 class ModelData(ModelObject, ogl.EllipseShape):
     def __init__(self, parent, x, y, value = '', prompt = '', width = None, height = None):
         """Data item class
         @param parent window parent
         @param x, y   position of the shape
         @param fname, tname list of parameter names from / to
@@ -1947,7 +1958,7 @@
             self.SetPen(wx.BLACK_PEN)
             self._setBrush()
-            self.AddText(value)
+            self._setText()
     def IsIntermediate(self):
         """!Checks if data item is intermediate"""
@@ -2072,7 +2083,10 @@
             name.append(rel.GetName())
         self.AddText('/'.join(name))
-        self.AddText(self.value)
+        if self.value:
+            self.AddText(self.value)
+        else:
+            self.AddText(_('<not defined>'))
     def Update(self):
         """!Update action"""
@@ -2491,6 +2505,10 @@
         ogl.LineShape.__init__(self)
+        self.fromShape.rels.remove(self)
+        self.toShape.rels.remove(self)
     def GetFrom(self):
         """!Get id of 'from' shape"""
         return self.fromShape
@@ -2498,7 +2516,7 @@
     def GetTo(self):
         """!Get id of 'to' shape"""
         return self.toShape
     def GetData(self):
         """!Get related ModelData instance
