[GRASS-SVN] r43357 - in grass/branches/develbranch_6/scripts: v.in.garmin v.in.gpsbabel
Tue Aug 31 01:59:14 EDT 2010
Author: hamish
Date: 2010-08-31 05:59:14 +0000 (Tue, 31 Aug 2010)
New Revision: 43357
   grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
   grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
survive cs2cs + spaces in NTv2 grid file pathnames; incr. gpsbabel coord prec to %.9f for lat/long
Modified: grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
--- grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin	2010-08-31 04:24:02 UTC (rev 43356)
+++ grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin	2010-08-31 05:59:14 UTC (rev 43357)
@@ -456,7 +456,8 @@
 	cp "${TEMPFILE}.base" "${TEMPFILE}.P_base"
     else
 	g.message "Attempting waypoint projection transform with cs2cs..."
-	cs2cs -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_base"
+	eval cs2cs -f %.7f $IN_PROJ +to `echo $OUT_PROJ` \
+	   < "${TEMPFILE}.base" > "${TEMPFILE}.P_base"
 	EXITCODE=$?
 	# check if transform REALLY worked (e.g. grid file not found)
 	BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_base"`"
@@ -664,7 +665,8 @@
 	    $1!="L" { printf(" %.7f %.7f\n", $1, $2) } END {;}' > "${TEMPFILE}.P_base"
     else
-	cs2cs -tL -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_mid"
+	eval cs2cs -tL -f %.7f $IN_PROJ +to `echo $OUT_PROJ` \
+	   < "${TEMPFILE}.base" > "${TEMPFILE}.P_mid"
 	EXITCODE=$?
 	BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_mid"`"
Modified: grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
--- grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel	2010-08-31 04:24:02 UTC (rev 43356)
+++ grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel	2010-08-31 05:59:14 UTC (rev 43357)
@@ -322,8 +322,12 @@
     else
 	g.message "Attempting waypoint projection transform with cs2cs"
+	eval cs2cs -f %.9f `echo $IN_PROJ` +to `echo $OUT_PROJ` \
 	EXITCODE=$?
 	# check if transform REALLY worked (e.g. when the grid file is not found)
 	if [ "$BAD_PTS" -gt 0 ] ; then
@@ -589,10 +593,14 @@
 	    $1!="L" { " %s %s\n", $1, $2) } END {;}' > "${TEMPFILE}.P_base"
     else
+	eval cs2cs -tL -f %.9f `echo $IN_PROJ` +to `echo $OUT_PROJ` \
 	EXITCODE=$?
-	 # check if transform REALLY worked (e.g. grid file not found)
-	 BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_mid"`"
+	# check if transform REALLY worked (e.g. grid file not found)
+	BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_mid"`"
 	    g.message message=""
 	    g.message -w "$BAD_PTS vertices failed reprojection."
