[GRASS-SVN] r44682 - in grass/branches/develbranch_6/raster: . r.regression.line
Thu Dec 23 08:45:54 EST 2010
Author: neteler
Date: 2010-12-23 05:45:54 -0800 (Thu, 23 Dec 2010)
New Revision: 44682
Added:
   grass/branches/develbranch_6/raster/r.regression.line/
   grass/branches/develbranch_6/raster/r.regression.line/Makefile
   grass/branches/develbranch_6/raster/r.regression.line/description.html
   grass/branches/develbranch_6/raster/r.regression.line/main.c
backported from GRASS 7
Added: grass/branches/develbranch_6/raster/r.regression.line/Makefile
--- grass/branches/develbranch_6/raster/r.regression.line/Makefile	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.regression.line/Makefile	2010-12-23 13:45:54 UTC (rev 44682)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.regression.line
+LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass/branches/develbranch_6/raster/r.regression.line/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass/branches/develbranch_6/raster/r.regression.line/description.html
--- grass/branches/develbranch_6/raster/r.regression.line/description.html	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.regression.line/description.html	2010-12-23 13:45:54 UTC (rev 44682)
@@ -0,0 +1,48 @@
+<H2>DESCRIPTION</H2>
+<EM>r.regression.line</EM> Calculates linear regression from two raster maps,
+according to the formula y = a + b*x, where x and y represent raster maps.
+Optionally saves regression coefficients to an ASCII file.
+The result includes the following coefficients:
+offset/intercept (a) and gain/slope (b), residuals (R),
+number of elements (N), means (medX, medY), standard deviations
+(sdX, sdY), and the F test for testing the significance of the
+regression model as a whole (F).
+<H2>NOTES</H2>
+The results for offset/intercept (a) and gain/slope (b) are
+identical to that obtained from R-stats's lm() function.
+<H2>EXAMPLE</H2>
+Comparison of the old and the new DEM in Spearfish:
+<div class="code"><pre>
+g.region rast=elevation.10m -p
+r.regression.line map1=elevation.dem map2=elevation.10m
+</pre></div>
+<p>
+Using the script style flag AND <em>eval</em> to make results
+available in the shell:
+eval `r.regression.line -g map1=elevation.dem map2=elevation.10m`
+echo $a
+479.615
+echo $b
+0.645631
+echo $R
+0.804441
+</pre></div>
+<H2>AUTHOR</H2>
+Dr. Agustin Lobo - alobo at ija.csic.es<BR>
+Updated to GRASS 5.7 Michael Barton, Arizona State University<BR>
+Script style output Markus Neteler<BR>
+Conversion to C module Markus Metz
+<p><i>Last changed: $Date$</i>
Property changes on: grass/branches/develbranch_6/raster/r.regression.line/description.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/branches/develbranch_6/raster/r.regression.line/main.c
--- grass/branches/develbranch_6/raster/r.regression.line/main.c	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.regression.line/main.c	2010-12-23 13:45:54 UTC (rev 44682)
@@ -0,0 +1,169 @@
+ * r.regression
+ *   Calculates linear regression from two raster maps: y = a + b*x
+ *   Copyright (C) 2010 by the GRASS Development Team
+ *   Author(s): original author Dr. Agustin Lobo
+ *              Markus Metz (conversion to C for speed)
+ *      This program is free software under the GNU General Public
+ *      License (>=v2). Read the file COPYING that comes with GRASS
+ *      for details.
+ *   This program is a replacement for the r.regression.line script
+ *   (the C version is up to 200x faster than the script version)
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+    unsigned int r, c, rows, cols;	/*  totals  */
+    int map1_fd, map2_fd;
+    double sumX, sumY, sumsqX, sumsqY, sumXY;
+    double meanX, meanY, varX, varY, sdX, sdY;
+    double A, B, R, F;
+    long count = 0;
+    DCELL *map1_buf, *map2_buf, map1_val, map2_val;
+    char *name, *mapset;
+    struct Option *input_map1, *input_map2, *output_opt;
+    struct Flag *shell_style;
+    struct Cell_head region;
+    struct GModule *module;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = (_("raster, statistics"));
+    module->description =
+	_("Calculates linear regression from two raster maps: y = a + b*x.");
+    /* Define the different options */
+    input_map1 = G_define_standard_option(G_OPT_R_MAP);
+    input_map1->key = "map1";
+    input_map1->description = (_("Map for x coefficient"));
+    input_map2 = G_define_standard_option(G_OPT_R_MAP);
+    input_map2->key = "map2";
+    input_map2->description = (_("Map for y coefficient"));
+    output_opt = G_define_standard_option(G_OPT_F_OUTPUT);
+    output_opt->key = "output";
+    output_opt->required = NO;
+    output_opt->description =
+	(_("ASCII file for storing regression coefficients (output to screen if file not specified)."));
+    shell_style = G_define_flag();
+    shell_style->key = 'g';
+    shell_style->description = _("Print in shell script style");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    name = output_opt->answer;
+    if (name != NULL && strcmp(name, "-") != 0) {
+	if (NULL == freopen(name, "w", stdout)) {
+	    G_fatal_error(_("Unable to open file <%s> for writing"), name);
+    G_get_window(&region);
+    rows = region.rows;
+    cols = region.cols;
+    /* open maps */
+    mapset = G_find_cell2(input_map1->answer, "");
+    if (mapset == NULL) {
+	G_fatal_error(_("Raster map <%s> not found"), input_map1->answer);
+    map1_fd = G_open_cell_old(input_map1->answer, "");
+    if (map1_fd < 0)
+	G_fatal_error(_("Unable to open raster map <%s>"),
+		      input_map1->answer);
+    mapset = G_find_cell2(input_map2->answer, "");
+	G_fatal_error(_("Raster map <%s> not found"), input_map2->answer);
+    map2_fd = G_open_cell_old(input_map2->answer, "");
+    if (map2_fd < 0)
+		      input_map2->answer);
+    map1_buf = G_allocate_raster_buf(DCELL_TYPE);
+    map2_buf = G_allocate_raster_buf(DCELL_TYPE);
+    sumX = sumY = sumsqX = sumsqY = sumXY = 0.0;
+    meanX = meanY = varX = varY = sdX = sdY = 0.0;
+    for (r = 0; r < rows; r++) {
+	G_percent(r, rows, 2);
+	G_get_raster_row(map1_fd, map1_buf, r, DCELL_TYPE);
+	G_get_raster_row(map2_fd, map2_buf, r, DCELL_TYPE);
+	for (c = 0; c < cols; c++) {
+	    map1_val = map1_buf[c];
+	    map2_val = map2_buf[c];
+	    if (G_is_null_value(&map1_val, DCELL_TYPE) ||
+		G_is_null_value(&map2_val, DCELL_TYPE))
+		continue;
+	    sumX += map1_val;
+	    sumY += map2_val;
+	    sumsqX += map1_val * map1_val;
+	    sumsqY += map2_val * map2_val;
+	    sumXY += map1_val * map2_val;
+	    count++;
+    G_close_cell(map1_fd);
+    G_close_cell(map2_fd);
+    G_free(map1_buf);
+    G_free(map2_buf);
+    B = (sumXY - sumX * sumY / count) / (sumsqX - sumX * sumX / count);
+    R = (sumXY - sumX * sumY / count) /
+	sqrt((sumsqX - sumX * sumX / count) * (sumsqY - sumY * sumY / count));
+    meanX = sumX / count;
+    sumsqX = sumsqX / count;
+    varX = sumsqX - (meanX * meanX);
+    sdX = sqrt(varX);
+    meanY = sumY / count;
+    sumsqY = sumsqY / count;
+    varY = sumsqY - (meanY * meanY);
+    sdY = sqrt(varY);
+    A = meanY - B * meanX;
+    F = R * R / (1 - R * R / count - 2);
+    if (shell_style->answer) {
+	fprintf(stdout, "a=%f\n", A);
+	fprintf(stdout, "b=%f\n", B);
+	fprintf(stdout, "R=%f\n", R);
+	fprintf(stdout, "N=%ld\n", count);
+	fprintf(stdout, "F=%f\n", F);
+	fprintf(stdout, "meanX=%f\n", meanX);
+	fprintf(stdout, "sdX=%f\n", sdX);
+	fprintf(stdout, "meanY=%f\n", meanY);
+	fprintf(stdout, "sdY=%f\n", sdY);
+    else {
+	fprintf(stdout, "y = a + b*x\n");
+	fprintf(stdout, "   a (Offset): %f\n", A);
+	fprintf(stdout, "   b (Gain): %f\n", B);
+	fprintf(stdout, "   R (sumXY - sumX*sumY/N): %f\n", R);
+	fprintf(stdout, "   N (Number of elements): %ld\n", count);
+	fprintf(stdout, "   F (F-test significance): %f\n", F);
+	fprintf(stdout, "   meanX (Mean of map1): %f\n", meanX);
+	fprintf(stdout, "   sdX (Standard deviation of map1): %f\n", sdX);
+	fprintf(stdout, "   meanY (Mean of map2): %f\n", meanY);
+	fprintf(stdout, "   sdY (Standard deviation of map1): %f", sdY);
+    exit(EXIT_SUCCESS);
Property changes on: grass/branches/develbranch_6/raster/r.regression.line/main.c
   + text/x-csrc
   + native
