[GRASS-SVN] r40848 - grass/branches/releasebranch_6_4/tools
Sat Feb 6 14:47:42 EST 2010
Author: neteler
Date: 2010-02-06 14:47:42 -0500 (Sat, 06 Feb 2010)
New Revision: 40848
   grass/branches/releasebranch_6_4/tools/sql.sh
Allow symbols up to 256 characters (sync with 7.0)
Modified: grass/branches/releasebranch_6_4/tools/sql.sh
--- grass/branches/releasebranch_6_4/tools/sql.sh	2010-02-06 19:45:11 UTC (rev 40847)
+++ grass/branches/releasebranch_6_4/tools/sql.sh	2010-02-06 19:47:42 UTC (rev 40848)
@@ -287,21 +287,21 @@
 CREATE TABLE stlib_exp (
 	library VARCHAR(80) NOT NULL,
 	object VARCHAR(40) NOT NULL,
-	symbol VARCHAR(150) NOT NULL
+	symbol VARCHAR(256) NOT NULL
 \copy stlib_exp FROM '$tmpdir/stlib_exp.lst'
 CREATE TABLE shlib_exp (
 \copy shlib_exp FROM '$tmpdir/shlib_exp.lst'
 CREATE TABLE obj_exp (
 	object VARCHAR(100) NOT NULL,
-	symbol VARCHAR(200) NOT NULL
 \copy obj_exp FROM '$tmpdir/obj_exp.lst'
@@ -309,42 +309,42 @@
 CREATE TABLE stlib_imp (
 \copy stlib_imp FROM '$tmpdir/stlib_imp.lst'
 CREATE TABLE shlib_imp (
 \copy shlib_imp FROM '$tmpdir/shlib_imp.lst'
 CREATE TABLE obj_imp (
 \copy obj_imp FROM '$tmpdir/obj_imp.lst'
 CREATE TABLE prog_imp (
 	program VARCHAR(80) NOT NULL,
 \copy prog_imp FROM '$tmpdir/prog_imp.lst'
 CREATE TABLE prog_exp (
-	symbol VARCHAR(180) NOT NULL
 \copy prog_exp FROM '$tmpdir/prog_exp.lst'
 CREATE TABLE libs (
-	symbol VARCHAR(160) NOT NULL
 \copy libs FROM '$tmpdir/libs.lst'
@@ -358,7 +358,7 @@
 \copy ldd FROM '$tmpdir/ldd.lst'
 CREATE TABLE ansi (
 \copy ansi FROM '$tmpdir/ansi.lst'
