[GRASS-SVN] r41118 - grass-addons/gui/wxpython/data_catalog
Fri Feb 19 06:39:20 EST 2010
Author: rashadkm
Date: 2010-02-19 06:39:19 -0500 (Fri, 19 Feb 2010)
New Revision: 41118
Removed:
   grass-addons/gui/wxpython/data_catalog/toolbars1.py
minor updates only;
Deleted: grass-addons/gui/wxpython/data_catalog/toolbars1.py
--- grass-addons/gui/wxpython/data_catalog/toolbars1.py	2010-02-19 11:36:31 UTC (rev 41117)
+++ grass-addons/gui/wxpython/data_catalog/toolbars1.py	2010-02-19 11:39:19 UTC (rev 41118)
@@ -1,1380 +0,0 @@
- at package toolbar
- at brief Toolbars for Map Display window
-Classes:
- - AbstractToolbar
- - MapToolbar
- - GRToolbar
- - GCPToolbar
- - VDigitToolbar
- - ProfileToolbar
- - NvizToolbar
-(C) 2007-2008 by the GRASS Development Team This program is free
-software under the GNU General Public License (>=v2). Read the file
-COPYING that comes with GRASS for details.
- at author Michael Barton
- at author Jachym Cepicky
- at author Martin Landa <landa.martin gmail.com>
-import wx
-import os, sys
-import platform
-import globalvar
-import gcmd
-version = os.getenv("GRASS_VERSION")
-if version == "6.4.0svn":
-    import grassenv
-import gdialogs
-import vdigit
-from vdigit import VDigitSettingsDialog as VDigitSettingsDialog
-from debug import Debug as Debug
-from icon import Icons as Icons
-from preferences import globalSettings as UserSettings
-gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
-sys.path.append(gmpath)
-class AbstractToolbar(object):
-    """Abstract toolbar class"""
-    def __init__(self):
-        pass
-    def InitToolbar(self, parent, toolbar, toolData):
-        """Initialize toolbar, i.e. add tools to the toolbar
-        @return list of ids (of added tools)
-        for tool in toolData:
-            self.CreateTool(parent, toolbar, *tool)
-        self._toolbar = toolbar
-        self._data = toolData
-        self.parent = parent
-    def ToolbarData(self):
-        """Toolbar data"""
-        return None
-    def CreateTool(self, parent, toolbar, tool, label, bitmap, kind,
-                   shortHelp, longHelp, handler):
-        """Add tool to the toolbar
-        @return id of tool
-        bmpDisabled=wx.NullBitmap
-        if label:
-            Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
-                  (tool, label, bitmap))
-            toolWin = toolbar.AddLabelTool(tool, label, bitmap,
-                                           bmpDisabled, kind,
-                                           shortHelp, longHelp)
-            parent.Bind(wx.EVT_TOOL, handler, toolWin)
-        else: # add separator
-            toolbar.AddSeparator()
-        return tool
-    def GetToolbar(self):
-        """Get toolbar widget reference"""
-        return self._toolbar
-    def EnableLongHelp(self, enable=True):
-        """Enable/disable long help
-        @param enable True for enable otherwise disable
-        for tool in self._data:
-            if tool[0] == '': # separator
-                continue
-            if enable:
-                self._toolbar.SetToolLongHelp(tool[0], tool[5])
-            else:
-                self._toolbar.SetToolLongHelp(tool[0], "")
-    def OnTool(self, event):
-        """Tool selected"""
-        if self.parent.toolbars['vdigit']:
-            # update vdigit toolbar (unselect currently selected tool)
-            id = self.parent.toolbars['vdigit'].GetAction(type='id')
-            self.parent.toolbars['vdigit'].GetToolbar().ToggleTool(id, False)
-        if event:
-            # deselect previously selected tool
-            id = self.action.get('id', -1)
-            if id != event.GetId():
-                self._toolbar.ToggleTool(self.action['id'], False)
-            else:
-                self._toolbar.ToggleTool(self.action['id'], True)
-            self.action['id'] = event.GetId()
-            event.Skip()
-        else:
-            # initialize toolbar
-    def GetAction(self, type='desc'):
-        """Get current action info"""
-        return self.action.get(type, '')
-    def SelectDefault(self, event):
-        """Select default tool"""
-        self._toolbar.ToggleTool(self.defaultAction['id'], True)
-        self.defaultAction['bind'](event)
-        self.action = { 'id' : self.defaultAction['id'],
-                        'desc' : self.defaultAction.get('desc', '') }
-    def FixSize(self, width):
-	"""Fix toolbar width on Windows
-	@todo Determine why combobox causes problems here
-        if platform.system() == 'Windows':
-            size = self._toolbar.GetBestSize()
-            self._toolbar.SetSize((size[0] + width, size[1]))
-class MapToolbar(AbstractToolbar):
-    Main Map Display toolbar
-    def __init__(self, mapdisplay, map):
-        AbstractToolbar.__init__(self)
-        self.mapcontent = map
-        self.mapdisplay = mapdisplay
-        self.toolbar = wx.ToolBar(parent=self.mapdisplay, id=wx.ID_ANY)
-        self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
-        self.InitToolbar(self.mapdisplay, self.toolbar, self.ToolbarData())
-        # optional tools
-        self.combo = wx.ComboBox(parent=self.toolbar, id=wx.ID_ANY, value=_('2D view'),
-                                 choices=[_('2D view'), _('3D view'), _('Digitize')],
-                                 style=wx.CB_READONLY, size=(90, -1))
-        self.comboid = self.toolbar.AddControl(self.combo)
-        self.mapdisplay.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
-        # realize the toolbar
-        self.toolbar.Realize()
-        # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
-        self.combo.Hide()
-        self.combo.Show()
-        # default action
-        self.action = { 'id' : self.pointer }
-        self.defaultAction = { 'id' : self.pointer,
-                               'bind' : self.mapdisplay.OnPointer }
-        self.OnTool(None)
-        self.FixSize(width = 90)
-        self.displaymap = wx.NewId()
-        self.rendermap = wx.NewId()
-        self.erase = wx.NewId()
-        self.pointer = wx.NewId()
-        self.query = wx.NewId()
-        self.pan = wx.NewId()
-        self.zoomin = wx.NewId()
-        self.zoomout = wx.NewId()
-        self.zoomback = wx.NewId()
-        self.zoommenu = wx.NewId()
-        self.analyze = wx.NewId()
-        self.dec = wx.NewId()
-        self.savefile = wx.NewId()
-        self.printmap = wx.NewId()
-        # tool, label, bitmap, kind, shortHelp, longHelp, handler
-        return (
-            (self.displaymap, "displaymap", Icons["displaymap"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["displaymap"].GetLabel(), Icons["displaymap"].GetDesc(),
-             self.mapdisplay.OnDraw),
-            (self.rendermap, "rendermap", Icons["rendermap"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["rendermap"].GetLabel(), Icons["rendermap"].GetDesc(),
-             self.mapdisplay.OnRender),
-            (self.erase, "erase", Icons["erase"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["erase"].GetLabel(), Icons["erase"].GetDesc(),
-             self.mapdisplay.OnErase),
-            (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
-             self.mapdisplay.OnPointer),
-            (self.query, "query", Icons["query"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["query"].GetLabel(), Icons["query"].GetDesc(),
-             self.mapdisplay.OnQuery),
-            (self.pan, "pan", Icons["pan"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
-             self.mapdisplay.OnPan),
-            (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
-             self.mapdisplay.OnZoomIn),
-            (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
-             self.mapdisplay.OnZoomOut),
-            (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
-             self.mapdisplay.OnZoomBack),
-            (self.zoommenu, "zoommenu", Icons["zoommenu"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["zoommenu"].GetLabel(), Icons["zoommenu"].GetDesc(),
-             self.mapdisplay.OnZoomMenu),
-            (self.analyze, "analyze", Icons["analyze"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["analyze"].GetLabel(), Icons["analyze"].GetDesc(),
-             self.mapdisplay.OnAnalyze),
-            (self.dec, "overlay", Icons["overlay"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["overlay"].GetLabel(), Icons["overlay"].GetDesc(),
-             self.mapdisplay.OnDecoration),
-            (self.savefile, "savefile", Icons["savefile"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["savefile"].GetLabel(), Icons["savefile"].GetDesc(),
-             self.mapdisplay.SaveToFile),
-            (self.printmap, "printmap", Icons["printmap"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["printmap"].GetLabel(), Icons["printmap"].GetDesc(),
-             self.mapdisplay.PrintMenu),
-    def OnSelectTool(self, event):
-        Select / enable tool available in tools list
-        tool =  event.GetSelection()
-        if tool == 0:
-            self.ExitToolbars()
-            self.Enable2D(True)
-        elif tool == 1 and not self.mapdisplay.toolbars['nviz']:
-            self.mapdisplay.AddToolbar("nviz")
-        elif tool == 2 and not self.mapdisplay.toolbars['vdigit']:
-            self.mapdisplay.AddToolbar("vdigit")
-    def ExitToolbars(self):
-        if self.mapdisplay.toolbars['vdigit']:
-            self.mapdisplay.toolbars['vdigit'].OnExit()
-        if self.mapdisplay.toolbars['nviz']:
-            self.mapdisplay.toolbars['nviz'].OnExit()
-    def Enable2D(self, enabled):
-        """Enable/Disable 2D display mode specific tools"""
-        for tool in (self.pointer,
-                     self.query,
-                     self.pan,
-                     self.zoomin,
-                     self.zoomout,
-                     self.zoomback,
-                     self.zoommenu,
-                     self.analyze,
-                     self.dec,
-                     self.savefile,
-                     self.printmap):
-            self.toolbar.EnableTool(tool, enabled)
-class GRToolbar(AbstractToolbar):
-    Georectification Display toolbar
-        # self.SetToolBar(self.toolbar)
-        self.gcpset = wx.NewId()
-        self.zoomtomap = wx.NewId()
-        return (
-            (self.gcpset, "grGcpSet", Icons["grGcpSet"].GetBitmap(),
-             wx.ITEM_RADIO, Icons["grGcpSet"].GetLabel(), Icons["grGcpSet"].GetDesc(),
-             wx.ITEM_RADIO, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
-             wx.ITEM_RADIO, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
-             wx.ITEM_RADIO, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
-            (self.zoomtomap, "zoomtomap", Icons["zoommenu"].GetBitmap(),
-             wx.ITEM_NORMAL, _("Zoom to map"), _("Zoom to displayed map"),
-             self.OnZoomMap),
-    def OnZoomMap(self, event):
-        """Zoom to selected map"""
-        layer = self.mapcontent.GetListOfLayers()[0]
-        self.mapdisplay.MapWindow.ZoomToMap(layer=layer)
-        event.Skip()
-class GCPToolbar(AbstractToolbar):
-    Toolbar for managing ground control points during georectification
-    def __init__(self, parent, tbframe):
-        self.parent  = parent # GCP
-        self.tbframe = tbframe
-        self.toolbar = wx.ToolBar(parent=self.tbframe, id=wx.ID_ANY)
-        self.InitToolbar(self.tbframe, self.toolbar, self.ToolbarData())
-        self.gcpSave = wx.NewId()
-        self.gcpAdd = wx.NewId()
-        self.gcpDelete = wx.NewId()
-        self.gcpClear = wx.NewId()
-        self.gcpReload = wx.NewId()
-        self.rms = wx.NewId()
-        self.georect = wx.NewId()
-        self.settings = wx.NewId()
-        self.quit = wx.NewId()
-        return (
-            (self.gcpSave, 'grGcpSave', Icons["grGcpSave"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGcpSave"].GetLabel(), Icons["grGcpSave"].GetDesc(),
-             self.parent.SaveGCPs),
-            (self.gcpAdd, 'grGrGcpAdd', Icons["grGcpAdd"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGcpAdd"].GetLabel(), Icons["grGcpAdd"].GetDesc(),
-             self.parent.AddGCP),
-            (self.gcpDelete, 'grGrGcpDelete', Icons["grGcpDelete"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGcpDelete"].GetLabel(), Icons["grGcpDelete"].GetDesc(),
-             self.parent.DeleteGCP),
-            (self.gcpClear, 'grGcpClear', Icons["grGcpClear"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGcpClear"].GetLabel(), Icons["grGcpClear"].GetDesc(),
-             self.parent.ClearGCP),
-            (self.gcpReload, 'grGcpReload', Icons["grGcpReload"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGcpReload"].GetLabel(), Icons["grGcpReload"].GetDesc(),
-             self.parent.ReloadGCPs),
-            (self.rms, 'grGcpRms', Icons["grGcpRms"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGcpRms"].GetLabel(), Icons["grGcpRms"].GetDesc(),
-             self.parent.OnRMS),
-            (self.georect, 'grGeorect', Icons["grGeorect"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGeorect"].GetLabel(), Icons["grGeorect"].GetDesc(),
-             self.parent.OnGeorect),
-            (self.settings, 'grSettings', Icons["grSettings"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grSettings"].GetLabel(), Icons["grSettings"].GetDesc(),
-             self.parent.OnSettings),
-            (self.quit, 'grGcpQuit', Icons["grGcpQuit"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["grGcpQuit"].GetLabel(), Icons["grGcpQuit"].GetDesc(),
-             self.parent.OnQuit)
-class VDigitToolbar(AbstractToolbar):
-    Toolbar for digitization
-    def __init__(self, parent, map, layerTree=None, log=None):
-        self.mapcontent    = map       # Map class instance
-        self.parent        = parent    # MapFrame
-        self.layerTree     = layerTree # reference to layer tree associated to map display
-        self.log           = log       # log area
-        # currently selected map layer for editing (reference to MapLayer instance)
-        self.mapLayer = None
-        # list of vector layers from Layer Manager (only in the current mapset)
-        self.layers   = []
-        self.comboid    = None
-        # only one dialog can be open
-        self.settingsDialog   = None
-        # create toolbars (two rows optionally)
-        self.toolbar = []
-        self.numOfRows = 1 # number of rows for toolbar
-        for row in range(0, self.numOfRows):
-            self.toolbar.append(wx.ToolBar(parent=self.parent, id=wx.ID_ANY))
-            self.toolbar[row].SetToolBitmapSize(globalvar.toolbarSize)
-            self.toolbar[row].Bind(wx.EVT_TOOL, self.OnTool)
-            # create toolbar
-            if self.numOfRows ==  1:
-                rowdata=None
-            else:
-                rowdata = row
-            self.InitToolbar(self.parent, self.toolbar[row], self.ToolbarData(rowdata))
-        # default action (digitize new point, line, etc.)
-        self.action = { 'desc' : 'addLine',
-                        'type' : 'point',
-                        'id'   : self.addPoint }
-        # list of available vector maps
-        self.UpdateListOfLayers(updateTool=True)
-        # realize toolbar
-            self.toolbar[row].Realize()
-            self.combo.Hide()
-            self.combo.Show()
-        # disable undo/redo
-        self.toolbar[0].EnableTool(self.undo, False)
-        # toogle to pointer by default
-        self.OnTool(None)
-        self.FixSize(width = 105)
-    def ToolbarData(self, row=None):
-        Toolbar data
-        data = []
-        if row is None or row == 0:
-            self.addPoint = wx.NewId()
-            self.addLine = wx.NewId()
-            self.addBoundary = wx.NewId()
-            self.addCentroid = wx.NewId()
-            self.moveVertex = wx.NewId()
-            self.addVertex = wx.NewId()
-            self.removeVertex = wx.NewId()
-            self.splitLine = wx.NewId()
-            self.editLine = wx.NewId()
-            self.moveLine = wx.NewId()
-            self.deleteLine = wx.NewId()
-            self.additionalTools = wx.NewId()
-            self.displayCats = wx.NewId()
-            self.displayAttr = wx.NewId()
-            self.copyCats = wx.NewId()
-            data = [("", "", "", "", "", "", ""),
-                    (self.addPoint, "digAddPoint", Icons["digAddPoint"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digAddPoint"].GetLabel(), Icons["digAddPoint"].GetDesc(),
-                     self.OnAddPoint),
-                    (self.addLine, "digAddLine", Icons["digAddLine"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digAddLine"].GetLabel(), Icons["digAddLine"].GetDesc(),
-                     self.OnAddLine),
-                    (self.addBoundary, "digAddBoundary", Icons["digAddBoundary"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digAddBoundary"].GetLabel(), Icons["digAddBoundary"].GetDesc(),
-                     self.OnAddBoundary),
-                    (self.addCentroid, "digAddCentroid", Icons["digAddCentroid"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digAddCentroid"].GetLabel(), Icons["digAddCentroid"].GetDesc(),
-                     self.OnAddCentroid),
-                    (self.moveVertex, "digMoveVertex", Icons["digMoveVertex"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digMoveVertex"].GetLabel(), Icons["digMoveVertex"].GetDesc(),
-                     self.OnMoveVertex),
-                    (self.addVertex, "digAddVertex", Icons["digAddVertex"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digAddVertex"].GetLabel(), Icons["digAddVertex"].GetDesc(),
-                     self.OnAddVertex),
-                    (self.removeVertex, "digRemoveVertex", Icons["digRemoveVertex"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digRemoveVertex"].GetLabel(), Icons["digRemoveVertex"].GetDesc(),
-                     self.OnRemoveVertex),
-                    (self.splitLine, "digSplitLine", Icons["digSplitLine"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digSplitLine"].GetLabel(), Icons["digSplitLine"].GetDesc(),
-                     self.OnSplitLine),
-                    (self.editLine, "digEditLine", Icons["digEditLine"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digEditLine"].GetLabel(), Icons["digEditLine"].GetDesc(),
-                     self.OnEditLine),
-                    (self.moveLine, "digMoveLine", Icons["digMoveLine"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digMoveLine"].GetLabel(), Icons["digMoveLine"].GetDesc(),
-                     self.OnMoveLine),
-                    (self.deleteLine, "digDeleteLine", Icons["digDeleteLine"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digDeleteLine"].GetLabel(), Icons["digDeleteLine"].GetDesc(),
-                     self.OnDeleteLine),
-                    (self.displayCats, "digDispCats", Icons["digDispCats"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digDispCats"].GetLabel(), Icons["digDispCats"].GetDesc(),
-                     self.OnDisplayCats),
-                    (self.copyCats, "digCopyCats", Icons["digCopyCats"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digCopyCats"].GetLabel(), Icons["digCopyCats"].GetDesc(),
-                     self.OnCopyCA),
-                    (self.displayAttr, "digDispAttr", Icons["digDispAttr"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digDispAttr"].GetLabel(), Icons["digDispAttr"].GetDesc(),
-                     self.OnDisplayAttr),
-                    (self.additionalTools, "digAdditionalTools", Icons["digAdditionalTools"].GetBitmap(),
-                     wx.ITEM_CHECK, Icons["digAdditionalTools"].GetLabel(),
-                     Icons["digAdditionalTools"].GetDesc(),
-                     self.OnAdditionalToolMenu)]
-        if row is None or row == 1:
-            self.undo = wx.NewId()
-            self.exit = wx.NewId()
-            data.append(("", "", "", "", "", "", ""))
-            data.append((self.undo, "digUndo", Icons["digUndo"].GetBitmap(),
-                         wx.ITEM_NORMAL, Icons["digUndo"].GetLabel(), Icons["digUndo"].GetDesc(),
-                         self.OnUndo))
-            # data.append((self.undo, "digRedo", Icons["digRedo"].GetBitmap(),
-            #             wx.ITEM_NORMAL, Icons["digRedo"].GetLabel(), Icons["digRedo"].GetDesc(),
-            #             self.OnRedo))
-            data.append((self.settings, "digSettings", Icons["digSettings"].GetBitmap(),
-                         wx.ITEM_NORMAL, Icons["digSettings"].GetLabel(), Icons["digSettings"].GetDesc(),
-                         self.OnSettings))
-            data.append((self.exit, "digExit", Icons["quit"].GetBitmap(),
-                         wx.ITEM_NORMAL, Icons["digExit"].GetLabel(), Icons["digExit"].GetDesc(),
-                         self.OnExit))
-        return data
-        """Tool selected -> disable selected tool in map toolbar"""
-        # update map toolbar (unselect currently selected tool)
-        id = self.parent.toolbars['map'].GetAction(type='id')
-        self.parent.toolbars['map'].toolbar.ToggleTool(id, False)
-        # set cursor
-        cursor = self.parent.cursors["cross"]
-        self.parent.MapWindow.SetCursor(cursor)
-        # pointer
-        self.parent.OnPointer(None)
-        if event:
-                self.toolbar[0].ToggleTool(self.action['id'], False)
-            else:
-                self.toolbar[0].ToggleTool(self.action['id'], True)
-            event.Skip()
-        else:
-        # clear tmp canvas
-        if self.action['id'] != id:
-            self.parent.MapWindow.ClearLines(pdc=self.parent.MapWindow.pdcTmp)
-            if self.parent.digit and \
-                    len(self.parent.digit.driver.GetSelected()) > 0:
-                # cancel action
-                self.parent.MapWindow.OnMiddleDown(None)
-    def OnAddPoint(self, event):
-        """Add point to the vector map Laier"""
-        Debug.msg (2, "VDigitToolbar.OnAddPoint()")
-        self.action = { 'desc' : "addLine",
-                        'type' : "point",
-        self.parent.MapWindow.mouse['box'] = 'point'
-    def OnAddLine(self, event):
-        """Add line to the vector map layer"""
-        Debug.msg (2, "VDigitToolbar.OnAddLine()")
-                        'type' : "line",
-                        'id'   : self.addLine }
-        self.parent.MapWindow.mouse['box'] = 'line'
-        ### self.parent.MapWindow.polycoords = [] # reset temp line
-    def OnAddBoundary(self, event):
-        """Add boundary to the vector map layer"""
-        Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
-        if self.action['desc'] != 'addLine' or \
-                self.action['type'] != 'boundary':
-            self.parent.MapWindow.polycoords = [] # reset temp line
-                        'type' : "boundary",
-                        'id'   : self.addBoundary }
-    def OnAddCentroid(self, event):
-        """Add centroid to the vector map layer"""
-        Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
-                        'type' : "centroid",
-                        'id'   : self.addCentroid }
-    def OnExit (self, event=None):
-        """Quit digitization tool"""
-        # stop editing of the currently selected map layer
-        if self.mapLayer:
-            self.StopEditing()
-        # close dialogs if still open
-        if self.settingsDialog:
-            self.settingsDialog.OnCancel(None)
-        # disable the toolbar
-        self.parent.RemoveToolbar ("vdigit")
-        # set default mouse settings
-        self.parent.MapWindow.mouse['use'] = "pointer"
-        self.parent.MapWindow.mouse['box'] = "point"
-    def OnMoveVertex(self, event):
-        """Move line vertex"""
-        Debug.msg(2, "Digittoolbar.OnMoveVertex():")
-        self.action = { 'desc' : "moveVertex",
-                        'id'   : self.moveVertex }
-    def OnAddVertex(self, event):
-        """Add line vertex"""
-        Debug.msg(2, "Digittoolbar.OnAddVertex():")
-        self.action = { 'desc' : "addVertex",
-                        'id'   : self.addVertex }
-    def OnRemoveVertex(self, event):
-        """Remove line vertex"""
-        Debug.msg(2, "Digittoolbar.OnRemoveVertex():")
-        self.action = { 'desc' : "removeVertex",
-                        'id'   : self.removeVertex }
-    def OnSplitLine(self, event):
-        """Split line"""
-        Debug.msg(2, "Digittoolbar.OnSplitLine():")
-        self.action = { 'desc' : "splitLine",
-                        'id'   : self.splitLine }
-    def OnEditLine(self, event):
-        """Edit line"""
-        Debug.msg(2, "Digittoolbar.OnEditLine():")
-        self.action = { 'desc' : "editLine",
-                        'id'   : self.editLine }
-    def OnMoveLine(self, event):
-        """Move line"""
-        Debug.msg(2, "Digittoolbar.OnMoveLine():")
-        self.action = { 'desc' : "moveLine",
-                        'id'   : self.moveLine }
-        self.parent.MapWindow.mouse['box'] = 'box'
-    def OnDeleteLine(self, event):
-        """Delete line"""
-        Debug.msg(2, "Digittoolbar.OnDeleteLine():")
-        self.action = { 'desc' : "deleteLine",
-                        'id'   : self.deleteLine }
-    def OnDisplayCats(self, event):
-        """Display/update categories"""
-        Debug.msg(2, "Digittoolbar.OnDisplayCats():")
-        self.action = { 'desc' : "displayCats",
-                        'id'   : self.displayCats }
-    def OnDisplayAttr(self, event):
-        """Display/update attributes"""
-        Debug.msg(2, "Digittoolbar.OnDisplayAttr():")
-        self.action = { 'desc' : "displayAttrs",
-                        'id'   : self.displayAttr }
-    def OnCopyCA(self, event):
-        """Copy categories/attributes menu"""
-        point = wx.GetMousePosition()
-        toolMenu = wx.Menu()
-        # Add items to the menu
-        cats = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                           text=_('Copy categories'),
-                           kind=wx.ITEM_CHECK)
-        toolMenu.AppendItem(cats)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyCats, cats)
-        if self.action['desc'] == "copyCats":
-            cats.Check(True)
-        attrb = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                            text=_('Duplicate attributes'),
-        toolMenu.AppendItem(attrb)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyAttrb, attrb)
-        if self.action['desc'] == "copyAttrs":
-            attrb.Check(True)
-        # Popup the menu.  If an item is selected then its handler
-        # will be called before PopupMenu returns.
-        self.parent.MapWindow.PopupMenu(toolMenu)
-        toolMenu.Destroy()
-        if self.action['desc'] == "addPoint":
-            self.toolbar[0].ToggleTool(self.copyCats, False)
-    def OnCopyCats(self, event):
-        """Copy categories"""
-        if self.action['desc'] == 'copyCats': # select previous action
-            self.toolbar[0].ToggleTool(self.addPoint, True)
-            self.OnAddPoint(event)
-            return
-        Debug.msg(2, "Digittoolbar.OnCopyCats():")
-        self.action = { 'desc' : "copyCats",
-                        'id'   : self.copyCats }
-    def OnCopyAttrb(self, event):
-        if self.action['desc'] == 'copyAttrs': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnCopyAttrb():")
-        self.action = { 'desc' : "copyAttrs",
-    def OnUndo(self, event):
-        """Undo previous changes"""
-        self.parent.digit.Undo()
-        event.Skip()
-    def EnableUndo(self, enable=True):
-        """Enable 'Undo' in toolbar
-        @param enable False for disable
-        if enable:
-            if self.toolbar[0].GetToolEnabled(self.undo) is False:
-                self.toolbar[0].EnableTool(self.undo, True)
-        else:
-            if self.toolbar[0].GetToolEnabled(self.undo) is True:
-    def OnSettings(self, event):
-        """Show settings dialog"""
-        if self.parent.digit is None:
-            reload(vdigit)
-            from vdigit import Digit as Digit
-            self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
-        if not self.settingsDialog:
-            self.settingsDialog = VDigitSettingsDialog(parent=self.parent, title=_("Digitization settings"),
-                                                       style=wx.DEFAULT_DIALOG_STYLE)
-            self.settingsDialog.Show()
-    def OnAdditionalToolMenu(self, event):
-        """Menu for additional tools"""
-        copy = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                           text=_('Copy features from (background) vector map'),
-        toolMenu.AppendItem(copy)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
-        if self.action['desc'] == "copyLine":
-            copy.Check(True)
-        flip = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                           text=_('Flip selected lines/boundaries'),
-        toolMenu.AppendItem(flip)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
-        if self.action['desc'] == "flipLine":
-            flip.Check(True)
-        merge = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                            text=_('Merge selected lines/boundaries'),
-        toolMenu.AppendItem(merge)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnMerge, merge)
-        if self.action['desc'] == "mergeLine":
-            merge.Check(True)
-        breakL = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                             text=_('Break selected lines/boundaries at intersection'),
-        toolMenu.AppendItem(breakL)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnBreak, breakL)
-        if self.action['desc'] == "breakLine":
-            breakL.Check(True)
-        snap = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                           text=_('Snap selected lines/boundaries (only to nodes)'),
-        toolMenu.AppendItem(snap)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnSnap, snap)
-        if self.action['desc'] == "snapLine":
-            snap.Check(True)
-        connect = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                              text=_('Connect selected lines/boundaries'),
-        toolMenu.AppendItem(connect)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnConnect, connect)
-        if self.action['desc'] == "connectLine":
-            connect.Check(True)
-        query = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                            text=_('Query features'),
-        toolMenu.AppendItem(query)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnQuery, query)
-        if self.action['desc'] == "queryLine":
-            query.Check(True)
-        zbulk = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                            text=_('Z bulk-labeling of 3D lines'),
-        toolMenu.AppendItem(zbulk)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
-        if self.action['desc'] == "zbulkLine":
-            zbulk.Check(True)
-        typeconv = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
-                               text=_('Feature type conversion'),
-        toolMenu.AppendItem(typeconv)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
-        if self.action['desc'] == "typeConv":
-            typeconv.Check(True)
-        if self.action['desc'] == 'addPoint':
-            self.toolbar[0].ToggleTool(self.additionalTools, False)
-    def OnCopy(self, event):
-        """Copy selected features from (background) vector map"""
-        if self.action['desc'] == 'copyLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnCopy():")
-        self.action = { 'desc' : "copyLine",
-                        'id'   : self.additionalTools }
-    def OnFlip(self, event):
-        """Flip selected lines/boundaries"""
-        if self.action['desc'] == 'flipLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnFlip():")
-        self.action = { 'desc' : "flipLine",
-    def OnMerge(self, event):
-        """Merge selected lines/boundaries"""
-        if self.action['desc'] == 'mergeLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnMerge():")
-        self.action = { 'desc' : "mergeLine",
-    def OnBreak(self, event):
-        """Break selected lines/boundaries"""
-        if self.action['desc'] == 'breakLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnBreak():")
-        self.action = { 'desc' : "breakLine",
-    def OnSnap(self, event):
-        """Snap selected features"""
-        if self.action['desc'] == 'snapLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnSnap():")
-        self.action = { 'desc' : "snapLine",
-    def OnConnect(self, event):
-        """Connect selected lines/boundaries"""
-        if self.action['desc'] == 'connectLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnConnect():")
-        self.action = { 'desc' : "connectLine",
-    def OnQuery(self, event):
-        """Query selected lines/boundaries"""
-        if self.action['desc'] == 'queryLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnQuery(): %s" % \
-                      UserSettings.Get(group='vdigit', key='query', subkey='selection'))
-        self.action = { 'desc' : "queryLine",
-    def OnZBulk(self, event):
-        """Z bulk-labeling selected lines/boundaries"""
-        if not self.parent.digit.driver.Is3D():
-            wx.MessageBox(parent=self.parent,
-                          message=_("Vector map is not 3D. Operation canceled."),
-                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-            return
-        if self.action['desc'] == 'zbulkLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnZBulk():")
-        self.action = { 'desc' : "zbulkLine",
-    def OnTypeConversion(self, event):
-        """Feature type conversion
-        Supported conversions:
-         - point <-> centroid
-         - line <-> boundary
-        if self.action['desc'] == 'typeConv': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnTypeConversion():")
-        self.action = { 'desc' : "typeConv",
-    def OnSelectMap (self, event):
-        Select vector map layer for editing
-        If there is a vector map layer already edited, this action is
-        firstly terminated. The map layer is closed. After this the
-        selected map layer activated for editing.
-        if event.GetSelection() == 0: # create new vector map layer
-            if self.mapLayer:
-                openVectorMap = self.mapLayer.GetName(fullyQualified=False)['name']
-            else:
-                openVectorMap = None
-            mapName = gdialogs.CreateNewVector(self.parent,
-                                               exceptMap=openVectorMap, log=self.log,
-                                               cmdDef=(['v.edit', 'tool=create'], "map"),
-                                               disableAdd=True)[0]
-            if mapName:
-                # add layer to map layer tree
-                if self.layerTree:
-                    self.layerTree.AddLayer(ltype='vector',
-                                            lname=mapName,
-                                            lchecked=True,
-                                            lopacity=1.0,
-                                            lcmd=['d.vect', 'map=%s' % mapName])
-                    vectLayers = self.UpdateListOfLayers(updateTool=True)
-                    selection = vectLayers.index(mapName)
-                else:
-                    pass # TODO (no Layer Manager)
-            else:
-                self.combo.SetValue(_('Select vector map'))
-                return
-        else:
-            selection = event.GetSelection() - 1 # first option is 'New vector map'
-        # skip currently selected map
-        if self.layers[selection] == self.mapLayer:
-            return False
-        if self.mapLayer:
-            # deactive map layer for editing
-        # select the given map layer for editing
-        self.StartEditing(self.layers[selection])
-        event.Skip()
-        return True
-    def StartEditing (self, mapLayer):
-        Start editing selected vector map layer.
-        @param mapLayer reference to MapLayer instance
-        # deactive layer
-        self.mapcontent.ChangeLayerActive(mapLayer, False)
-        # clean map canvas
-        ### self.parent.MapWindow.EraseMap()
-        # unset background map if needed
-        if UserSettings.Get(group='vdigit', key='bgmap',
-                            subkey='value', internal=True) == mapLayer.GetName():
-            UserSettings.Set(group='vdigit', key='bgmap',
-                             subkey='value', value='', internal=True)
-        self.parent.statusbar.SetStatusText(_("Please wait, "
-                                              "opening vector map <%s> for editing...") % \
-                                                mapLayer.GetName(),
-                                            0)
-        # reload vdigit module
-        reload(vdigit)
-        self.mapLayer = mapLayer
-        # open vector map
-        try:
-            self.parent.digit.SetMapName(mapLayer.GetName())
-        except gcmd.DigitError, e:
-            print >> sys.stderr, e # wxMessageBox
-            return False
-        # update toolbar
-        self.combo.SetValue(mapLayer.GetName())
-        self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
-        Debug.msg (4, "VDigitToolbar.StartEditing(): layer=%s" % mapLayer.GetName())
-        # change cursor
-        if self.parent.MapWindow.mouse['use'] == 'pointer':
-            self.parent.MapWindow.SetCursor(self.parent.cursors["cross"])
-        # create pseudoDC for drawing the map
-        self.parent.MapWindow.pdcVector = vdigit.PseudoDC()
-        self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
-        if not self.parent.MapWindow.resize:
-            self.parent.MapWindow.UpdateMap(render=True)
-        opacity = mapLayer.GetOpacity(float=True)
-        if opacity < 1.0:
-            alpha = int(opacity * 255)
-            self.parent.digit.driver.UpdateSettings(alpha)
-        return True
-    def StopEditing (self):
-        """Stop editing of selected vector map layer.
-        @return True on success
-        @return False on failure
-        if not self.mapLayer:
-            return False
-        Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
-        self.combo.SetValue (_('Select vector map'))
-        # save changes
-        if UserSettings.Get(group='vdigit', key='saveOnExit', subkey='enabled') is False:
-            if self.parent.digit.GetUndoLevel() > 0:
-                dlg = wx.MessageDialog(parent=self.parent,
-                                       message=_("Do you want to save changes "
-                                                 "in vector map <%s>?") % self.mapLayer.GetName(),
-                                       caption=_("Save changes?"),
-                                       style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
-                if dlg.ShowModal() == wx.ID_NO:
-                    # revert changes
-                    self.parent.digit.Undo(0)
-                dlg.Destroy()
-                                              "closing and rebuilding topology of "
-                                              "vector map <%s>...") % self.mapLayer.GetName(),
-                                            0)
-        self.parent.digit.SetMapName(None) # -> close map
-        # re-active layer
-        item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
-        if item and self.parent.tree.IsItemChecked(item):
-            self.mapcontent.ChangeLayerActive(self.mapLayer, True)
-        # change cursor
-        self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
-        # disable pseudodc for vector map layer
-        self.parent.MapWindow.pdcVector = None
-        self.parent.digit.driver.SetDevice(None)
-        # close dialogs
-        for dialog in ('attributes', 'category'):
-            if self.parent.dialogs[dialog]:
-                self.parent.dialogs[dialog].Close()
-                self.parent.dialogs[dialog] = None
-        self.parent.digit.__del__() # FIXME: destructor is not called here (del)
-        self.parent.digit = None
-        self.parent.MapWindow.redrawAll = True
-        return True
-    def UpdateListOfLayers (self, updateTool=False):
-        Update list of available vector map layers.
-        This list consists only editable layers (in the current mapset)
-        Optionally also update toolbar
-        Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
-                   updateTool)
-        layerNameSelected = None
-         # name of currently selected layer
-        if self.mapLayer:
-            layerNameSelected = self.mapLayer.GetName()
-        # select vector map layer in the current mapset
-        layerNameList = []
-        self.layers = self.mapcontent.GetListOfLayers(l_type="vector",
-                                                      l_mapset=grassenv.GetGRASSVariable('MAPSET'))
-        for layer in self.layers:
-            if not layer.name in layerNameList: # do not duplicate layer
-                layerNameList.append (layer.GetName())
-        if updateTool: # update toolbar
-                value = _('Select vector map')
-            else:
-                value = layerNameSelected
-            if not self.comboid:
-                self.combo = wx.ComboBox(self.toolbar[self.numOfRows-1], id=wx.ID_ANY, value=value,
-                                         choices=[_('New vector map'), ] + layerNameList, size=(85, -1),
-                                         style=wx.CB_READONLY)
-                self.comboid = self.toolbar[self.numOfRows-1].InsertControl(0, self.combo)
-                self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectMap, self.comboid)
-            else:
-                self.combo.SetItems([_('New vector map'), ] + layerNameList)
-            self.toolbar[self.numOfRows-1].Realize()
-        return layerNameList
-    def GetLayer(self):
-        """Get selected layer for editing -- MapLayer instance"""
-        return self.mapLayer
-class ProfileToolbar(AbstractToolbar):
-    Toolbar for profiling raster map
-        self.transect = wx.NewId()
-        self.addraster = wx.NewId()
-        self.draw = wx.NewId()
-        self.options = wx.NewId()
-        self.drag = wx.NewId()
-        self.zoom = wx.NewId()
-        self.unzoom = wx.NewId()
-        self.save = wx.NewId()
-        self.printer = wx.NewId()
-        return   (
-            (self.addraster, 'raster', Icons["addrast"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
-             self.parent.OnSelectRaster),
-            (self.transect, 'transect', Icons["transect"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["transect"].GetLabel(), Icons["transect"].GetDesc(),
-             self.parent.OnDrawTransect),
-            (self.draw, 'profiledraw', Icons["profiledraw"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["profiledraw"].GetLabel(), Icons["profiledraw"].GetDesc(),
-             self.parent.OnCreateProfile),
-            (self.options, 'options', Icons["profileopt"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["profileopt"].GetLabel(), Icons["profileopt"].GetDesc(),
-             self.parent.ProfileOptionsMenu),
-            (self.drag, 'drag', Icons['pan'].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
-             self.parent.OnDrag),
-            (self.zoom, 'zoom', Icons['zoom_in'].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
-             self.parent.OnZoom),
-            (self.unzoom, 'unzoom', Icons['zoom_back'].GetBitmap(),
-             self.parent.OnRedraw),
-            (self.erase, 'erase', Icons["erase"].GetBitmap(),
-             self.parent.OnErase),
-            (self.save, 'save', Icons["savefile"].GetBitmap(),
-             self.parent.SaveToFile),
-            (self.printer, 'print', Icons["printmap"].GetBitmap(),
-             self.parent.PrintMenu),
-            (self.quit, 'quit', Icons["quit"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
-             self.parent.OnQuit),
-class NvizToolbar(AbstractToolbar):
-    Nviz toolbar
-    def __init__(self, parent, map):
-        self.toolbar = wx.ToolBar(parent=self.parent, id=wx.ID_ANY)
-        self.InitToolbar(self.parent, self.toolbar, self.ToolbarData())
-        return   (
-            (self.settings, "settings", Icons["nvizSettings"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["nvizSettings"].GetLabel(), Icons["nvizSettings"].GetDesc(),
-             self.OnSettings),
-             self.OnExit),
-        win = self.parent.nvizToolWin
-        if not win.IsShown():
-            self.parent.nvizToolWin.Show()
-        else:
-            self.parent.nvizToolWin.Hide()
-        """Quit nviz tool (swith to 2D mode)"""
-        # hide dialogs if still open
-        if self.parent.nvizToolWin:
-        self.parent.RemoveToolbar ("nviz")
