[GRASS-SVN] r41168 - in grass/trunk/scripts: . d.vect.thematic
Tue Feb 23 13:32:27 EST 2010
Author: glynn
Date: 2010-02-23 13:32:26 -0500 (Tue, 23 Feb 2010)
New Revision: 41168
Added:
   grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
   grass/trunk/scripts/Makefile
Convert d.vect.thematic to Python
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile	2010-02-23 18:13:51 UTC (rev 41167)
+++ grass/trunk/scripts/Makefile	2010-02-23 18:32:26 UTC (rev 41168)
@@ -6,6 +6,7 @@
 	d.rast.edit \
 	d.rast.leg \
 	d.shadedmap \
+	d.vect.thematic \
 	db.dropcolumn \
 	db.droptable \
 	db.in.ogr \
@@ -65,7 +66,6 @@
 	v.krige \
 	wxpyimgview
-#	d.vect.thematic \
 #	d.out.gpsdrive \
 #	r.mapcalculator \
 #	r3.mapcalculator \
Added: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py	                        (rev 0)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py	2010-02-23 18:32:26 UTC (rev 41168)
@@ -0,0 +1,1115 @@
+#!/usr/bin/env python
+# MODULE:       d.vect.thematic
+# AUTHOR(S):	Michael Barton, Arizona State University with contributions
+#               by Martin Landa, Jachym Cepicky, Daniel Calvelo Aros and Moritz Lennert
+# PURPOSE:	    Displays thematic vector map with graduated colors
+#               or graduated points and line thickneses
+# COPYRIGHT:	(C) 2006 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: Displays thematic vector map
+#%  keywords: display, vector, thematic, legend
+#%End
+#%option
+#% guisection: Files
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of vector map
+#% required : yes
+#%end
+#%option
+#% guisection: Theme
+#% key: type
+#% type: string
+#% description: Feature type
+#% options: area,point,centroid,line,boundary
+#% answer: area
+#% required : yes
+#%end
+#%option
+#% key: column
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
+#% type: string
+#% description: Name of attribute column to use for thematic display (must be numeric)
+#% required : yes
+#%end
+#%option
+#% key: themetype
+#% type: string
+#% options: graduated_colors,graduated_points,graduated_lines
+#% answer: graduated_colors
+#% description: Type of thematic display
+#% required : yes
+#%end
+#%option
+#% key: themecalc
+#% type: string
+#% options: interval,std_deviation,quartiles,custom_breaks
+#% answer: interval
+#% description: Thematic divisions of data for display
+#% required : yes
+#%end
+#%option
+#% key: breakpoints
+#% type: string
+#% label: Break points for custom breaks option
+#% description: Separate values by spaces (0 10 20 30 ...)
+#% required : no
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% gisprompt: old_layer,layer,layer
+#% description: Layer number
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% guisection: Points
+#% key: icon
+#% type: string
+#% description: Vector point icon for point data
+#% options: basic/box,basic/circle,basic/cross2,basic/diamond,basic/star,basic/cross1,basic/x
+#% answer: basic/circle
+#% required : no
+#%end
+#%option
+#% key: size
+#% type: double
+#% label: Icon size for point data
+#% description: Minimum icon size/line width for graduated points/lines)
+#% answer: 5
+#% required : no
+#%end
+#%option
+#% key: maxsize
+#% type: double
+#% description: Maximum icon size/line width for graduated points and lines
+#% answer: 20
+#% required : no
+#%end
+#%option
+#% key: nint
+#% type: integer
+#% description: Number of classes for interval theme (integer)
+#% answer: 4
+#% required : no
+#%end
+#%option
+#% guisection: Color
+#% key: colorscheme
+#% type: string
+#% label: Color scheme for graduated color mapping
+#% description: Select 'single_color' for graduated point/line display
+#% options: blue-red,red-blue,green-red,red-green,blue-green,green-blue,cyan-yellow,yellow-cyan,custom_gradient,single_color
+#% answer: blue-red
+#% required : yes
+#%end
+#% option
+#% key: pointcolor
+#% type: string
+#% label: Color for graduated points map
+#% description: GRASS named color or R:G:B triplet. Set color scheme to single color
+#% answer: 255:0:0
+#% required : no
+#%end
+#% option
+#% key: linecolor
+#% type: string
+#% label: Color for graduated lines or point/area outlines
+#% description: GRASS named color or R:G:B triplet. Set color scheme to single color.
+#% answer: 0:0:0
+#% required : no
+#%end
+#% option
+#% key: startcolor
+#% type: string
+#% label: Beginning color for custom color gradient
+#% description: Must be expressed as R:G:B triplet
+#% answer: 255:0:0
+#% required : no
+#%end
+#% option
+#% key: endcolor
+#% type: string
+#% label: Ending color for custom color gradient
+#% answer: 0:0:255
+#% required : no
+#%end
+#% option
+#% guisection: Misc
+#% key: monitor
+#% type: string
+#% description: Select x11 display monitor for legend
+#% options: x0,x1,x2,x3,x4,x5,x6,none
+#% answer: x1
+#% required : no
+#%end
+#%flag
+#%key: g
+#%description: Save thematic map commands to group file for GIS Manager
+#%end
+#%option
+#% key: where
+#% type: string
+#% description: WHERE conditions of SQL statement without 'where' keyword
+#% required : no
+#%end
+#%option
+#% key: psmap
+#% type: string
+#% label: Root for the name of psmap instruction files to be in current directory
+#% description: If not set, no psmap instruction files will be created)
+#% required : no
+#%end
+#%option
+#% key: group
+#% type: string
+#% gisprompt: new_file,file,group
+#% description: Name of group file where thematic map commands will be saved
+#% required : no
+#%end
+#%flag
+#%key: l
+#%description: Create graphic legend in x11 display monitor
+#%end
+#%flag
+#% key: f
+#% description: Only draw fills (no outlines) for areas and points
+#%end
+#%flag
+#% key: u
+#% description: Update color values to GRASSRGB column in attribute table
+#%end
+#%flag
+#%key: s
+#%description: Output legend for GIS Manager (for scripting use only)
+#%end
+#%flag
+#%key: m
+#%description: Use math notation brackets in legend
+#%end
+import sys
+import os
+import string
+import shutil
+import atexit
+import grass.script as grass
+def cleanup():
+    for i in xrange(1,6+1):
+	grass.try_remove(tmpfile[i])
+	grass.try_remove(tmpfile[i] + ".sort")
+# hard-coded parameter: the maximum number of legend items before
+# we strip them using a middle ellipsis
+max_leg_items = 18
+def subs(vars, tmpl):
+    return string.Template(tmpl).substitute(vars)
+def msg(vars, tmpl):
+    grass.message(subs(vars, tmpl))
+def out(fh, vars, tmpl):
+    fh.write(subs(vars, tmpl))
+def main():
+    breakpoints = options['breakpoints']
+    colorscheme = options['colorscheme']
+    column = options['column']
+    endcolor = options['endcolor']
+    group = options['group']
+    layer = options['layer']
+    linecolor = options['linecolor']
+    map = options['map']
+    maxsize = options['maxsize']
+    monitor = options['monitor']
+    nint = options['nint']
+    pointcolor = options['pointcolor']
+    psmap = options['psmap']
+    size = options['size']
+    startcolor = options['startcolor']
+    themecalc = options['themecalc']
+    themetype = options['themetype']
+    type = options['type']
+    where = options['where']
+    flag_f = flags['f']
+    flag_g = flags['g']
+    flag_l = flags['l']
+    flag_m = flags['m']
+    flag_s = flags['s']
+    flag_u = flags['u']
+    # check column type
+    inf = grass.vector_columns(map, layer)
+    if column not in inf:
+	grass.fatal(_("No such column <%s>") % column)
+    coltype = inf[column]['type'].lower()
+    if coltype not in ["integer", "double precision"]:
+	grass.fatal(_("Column <%s> is of type <%s> which is not numeric.") % (column, coltype))
+    # create temporary file to hold d.graph commands for legend
+    tmp_graph = grass.tempfile()
+    # Create temporary file to commands for GIS Manager group
+    tmp_group = grass.tempfile()
+    # Create temporary file for commands for ps.map map file
+    tmp_psmap = grass.tempfile()
+    # Create temporary file for commands for ps.map legend file
+    tmp_psleg = grass.tempfile()
+    # create file to hold elements for GIS Manager legend
+    tmp_gisleg = grass.tempfile()
+    # Set display variables for group
+    atype = int(type == "area")
+    ptype = int(type == "point")
+    ctype = int(type == "centroid")
+    ltype = int(type == "line")
+    btype = int(type == "boundary")
+    # if running in the GUI, do not create a graphic legend in an xmon
+    if flag_s:
+        flag_l = False
+        # if running in GUI, turn off immediate mode rendering so that the
+        # iterated d.vect commands will composite using the display driver
+        os.environ['GRASS_PNG_READ'] = 'TRUE'
+        os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
+    db = vector_db(map)[1]
+    if not db or not db['table']:
+        grass.fatal(_("No table connected or layer <%s> does not exist.") % layer)
+    table = db['table']
+    database = db['database']
+    driver = db['driver']
+    # update color values to the table?
+    if flag_u:
+        # test, if the column GRASSRGB is in the table
+        s = grass.read_command('db.columns', table = table, database = database, driver = driver)
+        if 'grassrgb' not in s.splitlines():
+            msg(locals(), _("Creating column 'grassrgb' in table <$table>"))
+            sql = "ALTER TABLE %s ADD COLUMN grassrgb varchar(11)" % table
+            grass.write_command('db.execute', database = database, driver = driver, stdin = sql)
+    # Group name
+    if not group:
+        group = "themes"
+    f_group = file(tmp_group, 'w')
+    f_group.write("Group %s\n" % group)
+    # Calculate statistics for thematic intervals
+    if type == "line":
+        stype = "line"
+    else:
+        stype = ["point", "centroid"]
+    if not where:
+        where = None
+    stats = grass.read_command('v.univar', flags = 'eg', map = map, type = stype, column = column, where = where)
+    stats = grass.parse_key_val(stats)
+    min  = float(stats['min'])
+    max  = float(stats['max'])
+    mean = float(stats['mean'])
+    sd   = float(stats['population_stddev'])
+    q1   = float(stats['first_quartile'])
+    q2   = float(stats['median'])
+    q3   = float(stats['third_quartile'])
+    q4   = max
+    ptsize = size
+    if breakpoints and themecalc != "custom_breaks":
+        grass.warning(_("Custom breakpoints ignored due to themecalc setting."))
+    # set interval for each thematic map calculation type
+    if themecalc == "interval":
+        numint = nint
+        step = float(max - min) / numint
+        breakpoints = [min + i * step for i in xrange(numint + 1)]
+        annotations = ""
+    elif themecalc == "std_deviation":
+        # 2 standard deviation units on either side of mean,
+        # plus min to -2 sd units and +2 sd units to max, if applicable
+        breakpoints = [min] + [i for i in [(mean + i * sd) for i in [-2,-1,0,1,2]] if min < i < max] + [max]
+        annotations = [""] + [("%dsd" % i) for (i, j) in [(i, mean + i * sd) for i in [-2,-1,0,1,2]] if (min < j < max)] + [""]
+        annotations = ";".join(annotations)
+        numint = len(breakpoints) - 1
+    elif themecalc == "quartiles":
+        numint=4
+        # one for each quartile
+        breakpoints = [min, q1, q2, q3, max]
+        annotations = " %f; %f; %f; %f" % (q1, q2, q3, q4)
+    elif themecalc == "custom_breaks":
+        if not breakpoints:
+            breakpoints = sys.stdin.read()
+        breakpoints = [int(x) for x in breakpoints.split()]
+        annotations = ""
+    else:
+        grass.fatal(_("Unknown themecalc type <%s>") % themecalc)
+    pointstep = float(maxsize - ptsize) / (numint - 1)
+    # Prepare legend cuts for too large numint
+    if numint > max_leg_items:
+        xupper = int(numint - max_leg_items / 2) + 1
+        xlower = int(max_leg_items / 2) + 1
+    else:
+        xupper = 0
+        xlower = 0
+    # legend title
+    f_graph = file(tmp_graph, 'w')
+    out(f_graph, locals(), """\
+color 0:0:0
+size 2 2
+move 1 95
+text Thematic map legend for column $column of map $map
+size 1.5 1.8
+move 4 90
+text Value range: $min - $max
+    f_gisleg = file(tmp_gisleg, 'w')
+    out(f_gisleg, locals(), """\
+title - - - {Thematic map legend for column $colum of map $map}
+    f_psleg = file(tmp_psleg, 'w')
+    out(f.psleg, locals(), """\
+text 1% 95% Thematic map legend for column $column of map $map
+  ref bottom left
+end
+text 4% 90% Value range: $min - $max
+  ref bottom left
+end
+    msg(locals(), _("Thematic map legend for column $column of map $map"))
+    msg(locals(), _("Value range: $min - $max"))
+    colorschemes = {
+        "blue-red":		("0:0:255",	"255:0:0"),
+        "red-blue":		("255:0:0",	"0:0:255"),
+        "green-red":	("0:255:0",	"255:0:0"),
+        "red-green":	("255:0:0",	"0:255:0"),
+        "blue-green":	("0:0:255",	"0:255:0"),
+        "green-blue":	("0:255:0",	"0:0:255"),
+        "cyan-yellow":	("0:255:255",	"255:255:0"),
+        "yellow-cyan":	("255:255:0",	"0:255:255"),
+        "custom_gradient":	(startcolor,	endcolor)
+    # graduated color thematic mapping
+    if themetype == "graduated_colors":
+        if colorscheme in colorschemes:
+            startc, endc = colorschemes[colorscheme]
+        # set color schemes for graduated color maps
+        elif colorscheme == "single_color":
+            if themetype == "graduated_points":
+                startc = endc = linecolor
+            else:
+                startc = endc = pointcolor
+        else:
+            grass.fatal(_("This should not happen: parser error. Unknown color scheme %s") % colorscheme)
+        color = startc.split(":")
+        endcolor = endc.split(":")
+        #The number of color steps is one less then the number of classes
+        nclrstep = numint - 1
+        clrstep = [(a - b) / nclrstep for a, b in zip(color, endcolor)]
+        themecolor = startc
+        # display graduated color themes
+move 4 87
+text Mapped by $numint intervals of $step
+subtitle - - - {Mapped by $numint intervals of $step}
+text 4% 87% Mapped by $numint intervals of $step
+  ref bottom left
+end
+            msg(locals(), _("Mapped by $numint intervals of $step"))
+        # display graduated color themes for standard deviation units
+        if themecalc == "std_deviation":
+move 4 87
+text Mapped by standard deviation units of $sd (mean = $mean)
+subtitle - - - {Mapped by standard deviation units of $sd (mean = $mean)}
+            out(f_psleg, locals(), """\
+text 4% 87% Mapped by standard deviation units of $sd (mean = $mean)
+  ref bottom left
+end
+            msg(locals(), _("Mapped by standard deviation units of $sd (mean = $mean)"))
+        # display graduated color themes for quartiles
+        if themecalc == "quartiles":
+move 4 87
+text Mapped by quartiles (median = $q2)
+subtitle - - - {Mapped by quartiles (median = $q2)}
+text 4% 87% Mapped by quartiles (median = $q2)
+  ref bottom left
+end
+            msg(locals(), _("Mapped by quartiles (median = $q2)"))
+        f_graph.write("""\
+move 4 83
+text Color
+move 14 83
+text Value
+move 4 80
+text =====
+move 14 80
+text ============
+        f_psleg.write("""\
+text 4% 83% Color
+  ref bottom left
+end
+text 14% 83% Value
+  ref bottom left
+end
+text 4% 80% =====
+  ref bottom left
+end
+text 14% 80% ============
+  ref bottom left
+end
+        sys.stdout.write("Color(R:G:B)\tValue\n")
+        sys.stdout.write("============\t==========\n")
+        line1 = 78
+        line2 = 76
+        line3 = 75
+        i = 1
+        first = True
+        while i < numint:
+            if flag_m:
+                # math notation
+                if first:
+                    closebracket = "]"
+                    openbracket = "["
+                    mincomparison = ">="
+                    first = False
+                else:
+                    openbracket = "]"
+                    mincomparison = ">"
+            else:
+                closebracket = ""
+                openbracket = ""
+                if first:
+                    first = False
+                else:
+            themecolor = ":".join(color)
+            if flag_f:
+                linecolor = "none"
+            else:
+                if type in ["line", "boundary"]:
+                    linecolor = themecolor
+                else:
+                    linecolor = linecolor
+            rangemin = __builtins__.min(breakpoints)
+            rangemax = __builtins__.max(breakpoints)
+            if not annotations:
+                extranote = ""
+            else:
+                extranote = annotations[i]
+            if i < xlower or i >= xupper:
+                xline1 = line2 + 2
+                xline3 = line2 - 1
+color $themecolor
+polygon
+5 $xline1
+8 $xline1
+8 $xline3
+5 $xline3
+color $linecolor
+move 5 $xline1
+draw 8 $xline1
+draw 8 $xline3
+draw 5 $xline3
+draw 5 $xline1
+move 14 $line2
+color 0:0:0
+text $openbracket$rangemin - $rangemax$closebracket $extranote
+            else:
+                if i == xlower:
+color 0:0:0
+move 10 $line2
+text ...
+                else:
+                    #undo next increment
+                    line2 += 4
+area $themecolor $linecolor - {$openbracket$rangemin - $rangemax$closebracket $extranote}
+line 5% $xline1% 8% $xline1%
+  color $linecolor
+end
+text 14% $xline1% $openbracket$rangemin - $rangemax$closebracket $extranote
+  ref center left
+end
+                elif type in ["point", "centroid"]:
+point 8% $xline1%
+  color $linecolor
+  fcolor $themecolor
+  size $size
+  symbol $icon
+end
+  ref center left
+end
+                else:
+rectangle 5% $xline1% 8% $xline3%
+  color 0:0:0
+end
+text 14% $xline3% $openbracket$rangemin - $rangemax$closebracket DCADCA $extranote
+  ref bottom left
+end
+            else:
+                if i == xlower:
+color 0:0:0
+text 14% $xline3% ...
+  ref bottom left
+end
+                f_gisleg.write("text - - - {...}\n")
+            sys.stdout.write(subs(locals(), "$themecolor\t\t$openbracket$rangemin - $rangemax$closebracket $extranote"))
+            if not where:
+                sqlwhere = subs(locals(), "$column $mincomparison $rangemin AND $column <= $rangemax")
+            else:
+                sqlwhere = subs(locals(), "$column $mincomparison $rangemin AND $column <= $rangemax AND $where")
+            # update color to database?
+            if flag_u:
+                sql = subs(locals(), "UPDATE $table SET GRASSRGB = '$themecolor' WHERE $sqlwhere")
+            # Create group for GIS Manager
+            if flag_g:
+                # change rgb colors to hex
+                xthemecolor = "#%02X%02X%02X" % tuple(themecolor.split(":"))
+                #xlinecolor=`echo $linecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
+                if "$linecolor" == "black":
+                    xlinecolor = "#000000"
+                else:
+                    xlinecolor = xthemecolor
+                # create group entry
+                out(f_group, locals(), """\
+  _check 1
+  Vector $column = $rangemin - $rangemax
+    _check 1
+    map $map
+    display_shape 1
+    display_cat 0
+    display_topo 0
+    display_dir 0
+    display_attr 0
+    type_point $ptype
+    type_line $ltype
+    type_boundary $btype
+    type_centroid $ctype
+    type_area $atype
+    type_face 0
+    color $xlinecolor
+    fcolor $xthemecolor
+    width $ptsize
+    _use_fcolor 1
+    lcolor #000000
+    sqlcolor 0
+    icon $icon
+    size $ptsize
+    field $layer
+    lfield $layer
+    attribute
+    xref left
+    yref center
+    lsize 8
+    cat
+    where $sqlwhere
+    _query_text 0
+    _query_edit 1
+    _use_where 1
+    minreg
+    maxreg
+    _width 0.1
+  End
+            # display theme vector map
+            grass.run_command('d.vect', map = map, type = type, layer = layer,
+                              where = sqlwhere,
+                              color = linecolor, fcolor = themecolor, icon = icon, size = ptsize)
+            f_psmap = file(tmp_psmap, 'w')
+                out(f_psmap, locals(), """\
+vlines $map
+  type $type
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+  label $rangemin - $rangemax
+end
+vpoints $map
+  type $type
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+  symbol $icon
+end
+            else:
+vareas $map
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+end
+            # increment for next theme
+            i += 1
+            if i == numint:
+                color = endcolor
+            else:
+                color = [a - b for a, b in zip(color, clrstep)]
+            line1 -= 4
+            line2 -= 4
+            line3 -= 4
+    #graduated points and line widths thematic mapping
+    if themetype in ["graduated_points", "graduated_lines"]:
+        #display graduated points/lines by intervals
+move 4 87
+  ref bottom left
+end
+        # display graduated points/lines for standard deviation units
+move 4 87
+  ref bottom left
+end
+        # display graduated points/lines for quartiles
+move 4 87
+  ref bottom left
+end
+        line1 = 76
+        line2 = 75
+move 4 83
+text Size/width
+move 25 83
+text Value
+move 4 80
+text ==============
+move 25 80
+text 4% 83% Icon size
+  ref bottom left
+end
+text 25% 83% Value
+  ref bottom left
+end
+text 4% 80% ============
+  ref bottom left
+end
+text 25% 80% ============
+  ref bottom left
+end
+        sys.stdout.write("Size/width\tValue")
+        sys.stdout.write("==========\t=====")
+        themecolor = pointcolor
+        if flag_f:
+        i = numint
+        ptsize = maxsize
+        while i >= 1:
+            if flag_m:
+                # math notation
+                if i == 1:
+                    openbracket = "["
+                else:
+                    openbracket = "]"
+            else:
+                closebracket = ""
+                openbracket = ""
+                if i == 1:
+                else:
+            if flag_f:
+                extranote = ""
+            else:
+            iconsize = int(ptsize / 2)
+            lineht = int(ptsize / 4)
+            if lineht < 4:
+                lineht = 4
+                if themetype == graduated_lines:
+color $linecolor
+line $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}
+                else:
+color $themecolor
+point $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}
+icon + $iconsize 5 $line1
+color 0:0:0
+move 10 $line2
+text $ptsize pts
+move 25 $line2
+            else:
+                if i == xlower:
+color 0:0:0
+move 10 $line2
+text ...
+text - - - ...
+                else:
+                    # undo future line increment
+                    line2 += lineht
+point 8% $line1%
+  color $linecolor
+  size $iconsize
+  symbol $icon
+end
+text 25% $line1% $openbracket$rangemin - $rangemax$closebracket $extranote
+  ref center left
+end
+            else:
+                if i == xlower:
+text 25% $xline1% ...
+   ref center left
+end
+            sys.stdout.write(subs(locals(), "$ptsize\t\t$openbracket$rangemin - $rangemax$closebracket $extranote"))
+            if not where:
+            else:
+            if flag_u:
+                sql = subs(locals(), "UPDATE $table SET grassrgb = '$themecolor' WHERE $sqlwhere")
+            if flag_g:
+  _check 1
+    _check 1
+    map $map
+    display_shape 1
+    display_cat 0
+    display_topo 0
+    display_dir 0
+    display_attr 0
+    type_point $ptype
+    type_line $ltype
+    type_area $atype
+    type_face 0
+    color $xlinecolor
+    width $ptsize
+    _use_fcolor 1
+    lcolor #000000
+    sqlcolor 0
+    icon $icon
+    size $ptsize
+    field $layer
+    lfield $layer
+    attribute
+    xref left
+    yref center
+    lsize 8
+    cat
+    where $sqlwhere
+    _query_text 0
+    _query_edit 1
+    _use_where 1
+    minreg
+    maxreg
+    _width 0.1
+  End
+            #graduates line widths or point sizes
+            if themetype == "graduated_lines":
+                                  where = sqlwhere,
+                                  color = linecolor, fcolor = themecolor, icon = icon, size = ptsize,
+                                  width = ptsize)
+            else:
+                                  where = sqlwhere,
+vpoints $map
+  type $type
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+  symbol $icon
+  size $ptsize
+end
+            ptsize -= pointstep
+            line1 -= lineht
+            line2 -= lineht
+            i -= 1
+    # Create graphic legend
+    f_graph.close()
+    if flag_l:
+        grass.run_command('d.erase')
+        grass.run_command('d.graph', input = tmp_graph)
+    # Create group file for GIS Manager
+    f_group.write("End\n")
+    f_group.close()
+    if flag_g:
+        shutil.copyfile(tmp_group, "%s.dm" % group)
+    # Create ps.map map file
+    f_psmap.write("end\n")
+    f_psmap.close()
+    if psmap:
+        shutil.copyfile(tmp_psmap, "%s.psmap" % psmap)
+    # Create ps.map legend file
+    f_psleg.write("end\n")
+    f_psleg.close()
+    if psmap:
+        shutil.copyfile(tmp_psleg, "%s_legend.psmap" % psmap)
+    # Create text file to use with d.graph in GIS Manager
+    f_gisleg.close()
+    if flag_s:
+        tmpdir = os.path.dirname(tmp_gisleg)
+        tlegfile = os.path.join(tmpdir, "gismlegend.txt")
+        shutil.copyfile(tmp_gisleg, tlegfile)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
