[GRASS-SVN] r40173 - grass/branches/develbranch_6/visualization/nviz/scripts
Fri Jan 1 11:35:41 EST 2010
Author: hamish
Date: 2010-01-01 11:35:40 -0500 (Fri, 01 Jan 2010)
New Revision: 40173
   grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl
   grass/branches/develbranch_6/visualization/nviz/scripts/widgets.tcl
less saturated ui colors
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl	2010-01-01 13:16:37 UTC (rev 40172)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/config.tcl	2010-01-01 16:35:40 UTC (rev 40173)
@@ -83,7 +83,7 @@
 option add *font -*-helvetica-medium-r-normal-*-12-*-iso8859-1 widgetDefault
 option add *Label.font -*-helvetica-bold-r-normal-*-12-*-iso8859-1
 option add *label.font -*-helvetica-medium-r-normal-*-12-*-iso8859-1
-option add *Label.foreground "medium blue"
+option add *Label.foreground "#226333"
 option add *label.foreground "black"
 option add *Radiobutton.relief flat
 option add *Checkbutton.relief flat
@@ -106,6 +106,3 @@
 option add *menubutton.borderwidth 1
 option add *button.borderWidth 1
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/widgets.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/widgets.tcl	2010-01-01 13:16:37 UTC (rev 40172)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/widgets.tcl	2010-01-01 16:35:40 UTC (rev 40173)
@@ -29,7 +29,7 @@
 	set y [$c canvasy $y]
 	if { $item == "puck"} {
 	$c delete line
-	$c create line $x $y [expr $w/2] [expr $h/2] -fill green3 -arrow last -tags line
+	$c create line $x $y [expr $w/2] [expr $h/2] -fill gray70 -arrow last -tags line
 	$c move $item [expr $x-$lastx] [expr $y-$lasty]
 	St_set $info lastx $x
@@ -72,14 +72,14 @@
 		$C create text [expr $width/2] 2 -text N -fill black -anchor n
 		$C create text [expr $width/2] $height -text S -fill black -anchor s
 		$C create line $x $y [expr $width/2] [expr $height/2] -tags line \
-		   -fill green3 -arrow last
-		$C create oval $x1 $y1 $x2 $y2 -width 1 -outline green3 -fill green3 \
+		   -fill gray70 -arrow last
+		$C create oval $x1 $y1 $x2 $y2 -width 1 -outline gray70 -fill LightGoldenrod \
 			-tags puck
 	} else {
 		$C create line [expr 0 -$width] $x [expr 2 * $width] $x \
-			-width 1 -tags cross -fill green3
+			-width 1 -tags cross -fill gray70
 		$C create line $y [expr 0 - $height] $y [expr 2*$height] \
 	if {[string compare $name null] == 0} {set name $C.item}
 	set Nv_($name) [St_create {item lastx lasty width height} $type $x $y $width $height]
