[GRASS-SVN] r40250 - grass-addons/raster/r.stream.order
Tue Jan 5 08:45:16 EST 2010
Author: jarekj71
Date: 2010-01-05 08:45:10 -0500 (Tue, 05 Jan 2010)
New Revision: 40250
   grass-addons/raster/r.stream.order/Makefile
   grass-addons/raster/r.stream.order/global.h
   grass-addons/raster/r.stream.order/io.c
   grass-addons/raster/r.stream.order/main.c
   grass-addons/raster/r.stream.order/order.c
update
Modified: grass-addons/raster/r.stream.order/Makefile
--- grass-addons/raster/r.stream.order/Makefile	2010-01-05 13:28:07 UTC (rev 40249)
+++ grass-addons/raster/r.stream.order/Makefile	2010-01-05 13:45:10 UTC (rev 40250)
@@ -4,8 +4,10 @@
 PGM = r.stream.order
-LIBES = $(GISLIB)
-DEPENDENCIES = $(GISDEP)
+LIBES     = $(VECTLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/raster/r.stream.order/global.h
--- grass-addons/raster/r.stream.order/global.h	2010-01-05 13:28:07 UTC (rev 40249)
+++ grass-addons/raster/r.stream.order/global.h	2010-01-05 13:45:10 UTC (rev 40250)
@@ -3,6 +3,8 @@
 #include <string.h>
 #include <math.h>
 #include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/dbmi.h>
 	  /* define */
 #define NODES struct node
@@ -40,10 +42,13 @@
     int strahler, shreeve, horton, hack;	/* orders */
     int next_stream;
     int trib_num;
-    int trib[5];		/* for now, I have problems with realock */
+    int trib[5];
     /*  int *trib; */
     double accum;
+    double length;
+    double stright;
+    double fractal;
     /* float length; */
@@ -73,12 +78,13 @@
 int destroy_c_data(CELL ** data_name);
 int destroy_d_data(DCELL ** data_name);
 int write_maps(void);
+int create_table (void);
 	  /* variables */
 GLOBAL struct Cell_head window;
-GLOBAL char *in_dirs, *in_streams, *in_accum;	/* input dirrection and accumulation raster names */
+GLOBAL char *in_dirs, *in_streams, *in_vector, *in_table, *in_accum;	/* input dirrection and accumulation raster names */
 GLOBAL char *out_strahler, *out_shreeve, *out_hack, *out_horton;	/* output strahler, shreeve and class raster names */
 GLOBAL int out_zero; /* zero-value background */
@@ -91,4 +97,4 @@
 GLOBAL STREAM *s_streams;	/* stream structure all parameters we have here */
 GLOBAL INITS *s_inits;
 int *springs, *outlets;
-int springs_num, outlets_num;
+int springs_num, outlets_num, stream_num;
Modified: grass-addons/raster/r.stream.order/io.c
--- grass-addons/raster/r.stream.order/io.c	2010-01-05 13:28:07 UTC (rev 40249)
+++ grass-addons/raster/r.stream.order/io.c	2010-01-05 13:45:10 UTC (rev 40250)
@@ -125,18 +125,7 @@
 	G_read_range(in_streams,cur_mapset,&stream_range);
 	G_get_range_min_max(&stream_range, &c_min, &c_max);
 	return c_max;
-int r, c;
-int max=0;
-    for (r = 0; r < nrows; ++r) {
-		for (c = 0; c < ncols; ++c) {
-		if (streams[r][c]>max)
-			max=streams[r][c];
-	return max;
@@ -257,3 +246,195 @@
     return 0;
 }				/* end write_maps */
+	int i,j;
+	int index_cat=0;
+	int max_trib=0;
+	char *mapset;
+	struct Map_info Map;
+	char out_table[30];
+	char* out_table;
+	dbConnection conn;
+	dbDriver *driver;
+	dbHandle handle;
+	dbString table_name, db_sql, val_string;
+	char buf[1000];
+	char ins_prev_streams[50]; /* insert */
+	/* table definition */
+	char* tab_cat_col_name="cat integer";
+	char* tab_stream="stream integer";
+	char* tab_next_stream="next_stream integer";
+	char* tab_prev_streams;
+	char* tab_strahler="strahler integer";
+	char* tab_horton="horton integer";
+	char* tab_shreve="shreve integer";
+	char* tab_hack="hack integer";
+	char* tab_length="length double precision";
+	char* tab_cumlength="cum_length double precision";
+	char* tab_stright="stright double precision";
+	char* tab_fractal="fractal double precision";
+	G_message("Adding table...");
+	/* trib num */
+	for (i=0;i<stream_num;++i) {
+			if (s_streams[i].trib_num>max_trib)
+		max_trib=s_streams[i].trib_num;
+		mapset = G_find_vector(in_vector, "");
+		if (mapset == NULL)
+	G_fatal_error(_("Vector map <%s> not found"), in_vector);
+	  if (Vect_open_update(&Map, in_vector, mapset) < 0)
+	G_fatal_error("Cannot open vector map <%s>", in_vector);
+		if(in_table)
+	sprintf(out_table, "%s",in_table);
+		else
+	sprintf(out_table, "%s_new",in_vector);
+	/* init */
+	db_init_string(&db_sql);
+	db_init_string(&val_string);
+	db_init_string(&table_name);
+	db_init_handle(&handle);
+	/* string to db */
+	db_get_connection(&conn);
+	driver=db_start_driver_open_database(conn.driverName, conn.databaseName);
+		if(db_table_exists(conn.driverName, conn.databaseName,out_table)>0)
+	G_fatal_error("table %s exists. Choose different table name or check and remove existing table",out_table);
+	/* creating table */
+	switch (max_trib) {
+		case 2:
+	tab_prev_streams="prev_str01 integer, prev_str02 integer";
+	break;
+		case 3:
+	tab_prev_streams="prev_str01 integer, prev_str02 integer, prev_str03 integer";
+	break;
+		case 4:
+	tab_prev_streams="prev_str01 integer, prev_str02 integer, prev_str03 integer prev_str04 integer";
+	break;
+		case 5:
+	tab_prev_streams="prev_str01 integer, prev_str02 integer, prev_str03 integer prev_str04 integer, prev_str05 integer";
+	break;
+		default:
+	G_fatal_error("Error with number of tributuaries");
+	break;
+	sprintf(buf,"create table %s (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
+		out_table,
+		tab_cat_col_name,
+		tab_stream,
+		tab_next_stream,
+		tab_prev_streams,
+		tab_strahler,
+		tab_horton,
+		tab_shreve,
+		tab_hack,
+		tab_length,
+		tab_cumlength,
+		tab_stright,
+		tab_fractal);
+	db_set_string(&db_sql, buf);
+	if(db_execute_immediate(driver,&db_sql) !=DB_OK) {
+		db_close_database(driver);
+		db_shutdown_driver(driver);
+		G_fatal_error("Cannot create table %s", db_get_string(&db_sql));
+		if (db_create_index2(driver,out_table,tab_cat_col_name) !=DB_OK)
+	G_warning("cannot create index");
+		if (db_grant_on_table(driver,out_table,DB_PRIV_SELECT, DB_GROUP |DB_PUBLIC) !=DB_OK)
+	G_fatal_error("cannot grant privileges on table %s", out_table);
+	db_begin_transaction(driver);
+			if(s_streams[i].stream<0)
+		continue;
+			case 2:
+			sprintf(ins_prev_streams,"%d, %d",s_streams[i].trib[0],s_streams[i].trib[1]);
+		break;
+			case 3:
+			sprintf(ins_prev_streams,"%d ,%d, %d",s_streams[i].trib[0],s_streams[i].trib[1],s_streams[i].trib[2]);
+		break;
+			case 4:
+		sprintf(ins_prev_streams,"%d, %d, %d, %d",s_streams[i].trib[0],s_streams[i].trib[1],s_streams[i].trib[2],s_streams[i].trib[3]);
+		break;
+			case 5:
+		sprintf(ins_prev_streams,"%d, %d, %d, %d, %d",s_streams[i].trib[0],s_streams[i].trib[1],s_streams[i].trib[2],s_streams[i].trib[3],s_streams[i].trib[4]);
+		break;
+			default:
+		break;
+		sprintf(buf,"insert into %s  values	\
+			(%d, %d, %d, %s, %d, %d, %d, %d, %f, %f , %f, %f)",
+		out_table,
+		i,
+		s_streams[i].stream,
+		s_streams[i].next_stream,
+		ins_prev_streams,
+		s_streams[i].strahler,
+		s_streams[i].horton,
+		s_streams[i].shreeve,
+		s_streams[i].hack,
+		s_streams[i].length,
+		s_streams[i].accum,
+		s_streams[i].stright,
+		s_streams[i].fractal);
+		db_set_string(&db_sql,buf);
+				G_fatal_error("Cannot inset new row: %s", db_get_string(&db_sql));
+db_commit_transaction(driver);
+db_close_database_shutdown_driver(driver);
+		if(Vect_map_check_dblink(&Map,1))
+	Vect_map_del_dblink(&Map,1);
+	Vect_map_add_dblink(&Map, 1, NULL, out_table,
+		tab_cat_col_name, conn.driverName, conn.databaseName);
+	  Vect_hist_command(&Map);
+    Vect_build(&Map);
+    Vect_close(&Map);
+G_message("Table %s created. You can join it to vector created with r.stream.extract \
+						using v.db.connect", out_table);
+	return 0;
Modified: grass-addons/raster/r.stream.order/main.c
--- grass-addons/raster/r.stream.order/main.c	2010-01-05 13:28:07 UTC (rev 40249)
+++ grass-addons/raster/r.stream.order/main.c	2010-01-05 13:45:10 UTC (rev 40250)
@@ -25,9 +25,9 @@
     struct GModule *module;	/* GRASS module for parsing arguments */
-    struct Option *in_dir_opt, *in_stm_opt, *in_acc_opt, *out_str_opt, *out_shr_opt, *out_hck_opt, *out_hrt_opt;	/* options */
+    struct Option *in_dir_opt, *in_stm_opt, /* *in_vect_opt,*/ *in_table_opt, *in_acc_opt, *out_str_opt, *out_shr_opt, *out_hck_opt, *out_hrt_opt;	/* options */
     struct Flag *out_back;	/* flags */
-    int stream_num, i;
+    int i;
     /* initialize GIS environment */
     G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
@@ -56,7 +56,22 @@
     in_dir_opt->gisprompt = "old,cell,raster";
     in_dir_opt->description =
 	"Name of direction input map (r.watershed or r.stream.extract)";
+    in_vect_opt = G_define_option();
+    in_vect_opt->key = "vector";
+    in_vect_opt->type = TYPE_STRING;
+    in_vect_opt->required = NO;
+    in_vect_opt->gisprompt = "old,vector,vector";
+    in_vect_opt->description =
+	"Name of stream vector file (r.stream.extract output only)";
+		in_table_opt = G_define_option();	/* optional tabe name */
+    in_table_opt->key = "table";
+    in_table_opt->type = TYPE_STRING;
+    in_table_opt->required = NO;
+    in_table_opt->description =
+	"Name of new table to create";
     in_acc_opt = G_define_option();	/* input stream mask file - optional */
     in_acc_opt->key = "accum";	/* required if strahler stream order is calculated for existing stream network */
     in_acc_opt->type = TYPE_STRING;
@@ -124,6 +139,8 @@
     /* stores input options to variables */
     in_dirs = in_dir_opt->answer;
     in_streams = in_stm_opt->answer;
+    /* in_vector = in_vect_opt->answer; */
+		in_table = in_table_opt->answer;
     in_accum = in_acc_opt->answer;
     /* stores output options to variables */
@@ -135,19 +152,19 @@
 		if (out_strahler) {
  	if (G_legal_filename(out_strahler) < 0)
-		G_fatal_error(_("<%s> is an illegal file name"), out_strahler);
+		G_fatal_error("<%s> is an illegal file name", out_strahler);
 		if (out_shreeve) {
 	if (G_legal_filename(out_shreeve) < 0)
-	  G_fatal_error(_("<%s> is an illegal file name"), out_shreeve);
+	  G_fatal_error("<%s> is an illegal file name", out_shreeve);
 		if (out_hack) {
 	if (G_legal_filename(out_hack) < 0)
-		G_fatal_error(_("<%s> is an illegal file name"), out_hack);
+		G_fatal_error("<%s> is an illegal file name", out_hack);
 		if (out_horton) {
 	if (G_legal_filename(out_horton) < 0)
-		G_fatal_error(_("<%s> is an illegal file name"), out_horton);
+		G_fatal_error("<%s> is an illegal file name", out_horton);
     nrows = G_window_rows();
@@ -159,19 +176,23 @@
 	stack_max = stream_num;	/* stack's size depends on number of streams */
     init_streams(stream_num);
     find_nodes(stream_num);
-    if ((out_hack || out_horton) && !in_accum)
+    if (out_hack || out_horton || in_table)
    do_cum_length();
-    if (out_strahler || out_horton)
+    if (out_strahler || out_horton || in_table)
 	strahler();
-    if (out_shreeve)
+    if (out_shreeve || in_table)
 	shreeve();
-    if (out_horton)
+    if (out_horton || in_table)
 	horton();
-    if (out_hack)
+    if (out_hack || in_table)
 	hack();
-    write_maps();
+  write_maps();
+		if(in_table)
+	create_table();
     exit(EXIT_SUCCESS);
Modified: grass-addons/raster/r.stream.order/order.c
--- grass-addons/raster/r.stream.order/order.c	2010-01-05 13:28:07 UTC (rev 40249)
+++ grass-addons/raster/r.stream.order/order.c	2010-01-05 13:45:10 UTC (rev 40250)
@@ -32,14 +32,18 @@
     int i;
     s_streams = (STREAM *) G_malloc((stream_num + 1) * sizeof(STREAM));
-    for (i = 0; i <= stream_num; ++i) {
+        for (i = 0; i <= stream_num; ++i) {
 	s_streams[i].next_stream = -1;
 	s_streams[i].stream = -1;
+	s_streams[i].trib_num = -1;
 	s_streams[i].strahler = -1;
 	s_streams[i].shreeve = -1;
 	s_streams[i].hack = -1;
 	s_streams[i].horton = -1;
 	s_streams[i].accum = 0.;
+	s_streams[i].length = 0.;
+	s_streams[i].stright = 0.;
+	s_streams[i].fractal = 0.;
 	s_streams[i].trib[0] = 0;
 	s_streams[i].trib[1] = 0;
 	s_streams[i].trib[2] = 0;
@@ -87,7 +91,7 @@
 		cur_stream = streams[r][c];
 		if (cur_stream != next_stream) {	/* building hierarchy */
 		    if (outlets_num > (stream_num - 1))
 			G_fatal_error(_("Error finding nodes. Stream and direction maps probably do not match..."));
@@ -111,6 +115,7 @@
 		if (trib_num > 1) {	/* adding tributuaries */
 		    s_streams[cur_stream].trib_num = trib_num;
+		    //G_message("HERE %d %d", cur_stream, s_streams[cur_stream].trib_num);
 		    for (i = 1; i < 9; ++i) {
 			if (trib > 4)
@@ -152,8 +157,10 @@
   int cur_stream;
   float cur_northing, cur_easting;
   float next_northing, next_easting;
+  float init_northing, init_easting;//
   double cur_length=0.;
   double cur_accum=0.;
 	G_message(_("Finding longests streams..."));
 	G_begin_distance_calculations();
@@ -164,10 +171,14 @@
 		cur_length=0;
 		done=1;
+		init_northing = window.north - (r + .5) * window.ns_res; //
+	  init_easting = window.west + (c + .5) * window.ew_res; //
 		while(done) {
 		 cur_northing = window.north - (r + .5) * window.ns_res;
 	   cur_easting = window.west + (c + .5) * window.ew_res;
 		 d=dirs[r][c];
 		 next_r=r+nextr[d];
 	   next_c=c+nextc[d];
@@ -177,25 +188,35 @@
 		c + nextc[d] < 0 || c + nextc[d] > (ncols - 1) ||
 		streams[next_r][next_c]<1) { /* mask */
-			next_northing = window.north - (r + .5) * window.ns_res;
-			next_easting = 	window.west + (c + .5) * window.ew_res;
-			cur_length=G_distance(next_easting, next_northing, cur_easting,  cur_northing);
-			s_streams[cur_stream].accum += cur_length;
+			cur_length=(window.ns_res+window.ew_res)/2;
+			s_streams[cur_stream].accum += cur_length;
+			s_streams[cur_stream].length += cur_length;
+			s_streams[cur_stream].stright =
+				G_distance(cur_easting, cur_northing, init_easting,  init_northing);
+			s_streams[cur_stream].fractal =
+				s_streams[cur_stream].length/s_streams[cur_stream].stright;
 			break;
 		 next_northing = window.north - (next_r + .5) * window.ns_res;
 		 next_easting = 	window.west + (next_c + .5) * window.ew_res;
 		 cur_length =	G_distance(next_easting, next_northing, cur_easting,  cur_northing);
 		 r=next_r;
 		 c=next_c;
 			if (streams[next_r][next_c] != cur_stream) {
+					G_distance(next_easting, next_northing, init_easting,  init_northing);
+				init_northing = cur_northing;
+				init_easting = cur_easting;
 				cur_stream=streams[next_r][next_c];
 				cur_accum=0;
 				for (i = 0; i < s_streams[cur_stream].trib_num; ++i) {
 					if (s_streams[s_streams[cur_stream].trib[i]].accum == 0) {
 						done=0;
@@ -205,6 +226,7 @@
 					if(s_streams[s_streams[cur_stream].trib[i]].accum>cur_accum)
 						cur_accum=s_streams[s_streams[cur_stream].trib[i]].accum;
 				} /* end for i */
+				if(!in_accum)
 			s_streams[cur_stream].accum=cur_accum;
 			}/* end if */
 		} /* end while */
