[GRASS-SVN] r40293 - grass/trunk/raster/r.in.xyz
Wed Jan 6 21:45:31 EST 2010
Author: hamish
Date: 2010-01-06 21:45:30 -0500 (Wed, 06 Jan 2010)
New Revision: 40293
   grass/trunk/raster/r.in.xyz/r.in.xyz.html
notes on importing gridded data
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html	2010-01-06 20:06:41 UTC (rev 40292)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html	2010-01-07 02:45:30 UTC (rev 40293)
@@ -2,7 +2,8 @@
 The <em>r.in.xyz</em> module will load and bin ungridded x,y,z ASCII data
 into a new raster map. The user may choose from a variety of statistical
-methods in creating the new raster.
+methods in creating the new raster. Gridded data provided as a stream of
+x,y,z points may also be imported.
 <p>
 <em>r.in.xyz</em> is designed for processing massive point cloud datasets,
@@ -39,6 +40,26 @@
 <h2>NOTES</h2>
+<h4>Gridded data</h4>
+If data is known to be on a regular grid <em>r.in.xyz</em> can reconstruct
+the map perfectly as long as some care is taken to set up the region
+correctly and that the data's native map projection is used. A typical
+method would involve determining the grid resolution either by examining
+the data's associated documentation or by studying the text file. Next scan
+the data with <em>r.in.xyz</em>'s <b>-s</b> (or <b>-g</b>) flag to find the
+input data's bounds. GRASS uses the cell-center raster convention where
+data points fall within the center of a cell, as opposed to the grid-node
+convention. Therefore you will need to grow the region out by half a cell
+in all directions beyond what the scan found in the file. After the region
+bounds and resolution are set correctly with <em>g.region</em>, run
+<em>r.in.xyz</em> using the <i>n</i> method and verify that n=1 at all places.
+<em>r.univar</em> can help. Once you are confident that the region exactly
+matches the data proceed to run <em>r.in.xyz</em> using one of the <i>mean,
+min, max</i>, or <i>median</i> methods. With n=1 throughout, the result
+should be identical regardless of which of those methods are used.
 <h4>Memory use</h4>
 While the <b>input</b> file can be arbitrarily large, <em>r.in.xyz</em>
