[GRASS-SVN] r40351 - grass/trunk/scripts/v.in.lines
Sat Jan 9 08:24:26 EST 2010
Author: hamish
Date: 2010-01-09 08:24:26 -0500 (Sat, 09 Jan 2010)
New Revision: 40351
Added:
   grass/trunk/scripts/v.in.lines/v.in.lines.html
rename html to gr7 style
Copied: grass/trunk/scripts/v.in.lines/v.in.lines.html (from rev 40349, grass/trunk/scripts/v.in.lines/description.html)
--- grass/trunk/scripts/v.in.lines/v.in.lines.html	                        (rev 0)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.html	2010-01-09 13:24:26 UTC (rev 40351)
@@ -0,0 +1,56 @@
+<H2>DESCRIPTION</H2>
+Imports a stream of ASCII x,y[,z] coordinates as a line or series of lines.
+<H2>NOTES</H2>
+Input ASCII coordinates are simply a series of "x&nbsp;y" data points.
+Lines are separated by a row containing "<tt>NaN&nbsp;NaN</tt>".
+<!-- TODO:? Line categories start at 1 and increase sequentially. -->
+<P>
+You can import 3D lines by providing 3 columns of data in the input
+stream and using the <B>-z</B> flag.
+<P>
+This script is a simple wrapper around the <em>v.in.mapgen</em> module.
+<H2>EXAMPLE</H2>
+<div class="code"><pre>
+v.in.lines in=- out=two_lines fs=, &lt;&lt;EOF
+167.846717,-46.516653
+167.846663,-46.516645
+167.846656,-46.516644
+167.846649,-46.516644
+167.846642,-46.516643
+NaN,NaN
+167.846520,-46.516457
+167.846528,-46.516461
+167.846537,-46.516464
+167.846535,-46.516486
+167.846544,-46.516489
+167.846552,-46.516493
+EOF
+v.category in=two_lines out=lines_with_cats option=add
+</pre></div>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="v.in.ascii.html">v.in.ascii</A><br>
+<A HREF="v.in.mapgen.html">v.in.mapgen</A><br>
+<A HREF="v.out.ascii.html">v.out.ascii</A><br>
+<A HREF="d.graph.html">d.graph</a><br>
+<A HREF="r.in.poly.html">r.in.poly</A>
+</em>
+<H2>AUTHOR</H2>
+Hamish Bowman<BR>
+Dunedin, New Zealand
+<p>
+<i>Last changed: $Date$</i>
