[GRASS-SVN] r40522 - grass/trunk/raster/r.mapcalc
Sun Jan 17 21:16:48 EST 2010
Author: glynn
Date: 2010-01-17 21:16:47 -0500 (Sun, 17 Jan 2010)
New Revision: 40522
   grass/trunk/raster/r.mapcalc/evaluate.c
Use G_add_error_handler() instead of G_set_error_routine()
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c	2010-01-18 02:13:51 UTC (rev 40521)
+++ grass/trunk/raster/r.mapcalc/evaluate.c	2010-01-18 02:16:47 UTC (rev 40522)
@@ -241,13 +241,10 @@
-static int error_handler(const char *msg, int fatal)
+static void error_handler(void *p)
     expr_list *l;
-    if (!fatal)
-	return 0;
     for (l = exprs; l; l = l->next) {
 	expression *e = l->exp;
 	int fd = e->data.bind.fd;
@@ -255,10 +252,6 @@
 	if (fd >= 0)
 	    unopen_output_map(fd);
-    G_unset_error_routine();
-    G_fatal_error("%s", msg);
-    return 0;
 static void setup_rand(void)
@@ -291,7 +284,7 @@
     setup_rand();
     exprs = ee;
-    G_set_error_routine(error_handler);
+    G_add_error_handler(error_handler, NULL);
     for (l = ee; l; l = l->next) {
