[GRASS-SVN] r40648 - in grass/trunk: include lib/gis lib/imagery
	raster/r.coin raster/r.mode raster/r.rescale
	raster/r.rescale.eq raster/r.statistics
    svn_grass at osgeo.org
    Mon Jan 25 13:28:39 EST 2010
Author: glynn
Date: 2010-01-25 13:28:36 -0500 (Mon, 25 Jan 2010)
New Revision: 40648
Removed:
   grass/trunk/lib/imagery/ls_groups.c
   grass/trunk/raster/r.statistics/o_distrib.c
   grass/trunk/include/gis.h
   grass/trunk/include/gisdefs.h
   grass/trunk/include/imagedefs.h
   grass/trunk/include/spawn.h
   grass/trunk/lib/gis/error.c
   grass/trunk/lib/gis/list.c
   grass/trunk/lib/gis/parser_wps.c
   grass/trunk/lib/gis/popen.c
   grass/trunk/lib/gis/spawn.c
   grass/trunk/raster/r.coin/make_coin.c
   grass/trunk/raster/r.mode/main.c
   grass/trunk/raster/r.rescale.eq/main.c
   grass/trunk/raster/r.rescale/main.c
   grass/trunk/raster/r.statistics/main.c
   grass/trunk/raster/r.statistics/method.h
   grass/trunk/raster/r.statistics/o_adev.c
   grass/trunk/raster/r.statistics/o_average.c
   grass/trunk/raster/r.statistics/o_divr.c
   grass/trunk/raster/r.statistics/o_kurt.c
   grass/trunk/raster/r.statistics/o_max.c
   grass/trunk/raster/r.statistics/o_median.c
   grass/trunk/raster/r.statistics/o_min.c
   grass/trunk/raster/r.statistics/o_mode.c
   grass/trunk/raster/r.statistics/o_sdev.c
   grass/trunk/raster/r.statistics/o_skew.c
   grass/trunk/raster/r.statistics/o_sum.c
   grass/trunk/raster/r.statistics/o_var.c
   grass/trunk/raster/r.statistics/r.statistics.html
   grass/trunk/raster/r.statistics/run_cmd.c
Eliminate use of [G_]popen()
Add G_wait()
Add G_{open,close}_pager ($GRASS_PAGER interface)
Add G_{open,close}_mail (mailing error messages to user)
Add G_popen_{read,write,close} (non-shell popen/pclose replacement)
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/include/gis.h	2010-01-25 18:28:36 UTC (rev 40648)
@@ -364,6 +364,11 @@
     int value;
+struct Popen {
+    FILE *fp;
+    int pid;
 /*============================== Prototypes ================================*/
 /* Since there are so many prototypes for the gis library they are stored */
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/include/gisdefs.h	2010-01-25 18:28:36 UTC (rev 40648)
@@ -444,6 +444,12 @@
 /* overwrite.c */
 int G_check_overwrite(int argc, char **argv);
+/* pager.c */
+FILE *G_open_pager(struct Popen *);
+void G_close_pager(struct Popen *);
+FILE *G_open_mail(struct Popen *);
+void G_close_mail(struct Popen *);
 /* parser.c */
 void G_disable_interactive(void);
 struct GModule *G_define_module(void);
@@ -472,6 +478,11 @@
 void G_set_percent_routine(int (*) (int));
 void G_unset_percent_routine(void);
+/* popen.c */
+FILE *G_popen_write(struct Popen *, const char *, const char **);
+FILE *G_popen_read(struct Popen *, const char *, const char **);
+void G_popen_close(struct Popen *);
 /* plot.c */
 void G_setup_plot(double, double, double, double, int (*)(int, int),
 		  int (*)(int, int));
@@ -488,10 +499,6 @@
 /* pole_in_poly.c */
 int G_pole_in_polygon(const double *, const double *, int);
-/* popen.c */
-FILE *G_popen(const char *, const char *);
-int G_pclose(FILE *);
 /* progrm_nme.c */
 const char *G_program_name(void);
 void G_set_program_name(const char *);
Modified: grass/trunk/include/imagedefs.h
--- grass/trunk/include/imagedefs.h	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/include/imagedefs.h	2010-01-25 18:28:36 UTC (rev 40648)
@@ -61,10 +61,6 @@
 /* loc_info.c */
 int I_location_info(char *, const char *);
-/* ls_groups.c */
-int I_list_groups(int);
-int I_list_subgroups(const char *, int);
 /* points.c */
 int I_new_control_point(struct Control_Points *, double, double, double,
 			double, int);
Modified: grass/trunk/include/spawn.h
--- grass/trunk/include/spawn.h	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/include/spawn.h	2010-01-25 18:28:36 UTC (rev 40648)
@@ -44,5 +44,6 @@
 extern int G_spawn(const char *command, ...);
 extern int G_vspawn_ex(const char *command, const char **args);
 extern int G_spawn_ex(const char *command, ...);
+extern int G_wait(int i_pid);
 #endif
Modified: grass/trunk/lib/gis/error.c
--- grass/trunk/lib/gis/error.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/lib/gis/error.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -54,7 +54,7 @@
 static int print_word(FILE *, char **, int *, const int);
 static void print_sentence(FILE *, const int, const char *);
 static void print_error(const char *, const int);
-static int mail_msg(const char *, int);
+static void mail_msg(const char *, int);
 static int write_error(const char *, int, time_t, const char *);
 static void log_error(const char *, int);
@@ -388,23 +388,15 @@
 /* Mail a message */
-static int mail_msg(const char *msg, int fatal)
+static void mail_msg(const char *msg, int fatal)
-    FILE *mail;
-    char command[64];
-    const char *user;
+    struct Popen mail;
+    FILE *fp = G_open_mail(&mail);
-    user = G_whoami();
-    if (user == 0 || *user == 0)
-	return 1;
+    if (fp)
+	fprintf(fp, "GIS %s: %s\n", fatal ? "ERROR" : "WARNING", msg);
-    sprintf(command, "mail '%s'", G_whoami());
-    if ((mail = G_popen(command, "w"))) {
-	fprintf(mail, "GIS %s: %s\n", fatal ? "ERROR" : "WARNING", msg);
-	G_pclose(mail);
-    return 0;
+    G_close_mail(&mail);
 /* Print one word, new line if necessary */
Modified: grass/trunk/lib/gis/list.c
--- grass/trunk/lib/gis/list.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/lib/gis/list.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -23,11 +23,10 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
-static volatile int broken_pipe;
 static int list_element(FILE *, const char *, const char *, const char *,
 			int (*)(const char *, const char *, const char *));
-static void sigpipe_catch(int);
    \brief General purpose list function.
@@ -55,41 +54,19 @@
 		    const char *mapset,
 		    int (*lister) (const char *, const char *, const char *))
+    struct Popen pager;
     int n;
     FILE *more;
     int count;
-#ifdef SIGPIPE
-    RETSIGTYPE (*sigpipe)(int);
-#endif
-    /* must catch broken pipe in case "more" quits */
-    broken_pipe = 0;
-#ifdef SIGPIPE
-    sigpipe = signal(SIGPIPE, sigpipe_catch);
-#endif
     count = 0;
     if (desc == 0 || *desc == 0)
 	desc = element;
-    /* G_popen() does not work with MinGW? */
-#ifndef __MINGW32__
      * G_popen() the more command to page the output
-    if (isatty(1)) {
-#ifdef __MINGW32__
-	more = G_popen("%GRASS_PAGER%", "w");
-#else
-	more = G_popen("$GRASS_PAGER", "w");
-#endif
-	if (!more)
-	    more = stdout;
-    else
-#endif
-	more = stdout;
+    more = G_open_pager(&pager);
     fprintf(more, "----------------------------------------------\n");
@@ -98,39 +75,27 @@
      * otherwise just list the specified mapset
     if (mapset == 0 || *mapset == 0)
-	for (n = 0; !broken_pipe && (mapset = G__mapset_name(n)); n++)
+	for (n = 0; (mapset = G__mapset_name(n)); n++)
 	    count += list_element(more, element, desc, mapset, lister);
     else
-    if (!broken_pipe) {
-	if (count == 0) {
-	    if (mapset == 0 || *mapset == 0)
-		fprintf(more, _("no %s files available in current mapset\n"),
-			desc);
-	    else
-		fprintf(more, _("no %s files available in mapset <%s>\n"),
-			desc, mapset);
+    if (count == 0) {
+	if (mapset == 0 || *mapset == 0)
+	    fprintf(more, _("no %s files available in current mapset\n"),
+		    desc);
+	else
+	    fprintf(more, _("no %s files available in mapset <%s>\n"),
+		    desc, mapset);
      * close the more
-    if (more != stdout)
-	G_pclose(more);
-#ifdef SIGPIPE
-    signal(SIGPIPE, sigpipe);
-#endif
+    G_close_pager(&pager);
-static void sigpipe_catch(int n)
-    broken_pipe = 1;
-    signal(n, sigpipe_catch);
     FILE *out, const char *element, const char *desc, const char *mapset,
     int (*lister)(const char *, const char *, const char *))
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/lib/gis/parser_wps.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -745,4 +745,5 @@
     fprintf(stdout,"\t\t\t\t\t</Supported>\n");
     fprintf(stdout,"\t\t\t\t</BoundingBoxData>\n");
     fprintf(stdout,"\t\t\t</Input>\n");
\ No newline at end of file
Modified: grass/trunk/lib/gis/popen.c
--- grass/trunk/lib/gis/popen.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/lib/gis/popen.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -1,21 +1,70 @@
-#include <unistd.h>
 #include <stdio.h>
-#include <signal.h>
 #include <stdlib.h>
-#include <sys/types.h>
+#include <unistd.h>
+#include <grass/spawn.h>
-#ifdef __MINGW32__
-#define popen(cmd,mode) _popen(cmd,mode)
-#define pclose(fp) _pclose(fp)
-#endif
+static FILE *do_popen(struct Popen *state, int wr,
+		      const char *program, const char **args)
+    const char *which = wr ? SF_STDIN : SF_STDOUT;
+    const char *dir = wr ? "w" : "r";
+    int pfd, cfd;
+    int pipe_fds[2];
+    const char *argv[2];
-FILE *G_popen(const char *cmd, const char *mode)
+    state->fp = NULL;
+    state->pid = -1;
+    if (pipe(pipe_fds) < 0)
+	return NULL;
+    cfd = pipe_fds[wr ? 0 : 1];
+    pfd = pipe_fds[wr ? 1 : 0];
+    if (!args) {
+	argv[0] = program;
+	argv[1] = NULL;
+	args = argv;
+    state->pid = G_spawn_ex(
+	program,
+	SF_ARGVEC, args,
+	SF_REDIRECT_DESCRIPTOR, which, cfd,
+	SF_CLOSE_DESCRIPTOR, pfd,
+	SF_BACKGROUND, NULL);
+    if (state->pid == -1) {
+	close(pipe_fds[0]);
+	close(pipe_fds[1]);
+	return NULL;
+    close(cfd);
+    state->fp = fdopen(pfd, dir);
+    return state->fp;
+FILE *G_popen_write(struct Popen *state, const char *program, const char **args)
-    return popen(cmd, mode);
+    return do_popen(state, 1, program, args);
-int G_pclose(FILE *ptr)
+FILE *G_popen_read(struct Popen *state, const char *program, const char **args)
-    return pclose(ptr);
+    return do_popen(state, 0, program, args);
+void G_popen_close(struct Popen *state)
+    if (state->fp)
+	fclose(state->fp);
+    if (state->pid != -1)
+	G_wait(state->pid);
Modified: grass/trunk/lib/gis/spawn.c
--- grass/trunk/lib/gis/spawn.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/lib/gis/spawn.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -386,13 +386,18 @@
 	return -1;
+    CloseHandle(pi.hThread);
     if (!background) {
 	WaitForSingleObject(pi.hProcess, INFINITE);
 	if (!GetExitCodeProcess(pi.hProcess, &exitcode))
 	    return -1;
+	CloseHandle(pi.hProcess);
 	return (int) exitcode;
     return pi.dwProcessId;
@@ -934,3 +939,42 @@
     return status;
+int G_wait(int i_pid)
+#ifdef __MINGW32__
+    DWORD rights = PROCESS_QUERY_INFORMATION | SYNCHRONIZE;
+    HANDLE hProcess = OpenProcess(rights, FALSE, (DWORD) i_pid);
+    DWORD exitcode;
+    if (!hProcess)
+	return -1;
+    WaitForSingleObject(hProcess, INFINITE);
+    if (!GetExitCodeProcess(hProcess, &exitcode))
+	exitcode = (DWORD) -1;
+    CloseHandle(hProcess);
+    return (int) exitcode;
+#else
+    pid_t pid = (pid_t) i_pid;
+    int status = -1;
+    pid_t n;
+    do
+	n = waitpid(pid, &status, 0);
+    while (n == (pid_t) - 1 && errno == EINTR);
+    if (n != pid)
+	return -1;
+    else {
+	if (WIFEXITED(status))
+	    return WEXITSTATUS(status);
+	else if (WIFSIGNALED(status))
+	    return WTERMSIG(status);
+	else
+	    return -0x100;
+#endif
Deleted: grass/trunk/lib/imagery/ls_groups.c
--- grass/trunk/lib/imagery/ls_groups.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/lib/imagery/ls_groups.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -1,131 +0,0 @@
-* I_list_groups (full)
-* I_list_subgroups (group, full)
-#include <stdio.h>
-#include <string.h>
-#include <stdlib.h>
-#include <grass/imagery.h>
-#include <grass/spawn.h>
-static char *tempfile = NULL;
-int I_list_groups(int full)
-    char *element;
-    int i;
-    char buf[GPATH_MAX];
-    char title[50];
-    FILE *ls, *temp;
-    struct Ref ref;
-    int any;
-    if (tempfile == NULL)
-	tempfile = G_tempfile();
-    element = "group";
-    G__make_mapset_element(element);
-    temp = fopen(tempfile, "w");
-    if (temp == NULL)
-	G_fatal_error("can't open any temp files");
-    fprintf(temp, "Available groups\n");
-    fprintf(temp, "---------------------------------\n");
-    any = 0;
-    strcpy(buf, "cd ");
-    G__file_name(buf + strlen(buf), element, "", G_mapset());
-    strcat(buf, ";ls");
-    if (!full)
-	strcat(buf, " -C");
-    /* FIXME: use G__ls() */
-    if ((ls = popen(buf, "r"))) {
-	while (G_getl2(buf, sizeof(buf), ls)) {
-	    any = 1;
-	    fprintf(temp, "%s", buf);
-	    if (full) {
-		I_get_group_title(buf, title, sizeof(title));
-		if (*title)
-		    fprintf(temp, " (%s)", title);
-		fprintf(temp, "\n");
-		I_get_group_ref(buf, &ref);
-		for (i = 0; i < ref.nfiles; i++)
-		    fprintf(temp, "\t%s in %s\n", ref.file[i].name,
-			    ref.file[i].mapset);
-		if (ref.nfiles <= 0)
-		    fprintf(temp, "\t** empty **\n");
-		I_free_group_ref(&ref);
-	    else
-	pclose(ls);
-    if (!any)
-	fprintf(temp, "no group files available\n");
-    fclose(temp);
-    G_spawn(getenv("GRASS_PAGER"), getenv("GRASS_PAGER"), tempfile, NULL);
-    remove(tempfile);
-    return 0;
-int I_list_subgroups(const char *group, int full)
-    char element[GNAME_MAX + 15];
-    int i;
-    FILE *ls, *temp;
-    struct Ref ref;
-    int any;
-    sprintf(element, "group/%s/subgroup", group);
-    if (temp == NULL)
-	G_fatal_error("Unable to open any temporary file");
-    fprintf(temp, "Available subgroups in group %s\n", group);
-    any = 0;
-    if (!full)
-	    any = 1;
-	    fprintf(temp, "%s\n", buf);
-	    if (full) {
-		I_get_subgroup_ref(group, buf, &ref);
-	pclose(ls);
-    if (!any)
-	fprintf(temp, "no subgroup files available\n");
-    fclose(temp);
-    remove(tempfile);
-    return 0;
Modified: grass/trunk/raster/r.coin/make_coin.c
--- grass/trunk/raster/r.coin/make_coin.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.coin/make_coin.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -28,8 +28,8 @@
 int make_coin(void)
-    FILE *fd;
-    FILE *statfd;
+    FILE *fp;
+    FILE *stat_fp;
     struct stats
 	long cat1;
@@ -39,43 +39,48 @@
     } stats;
     int n, n1, n2;
     int reversed;
+    char input[GNAME_MAX*2+8];
+    const char *args[5];
+    struct Popen child;
     char buf[512];
     int count;
     G_message(_("Tabulating Coincidence between '%s' and '%s'"),
 	      map1name, map2name);
-    sprintf(buf, "r.stats -anrc fs=: input=\"");
-    strcat(buf, map1name);
-    strcat(buf, ",");
-    strcat(buf, map2name);
-    strcat(buf, "\"");
-    statfd = fopen(statname, "w");
-    if (statfd == NULL)
+    sprintf(input, "input=%s,%s", map1name, map2name);
+    args[0] = "r.stats";
+    args[1] = "-anrc";
+    args[2] = "fs=:";
+    args[3] = input;
+    args[4] = NULL;
+    stat_fp = fopen(statname, "w");
+    if (!stat_fp)
 	G_fatal_error(_("Unable to create any tempfiles"));
-    fd = popen(buf, "r");
-    if (fd == NULL)
+    fp = G_popen_read(&child, "r.stats", args);
+    if (!fp)
 	G_fatal_error(_("Unable to run r.stats"));
     /* need to find the number of cats in each file */
     count = 0;
-    while (fgets(buf, sizeof buf, fd)) {
+    while (fgets(buf, sizeof buf, fp)) {
 	if (sscanf(buf, "%ld:%ld:%lf:%ld",
 		   &stats.cat1, &stats.cat2, &stats.area, &stats.count) != 4)
-	    pclose(fd);
 	    G_fatal_error(_("Unexpected output from r.stats"));
-	fwrite(&stats, sizeof(stats), 1, statfd);
+	fwrite(&stats, sizeof(stats), 1, stat_fp);
 	count++;
-    pclose(fd);
-    fclose(statfd);
+    G_popen_close(&child);
-    statfd = fopen(statname, "r");
+    fclose(stat_fp);
+    stat_fp = fopen(statname, "r");
+    if (!stat_fp)
 	G_fatal_error(_("Unable to open tempfile"));
     /* build a sorted list of cats in both maps */
@@ -84,7 +89,7 @@
     /* read the statsfile to get the cat lists */
     count = 0;
-    while (fread(&stats, sizeof(stats), 1, statfd)) {
+    while (fread(&stats, sizeof(stats), 1, stat_fp)) {
 	catlist1[count] = stats.cat1;
 	catlist2[count++] = stats.cat2;
@@ -145,8 +150,8 @@
 	    break;
     /* now read the statsfile and insert into the table */
-    G_fseek(statfd, 0L, 0);
+    G_fseek(stat_fp, 0L, 0);
 	long z;
 	if (reversed) {
@@ -172,7 +177,7 @@
 	table[n].count = stats.count;
 	table[n].area = stats.area;
-    fclose(statfd);
+    fclose(stat_fp);
     return 0;
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.mode/main.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -38,7 +38,10 @@
     char *basemap;
     char *covermap;
     char *outmap;
-    char command[1024];
+    char output[GNAME_MAX+8];
+    const char *args[4];
+    struct Popen stats_child, reclass_child;
     struct Categories cover_cats;
     FILE *stats, *reclass;
     int first;
@@ -86,16 +89,25 @@
 	G_fatal_error(_("%s: Unable to read category labels"), covermap);
-    sprintf(command, "r.stats -an \"%s,%s\"", basemap, covermap);
+    sprintf(input, "input=%s,%s", basemap, covermap);
-    /* printf(command); */
-    stats = popen(command, "r");
+    args[1] = "-an";
+    args[2] = input;
+    args[3] = NULL;
-    sprintf(command, "r.reclass i=\"%s\" o=\"%s\"", basemap, outmap);
+    stats = G_popen_read(&stats_child, "r.stats", args);
-    reclass = popen(command, "w");
+    sprintf(input, "input=%s", basemap);
+    sprintf(output, "output=%s", outmap);
+    args[0] = "r.reclass";
+    args[1] = input;
+    args[2] = output;
+    args[3] = NULL;
+    reclass = G_popen_write(&reclass_child, "r.reclass", args);
     first = 1;
     while (read_stats(stats, &basecat, &covercat, &value)) {
 	if (first) {
@@ -120,8 +132,8 @@
     write_reclass(reclass, catb, catc, Rast_get_c_cat((CELL *) &catc, &cover_cats));
-    pclose(stats);
-    pclose(reclass);
+    G_popen_close(&reclass_child);
+    G_popen_close(&stats_child);
-    exit(0);
+    return 0;
Modified: grass/trunk/raster/r.rescale/main.c
--- grass/trunk/raster/r.rescale/main.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.rescale/main.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -21,8 +21,12 @@
 int main(int argc, char *argv[])
-    FILE *fd;
+    char input[GNAME_MAX+8];
+    char title[GPATH_MAX];
+    FILE *fp;
     long old_min, old_max;
     long new_min, new_max;
     long new_delta, old_delta;
@@ -112,17 +116,22 @@
     G_message(_("Rescale %s[%ld,%ld] to %s[%ld,%ld]"),
 	      old_name, old_min, old_max, new_name, new_min, new_max);
-    sprintf(buf, "r.reclass input=\"%s\" output=\"%s\" title=\"",
-	    old_name, new_name);
+    sprintf(input, "input=%s", old_name);
+    sprintf(output, "output=%s", new_name);
     if (parm.title->answer)
-	strcat(buf, parm.title->answer);
-    else {
-	strcat(buf, "rescale of ");
-	strcat(buf, old_name);
+	sprintf(title, "title=%s", parm.title->answer);
+    else
+	sprintf(title, "title=rescale of %s", old_name);
-    fd = popen(buf, "w");
+    args[1] = input;
+    args[2] = output;
+    args[3] = title;
+    args[4] = NULL;
+    fp = G_popen_write(&child, "r.reclass", args);
     old_delta = old_max - old_min;
     new_delta = new_max - new_min;
     divisor = (float)new_delta / (float)old_delta;
@@ -132,20 +141,21 @@
     for (cat = old_min; cat <= old_max; cat++) {
 	value = (int)(divisor * (cat - old_min) + new_min + .5);
 	if (value != prev) {
-	    fprintf(fd, "%ld thru %ld = %ld %ld", first, cat - 1, prev,
+	    fprintf(fp, "%ld thru %ld = %ld %ld", first, cat - 1, prev,
 		    first);
 	    if (cat - 1 != first)
-		fprintf(fd, " thru %ld", cat - 1);
-	    fprintf(fd, "\n");
+		fprintf(fp, " thru %ld", cat - 1);
+	    fprintf(fp, "\n");
 	    prev = value;
 	    first = cat;
-    fprintf(fd, "%ld thru %ld = %ld %ld", first, cat - 1, prev, first);
+    fprintf(fp, "%ld thru %ld = %ld %ld", first, cat - 1, prev, first);
-    pclose(fd);
-    exit(EXIT_SUCCESS);
+    return EXIT_SUCCESS;
Modified: grass/trunk/raster/r.rescale.eq/main.c
--- grass/trunk/raster/r.rescale.eq/main.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.rescale.eq/main.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -21,12 +21,16 @@
 #include "local_proto.h"
-static FILE *fd;
+static FILE *fp;
 static void reclass(CELL, CELL, CELL);
     CELL old_min, old_max;
     CELL new_min, new_max;
     long cat;
@@ -117,29 +121,36 @@
     G_message(_("Rescale %s[%d,%d] to %s[%d,%d]"),
-    else {
+    else
-    Rast_cell_stats_histo_eq(&statf, (CELL) old_min, (CELL) old_max,
-			  (CELL) new_min, (CELL) new_max, 0, reclass);
-    if (fd != stdout)
-	pclose(fd);
+    args[1] = input;
+    args[2] = output;
+    args[3] = title;
+    args[4] = NULL;
+    Rast_cell_stats_histo_eq(&statf,
+			     old_min, old_max,
+			     new_min, new_max,
+			     0, reclass);
 static void reclass(CELL cat1, CELL cat2, CELL value)
 	    (long)cat1, (long)cat2, (long)value, (long)cat1);
     if (cat1 != cat2)
-	fprintf(fd, " thru %ld", (long)cat2);
+	fprintf(fp, " thru %ld", (long)cat2);
Modified: grass/trunk/raster/r.statistics/main.c
--- grass/trunk/raster/r.statistics/main.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/main.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -25,26 +25,21 @@
 /* modify this table to add new methods */
 struct menu menu[] = {
-    {"diversity", DIV, "diversity of values in specified objects in %%"},
-    {"distribution", DISTRIB,
-     "distribution of values in specified objects in %%"},
-    {"average", AVERAGE, "average of values in specified objects"},
-    {"mode", MODE, "mode of values in specified objects"},
-    {"median", MEDIAN, "median of values in specified objects"},
-    {"avedev", ADEV, "Average deviation of values in specified objects"},
-    {"stddev", SDEV, "Standard deviation of values in specified objects"},
-    {"variance", VARIANC, "Variance of values in specified objects"},
-    {"skewness", SKEWNES, "Skewnes of values in specified objects"},
-    {"kurtosis", KURTOSI, "Kurtosis of values in specified objects"},
-    {"min", MIN, "Minimum of values in specified objects"},
-    {"max", MAX, "Maximum of values in specified objects"},
-    {"sum", SUM, "Sum of values in specified objects"},
-    {0, 0, 0}
+    {"diversity", o_divr,    "Diversity of values in specified objects in %%"},
+    {"average",   o_average, "Average of values in specified objects"},
+    {"mode",      o_mode,    "Mode of values in specified objects"},
+    {"median",    o_median,  "Median of values in specified objects"},
+    {"avedev",    o_adev,    "Average deviation of values in specified objects"},
+    {"stddev",    o_sdev,    "Standard deviation of values in specified objects"},
+    {"variance",  o_var,     "Variance of values in specified objects"},
+    {"skewness",  o_skew,    "Skewnes of values in specified objects"},
+    {"kurtosis",  o_kurt,    "Kurtosis of values in specified objects"},
+    {"min",       o_min,     "Minimum of values in specified objects"},
+    {"max",       o_max,     "Maximum of values in specified objects"},
+    {"sum",       o_sum,     "Sum of values in specified objects"},
+    {NULL,        NULL,      NULL}
-/* function prototypes */
-static int is_ok(char *, char *);
 int main(int argc, char **argv)
     int o_method;
@@ -82,9 +77,8 @@
     method->options = methods;
     outputmap = G_define_standard_option(G_OPT_R_OUTPUT);
-    outputmap->description =
-	_("Resultant raster map (not used with 'distribution')");
-    outputmap->required = NO;
+    outputmap->description = _("Resultant raster map");
+    outputmap->required = YES;
     flag_c = G_define_flag();
     flag_c->key = 'c';
@@ -100,10 +94,9 @@
     if (Rast_map_is_fp(covermap->answer, "") != 0)
 	G_fatal_error(_("This module currently only works for integer (CELL) maps"));
-    if (Rast_read_cats(covermap->answer, "", &cats) < 0) {
+    if (Rast_read_cats(covermap->answer, "", &cats) < 0)
 	G_fatal_error(_("Unable to read category file of raster map <%s>"),
 		      covermap->answer);
     for (o_method = 0; menu[o_method].name; o_method++)
 	if (strcmp(menu[o_method].name, method->answer) == 0)
@@ -117,88 +110,10 @@
 	exit(EXIT_FAILURE);
-    switch (menu[o_method].val) {
-    case DISTRIB:
-	if (outputmap->answer != NULL)
-	    G_warning(_("Output map <%s> ignored"), outputmap->answer);
+    (*menu[o_method].func)(basemap->answer, covermap->answer,
+			   outputmap->answer,
+			   flag_c->answer, &cats);
-	o_distrib(basemap->answer, covermap->answer,
-		  outputmap->answer, flag_c->answer);
-	break;
-    case AVERAGE:
-	is_ok(method->answer, outputmap->answer);
-	o_average(basemap->answer, covermap->answer,
-		  outputmap->answer, flag_c->answer, &cats);
-	break;
-    case MODE:
-	o_mode(basemap->answer, covermap->answer,
-	break;
-    case ADEV:
-	o_adev(basemap->answer, covermap->answer,
-	break;
-    case SDEV:
-	o_sdev(basemap->answer, covermap->answer,
-	break;
-    case VARIANC:
-	o_var(basemap->answer, covermap->answer,
-	break;
-    case SKEWNES:
-	o_skew(basemap->answer, covermap->answer,
-	break;
-    case KURTOSI:
-	o_kurt(basemap->answer, covermap->answer,
-	break;
-    case MEDIAN:
-	o_median(basemap->answer, covermap->answer,
-	break;
-    case MIN:
-	o_min(basemap->answer, covermap->answer,
-	break;
-    case MAX:
-	o_max(basemap->answer, covermap->answer,
-	break;
-    case SUM:
-	o_sum(basemap->answer, covermap->answer,
-	break;
-    case DIV:
-	o_divr(basemap->answer, covermap->answer,
-	break;
-    default:
-	G_fatal_error(_("Not yet implemented!"));
     return 0;
-static int is_ok(char *method, char *map)
-    if (map == NULL)
-	G_fatal_error(_("An output raster map needs to be defined with method '%s'"),
-		      method);
-    return 0;
Modified: grass/trunk/raster/r.statistics/method.h
--- grass/trunk/raster/r.statistics/method.h	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/method.h	2010-01-25 18:28:36 UTC (rev 40648)
@@ -1,20 +1,7 @@
 #include <stdio.h>
+#include <grass/gis.h>
 #include <grass/raster.h>
-#define DISTRIB 0
-#define AVERAGE 1
-#define MODE    2
-#define MEDIAN  3
-#define ADEV    4		/* Average deviation     */
-#define SDEV    5		/* Standard deviation    */
-#define VARIANC 6		/* Variance              */
-#define SKEWNES 7		/* Skewnes               */
-#define KURTOSI 8		/* Kurtosis              */
-#define MIN	9		/* Minimum               */
-#define MAX	10		/* Maximum               */
-#define SUM	11		/* Sum                   */
-#define DIV	12		/* Diversity             */
 struct stats
     int nalloc;
@@ -26,56 +13,30 @@
 struct menu
     const char *name;		/* method name */
-    int val;			/* number of function */
+    int (*func)(const char *, const char *, const char *, int, struct Categories *);
     const char *text;		/* menu display - full description */
 extern struct menu menu[];
-/* run_cmd.c */
-extern void run_stats(const char *, const char *, const char *, const char *);
-extern int run_reclass(const char *, const char *, const char *);
-/* o_adev.c */
 int o_adev(const char *, const char *, const char *, int, struct Categories *);
-/* o_average.c */
 int o_average(const char *, const char *, const char *, int, struct Categories *);
-/* o_distrib.c */
-int o_distrib(const char *, const char *, const char *, int);
-/* o_kurt.c */
+int o_divr(const char *, const char *, const char *, int, struct Categories *);
 int o_kurt(const char *, const char *, const char *, int, struct Categories *);
-/* o_max.c */
 int o_max(const char *, const char *, const char *, int, struct Categories *);
-/* o_median.c */
 int o_median(const char *, const char *, const char *, int, struct Categories *);
-/* o_min.c */
 int o_min(const char *, const char *, const char *, int, struct Categories *);
-/* o_mode.c */
 int o_mode(const char *, const char *, const char *, int, struct Categories *);
-/* o_sdev.c */
 int o_sdev(const char *, const char *, const char *, int, struct Categories *);
-/* o_skew.c */
 int o_skew(const char *, const char *, const char *, int, struct Categories *);
-/* o_sum.c */
 int o_sum(const char *, const char *, const char *, int, struct Categories *);
-/* o_var.c */
 int o_var(const char *, const char *, const char *, int, struct Categories *);
-/* o_divr.c */
-int o_divr(const char *, const char *, const char *, int, struct Categories *);
+/* run_cmd.c */
+FILE *run_stats(struct Popen *, const char *, const char *, const char *);
+FILE *run_reclass(struct Popen *, const char *, const char *);
 /* read_stats.c */
 int read_stats(FILE *, long *, long *, double *);
Modified: grass/trunk/raster/r.statistics/o_adev.c
--- grass/trunk/raster/r.statistics/o_adev.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_adev.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -13,11 +13,10 @@
 static int a_dev(double *, int, double *);
-int
-o_adev(const char *basemap, const char *covermap, const char *outputmap, int usecats,
-       struct Categories *cats)
+int o_adev(const char *basemap, const char *covermap, const char *outputmap,
+	   int usecats, struct Categories *cats)
     int first, mem, i, count;
     long basecat, covercat, catb, catc;
@@ -27,14 +26,9 @@
     mem = MEM * sizeof(double);
     tab = (double *)G_malloc(mem);
-    sprintf(command, "r.stats -cn input=\"%s,%s\" fs=space", basemap,
-	    covermap);
+    stats = run_stats(&stats_child, basemap, covermap, "-cn");
+    reclass = run_reclass(&reclass_child, basemap, outputmap);
-    sprintf(command, "r.reclass i=\"%s\" o=\"%s\"", basemap, outputmap);
     first = 1;
 	if (first) {
@@ -76,9 +70,10 @@
 	fprintf(reclass, "%ld = %ld %f\n", catb, catb, adev);
-    pclose(stats);
-    pclose(reclass);
-    /**/ return (0);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_average.c
--- grass/trunk/raster/r.statistics/o_average.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_average.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -8,37 +8,25 @@
 static int out(FILE *, long, double, double);
-int
-o_average(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_average(const char *basemap, const char *covermap, const char *outputmap,
-    char *me = "o_average";
+    FILE *stats, *reclass;
     long catb, basecat, covercat;
     double x, area, sum1, sum2;
-    int stat;
-    char *tempfile1, *tempfile2;
-    FILE *fd1, *fd2;
-    tempfile1 = G_tempfile();
-    tempfile2 = G_tempfile();
+    stats = run_stats(&stats_child, basemap, covermap, "-an");
-    run_stats(basemap, covermap, "-a", tempfile1);
+    out(reclass, 0L, 0.0, 1.0);	/* force at least one reclass rule */
-    fd1 = fopen(tempfile1, "r");
-    fd2 = fopen(tempfile2, "w");
-    if (fd1 == NULL || fd2 == NULL) {
-	unlink(tempfile1);
-	unlink(tempfile2);
-	G_fatal_error(_("%s: unable to open temporary file"), me);
-    out(fd2, 0L, 0.0, 1.0);	/* force at least one reclass rule */
     catb = 0;
     sum1 = 0.0;
     sum2 = 0.0;
-    while (fscanf(fd1, "%ld %ld %lf", &basecat, &covercat, &area) == 3) {
+    while (fscanf(stats, "%ld %ld %lf", &basecat, &covercat, &area) == 3) {
 	if (catb != basecat) {
-	    out(fd2, catb, sum1, sum2);
+	    out(reclass, catb, sum1, sum2);
 	    sum1 = 0.0;
 	    sum2 = 0.0;
 	    catb = basecat;
@@ -50,18 +38,17 @@
 	sum1 += x * area;
 	sum2 += area;
-    out(fd2, basecat, sum1, sum2);
-    fclose(fd1);
-    fclose(fd2);
-    stat = run_reclass(basemap, outputmap, tempfile2);
-    return (stat);
+    out(reclass, basecat, sum1, sum2);
+    return 0;
-static int out(FILE * fd, long cat, double sum1, double sum2)
+static int out(FILE *fp, long cat, double sum1, double sum2)
     char buf[80];
@@ -73,7 +60,7 @@
 	sprintf(buf, "%.10f", sum1 / sum2);
 	G_trim_decimal(buf);
-    fprintf(fd, "%ld = %ld %s\n", cat, cat, buf);
+    fprintf(fp, "%ld = %ld %s\n", cat, cat, buf);
     return 0;
Deleted: grass/trunk/raster/r.statistics/o_distrib.c
--- grass/trunk/raster/r.statistics/o_distrib.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_distrib.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -1,91 +0,0 @@
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include "method.h"
-static int o_out(FILE *, long, long);
-int o_distrib(const char *basemap, const char *covermap, const char *outputmap, int usecats)
-    char *me = "o_distrib";
-    long csum, area, catb, basecat, covercat;
-    double sum, tot;
-    long stat, cat, total_count;
-    FILE *fd1, *fd2;
-    run_stats(basemap, covermap, "-c", tempfile1);
-    o_out(fd2, 0L, 0);		/* force at least one reclass rule */
-    catb = 0;
-    csum = 0;
-    G_debug(1, "***** Stage 1 - Calculating sums ****");
-    while (fscanf(fd1, "%ld %ld %ld", &basecat, &covercat, &area) == 3) {
-	if (catb != basecat) {
-	    o_out(fd2, catb, csum);
-	    csum = 0;
-	    catb = basecat;
-	csum += area;
-    rewind(fd1);
-    freopen(tempfile2, "r", fd2);
-    G_debug(1, "***** Stage 2 - Calculating percents of values in cover  ****");
-    catb = 0;
-    tot = 0;
-    total_count = 0;
-	if (catb != basecat && basecat > 0) {
-	    if (fscanf(fd2, "%ld %ld", &cat, &total_count) != 2)
-		return (1);
-	    catb = basecat;
-	    /* fprintf(stderr,"Total (must be 100): %lf\n",tot); */
-	    tot = 0;
-	if (basecat) {
-	    sum = (double)(100.0 * area) / total_count;
-	    fprintf(stdout, "%8ld %8ld %f\n", basecat, covercat, sum);
-	    /*tot+=sum;
-	       fprintf(stderr,"Area: %ld   Tot: %ld  totsum: %lf\n",area,total_count,tot); */
-    fclose(fd1);
-    fclose(fd2);
-    return (stat);
-static int o_out(FILE * fd, long cat, long sum)
-    if (sum == 0 || cat == 0)
-	return -1;
-    fprintf(fd, "%ld %ld\n", cat, sum);
-    return 0;
Modified: grass/trunk/raster/r.statistics/o_divr.c
--- grass/trunk/raster/r.statistics/o_divr.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_divr.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -4,34 +4,27 @@
 #include "method.h"
-int
-o_divr(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_divr(const char *basemap, const char *covermap, const char *outputmap,
-    FILE *stats_fd, *reclass_fd;
+    FILE *stats_fp, *reclass_fp;
     int first;
     double area;
+    stats_fp = run_stats(&stats_child, basemap, covermap, "-an");
+    reclass_fp = run_reclass(&reclass_child, basemap, outputmap);
-    sprintf(command, "r.stats -an input=\"%s,%s\" fs=space", basemap,
-	    covermap);
-    stats_fd = popen(command, "r");
-    reclass_fd = popen(command, "w");
     first = 1;
-    while (read_stats(stats_fd, &basecat, &covercat, &area)) {
+    while (read_stats(stats_fp, &basecat, &covercat, &area)) {
 	if (first) {
 	    first = 0;
 	    catb = basecat;
 	    catc = 0;
 	if (basecat != catb) {
-	  write_reclass(reclass_fd, catb, catc, Rast_get_c_cat((CELL *) &catc, cats),
+	  write_reclass(reclass_fp, catb, catc, Rast_get_c_cat((CELL *) &catc, cats),
 			  usecats);
 	    catb = basecat;
 	    catc = 0;
@@ -39,10 +32,11 @@
 	catc++;
     if (!first)
-      write_reclass(reclass_fd, catb, catc, Rast_get_c_cat((CELL *) &catc, cats), usecats);
+      write_reclass(reclass_fp, catb, catc, Rast_get_c_cat((CELL *) &catc, cats), usecats);
-    pclose(stats_fd);
-    pclose(reclass_fd);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_kurt.c
--- grass/trunk/raster/r.statistics/o_kurt.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_kurt.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -13,11 +13,10 @@
 static int kurt(double *, int, double *);
-int
-o_kurt(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_kurt(const char *basemap, const char *covermap, const char *outputmap,
@@ -27,13 +26,9 @@
-	    covermap);
     first = 1;
 	if (first) {
@@ -74,11 +69,10 @@
     kurt(tab, count, &var);
     fprintf(reclass, "%ld = %ld %f\n", catb, catb, var);
-    pclose(stats);
-    pclose(reclass);
-    return (0);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_max.c
--- grass/trunk/raster/r.statistics/o_max.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_max.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -4,22 +4,17 @@
 #include "method.h"
-int
-o_max(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_max(const char *basemap, const char *covermap, const char *outputmap,
     int first;
-    sprintf(command, "r.stats -n input=\"%s,%s\" fs=space", basemap,
-	    covermap);
+    stats = run_stats(&stats_child, basemap, covermap, "-n");
     first = 1;
     while (fscanf(stats, "%ld %ld", &basecat, &covercat) == 2) {
@@ -46,8 +41,9 @@
     write_reclass(reclass, catb, catc, Rast_get_c_cat((CELL *) &catc, cats), usecats);
-    pclose(stats);
-    pclose(reclass);
-    return (0);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_median.c
--- grass/trunk/raster/r.statistics/o_median.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_median.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -8,28 +8,21 @@
 static long median(struct stats *);
-int
-o_median(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_median(const char *basemap, const char *covermap, const char *outputmap,
     int first;
     double area;
     struct stats stats;
-	    covermap);
     first = 1;
 	if (first) {
 	    stats.n = 0;
 	    stats.nalloc = 16;
@@ -42,7 +35,7 @@
 	    catc = median(&stats);
 			  usecats);
 	    catb = basecat;
 	    stats.n = 0;
@@ -60,13 +53,13 @@
     if (!first) {
-    pclose(stats_fd);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_min.c
--- grass/trunk/raster/r.statistics/o_min.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_min.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -4,22 +4,17 @@
 #include "method.h"
-int
-o_min(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_min(const char *basemap, const char *covermap, const char *outputmap,
     int first;
-	    covermap);
     first = 1;
@@ -46,8 +41,8 @@
-    pclose(stats);
-    pclose(reclass);
-    return (0);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_mode.c
--- grass/trunk/raster/r.statistics/o_mode.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_mode.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -8,19 +8,15 @@
 o_mode(const char *basemap, const char *covermap, const char *outputmap, int usecats,
     int first;
     double value, max;
-	    covermap);
     first = 1;
@@ -51,8 +47,9 @@
-    pclose(stats);
-    pclose(reclass);
-    return (0);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_sdev.c
--- grass/trunk/raster/r.statistics/o_sdev.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_sdev.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -13,11 +13,10 @@
 static int s_dev(double *, int, double *);
-int
-o_sdev(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_sdev(const char *basemap, const char *covermap, const char *outputmap,
@@ -28,15 +27,9 @@
-	    covermap);
     first = 1;
 	if (first) {
@@ -78,10 +71,10 @@
     fprintf(reclass, "%ld = %ld %f\n", catb, catb, sdev);
     G_debug(5, "%ld = %ld %f\n", catb, catb, sdev);
-    pclose(stats);
-    pclose(reclass);
-    return (0);
+    return 0;
Modified: grass/trunk/raster/r.statistics/o_skew.c
--- grass/trunk/raster/r.statistics/o_skew.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_skew.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -13,11 +13,10 @@
 static int skew(double *, int, double *);
-int
-o_skew(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_skew(const char *basemap, const char *covermap, const char *outputmap,
@@ -28,14 +27,9 @@
-	    covermap);
     first = 1;
 	if (first) {
@@ -76,13 +70,12 @@
     skew(tab, count, &var);
-    pclose(stats);
-    pclose(reclass);
-    /**/ return (0);
+    return 0;
 *  Given an array of data[1...n], this routine returns its skewness
Modified: grass/trunk/raster/r.statistics/o_sum.c
--- grass/trunk/raster/r.statistics/o_sum.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_sum.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -5,46 +5,29 @@
 #include "method.h"
-#define STATS "r.stats"
-#define RECLASS "r.reclass"
 static void sum_out(FILE *, long, double);
-int
-o_sum(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_sum(const char *basemap, const char *covermap, const char *outputmap,
-    char *me = "o_sum";
     double x, area, sum1;
     int stat;
-    FILE *fd1, *fd2;
+    sum_out(reclass, 0L, 0.0);	/* force at least one reclass rule */
-    sum_out(fd2, 0L, 0.0);	/* force at least one reclass rule */
     catb = 0;
     sum1 = 0.0;
-	    sum_out(fd2, catb, sum1);
+	    sum_out(reclass, catb, sum1);
 	    sum1 = 0.0;
 	    catb = basecat;
@@ -56,18 +39,15 @@
 	/*        fprintf(stderr,"sum: %d\n",(int)sum1); */
-    sum_out(fd2, basecat, sum1);
-    fclose(fd1);
-    fclose(fd2);
+    sum_out(reclass, basecat, sum1);
-    return (stat);
+    return stat;
-static void sum_out(FILE * fd, long cat, double sum1)
+static void sum_out(FILE *fp, long cat, double sum1)
     char buf[64];
@@ -78,5 +58,6 @@
Modified: grass/trunk/raster/r.statistics/o_var.c
--- grass/trunk/raster/r.statistics/o_var.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/o_var.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -13,11 +13,10 @@
 static int m_var(double *, int, double *);
-int
-o_var(const char *basemap, const char *covermap, const char *outputmap, int usecats,
+int o_var(const char *basemap, const char *covermap, const char *outputmap,
@@ -28,14 +27,9 @@
-	    covermap);
     first = 1;
 	if (first) {
@@ -79,10 +73,10 @@
     fprintf(reclass, "%ld = %ld %f\n", catb, catb, vari);
     G_debug(5, "2. %ld = %ld %f", catb, catb, vari);
-    pclose(stats);
-    pclose(reclass);
-    return (0);
+    return 0;
Modified: grass/trunk/raster/r.statistics/r.statistics.html
--- grass/trunk/raster/r.statistics/r.statistics.html	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/r.statistics.html	2010-01-25 18:28:36 UTC (rev 40648)
@@ -13,7 +13,6 @@
 The available methods are the following (english - german):
 <ul>
-<li>distribution - Verteilung in Prozent</li>
 <li>average - Durchschnitt</li>
 <li>mode - Modalwert</li>
 <li>median - Median</li>
@@ -36,39 +35,11 @@
 stored.
 <p>
-All calculations except "distribution" create an output layer.  The output
+All calculations create an output layer.  The output
 layer is a reclassified version of the base layer with identical
 category values, but modified category labels - the results of the calculations
 are stored in the category labels of the output layer.
-<p>
-For distributions, the output is printed to the user interface (stdout).
-If an output file name was specified, it will be ignored. The result will
-be a text table with three columns.
-In the first column are the category values of the base layer (a), in the second
-column the associated value of the cover layers (b), and in the third column the
-percentage of area in that base layer category (a) that falls into that row's
-value in the cover layer(b). Example:
-<div class="code"><pre>
-1   124  23
-1   201  47
-1   273  30
-2   101  5
-2   152  16
-2   167  60
-2   187  19
-</pre></div>
-So for the first line in the output above, we see that 23% of the cells of the
-base layer category 1 have a value of 124 in the cover layer.
-To transfer the values stored as category labels into cell values,
-<em>r.mapcalc</em> can be used ('@' operator).
 <h2>EXAMPLES</h2>
 Calculation of average elevation of each field in the Spearfish region:
Modified: grass/trunk/raster/r.statistics/run_cmd.c
--- grass/trunk/raster/r.statistics/run_cmd.c	2010-01-25 12:20:13 UTC (rev 40647)
+++ grass/trunk/raster/r.statistics/run_cmd.c	2010-01-25 18:28:36 UTC (rev 40648)
@@ -4,62 +4,49 @@
 #include <sys/stat.h>
 #include <fcntl.h>
 #include "method.h"
-void run_stats(const char *basemap, const char *covermap, const char *mode,
-	       const char *tempfile)
+FILE *run_stats(struct Popen *child,
+		const char *basemap, const char *covermap, const char *mode)
-    char buf[6 + GNAME_MAX + 1 + GMAPSET_MAX + 1 + GNAME_MAX + 1 + GMAPSET_MAX + 1];
-    const char *argv[10];
-    int argc = 0;
+    char input[6 + GNAME_MAX + 1 + GMAPSET_MAX + 1 + GNAME_MAX + 1 + GMAPSET_MAX + 1];
+    const char *argv[5];
+    FILE *fp;
-    argv[argc++] = "r.stats";
-    argv[argc++] = mode;
+    argv[0] = "r.stats";
+    argv[1] = mode;
+    argv[2] = input;
+    argv[3] = "fs=space";
+    argv[4] = NULL;
-    argv[argc++] = "-n";
-    sprintf(buf, "input=%s,%s", basemap, covermap);
-    argv[argc++] = buf;
-    argv[argc++] = "fs=space";
-    argv[argc++] = SF_REDIRECT_FILE;
-    argv[argc++] = SF_STDOUT;
-    argv[argc++] = SF_MODE_OUT;
-    argv[argc++] = tempfile;
-    argv[argc++] = NULL;
-    if (G_vspawn_ex(argv[0], argv) != 0) {
-	remove(tempfile);
+    fp = G_popen_read(child, argv[0], argv);
+    if (!fp)
 	G_fatal_error("error running r.stats");
+    return fp;
-int run_reclass(const char *basemap, const char *outputmap, const char *tempfile)
+FILE *run_reclass(struct Popen *child, const char *basemap, const char *outputmap)
-    char buf1[6 + GNAME_MAX + 1 + GMAPSET_MAX + 1];
-    char buf2[7 + GNAME_MAX + 1];
-    const char *argv[8];
-    int argc = 0;
+    char input[6 + GNAME_MAX + 1 + GMAPSET_MAX + 1];
+    char output[7 + GNAME_MAX + 1];
+    const char *argv[4];
+    FILE *fp;
-    argv[argc++] = "r.reclass";
+    sprintf(output, "output=%s", outputmap);
-    sprintf(buf1, "input=%s", basemap);
-    argv[argc++] = buf1;
+    argv[0] = "r.reclass";
+    argv[1] = input;
+    argv[2] = output;
+    argv[3] = NULL;
-    sprintf(buf2, "output=%s", outputmap);
-    argv[argc++] = buf2;
+    fp = G_popen_write(child, argv[0], argv);
+    if (!fp)
+	G_fatal_error("error running r.stats");
-    argv[argc++] = SF_STDIN;
-    argv[argc++] = SF_MODE_IN;
-    return G_vspawn_ex(argv[0], argv);
+    return fp;
