[GRASS-SVN] r40657 - grass/branches/develbranch_6/raster/r.watershed/ram
Tue Jan 26 03:56:28 EST 2010
Author: mmetz
Date: 2010-01-26 03:56:27 -0500 (Tue, 26 Jan 2010)
New Revision: 40657
   grass/branches/develbranch_6/raster/r.watershed/ram/init_vars.c
initialize alt, wat and asp together
Modified: grass/branches/develbranch_6/raster/r.watershed/ram/init_vars.c
--- grass/branches/develbranch_6/raster/r.watershed/ram/init_vars.c	2010-01-26 08:53:12 UTC (rev 40656)
+++ grass/branches/develbranch_6/raster/r.watershed/ram/init_vars.c	2010-01-26 08:56:27 UTC (rev 40657)
@@ -9,8 +9,8 @@
 int init_vars(int argc, char *argv[])
     SHORT r, c;
-    CELL *buf, alt_value, wat_value, asp_value, block_value;
-    DCELL dvalue;
+    CELL *buf, alt_value, asp_value, block_value;
+    DCELL dvalue, wat_value;
     void *elebuf, *ptr;
     int fd, index, ele_map_type;
     size_t ele_size;
@@ -129,6 +129,12 @@
     alt =
 	(CELL *) G_malloc(sizeof(CELL) * size_array(&alt_seg, nrows, ncols));
+    wat =
+	(DCELL *) G_malloc(sizeof(DCELL) *
+			   size_array(&wat_seg, nrows, ncols));
+    asp =
+	(CELL *) G_malloc(size_array(&asp_seg, nrows, ncols) * sizeof(CELL));
     if (er_flag) {
 	r_h =
 	    (CELL *) G_malloc(sizeof(CELL) * size_array(&r_h_seg, nrows, ncols));
@@ -152,6 +158,7 @@
 	ele_scale = 1000; 	/* should be enough to do the trick */
     /* read elevation input and mark NULL/masked cells */
+    /* intialize accumulation and drainage direction */
     MASK_flag = 0;
     do_points = nrows * ncols;
     for (r = 0; r < nrows; r++) {
@@ -170,6 +177,7 @@
 		FLAG_SET(worked, r, c);
 		FLAG_SET(in_list, r, c);
 		G_set_c_null_value(&alt_value, 1);
+		G_set_d_null_value(&wat_value, 1);
 		do_points--;
 	    else {
@@ -186,8 +194,11 @@
 		    dvalue *= ele_scale;
 		    alt_value = ele_round(dvalue);
+		wat_value = 1.0;
 	    alt[index] = alt_value;
+	    wat[index] = wat_value;
+	    asp[index] = 0;
 	    if (er_flag) {
 		r_h[index] = alt_value;
@@ -199,14 +210,9 @@
     if (do_points < nrows * ncols)
 	MASK_flag = 1;
-    /* initialize flow accumulation ... */
-    wat =
-	(DCELL *) G_malloc(sizeof(DCELL) *
-			   size_array(&wat_seg, nrows, ncols));
+    /* read flow accumulation from input map flow: amount of overland flow per cell */
     buf = G_allocate_cell_buf();
     if (run_flag) {
-	/* ... with input map flow: amount of overland flow per cell */
 	fd = G_open_cell_old(run_name, "");
 	if (fd < 0) {
 	    G_fatal_error(_("unable to open runoff map layer"));
@@ -227,22 +233,6 @@
 	G_close_cell(fd);
-    else {
-	/* ... with 1.0 */
-	for (r = 0; r < nrows; r++) {
-	    for (c = 0; c < ncols; c++) {
-		if (MASK_flag) {
-		    index = FLAG_GET(worked, r, c);
-		    if (!index)
-			wat[SEG_INDEX(wat_seg, r, c)] = 1.0;
-		else
-    asp =
-	(CELL *) G_malloc(size_array(&asp_seg, nrows, ncols) * sizeof(CELL));
     /* depression: drainage direction will be set to zero later */
     if (pit_flag) {
