[GRASS-SVN] r40690 - in grass/branches/develbranch_6/scripts: v.in.garmin v.in.gpsbabel v.in.lines v.in.wfs v.out.gpsbabel v.rast.stats v.univar.sh
Wed Jan 27 00:12:21 EST 2010
Author: hamish
Date: 2010-01-27 00:12:20 -0500 (Wed, 27 Jan 2010)
New Revision: 40690
   grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
   grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
   grass/branches/develbranch_6/scripts/v.in.lines/v.in.lines
   grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs
   grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel
   grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
   grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh
rename TMP variable to avoid namespace collision on MS Windows (trac #890)
Modified: grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
--- grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin	2010-01-27 04:48:40 UTC (rev 40689)
+++ grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin	2010-01-27 05:12:20 UTC (rev 40690)
@@ -142,14 +142,14 @@
 #### setup temporary file
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
     g.message -e "Unable to create temporary files"
     exit 1
 fi
 #### trap ctrl-c so that we can clean up tmp
-trap 'rm -f "${TMP}"*' 2 3 15
+trap 'rm -f "${TEMPFILE}"*' 2 3 15
 #### process command line arguments
@@ -180,7 +180,7 @@
 if [ "`expr $GIS_FLAG_W + $GIS_FLAG_R + $GIS_FLAG_T`" -gt 1 ] ; then
     g.message -e "One feature at a time please. Use v.patch if you need to combine them."
-    rm -f "$TMP"
+    rm -f "$TEMPFILE"
     exit 1
 fi
@@ -207,13 +207,13 @@
 if [ "`expr $WPT + $TRK + $RTE`" -eq 0 ] ; then
     g.message -e "Must request either waypoints, route, or track."
-    rm -f "$TMP"
+    rm -f "$TEMPFILE"
     exit 1
 fi
 if [ $GIS_FLAG_Z -eq 1 ] &&  [ $TRK -ne 1 ] ; then
     g.message -e "3D import is only supported for tracks so far"
-    rm -f "$TMP"
+    rm -f "$TEMPFILE"
     exit 1
 fi
@@ -224,7 +224,7 @@
     gpstrans "$GPSPORT" -i 1> /dev/null
     if [ $? -ne 0 ] ; then
 	g.message -e message="Receiver on $GIS_OPT_PORT not responding, exiting"
-	rm -f "$TMP"
+	rm -f "$TEMPFILE"
 	exit 1
     fi
 elif [ $VERBOSE -eq 1 ] ; then
@@ -233,7 +233,7 @@
     gardump -u -p "$GIS_OPT_PORT" 1>&2
-	rm -f "$TMP"
+	rm -f "$TEMPFILE"
 	exit 1
     fi
     g.message "GPS connection ok"
@@ -245,7 +245,7 @@
 PROJ_TYPE=`g.region -p | grep 'projection' | cut -f2 -d" "`
 if [ $PROJ_TYPE -eq 0 ] && [ $KEEP_WGS84 -ne 1 ] ; then
     g.message -e "Cannot project to a XY location."
-    rm -f "$TMP"
+    rm -f "$TEMPFILE"
     exit 1
 fi
@@ -254,57 +254,57 @@
 if [ $WPT -eq 1 ] ; then
     g.message "Receiving Waypoints..."
     if [ $GIS_FLAG_U -eq 0 ] ; then
-	gpstrans "$GPSPORT" -dw > "$TMP".gpst 2>/dev/null
+	gpstrans "$GPSPORT" -dw > "$TEMPFILE".gpst 2>/dev/null
 	EXITCODE=$?
     else
-	gardump -w -p "$GIS_OPT_PORT" > "$TMP".gard
+	gardump -w -p "$GIS_OPT_PORT" > "$TEMPFILE".gard
 	EXITCODE=$?
     fi
 fi
 if [ $RTE -eq 1 ] ; then
     g.message "Receiving Routes..."
-	gpstrans "$GPSPORT" -dr > "$TMP".gpst 2>/dev/null
+	gpstrans "$GPSPORT" -dr > "$TEMPFILE".gpst 2>/dev/null
 	EXITCODE=$?
     else
-	gardump -r -p "$GIS_OPT_PORT" > "$TMP".gard
+	gardump -r -p "$GIS_OPT_PORT" > "$TEMPFILE".gard
 	EXITCODE=$?
     fi
 fi
 if [ $TRK -eq 1 ] ; then
     g.message "Receiving Tracks..."
-	gpstrans "$GPSPORT" -dt > "$TMP".gpst 2>/dev/null
+	gpstrans "$GPSPORT" -dt > "$TEMPFILE".gpst 2>/dev/null
 	EXITCODE=$?
     else
-	gardump -t -p "$GIS_OPT_PORT" > "$TMP".gard
+	gardump -t -p "$GIS_OPT_PORT" > "$TEMPFILE".gard
 	EXITCODE=$?
     fi
 fi
 #### check success/failure
 if [ "$EXITCODE" -ne 0 ] ; then
     g.message -e "Retrieving data."
-    rm -f "${TMP}"*
+    rm -f "${TEMPFILE}"*
     exit 1
 fi
-    if [ ! -e "${TMP}.gpst" ] || [ `wc -l < "${TMP}.gpst"` -le 1 ] ; then
+    if [ ! -e "${TEMPFILE}.gpst" ] || [ `wc -l < "${TEMPFILE}.gpst"` -le 1 ] ; then
 	g.message -w 'No Data! Exiting.'
-	rm -f "${TMP}"*
 	exit 0
     fi
 else
-    if [ "`cat "${TMP}.gard" | grep -v '^\[' | grep -v '^#' -c`" -eq 0 ] ; then
+    if [ "`cat "${TEMPFILE}.gard" | grep -v '^\[' | grep -v '^#' -c`" -eq 0 ] ; then
-	rm -f "${TMP}"*
 	exit 0
     fi
 fi
     #### check which projection we are working with
-    PROJ="`head -n 1 "${TMP}.gpst" | sed -e 's/Format: //' | sed -e 's/  UTC.*//'`"
+    PROJ="`head -n 1 "${TEMPFILE}.gpst" | sed -e 's/Format: //' | sed -e 's/  UTC.*//'`"
 	g.message message="Coordinate format: ${PROJ}"
     fi
@@ -313,10 +313,10 @@
 	# or DM.MM formatted input and I'm not going to start doing that sort
 	# of math in a shell script.
 	g.message -e message="Only DDD coordinates currently supported. [$PROJ]"
-	rm -f "${TMP}"*
 	exit 1
     fi
-    IS_WGS84="`head -n 1 "$TMP".gpst | grep 'WGS 84'`"
+    IS_WGS84="`head -n 1 "$TEMPFILE".gpst | grep 'WGS 84'`"
 else
     # gardump
     IS_WGS84=TRUE
@@ -331,19 +331,19 @@
         # gpstrans
-	    cat "${TMP}.gpst" | sed -e '1d' | awk -F '\t' '{print $6 " " $5}' > "$TMP".base
-	    cat "${TMP}.gpst" | sed -e '1d' | cut -f1,2,3 | tr '\t' '|' > "$TMP".attributes
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | awk -F '\t' '{print $6 " " $5}' > "$TEMPFILE".base
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | cut -f1,2,3 | tr '\t' '|' > "$TEMPFILE".attributes
 	    ATTR_COLS='x DOUBLE PRECISION, y DOUBLE PRECISION, type VARCHAR(1), name VARCHAR(10), comments VARCHAR(40)'
 	fi
-	    cat "${TMP}.gpst" | sed -e '1d' | grep '^W' | awk -F '\t' '{print $6 " " $5}' > "$TMP".base
-	    cat "${TMP}.gpst" | sed -e '1d' | grep '^W' | cut -f1,2,3 | tr '\t' '|' > "$TMP".attributes
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | grep '^W' | awk -F '\t' '{print $6 " " $5}' > "$TEMPFILE".base
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | grep '^W' | cut -f1,2,3 | tr '\t' '|' > "$TEMPFILE".attributes
 	    ATTR_COLS='x DOUBLE PRECISION, y DOUBLE PRECISION, type VARCHAR(1), name varchar(10), comments VARCHAR(40)'
 	fi
 	    # we use uniq here as gpstrans can dupe up track points !?
-	    uniq "${TMP}.gpst" | sed -e '1d' | grep '^T' | awk -F '\t' '{print $4 " " $3}' > "$TMP".base
-	    uniq "${TMP}.gpst" | sed -e '1d' | grep '^T' | cut -f1,2 | tr '\t' '|' > "$TMP".attributes
+	    uniq "${TEMPFILE}.gpst" | sed -e '1d' | grep '^T' | awk -F '\t' '{print $4 " " $3}' > "$TEMPFILE".base
+	    uniq "${TEMPFILE}.gpst" | sed -e '1d' | grep '^T' | cut -f1,2 | tr '\t' '|' > "$TEMPFILE".attributes
 	    ATTR_COLS='x DOUBLE PRECISION, y DOUBLE PRECISION, type VARCHAR(1), localtime VARCHAR(40)'
 	    HAVE_ALT=FALSE
 	fi
@@ -352,7 +352,7 @@
 	if [ $WPT -eq 1 ] || [ $RTE -eq 1 ] ; then
 	    # **n [route name]
 	    # lat long [A:alt] [S:sym] [D:display] [I:id] [C:cmnt] [W:wpt info] [L:link]
-	    grep -E -v '^\[|^#|^\*\*' "${TMP}.gard" | awk '{print $2 " " $1}' > "$TMP".base
+	    grep -E -v '^\[|^#|^\*\*' "${TEMPFILE}.gard" | awk '{print $2 " " $1}' > "$TEMPFILE".base
 	    ROUTE_NUM=""
 	    ROUTE_NAME=""
@@ -381,11 +381,11 @@
 		fi
-		    echo "$A_VAL|$S_VAL|$D_VAL|$I_VAL|$C_VAL|$W_VAL|$L_VAL" >> "$TMP".attributes
+		    echo "$A_VAL|$S_VAL|$D_VAL|$I_VAL|$C_VAL|$W_VAL|$L_VAL" >> "$TEMPFILE".attributes
 		elif [ $RTE -eq 1 ] ; then
-		    echo "$ROUTE_NUM|$ROUTE_NAME|$A_VAL|$S_VAL|$D_VAL|$I_VAL|$C_VAL|$W_VAL|$L_VAL" >> "$TMP".attributes
+		    echo "$ROUTE_NUM|$ROUTE_NAME|$A_VAL|$S_VAL|$D_VAL|$I_VAL|$C_VAL|$W_VAL|$L_VAL" >> "$TEMPFILE".attributes
 		fi
-	    done < "${TMP}.gard"
+	    done < "${TEMPFILE}.gard"
 		ATTR_COLS='x DOUBLE PRECISION, y DOUBLE PRECISION, altitude DOUBLE PRECISION, symbol INTEGER, smbl_flag INTEGER, name VARCHAR(15), comments VARCHAR(50), poi_code VARCHAR(40), poi_link VARCHAR(4)'
@@ -398,24 +398,24 @@
 	    # [yyyy-mm-dd hh:mm:ss] lat long [alt] [start]
 	    unset HAVE_ALT
 	    # some tracks don't have time/date, so we have to decide on the fly
-	    grep -v '^\[\|^#\|^Track:' "${TMP}.gard" | \
+	    grep -v '^\[\|^#\|^Track:' "${TEMPFILE}.gard" | \
 	      awk '{ if ( $0 ~ /..:..:../) {
 			print $4 " " $3
 		     } else {
 			print $2 " " $1
-		   }' > "$TMP".base
+		   }' > "$TEMPFILE".base
 			print $1 "|" $2 "|" $5 "|" $6
 		     } else {
 			print "||" $3 "|" $4
-		   }' > "$TMP.attr"
+		   }' > "$TEMPFILE.attr"
 	    # check if there is any altitude data
-	    if [ `cut -f3 -d'|' "$TMP.attr" | grep -c 'start'` -ge 1 ] ; then
+	    if [ `cut -f3 -d'|' "$TEMPFILE.attr" | grep -c 'start'` -ge 1 ] ; then
 		HAVE_ALT=FALSE
 		ATTR_COLS='x DOUBLE PRECISION, y DOUBLE PRECISION, gmt_date VARCHAR(10), gmt_time VARCHAR(8), new_track VARCHAR(5)'
 		if [ $GIS_FLAG_Z -eq 1 ] ; then
@@ -427,17 +427,17 @@
 	    fi
 	    # check if there is any track name data
-	    if [ `grep -c '^Track:' "${TMP}.gard"` -ge 1 ] ; then
+	    if [ `grep -c '^Track:' "${TEMPFILE}.gard"` -ge 1 ] ; then
 		ATTR_COLS="$ATTR_COLS, track_name VARCHAR(15)"
 		# create data for track name column
 # need extra if(TRK) else NULL stuff for v.in.ascii empty last column bug
-		grep -v '^\[\|^#' "${TMP}.gard" | awk \
+		grep -v '^\[\|^#' "${TEMPFILE}.gard" | awk \
 		  '/^Track:/ {TRK=$0; sub(/^Track: /, "", TRK)} ;
-		   /^[-0-9]/ {if(TRK) {print TRK} else {print "NULL"}}' > "$TMP.trackname"
-		paste -d'|' "$TMP.attr" "$TMP.trackname"  > "$TMP.attributes"
+		   /^[-0-9]/ {if(TRK) {print TRK} else {print "NULL"}}' > "$TEMPFILE.trackname"
+		paste -d'|' "$TEMPFILE.attr" "$TEMPFILE.trackname"  > "$TEMPFILE.attributes"
 	    else
-		cp "$TMP.attr" "$TMP.attributes"
+		cp "$TEMPFILE.attr" "$TEMPFILE.attributes"
 	    fi
 	fi
     fi
@@ -445,13 +445,13 @@
     #### reproject if needed (only consider 2D)
     if [ -z "$IS_WGS84" ] || [ $KEEP_WGS84 -eq 1 ] ; then
 	g.message "No projection transformation performed"
-	cp "${TMP}.base" "${TMP}.P_base"
+	cp "${TEMPFILE}.base" "${TEMPFILE}.P_base"
     else
 	g.message "Attempting waypoint projection transform with cs2cs..."
-	cs2cs -f %.7f $IN_PROJ +to $OUT_PROJ < "${TMP}.base" > "${TMP}.P_base"
+	cs2cs -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_base"
 	EXITCODE=$?
 	# check if transform REALLY worked (e.g. grid file not found)
-	BAD_PTS="`grep -c "^\*" "${TMP}.P_base"`"
+	BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_base"`"
 	if [ "$BAD_PTS" -gt 0 ] ; then
 	    g.message message=""
 	    g.message -w "$BAD_PTS point(s) failed reprojection."
@@ -460,46 +460,46 @@
 	if [ $EXITCODE -ne 0 ] ; then
 	    g.message -w "Projection transform failed, retaining WGS84"
-	    cp -f "${TMP}.base" "${TMP}.P_base"
+	    cp -f "${TEMPFILE}.base" "${TEMPFILE}.P_base"
 	fi
     fi
-    cat "${TMP}.P_base" | awk '{print $1 "|" $2}' > "${TMP}.vertices"
+    cat "${TEMPFILE}.P_base" | awk '{print $1 "|" $2}' > "${TEMPFILE}.vertices"
     #### and put back together
     # wpt list:   x|y|    W   MOB    04-OCT-03 08:07
-    paste -d"|" "$TMP".vertices "$TMP".attributes > "$TMP".asc
+    paste -d"|" "$TEMPFILE".vertices "$TEMPFILE".attributes > "$TEMPFILE".asc
     if [ -z "$NAME" ] ; then
 	g.message "ASCII file redirected to stdout"
-	cat "${TMP}.asc" 2> /dev/null
+	cat "${TEMPFILE}.asc" 2> /dev/null
     else
 	#### import into new ascii points file
 	    g.message "Importing Waypoints..."
-	    v.in.ascii input="${TMP}.asc" output="$NAME" cat=0 columns="$ATTR_COLS" --quiet
+	    v.in.ascii input="${TEMPFILE}.asc" output="$NAME" cat=0 columns="$ATTR_COLS" --quiet
 	    EXITCODE=$?
 	fi
 	    g.message "Importing Routes as points..."
 	    EXITCODE=$?
 	fi
 	    if [ $GIS_FLAG_Z -eq 1 ] && [ "$HAVE_ALT" = "TRUE" ] ; then
 		g.message "Importing Track as 3D points..."
-		v.in.ascii input="${TMP}.asc" output="$NAME" cat=0 columns="$ATTR_COLS" -z z=5
+		v.in.ascii input="${TEMPFILE}.asc" output="$NAME" cat=0 columns="$ATTR_COLS" -z z=5
 		EXITCODE=$?
 	    else
 		g.message "Importing Track as points..."
 		EXITCODE=$?
 	    fi
 	fi
 	    g.message -e "While importing data with v.in.ascii"
-	    rm -f "${TMP}"*
 	    exit 1
 	fi
@@ -515,32 +515,32 @@
 	#### prepare line components
 	    # add vertex counts
-	    cat "${TMP}.gpst" | sed -e '1d' | tac | awk 'BEGIN { FS="\t" ; R=0 } \
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | tac | awk 'BEGIN { FS="\t" ; R=0 } \
 		$1=="W" { printf(" %.7f %.7f\n", $6, $5) ; ++R } ; \
-		$1=="R" { printf("L %d 1\n", R) ; R=0 } END {;}' | tac > "${TMP}.base"
+		$1=="R" { printf("L %d 1\n", R) ; R=0 } END {;}' | tac > "${TEMPFILE}.base"
 	    # create attr table: cat(int), id number(int 0-19), name varchar(16+), starting_wpt(varchar 10)
-	    cat "${TMP}.gpst" | grep '^R' | cut -f2,3 | grep -n '^' | \
-		sed -e 's/:/\t/' > "${TMP}.route_ids"
-	    cat "${TMP}.gpst" | sed -e '1d' | grep '^R' -A 1 | grep '^W' | cut -f2 > "${TMP}.route_start"
-	    paste "${TMP}.route_ids" "${TMP}.route_start" > "${TMP}.route_atts"
-	    ATTR_FILE="${TMP}.route_atts"
+	    cat "${TEMPFILE}.gpst" | grep '^R' | cut -f2,3 | grep -n '^' | \
+		sed -e 's/:/\t/' > "${TEMPFILE}.route_ids"
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | grep '^R' -A 1 | grep '^W' | cut -f2 > "${TEMPFILE}.route_start"
+	    paste "${TEMPFILE}.route_ids" "${TEMPFILE}.route_start" > "${TEMPFILE}.route_atts"
+	    ATTR_FILE="${TEMPFILE}.route_atts"
 	    ATTR_COLS='cat INT, route_id INT, name VARCHAR(20), start_wpt VARCHAR(10)'
 	elif [ $TRK -eq 1 ] ; then
 	    # add vertex counts
 		$1=="T" { printf(" %.7f %.7f\n", $4, $3) ; ++R } ; \
-		$1=="" { printf("L %d 1\n", R) ; R=0 } END {;}' | tac > "${TMP}.base"
+		$1=="" { printf("L %d 1\n", R) ; R=0 } END {;}' | tac > "${TEMPFILE}.base"
 	    # create attr table: cat(int), start_time varchar(40), start_lat(double precision), start_lon(double precision), \
 	    #			    end_time varchar(40), end_lat(double precision), end_lon(double precision)
-	    cat "${TMP}.gpst" | sed -e '1d' | grep '^$' -B 1 | grep '^T' | cut -f2,3,4 > "${TMP}.end_time"
-	    cat "${TMP}.gpst" | grep '^T' | tail -n 1 | cut -f2,3,4 >> "${TMP}.end_time"
-	    cat "${TMP}.gpst" | sed -e '1d' | grep '^$' -A 1 | grep '^T' | cut -f2,3,4 | \
-		grep -n '^' | sed -e 's/:/\t/'  > "${TMP}.start_time"
-	    paste "${TMP}.start_time" "${TMP}.end_time" > "${TMP}.track_atts"
-	    ATTR_FILE="${TMP}.track_atts"
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | grep '^$' -B 1 | grep '^T' | cut -f2,3,4 > "${TEMPFILE}.end_time"
+	    cat "${TEMPFILE}.gpst" | grep '^T' | tail -n 1 | cut -f2,3,4 >> "${TEMPFILE}.end_time"
+	    cat "${TEMPFILE}.gpst" | sed -e '1d' | grep '^$' -A 1 | grep '^T' | cut -f2,3,4 | \
+		grep -n '^' | sed -e 's/:/\t/'  > "${TEMPFILE}.start_time"
+	    paste "${TEMPFILE}.start_time" "${TEMPFILE}.end_time" > "${TEMPFILE}.track_atts"
+	    ATTR_FILE="${TEMPFILE}.track_atts"
 	    ATTR_COLS='cat INT, start_time VARCHAR(40), start_lat DOUBLE PRECISION, start_lon DOUBLE PRECISION, end_time VARCHAR(40), end_lat DOUBLE PRECISION, end_lon DOUBLE PRECISION'
 	fi
@@ -548,27 +548,27 @@
 	# gardump
 	    # add vertex counts
-	    grep -v '^\[\|^#' "${TMP}.gard" | tac | awk 'BEGIN { R=0 } \
+	    grep -v '^\[\|^#' "${TEMPFILE}.gard" | tac | awk 'BEGIN { R=0 } \
 		/^[-0-9]/ { printf(" %.7f %.7f\n", $2, $1) ; ++R } ; \
-		/^\*\*/ { printf("L %d 1\n", R) ; R=0 } END {;}' | tac > "${TMP}.base"
+		/^\*\*/ { printf("L %d 1\n", R) ; R=0 } END {;}' | tac > "${TEMPFILE}.base"
 	    # create attr table: cat(int), id number(int 0-19), name varchar(40), starting_wpt(varchar 15)
 	    # grep -n is to insert cat number, starting from 1. (route numbers start from 0)
-	    grep '^\*\*' "${TMP}.gard" | sed -e 's/^\*\*//' -e 's/ /|/' \
-	       | grep -n '^' | sed -e 's/:/|/' > "${TMP}.route_ids"
+	    grep '^\*\*' "${TEMPFILE}.gard" | sed -e 's/^\*\*//' -e 's/ /|/' \
+	       | grep -n '^' | sed -e 's/:/|/' > "${TEMPFILE}.route_ids"
-	    grep -A 1 '^\*\*' "${TMP}.gard" | grep -E -v '^\*\*|^--' | \
-	      sed -e 's/.* I://' | awk '{print $1}' > "${TMP}.route_start"
+	    grep -A 1 '^\*\*' "${TEMPFILE}.gard" | grep -E -v '^\*\*|^--' | \
+	      sed -e 's/.* I://' | awk '{print $1}' > "${TEMPFILE}.route_start"
-	    paste -d'|' "${TMP}.route_ids" "${TMP}.route_start" > "${TMP}.route_atts"
+	    paste -d'|' "${TEMPFILE}.route_ids" "${TEMPFILE}.route_start" > "${TEMPFILE}.route_atts"
 	    ATTR_COLS='cat int, route_id INT, name VARCHAR(40), start_wpt VARCHAR(15)'
 	    # add vertex counts
-	    grep -v '^\[\|^#\|^Track:' "${TMP}.gard" | tac | awk 'BEGIN { R=0 } \
+	    grep -v '^\[\|^#\|^Track:' "${TEMPFILE}.gard" | tac | awk 'BEGIN { R=0 } \
 	    ! /start/ {
 	      if($0 ~ /..:..:../ ) { printf(" %.7f %.7f\n", $4, $3) }
 	      else { printf(" %.7f %.7f\n", $2, $1) }
@@ -580,7 +580,7 @@
 	      else { printf(" %.7f %.7f\nL %d 1\n", $2, $1, R+1) }
 	      R=0
-	    END {;}' | tac > "${TMP}.base"
+	    END {;}' | tac > "${TEMPFILE}.base"
 	    # create attr table: cat(int), \
 	    #  start_time varchar(40), start_lat(double precision), start_lon(double precision), \
@@ -592,16 +592,16 @@
 	    # - use grep -n to add "line number: string" for cat as track nums start as 0
 	    # crop out start times
-	    grep 'start$' "${TMP}.gard" | \
+	    grep 'start$' "${TEMPFILE}.gard" | \
 	      awk '{ if ( $0 ~ /..:..:../ ) {
 			print $1 "T" $2 "Z|" $3 "|" $4
 		     } else {
 			print "|" $1 "|" $2
-		   }' | grep -n '^' | sed -e 's/:/|/' > "${TMP}.start_time"
+		   }' | grep -n '^' | sed -e 's/:/|/' > "${TEMPFILE}.start_time"
 	    # find and crop out end times. if only 1 pt in trk, use start as end time
-	    grep -v '^#\|^\[\|^Track:' "${TMP}.gard" | grep -B 1 'start$' | \
+	    grep -v '^#\|^\[\|^Track:' "${TEMPFILE}.gard" | grep -B 1 'start$' | \
 	      grep -v '^--' | awk 'BEGIN { FIRST=1 } \
 		/start/ {
 		  if (FIRST != 1) { print TIME "|" LAT "|" LON } else { FIRST=0 } ;
@@ -617,49 +617,49 @@
 		  } else {
 		    TIME=""; LAT=$1; LON=$2
-		}' > "${TMP}.end_time"
+		}' > "${TEMPFILE}.end_time"
 	    # get time & coord of final point
-	    grep -B 1 'end transfer' "${TMP}.gard" | grep '^[0-9]' | awk \
+	    grep -B 1 'end transfer' "${TEMPFILE}.gard" | grep '^[0-9]' | awk \
 		  } else {
 		    print "|" $1 "|" $2
-		}' >> "${TMP}.end_time"
+		}' >> "${TEMPFILE}.end_time"
 	    unset HAVE_TRACK_NAME
 		HAVE_TRACK_NAME=TRUE
 		# extract data for track name column
-		grep -v '^\[\|^#' "${TMP}.gard" | grep '^Track:\|start' | awk \
+		grep -v '^\[\|^#' "${TEMPFILE}.gard" | grep '^Track:\|start' | awk \
-		   /^[-0-9]/ {print TRK}' > "$TMP.trackname"
-		paste -d'|' "${TMP}.start_time" "${TMP}.end_time" "$TMP.trackname" > "${TMP}.track_atts"
+		   /^[-0-9]/ {print TRK}' > "$TEMPFILE.trackname"
+		paste -d'|' "${TEMPFILE}.start_time" "${TEMPFILE}.end_time" "$TEMPFILE.trackname" > "${TEMPFILE}.track_atts"
 	    else
 		HAVE_TRACK_NAME=FALSE
-		paste -d'|' "${TMP}.start_time" "${TMP}.end_time" > "${TMP}.track_atts"
+		paste -d'|' "${TEMPFILE}.start_time" "${TEMPFILE}.end_time" > "${TEMPFILE}.track_atts"
 	    fi
 	fi
     fi
-	cat "${TMP}.base" | awk 'BEGIN {;} $1=="L" { print } ; \
-	    $1!="L" { printf(" %.7f %.7f\n", $1, $2) } END {;}' > "${TMP}.P_base"
+	cat "${TEMPFILE}.base" | awk 'BEGIN {;} $1=="L" { print } ; \
+	    $1!="L" { printf(" %.7f %.7f\n", $1, $2) } END {;}' > "${TEMPFILE}.P_base"
     else
-	cs2cs -tL -f %.7f $IN_PROJ +to $OUT_PROJ < "${TMP}.base" > "${TMP}.P_mid"
+	cs2cs -tL -f %.7f $IN_PROJ +to $OUT_PROJ < "${TEMPFILE}.base" > "${TEMPFILE}.P_mid"
 	EXITCODE=$?
-	BAD_PTS="`grep -c "^\*" "${TMP}.P_mid"`"
+	BAD_PTS="`grep -c "^\*" "${TEMPFILE}.P_mid"`"
 	    g.message -w "$BAD_PTS vertices failed reprojection."
@@ -668,24 +668,24 @@
 	else
-	    cat "${TMP}.P_mid" | awk 'BEGIN {;} $1=="L" { print } ; \
+	    cat "${TEMPFILE}.P_mid" | awk 'BEGIN {;} $1=="L" { print } ; \
 	fi
     fi
     # add category numbers
-    cat "${TMP}.P_base" | awk 'BEGIN { FS=" " ; R=0 } \
+    cat "${TEMPFILE}.P_base" | awk 'BEGIN { FS=" " ; R=0 } \
 	$1=="L" { printf(" 1 %d\nL %d 1\n", R, $2) ; ++R } ; \
-	$1!="L" { print } END { printf(" 1 %d\n", R) }' | sed -e '1d' > "${TMP}.P_baseC"
+	$1!="L" { print } END { printf(" 1 %d\n", R) }' | sed -e '1d' > "${TEMPFILE}.P_baseC"
     # add z for 3D maps
     unset HAVE_ALT
-	if [ `grep -v '^\[\|^#\|^Track:' "${TMP}.gard" | tr -s ' ' '|' | cut -f6 -d'|' | grep -c start` -ge 1 ] ; then
+	if [ `grep -v '^\[\|^#\|^Track:' "${TEMPFILE}.gard" | tr -s ' ' '|' | cut -f6 -d'|' | grep -c start` -ge 1 ] ; then
 	    HAVE_ALT=TRUE
 	else
 	    HAVE_ALT=FALSE
@@ -699,28 +699,28 @@
     if [ "$HAVE_ALT" = "TRUE" ] ; then
 	# cut out altitude data and add blank lines between track lines
-	grep -v '^\[\|^#\|^Track:' "${TMP}.gard" | tac | \
+	grep -v '^\[\|^#\|^Track:' "${TEMPFILE}.gard" | tac | \
 	  awk '{ if($0 ~ /..:..:../ ) {
 		   print $5 " " $6
 		 } else {
 		   print $3 " " $4
-	       }' | sed -e 's/ start/\n/' -e 's/ $//' | tac > "${TMP}.alt"
+	       }' | sed -e 's/ start/\n/' -e 's/ $//' | tac > "${TEMPFILE}.alt"
-	paste -d' ' "${TMP}.P_base" "${TMP}.alt" > "${TMP}.P_baseZ"
+	paste -d' ' "${TEMPFILE}.P_base" "${TEMPFILE}.alt" > "${TEMPFILE}.P_baseZ"
     else
-	cp "${TMP}.P_base" "${TMP}.P_baseZ"
+	cp "${TEMPFILE}.P_base" "${TEMPFILE}.P_baseZ"
     fi
-    cat "${TMP}.P_baseZ" | awk 'BEGIN { FS=" " ; R=0 } \
+    cat "${TEMPFILE}.P_baseZ" | awk 'BEGIN { FS=" " ; R=0 } \
 	$1!="L" { print } END { printf(" 1 %d\n", R) }' | sed -e '1d' \
-	  > "${TMP}.P_baseC"
+	  > "${TEMPFILE}.P_baseC"
     #### create digit header
-    cat << EOF > "${TMP}.dig"
+    cat << EOF > "${TEMPFILE}.dig"
 ORGANIZATION: GRASSroots organization
 DIGIT DATE:   `date "+%Y/%m/%d"`
 DIGIT NAME:   $PROG
@@ -734,12 +734,12 @@
 EOF
     #### merge in vertices
-    cat "${TMP}.P_baseC" >> "${TMP}.dig"
+    cat "${TEMPFILE}.P_baseC" >> "${TEMPFILE}.dig"
     #### if no name for vector file given, cat to stdout
-	cat "${TMP}.dig" 2> /dev/null
+	cat "${TEMPFILE}.dig" 2> /dev/null
     else
 	#### import to binary vector file
@@ -749,14 +749,14 @@
 	fi
 	g.message "Importing with v.in.ascii..."
-	v.in.ascii format=standard output="$NAME" input="${TMP}.dig" $ZFLAG
+	v.in.ascii format=standard output="$NAME" input="${TEMPFILE}.dig" $ZFLAG
 	if [ $? -eq 0 ] ; then
 	    g.message -v message="Line vector <$NAME> successfully created"
 	else
 	    g.message -e "An error occured creating <$NAME>, please check"'!'
-	    rm -f "${TMP}"*
 	    exit 1
 	fi
@@ -771,7 +771,7 @@
 	echo "CREATE TABLE $NAME ($ATTR_COLS)" | db.execute
 	    g.message -e "Map created but failed to create database table."
-	    rm -f "${TMP}"*
 	    exit 1
 	fi
@@ -810,7 +810,7 @@
 	    # need to connect it before we can delete it. :-/
 	    v.db.connect map="$NAME" table="$NAME" 2> /dev/null
 	    v.db.droptable -f map=$NAME --quiet
-	    rm -f "${TMP}"*
 	    exit 1
 	fi
 ### </hack>
@@ -832,7 +832,7 @@
 v.support map="$NAME" cmdhist="${CMDLINE}"
 #### clean up the mess
-\rm -f "${TMP}"*
+\rm -f "${TEMPFILE}"*
 #### end
 g.message "Done."
Modified: grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
--- grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel	2010-01-27 04:48:40 UTC (rev 40689)
+++ grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel	2010-01-27 05:12:20 UTC (rev 40690)
@@ -136,14 +136,14 @@
 fi
 #### set temporary files
     exit 1
 fi
-trap 'rm -f "${TMP}."*' 2 3 15
+trap 'rm -f "${TEMPFILE}."*' 2 3 15
@@ -171,13 +171,13 @@
 if [ $GIS_FLAG_W -eq 1 ] && ([ $GIS_FLAG_R -eq 1 ] || [ $GIS_FLAG_T -eq 1 ]) ; then
-    rm -f "${TMP}"
     exit 1
 fi
 # logic eludes me at pressent..  [combine with above]
 if [ $GIS_FLAG_R -eq 1 ] && [ $GIS_FLAG_T -eq 1 ] ; then
-    rm -f "${TMP}"
     exit 1
 fi
@@ -221,7 +221,7 @@
-    rm -f "${TMP}"
     exit 1
 fi
@@ -251,12 +251,12 @@
     fi
     gpsbabel $TYPE -i $GIS_OPT_FORMAT -f "$GPSdevice" $PROGVERBOSE \
-	-o xcsv,style="$STYLE" -F "$TMP".xcsv
+	-o xcsv,style="$STYLE" -F "$TEMPFILE".xcsv
     EXITCODE=$?
-    if [ "`wc -l < "${TMP}.xcsv"`" -eq 0 ] ; then
+    if [ "`wc -l < "${TEMPFILE}.xcsv"`" -eq 0 ] ; then
 	g.message -w 'No data! Exiting.'
-	rm -f "${TMP}."*
+	rm -f "${TEMPFILE}."*
 	exit 0
     fi
@@ -271,14 +271,14 @@
 	EXITCODE=$?
     fi
-	-o gpx -F "$TMP".gpx
+	-o gpx -F "$TEMPFILE".gpx
     EXITCODE=$?
     if [ $EXITCODE -eq 0 ] && \
-       [ "`grep -c '<rte>' "${TMP}.gpx"`" -eq 0 ] && \
-       [ "`grep -c '<trk>' "${TMP}.gpx"`" -eq 0 ] ; then
+       [ "`grep -c '<rte>' "${TEMPFILE}.gpx"`" -eq 0 ] && \
+       [ "`grep -c '<trk>' "${TEMPFILE}.gpx"`" -eq 0 ] ; then
 	g.message -e 'No data! Exiting.'
-	rm -f "${TMP}."*
 	exit 0
     fi
 fi
@@ -286,7 +286,7 @@
     g.message -e "Error loading data from gpsbabel"
-    rm -f "${TMP}."*
     exit 1
 fi
@@ -295,25 +295,25 @@
 if [ $CREATE_POINTS -eq 1 ] ; then
-    cat "${TMP}.xcsv" | cut -f 1,2 -d '|'| tr '|' ' '  > "$TMP".base
+    cat "${TEMPFILE}.xcsv" | cut -f 1,2 -d '|'| tr '|' ' '  > "$TEMPFILE".base
 # FIXME: if last field (comments) is empty it causes a not-enough fields error in v.in.ascii
 # FIXME: if altitude column is empty (1st attr) v.in.ascii complains as the column type is defined as 'double'
-    cat "${TMP}.xcsv" | tr '+' '|' | cut -f3,4,5,6 -d '|' | \
+    cat "${TEMPFILE}.xcsv" | tr '+' '|' | cut -f3,4,5,6 -d '|' | \
 	sed -e 's/-99999999.000000//' -e 's/|$/|_/' \
 	    -e 's/01\/01\/1970|00:00:00 AM/|/' \
-	    -e 's/^|/-9999|/'> "$TMP".attributes
+	    -e 's/^|/-9999|/'> "$TEMPFILE".attributes
     if [ "$IN_PROJ" = "$OUT_PROJ" ] || [ $KEEP_WGS84 -eq 1 ] ; then
     else
 	g.message "Attempting waypoint projection transform with cs2cs"
 	EXITCODE=$?
 	# check if transform REALLY worked (e.g. when the grid file is not found)
@@ -322,20 +322,20 @@
 	fi
     fi
     # wpt list:   x|y|<attr1>|...|<attr n>
     #### output or import
     else
 	#### import into new points file
@@ -346,14 +346,14 @@
 	    g.message "Importing Tracks as points..."
 	fi
-	v.in.ascii in="${TMP}.asc" output="$NAME" cat=0 \
+	v.in.ascii in="${TEMPFILE}.asc" output="$NAME" cat=0 \
 	  columns='x double precision, y double precision, altitude double precision, gmt_date varchar(10), gmt_time varchar(11), comments varchar(40)'
 	EXITCODE=$?
 	# EXITCODE also used at pgm termination below!
 	    g.message -e "While Importing data with v.in.ascii"
-	    rm -f "${TMP}"*
 	    exit 1
 	fi
     fi
@@ -370,51 +370,51 @@
 	# if someone has any suggest please mail!!!!
 	# list of bytes where routes finish
-	cat "$TMP.gpx" | grep -n "</rte>" > "$TMP.bytes"
+	cat "$TEMPFILE.gpx" | grep -n "</rte>" > "$TEMPFILE.bytes"
 	# number of routes
-	cat "$TMP.bytes" | grep -c "</rte>" > "$TMP.var"
+	cat "$TEMPFILE.bytes" | grep -c "</rte>" > "$TEMPFILE.var"
 	ROUTE_NUMBER=0
-	read ROUTE_NUMBER < "$TMP.var" # route number to process
+	read ROUTE_NUMBER < "$TEMPFILE.var" # route number to process
 	READ_BYTES=0 # offset of bytes already read
-	cp "$TMP.gpx" "$TMP.gpx2" # file to be "eaten" by head commands in while
+	cp "$TEMPFILE.gpx" "$TEMPFILE.gpx2" # file to be "eaten" by head commands in while
 	ROUTE_ID=0 # route identifier
 	while [ "$ROUTE_NUMBER" -gt 0 ] ; do
-	    head -n 1 "$TMP.bytes" | cut -f 1 -d ':'> "$TMP.var"
+	    head -n 1 "$TEMPFILE.bytes" | cut -f 1 -d ':'> "$TEMPFILE.var"
 	    END_BYTE=0
-	    read END_BYTE < "$TMP.var" # this route ends at END_BYTE in $TMP.gpx file
+	    read END_BYTE < "$TEMPFILE.var" # this route ends at END_BYTE in $TEMPFILE.gpx file
 	    TO_READ=0
-	    TO_READ="`expr $END_BYTE - $READ_BYTES`"    # bytes to read from $TMP.gpx2 file
+	    TO_READ="`expr $END_BYTE - $READ_BYTES`"    # bytes to read from $TEMPFILE.gpx2 file
 	    READ_BYTES="`expr $READ_BYTES + $TO_READ`"  # update readed bytes
 	    # list of points in route
-	    head -n $TO_READ "$TMP.gpx2" | grep "<rtept" > "$TMP.points"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | grep "<rtept" > "$TEMPFILE.points"
 	    POINTS=0 # number of points in route
-	    cat "$TMP.points" | grep -c "<rtept" > "$TMP.var"
-	    read POINTS < "$TMP.var"
-	    echo "L $POINTS 1" >> "$TMP.base"
+	    cat "$TEMPFILE.points" | grep -c "<rtept" > "$TEMPFILE.var"
+	    read POINTS < "$TEMPFILE.var"
+	    echo "L $POINTS 1" >> "$TEMPFILE.base"
 	    # read lat lon data
-	    cat "$TMP.points" | cut -f2 -d'<' | cut -f2,3 -d ' ' | cut -f2,4 -d '"' | tr '"' '\t' > "$TMP.latlon"
-	    cat "$TMP.latlon" | tr ',' '.' | awk '{printf(" %s %s\n", $2, $1) }' >> "$TMP.base"
+	    cat "$TEMPFILE.points" | cut -f2 -d'<' | cut -f2,3 -d ' ' | cut -f2,4 -d '"' | tr '"' '\t' > "$TEMPFILE.latlon"
+	    cat "$TEMPFILE.latlon" | tr ',' '.' | awk '{printf(" %s %s\n", $2, $1) }' >> "$TEMPFILE.base"
 	    # create attribute line
-	    head -n $TO_READ "$TMP.gpx2" | grep -n "<rtept" | head -n 1 | cut -f1 -d ':' > "$TMP.var"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | grep -n "<rtept" | head -n 1 | cut -f1 -d ':' > "$TEMPFILE.var"
 	    OFFSET=0
-	    read OFFSET < "$TMP.var"
-	    head -n $OFFSET "$TMP.gpx2" > "$TMP.rte_attr"
+	    read OFFSET < "$TEMPFILE.var"
+	    head -n $OFFSET "$TEMPFILE.gpx2" > "$TEMPFILE.rte_attr"
 	    # read needed attributes
 	    ROUTE_ID="`expr $ROUTE_ID + 1`"
-	    cat "$TMP.rte_attr"| grep "<number" | tail -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TMP.var"
+	    cat "$TEMPFILE.rte_attr"| grep "<number" | tail -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TEMPFILE.var"
 	    NUMBER=0
-	    read NUMBER < "$TMP.var" # read the route number
-	    cat "$TMP.rte_attr"| grep "<name" | tail -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TMP.var"
+	    read NUMBER < "$TEMPFILE.var" # read the route number
+	    cat "$TEMPFILE.rte_attr"| grep "<name" | tail -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TEMPFILE.var"
 	    R_NAME=""
-	    read R_NAME < "$TMP.var" # read the route name
+	    read R_NAME < "$TEMPFILE.var" # read the route name
 	    OFFSET="`expr $TO_READ - $OFFSET`"
-	    head -n $TO_READ "$TMP.gpx2" | tail -n $OFFSET | grep "<name" | head -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TMP.var"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | tail -n $OFFSET | grep "<name" | head -n 1 | cut -f2 -d'<' | cut -f2 -d'>' > "$TEMPFILE.var"
 	    START_PNT=""
-	    read START_PNT < "$TMP.var" # read the name of start point
+	    read START_PNT < "$TEMPFILE.var" # read the name of start point
 	    # check that numberic values don't try and pass an empty string
 ### variable names don't line up with column names ?!
@@ -427,84 +427,84 @@
 		g.message -w "Route $ROUTE_NUMBER: route ID was empty. Bug?"
 	    fi
-	    echo "$ROUTE_ID|$NUMBER|$R_NAME|$START_PNT" >> "$TMP.route_atts"
+	    echo "$ROUTE_ID|$NUMBER|$R_NAME|$START_PNT" >> "$TEMPFILE.route_atts"
 	    ROUTE_NUMBER="`expr $ROUTE_NUMBER - 1`"
 	    # eat files
-	    tail -n $ROUTE_NUMBER "$TMP.bytes" > "$TMP.bytes2"
-	    mv "$TMP.bytes2" "$TMP.bytes"
-	    head -n $TO_READ "$TMP.gpx2" > "$TMP.points"
+	    tail -n $ROUTE_NUMBER "$TEMPFILE.bytes" > "$TEMPFILE.bytes2"
+	    mv "$TEMPFILE.bytes2" "$TEMPFILE.bytes"
+	    head -n $TO_READ "$TEMPFILE.gpx2" > "$TEMPFILE.points"
 	    B_GPX=0
-	    wc -c < "$TMP.gpx2" > "$TMP.var"
-	    read B_GPX < "$TMP.var"
+	    wc -c < "$TEMPFILE.gpx2" > "$TEMPFILE.var"
+	    read B_GPX < "$TEMPFILE.var"
 	    B_PNT=0
-	    wc -c < "$TMP.points" > "$TMP.var"
-	    read B_PNT < "$TMP.var"
+	    wc -c < "$TEMPFILE.points" > "$TEMPFILE.var"
+	    read B_PNT < "$TEMPFILE.var"
 	    TO_READ="`expr $B_GPX - $B_PNT`"
-	    tail -c $TO_READ "$TMP.gpx2" > "$TMP.points"
-	    mv "$TMP.points" "$TMP.gpx2"
+	    tail -c $TO_READ "$TEMPFILE.gpx2" > "$TEMPFILE.points"
+	    mv "$TEMPFILE.points" "$TEMPFILE.gpx2"
 	done
 	ATTR_COLS='cat int, route_id int, name varchar(40), start_wpt varchar(40)'
     fi
 	# list of bytes where tracks finish
-	cat "$TMP.gpx" | grep -n "</trkseg>" > "$TMP.bytes"
+	cat "$TEMPFILE.gpx" | grep -n "</trkseg>" > "$TEMPFILE.bytes"
 	# number of tracks
-	cat "$TMP.bytes" | grep -c "</trkseg>" > "$TMP.var"
+	cat "$TEMPFILE.bytes" | grep -c "</trkseg>" > "$TEMPFILE.var"
 	TRACK_NUMBER=0
-	read TRACK_NUMBER < "$TMP.var" # route number to process
+	read TRACK_NUMBER < "$TEMPFILE.var" # route number to process
 	TRACK_ID=0 # track identifier
 	while [ "$TRACK_NUMBER" -gt 0 ] ; do
 	    END_BYTE=0
 	    TO_READ=0
-	    head -n $TO_READ "$TMP.gpx2" | grep "<trkpt" > "$TMP.points"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | grep "<trkpt" > "$TEMPFILE.points"
 	    POINTS=0 # number of points in track
-	    cat "$TMP.points" | grep -c "<trkpt" > "$TMP.var"
+	    cat "$TEMPFILE.points" | grep -c "<trkpt" > "$TEMPFILE.var"
 	    # read lat lon data
-	    head -n $TO_READ "$TMP.gpx2" | grep -n "<trk" | head -n 1 | cut -f1 -d ':' > "$TMP.var"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | grep -n "<trk" | head -n 1 | cut -f1 -d ':' > "$TEMPFILE.var"
 	    OFFSET=0
 	    S_LAT=""
-	    head -n 1 "$TMP.latlon" | cut -f1 > "$TMP.var"
-	    read S_LAT < "$TMP.var"
+	    head -n 1 "$TEMPFILE.latlon" | cut -f1 > "$TEMPFILE.var"
+	    read S_LAT < "$TEMPFILE.var"
 	    S_LON=""
-	    head -n 1 "$TMP.latlon" | cut -f2 > "$TMP.var"
-	    read S_LON < "$TMP.var"
+	    head -n 1 "$TEMPFILE.latlon" | cut -f2 > "$TEMPFILE.var"
+	    read S_LON < "$TEMPFILE.var"
 	    E_LAT=""
-	    tail -n 1 "$TMP.latlon" | cut -f1 > "$TMP.var"
-	    read E_LAT < "$TMP.var"
+	    tail -n 1 "$TEMPFILE.latlon" | cut -f1 > "$TEMPFILE.var"
+	    read E_LAT < "$TEMPFILE.var"
 	    E_LON=""
-	    tail -n 1 "$TMP.latlon" | cut -f2 > "$TMP.var"
-	    read E_LON < "$TMP.var"
+	    tail -n 1 "$TEMPFILE.latlon" | cut -f2 > "$TEMPFILE.var"
+	    read E_LON < "$TEMPFILE.var"
-	    head -n $TO_READ "$TMP.gpx2" | tail -n $OFFSET | grep "<time" > "$TMP.time"
+	    head -n $TO_READ "$TEMPFILE.gpx2" | tail -n $OFFSET | grep "<time" > "$TEMPFILE.time"
 	    S_TIME=""
-	    head -n 1 "$TMP.time" | cut -f 2 -d'>' | cut -f1 -d'<' > "$TMP.var"
-	    read S_TIME < "$TMP.var"
+	    head -n 1 "$TEMPFILE.time" | cut -f 2 -d'>' | cut -f1 -d'<' > "$TEMPFILE.var"
+	    read S_TIME < "$TEMPFILE.var"
 	    E_TIME=""
-	    tail -n 1 "$TMP.time" | cut -f 2 -d'>' | cut -f1 -d'<' > "$TMP.var"
-	    read E_TIME < "$TMP.var"
+	    tail -n 1 "$TEMPFILE.time" | cut -f 2 -d'>' | cut -f1 -d'<' > "$TEMPFILE.var"
+	    read E_TIME < "$TEMPFILE.var"
 	    TRACK_ID="`expr $TRACK_ID + 1`"
@@ -530,31 +530,31 @@
 		g.message -w "Track $TRACK_NUMBER:  ending lon was empty. Bug?"
 	    fi
-	    echo "$TRACK_ID|$S_TIME|$S_LAT|$S_LON|$E_TIME|$E_LAT|$E_LON" >> "$TMP.track_atts"
+	    echo "$TRACK_ID|$S_TIME|$S_LAT|$S_LON|$E_TIME|$E_LAT|$E_LON" >> "$TEMPFILE.track_atts"
 	    TRACK_NUMBER="`expr $TRACK_NUMBER - 1`"
 	    # eat files
-	    tail -n $TRACK_NUMBER "$TMP.bytes" > "$TMP.bytes2"
+	    tail -n $TRACK_NUMBER "$TEMPFILE.bytes" > "$TEMPFILE.bytes2"
 	    B_GPX=0
 	    B_PNT=0
 	done
 	ATTR_COLS='cat int, start_time varchar(40), start_lat double precision, start_lon double precision, end_time varchar(40), end_lat double precision, end_lon double precision'
     fi
@@ -562,14 +562,14 @@
-	    $1!="L" { " %s %s\n", $1, $2) } END {;}' > "${TMP}.P_base"
+	    $1!="L" { " %s %s\n", $1, $2) } END {;}' > "${TEMPFILE}.P_base"
     else
 	EXITCODE=$?
@@ -578,22 +578,22 @@
 	    g.message "Projection transform failed, retaining WGS84"
-		$1!="L" { printf(" %s %s\n", $1, $2) } END {;}' > "${TMP}.P_base"
+		$1!="L" { printf(" %s %s\n", $1, $2) } END {;}' > "${TEMPFILE}.P_base"
 	else
 	fi
     fi
 DIGIT NAME:   $PROG
@@ -608,16 +608,16 @@
 #HB#?? locale test fixed this
-    cat "${TMP}.P_baseC" | tr ',' '.' >> "${TMP}.dig"
+    cat "${TEMPFILE}.P_baseC" | tr ',' '.' >> "${TEMPFILE}.dig"
     else
 	g.message "Importing with v.in.ascii"
@@ -680,7 +680,7 @@
-rm -f "${TMP}."* "${TMP}"
+rm -f "${TEMPFILE}."* "${TEMPFILE}"
 #### end
 g.message "Done."
Modified: grass/branches/develbranch_6/scripts/v.in.lines/v.in.lines
--- grass/branches/develbranch_6/scripts/v.in.lines/v.in.lines	2010-01-27 04:48:40 UTC (rev 40689)
+++ grass/branches/develbranch_6/scripts/v.in.lines/v.in.lines	2010-01-27 05:12:20 UTC (rev 40690)
@@ -58,14 +58,14 @@
     g.message -e "unable to create temporary files"
     exit 1
 fi
-trap 'rm -f "$TMP"' 2 3 15
+trap 'rm -f "$TEMPFILE"' 2 3 15
 #### parse field separator
 if [ "$GIS_OPT_FS" = "space" ] || [ "$GIS_OPT_FS" = "tab" ] ; then
@@ -83,30 +83,30 @@
       read REPLY
       EXITCODE=$?
       if [ -n "$REPLY" ] ; then
-	 echo "$REPLY" >> "$TMP.raw"
+	 echo "$REPLY" >> "$TEMPFILE.raw"
       fi
    done
    if [ "$fs" = " " ] ; then
-     \mv -f "$TMP.raw" "$TMP"
+     \mv -f "$TEMPFILE.raw" "$TEMPFILE"
    else
-     tr "$fs" ' ' < "$TMP.raw" > "$TMP"
-     \rm  -f "$TMP.raw"
+     tr "$fs" ' ' < "$TEMPFILE.raw" > "$TEMPFILE"
+     \rm  -f "$TEMPFILE.raw"
    fi
    # make sure we have at least one line of data
-   if [ "`wc -l "$TMP" | cut -f1 -d' '`" -eq 0 ] ; then
+   if [ "`wc -l "$TEMPFILE" | cut -f1 -d' '`" -eq 0 ] ; then
       g.message -e "Problem reading data from stdin"
       exit 1
    fi
-   INFILE="$TMP"
+   INFILE="$TEMPFILE"
 else
       INFILE="$GIS_OPT_INPUT"
    else
-      tr "$fs" ' ' < "$GIS_OPT_INPUT" > "$TMP"
-      INFILE="$TMP"
+      tr "$fs" ' ' < "$GIS_OPT_INPUT" > "$TEMPFILE"
    fi
 fi
@@ -119,7 +119,7 @@
 if [ -z "`head -n 1 "$INFILE" | sed -e 's/[^ \t]*$//'`" ] ; then
    g.message -e "Not enough data columns. (incorrect fs setting?)"
-   rm -f "$TMP"
+   rm -f "$TEMPFILE"
    exit 1
 fi
@@ -127,7 +127,7 @@
 EXITCODE=$?
 #cleanup
-rm -f "$TMP"
+rm -f "$TEMPFILE"
 exit $EXITCODE
Modified: grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs
--- grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs	2010-01-27 04:48:40 UTC (rev 40689)
+++ grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs	2010-01-27 05:12:20 UTC (rev 40690)
@@ -61,28 +61,28 @@
     exit 1
 fi
     exit 1
 fi
-OUT=$GIS_OPT_output
+OUT="$GIS_OPT_output"
 WFS_URL="$GIS_OPT_WFS"
 g.message "Retrieving data ..."
-curl "$WFS_URL" > "$TMP.xml"
+curl "$WFS_URL" > "$TEMPFILE.xml"
-v.in.ogr dsn="$TMP.xml" out=$OUT -o
+v.in.ogr dsn="$TEMPFILE.xml" out=$OUT -o
   g.message -e "WFS-XML file not readable. Check if xerces-c support is compiled into GDAL/OGR library."
-  rm -f "$TMP.xml" "$TMP" "$TMP.gfs"
+  rm -f "$TEMPFILE.xml" "$TEMPFILE" "$TEMPFILE.gfs"
   exit 1
 fi
-rm -f "$TMP.xml" "$TMP" "$TMP.gfs"
+rm -f "$TEMPFILE.xml" "$TEMPFILE" "$TEMPFILE.gfs"
-v.support $OUT cmdhist="${CMDLINE}"
+v.support "$OUT" cmdhist="${CMDLINE}"
 g.message "Vector points map <$OUT> imported from WFS."
 exit 0
Modified: grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel
--- grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel	2010-01-27 04:48:40 UTC (rev 40689)
+++ grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel	2010-01-27 05:12:20 UTC (rev 40690)
@@ -150,8 +150,8 @@
     exit 1
 fi
@@ -160,7 +160,7 @@
 cleanup()
    g.message -v "Cleaning up ..."
-   \rm -f "$TMP" "$TMP.gpx"
+   \rm -f "$TEMPFILE" "$TEMPFILE.gpx"
    # only try to remove map if it exists to avoid ugly warnings
    g.findfile element=vector file="tmp_vogb_epsg4326_$$" > /dev/null
@@ -181,13 +181,13 @@
 if [ $WPT -eq 1 ] && ([ $RTE -eq 1 ] || [ $TRK -eq 1 ]) ; then
     g.message -e "One feature at a time please."
-    rm -f "${TMP}"
+    rm -f "$TEMPFILE"
     exit 1
 fi
 if [ $RTE -eq 1 ] && [ $TRK -eq 1 ] ; then
-    rm -f "${TMP}"
+    rm -f "$TEMPFILE"
     exit 1
 fi
@@ -310,7 +310,7 @@
 g.message -v "Exporting data ..."
-v.out.ogr in="tmp_vogb_epsg4326_$$" dsn="$TMP.gpx" type="$GIS_OPT_TYPE" \
+v.out.ogr in="tmp_vogb_epsg4326_$$" dsn="$TEMPFILE.gpx" type="$GIS_OPT_TYPE" \
   format=GPX ${LINETYPE} dsco="GPX_USE_EXTENSIONS=YES" --quiet
@@ -321,7 +321,7 @@
 if [ "$GIS_OPT_FORMAT" = gpx ] ; then
    # short circuit, we have what we came for.
-   mv -f "$TMP.gpx" "$GIS_OPT_OUTPUT"
+   mv -f "$TEMPFILE.gpx" "$GIS_OPT_OUTPUT"
    cleanup
    g.message -v "Fast exit."
    exit 0
@@ -340,7 +340,7 @@
 g.message -v "Running GpsBabel ..."
-gpsbabel $GTYPE -i gpx -f "$TMP.gpx" \
+gpsbabel $GTYPE -i gpx -f "$TEMPFILE.gpx" \
     -o "$GIS_OPT_FORMAT" -F "$GIS_OPT_OUTPUT"
Modified: grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
--- grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats	2010-01-27 04:48:40 UTC (rev 40689)
+++ grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats	2010-01-27 05:12:20 UTC (rev 40690)
@@ -88,14 +88,14 @@
 export LC_NUMERIC
     exit 1
 fi
-SQLTMP="$TMP.sql"
+SQLTMP="$TEMPFILE.sql"
 # we need a random name
-TMPNAME=`basename "$TMP"`
+TMPNAME=`basename "$TEMPFILE"`
 cleanup()
@@ -108,7 +108,7 @@
       g.message "Restoring previous MASK..."
       g.rename "${TMPNAME}_origmask",MASK --quiet
    fi
-   rm -f "$TMP" "$TMPNAME" "$TMP.cats" "$SQLTMP"
+   rm -f "$TEMPFILE" "$TMPNAME" "$TEMPFILE.cats" "$SQLTMP"
 # what to do in case of user break:
@@ -185,9 +185,9 @@
 #dump cats to file to avoid "too many argument" problem:
-r.category "${VECTOR}_${TMPNAME}" fs=';' --quiet | cut -d';' -f1 > "$TMP.cats"
+r.category "${VECTOR}_${TMPNAME}" fs=';' --quiet | cut -d';' -f1 > "$TEMPFILE.cats"
 #echo "List of categories found: $CATSLIST"
-NUMBER=`cat "$TMP.cats" | wc -l | awk '{print $1}'`
+NUMBER=`cat "$TEMPFILE.cats" | wc -l | awk '{print $1}'`
 if [ $NUMBER -lt 1 ] ; then
    g.message -e "No categories found in raster map"
    cleanup
@@ -297,7 +297,7 @@
    EXTSTAT=""
 fi
-for i in `cat "$TMP.cats"` ; do
+for i in `cat "$TEMPFILE.cats"` ; do
    g.message -v message="Processing category $i ($CURRNUM/$NUMBER)"
    g.remove MASK --quiet 2>/dev/null
    # r.mapcalc doesn't use the parser, so we set the env var version instead
Modified: grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh
--- grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh	2010-01-27 04:48:40 UTC (rev 40689)
+++ grass/branches/develbranch_6/scripts/v.univar.sh/v.univar.sh	2010-01-27 05:12:20 UTC (rev 40690)
@@ -80,15 +80,15 @@
 export LC_NUMERIC
     exit 1
 fi
 cleanup()
-   \rm -f "$TMP" "$TMP.sort"
+   \rm -f "$TEMPFILE" "$TEMPFILE.sort"
@@ -118,9 +118,9 @@
 fi
 if [ -z "$GIS_OPT_WHERE" ] ; then
-   db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TMP"
+   db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TEMPFILE"
 else
-   db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TMP"
+   db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TEMPFILE"
 fi
@@ -133,7 +133,7 @@
 #echo ""
 #check if map contains only NULL's in current region
-LINES=`wc -l "$TMP" | awk '{print $1}'`
+LINES=`wc -l "$TEMPFILE" | awk '{print $1}'`
 if [ "$LINES" -eq 0 ] ; then
  g.message -e "Table $GIS_OPT_TABLE contains no data."
  cleanup
@@ -142,7 +142,7 @@
 # calculate statistics
 g.message "Calculating statistics..."
-cat "$TMP" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
+cat "$TEMPFILE" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
 function abs(x){return x < 0 ? -x : x}
 (NF>0) {
 	sum += $1 ; sum2 += $1 * $1 ; sum3 += abs($1) ; N++;
@@ -170,14 +170,14 @@
 if [ $GIS_FLAG_E -eq 1 ] ; then
   #preparations:
-  cat "$TMP" | sort -n > "$TMP.sort"
-  NUMBER=`cat "$TMP.sort" | wc -l | awk '{print $1}'`
+  cat "$TEMPFILE" | sort -n > "$TEMPFILE.sort"
+  NUMBER=`cat "$TEMPFILE.sort" | wc -l | awk '{print $1}'`
   ODDEVEN=`echo "$NUMBER" | awk '{print $1%2}'`
   # 0.25 quartile
   QUARTILE=0.25
   QPOS=`echo $NUMBER $QUARTILE | awk '{printf "%d", $1 * $2 + 0.5}'`
-  QELEMENT=`head -n $QPOS "$TMP.sort" | tail -n 1`
+  QELEMENT=`head -n $QPOS "$TEMPFILE.sort" | tail -n 1`
   echo "1st Quartile: $QELEMENT"
   #Calculate median
@@ -187,13 +187,13 @@
    EVENMEDIANNUMBER=`expr $NUMBER / 2`
    EVENMEDIANNUMBERPLUSONE=`expr $EVENMEDIANNUMBER + 1`
    # select two numbers
-   SELECTEDNUMBERS=`cat "$TMP.sort" | head -n $EVENMEDIANNUMBERPLUSONE | tail -n 2`
+   SELECTEDNUMBERS=`cat "$TEMPFILE.sort" | head -n $EVENMEDIANNUMBERPLUSONE | tail -n 2`
    RESULTEVENMEDIAN=`echo $SELECTEDNUMBERS | awk '{printf "%f", ($1 + $2)/2.0}'`
    echo "Median (even N): $RESULTEVENMEDIAN"
   else
    # odd
    ODDMEDIANNUMBER=`echo $NUMBER | awk '{printf "%d", int($1/2+.5)}'`
-   RESULTODDMEDIAN=`cat "$TMP.sort" | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
+   RESULTODDMEDIAN=`cat "$TEMPFILE.sort" | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
    echo "Median (odd N): $RESULTODDMEDIAN"
   fi
@@ -201,13 +201,13 @@
   # 0.75 quartile
   QUARTILE=0.75
   echo "3rd Quartile: $QELEMENT"
   # 0.90 percentile
   QUARTILE=0.9
   echo "90th Percentile: $QELEMENT"
 fi
