[GRASS-SVN] r40739 - in grass/trunk: include lib/raster raster/r.info
Fri Jan 29 15:04:19 EST 2010
Author: glynn
Date: 2010-01-29 15:04:18 -0500 (Fri, 29 Jan 2010)
New Revision: 40739
   grass/trunk/include/rasterdefs.h
   grass/trunk/lib/raster/raster_metadata.c
   grass/trunk/raster/r.info/main.c
Change interface of Rast_{read,write}_{units,vdatum}
 read returns dynamically-allocated string rather than filling buffer
 write generates fatal errors rather than returning status
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h	2010-01-29 20:02:42 UTC (rev 40738)
+++ grass/trunk/include/rasterdefs.h	2010-01-29 20:04:18 UTC (rev 40739)
@@ -496,10 +496,10 @@
 DCELL Rast_get_d_value(const void *, RASTER_MAP_TYPE);
 /* raster_metadata.c */
-int Rast_read_units(const char *, const char *, char *);
-int Rast_read_vdatum(const char *, const char *, char *);
-int Rast_write_units(const char *, const char *);
-int Rast_write_vdatum(const char *, const char *);
+char *Rast_read_units(const char *, const char *);
+char *Rast_read_vdatum(const char *, const char *);
+void Rast_write_units(const char *, const char *);
+void Rast_write_vdatum(const char *, const char *);
 /* reclass.c */
 int Rast_is_reclass(const char *, const char *, char *, char *);
Modified: grass/trunk/lib/raster/raster_metadata.c
--- grass/trunk/lib/raster/raster_metadata.c	2010-01-29 20:02:42 UTC (rev 40738)
+++ grass/trunk/lib/raster/raster_metadata.c	2010-01-29 20:04:18 UTC (rev 40739)
@@ -19,8 +19,8 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
-static int misc_read_line(const char *, const char *, const char *, char *);
-static int misc_write_line(const char *, const char *, const char *);
+static char *misc_read_line(const char *, const char *, const char *);
+static void misc_write_line(const char *, const char *, const char *);
  * \brief Get a raster map's units metadata string
@@ -29,14 +29,13 @@
  * \param name raster map name
  * \param mapset mapset name
- * \param str  string to be populated with data
- * \return 0 on success
- * \return -1, EOF (fclose() result) on error
+ * \return  string representing units on success
+ * \return  NULL on error
-int Rast_read_units(const char *name, const char *mapset, char *str)
+char *Rast_read_units(const char *name, const char *mapset)
-    return misc_read_line("units", name, mapset, str);
+    return misc_read_line("units", name, mapset);
@@ -46,13 +45,10 @@
  * \param str  string containing data to be written
-int Rast_write_units(const char *name, const char *str)
+void Rast_write_units(const char *name, const char *str)
-    return misc_write_line("units", name, str);
+    misc_write_line("units", name, str);
@@ -62,14 +58,13 @@
+ * \return  string representing vertical datum on success
-int Rast_read_vdatum(const char *name, const char *mapset, char *str)
+char *Rast_read_vdatum(const char *name, const char *mapset)
-    return misc_read_line("vertical_datum", name, mapset, str);
+    return misc_read_line("vertical_datum", name, mapset);
@@ -80,13 +75,10 @@
-int Rast_write_vdatum(const char *name, const char *str)
+void Rast_write_vdatum(const char *name, const char *str)
-    return misc_write_line("vertical_datum", name, str);
+    misc_write_line("vertical_datum", name, str);
@@ -99,34 +91,36 @@
  * \param name
  * \param mapset
  * \param *str  string to be populated with data
+ * \return dynamically-allocated string on success
-int misc_read_line(const char *elem, const char *name,
-		   const char *mapset, char *str)
+static char *misc_read_line(const char *elem,
+			    const char *name, const char *mapset)
-    FILE *fd;
     char buff[GNAME_MAX];
+    FILE *fp;
     buff[0] = '\0';
     if (G_find_file2_misc("cell_misc", elem, name, mapset) == NULL)
-	return -1;
+	return NULL;
-    fd = G_fopen_old_misc("cell_misc", elem, name, mapset);
-    if (!fd) {
-	G_warning(_("Unable to read %s for raster map <%s@%s>"),
+    fp = G_fopen_old_misc("cell_misc", elem, name, mapset);
+    if (!fp) {
+	G_warning(_("Unable to read <%s> for raster map <%s@%s>"),
-	return -1;
+	return NULL;
-    if (G_getl2(buff, sizeof(buff) - 1, fd) == 0) {
+    if (G_getl2(buff, sizeof(buff) - 1, fp) == 0) {
 	/* file is empty */
-	return fclose(fd);
+	*buff = '\0';
-    strcpy(str, buff);
+    if (fclose(fp) != 0)
+	G_fatal_error(_("Error closing <%s> metadata file for raster map <%s@%s>"),
+		      elem, name, mapset);
+    return *buff ? G_store(buff) : NULL;
@@ -139,21 +133,20 @@
  * \param element  metadata component filename
  * \param name
  * \param *str  string containing data to be written
-int misc_write_line(const char *elem, const char *name, const char *str)
+static void misc_write_line(const char *elem, const char *name, const char *str)
-    FILE *fd;
+    FILE *fp;
-    fd = G_fopen_new_misc("cell_misc", elem, name);
-    if (fd == NULL) {
-	G_warning(_("Unable to create %s metadata file for raster map <%s@%s>"),
-		  elem, name, G_mapset());
-	return -1;
+    fp = G_fopen_new_misc("cell_misc", elem, name);
+    if (!fp)
+	G_fatal_error(_("Unable to create <%s> metadata file for raster map <%s@%s>"),
+		      elem, name, G_mapset());
-    fprintf(fd, "%s", str);
+    fprintf(fp, "%s\n", str);
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c	2010-01-29 20:02:42 UTC (rev 40738)
+++ grass/trunk/raster/r.info/main.c	2010-01-29 20:04:18 UTC (rev 40739)
@@ -42,7 +42,7 @@
     const char *name, *mapset;
     char tmp1[100], tmp2[100], tmp3[100];
     char timebuff[256];
-    char units[GNAME_MAX], vdatum[GNAME_MAX];
+    char *units, *vdatum;
     int i;
     CELL mincat = 0, maxcat = 0, cat;
     double zmin, zmax;		/* min and max data values */
@@ -125,11 +125,10 @@
     is_reclass = Rast_get_reclass(name, "", &reclass);
     data_type = Rast_map_type(name, "");
-    if (Rast_read_units(name, "", units) != 0)
-	units[0] = '\0';
-    if (Rast_read_vdatum(name, "", vdatum) != 0)
-	vdatum[0] = '\0';
+    units = Rast_read_units(name, "");
+    vdatum = Rast_read_vdatum(name, "");
     /*Check the Timestamp */
     time_ok = G_read_raster_timestamp(name, "", &ts) > 0;
     /*Check for valid entries, show none if no timestamp available */
@@ -188,10 +187,9 @@
 	/* For now hide these unless they exist to keep the noise low. In
 	 *   future when the two are used more widely they can be printed
 	 *   along with the standard set. */
-	if (units[0] || vdatum[0]) {
+	if (units && vdatum)
 	    compose_line(out, "  Data Units:   %-20.20s Vertical datum: %s",
 			 units, vdatum);
 	    compose_line(out, "  Rows:         %d", cellhd.rows);
@@ -397,9 +395,9 @@
 	if (uflag->answer)
-	    fprintf(out, "units=%s\n", units);
+	    fprintf(out, "units=%s\n", units ? units : "(none)");
 	if (dflag->answer)
-	    fprintf(out, "vertical_datum=%s\n", vdatum);
+	    fprintf(out, "vertical_datum=%s\n", vdatum ? vdatum : "(none)");
 	if (hflag->answer) {
 	    if (hist_ok) {
