[GRASS-SVN] r42751 - grass-addons/LandDyn/r.catchment.py
Fri Jul 9 18:39:34 EDT 2010
Author: isaacullah
Date: 2010-07-09 22:39:34 +0000 (Fri, 09 Jul 2010)
New Revision: 42751
   grass-addons/LandDyn/r.catchment.py/r.catchment.py
Re-wrote the script to use grass python librabry. Added functionality to be able to list all the differnt possible catchment conifgurations (cost surface value and the coresponding area of the catchment that they would delimit). Removed excess commentary.
Modified: grass-addons/LandDyn/r.catchment.py/r.catchment.py
--- grass-addons/LandDyn/r.catchment.py/r.catchment.py	2010-07-09 21:35:44 UTC (rev 42750)
+++ grass-addons/LandDyn/r.catchment.py/r.catchment.py	2010-07-09 22:39:34 UTC (rev 42751)
@@ -113,13 +113,6 @@
 #% required : yes
 #%END
 #%option
-#% key: deviation
-#% type: integer
-#% description: Percentage to which output buffer can differ from desired buffer size (large values decrease run-time, but results will be less precise)
-#% answer: 10
-#% required : yes
-#%END
-#%option
 #% key: mapval
 #% type: integer
 #% description: Integer vlaue for out put catchment area (all other areas will be Null)
@@ -134,39 +127,19 @@
 #% key: c
 #% description: -c Keep cost surface used to calculate buffers
 #%END
+#%flag
+#% key: l
+#% description: -l Show a list of all cost surface values and the area of the catchment that they delimit
+#%END
 import sys
 import os
 import subprocess
 import tempfile
-# first define some useful custom methods
+import grass.script as grass
+# first define a useful custom method
-# m is a message (as a string) one wishes to have printed in the output window
-def grass_print(m):
-	subprocess.Popen('g.message message="%s"' % m, shell='bash').wait()
-	return
-# m is grass (or bash) command to execute (written as a string). script will wait for grass command to finish
-def grass_com(m):
-	subprocess.Popen('%s' % m, shell='bash').wait()
-	return
-# m is grass (or bash) command to execute (written as a string). script will not wait for grass command to finish
-def grass_com_nw(m):
-	return
-# m is a grass/bash command that will generate some info to stdout. You must invoke this command in the form of "variable to be made" = out2var('command')
-def out2var(m):
-        pn = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
-        return pn.stdout.read()
-# m is a grass/bash command that will generate some list of keyed info to stdout, n is the character that seperates the key from the data, o is a defined blank dictionary to write results to
-def out2dict(m, n, o):
-    p1 = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
-    p2 = p1.stdout.readlines()
-    for y in p2:
-        y0,y1 = y.split('%s' % n)
-        o[y0] = y1.strip('\n')
 # m is a grass/bash command that will generate some list of keyed info to stdout where the keys are numeric values, n is the character that seperates the key from the data, o is a defined blank dictionary to write results to
 def out2dictnum(m, n, o):
@@ -176,15 +149,6 @@
         y0num = float(y0)
         o[y0num] = y1.strip('\n')
-# m is a grass/bash command that will generate some charcater seperated list of info to stdout, n is the character that seperates individual pieces of information, and  o is a defined blank list to write results to
-def out2list2(m, n, o):
-        for y in p2:
-            o.append(y0)
-            o.append(y1.strip('\n'))
 #main block of code starts here
 def main():
     #setting up variables for use later on
@@ -198,147 +162,127 @@
     d = os.getenv('GIS_OPT_d')
     sigma = os.getenv('GIS_OPT_sigma')
     area = float(os.getenv('GIS_OPT_area'))
-    deviation = area*(float(os.getenv('GIS_OPT_deviation'))/100)
     buffer = os.getenv('GIS_OPT_buffer')
     mapval = os.getenv('GIS_OPT_mapval')
+    w_coefs = a + ',' +  b + ',' + c + ',' + d
-    grass_print("Wanted buffer area=%s\n" % int(area))
-    grass_com('g.region --quiet rast=' + elev)
+    grass.message("Wanted buffer area=%s\n" % int(area))
+    grass.run_command('g.region',  quiet = True, rast = elev)
     if bool(os.getenv('GIS_OPT_incost')) is True:
-        grass_print('\n\nstep 1 of 4: Using input cost surface\n')
+        grass.message('\n\nUsing input cost surface\n')
         cost = os.getenv('GIS_OPT_incost')
     else:
-        grass_print('\n\nstep 1 of 4: Calculating cost surface\n')
+        grass.message('\n\nstep 1 of 4: Calculating cost surface\n')
         cost = 'temporary.cost'
         if bool(os.getenv('GIS_OPT_frict')) is True:
-            grass_print('Calculating costs using input friction map\n')
+            grass.message('Calculating costs using input friction map\n')
             frict = os.getenv('GIS_OPT_frict')
         else:
-            grass_print('Calculating for time costs only')
+            grass.message('Calculating for time costs only')
             frict = "temporary.friction"
-            grass_com('r.mapcalc "' + frict + '=if(isnull(' + elev + '), null(), 1)"')
+            grass.mapcalc("${out} = if(isnull(${rast1}), null(), 1)",  out = frict,  rast1 = elev)
         if os.getenv('GIS_FLAG_k') == '1':
-            grass_print('Using Knight\'s move\n')
-            grass_com('r.walk --quiet -k elevation=' + elev + ' friction=' + frict + ' output=' + cost +' start_points=' + vect + ' lambda=' + lmbda + ' percent_memory=100 nseg=4 walk_coeff=' + a + ',' + b + ',' + c + ',' + d + ' slope_factor=' + slpfct)
+            grass.message('Using Knight\'s move\n')
+            #NOTE! because "lambda" is an internal python variable, it is impossible to enter the value for key "lambda" in r.walk. It ends up with a python error.
+            grass.run_command('r.walk', quiet = True, flags = 'k', elevation = elev, friction = frict, output = cost, start_points = vect, walk_coeff = w_coefs, slope_factor = slpfct)
         else:
-            grass_com('r.walk --quiet elevation=' + elev + ' friction=' + frict + ' output=' + cost +' start_points=' + vect + ' lambda=' + lmbda + ' percent_memory=100 nseg=4 walk_coeff=' + a + ',' + b + ',' + c + ',' + d + ' slope_factor=' + slpfct)
+            grass.run_command('r.walk', quiet = True, elevation = elev, friction = frict, output = cost, start_points = vect, percent_memory = '100', nseg ='4', walk_coeff = w_coefs, slope_factor = slpfct)
         if bool(os.getenv('GIS_OPT_frict')) is False:
-            grass_com('g.remove --quiet rast=' + frict)
+            grass.run_command('g.remove', quiet = True,  rast = frict)
-    grass_print('\n\nstep 2 of 4: Creating optional slope mask\n')
+    grass.message('\n\nCreating optional slope mask\n')
     if bool(os.getenv('GIS_OPT_sigma')) is True:
         slope = "temporary.slope"
-        grass_com('r.slope.aspect --quiet --overwrite elevation=' + elev + ' slope=' + slope)
-        grass_com('r.mapcalc "MASK=if(' + slope + ' <= ' + sigma + ', 1, null())"')
+        grass.run_command('r.slope.aspect', quiet = True, overwrite = True,  elevation = elev,  slope = slope)
+        grass.mapcalc("MASK=if(${rast1} <= %s, 1, null())" % sigma,  rast1 = slope)
     else:
-        grass_print('No slope mask created')
+        grass.message('No slope mask created')
-    grass_print('\n\nstep 3 of 4: Calculating buffer\n')
-    #set up for loop by getting initial variables from map
-    costdict = {}
-    out2dict('r.univar -g map=%s' % cost,'=' , costdict)
-    maxcost = float(costdict['max'])
-    areadict = {}
-    out2dictnum('r.stats -a -n input=' + cost + ' fs=, nv=* nsteps=255', ',', areadict)
-#    cutoff = maxcost
-#    mincost = 0.0
-    tot_area = 0
-    for key in areadict:
-        tot_area = tot_area + int(float(areadict[key]))
-    grass_print("Maximum cost distance value %s covers an area of %s square meters\n\nCommencing to find a catchment configuration.....\n\n" % (int(maxcost),  tot_area))
-#    # set up error trap to prevent infinite loops
-#    lastcut = 0
-    testarea = 0
-    #start the loop, and home in on the target range
-    for key in sorted(areadict):
-        testarea = testarea +  int(float(areadict[key]))
-        #grass_print("%s | %s" % (int(key),  testarea))
-        if testarea >= area:
-            grass_print("Catchment configuration found! Cost cutoff %s produces a catchment of %s square meters." % (int(key),  testarea))
-            break
-    cutoff = key
-#    while testarea not in range((int(area)-int(deviation)),(int(area)+(int(deviation)+1))):
-#        lastcut = cutoff
-#        if testarea > area:
-#            maxcost = cutoff
-#            cutoff = (maxcost+mincost)/2.0
-#        else:
-#            mincost = cutoff
-#        testarea = 0
-#        for key in areadict:
-#            if key <= cutoff:
-#                testarea = testarea +  int(float(areadict[key]))
-#                grass_print('\nTesting with cost distance value = %s......\ncurrent area = %s\n' % (cutoff,  testarea))
-    #loop conditions have been met, and cuttoff point is determined.
-#    #set up for loop by getting initial variables from map
-#    costdict = {}
-#    out2dict('r.univar -g map=%s' % cost,'=' , costdict)
-#    maxcost = float(costdict['max'])
-#    grass_print("\nMaximum cost distance value= %s\n" % maxcost)
-#    arealist = []
-#    out2list2('r.stats -a -n input=' + cost + ' fs=, nv=* nsteps=1', ',', arealist)
-#    maxarea = int(float(arealist[1]))
-#    grass_print('Total map area = %s' % maxarea)
-#    cutoff = maxcost
-#    mincost = 0.0
-#    testarea = maxarea
-#    lastcut = 0
-#    #start the loop, and home in on the target range
-#    while testarea not in range((int(area)-int(deviation)),(int(area)+(int(deviation)+1))) and round(lastcut) != round(cutoff):
-#        lastcut = cutoff
-#            maxcost = cutoff
-#        else:
-#            mincost = cutoff
-#        temp = tempfile.NamedTemporaryFile()
-#        temp.write('0 thru %s = %s\n' % (int(cutoff),  mapval))
-#        temp.flush()
-#        grass_print('0 thru %s = %s\n' % (int(cutoff),  mapval))
-#        grass_com('r.reclass --overwrite --quiet input=%s output=cost.reclass rules=%s' % (cost,  temp.name))
-#        temp.close()
-#        arealist = []
-#        out2list2('r.stats -a -n input=cost.reclass fs=, nv=* nsteps=1', ',', arealist)
-#        testarea = int(float(arealist[1]))
-#    #loop is done, so print the final stats
-#    difference = testarea-area
-#    grass_print('\n\n*************************\n\n Final cost distance cutoff of %s produces a catchment of %s square meters.\nThe difference from the requested catchment size is %s square meters.' % (cutoff,  testarea,  difference))
-    grass_print('\n\nstep 4 of 4: Creating output map\n')
-    temp = tempfile.NamedTemporaryFile()
-    temp.write('0 thru %s = %s\n' % (int(cutoff),  mapval))
-    temp.flush()
-    grass_com('r.reclass --overwrite --quiet input=%s output=cost.reclass rules=%s' % (cost,  temp.name))
-    temp.close()
-    grass_com('r.mapcalc "%s=if(isnull(cost.reclass), null(), cost.reclass)"' % buffer)
-    grass_print(buffer)
-    grass_com('r.colors --quiet map=%s color=ryb' % buffer)
-    if os.getenv('GIS_FLAG_c') == '1':
-        if bool(os.getenv('GIS_OPT_incost')) is False:
-            grass_com('g.rename temporary.cost,' + buffer + '_cost_surface')
-            grass_print('Cleaning up...(keeping cost map)')
-            grass_com('g.remove --quiet rast=cost.reclass')
-        else:
-            grass_print('Cleaning up...1')
+    if os.getenv('GIS_FLAG_l') == '1':
+            grass.message('\n\nCalculating list of possible catchment configurations\n')
+            grass.message("cost value | catchment area")
+            areadict = {}
+            out2dictnum('r.stats -a -n input=' + cost + ' fs=, nv=* nsteps=255', ',', areadict)
+            testarea = 0
+            #start the loop, and list the values
+            for key in sorted(areadict):
+                testarea = testarea +  int(float(areadict[key]))
+                grass.message("%s | %s" % (int(key),  testarea))
+            if os.getenv('GIS_FLAG_c') == '1':
+                if bool(os.getenv('GIS_OPT_incost')) is False:
+                    grass.run_command('g.rename',  quiet = True,  rast = 'temporary.cost,%s_cost_surface' % (buffer))
+                    grass.message('Cleaning up...(keeping cost map)')
+                    grass.run_command('g.remove',  quiet = True, rast='cost.reclass')
+                else:
+                    grass.message('Cleaning up...1')
+            else:
+                    grass.message('Cleaning up...2')
+                    grass.run_command('g.remove',  quiet = True, rast = 'cost.reclass,temporary.cost')
+                else:
+                    grass.message('Cleaning up...3')
+                    grass.run_command('g.remove',  quiet = True, rast = 'cost.reclass')
+            if bool(os.getenv('GIS_OPT_sigma')) is True:
+                grass.run_command('g.remove',  quiet = True, rast = slope)
+            grass.run_command('g.remove',  quiet = True, rast = 'MASK')
+            grass.message('     DONE!')
+            return
     else:
-            grass_print('Cleaning up...2')
-            grass_com('g.remove --quiet rast=cost.reclass,temporary.cost' )
+        grass.message('\n\nCalculating buffer\n')
+        areadict = {}
+        tot_area = 0
+            tot_area = tot_area + int(float(areadict[key]))
+            maxcost = key
+        grass.message("Maximum cost distance value %s covers an area of %s square meters\n\nCommencing to find a catchment configuration.....\n\n" % (int(maxcost),  tot_area))
+        testarea = 0
+        #start the loop, and home in on the target range
+            if testarea >= area:
+                break
+            lastkey = key
+            lastarea = testarea
+        if (testarea - area) <= (area - lastarea):
+            cutoff = key
+            displayarea = testarea
         else:
-            grass_print('Cleaning up...3')
-    if bool(os.getenv('GIS_OPT_sigma')) is True:
-        grass_com('g.remove --quiet rast=' + slope)
-    grass_com('g.remove --quiet rast=MASK')
-    grass_print('     DONE!')
-    return
+            cutoff = lastkey
+            displayarea = lastarea
+        grass.message("Catchment configuration found! Cost cutoff %s produces a catchment of %s square meters." % (int(cutoff),  displayarea))
+        grass.message('\n\nCreating output map\n')
+        temp = tempfile.NamedTemporaryFile()
+        temp.write('0 thru %s = %s\n' % (int(cutoff),  mapval))
+        temp.flush()
+        grass.run_command('r.reclass', overwrite = True,  input = cost,  output = 'cost.reclass',  rules = temp.name)
+        temp.close()
+        grass.mapcalc("${out}=if(isnull(cost.reclass), null(), cost.reclass)", out = buffer)
+        grass.message("\nThe output catchment map wil be named %s" % buffer)
+        grass.run_command('r.colors', quiet = True,  map = buffer, color = 'ryb')
+            else:
+        else:
+            else:
+        return
 # here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
 if __name__ == "__main__":
