[GRASS-SVN] r42862 - grass-addons/gui/wxpython/data_catalog
Tue Jul 20 08:14:45 EDT 2010
Author: rashadkm
Date: 2010-07-20 12:14:44 +0000 (Tue, 20 Jul 2010)
New Revision: 42862
   grass-addons/gui/wxpython/data_catalog/LayerTree.py
   grass-addons/gui/wxpython/data_catalog/TODO
   grass-addons/gui/wxpython/data_catalog/catalog.py
   grass-addons/gui/wxpython/data_catalog/mapdisplay.py
added keymap browsing/panning feature to data catalog
Modified: grass-addons/gui/wxpython/data_catalog/LayerTree.py
--- grass-addons/gui/wxpython/data_catalog/LayerTree.py	2010-07-20 12:12:36 UTC (rev 42861)
+++ grass-addons/gui/wxpython/data_catalog/LayerTree.py	2010-07-20 12:14:44 UTC (rev 42862)
@@ -10,7 +10,9 @@
 import gdialogs
 from preferences import globalSettings as UserSettings
 from vdigit import haveVDigit
-from gcmd import GMessage
+grassversion = os.getenv("GRASS_VERSION")
+if grassversion.rfind("6.4") != 0:
+    from gcmd import GMessage
 import histogram
 import gui_modules.profile as profile
@@ -38,13 +40,15 @@
 import utils
 from grass.script import core as grass
-import gui_modules.layertree as layertree
+    from gui_modules.layertree import LayerTree as layertree
+else:
+    from gui_modules.wxgui_utils import LayerTree as layertree
+class LayerTree(layertree):
-class LayerTree(layertree.LayerTree):
     def __init__(self, parent,
                  id=wx.ID_ANY, pos=wx.DefaultPosition,
                  size=(300,300), style=wx.SUNKEN_BORDER,
@@ -191,12 +195,14 @@
         self.Bind(wx.EVT_TREE_END_DRAG,         self.OnEndDrag)
         self.Bind(wx.EVT_KEY_UP,                self.OnKeyUp)
         self.Bind(wx.EVT_IDLE,                  self.OnIdle)
+        self.addon = os.getenv("integrated-gui")
     def Minimal(self,item):
+        print "here"
         mnuCopy = self.popupMenu.Append(self.ID_COPY,'&Copy Map\tCtrl+C')
         mnuRename = self.popupMenu.Append(self.ID_REN,'&Rename Map\tCtrl-R')
         mnuDel = self.popupMenu.Append(self.ID_DEL,'&Delete Map\tDEL')
@@ -205,19 +211,23 @@
         mnuOssim = self.popupMenu.Append(self.ID_OSSIM2,'&Remove from OssimPlanet')
     def OnLayerContextMenu (self, event):
         """!Contextual menu for item/layer"""
         if not self.layer_selected:
             event.Skip()
             return
         self.popupMenu = wx.Menu()
         item =  event.GetItem()
         if self.IsItemChecked(item) == False:
-            self.Minimal(item)
+            if self.addon == "True":
+                self.Minimal(item)
         else:
             ltype =  self.GetPyData(self.layer_selected)[0]['type']
             Debug.msg (4, "LayerTree.OnContextMenu: layertype=%s" % \
@@ -528,6 +538,19 @@
 			ret = dlg.ShowModal()
 			if ret == wx.ID_YES:
 				dlg.Destroy()
+                mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
+                mltype = self.GetPyData(self.layer_selected)[0]['type']
+        if mltype == 'raster':
+            cmd = ['g.remove rast=']
+        elif mltype == 'vector':
+            cmd = ['g.remove vect=']
+        cmd.append('%s' % mapLayer.name)
+        # print output to command log area
+        self.lmgr.goutput.RunCmd(cmd, switchPage=True)
 				parent  =self.GetItemParent(item)
 				if self.GetItemText(parent) == "Raster Map" :
 					cmdflag = 'rast=' + str(self.GetItemText(item))
Modified: grass-addons/gui/wxpython/data_catalog/TODO
--- grass-addons/gui/wxpython/data_catalog/TODO	2010-07-20 12:12:36 UTC (rev 42861)
+++ grass-addons/gui/wxpython/data_catalog/TODO	2010-07-20 12:14:44 UTC (rev 42862)
@@ -1,3 +1,2 @@
 def onossim
 def onossim2
-def ondeletemap
Modified: grass-addons/gui/wxpython/data_catalog/catalog.py
--- grass-addons/gui/wxpython/data_catalog/catalog.py	2010-07-20 12:12:36 UTC (rev 42861)
+++ grass-addons/gui/wxpython/data_catalog/catalog.py	2010-07-20 12:14:44 UTC (rev 42862)
@@ -29,6 +29,10 @@
 import platform
 import shlex
+#os.system("export integ=True")
+os.environ['integrated-gui'] = "True"
 try:
     import xml.etree.ElementTree as etree
 except ImportError:
@@ -94,10 +98,11 @@
 import gui_modules.dbm as dbm
 import gui_modules.workspace as workspace
 import gui_modules.colorrules as colorrules
-import gui_modules.vclean as vclean
+#import gui_modules.vclean as vclean
 import gui_modules.nviz_tools as nviz_tools
-if grassversion != "6.4.0svn":
     import gui_modules.menu as menu
     import gui_modules.gmodeler as gmodeler
@@ -114,10 +119,11 @@
 import render
 import gc
-from   gui_modules.ghelp import MenuTreeWindow
-from   gui_modules.ghelp import AboutWindow
-from   gui_modules.toolbars import LayerManagerToolbar
-from   gui_modules.ghelp import InstallExtensionWindow
+    from   gui_modules.ghelp import MenuTreeWindow
+    from   gui_modules.ghelp import AboutWindow
+    from   gui_modules.toolbars import LayerManagerToolbar
+    from   gui_modules.ghelp import InstallExtensionWindow
 from wxgui import GMFrame
@@ -127,7 +133,6 @@
     def __init__(self, parent=None, id=wx.ID_ANY, title=_("Data Catalog Beta"),
                  workspace=None,size=wx.DefaultSize,pos=wx.DefaultPosition):
         self.iconsize  = (16, 16)
         self.baseTitle = title
         self.parent = parent
@@ -159,14 +164,20 @@
         self.dialogs        = dict()
         self.dialogs['preferences'] = None
         self.dialogs['atm'] = list()
+        #print os.getenv("integrated-gui")
         # creating widgets
-        self.menubar = menu.Menu(parent = self, data = menudata.ManagerData())
-        self.SetMenuBar(self.menubar)
-        self.menucmd = self.menubar.GetCmd()
+        if grassversion.rfind("6.4") != 0:
+            self.menubar = menu.Menu(parent = self, data = menudata.ManagerData())
+            self.SetMenuBar(self.menubar)
+            self.menucmd = self.menubar.GetCmd()
         self.statusbar = self.CreateStatusBar(number=1)
         self.notebook  = self.__createNoteBook()
-        self.toolbar = LayerManagerToolbar(parent = self)
+            self.toolbar = LayerManagerToolbar(parent = self)
+        else:
+            self.toolbar   = self.__createToolBar()
         self.SetToolBar(self.toolbar)
@@ -189,13 +200,13 @@
         self.loclist.sort()
         #self.pg_panel4 = None
-        if grassversion != "6.4.0svn":
         else:
             self.menubar, self.menudata = self.__createMenuBar()
-        self.statusbar = self.CreateStatusBar(number=1)
+        self.statusbar = self.CreateStatusBar(number=4, style=0)
@@ -239,6 +250,55 @@
         self.doLayout()
+    def OnCloseWindow(self, event):
+        """!Cleanup when wxGUI is quit"""
+        if not self.curr_page:
+            self._auimgr.UnInit()
+            self.Destroy()
+            return
+        os.environ['integrated-gui'] = "False"
+        maptree = self.curr_page.maptree
+        if self.workspaceChanged and \
+                UserSettings.Get(group='manager', key='askOnQuit', subkey='enabled'):
+            if self.workspaceFile:
+                message = _("Do you want to save changes in the workspace?")
+            else:
+                message = _("Do you want to store current settings "
+                            "to workspace file?")
+            # ask user to save current settings
+            if maptree.GetCount() > 0:
+                dlg = wx.MessageDialog(self,
+                                       message=message,
+                                       caption=_("Quit GRASS GUI"),
+                                       style=wx.YES_NO | wx.YES_DEFAULT |
+                                       wx.CANCEL | wx.ICON_QUESTION | wx.CENTRE)
+                ret = dlg.ShowModal()
+                if ret == wx.ID_YES:
+                    if not self.workspaceFile:
+                        self.OnWorkspaceSaveAs()
+                    else:
+                        self.SaveToWorkspaceFile(self.workspaceFile)
+                elif ret == wx.ID_CANCEL:
+                    event.Veto()
+                    dlg.Destroy()
+                    return
+                dlg.Destroy()
+        # don't ask any more...
+        UserSettings.Set(group = 'manager', key = 'askOnQuit', subkey = 'enabled',
+                         value = False)
+        for page in range(self.gm_cb.GetPageCount()):
+            self.gm_cb.GetPage(0).maptree.mapdisplay.OnCloseWindow(event)
+        self.gm_cb.DeleteAllPages()
+        self.Destroy()
     def __createNoteBook(self):
         """!Creates notebook widgets"""
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py	2010-07-20 12:12:36 UTC (rev 42861)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py	2010-07-20 12:14:44 UTC (rev 42862)
@@ -72,16 +72,18 @@
 import utils
 import gdialogs
 import goutput
-import units
+    import units
 from debug import Debug
 import dbm
-grassversion = os.getenv("GRASS_VERSION")
-if grassversion == "6.4.0.svn":
 	import dbm_dialogs
-from units import ConvertValue as UnitsConvertValue
+    from units import ConvertValue as UnitsConvertValue
 from vdigit import GV_LINES as VDigit_Lines_Type
 from vdigit import VDigitCategoryDialog
 from vdigit import VDigitZBulkDialog
@@ -105,7 +107,13 @@
 # for standalone app
 cmdfilename = None
-from mapdisp_window import BufferedWindow
+    from mapdisp_window import BufferedWindow
+else:
+    from mapdisp import BufferedWindow
+from mapdisp_window import MapWindow
 from mapdisp import MapFrame
 class MapFrame(wx.Panel,MapFrame):
@@ -184,9 +192,55 @@
             self.statusbar.SetStatusWidths([-5, -2, -1, -1])
         else:
             self.statusbar = self.frame.GetStatusBar()
+            self.statusbar.SetStatusWidths([-5, -2, -1, -1])
+        if grassversion.rfind("6.4") == 0:
+            self.autoRender = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                          label=_("Render"))
+            self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.autoRender)
+            self.autoRender.SetValue(UserSettings.Get(group='display', key='autoRendering', subkey='enabled'))
+            self.autoRender.SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
+            self.maskInfo = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
+                                                      label = '')
+            self.maskInfo.SetForegroundColour(wx.Colour(255, 0, 0))
+            self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
+                                      choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+            self.toggleStatus.SetSelection(UserSettings.Get(group='display', key='statusbarMode', subkey='selection'))
+            self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.toggleStatus)
+            self.onRenderGauge = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
+                                          range=0, style=wx.GA_HORIZONTAL)
+            self.onRenderGauge.Hide()
+            self.mapScale = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
+                                        value="", style=wx.TE_PROCESS_ENTER,
+                                        size=(150, -1))
+            self.mapScale.Hide()
+            self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.mapScale)
+            self.compResolution = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                             label=_("Constrain display resolution to computational settings"))
+            self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.compResolution)
+            self.compResolution.SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+            self.compResolution.Hide()
+            self.compResolution.SetToolTip(wx.ToolTip (_("Constrain display resolution "
+                                                     "to computational region settings. "
+                                                     "Default value for new map displays can "
+                                                     "be set up in 'User GUI settings' dialog.")))
+            self.showRegion = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                      label=_("Show computational extent"))
+            self.showRegion.SetValue(False)
+            self.showRegion.Hide()
+            self.showRegion.SetToolTip(wx.ToolTip (_("Show/hide computational "
+                                                 "region extent (set with g.region). "
+                                                 "Display region drawn as a blue box inside the "
+                                                 "computational region, "
+                                                 "computational region inside a display region "
+                                                 "as a red box).")))
         self.statusbarWin = dict()
@@ -245,7 +299,8 @@
                                                 size=(300, -1))
         self.statusbarWin['goto'].Hide()
-        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
+            self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
         # projection
         self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
@@ -289,6 +344,8 @@
         self.lmgr= frame
         self.maptree = LayerTree(self, id=wx.ID_ANY, pos=wx.DefaultPosition,
                                                       size=wx.DefaultSize, style=wx.TR_HAS_BUTTONS
                                                       |wx.TR_LINES_AT_ROOT|wx.TR_HIDE_ROOT,
@@ -298,13 +355,15 @@
         self.tree=self.maptree
+            self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,Map=self.Map, tree=self.tree, gismgr=self.gismanager)
+        else:
+            self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,   Map=self.Map, tree=self.tree, lmgr=self._layerManager)
-        self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,   Map=self.Map, tree=self.tree, lmgr=self._layerManager)
         self.tree.MapWindow = self.MapWindow2D
         # default is 2D display mode
         self.MapWindow = self.MapWindow2D
-        self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+#        self.MapWindow.Bind(wx.EVT_MOTION, MapWindow.OnMotion)
         #self.MapWindow.Bind(wx.EVT_LEFT_DOWN, self.OnClick)
         self.MapWindow.SetCursor(self.cursors["default"])
         # used by Nviz (3D display mode)
@@ -380,17 +439,117 @@
-        #self.maptree.SetBackgroundColour("red")
+        self.p = wx.Panel(self)
+        #hb = wx.BoxSizer(wx.HORIZONTAL)
+        self.p.Bind(wx.EVT_PAINT,self.onPaint)
+        self.p.Bind(wx.EVT_LEFT_DOWN,self.OnButtonDClick)
+        self.p.Bind(wx.EVT_MOTION, self.move)
+        self.moveFlag = False
+        self._mgr.AddPane(self.p, wx.aui.AuiPaneInfo().Right().
+                                        Dockable(True).BestSize((400,300)).
+                                        CloseButton(True).DestroyOnClose(True).
+                                        Layer(0).Caption("KeyMap"))
         self._mgr.AddPane(self.maptree, wx.aui.AuiPaneInfo().Left().
                                         Dockable(False).BestSize((400,300)).
                                         CloseButton(False).DestroyOnClose(True).
                                         Layer(0).Caption("Map Tree"))
+        self.previous = [0,0]
+        self.current  = [0,0]
         self._mgr.Update()
         #r.rightSizer.Add(self.maptree)
+    def OnButtonDClick(self,event):
+        try:
+            e, n = event.GetPositionTuple()
+	    #print e,n
+        except AttributeError:
+            return
+        self.paintwindow((e-50),(n-37),100,75,"/tmp/keymap.ppm")
+        begin = e,n
+        if self.moveFlag == False:
+            self.moveFlag=True
+            self.current = event.GetPositionTuple()[:]
+        else:
+           self.previous = event.GetPositionTuple()[:]
+           #print self.current
+           #print self.previous
+           move = (self.current[0] - self.previous[0],
+                self.current[1] - self.previous[1])
+           self.MapWindow.DragMap(move)
+    def move(self,event):
+        #print "here"
+        if self.moveFlag == True:
+            e,n = event.GetPosition()
+    def onPaint(self,event):
+        #print "here"
+        if self.MapWindow.mapfile is not None:
+            cmd = 'cp ' + self.MapWindow.mapfile + ' '+ '/tmp/keymap.ppm'
+            os.system(cmd)
+            self.paintwindow(50,50,100,75,"/tmp/keymap.ppm")
+    def paintwindow(self,x,y,length,breadth,imageFile):
+        #imageFile = "/home/rashad/keymap.png"
+        #self.dc = wx.PaintDC(self.p)
+        try:
+            png = wx.Image(_(imageFile), wx.BITMAP_TYPE_ANY).Scale(210,160,wx.IMAGE_QUALITY_HIGH)
+        except:
+            pass
+        #self.hbitmap = wx.StaticBitmap(self.p, -1, png, (10, 5), (50,50))
+        #self.hbitmap.SetCursor(wx.StockCursor(wx.CURSOR_MAGNIFIER))
+        self.wxbmp=png.ConvertToBitmap()
+        #self.wxbmp.Bind(wx.EVT_MOTION, self.move)
+        #self.dc.DrawBitmap(self.wxbmp, 0,0, True)
+        #self.dc.SetPen(wx.Pen("RED",style=wx.TRANSPARENT))
+        self.dc = wx.PaintDC(self.p)
+        self.dc.Clear()
+        self.dc.BeginDrawing()
+        self.dc.SetPen(wx.Pen("RED"))
+        self.dc.SetBrush(wx.Brush("WHITE",style=wx.TRANSPARENT))
+        self.dc.DrawBitmap(self.wxbmp, 0,0, True)
+        # set x, y, w, h for rectangle
+        #self.dc.DrawLine(10,10,30, 30)
+        self.dc.EndDrawing()
+        #self.dc.SetBrush(wx.Brush("RED"))
+        self.dc.DrawRectangle(x, y, length, breadth)
     def read_gisrc(self):
 	    Read variables gisrc file
