[GRASS-SVN] r42421 - grass/branches/develbranch_6/raster/r.random
Tue Jun 1 15:04:02 EDT 2010
Author: hamish
Date: 2010-06-01 15:04:01 -0400 (Tue, 01 Jun 2010)
New Revision: 42421
   grass/branches/develbranch_6/raster/r.random/main.c
   grass/branches/develbranch_6/raster/r.random/random.c
named boolean for cover map
Modified: grass/branches/develbranch_6/raster/r.random/main.c
--- grass/branches/develbranch_6/raster/r.random/main.c	2010-06-01 18:48:18 UTC (rev 42420)
+++ grass/branches/develbranch_6/raster/r.random/main.c	2010-06-01 19:04:01 UTC (rev 42421)
@@ -101,11 +101,11 @@
     myState.use_nulls = flag.zero->answer;
     myState.inraster = parm.input->answer;
     if (parm.cover->answer) {
-	myState.docover = 1;
+	myState.docover = TRUE;
 	myState.inrcover = parm.cover->answer;
     else {
-	myState.docover = 0;
+	myState.docover = FALSE;
 	myState.cmapset = NULL;
 	myState.inrcover = NULL;
@@ -118,7 +118,7 @@
     if (myState.mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), myState.inraster);
-    if (myState.docover == 1) {
+    if (myState.docover == TRUE) {
 	myState.cmapset = G_find_cell(myState.inrcover, "");
 	if (myState.cmapset == NULL)
 	    G_fatal_error(_("Raster map <%s> not found"), myState.inrcover);
Modified: grass/branches/develbranch_6/raster/r.random/random.c
--- grass/branches/develbranch_6/raster/r.random/random.c	2010-06-01 18:48:18 UTC (rev 42420)
+++ grass/branches/develbranch_6/raster/r.random/random.c	2010-06-01 19:04:01 UTC (rev 42421)
@@ -40,14 +40,14 @@
     if ((infd = theState->fd_old) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"),
 		      theState->inraster);
-    if (theState->docover == 1) {
+    if (theState->docover == TRUE) {
 	if ((cinfd = theState->fd_cold) < 0)
 			  theState->inrcover);
     if (theState->outraster != NULL) {
 	    type = theState->cover.type;
 	else
 	    type = theState->buf.type;
@@ -77,7 +77,7 @@
 	Vect_map_add_dblink(&Out, 1, NULL, fi->table, "cat", fi->database,
 			    fi->driver);
 	    table = db_alloc_table(3);
 	else
 	    table = db_alloc_table(2);
@@ -91,7 +91,7 @@
 	db_set_column_name(column, "value");
 	db_set_column_sqltype(column, DB_SQL_TYPE_DOUBLE_PRECISION);
 	    column = db_get_table_column(table, 2);
 	    db_set_column_name(column, "covervalue");
@@ -121,13 +121,14 @@
 	theState->nCells - theState->nNulls;
     nt = theState->nRand;	/* Number of points to generate */
     cat = 1;
     /* Execute for loop for every row if nt>1 */
     for (row = 0; row < nrows && nt; row++) {
 	if (G_get_raster_row
 	    (infd, theState->buf.data.v, row, theState->buf.type) < 0)
 	    G_fatal_error(_("Cannot read raster row [%d] from raster map <%s>"),
 			  row, theState->inraster);
 		(cinfd, theState->cover.data.v, row,
 		 theState->cover.type) < 0)
@@ -138,7 +139,7 @@
 	for (col = 0; col < ncols && nt; col++) {
 	    if (!theState->use_nulls && is_null_value(theState->buf, col))
 		continue;
-	    if (theState->docover == 1) {	/* skip no data cover points */
+	    if (theState->docover == TRUE) {	/* skip no data cover points */
 		    is_null_value(theState->cover, col))
 		    continue;
@@ -148,7 +149,7 @@
 		nt--;
 		if (is_null_value(theState->buf, col))
 		    cpvalue(&theState->nulls, 0, &theState->buf, col);
 		    if (is_null_value(theState->cover, col))
 			cpvalue(&theState->cnulls, 0, &theState->cover, col);
@@ -247,7 +248,7 @@
     /* close files */
     G_close_cell(infd);
 	G_close_cell(cinfd);
     if (theState->outvector) {
 	db_commit_transaction(driver);
