[GRASS-SVN] r42458 - grass-addons/raster/r.stream.distance
Thu Jun 3 07:32:18 EDT 2010
Author: mmetz
Date: 2010-06-03 07:32:18 -0400 (Thu, 03 Jun 2010)
New Revision: 42458
   grass-addons/raster/r.stream.distance/distance.c
   grass-addons/raster/r.stream.distance/global.h
   grass-addons/raster/r.stream.distance/inits.c
   grass-addons/raster/r.stream.distance/io.c
   grass-addons/raster/r.stream.distance/main.c
format and clean up code
Modified: grass-addons/raster/r.stream.distance/distance.c
--- grass-addons/raster/r.stream.distance/distance.c	2010-06-03 11:31:48 UTC (rev 42457)
+++ grass-addons/raster/r.stream.distance/distance.c	2010-06-03 11:32:18 UTC (rev 42458)
@@ -1,135 +1,138 @@
 #include <grass/glocale.h>
 #include "global.h"
-int calculate_upstream(void) {
-	int r,c;
-	int next_r, next_c;
-	float easting, northing;
-	float cell_easting, cell_northing;
-	int i,j,k;
-	int done;
-	int n_inits=0;
-	float cur_dist;
-	POINT* d_inits;
-	float* tmp_elevation=NULL; /* only for elevation */
-	float tmp_dist=0;
-	float tmp_elev=0;
-	float target_elev=0;
-	int tmp_inits=0;
-	int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
-	int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
-	for (r = 0; r < nrows; ++r) {
-		for (c = 0; c < ncols; ++c) {
-			for (i=1;i<9;++i) {
-					if (r + nextr[i] < 0 || r + nextr[i] > (nrows - 1) ||	c + nextc[i] < 0 || c + nextc[i] > (ncols - 1))
-				continue;	/* out of border */
-				j = (i + 4) > 8 ? i - 4 : i + 4;
-				if (dirs[r + nextr[i]][c + nextc[i]] == j &&
-						distance[r][c]!=0) {/* is contributing cell */
-					distance[r][c]=-1;
-					break;
-				if(distance[r][c]==1 && dirs[r][c]>0)
-			n_inits++;
-				else if (dirs[r][c]>0)
+int calculate_upstream(void)
+    int r, c;
+    int next_r, next_c;
+    float easting, northing;
+    float cell_easting, cell_northing;
+    int i, j, k;
+    int done;
+    int n_inits = 0;
+    float cur_dist;
+    POINT *d_inits;
+    float *tmp_elevation = NULL;	/* only for elevation */
+    float tmp_dist = 0;
+    float target_elev = 0;
+    int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+    int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
-		d_inits=(POINT *) G_malloc(n_inits * sizeof(POINT));
-	if(out_elev) {
-		tmp_elevation=(float *) G_malloc(nrows*ncols*sizeof(float));
-		tmp_elevation[r*ncols+c]=elevation[r][c];
+    for (r = 0; r < nrows; ++r) {
+	for (c = 0; c < ncols; ++c) {
+	    for (i = 1; i < 9; ++i) {
+		if (r + nextr[i] < 0 || r + nextr[i] > (nrows - 1) ||
+		    c + nextc[i] < 0 || c + nextc[i] > (ncols - 1))
+		    continue;	/* out of border */
+		j = (i + 4) > 8 ? i - 4 : i + 4;
+		if (dirs[r + nextr[i]][c + nextc[i]] == j && distance[r][c] != 0) {	/* is contributing cell */
+		    distance[r][c] = -1;
+		    break;
+	    if (distance[r][c] == 1 && dirs[r][c] > 0)
+		n_inits++;
+	    else if (dirs[r][c] > 0)
-	k=0;
+    d_inits = (POINT *) G_malloc(n_inits * sizeof(POINT));
+    if (out_elev) {
+	tmp_elevation = (float *)G_malloc(nrows * ncols * sizeof(float));
-			if(distance[r][c]==1) {
-				distance[r][c]=0;
-					if(out_elev)
-				elevation[r][c]=0;
-				if(dirs[r+nextr[dirs[r][c]]][c+nextc[dirs[r][c]]]<0)
-					continue;
-				if(distance[next_r][next_c]==0)
-					continue;
-				d_inits[k].r=r;
-				d_inits[k].c=c;
-				d_inits[k].cur_dist=0;
-					if(out_elev)
-				d_inits[k].target_elev=tmp_elevation[r*ncols+c];
-				k++;
+		tmp_elevation[r * ncols + c] = elevation[r][c];
-n_inits=k;
-while (n_inits>0) {
-	k=0;
+    k = 0;
-	for(i=0;i<n_inits;++i) {
-		r=d_inits[i].r;
-		c=d_inits[i].c;
-		next_r=r+nextr[dirs[r][c]];
-		next_c=c+nextc[dirs[r][c]];
-		tmp_dist=d_inits[i].cur_dist;
-		if(out_elev)
-			target_elev=d_inits[i].target_elev;
-		easting=window.west + (c + 0.5) * window.ew_res;
-		northing=window.north - (r + 0.5) * window.ns_res;
-		cell_easting=window.west + (next_c + 0.5) * window.ew_res;
-		cell_northing=window.north - (next_r + 0.5) * window.ns_res;
-		cur_dist=tmp_dist+G_distance(easting,northing,cell_easting,cell_northing);
-			if(near)
-		done=(distance[next_r][next_c]>cur_dist||distance[next_r][next_c]==-1) ? 1: 0;
-			else
-		done=(distance[next_r][next_c]<cur_dist||distance[next_r][next_c]==-1) ? 1: 0;
-		if(done) {
-			distance[next_r][next_c]=cur_dist;
-				if(out_elev)
-			elevation[next_r][next_c]=target_elev-tmp_elevation[next_r*ncols+next_c];
+	    if (distance[r][c] == 1) {
+		distance[r][c] = 0;
+		if (out_elev)
+		    elevation[r][c] = 0;
-				if(dirs[r+nextr[dirs[r][c]]][c+nextc[dirs[r][c]]]<1)
-			continue;
+		next_r = r + nextr[dirs[r][c]];
+		next_c = c + nextc[dirs[r][c]];
-			d_inits[k].r=next_r;
-			d_inits[k].c=next_c;
-			d_inits[k].cur_dist=cur_dist;
+		if (dirs[next_r][next_c] < 0)
+		    continue;
+		if (distance[next_r][next_c] == 0)
+		    continue;
-				if(out_elev)
-			d_inits[k].target_elev=target_elev;
-			k++;
-		} /* end of if done */
+		d_inits[k].r = r;
+		d_inits[k].c = c;
+		d_inits[k].cur_dist = 0;
+		if (out_elev)
+		    d_inits[k].target_elev = tmp_elevation[r * ncols + c];
+		k++;
-	n_inits=k;
+    n_inits = k;
+    while (n_inits > 0) {
+	k = 0;
+	for (i = 0; i < n_inits; ++i) {
+	    r = d_inits[i].r;
+	    c = d_inits[i].c;
+	    tmp_dist = d_inits[i].cur_dist;
+	    if (out_elev)
+		target_elev = d_inits[i].target_elev;
+	    easting = window.west + (c + 0.5) * window.ew_res;
+	    northing = window.north - (r + 0.5) * window.ns_res;
+	    cell_easting = window.west + (next_c + 0.5) * window.ew_res;
+	    cell_northing = window.north - (next_r + 0.5) * window.ns_res;
+	    cur_dist =
+		tmp_dist + G_distance(easting, northing, cell_easting,
+				      cell_northing);
+	    if (near)
+		done = (distance[next_r][next_c] > cur_dist ||
+			distance[next_r][next_c] == -1) ? 1 : 0;
+	    else
+		done = (distance[next_r][next_c] < cur_dist ||
+	    if (done) {
+		distance[next_r][next_c] = cur_dist;
+		if (out_elev)
+		    elevation[next_r][next_c] =
+			target_elev - tmp_elevation[next_r * ncols + next_c];
+		if (dirs[r + nextr[dirs[r][c]]][c + nextc[dirs[r][c]]] < 1)
+		    continue;
+		d_inits[k].r = next_r;
+		d_inits[k].c = next_c;
+		d_inits[k].cur_dist = cur_dist;
+		if (out_elev)
+		    d_inits[k].target_elev = target_elev;
+		k++;
+	    }			/* end of if done */
+	n_inits = k;
+    return 0;
-return 0;
@@ -139,11 +142,9 @@
 int fill_maps(OUTLET outlet)
-    int r, c, val, i, j;
+    int r, c,  i, j;
     POINT n_cell;
     float cur_dist = 0;
     float tmp_dist = 0;
@@ -245,7 +246,7 @@
 POINT fifo_return_del(void)
-    if (head > fifo_max)
+    if (head >= fifo_max)
 	head = -1;
     return fifo_outlet[++head];
Modified: grass-addons/raster/r.stream.distance/global.h
--- grass-addons/raster/r.stream.distance/global.h	2010-06-03 11:31:48 UTC (rev 42457)
+++ grass-addons/raster/r.stream.distance/global.h	2010-06-03 11:32:18 UTC (rev 42458)
@@ -22,30 +22,30 @@
 #define RELATIVE 2
 POINT {
-	int r, c;
-float cur_dist;
-float target_elev;
+    int r, c;
+    float cur_dist;
+    float target_elev;
 #define OUTLET struct outs
 OUTLET {
-	int r, c;
-	float easting;
-	float northing;
+    int r, c;
+    float easting;
+    float northing;
 					/* functions.c */
 /* io.c */
-int open_raster(char *mapname);
+int open_raster(char *);
 int create_maps(void);
+int write_maps(char *, FCELL **);
 void free_streams (void);
 int write_distance(void);
 int write_elevation(void);
-int set_null_elev(void);
+int set_null(FCELL **);
 /* inits */
-int find_chatchment_outlets(void);
 int fill_catchments(OUTLET outlet);
 int find_outlets(void);
 int reset_distance(void);
Modified: grass-addons/raster/r.stream.distance/inits.c
--- grass-addons/raster/r.stream.distance/inits.c	2010-06-03 11:31:48 UTC (rev 42457)
+++ grass-addons/raster/r.stream.distance/inits.c	2010-06-03 11:32:18 UTC (rev 42458)
@@ -4,11 +4,10 @@
-    int d, i, j;		/* d: direction, i: iteration */
+    int d;		/* d: direction */
     int r, c;
     int next_stream = -1, cur_stream;
     int out_max = ncols + nrows;
@@ -100,11 +99,9 @@
-    int r, c,  i, j;
+    int r, c, i, j;
     float stop, val;
     POINT n_cell;
@@ -113,7 +110,7 @@
     r = outlet.r;
     c = outlet.c;
     val = 1;
-    stop =0;
+    stop = 0;
     distance[r][c] = stop;
@@ -125,14 +122,14 @@
 	    if (dirs[r + nextr[i]][c + nextc[i]] == j) {	/* countributing cell */
-			//		if (distance[r + nextr[i]][c + nextc[i]] == 0)
-		   // continue;	/* other outlet */
+		/* if (distance[r + nextr[i]][c + nextc[i]] == 0) */
+		/* continue; */ /* other outlet */
-		distance[r + nextr[i]][c + nextc[i]]=
-			(distance[r + nextr[i]][c + nextc[i]] == stop) ?
-			stop : val;
-		//distance[r + nextr[i]][c + nextc[i]] = val;
+		distance[r + nextr[i]][c + nextc[i]] =
+		    (distance[r + nextr[i]][c + nextc[i]] == stop) ?
+		    stop : val;
+		/* distance[r + nextr[i]][c + nextc[i]] = val; */
 		n_cell.r = (r + nextr[i]);
 		n_cell.c = (c + nextc[i]);
 		fifo_insert(n_cell);
@@ -146,5 +143,3 @@
     return 0;
Modified: grass-addons/raster/r.stream.distance/io.c
--- grass-addons/raster/r.stream.distance/io.c	2010-06-03 11:31:48 UTC (rev 42457)
+++ grass-addons/raster/r.stream.distance/io.c	2010-06-03 11:32:18 UTC (rev 42458)
@@ -86,7 +86,6 @@
 	    G_fatal_error(_("Unable to read raster maps at row <%d>"), r);
 	if (in_elev) {
 	    elevation[r] = (FCELL *) G_malloc(sizeof(FCELL) * ncols);
@@ -154,6 +153,7 @@
 	/* END dirs & streams  & accums */
     }				/*end for r */
     switch (elev_type) {
     case CELL_TYPE:
 	G_free(r_dem_c);
@@ -163,7 +163,6 @@
 	break;
     G_free(r_streams);
     G_free(r_dirs);
     G_percent(r, nrows, 2);
@@ -184,7 +183,7 @@
 int write_maps(char *mapname, FCELL ** map)
-    int r, c;
+    int r;
     int fd = 0;
     if ((fd = G_open_raster_new(mapname, FCELL_TYPE)) < 0)
Modified: grass-addons/raster/r.stream.distance/main.c
--- grass-addons/raster/r.stream.distance/main.c	2010-06-03 11:31:48 UTC (rev 42457)
+++ grass-addons/raster/r.stream.distance/main.c	2010-06-03 11:32:18 UTC (rev 42458)
@@ -32,20 +32,11 @@
 int main(int argc, char *argv[])
     struct GModule *module;	/* GRASS module for parsing arguments */
-    struct Option *in_dir_opt,
-									*in_stm_opt,
-									*in_elev_opt,
-									*in_method_opt,
-									*out_dist_opt,
-									*out_elev_opt;	/* options */
+    struct Option *in_dir_opt, *in_stm_opt, *in_elev_opt, *in_method_opt, *out_dist_opt, *out_elev_opt;	/* options */
     struct Flag *out_outs, *out_sub, *out_near;	/* flags */
+    char *method_name[] = { "upstream", "downstream" };
-    int link_max;
-		char* method_name[]={"upstream","downstream"};
     /* initialize GIS environment */
     G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
@@ -77,13 +68,13 @@
     in_elev_opt->required = NO;
     in_elev_opt->gisprompt = "old,cell,raster";
     in_elev_opt->description = "Name of elevation map";
     in_method_opt = G_define_option();
-		in_method_opt->key = "method";
-    in_method_opt->description ="Calculation method";
+    in_method_opt->key = "method";
+    in_method_opt->description = "Calculation method";
     in_method_opt->type = TYPE_STRING;
     in_method_opt->required = YES;
-    in_method_opt->options ="upstream,downstream";
+    in_method_opt->options = "upstream,downstream";
     in_method_opt->answer = "downstream";
     /*  output option - at least one is reqired  */
@@ -113,8 +104,8 @@
     out_sub->key = 's';
     out_sub->description =
 	_("Calculate parameters for subbasins (ignored in stream mode)");
-	  out_near = G_define_flag();
+    out_near = G_define_flag();
     out_near->key = 'n';
     out_near->description =
 	_("Calculate nearest local maximum (ignored in downstream calculation)");
@@ -146,12 +137,11 @@
 	    G_fatal_error(_("<%s> is an illegal file name"), out_elev);
+    if (!strcmp(in_method_opt->answer, "upstream"))
+	method = UPSTREAM;
+    else if (!strcmp(in_method_opt->answer, "downstream"))
+	method = DOWNSTREAM;
-			if (!strcmp(in_method_opt->answer, "upstream"))
-		method = UPSTREAM;
-			else if (!strcmp(in_method_opt->answer, "downstream"))
-		method = DOWNSTREAM;
     nrows = G_window_rows();
     ncols = G_window_cols();
     G_get_window(&window);
@@ -161,35 +151,37 @@
     find_outlets();
     reset_distance();
     free_streams();
-		G_message(_("Calculate %s distance"),method_name[method]);
-  if (method==UPSTREAM) {
-		int j;
-		fifo_max = 4 * (nrows + ncols);
-		fifo_outlet = (POINT *) G_malloc((fifo_max + 1) * sizeof(POINT));
-		for (j = 0; j < outlets_num; ++j) {
-			fill_catchments(outlets[j]);
-		G_free(fifo_outlet);
-		calculate_upstream();
-  if (method==DOWNSTREAM) {
-    /* fifo queue for contributing cell */
+    G_message(_("Calculate %s distance"), method_name[method]);
-			int j;
-	    fill_maps(outlets[j]);
+    if (method == UPSTREAM) {
+	int j;
+	fifo_max = 4 * (nrows + ncols);
+	fifo_outlet = (POINT *) G_malloc((fifo_max + 1) * sizeof(POINT));
+	for (j = 0; j < outlets_num; ++j) {
+	    fill_catchments(outlets[j]);
+	G_free(fifo_outlet);
+	calculate_upstream();
+    if (method == DOWNSTREAM) {
+	/* fifo queue for contributing cell */
+	    int j;
+		fill_maps(outlets[j]);
     if (out_elev) {
 	set_null(elevation);
 	write_maps(out_elev, elevation);
