[GRASS-SVN] r42588 - grass-addons/gui/wxpython/wx.path
Sat Jun 19 08:23:55 EDT 2010
Author: rashadkm
Date: 2010-06-19 12:23:55 +0000 (Sat, 19 Jun 2010)
New Revision: 42588
Added:
   grass-addons/gui/wxpython/wx.path/myroads.dbf
   grass-addons/gui/wxpython/wx.path/myroads.prj
   grass-addons/gui/wxpython/wx.path/myroads.shp
   grass-addons/gui/wxpython/wx.path/myroads.shx
   grass-addons/gui/wxpython/wx.path/mapdisplay_window.py
   grass-addons/gui/wxpython/wx.path/wx.path.py
added vector file
Modified: grass-addons/gui/wxpython/wx.path/mapdisplay_window.py
--- grass-addons/gui/wxpython/wx.path/mapdisplay_window.py	2010-06-19 11:55:19 UTC (rev 42587)
+++ grass-addons/gui/wxpython/wx.path/mapdisplay_window.py	2010-06-19 12:23:55 UTC (rev 42588)
@@ -108,6 +108,7 @@
         self.select = {}      # selecting/unselecting decorations for dragging
         self.textdict = {}    # text, font, and color indexed by id
         self.currtxtid = None # PseudoDC id for currently selected text
+        self.flag =False
         # Zoom objects
@@ -147,6 +148,7 @@
             return
         self.counter = self.counter + 1
+        self.flag=True
         point =("%.*f|%.*f" %  (precision, e, precision, n))
         self.points.append(point + '|point')
         if self.counter == 2:
@@ -176,6 +178,9 @@
             self.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
             self.UpdateMap(render=True)
             self.counter =0
+            self.points=[]
+            #os.remove("tmp1")
+            #os.remove("tmp2")
     def DefinePseudoDC(self, vdigit = False):
         """!Define PseudoDC class to use
@@ -913,7 +918,7 @@
         ### self.OnPaint(None)
         # update statusbar
-        self.parent.StatusbarUpdate()
+#        self.parent.StatusbarUpdate()
         self.Refresh()
         self.processMouse = True
Added: grass-addons/gui/wxpython/wx.path/myroads.dbf
(Binary files differ)
Property changes on: grass-addons/gui/wxpython/wx.path/myroads.dbf
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass-addons/gui/wxpython/wx.path/myroads.prj
--- grass-addons/gui/wxpython/wx.path/myroads.prj	                        (rev 0)
+++ grass-addons/gui/wxpython/wx.path/myroads.prj	2010-06-19 12:23:55 UTC (rev 42588)
@@ -0,0 +1 @@
+PROJCS["UTM Zone 13, Northern Hemisphere",GEOGCS["clark66",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-105],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
\ No newline at end of file
Added: grass-addons/gui/wxpython/wx.path/myroads.shp
Property changes on: grass-addons/gui/wxpython/wx.path/myroads.shp
Added: grass-addons/gui/wxpython/wx.path/myroads.shx
Property changes on: grass-addons/gui/wxpython/wx.path/myroads.shx
Modified: grass-addons/gui/wxpython/wx.path/wx.path.py
--- grass-addons/gui/wxpython/wx.path/wx.path.py	2010-06-19 11:55:19 UTC (rev 42587)
+++ grass-addons/gui/wxpython/wx.path/wx.path.py	2010-06-19 12:23:55 UTC (rev 42588)
@@ -92,7 +92,7 @@
         self.Maximize()
-        wx.MessageBox('Development has only started. currently works with spearfish data (myroads vector file). Kindly bear with me, Thankyou', 'Info')
+        wx.MessageBox('Development has only started. currently works with spearfish data (myroads vector file given in folder). Kindly bear with me, Thankyou', 'Info')
@@ -202,6 +202,8 @@
                 return
         self.statusbar.SetStatusText("%.*f; %.*f" %  (precision, e, precision, n), 0)
+        p = self.statusbar.GetStatusText()
+        self.statusbar.SetStatusText(p + "    Double Click to select Points")
         event.Skip()
