[GRASS-SVN] r41247 - grass-addons/raster/r.stream.distance
Mon Mar 1 01:43:38 EST 2010
Author: jarekj71
Date: 2010-03-01 01:43:36 -0500 (Mon, 01 Mar 2010)
New Revision: 41247
Added:
   grass-addons/raster/r.stream.distance/inits.c
missing file
Added: grass-addons/raster/r.stream.distance/inits.c
--- grass-addons/raster/r.stream.distance/inits.c	                        (rev 0)
+++ grass-addons/raster/r.stream.distance/inits.c	2010-03-01 06:43:36 UTC (rev 41247)
@@ -0,0 +1,150 @@
+#include <grass/glocale.h>
+#include "global.h"
+int find_outlets(void)
+    int d, i, j;		/* d: direction, i: iteration */
+    int r, c;
+    int next_stream = -1, cur_stream;
+    int out_max = ncols + nrows;
+    int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+    int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+    G_message(_("Finding nodes..."));
+    outlets = (OUTLET *) G_malloc((out_max) * sizeof(OUTLET));
+    outlets_num = 0;
+    for (r = 0; r < nrows; ++r) {
+	for (c = 0; c < ncols; ++c) {
+	    if (streams[r][c] > 0) {
+		if (outlets_num > (out_max - 1)) {
+		    out_max *= 2;
+		    outlets =
+			(OUTLET *) G_realloc(outlets,
+					     out_max * sizeof(OUTLET));
+		d = abs(dirs[r][c]);	/* abs */
+		if (r + nextr[d] < 0 || r + nextr[d] > (nrows - 1) ||
+		    c + nextc[d] < 0 || c + nextc[d] > (ncols - 1)) {
+		    next_stream = -1;	/* border */
+		else {
+		    next_stream = streams[r + nextr[d]][c + nextc[d]];
+		    if (next_stream < 1)
+			next_stream = -1;
+		if (d == 0)
+		    next_stream = -1;
+		cur_stream = streams[r][c];
+		if (subs && outs) {	/* in stream mode subs is ignored */
+		    if (cur_stream != next_stream) {	/* is outlet or node! */
+			outlets[outlets_num].r = r;
+			outlets[outlets_num].c = c;
+			outlets[outlets_num].northing =
+			    window.north - (r + .5) * window.ns_res;
+			outlets[outlets_num].easting =
+			    window.west + (c + .5) * window.ew_res;
+			outlets_num++;
+		else {
+		    if (cur_stream != next_stream && next_stream < 0) {	/* is outlet! */
+			outlets_num++;
+		}		/* end lasts */
+	    }			/* end if streams */
+	}			/* end for */
+    }				/* end for */
+    return 0;
+int reset_distance(void)
+    int r, c, i;
+    distance = (FCELL **) G_malloc(sizeof(FCELL *) * nrows);
+    if (!outs) {		/* stream mode */
+	    distance[r] = (FCELL *) G_malloc(sizeof(FCELL) * ncols);
+		distance[r][c] = (streams[r][c]) ? 0 : -1;
+	    }			/* r */
+	}			/* r */
+    else {			/* outlets mode */
+		distance[r][c] = -1;
+	for (i = 0; i < outlets_num; ++i) {
+	    distance[outlets[i].r][outlets[i].c] = 0;
+    return 0;
+int fill_catchments(OUTLET outlet)
+    int r, c,  i, j;
+    float stop, val;
+    POINT n_cell;
+    tail = 0;
+    head = -1;
+    r = outlet.r;
+    c = outlet.c;
+    val = 1;
+    stop =0;
+    distance[r][c] = stop;
+    while (tail != head) {
+	for (i = 1; i < 9; ++i) {
+	    if (r + nextr[i] < 0 || r + nextr[i] > (nrows - 1) ||
+		c + nextc[i] < 0 || c + nextc[i] > (ncols - 1))
+		continue;	/* out of border */
+	    j = (i + 4) > 8 ? i - 4 : i + 4;
+	    if (dirs[r + nextr[i]][c + nextc[i]] == j) {	/* countributing cell */
+			//		if (distance[r + nextr[i]][c + nextc[i]] == 0)
+		   // continue;	/* other outlet */
+		distance[r + nextr[i]][c + nextc[i]]=
+			(distance[r + nextr[i]][c + nextc[i]] == stop) ?
+			stop : val;
+		//distance[r + nextr[i]][c + nextc[i]] = val;
+		n_cell.r = (r + nextr[i]);
+		n_cell.c = (c + nextc[i]);
+		fifo_insert(n_cell);
+	}			/* end for i... */
+	n_cell = fifo_return_del();
+	r = n_cell.r;
+	c = n_cell.c;
+    return 0;
