[GRASS-SVN] r41300 - grass/trunk/vector/v.to.db
Fri Mar 5 13:50:18 EST 2010
Author: martinl
Date: 2010-03-05 13:50:18 -0500 (Fri, 05 Mar 2010)
New Revision: 41300
   grass/trunk/vector/v.to.db/global.h
   grass/trunk/vector/v.to.db/parse.c
   grass/trunk/vector/v.to.db/units.c
v.to.db: use libgis fns (units)
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h	2010-03-05 18:44:33 UTC (rev 41299)
+++ grass/trunk/vector/v.to.db/global.h	2010-03-05 18:50:18 UTC (rev 41300)
@@ -70,15 +70,6 @@
 #define O_AZIMUTH	15	/* line azimuth */
-#define U_ACRES		1
-#define U_HECTARES	2
-#define U_KILOMETERS	3
-#define U_METERS	4
-#define U_MILES		5
-#define U_FEET		6
-#define U_RADIANS	7
-#define U_DEGREES	8
 /* areas.c */
 int read_areas(struct Map_info *);
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c	2010-03-05 18:44:33 UTC (rev 41299)
+++ grass/trunk/vector/v.to.db/parse.c	2010-03-05 18:50:18 UTC (rev 41300)
@@ -75,17 +75,10 @@
 	"sinuous;line sinuousity, calculated as line length / distance between end points;"
 	"azimuth;line azimuth, calculated as angle between North direction and endnode direction at startnode";
-    parms.units = G_define_option();
-    parms.units->key = "units";
-    parms.units->type = TYPE_STRING;
-    parms.units->required = NO;
-    parms.units->multiple = NO;
+    parms.units = G_define_standard_option(G_OPT_M_UNITS);
     parms.units->options =
 	"miles,feet,meters,kilometers,acres,hectares,radians,degrees";
-    parms.units->label = _("Units");
-    parms.units->description =
-	_("miles,feet,meters,kilometers,acres,hectares,radians,degrees");
     parms.col = G_define_standard_option(G_OPT_DB_COLUMNS);
     parms.qcol = G_define_standard_option(G_OPT_DB_COLUMN);
Modified: grass/trunk/vector/v.to.db/units.c
--- grass/trunk/vector/v.to.db/units.c	2010-03-05 18:44:33 UTC (rev 41299)
+++ grass/trunk/vector/v.to.db/units.c	2010-03-05 18:50:18 UTC (rev 41300)
@@ -3,44 +3,15 @@
 int conv_units()
-    int i, rad = 0;
-    double f = 1.0, sq_f = 1.0;
+    int i, rad;
+    double f, sq_f;
-    switch (options.units) {
-    case U_METERS:
-	f = 1.0;
-	sq_f = 1.0;
-	break;
+    rad  = 0;
+    f    = G_units_to_meters_factor(options.units);
+    sq_f = G_units_to_meters_factor_sq(options.units);
-    case U_KILOMETERS:
-	f = 1.0e-3;
-	sq_f = 1.0e-6;
-	break;
-    case U_ACRES:
-	sq_f = 2.47105381467165e-4;	/* 640 acres in a sq mile */
-	break;
-    case U_HECTARES:
-	sq_f = 1.0e-4;
-	break;
-    case U_MILES:
-	f = 6.21371192237334e-4;	/*  1 / (0.0254 * 12 * 5280)    */
-	sq_f = 3.86102158542446e-7;	/*  1 / (0.0254 * 12 * 5280)^2  */
-	break;
-    case U_FEET:
-	f = 3.28083989501312;	/*  1 / (0.0254 * 12)    */
-	sq_f = 10.7639104167097;	/*  1 / (0.0254 * 12)^2  */
-	break;
-    case U_RADIANS:
+    if (options.units == U_RADIANS)
 	rad = 1;
-	break;
-    case U_DEGREES:
-	rad = 0;
-	break;
     switch (options.option) {
     case O_LENGTH:
