[GRASS-SVN] r41377 -
	grass/branches/releasebranch_6_4/raster/r.univar2
    svn_grass at osgeo.org
    Wed Mar 10 11:52:35 EST 2010
Author: hamish
Date: 2010-03-10 11:52:33 -0500 (Wed, 10 Mar 2010)
New Revision: 41377
   grass/branches/releasebranch_6_4/raster/r.univar2/globals.h
   grass/branches/releasebranch_6_4/raster/r.univar2/r.univar.html
   grass/branches/releasebranch_6_4/raster/r.univar2/r.univar_main.c
   grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar.html
   grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c
   grass/branches/releasebranch_6_4/raster/r.univar2/stats.c
support for non-integer percentiles (trac #873; merge from devbr6)
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/globals.h
--- grass/branches/releasebranch_6_4/raster/r.univar2/globals.h	2010-03-10 00:39:39 UTC (rev 41376)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/globals.h	2010-03-10 16:52:33 UTC (rev 41377)
@@ -30,7 +30,7 @@
     double min;
     double max;
     unsigned int n_perc;
-    int *perc;
+    double *perc;
     double sum_abs;
     int n;
     int size;
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/r.univar.html
--- grass/branches/releasebranch_6_4/raster/r.univar2/r.univar.html	2010-03-10 00:39:39 UTC (rev 41376)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/r.univar.html	2010-03-10 16:52:33 UTC (rev 41377)
@@ -9,6 +9,7 @@
 If the <b>-g</b> flag is given the results are presented in a format suitable
 for use in a shell script.
 <h2>NOTES</h2>
 As with most GRASS raster modules, <em>r.univar</em> operates on the cell
@@ -22,8 +23,6 @@
 <p>
 The <em>r.quantile</em> module will be significantly more efficient for
 calculating percentiles with large maps.
-In this version of the program the percentile option only calculates on
-whole integer values.
 <h2>TODO</h2>
@@ -31,7 +30,6 @@
 <i>mode, skewness, kurtosis</i>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/r.univar_main.c
--- grass/branches/releasebranch_6_4/raster/r.univar2/r.univar_main.c	2010-03-10 00:39:39 UTC (rev 41376)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/r.univar_main.c	2010-03-10 16:52:33 UTC (rev 41377)
@@ -31,7 +31,7 @@
     param.percentile = G_define_option();
     param.percentile->key = "percentile";
-    param.percentile->type = TYPE_INTEGER;
+    param.percentile->type = TYPE_DOUBLE;
     param.percentile->required = NO;
     param.percentile->multiple = YES;
     param.percentile->options = "0-100";
@@ -166,7 +166,7 @@
 	i++;
     stats = create_univar_stat_struct(map_type, size, i);
     for (i = 0; i < stats->n_perc; i++) {
-	sscanf(param.percentile->answers[i], "%i", &stats->perc[i]);
+	sscanf(param.percentile->answers[i], "%lf", &stats->perc[i]);
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar.html
--- grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar.html	2010-03-10 00:39:39 UTC (rev 41376)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar.html	2010-03-10 16:52:33 UTC (rev 41377)
@@ -9,6 +9,7 @@
 <h2>NOTES</h2>
 As with most GRASS raster3d modules, <em>r3.univar</em> operates on the cell
@@ -24,9 +25,6 @@
-<p>
 <h2>TODO</h2>
@@ -34,7 +32,6 @@
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c
--- grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c	2010-03-10 00:39:39 UTC (rev 41376)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c	2010-03-10 16:52:33 UTC (rev 41377)
@@ -30,7 +30,7 @@
@@ -118,7 +118,7 @@
 	i++;
     stats = create_univar_stat_struct(map_type, cols * rows * depths, i);
     stats->n = 0;
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/stats.c
--- grass/branches/releasebranch_6_4/raster/r.univar2/stats.c	2010-03-10 00:39:39 UTC (rev 41376)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/stats.c	2010-03-10 16:52:33 UTC (rev 41377)
@@ -28,7 +28,7 @@
     stats->max = 0.0 / 0.0;	/*set to nan as default */
     stats->n_perc = n_perc;
     if (n_perc > 0)
-	stats->perc = (int *)G_malloc(n_perc * sizeof(int));
+	stats->perc = (double *)G_malloc(n_perc * sizeof(double));
     else
 	stats->perc = NULL;
     stats->sum_abs = 0.0;
@@ -203,8 +203,10 @@
 	    fprintf(stdout, "median=%g\n", median);
 	    fprintf(stdout, "third_quartile=%g\n", quartile_75);
-		fprintf(stdout, "percentile_%d=%g\n", stats->perc[i],
-			quartile_perc[i]);
+		char buf[24];
+		sprintf(buf, "%.15g", stats->perc[i]);
+		G_strchg(buf, '.', '_');
+		fprintf(stdout, "percentile_%s=%g\n", buf, quartile_perc[i]);
 	else {
@@ -218,18 +220,38 @@
-		if (stats->perc[i] % 10 == 1 && stats->perc[i] != 11)
-		    fprintf(stdout, "%dst percentile: %g\n", stats->perc[i],
+		if (stats->perc[i] == (int)stats->perc[i]) {
+		    /* percentile is an exact integer */
+		    if ((int)stats->perc[i] % 10 == 1 && (int)stats->perc[i] != 11)
+			fprintf(stdout, "%dst percentile: %g\n", (int)stats->perc[i],
+				quartile_perc[i]);
+		    else if ((int)stats->perc[i] % 10 == 2 && (int)stats->perc[i] != 12)
+			fprintf(stdout, "%dnd percentile: %g\n", (int)stats->perc[i],
+		    else if ((int)stats->perc[i] % 10 == 3 && (int)stats->perc[i] != 13)
+			fprintf(stdout, "%drd percentile: %g\n", (int)stats->perc[i],
+		    else
+			fprintf(stdout, "%dth percentile: %g\n", (int)stats->perc[i],
+		else {
+		    /* percentile is not an exact integer */
+		    char buf[24], suffix[3];
+		    if (buf[strlen(buf)-1] == '1')
+			strcpy(suffix, "st");
+		    else if (buf[strlen(buf)-1] == '2')
+			strcpy(suffix, "nd");
+		    else if (buf[strlen(buf)-1] == '3')
+			strcpy(suffix, "rd");
+		    else
+			strcpy(suffix, "th");
+		    fprintf(stdout, "%.15g percentile: %g\n", stats->perc[i],
 			    quartile_perc[i]);
-		else if (stats->perc[i] % 10 == 2 && stats->perc[i] != 12)
-		    fprintf(stdout, "%dnd percentile: %g\n", stats->perc[i],
-		else if (stats->perc[i] % 10 == 3 && stats->perc[i] != 13)
-		    fprintf(stdout, "%drd percentile: %g\n", stats->perc[i],
-		else
-		    fprintf(stdout, "%dth percentile: %g\n", stats->perc[i],
 	G_free((void *)quartile_perc);
