[GRASS-SVN] r41442 - grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
Mon Mar 15 08:18:25 EDT 2010
Author: martinl
Date: 2010-03-15 08:18:24 -0400 (Mon, 15 Mar 2010)
New Revision: 41442
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
bugfix #928
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py	2010-03-14 21:10:06 UTC (rev 41441)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py	2010-03-15 12:18:24 UTC (rev 41442)
@@ -95,13 +95,13 @@
                 aborted = False
             time.sleep(.1)
             event = wxCmdDone(aborted = aborted,
                               returncode = returncode,
                               time = requestTime,
                               pid = requestId,
                               onDone = onDone)
             wx.PostEvent(self.parent, event)
     def abort(self):
@@ -289,17 +289,17 @@
             self.Map = curr_disp.GetRender()
         except:
             curr_disp = None
         # command given as a string ?
         try:
             cmdlist = command.strip().split(' ')
         except:
             cmdlist = command
         if cmdlist[0] in globalvar.grassCmd['all']:
             # send GRASS command without arguments to GUI command interface
             # except display commands (they are handled differently)
-            if cmdlist[0][0:2] == "d.":
+            if self.parent.GetName() == "LayerManager" and cmdlist[0][0:2] == "d.":
                 # display GRASS commands
@@ -319,13 +319,15 @@
                                  'd.rhumbline'    : 'rhumb',
                                  'd.labels'       : 'labels'}[cmdlist[0]]
                 except KeyError:
-                    wx.MessageBox(message=_("Command '%s' not yet implemented in the GUI. Try adding it as a command layer instead.") % cmdlist[0])
+                    wx.MessageBox(caption = _("Message"),
+                                  message=_("Command '%s' not yet implemented in the GUI. "
+                                            "Try adding it as a command layer instead.") % cmdlist[0])
                     return None
                 # add layer into layer tree
-                self.parent.curr_page.maptree.AddLayer(ltype=layertype,
-                                                       lcmd=cmdlist)
+                if self.parent.GetName() == "LayerManager":
+                    self.parent.curr_page.maptree.AddLayer(ltype=layertype,
+                                                           lcmd=cmdlist)
             else:
                 # other GRASS commands (r|v|g|...)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2010-03-14 21:10:06 UTC (rev 41441)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2010-03-15 12:18:24 UTC (rev 41442)
@@ -936,13 +936,13 @@
         return cmd
     def OnRun(self, event):
-        """Run the command"""
+        """!Run the command"""
         cmd = self.createCmd()
         if cmd == None or len(cmd) < 2:
             return
-        if cmd[0][0:2] != "d.":
+        if self.standalone or cmd[0][0:2] != "d.":
             # Send any non-display command to parent window (probably wxgui.py)
             # put to parents
             # switch to 'Command output'
@@ -951,13 +951,13 @@
             try:
                 self.goutput.RunCmd(cmd)
-            except AttributeError,e:
+            except AttributeError, e:
                 print >> sys.stderr, "%s: Propably not running in wxgui.py session?" % (e)
                 print >> sys.stderr, "parent window is: %s" % (str(self.parent))
             # Send any other command to the shell.
         else:
             gcmd.Command(cmd)
         # update buttons status
         for btn in (self.btn_run,
                     self.btn_cancel,
