[GRASS-SVN] r41480 - grass/branches/develbranch_6/vector/v.info
Fri Mar 19 12:19:59 EDT 2010
Author: neteler
Date: 2010-03-19 12:19:59 -0400 (Fri, 19 Mar 2010)
New Revision: 41480
   grass/branches/develbranch_6/vector/v.info/description.html
   grass/branches/develbranch_6/vector/v.info/main.c
backported support for level 1 by Markus Metz
Modified: grass/branches/develbranch_6/vector/v.info/description.html
--- grass/branches/develbranch_6/vector/v.info/description.html	2010-03-19 16:11:02 UTC (rev 41479)
+++ grass/branches/develbranch_6/vector/v.info/description.html	2010-03-19 16:19:59 UTC (rev 41480)
@@ -1,7 +1,11 @@
 <h2>DESCRIPTION</h2>
 <em>v.info</em> reports some basic information about a
-user-specified vector map layer and the topology status.
+user-specified vector map layer and the topology status.
+<p>
+Vector are opened without topology on level 1 when the <b>-l</b> flag is
+used. With the <b>-l</b> flag set, vector map extends and number of
+features need to be counted on the fly which may take some time.
 <h2>EXAMPLE</h2>
Modified: grass/branches/develbranch_6/vector/v.info/main.c
--- grass/branches/develbranch_6/vector/v.info/main.c	2010-03-19 16:11:02 UTC (rev 41479)
+++ grass/branches/develbranch_6/vector/v.info/main.c	2010-03-19 16:19:59 UTC (rev 41480)
@@ -4,15 +4,16 @@
  * MODULE:       v.info
  * AUTHOR(S):    CERL, updated to 5.7 by Markus Neteler
+ *               Update to 7.0 by Martin Landa <landa.martin gmail.com> (2009)
+ *               Support for level 1 by Markus Metz (2009)
- * PURPOSE:      print vector map info
+ * PURPOSE:      Print vector map info
- * COPYRIGHT:    (C) 2002 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2009 by the GRASS Development Team
- *               This program is free software under the
- *               GNU General Public License (>=v2).
- *               Read the file COPYING that comes with GRASS
- *               for details.
+ *               This program is free software under the GNU General
+ *               Public License (>=v2).  Read the file COPYING that
+ *               comes with GRASS for details.
 #include <string.h>
@@ -37,13 +38,13 @@
 void format_double(double, char *);
+int level_one_info(struct Map_info *);
 int main(int argc, char *argv[])
     struct GModule *module;
     struct Option *in_opt, *fieldopt;
-    struct Flag *histf, *columns, *gflag, *tflag, *mflag;
+    struct Flag *histf, *columns, *gflag, *tflag, *mflag, *lflag;
     struct Map_info Map;
     struct dig_head v_head;
     BOUND_BOX box;
@@ -86,6 +87,10 @@
     gflag->description = _("Print map region only");
     gflag->guisection = _("Print");
+    lflag = G_define_flag();
+    lflag->key = 'l';
+    lflag->description = _("Open Vector without topology (level 1)");
     mflag = G_define_flag();
     mflag->key = 'm';
     mflag->description = _("Print map title only");
@@ -104,8 +109,23 @@
 	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
-    Vect_set_open_level(2);
-    Vect_open_old_head(&Map, in_opt->answer, mapset);
+    if (lflag->answer) {
+        Vect_set_open_level(1); /* no topology */
+        if (tflag->answer && Vect_get_num_primitives(&Map, GV_POINT) == 0){
+            G_warning(_("Vector map requested on level 1 (flag -t ignored)"));
+            tflag->answer = 0;
+    else
+      Vect_set_open_level(2); /* topology requested */
+       Vect_open_old(&Map, in_opt->answer, "");
+       level_one_info(&Map);
+    else
+      Vect_open_old_head(&Map, in_opt->answer, "");
     with_z = Vect_is_3d(&Map);
     v_head = Map.head;
@@ -258,7 +278,7 @@
 	    printline(line);
-	    if (Vect_level(&Map) > 1) {
+	    if (Vect_level(&Map) > 0) {
 		printline("");
 		sprintf(line,
 			_("  Number of points:       %-9ld       Number of areas:      %-9ld"),
@@ -288,10 +308,6 @@
 			(long)Vect_get_num_dblinks(&Map));
 		printline(line);
-	    else {		/* should not be reached */
-		sprintf(line, _("                No topology present"));
-		printline(line);
 	    printline("");
 	    /* this differs from r.info in that proj info IS taken from the map here, not the location settings */
@@ -348,3 +364,88 @@
     sprintf(buf, "%.8f", value);
     G_trim_decimal(buf);
+/* code taken from Vect_build_nat() */
+int level_one_info(struct Map_info *Map)
+    struct Plus_head *plus;
+    int i, type, first = 1;
+    off_t offset;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    struct bound_box box;
+    int n_primitives, n_points, n_lines, n_boundaries, n_centroids, n_kernels;
+    G_debug(1, "Count vector objects for level 1");
+    plus = &(Map->plus);
+    n_primitives = n_points = n_lines = n_boundaries = n_centroids = n_kernels = 0;
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    Vect_rewind(Map);
+    /* G_message(_("Registering primitives...")); */
+    i = 1;
+    while (1) {
+	/* register line */
+	type = Vect_read_next_line(Map, Points, Cats);
+	/* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+	if (type == -1) {
+	    G_warning(_("Unable to read vector map"));
+	    return 0;
+	else if (type == -2) {
+	    break;
+	/* count features */
+	n_primitives++;
+	if (type & GV_POINT)  /* probably most common */
+	    n_points++;
+	else if (type & GV_LINE)
+	    n_lines++;
+	else if (type & GV_BOUNDARY)
+	    n_boundaries++;
+	else if (type & GV_CENTROID)
+	    n_centroids++;
+	else if (type & GV_KERNEL)
+	    n_kernels++;
+	offset = Map->head.last_offset;
+	G_debug(3, "Register line: offset = %lu", (unsigned long)offset);
+	dig_line_box(Points, &box);
+	if (first == 1) {
+	    Vect_box_copy(&(plus->box), &box);
+	    first = 0;
+	else
+	    Vect_box_extend(&(plus->box), &box);
+	/* can't print progress, unfortunately */
+	if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
+	    if (format == G_INFO_FORMAT_PLAIN)
+		fprintf(stderr, "%d..", i);
+	    else
+		fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", i);
+	i++;
+    /* save result in plus */
+    plus->n_lines = n_primitives;
+    plus->n_plines = n_points;
+    plus->n_llines = n_lines;
+    plus->n_blines = n_boundaries;
+    plus->n_clines = n_centroids;
+    plus->n_klines = n_kernels;
+    return 1;
