[GRASS-SVN] r41521 - grass/trunk/raster/r.external.out
Mon Mar 22 10:12:21 EDT 2010
Author: glynn
Date: 2010-03-22 10:12:19 -0400 (Mon, 22 Mar 2010)
New Revision: 41521
   grass/trunk/raster/r.external.out/main.c
Add -p flag (print current status)
Modified: grass/trunk/raster/r.external.out/main.c
--- grass/trunk/raster/r.external.out/main.c	2010-03-22 08:04:30 UTC (rev 41520)
+++ grass/trunk/raster/r.external.out/main.c	2010-03-22 14:12:19 UTC (rev 41521)
@@ -95,6 +95,38 @@
     return buf;
+static void print_status(void)
+    FILE *fp;
+    struct Key_Value *key_val;
+    const char *p;
+    if (!G_find_file2("", "GDAL", G_mapset())) {
+	fprintf(stdout, "Not using GDAL\n");
+	return;
+    fp = G_fopen_old("", "GDAL", G_mapset());
+    if (!fp)
+	G_fatal_error(_("Unable to open GDAL file"));
+    key_val = G_fread_key_value(fp);
+    fclose(fp);
+    p = G_find_key_value("directory", key_val);
+    fprintf(stdout, "directory: %s\n", p ? p : "not set (default 'gdal')");
+    p = G_find_key_value("extension", key_val);
+    fprintf(stdout, "extension: %s\n", p ? p : "<none>");
+    p = G_find_key_value("format", key_val);
+    fprintf(stdout, "format: %s\n", p ? p : "not set (default GTiff)");
+    p = G_find_key_value("options", key_val);
+    fprintf(stdout, "options: %s\n", p ? p : "<none>");
+    G_free_key_value(key_val);
 static void check_format(const char *format)
     GDALDriverH driver = GDALGetDriverByName(format);
@@ -172,7 +204,7 @@
     struct {
 	struct Option *dir, *ext, *format, *opts;
     } parm;
-    struct Flag *flag_f, *flag_r;
+    struct Flag *flag_f, *flag_r, *flag_p;
     G_gisinit(argv[0]);
@@ -219,9 +251,19 @@
     flag_r->key = 'r';
     flag_r->description = _("Cease using GDAL and revert to native output");
+    flag_p = G_define_flag();
+    flag_p->key = 'p';
+    flag_p->description = _("Print current status");
+    flag_p->guisection = _("Print");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    if (flag_p->answer) {
+	print_status();
+	exit(EXIT_SUCCESS);
     if (flag_f->answer) {
 	list_formats();
 	exit(EXIT_SUCCESS);
