[GRASS-SVN] r42199 - grass/trunk/gui/scripts
Sun May 9 16:50:28 EDT 2010
Author: martinl
Date: 2010-05-09 16:50:28 -0400 (Sun, 09 May 2010)
New Revision: 42199
Removed:
   grass/trunk/gui/scripts/v.type_wrapper.py
v.type wrapper not needed, removed
Deleted: grass/trunk/gui/scripts/v.type_wrapper.py
--- grass/trunk/gui/scripts/v.type_wrapper.py	2010-05-09 18:51:27 UTC (rev 42198)
+++ grass/trunk/gui/scripts/v.type_wrapper.py	2010-05-09 20:50:28 UTC (rev 42199)
@@ -1,91 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       v.type_wrapper.py (v.type wrapper script)
-# AUTHOR(S):    Hamish Bowman  (Otago University, New Zealand)
-#               (original contributor, v.type.sh)
-#               Pythonized by Martin Landa <landa.martin gmail.com> (2008/08)
-# PURPOSE:      Supply v.type options in a GUI compatible way
-# COPYRIGHT:    (C) 2007-2008 by Hamish Bowman, and the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-#%module
-#% description: Change the type of geometry elements.
-#% keywords: vector, geometry
-#%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#%end
-#%option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name for output vector map
-#% gisprompt: new,vector,vector
-#%end
-#%option
-#% key: type
-#% type: string
-#% required: no
-#% multiple: no
-#% options: point to centroid,point to kernel,centroid to point,centroid to kernel,kernel to point,kernel to centroid,line to boundary,line to face,boundary to line,boundary to face,face to line,face to boundary
-#% description: Conversion
-#% answer: boundary to line
-#%end
-import sys
-from grass.script import core as grass
-def main():
-    if options['type'] == "point to centroid":
-        type_cnv = "point,centroid"
-    elif options['type'] == "point to kernel":
-        type_cnv = "point,kernel"
-    elif options['type'] == "centroid to point":
-        type_cnv = "centroid,point"
-    elif options['type'] == "centroid to kernel":
-        type_cnv = "centroid,kernel"
-    elif options['type'] == "kernel to point":
-        type_cnv = "kernel,point"
-    elif options['type'] == "kernel to centroid":
-        type_cnv = "kernel,centroid"
-    elif options['type'] == "line to boundary":
-        type_cnv = "line,boundary"
-    elif options['type'] == "line to face":
-        type_cnv = "line,face"
-    elif options['type'] == "boundary to line":
-        type_cnv = "boundary,line"
-    elif options['type'] == "boundary to face":
-        type_cnv = "boundary,face"
-    elif options['type'] == "face to line":
-        type_cnv = "face,line"
-    elif options['type'] == "face to boundary":
-        type_cnv = "face,boundary"
-    options.pop('type')
-    grass.exec_command("v.type", type = type_cnv, **options)
-    return 0
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
