[GRASS-SVN] r44171 - in grass/branches/releasebranch_6_4/gui/wxpython: . gui_modules xml
Tue Nov 2 10:53:07 EDT 2010
Author: martinl
Date: 2010-11-02 07:53:07 -0700 (Tue, 02 Nov 2010)
New Revision: 44171
Removed:
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py
   grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
   grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
wxGUI: georect replaced by gcpmanager
(merge r44168 from devbr6)
Deleted: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py	2010-11-02 14:51:27 UTC (rev 44170)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py	2010-11-02 14:53:07 UTC (rev 44171)
@@ -1,1796 +0,0 @@
- at package georect.py
- at brief Georectification module for GRASS GIS. Includes ground control
-point management and interactive point and click GCP creation
-Classes:
- - GeorectWizard
- - LocationPage
- - GroupPage
- - DispMapPage
- - GCP
- - GCPList
- - VectGroup
- - EditGCP
- - GrSettingsDialog
-(C) 2006-2010 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Michael Barton
- at author Updated by Martin Landa <landa.martin gmail.com>
-import os
-import sys
-import tempfile
-import shutil
-import time
-import wx
-from wx.lib.mixins.listctrl import CheckListCtrlMixin, ListCtrlAutoWidthMixin, TextEditMixin
-import wx.lib.colourselect as  csel
-import wx.wizard as wiz
-import grass.script as grass
-import globalvar
-import mapdisp
-import render
-import toolbars
-import menuform
-import gselect
-import gcmd
-import utils
-from debug import Debug as Debug
-from icon import Icons as Icons
-from location_wizard import TitledPage as TitledPage
-from preferences import globalSettings as UserSettings
-try:
-    import subprocess # Not needed if GRASS commands could actually be quiet
-except:
-    CompatPath = globalvar.ETCWXDIR
-    sys.path.append(CompatPath)
-    from compat import subprocess
-gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
-sys.path.append(gmpath)
-# global variables
-global xy_map
-global maptype
-xy_map = ''
-maptype = 'cell'
-class GeorectWizard(object):
-    Start wizard here and finish wizard here
-    def __init__(self, parent):
-        self.parent = parent # GMFrame
-        # get environmental variables
-        self.grassdatabase = grass.gisenv()['GISDBASE']
-        # read original environment settings
-        self.orig_gisrc = os.environ['GISRC']
-        self.gisrc_dict = {}
-        try:
-            f = open(self.orig_gisrc, 'r')
-            for line in f.readlines():
-                line = line.replace('\n', '').strip()
-                if len(line) < 1:
-                    continue
-                key, value = line.split(':', 1)
-                self.gisrc_dict[key.strip()] = value.strip()
-        finally:
-            f.close()
-        self.currentlocation = self.gisrc_dict['LOCATION_NAME']
-        self.currentmapset = self.gisrc_dict['MAPSET']
-        # location for xy map to georectify
-        self.newlocation = ''
-        # mapset for xy map to georectify
-        self.newmapset = ''
-        # GISRC file for source location/mapset of map(s) to georectify
-        self.new_gisrc = ''
-        # define wizard pages
-        self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY, title=_("Setup for georectification"))
-        self.startpage = LocationPage(self.wizard, self)
-        self.grouppage = GroupPage(self.wizard, self)
-        self.mappage = DispMapPage(self.wizard, self)
-        # set the initial order of the pages
-        self.startpage.SetNext(self.grouppage)
-        self.grouppage.SetPrev(self.startpage)
-        self.grouppage.SetNext(self.mappage)
-        self.mappage.SetPrev(self.grouppage)
-        # do pages layout
-        self.startpage.DoLayout()
-        self.grouppage.DoLayout()
-        self.mappage.DoLayout()
-        self.wizard.FitToPage(self.startpage)
-        # self.Bind(wx.EVT_CLOSE,    self.Cleanup)
-        # self.parent.Bind(wx.EVT_ACTIVATE, self.OnGLMFocus)
-        success = False
-        # run wizard
-        if self.wizard.RunWizard(self.startpage):
-            success = self.OnWizFinished()
-            if success == False:
-                wx.MessageBox(parent=self.parent,
-                              message=_("Georectifying setup canceled."),
-                              caption=_("Georectify"),
-                              style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
-                self.Cleanup()
-        else:
-            self.Cleanup()
-        # start display showing xymap
-        if success != False:
-            # instance of render.Map to be associated with display
-            self.Map = render.Map(gisrc=self.new_gisrc)
-            global maptype
-            global xy_map
-            # add layer to map
-            if maptype == 'cell':
-                rendertype = 'raster'
-                cmdlist = ['d.rast', 'map=%s' % xy_map]
-            else: # -> vector layer
-                rendertype = 'vector'
-                cmdlist = ['d.vect', 'map=%s' % xy_map]
-            self.Map.AddLayer(type=rendertype, command=cmdlist, l_active=True,
-                              name=utils.GetLayerNameFromCmd(cmdlist),
-                              l_hidden=False, l_opacity=1.0, l_render=False)
-            # start GCP form
-            self.gcpmgr = GCP(self.parent, grwiz=self)
-            self.gcpmgr.Show()
-            # start map display
-            self.xy_mapdisp = mapdisp.MapFrame(self.gcpmgr, name = "GRMapWindow",
-                                               size=globalvar.MAP_WINDOW_SIZE,
-                                               toolbars=["georect"],
-                                               Map=self.Map, lmgr=self.parent)
-            self.xy_mapdisp.SetTitle(_("GRASS GIS Map Display: 1" +
-                                       " - Location: " + self.newlocation +
-                                       " (source location)"))
-            self.xy_mapdisp.GetWindow().ResetZoomHistory()
-            self.gcpmgr.SetMapDisplay(self.xy_mapdisp)
-            self.mapwin = self.xy_mapdisp.MapWindow
-            # set mouse characteristics
-            self.mapwin.mouse['box'] = 'point'
-            self.mapwin.mouse["use"] == "pointer"
-            self.mapwin.zoomtype = 0
-            self.mapwin.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
-            self.mapwin.SetCursor(self.xy_mapdisp.cursors["cross"])
-            # show new display & draw map
-            self.xy_mapdisp.toolbars['georect'].OnZoomMap(None)
-            self.xy_mapdisp.CenterOnScreen()
-            self.xy_mapdisp.Show()
-            self.gcpmgr.Centre()
-            self.gcpmgr.Raise()
-        else:
-            self.Cleanup()
-    def SetSrcEnv(self, location, mapset):
-        """!Create environment to use for location and mapset
-        that are the source of the file(s) to georectify
-        @param location source location
-        @param mapset source mapset
-        @return False on error
-        @return True on success
-        self.newlocation = location
-        self.newmapset = mapset
-        # check to see if we are georectifying map in current working location/mapset
-        if self.newlocation == self.currentlocation and self.newmapset == self.currentmapset:
-            return False
-        self.gisrc_dict['LOCATION_NAME'] = location
-        self.gisrc_dict['MAPSET'] = mapset
-        self.new_gisrc = utils.GetTempfile()
-        try:
-            f = open(self.new_gisrc, mode='w')
-            for line in self.gisrc_dict.items():
-                f.write(line[0] + ": " + line[1] + "\n")
-        finally:
-            f.close()
-        return True
-    def SwitchEnv(self, grc):
-        Switches between original working location/mapset and
-        location/mapset that is source of file(s) to georectify
-            return False
-        if grc == 'original':
-            os.environ["GISRC"] = str(self.orig_gisrc)
-        elif grc == 'new':
-            os.environ["GISRC"] = str(self.new_gisrc)
-        return True
-    def OnWizFinished(self):
-        # self.Cleanup()
-        return True
-    def OnGLMFocus(self, event):
-        """!Layer Manager focus"""
-        # self.SwitchEnv('original')
-        event.Skip()
-    def Cleanup(self):
-        """!Return to current location and mapset"""
-        self.SwitchEnv('original')
-        self.parent.georectifying = None
-        if hasattr(self, "xy_mapdisp") and \
-                self.xy_mapdisp:
-            self.xy_mapdisp.Close()
-            self.xy_mapdisp = None
-        self.wizard.Destroy()
-        # clear GCPs from target display
-        self.parent.curr_page.maptree.mapdisplay.MapWindow.UpdateMap(render=False)
-class LocationPage(TitledPage):
-    Set map type (raster or vector) to georectify and
-    select location/mapset of map(s) to georectify.
-    def __init__(self, wizard, parent):
-        TitledPage.__init__(self, wizard, _("Select map type and location/mapset"))
-        self.grassdatabase = self.parent.grassdatabase
-        self.xylocation = ''
-        self.xymapset = ''
-        # layout
-        self.sizer.AddGrowableCol(2)
-        # map type
-        self.rb_maptype = wx.RadioBox(parent=self, id=wx.ID_ANY,
-                                      label=' %s ' % _("Map type to georectify"),
-                                      choices=[_('raster'), _('vector')],
-                                      majorDimension=wx.RA_SPECIFY_COLS)
-        self.sizer.Add(item=self.rb_maptype,
-                       flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
-                       pos=(1, 1), span=(1, 2))
-        # location
-        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select source location:')),
-                       flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5,
-                       pos=(2, 1))
-        self.cb_location = gselect.LocationSelect(parent = self, gisdbase = self.grassdatabase)
-        self.sizer.Add(item=self.cb_location,
-                       pos=(2, 2))
-        # mapset
-        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select source mapset:')),
-                       pos=(3, 1))
-        self.cb_mapset = gselect.MapsetSelect(parent = self, gisdbase = self.grassdatabase,
-                                              setItems = False)
-        self.sizer.Add(item=self.cb_mapset,
-                       pos=(3,2))
-        # bindings
-        self.Bind(wx.EVT_RADIOBOX, self.OnMaptype, self.rb_maptype)
-        self.Bind(wx.EVT_COMBOBOX, self.OnLocation, self.cb_location)
-        self.Bind(wx.EVT_COMBOBOX, self.OnMapset, self.cb_mapset)
-        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
-        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
-        # self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
-    def OnMaptype(self,event):
-        """!Change map type"""
-        global maptype
-        if event.GetInt() == 0:
-            maptype = 'cell'
-        else:
-            maptype = 'vector'
-    def OnLocation(self, event):
-        """!Sets source location for map(s) to georectify"""
-        self.xylocation = event.GetString()
-        #create a list of valid mapsets
-        tmplist = os.listdir(os.path.join(self.grassdatabase, self.xylocation))
-        self.mapsetList = []
-        for item in tmplist:
-            if os.path.isdir(os.path.join(self.grassdatabase, self.xylocation, item)) and \
-                os.path.exists(os.path.join(self.grassdatabase, self.xylocation, item, 'WIND')):
-                if item != 'PERMANENT':
-                    self.mapsetList.append(item)
-        self.xymapset = 'PERMANENT'
-        utils.ListSortLower(self.mapsetList)
-        self.mapsetList.insert(0, 'PERMANENT')
-        self.cb_mapset.SetItems(self.mapsetList)
-        self.cb_mapset.SetStringSelection(self.xymapset)
-        if not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
-            wx.FindWindowById(wx.ID_FORWARD).Enable(True)
-    def OnMapset(self, event):
-        """!Sets source mapset for map(s) to georectify"""
-        if self.xylocation == '':
-            wx.MessageBox(_('You must select a valid location before selecting a mapset'))
-            return
-        self.xymapset = event.GetString()
-    def OnPageChanging(self, event=None):
-        if event.GetDirection() and \
-               (self.xylocation == '' or self.xymapset == ''):
-            wx.MessageBox(_('You must select a valid location and mapset in order to continue'))
-            event.Veto()
-            return
-        self.parent.SetSrcEnv(self.xylocation, self.xymapset)
-    def OnEnterPage(self, event=None):
-        if self.xylocation == '' or self.xymapset == '':
-            wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-        else:
-class GroupPage(TitledPage):
-    Set group to georectify. Create group if desired.
-        TitledPage.__init__(self, wizard, _("Select image/map group to georectify"))
-        self.groupList = []
-        self.xygroup = ''
-        # default extension
-        self.extension = 'georect' + str(os.getpid())
-        # layout
-        # group
-        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select group:')),
-                       pos=(1, 1))
-        self.cb_group = wx.ComboBox(parent=self, id=wx.ID_ANY,
-                                    choices=self.groupList, size=(350, -1),
-                                    style=wx.CB_DROPDOWN | wx.CB_READONLY)
-        self.sizer.Add(item=self.cb_group,
-                       pos=(1, 2))
-        # create group
-        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Create group if none exists')),
-                       pos=(2, 1))
-        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
-        self.btn_mkgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Create/edit group..."))
-        self.btn_vgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Add vector map to group..."))
-        btnSizer.Add(item=self.btn_mkgroup,
-                     flag=wx.RIGHT, border=5)
-        btnSizer.Add(item=self.btn_vgroup,
-                     flag=wx.LEFT, border=5)
-        self.sizer.Add(item=btnSizer,
-                       pos=(2, 2))
-        # extension
-        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Extension for output maps:')),
-                       pos=(3, 1))
-        self.ext_txt = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(350,-1))
-        self.ext_txt.SetValue(self.extension)
-        self.sizer.Add(item=self.ext_txt,
-                       pos=(3, 2))
-        # bindings
-        self.Bind(wx.EVT_COMBOBOX, self.OnGroup, self.cb_group)
-        self.Bind(wx.EVT_TEXT, self.OnExtension, self.ext_txt)
-        self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
-        # hide vector group button by default
-        self.btn_vgroup.Hide()
-    def OnGroup(self, event):
-        self.xygroup = event.GetString()
-    def OnMkGroup(self, event):
-        """!Create new group in source location/mapset"""
-        menuform.GUI().ParseCommand(['i.group'],
-                                    completed=(self.GetOptData, None, ''),
-                                    parentframe=self.parent.parent, modal=True)
-    def OnVGroup(self, event):
-        """!Add vector maps to group"""
-        dlg = VectGroup(parent = self,
-                        id = wx.ID_ANY,
-                        grassdb = self.grassdatabase,
-                        location = self.xylocation,
-                        mapset = self.xymapset,
-                        group = self.xygroup)
-        if dlg.ShowModal() != wx.ID_OK:
-            return
-        dlg.MakeVGroup()
-        self.OnEnterPage()
-    def GetOptData(self, dcmd, layer, params, propwin):
-        """!Process i.group"""
-        # update the page
-        if dcmd:
-            gcmd.Command(dcmd)
-        self.Update()
-    def OnExtension(self, event):
-        self.extension = event.GetString()
-        if event.GetDirection() and self.xygroup == '':
-            wx.MessageBox(_('You must select a valid image/map group in order to continue'))
-            event.Veto()
-            return
-        if event.GetDirection() and self.extension == '':
-            wx.MessageBox(_('You must enter an map name extension in order to continue'))
-            event.Veto()
-            return
-        global maptype
-        self.xylocation = self.parent.gisrc_dict['LOCATION_NAME']
-        self.xymapset = self.parent.gisrc_dict['MAPSET']
-        # create a list of groups in selected mapset
-                                      self.xylocation,
-                                      self.xymapset,
-                                      'group')):
-                                              self.xylocation,
-                                              self.xymapset,
-                                              'group'))
-                                              self.xylocation,
-                                              self.xymapset,
-                                              'group',
-                                              item)):
-                    self.groupList.append(item)
-            self.Bind(wx.EVT_BUTTON, self.OnMkGroup, self.btn_mkgroup)
-        elif maptype == 'vector':
-            self.btn_vgroup.Show()
-            self.Bind(wx.EVT_BUTTON, self.OnVGroup, self.btn_vgroup)
-        utils.ListSortLower(self.groupList)
-        self.cb_group.SetItems(self.groupList)
-        if len(self.groupList) > 0 and \
-                self.xygroup == '':
-            self.cb_group.SetSelection(0)
-            self.xygroup = self.groupList[0]
-        if self.xygroup == '' or \
-                self.extension == '':
-        else:
-        # switch to source
-        self.parent.SwitchEnv('new')
-class DispMapPage(TitledPage):
-    Select ungeoreferenced map to display for interactively
-    setting ground control points (GCPs).
-                            _("Select image/map to display for ground control point (GCP) creation"))
-        global maptype
-        # layout
-        self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select display image/map:')),
-                       pos=(1, 1))
-        self.selection = gselect.Select(self, id=wx.ID_ANY,
-                                        size=globalvar.DIALOG_GSELECT_SIZE, type='cell')
-        self.sizer.Add(item=self.selection,
-                       pos=(1, 2))
-        # bindings
-        self.selection.Bind(wx.EVT_TEXT, self.OnSelection)
-    def OnSelection(self,event):
-        """!Map to display selected"""
-        global xy_map
-        global maptype
-        xy_map = event.GetString()
-        if xy_map == '':
-        else:
-        try:
-        # set computational region to match selected map and zoom display to region
-                p = gcmd.Command(['g.region', 'rast=xy_map'])
-                p = gcmd.Command(['g.region', 'vect=xy_map'])
-            if p.returncode == 0:
-                print 'returncode = ', str(p.returncode)
-                self.parent.Map.region = self.parent.Map.GetRegion()
-        except:
-            pass
-        global xy_map
-        if event.GetDirection() and xy_map == '':
-            wx.MessageBox(_('You must select a valid image/map in order to continue'))
-            event.Veto()
-            return
-        self.parent.SwitchEnv('original')
-        global maptype
-        global xy_map
-        self.selection.SetElementList(maptype,
-                                      mapsets = [self.parent.newmapset, ])
-        if xy_map == '':
-        else:
-class GCP(wx.Frame):
-    Manages ground control points for georectifying. Calculates RMS statics.
-    Calls i.rectify or v.transform to georectify map.
-    def __init__(self, parent, grwiz, mapdisp = None, id = wx.ID_ANY,
-                 title = _("Define/manage ground control points"),
-                 size = (625, 300)):
-        wx.Frame.__init__(self, parent, id, title, size = size, name = "GCPFrame")
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
-        # init variables
-        self.parent.georectifying = self
-        self.mapdisp = mapdisp # XY-location Map Display
-        self.grwiz = grwiz # GR Wizard
-        self.grassdatabase = self.grwiz.grassdatabase
-        self.currentlocation = self.grwiz.currentlocation
-        self.currentmapset = self.grwiz.currentmapset
-        self.newlocation = self.grwiz.newlocation
-        self.newmapset = self.grwiz.newmapset
-        self.xylocation = self.grwiz.gisrc_dict['LOCATION_NAME']
-        self.xymapset = self.grwiz.gisrc_dict['MAPSET']
-        self.xygroup = self.grwiz.grouppage.xygroup
-        self.extension = self.grwiz.grouppage.extension
-        self.outname = ''
-        self.VectGRList = []
-        self.file = {
-            'points' : os.path.join(self.grassdatabase,
-                                    self.xylocation,
-                                    self.xymapset,
-                                    'group',
-                                    self.xygroup,
-                                    'POINTS'),
-            'rgrp' : os.path.join(self.grassdatabase,
-                                  self.xylocation,
-                                  self.xymapset,
-                                  'group',
-                                  self.xygroup,
-                                  'REF'),
-            'vgrp' : os.path.join(self.grassdatabase,
-                                  self.xylocation,
-                                  self.xymapset,
-                                  'group',
-                                  self.xygroup,
-                                  'VREF'),
-            'target' : os.path.join(self.grassdatabase,
-                                    self.xylocation,
-                                    self.xymapset,
-                                    'group',
-                                    self.xygroup,
-                                    'TARGET'),
-        # polynomial order transformation for georectification
-        self.gr_order = 1
-        # number of GCPs selected to be used for georectification (checked)
-        self.GCPcount = 0
-        # forward RMS error
-        self.fwd_rmserror = 0.0
-        # backward RMS error
-        self.bkw_rmserror = 0.0
-        # list map coords and ID of map display they came from
-        self.mapcoordlist = []
-        # region clipping for georectified map
-        self.clip_to_region = False
-        self.SetTarget(self.xygroup, self.currentlocation, self.currentmapset)
-        # toolbar and display for xy map
-        self.toolbar = toolbars.GCPToolbar(parent=self)
-        self.SetToolBar(self.toolbar)
-        self.SetMapDisplay(self.mapdisp)
-        # statusbar
-        self.CreateStatusBar(number=1)
-        # can put guage into custom statusbar for progress if can figure out how to get progress text from i.rectify
-        # self.gr_gauge = wx.Gauge(self, -1, 100, (-1,-1), (100, 25))
-        # self.gr_guage.Pulse()
-        panel = wx.Panel(parent=self)
-        # do layout
-        sizer = wx.BoxSizer(wx.VERTICAL)
-        self.rb_grmethod = wx.RadioBox(parent=panel, id=wx.ID_ANY,
-                                       label=" %s " % _("Select rectification method for rasters"),
-                                       choices=[_('1st order'), _('2nd order'), _('3rd order')],
-        sizer.Add(item=self.rb_grmethod, proportion=0,
-                       flag=wx.EXPAND | wx.ALL, border=5)
-        self.check = wx.CheckBox(parent=panel, id=wx.ID_ANY,
-                                label=_("clip to computational region in target location"))
-        sizer.Add(item=self.check, proportion=0,
-        box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
-                            label=" %s " % _("Ground Control Points"))
-        boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        # initialize list control for GCP management
-        self.list = GCPList(parent=panel, gcp=self)
-        boxSizer.Add(item=self.list, proportion=1,
-                     flag=wx.EXPAND | wx.ALL, border=3)
-        sizer.Add(item=boxSizer, proportion=1,
-                  flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
-        # bindigs
-        self.Bind(wx.EVT_RADIOBOX, self.OnGRMethod, self.rb_grmethod)
-        self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
-        self.Bind(wx.EVT_CLOSE, self.OnQuit)
-        self.Bind(wx.EVT_CHECKBOX, self.ClipRegion, self.check)
-        panel.SetSizer(sizer)
-        # sizer.Fit(self)
-    def __del__(self):
-        """!Disable georectification mode"""
-    def ClipRegion(self, event):
-        self.clip_to_region = event.IsChecked()
-    def SetMapDisplay(self, win):
-        self.mapdisp = win
-        if self.mapdisp:
-             self.list.LoadData()
-    def SetTarget(self, tgroup, tlocation, tmapset):
-        Sets rectification target to current location and mapset
-            gcmd.RunCommand('i.target',
-                            parent = self,
-                            flags = 'c',
-                            group = tgroup)
-        else:
-            self.grwiz.SwitchEnv('new')
-                            parent = self,
-                            group = tgroup,
-                            location = tlocation,
-                            mapset = tmapset)
-            self.grwiz.SwitchEnv('original')
-    def AddGCP(self, event):
-        Appends an item to GCP list
-        self.list.AddGCPItem()
-        # x, y, MapWindow instance
-        self.mapcoordlist.append({ 'gcpcoord' : (0.0, 0.0, None),
-                                   'mapcoord' : (0.0, 0.0, None) })
-    def DeleteGCP(self, event):
-        Deletes selected item in GCP list
-        minNumOfItems = self.OnGRMethod(None)
-        if self.list.GetItemCount() <= minNumOfItems:
-            wx.MessageBox(parent=self, message=_("At least %d GCPs required. Operation cancelled.") % minNumOfItems,
-                          caption=_("Delete GCP"), style=wx.OK | wx.ICON_INFORMATION)
-            return
-        item = self.list.DeleteGCPItem()
-        del self.mapcoordlist[item]
-    def ClearGCP(self, event):
-        Clears all values in selected item of GCP list and unchecks it
-        index = self.list.GetSelected()
-        for i in range(4):
-            self.list.SetStringItem(index, i, '0.0')
-        self.list.SetStringItem(index, 4, '')
-        self.list.SetStringItem(index, 5, '')
-        self.list.CheckItem(index, False)
-        self.mapcoordlist[index] = { 'gcpcoord' : (0.0, 0.0, None),
-    def DrawGCP(self, coordtype):
-        Updates GCP and map coord maps and redraws
-        active (checked) GCP markers
-        col = UserSettings.Get(group='georect', key='symbol', subkey='color')
-        wxCol = wx.Colour(col[0], col[1], col[2], 255)
-        wpx = UserSettings.Get(group='georect', key='symbol', subkey='width')
-        font = self.GetFont()
-        penOrig = polypenOrig = None
-        idx = 0
-        for gcp in self.mapcoordlist:
-            mapWin = gcp[coordtype][2]
-            if not self.list.IsChecked(idx) or not mapWin:
-                idx += 1
-                continue
-            if not penOrig:
-                penOrig = mapWin.pen
-                polypenOrig = mapWin.polypen
-                mapWin.pen = wx.Pen(colour=wxCol, width=wpx, style=wx.SOLID)
-                mapWin.polypen = wx.Pen(colour=wxCol, width=wpx, style=wx.SOLID) # ?
-            coord = mapWin.Cell2Pixel((gcp[coordtype][0], gcp[coordtype][1]))
-            mapWin.DrawCross(pdc=mapWin.pdcTmp, coords=coord,
-                             size=5, text={ 'text' : '%s' % str(idx + 1),
-                                            'active' : True,
-                                            'font' : font,
-                                            'color': wxCol,
-                                            'coords': [coord[0] + 5,
-                                                       coord[1] + 5,
-                                                       5,
-                                                       5]})
-            idx += 1
-        if penOrig:
-            mapWin.pen = penOrig
-            mapWin.polypen = polypenOrig
-    def SetGCPData(self, coordtype, coord, mapdisp=None, check=True):
-        Inserts coordinates from mouse click on map
-        into selected item of GCP list and checks it for use
-        if index == wx.NOT_FOUND:
-            return
-        coord0 = str(coord[0])
-        coord1 = str(coord[1])
-        if coordtype == 'gcpcoord':
-            self.list.SetStringItem(index, 0, coord0)
-            self.list.SetStringItem(index, 1, coord1)
-            self.mapcoordlist[index]['gcpcoord'] = (coord[0], coord[1], mapdisp)
-        elif coordtype == 'mapcoord':
-            self.list.SetStringItem(index, 2, coord0)
-            self.list.SetStringItem(index, 3, coord1)
-        self.mapcoordlist[index][coordtype] = (coord[0], coord[1], mapdisp)
-        self.list.CheckItem(index, check)
-        # self.list.ResizeColumns()
-    def SaveGCPs(self, event):
-        Make a POINTS file or save GCP coordinates to existing POINTS file
-        self.GCPcount = 0
-        try:
-            f = open(self.file['points'], mode='w')
-            # use os.linesep or '\n' here ???
-            f.write('# Ground Control Points File\n')
-            f.write("# \n")
-            f.write("# target location: " + self.currentlocation + '\n')
-            f.write("# target mapset: " + self.currentmapset + '\n')
-            f.write("#unrectified xy     georectified east north     1=use gcp point\n")
-            f.write("#--------------     -----------------------     ---------------\n")
-            for index in range(self.list.GetItemCount()):
-                if self.list.IsChecked(index) == True:
-                    check = "1"
-                    self.GCPcount += 1
-                else:
-                    check = "0"
-                coord0 = self.list.GetItem(index, 0).GetText()
-                coord1 = self.list.GetItem(index, 1).GetText()
-                coord2 = self.list.GetItem(index, 2).GetText()
-                coord3 = self.list.GetItem(index, 3).GetText()
-                f.write(coord0 + ' ' + coord1 + '     ' + coord2 + ' ' + coord3 + '     ' + check + '\n')
-            self.parent.goutput.WriteLog(_('POINTS file <%s> saved') % self.file['points'])
-            self.SetStatusText(_('POINTS file saved'))
-        except IOError, err:
-                          message="%s <%s>. %s%s" % (_("Writing POINTS file failed"),
-                                                     self.file['points'], os.linesep, err),
-                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-            return
-        f.close()
-    def ReadGCPs(self):
-        Reads GCPs and georectified coordinates from POINTS file
-        self.GCPcount = 0
-        sourceMapWin = self.mapdisp.MapWindow
-        targetMapWin = self.parent.curr_page.maptree.mapdisplay.MapWindow
-        try:
-            f = open(self.file['points'], 'r')
-            GCPcnt = 0
-                if line[0] == '#' or line =='':
-                    continue
-                coords = map(float, line.split())
-                if coords[4] == 1:
-                    check = True
-                    self.GCPcount +=1
-                else:
-                    check = False
-                index = self.AddGCP(event=None)
-                self.SetGCPData('gcpcoord', (coords[0], coords[1]), sourceMapWin, check)
-                self.SetGCPData('mapcoord', (coords[2], coords[3]), targetMapWin, check)
-                          message="%s <%s>. %s%s" % (_("Reading POINTS file failed"),
-            return
-        f.close()
-        # draw GCPs (source and target)
-        sourceMapWin.UpdateMap(render=False, renderVector=False)
-        if targetMapWin:
-            targetMapWin.UpdateMap(render=False, renderVector=False)
-        # calculate RMS
-        # FIXME auto calculation on load is not working
-        #if self.CheckGCPcount():
-        #    self.RMSError(self.xygroup, self.gr_order)
-    def ReloadGCPs(self, event):
-        """!Reload data from file"""
- 	# delete all items in mapcoordlist
-    def OnFocus(self, event):
-        # self.grwiz.SwitchEnv('new')
-        pass
-    def OnRMS(self, event):
-        RMS button handler
-        self.RMSError(self.xygroup,self.gr_order)
-    def CheckGCPcount(self, msg=False):
-        Checks to make sure that the minimum number of GCPs have been defined and
-        are active for the selected transformation order
-        if (self.GCPcount < 3 and self.gr_order == 1) or \
-            (self.GCPcount < 6 and self.gr_order == 2) or \
-            (self.GCPcount < 10 and self.gr_order == 3):
-            if msg:
-                              caption=_("RMS Error"),
-                              message=_('Insufficient points defined and active (checked) '
-                                        'for selected rectification method.\n'
-                                        '3+ points needed for 1st order,\n'
-                                        '6+ points for 2nd order, and\n'
-                                        '10+ points for 3rd order.'),
-                              style=wx.ICON_INFORMATION | wx.ID_OK | wx.CENTRE)
-                return False
-        else:
-            return True
-    def OnGeorect(self, event):
-        Georectifies map(s) in group using i.rectify or v.transform
-        global maptype
-        self.SaveGCPs(None)
-        if self.CheckGCPcount(msg=True) == False:
-            return
-            cmdlist = ['i.rectify','-a','group=%s' % self.xygroup,
-                       'extension=%s' % self.extension,'order=%s' % self.gr_order]
-            if self.clip_to_region:
-                cmdlist.append('-c')
-            self.parent.goutput.RunCmd(cmdlist, compReg=False,
-                                       switchPage=True)
-            time.sleep(.1)
-            outmsg = ''
-            # loop through all vectors in VREF
-            # and move resulting vector to target location
-            # make sure current mapset has a vector folder
-            if not os.path.isdir(os.path.join(self.grassdatabase,
-                                              self.currentlocation,
-                                              self.currentmapset,
-                                              'vector')):
-                os.mkdir(os.path.join(self.grassdatabase,
-                                      'vector'))
-            # make list of vectors to georectify from VREF
-            f = open(self.file['vgrp'])
-            vectlist = []
-            try:
-                for vect in f.readlines():
-                    vect = vect.strip('\n')
-                    if len(vect) < 1:
-                        continue
-                    vectlist.append(vect)
-            finally:
-                f.close()
-            # georectify each vector in VREF using v.transform
-            for vect in vectlist:
-                self.outname = vect + '_' + self.extension
-                self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
-                                             switchPage = True)
-                msg = err = ''
-                ret, out, err = gcmd.RunCommand('v.transform',
-                           flags = '-o',
-                           input=vect,
-                           output=self.outname,
-                           pointsfile=self.file['points'],
-                           getErrorMsg=True, read=True)
-                if ret == 0:
-                    self.VectGRList.append(self.outname)
-                    print err
-                    # note: WriteLog doesn't handle GRASS_INFO_PERCENT well, so using a print here
-#                    self.parent.goutput.WriteLog(text = _(err), switchPage = True)
-                    self.parent.goutput.WriteLog(text = _(out), switchPage = True)
-                else:
-                    self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
-                                                           self.outname)
-                    self.parent.goutput.WriteError(_(err))
-                # FIXME
-                # Copying database information not working.
-                # Does not copy from xy location to current location
-#                xyLayer = []
-#                for layer in grass.vector_db(map = vect).itervalues():
-#                    xyLayer.append((layer['driver'],
-#                                    layer['database'],
-#                                    layer['table']))
-#                dbConnect = grass.db_connection()
-#                print 'db connection =', dbConnect
-#                for layer in xyLayer:
-#                    self.parent.goutput.RunCmd(['db.copy',
-#                                                '--q',
-#                                                '--o',
-#                                                'from_driver=%s' % layer[0],
-#                                                'from_database=%s' % layer[1],
-#                                                'from_table=%s' % layer[2],
-#                                                'to_driver=%s' % dbConnect['driver'],
-#                                                'to_database=%s' % dbConnect['database'],
-#                                                'to_table=%s' % layer[2] + '_' + self.extension])
-            # copy all georectified vectors from source location to current location
-            for name in self.VectGRList:
-                xyvpath = os.path.join(self.grassdatabase,
-                                       self.xylocation,
-                                       self.xymapset,
-                                       'vector',
-                                       name)
-                vpath = os.path.join(self.grassdatabase,
-                                     'vector',
-                                     name)
-                if os.path.isdir(vpath):
-                    self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
-                                                       'Change extension name and '
-                                                       'georectify again.') % self.outname)
-                    break
-                else:
-                    shutil.move(xyvpath, vpath)
-            wx.MessageBox('For all vector maps georectified successfully, ' + '\n' +
-                          'you will need to copy any attribute tables' + '\n' +
-                          'and reconnect them to the georectified vectors')
-    def OnGeorectDone(self, **kargs):
-        """!Print final message"""
-        global maptype
-            return
-        returncode = kargs['returncode']
-        if returncode == 0:
-            print '*****vector list = ' + str(self.VectGRList)
-        else:
-                                                   self.outname)
-    def OnSettings(self, event):
-        """!Georectifier settings"""
-        dlg = GrSettingsDialog(parent=self, id=wx.ID_ANY, title=_('Georectifier settings'))
-        if dlg.ShowModal() == wx.ID_OK:
-            pass
-        dlg.Destroy()
-    def OnQuit(self, event):
-        """!Quit georectifier"""
-        self.grwiz.Cleanup()
-        self.Destroy()
-        event.Skip()
-    def OnGRMethod(self, event):
-        sets transformation order for georectifying
-        if event:
-            self.gr_order = event.GetInt() + 1
-        numOfItems = self.list.GetItemCount()
-        minNumOfItems = numOfItems
-        if self.gr_order == 1:
-            minNumOfItems = 3
-            # self.SetStatusText(_('Insufficient points, 3+ points needed for 1st order'))
-        elif self.gr_order == 2:
-            minNumOfItems = 6
-            diff = 6 - numOfItems
-            # self.SetStatusText(_('Insufficient points, 6+ points needed for 2nd order'))
-        elif self.gr_order == 3:
-            minNumOfItems = 10
-            # self.SetStatusText(_('Insufficient points, 10+ points needed for 3rd order'))
-        for i in range(minNumOfItems - numOfItems):
-            self.AddGCP(None)
-        return minNumOfItems
-    def RMSError(self, xygroup, order):
-        Uses g.transform to calculate forward and backward error for each used GCP
-        in POINTS file and insert error values into GCP list.
-        Calculates total forward and backward RMS error for all used points
-        # save GCPs to points file to make sure that all checked GCPs are used
-            return
-        # get list of forward and reverse rms error values for each point
-        ret = gcmd.RunCommand('g.transform',
-                              parent = self,
-                              read = True,
-                              group = xygroup,
-                              order = order)
-        if ret:
-            errlist = ret.splitlines()
-        if errlist == []:
-            return
-        # insert error values into GCP list for checked items
-        i = 0
-        sumsq_fwd_err = 0.0
-        sumsq_bkw_err = 0.0
-            if self.list.IsChecked(index):
-                fwd_err, bkw_err = errlist[i].split()
-                self.list.SetStringItem(index, 4, fwd_err)
-                self.list.SetStringItem(index, 5, bkw_err)
-                sumsq_fwd_err += float(fwd_err)**2
-                sumsq_bkw_err += float(bkw_err)**2
-                i += 1
-            else:
-        # calculate RMS error
-        self.fwd_rmserror = round((sumsq_fwd_err/i)**0.5,4)
-        self.bkw_rmserror = round((sumsq_bkw_err/i)**0.5,4)
-        self.list.ResizeColumns()
-        self.SetStatusText(_('RMS error for selected points forward: %(fwd)s backward: %(bkw)s') % \
-                           { 'fwd' : self.fwd_rmserror, 'bkw' : self.bkw_rmserror })
-class GCPList(wx.ListCtrl,
-              CheckListCtrlMixin,
-              ListCtrlAutoWidthMixin):
-    def __init__(self, parent, gcp, id=wx.ID_ANY,
-                 pos=wx.DefaultPosition, size=wx.DefaultSize,
-                 style=wx.LC_REPORT | wx.SUNKEN_BORDER | wx.LC_HRULES |
-                 wx.LC_SINGLE_SEL):
-        wx.ListCtrl.__init__(self, parent, id, pos, size, style)
-        # Mixin settings
-        CheckListCtrlMixin.__init__(self)
-        ListCtrlAutoWidthMixin.__init__(self)
-        # TextEditMixin.__init__(self)
-        self.gcp = gcp # GCP class
-        # tracks whether list items are checked or not
-        self.CheckList = []
-        self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
-        self.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
-        self._Create()
-        self.selected = wx.NOT_FOUND
-    def _Create(self):
-        idx_col = 0
-        for col in (_('use| X coord'),
-                    _('Y coord'),
-                    _('E coord'),
-                    _('N coord'),
-                    _('Forward error'),
-                    _('Backward error')):
-            self.InsertColumn(idx_col, col)
-            idx_col += 1
-    def LoadData(self):
-        """!Load data into list"""
-        self.DeleteAllItems()
-        if os.path.isfile(self.gcp.file['points']):
-            self.gcp.ReadGCPs()
-        else:
-            # 3 gcp is minimum
-            for i in range(3):
-                self.gcp.AddGCP(None)
-        # select first point by default
-        self.selected = 0
-        self.SetItemState(self.selected,
-                          wx.LIST_STATE_SELECTED,
-                          wx.LIST_STATE_SELECTED)
-        self.ResizeColumns()
-    def OnCheckItem(self, index, flag):
-        """!Item is checked/unchecked"""
-        pass
-    def AddGCPItem(self):
-        self.Append(['0.0',
-                     '0.0',
-                     '0.0',
-                     '0.0',
-        self.selected = self.GetItemCount() - 1
-        return self.selected
-    def DeleteGCPItem(self):
-        if self.selected == wx.NOT_FOUND:
-            return
-        self.DeleteItem(self.selected)
-        if self.GetItemCount() > 0:
-        else:
-    def ResizeColumns(self):
-        """!Resize columns"""
-        minWidth = 90
-        for i in range(self.GetColumnCount()):
-            self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
-            if self.GetColumnWidth(i) < minWidth:
-                self.SetColumnWidth(i, minWidth)
-        self.SendSizeEvent()
-    def GetSelected(self):
-        """!Get index of selected item"""
-    def OnItemSelected(self, event):
-        self.selected = event.GetIndex()
-    def OnItemActivated(self, event):
-        When item double clicked, open editor to update coordinate values
-        coords = []
-        index = event.GetIndex()
-            coords.append(self.GetItem(index, i).GetText())
-        dlg = EditGPC(parent=self, id=wx.ID_ANY, data=coords)
-            values = dlg.GetValues() # string
-            if len(values) == 0:
-                              caption=_("Edit GCP"),
-                              message=_("Invalid coordinate value. Operation cancelled."),
-                              style=wx.CENTRE | wx.ICON_ERROR | wx.ID_OK)
-            else:
-                for i in range(len(values)):
-                    if values[i] != coords[i]:
-                        self.SetStringItem(index, i, values[i])
-                mapdisp = self.gcp.mapcoordlist[index]['gcpcoord'][2]
-                self.gcp.mapcoordlist[index]['gcpcoord'] = (float(values[0]), float(values[1]), mapdisp)
-                mapdisp = self.gcp.mapcoordlist[index]['mapcoord'][2]
-                self.gcp.mapcoordlist[index]['mapcoord'] = (float(values[0]), float(values[1]), mapdisp)
-class VectGroup(wx.Dialog):
-    Dialog to create a vector group (VREF file) for georectifying
-    @todo Replace by g.group
-    def __init__(self, parent, id, grassdb, location, mapset, group,
-                 style=wx.DEFAULT_DIALOG_STYLE):
-        wx.Dialog.__init__(self, parent, id, style=style,
-                           title = _("Create vector map group"))
-        self.grassdatabase = grassdb
-        self.xylocation = location
-        self.xymapset = mapset
-        self.xygroup = group
-        # get list of valid vector directories
-        vectlist = os.listdir(os.path.join(self.grassdatabase,
-                                           self.xylocation,
-                                           self.xymapset,
-                                           'vector'))
-        for dir in vectlist:
-            if not os.path.isfile(os.path.join(self.grassdatabase,
-                                           self.xylocation,
-                                           self.xymapset,
-                                           'vector',
-                                           dir,
-                                           'coor')):
-                vectlist.remove(dir)
-        utils.ListSortLower(vectlist)
-        # path to vref file
-        self.vgrpfile = os.path.join(self.grassdatabase,
-                                     self.xylocation,
-                                     self.xymapset,
-                                     'group',
-                                     self.xygroup,
-                                     'VREF')
-        # buttons
-        self.btnCancel = wx.Button(parent = self,
-                                   id = wx.ID_CANCEL)
-        self.btnOK = wx.Button(parent = self,
-                                   id = wx.ID_OK)
-        self.btnOK.SetDefault()
-        # list of vector maps
-        self.listMap = wx.CheckListBox(parent = self, id = wx.ID_ANY,
-                                      choices = vectlist)
-        if os.path.isfile(self.vgrpfile):
-            f = open(self.vgrpfile)
-            try:
-                checked = []
-                    if len(line) < 1:
-                        continue
-                    checked.append(line)
-                self.listMap.SetCheckedStrings(checked)
-            finally:
-                f.close()
-        line = wx.StaticLine(parent = self,
-                             id = wx.ID_ANY, size = (20, -1),
-                             style = wx.LI_HORIZONTAL)
-        # layout
-        box = wx.BoxSizer(wx.HORIZONTAL)
-        box.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
-                                     label = _('Select vector map(s) to add to group:')),
-                flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
-                border = 5)
-        box.Add(item = self.listMap,
-                border = 5)
-        sizer.Add(box, flag = wx.ALIGN_RIGHT | wx.ALL,
-                  border = 3)
-        sizer.Add(item = line, proportion = 0,
-                  flag = wx.GROW | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
-                  border = 5)
-        # buttons
-        btnSizer = wx.StdDialogButtonSizer()
-        btnSizer.AddButton(self.btnCancel)
-        btnSizer.AddButton(self.btnOK)
-        btnSizer.Realize()
-        sizer.Add(item = btnSizer, proportion = 0,
-                  flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER,
-                  border = 5)
-        self.SetSizer(sizer)
-        sizer.Fit(self)
-        self.Layout()
-    def MakeVGroup(self):
-        """!Create VREF file"""
-        vgrouplist = []
-        for item in range(self.listMap.GetCount()):
-            if not self.listMap.IsChecked(item):
-                continue
-            vgrouplist.append(self.listMap.GetString(item))
-        f = open(self.vgrpfile, mode='w')
-        try:
-            for vect in vgrouplist:
-                f.write(vect + '\n')
-        finally:
-            f.close()
-class EditGPC(wx.Dialog):
-    def __init__(self, parent, data, id=wx.ID_ANY,
-                 title=_("Edit GCP"),
-        """!Dialog for editing GPC and map coordinates in list control"""
-        wx.Dialog.__init__(self, parent, id, title=title, style=style)
-                            label=" %s " % _("Ground Control Point"))
-        # source coordinates
-        gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
-        self.xcoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
-        self.ycoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
-        self.ncoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
-        self.ecoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
-        row = 0
-        col = 0
-        idx = 0
-        for label, win in ((_("X:"), self.xcoord),
-                           (_("Y:"), self.ycoord),
-                           (_("E:"), self.ecoord),
-                           (_("N:"), self.ncoord)):
-            label = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                  label=label)
-            gridSizer.Add(item=label,
-                          flag=wx.ALIGN_CENTER_VERTICAL,
-                          pos=(row, col))
-            col += 1
-            win.SetValue(str(data[idx]))
-            gridSizer.Add(item=win,
-                          pos=(row, col))
-            col += 1
-            idx += 1
-            if col > 3:
-                row += 1
-                col = 0
-        boxSizer.Add(item=gridSizer, proportion=1,
-        # buttons
-        self.btnCancel = wx.Button(panel, wx.ID_CANCEL)
-        self.btnOk = wx.Button(panel, wx.ID_OK)
-        self.btnOk.SetDefault()
-        btnSizer.AddButton(self.btnOk)
-        sizer.Add(item=btnSizer, proportion=0,
-                  flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
-        sizer.Fit(self)
-    def GetValues(self, columns=None):
-        """!Return list of values (as strings).
-        valuelist = []
-        try:
-            float(self.xcoord.GetValue())
-            float(self.ycoord.GetValue())
-            float(self.ecoord.GetValue())
-            float(self.ncoord.GetValue())
-        except ValueError:
-            return valuelist
-        valuelist.append(self.xcoord.GetValue())
-        valuelist.append(self.ycoord.GetValue())
-        valuelist.append(self.ecoord.GetValue())
-        valuelist.append(self.ncoord.GetValue())
-        return valuelist
-class GrSettingsDialog(wx.Dialog):
-    def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
-        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
-        Dialog to set profile text options: font, title
-        and font size, axis labels and font size
-        # initialize variables
-        self.symbol = {}
-        self._do_layout()
-    def _do_layout(self):
-        """!Do layout"""
-        # dialog layout
-        box = wx.StaticBox(parent=self, id=wx.ID_ANY,
-                           label=" %s " % _("Symbol settings"))
-        gridSizer.AddGrowableCol(1)
-        # symbol color
-        row = 0
-        label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Color:"))
-        gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
-        colWin = csel.ColourSelect(parent=self, id=wx.ID_ANY,
-                                   colour=wx.Colour(col[0],
-                                                    col[1],
-                                                    col[2],
-                                                    255))
-        self.symbol['color'] = colWin.GetId()
-        gridSizer.Add(item=colWin,
-                      flag=wx.ALIGN_RIGHT,
-                      pos=(row, 1))
-        # symbol width
-        row += 1
-        label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Width:"))
-        width = int(UserSettings.Get(group='georect', key='symbol', subkey='width'))
-        widWin = wx.SpinCtrl(parent=self, id=wx.ID_ANY,
-                             min=1, max=10)
-        widWin.SetValue(width)
-        self.symbol['width'] = widWin.GetId()
-        gridSizer.Add(item=widWin,
-                      pos=(row, 1))
-        boxSizer.Add(item=gridSizer, flag=wx.EXPAND)
-        sizer.Add(item=boxSizer, flag=wx.EXPAND | wx.ALL, border=5)
-        line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(20, -1), style=wx.LI_HORIZONTAL)
-        sizer.Add(item=line, proportion=0,
-                  flag=wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border=3)
-        # buttons
-        btnSave = wx.Button(self, wx.ID_SAVE)
-        btnApply = wx.Button(self, wx.ID_APPLY)
-        btnCancel = wx.Button(self, wx.ID_CANCEL)
-        btnSave.SetDefault()
-        # bindigs
-        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
-        btnApply.SetToolTipString(_("Apply changes for the current session"))
-        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
-        btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
-        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
-        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
-        # sizers
-        btnStdSizer = wx.StdDialogButtonSizer()
-        btnStdSizer.AddButton(btnCancel)
-        btnStdSizer.AddButton(btnSave)
-        btnStdSizer.AddButton(btnApply)
-        btnStdSizer.Realize()
-        sizer.Add(item=btnStdSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
-        sizer.Fit(self)
-    def UpdateSettings(self):
-        UserSettings.Set(group='georect', key='symbol', subkey='color',
-                         value=tuple(wx.FindWindowById(self.symbol['color']).GetColour()))
-        UserSettings.Set(group='georect', key='symbol', subkey='width',
-                         value=wx.FindWindowById(self.symbol['width']).GetValue())
-    def OnSave(self, event):
-        """!Button 'Save' pressed"""
-        self.UpdateSettings()
-        fileSettings = {}
-        UserSettings.ReadSettingsFile(settings=fileSettings)
-        fileSettings['georect'] = UserSettings.Get(group='georect')
-        file = UserSettings.SaveToFile(fileSettings)
-        self.parent.parent.goutput.WriteLog(_('Georectifier settings saved to file \'%s\'.') % file)
-        self.Close()
-    def OnApply(self, event):
-        """!Button 'Apply' pressed"""
-        self.Close()
-    def OnCancel(self, event):
-        """!Button 'Cancel' pressed"""
-        self.Close()
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py	2010-11-02 14:51:27 UTC (rev 44170)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py	2010-11-02 14:53:07 UTC (rev 44171)
@@ -70,7 +70,6 @@
 import gui_modules.profile as profile
 import gui_modules.mcalc_builder as mapcalculator
 import gui_modules.gcmd as gcmd
-import gui_modules.georect as georect
 import gui_modules.dbm as dbm
 import gui_modules.workspace as workspace
 import gui_modules.goutput as goutput
@@ -247,11 +246,6 @@
         if self.workspaceFile:
             self.SetTitle(self.baseTitle + " - " +  os.path.basename(self.workspaceFile) + '*')
-    def OnGeorectify(self, event):
-        """!Launch georectifier module
-        georect.GeorectWizard(self)
     def OnGCPManager(self, event):
@@ -993,7 +987,6 @@
     def OnMapCalculator(self, event, cmd = ''):
         """!Init map calculator for interactive creation of mapcalc statements
         if event:
             cmd = self.GetMenuCmd(event)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2010-11-02 14:51:27 UTC (rev 44170)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml	2010-11-02 14:53:07 UTC (rev 44171)
@@ -621,15 +621,10 @@
 	</menu>
 	<separator />
 	<menuitem>
-	  <label>Manage Ground Control Points</label>
+	  <label>Georectify</label>
 	  <help>Manage Ground Control Points for Georectification</help>
 	  <handler>OnGCPManager</handler>
 	</menuitem>
-	<menuitem>
-	  <label>Georectify</label>
-	  <help>Georectify raster and vector maps</help>
-	  <handler>OnGeorectify</handler>
-	</menuitem>
 	<separator />
 	<menuitem>
 	  <label>Graphical modeler</label>
