[GRASS-SVN] r44199 - grass/branches/develbranch_6/gui/wxpython/xml
Sat Nov 6 18:38:17 EDT 2010
Author: martinl
Date: 2010-11-06 15:38:17 -0700 (Sat, 06 Nov 2010)
New Revision: 44199
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
update wxGUI menu
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2010-11-06 22:33:31 UTC (rev 44198)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2010-11-06 22:38:17 UTC (rev 44199)
@@ -202,12 +202,19 @@
 	      <command>v.in.lines</command>
 	    </menuitem>
 	    <menuitem>
-	      <label>Old GRASS vector import</label>
+	      <label>Historical GRASS vector import</label>
 	      <help>Imports older versions of GRASS vector maps.</help>
 	      <keywords>vector,import,conversion</keywords>
 	      <handler>OnMenuCmd</handler>
 	      <command>v.convert</command>
 	    </menuitem>
+	    <menuitem>
+	      <label>Historical GRASS vector import (all maps)</label>
+	      <help>Convert all old GRASS &lt; Ver5.7 vector maps in current mapset to current format</help>
+	      <keywords>vector,import</keywords>
+	      <handler>OnMenuCmd</handler>
+	      <command>v.convert.all</command>
+	    </menuitem>
 	    <separator />
 	    <menuitem>
 	      <label>DXF import</label>
@@ -223,6 +230,14 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>WFS</label>
+	      <help>Import GetFeature from WFS</help>
+	      <keywords>vector,import,wfs</keywords>
+	      <command>v.in.wfs</command>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>ESRI e00 import</label>
 	      <help>Import E00 file into a vector map.</help>
@@ -710,7 +725,9 @@
 	    <menuitem>
 	      <label>Mapset access</label>
 	      <help>Set/unset access to other mapsets in current location</help>
+	      <keywords>general,settings,search path</keywords>
 	      <handler>OnMapsets</handler>
+	      <command>g.mapsets</command>
 	    </menuitem>
 	    <menuitem>
 	      <label>User access</label>
