[GRASS-SVN] r44238 - grass/branches/releasebranch_6_4/db/base
Sun Nov 7 18:00:38 EST 2010
Author: neteler
Date: 2010-11-07 15:00:38 -0800 (Sun, 07 Nov 2010)
New Revision: 44238
   grass/branches/releasebranch_6_4/db/base/db.execute.html
HTML fix
Modified: grass/branches/releasebranch_6_4/db/base/db.execute.html
--- grass/branches/releasebranch_6_4/db/base/db.execute.html	2010-11-07 22:56:51 UTC (rev 44237)
+++ grass/branches/releasebranch_6_4/db/base/db.execute.html	2010-11-07 23:00:38 UTC (rev 44238)
@@ -93,7 +93,7 @@
 </pre></div>
 <P>
-<em>Join table 'myroads' into table 'extratab' based on common 'cat' column values (not supported by DBF driver):<br>
+<em>Join table 'myroads' into table 'extratab' based on common 'cat' column values (not supported by DBF driver):</em><br>
 <div class="code"><pre>
 echo "UPDATE extratab SET names=(SELECT label FROM myroads WHERE extratab.cat=myroads.cat);" | db.execute
 </pre></div>
