[GRASS-SVN] r44305 - grass/branches/releasebranch_6_4/raster/r.cost
Sat Nov 13 07:02:26 EST 2010
Author: msieczka
Date: 2010-11-13 04:02:26 -0800 (Sat, 13 Nov 2010)
New Revision: 44305
   grass/branches/releasebranch_6_4/raster/r.cost/description.html
s/_sites/_points/g
Modified: grass/branches/releasebranch_6_4/raster/r.cost/description.html
--- grass/branches/releasebranch_6_4/raster/r.cost/description.html	2010-11-11 17:29:04 UTC (rev 44304)
+++ grass/branches/releasebranch_6_4/raster/r.cost/description.html	2010-11-13 12:02:26 UTC (rev 44305)
@@ -30,13 +30,13 @@
 Each <em>x,y</em> <b>coordinate</b> pair gives the geographic location of a
 point from which the transportation cost should be figured. As many points as
 desired can be entered by the user. These starting points can also be read
-from a vector points file through the <b>start_sites</b> option or from a
+from a vector points file through the <b>start_points</b> option or from a
 raster map through the <b>start_rast</b> option.
 <p>
 <em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
 or one of the stop points given with <b>stop_coordinates</b> is reached.
 Alternatively, the stop points can be read from a vector points file with the
-<b>stop_sites</b> option. During execution, once the cumulative cost to all
+<b>stop_points</b> option. During execution, once the cumulative cost to all
 stopping points has been determined, processing stops.
 Both sites read from a vector points file and those given on the command line
