[GRASS-SVN] r44324 - in grass-addons/raster: . r.pack r.unpack
    svn_grass at osgeo.org
    Mon Nov 15 07:43:31 EST 2010
Author: martinl
Date: 2010-11-15 04:43:31 -0800 (Mon, 15 Nov 2010)
New Revision: 44324
Added:
   grass-addons/raster/r.unpack/
   grass-addons/raster/r.unpack/Makefile
   grass-addons/raster/r.unpack/r.unpack
   grass-addons/raster/r.unpack/r.unpack.mat
Removed:
   grass-addons/raster/r.pack/r.unpack
   grass-addons/raster/r.pack/r.unpack.mat
r.unpack moved to raster/r.unpack
Deleted: grass-addons/raster/r.pack/r.unpack
--- grass-addons/raster/r.pack/r.unpack	2010-11-15 12:40:39 UTC (rev 44323)
+++ grass-addons/raster/r.pack/r.unpack	2010-11-15 12:43:31 UTC (rev 44324)
@@ -1,162 +0,0 @@
-#!/bin/sh
-#  r.unpack   --  unpack up a raster map packed with r.pack:
-#     tar+gzip'd map elements => GRASS 6 mapset structure
-#   (c) 2004-2008 GRASS Development Team
-#   AUTHOR: Hamish Bowman, Otago University, New Zealand
-#   This program is free software under the GNU General Public
-#   License (>=v2). Read the file COPYING that comes with GRASS
-#   for details.
-#%Module
-#%  description: UnPacks a raster map packed with r.pack
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old_file,file,input
-#% description: Name of an existing pack file
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% description: Output raster map (default: taken from input file internals)
-#% required : no
-#%end
-#%flag
-#%  key: o
-#%  description: Override projection check (use current location's projection)
-#%end
-if [ -z "$GISBASE" ] ; then
-   echo "You must be in GRASS GIS to run this program." >&2
-   exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-   exec g.parser "$0" "$@"
-fi
-# check for tar,gzip
-for PRGM in tar gzip ; do
-   if [ -z "`which $PRGM`" ] ; then
-      g.message -e "$PRGM must be installed to use this program."
-      exit 1
-   fi
-done
-if [ -z "$GRASS_OVERWRITE" ] ; then
-   GRASS_OVERWRITE=0
-fi
-if [ ! -e "$GIS_OPT_INPUT" ] ; then
-   g.message -e "File not found <$GIS_OPT_INPUT>"
-   exit 1
-fi
-eval `g.gisenv`
-MSET_DIR="$GISDBASE/$LOCATION_NAME/$MAPSET"
-# create temporary directory to hold bits
-TMP_DIR="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP_DIR" ] ; then
-   g.message -e "Unable to create temporary files"
-   exit 1
-fi
-rm -f "$TMP_DIR"
-mkdir "$TMP_DIR"
-if [ ! -d "$TMP_DIR" ] ; then
-   g.message -e "Unable to create temporary directory"
-   exit 1
-fi
-cleanup()
-   g.message -v "Cleaning up ..."
-   cd "$MSET_DIR"
-   rm -rf "$TMP_DIR"
-#### trap ctrl-c so that we can clean up tmp
-trap 'cleanup' 2 3 15
-cp "$GIS_OPT_INPUT" "$TMP_DIR"/
-cd "$TMP_DIR"/
-# remove .pack and path from $GIS_OPT_INPUT
-#MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
-INPUT_BASE=`basename $GIS_OPT_INPUT`
-DATA_NAME=`tar tzf "$INPUT_BASE" | head -n 1 | cut -f1 -d'/'`
-if [ -z "$DATA_NAME" ] ; then
-   g.message -e "Pack file unreadable"
-   cleanup
-   exit 1
-fi
-if [ -z "$GIS_OPT_OUTPUT" ] ; then
-   MAP_NAME="$DATA_NAME"
-else
-   MAP_NAME="$GIS_OPT_OUTPUT"
-fi
-eval `g.findfile element=cell file="$MAP_NAME" mapset=.`
-if [ ! -z "$file" ] && [ "$GRASS_OVERWRITE" -ne 1 ] ; then
-   g.message -e "Raster map <$MAP_NAME> already exists"
-   cleanup
-   exit 1
-fi
-# extract data
-tar xzf "$INPUT_BASE"
-if [ $? -ne 0 ] ; then
-   cleanup
-   exit 1
-fi
-cd "$DATA_NAME"/
-# check projection compatibility in a rather crappy way
-if [ ! -z `diff PROJ_INFO "$MSET_DIR"/../PERMANENT/PROJ_INFO` ] ; then
-    if [ $GIS_FLAG_O -eq 1 ] ; then
-        g.message -w "Projection information does not match. Proceeding.."
-    else
-        g.message -e "Projection information does not match. Aborting."
-        cleanup
-        exit 1
-    fi
-fi
-# install in $MAPSET
-for ELEMENT in cats cell cellhd colr fcell grid3 hist ; do
-    if [ -e "$ELEMENT" ] ; then
-	if [ ! -d "$MSET_DIR/$ELEMENT/" ] ; then
-	   mkdir "$MSET_DIR/$ELEMENT/"
-	fi
-	cp "$ELEMENT" "$MSET_DIR/$ELEMENT/$MAP_NAME"
-    fi
-done
-if [ -d "cell_misc" ] ; then
-    if [ ! -d "$MSET_DIR/cell_misc" ] ; then
-	mkdir "$MSET_DIR/cell_misc"
-    fi
-    cp -r "cell_misc"/ "$MSET_DIR/cell_misc/$MAP_NAME"
-fi
-cleanup
-g.message -v "Done. Map saved to <$MAP_NAME>"
-exit 0
Deleted: grass-addons/raster/r.pack/r.unpack.mat
--- grass-addons/raster/r.pack/r.unpack.mat	2010-11-15 12:40:39 UTC (rev 44323)
+++ grass-addons/raster/r.pack/r.unpack.mat	2010-11-15 12:43:31 UTC (rev 44324)
@@ -1,116 +0,0 @@
-#!/bin/sh
-#     tar+gzip => r.in.mat + support files
-#   (c) 2004 GRASS Development Team
-#   for details.
-#%Module
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: file,file,file
-#% required : yes
-#%end
-#%flag
-#%  key: o
-#%  description: Override projection (use location's projection)
-#%end
-   exit 1
-fi
-fi
-# check for tar  (is there a better way?)
-if [ -z "`which tar`" ] ; then
-   echo "ERROR: tar must be installed to use this program."
-   exit 1
-fi
-# check for gzip
-if [ -z "`which gzip`" ] ; then
-   echo "ERROR: gzip must be installed to use this program."
-   exit 1
-fi
-eval `g.gisenv`
-   echo "ERROR: file not found [$GIS_OPT_INPUT]"
-   exit 1
-fi
-MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
-echo "The imported map will be named [$MAP_NAME]."
-eval `g.findfile element=cell file="$MAP_NAME"`
-if [ ! -z "$file" ] ; then
-   echo "ERROR: '$MAP_NAME' already exists."
-   exit 1
-fi
-   echo "ERROR: unable to create temporary files" 1>&2
-   exit 1
-fi
-rm -f "$TMP_DIR"
-mkdir "$TMP_DIR"
-   echo "ERROR: unable to create temporary directory" 1>&2
-   exit 1
-fi
-cd "$TMP_DIR"/
-tar xzf "`basename $GIS_OPT_INPUT`"
-if [ ! -z "`diff proj_info "$MSET_DIR"/../PERMANENT/PROJ_INFO`" ] ; then
-        echo "WARNING: Projection information does not match. Proceeding.."
-    else
-        echo "ERROR: Projection information does not match. Aborting."
-        # clean up
-        cd "$MSET_DIR"
-        rm -rf "$TMP_DIR"
-        exit 1
-    fi
-fi
-r.in.mat input=map.mat output="$MAP_NAME"
-for SUPPORT in colr hist cats ; do
-    if [ -e $SUPPORT ] ; then
-        cp $SUPPORT "$MSET_DIR"/$SUPPORT/"$MAP_NAME"
-    fi
-done
-# clean up
-cd "$MSET_DIR"
-rm -rf "$TMP_DIR"
-echo Finished.
-exit 0
Added: grass-addons/raster/r.unpack/Makefile
--- grass-addons/raster/r.unpack/Makefile	                        (rev 0)
+++ grass-addons/raster/r.unpack/Makefile	2010-11-15 12:43:31 UTC (rev 44324)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.unpack
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/raster/r.unpack/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Copied: grass-addons/raster/r.unpack/r.unpack (from rev 44033, grass-addons/raster/r.pack/r.unpack)
--- grass-addons/raster/r.unpack/r.unpack	                        (rev 0)
+++ grass-addons/raster/r.unpack/r.unpack	2010-11-15 12:43:31 UTC (rev 44324)
@@ -0,0 +1,162 @@
+#!/bin/sh
+#  r.unpack   --  unpack up a raster map packed with r.pack:
+#     tar+gzip'd map elements => GRASS 6 mapset structure
+#   (c) 2004-2008 GRASS Development Team
+#   AUTHOR: Hamish Bowman, Otago University, New Zealand
+#   This program is free software under the GNU General Public
+#   License (>=v2). Read the file COPYING that comes with GRASS
+#   for details.
+#%Module
+#%  description: UnPacks a raster map packed with r.pack
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old_file,file,input
+#% description: Name of an existing pack file
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Output raster map (default: taken from input file internals)
+#% required : no
+#%end
+#%flag
+#%  key: o
+#%  description: Override projection check (use current location's projection)
+#%end
+if [ -z "$GISBASE" ] ; then
+   echo "You must be in GRASS GIS to run this program." >&2
+   exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+   exec g.parser "$0" "$@"
+fi
+# check for tar,gzip
+for PRGM in tar gzip ; do
+   if [ -z "`which $PRGM`" ] ; then
+      g.message -e "$PRGM must be installed to use this program."
+      exit 1
+   fi
+done
+if [ -z "$GRASS_OVERWRITE" ] ; then
+   GRASS_OVERWRITE=0
+fi
+if [ ! -e "$GIS_OPT_INPUT" ] ; then
+   g.message -e "File not found <$GIS_OPT_INPUT>"
+   exit 1
+fi
+eval `g.gisenv`
+MSET_DIR="$GISDBASE/$LOCATION_NAME/$MAPSET"
+# create temporary directory to hold bits
+TMP_DIR="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP_DIR" ] ; then
+   g.message -e "Unable to create temporary files"
+   exit 1
+fi
+rm -f "$TMP_DIR"
+mkdir "$TMP_DIR"
+if [ ! -d "$TMP_DIR" ] ; then
+   g.message -e "Unable to create temporary directory"
+   exit 1
+fi
+cleanup()
+   g.message -v "Cleaning up ..."
+   cd "$MSET_DIR"
+   rm -rf "$TMP_DIR"
+#### trap ctrl-c so that we can clean up tmp
+trap 'cleanup' 2 3 15
+cp "$GIS_OPT_INPUT" "$TMP_DIR"/
+cd "$TMP_DIR"/
+# remove .pack and path from $GIS_OPT_INPUT
+#MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
+INPUT_BASE=`basename $GIS_OPT_INPUT`
+DATA_NAME=`tar tzf "$INPUT_BASE" | head -n 1 | cut -f1 -d'/'`
+if [ -z "$DATA_NAME" ] ; then
+   g.message -e "Pack file unreadable"
+   cleanup
+   exit 1
+fi
+if [ -z "$GIS_OPT_OUTPUT" ] ; then
+   MAP_NAME="$DATA_NAME"
+else
+   MAP_NAME="$GIS_OPT_OUTPUT"
+fi
+eval `g.findfile element=cell file="$MAP_NAME" mapset=.`
+if [ ! -z "$file" ] && [ "$GRASS_OVERWRITE" -ne 1 ] ; then
+   g.message -e "Raster map <$MAP_NAME> already exists"
+   cleanup
+   exit 1
+fi
+# extract data
+tar xzf "$INPUT_BASE"
+if [ $? -ne 0 ] ; then
+   cleanup
+   exit 1
+fi
+cd "$DATA_NAME"/
+# check projection compatibility in a rather crappy way
+if [ ! -z `diff PROJ_INFO "$MSET_DIR"/../PERMANENT/PROJ_INFO` ] ; then
+    if [ $GIS_FLAG_O -eq 1 ] ; then
+        g.message -w "Projection information does not match. Proceeding.."
+    else
+        g.message -e "Projection information does not match. Aborting."
+        cleanup
+        exit 1
+    fi
+fi
+# install in $MAPSET
+for ELEMENT in cats cell cellhd colr fcell grid3 hist ; do
+    if [ -e "$ELEMENT" ] ; then
+	if [ ! -d "$MSET_DIR/$ELEMENT/" ] ; then
+	   mkdir "$MSET_DIR/$ELEMENT/"
+	fi
+	cp "$ELEMENT" "$MSET_DIR/$ELEMENT/$MAP_NAME"
+    fi
+done
+if [ -d "cell_misc" ] ; then
+    if [ ! -d "$MSET_DIR/cell_misc" ] ; then
+	mkdir "$MSET_DIR/cell_misc"
+    fi
+    cp -r "cell_misc"/ "$MSET_DIR/cell_misc/$MAP_NAME"
+fi
+cleanup
+g.message -v "Done. Map saved to <$MAP_NAME>"
+exit 0
Copied: grass-addons/raster/r.unpack/r.unpack.mat (from rev 44033, grass-addons/raster/r.pack/r.unpack.mat)
--- grass-addons/raster/r.unpack/r.unpack.mat	                        (rev 0)
+++ grass-addons/raster/r.unpack/r.unpack.mat	2010-11-15 12:43:31 UTC (rev 44324)
@@ -0,0 +1,116 @@
+#!/bin/sh
+#     tar+gzip => r.in.mat + support files
+#   (c) 2004 GRASS Development Team
+#   for details.
+#%Module
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: file,file,file
+#% required : yes
+#%end
+#%flag
+#%  key: o
+#%  description: Override projection (use location's projection)
+#%end
+   exit 1
+fi
+fi
+# check for tar  (is there a better way?)
+if [ -z "`which tar`" ] ; then
+   echo "ERROR: tar must be installed to use this program."
+   exit 1
+fi
+# check for gzip
+if [ -z "`which gzip`" ] ; then
+   echo "ERROR: gzip must be installed to use this program."
+   exit 1
+fi
+eval `g.gisenv`
+   echo "ERROR: file not found [$GIS_OPT_INPUT]"
+   exit 1
+fi
+MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
+echo "The imported map will be named [$MAP_NAME]."
+eval `g.findfile element=cell file="$MAP_NAME"`
+if [ ! -z "$file" ] ; then
+   echo "ERROR: '$MAP_NAME' already exists."
+   exit 1
+fi
+   echo "ERROR: unable to create temporary files" 1>&2
+   exit 1
+fi
+rm -f "$TMP_DIR"
+mkdir "$TMP_DIR"
+   echo "ERROR: unable to create temporary directory" 1>&2
+   exit 1
+fi
+cd "$TMP_DIR"/
+tar xzf "`basename $GIS_OPT_INPUT`"
+if [ ! -z "`diff proj_info "$MSET_DIR"/../PERMANENT/PROJ_INFO`" ] ; then
+        echo "WARNING: Projection information does not match. Proceeding.."
+    else
+        echo "ERROR: Projection information does not match. Aborting."
+        # clean up
+        cd "$MSET_DIR"
+        rm -rf "$TMP_DIR"
+        exit 1
+    fi
+fi
+r.in.mat input=map.mat output="$MAP_NAME"
+for SUPPORT in colr hist cats ; do
+    if [ -e $SUPPORT ] ; then
+        cp $SUPPORT "$MSET_DIR"/$SUPPORT/"$MAP_NAME"
+    fi
+done
+# clean up
+cd "$MSET_DIR"
+rm -rf "$TMP_DIR"
+echo Finished.
+exit 0
