[GRASS-SVN] r44331 - grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
Mon Nov 15 15:52:20 EST 2010
Author: martinl
Date: 2010-11-15 12:52:20 -0800 (Mon, 15 Nov 2010)
New Revision: 44331
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
wxGUI: better treat external scripts
(merge r44329 from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py	2010-11-15 20:39:41 UTC (rev 44330)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py	2010-11-15 20:52:20 UTC (rev 44331)
@@ -528,10 +528,25 @@
         else:
             # Send any other command to the shell. Send output to
             # console output window
-            self.cmdThread.RunCmd(GrassCmd,
-                                  onDone,
-                                  command,
-                                  self.cmd_stdout, self.cmd_stderr)
+            if len(command) == 1:
+                import menuform
+                try:
+                    task = menuform.GUI().ParseInterface(command)
+                except:
+                    task = None
+                # if not task.has_required():
+                # task = None # run command
+            else:
+                task = None
+            if task:
+                # process GRASS command without argument
+                menuform.GUI().ParseCommand(command, parentframe = self)
+            else:
+                self.cmdThread.RunCmd(GrassCmd,
+                                      onDone,
+                                      command,
+                                      self.cmd_stdout, self.cmd_stderr)
             self.cmd_output_timer.Start(50)
         return None
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2010-11-15 20:39:41 UTC (rev 44330)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2010-11-15 20:52:20 UTC (rev 44331)
@@ -1957,10 +1957,13 @@
     @param cmd command (name of GRASS module)
+    nuldev = file(os.devnull, 'w+')
     try:
-        cmdout = grass.Popen([cmd, '--interface-description'], stdout = grass.PIPE).communicate()[0]
+        cmdout = grass.Popen([cmd, '--interface-description'], stdout = grass.PIPE,
+                             stderr = nuldev).communicate()[0]
     except OSError:
         raise gcmd.GException, _("Unable to fetch interface description for command '%s'.") % cmd
+    nuldev.close()
     return cmdout.replace('grass-interface.dtd', os.path.join(globalvar.ETCDIR, 'grass-interface.dtd'))
