[GRASS-SVN] r44341 - in grass/trunk: lib/gis raster/r.mfilter
Mon Nov 15 17:57:30 EST 2010
Author: martinl
Date: 2010-11-15 14:57:29 -0800 (Mon, 15 Nov 2010)
New Revision: 44341
   grass/trunk/lib/gis/parser_standard_options.c
   grass/trunk/raster/r.mfilter/main.c
r.mfilter: cosmetics in module description
         minor changes in G_OPT_F
(merge r44338 from devbr6)
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c	2010-11-15 22:57:16 UTC (rev 44340)
+++ grass/trunk/lib/gis/parser_standard_options.c	2010-11-15 22:57:29 UTC (rev 44341)
@@ -422,18 +422,18 @@
     case G_OPT_F_INPUT:
 	Opt->key = "input";
 	Opt->type = TYPE_STRING;
-	Opt->key_desc = "name";
+	Opt->key_desc = "path";
 	Opt->required = YES;
 	Opt->gisprompt = "old_file,file,input";
-	Opt->description = _("Name of input file");
+	Opt->description = _("Path to input file");
 	break;
     case G_OPT_F_OUTPUT:
 	Opt->key = "output";
 	Opt->gisprompt = "new_file,file,output";
-	Opt->description = _("Name for output file");
+	Opt->description = _("Path for output file");
 	break;
     case G_OPT_F_SEP:
 	Opt->key = "fs";
Modified: grass/trunk/raster/r.mfilter/main.c
--- grass/trunk/raster/r.mfilter/main.c	2010-11-15 22:57:16 UTC (rev 44340)
+++ grass/trunk/raster/r.mfilter/main.c	2010-11-15 22:57:29 UTC (rev 44341)
@@ -7,7 +7,7 @@
  *               Glynn Clements <glynn gclements.plus.com>, Jachym Cepicky <jachym les-ejk.cz>,
  *               Jan-Oliver Wagner <jan intevation.de>
  * PURPOSE:
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2006, 2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -55,7 +55,7 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("map algebra"));
-    module->description = _("Raster map matrix filter.");
+    module->description = _("Performs raster map matrix filter.");
     /* Define the different options */
@@ -66,7 +66,7 @@
     opt3 = G_define_standard_option(G_OPT_F_INPUT);
     opt3->key = "filter";
     opt3->required = YES;
-    opt3->description = _("Name of filter file");
+    opt3->description = _("Path to filter file");
     opt4 = G_define_option();
     opt4->key = "repeat";
@@ -75,7 +75,8 @@
     opt4->required = NO;
     opt4->answer = "1";
     opt4->description = _("Number of times to repeat the filter");
+    opt4->guisection = _("Filter");
     opt5 = G_define_option();
     opt5->key = "title";
     opt5->type = TYPE_STRING;
@@ -93,6 +94,7 @@
     flag2 = G_define_flag();
     flag2->key = 'z';
     flag2->description = _("Apply filter only to null data values");
+    flag2->guisection = _("Filter");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
