[GRASS-SVN] r44366 - grass/branches/develbranch_6/lib/python
Mon Nov 22 16:14:34 EST 2010
Author: martinl
Date: 2010-11-22 13:14:34 -0800 (Mon, 22 Nov 2010)
New Revision: 44366
   grass/branches/develbranch_6/lib/python/core.py
sync pythonlib with trunk
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2010-11-22 08:28:28 UTC (rev 44365)
+++ grass/branches/develbranch_6/lib/python/core.py	2010-11-22 21:14:34 UTC (rev 44366)
@@ -29,6 +29,7 @@
 import re
 import atexit
 import subprocess
+import shutil
 # i18N
 import gettext
@@ -446,6 +447,14 @@
     """!Returns the name of a temporary file, created with g.tempfile."""
     return read_command("g.tempfile", pid = os.getpid()).strip()
+def tempdir():
+    """!Returns the name of a temporary dir, created with g.tempfile."""
+    tmp = read_command("g.tempfile", pid = os.getpid()).strip()
+    try_remove(tmp)
+    os.mkdir(tmp)
+    return tmp
 # key-value parsers
 def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
@@ -792,7 +801,7 @@
     """!Attempt to remove a file; no exception is generated if the
     attempt fails.
-    @param path path
+    @param path path to file to remove
     try:
 	os.remove(path)
@@ -805,12 +814,12 @@
     """!Attempt to remove a directory; no exception is generated if the
     attempt fails.
-    @param path path
+    @param path path to directory to remove
     try:
 	os.rmdir(path)
     except:
-	pass
+	shutil.rmtree(path, ignore_errors = True)
 def float_or_dms(s):
     """!Convert DMS to float.
