[GRASS-SVN] r44387 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Tue Nov 23 08:57:01 EST 2010
Author: martinl
Date: 2010-11-23 05:57:01 -0800 (Tue, 23 Nov 2010)
New Revision: 44387
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
wxGUI: mcalc fixes
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2010-11-23 10:38:35 UTC (rev 44386)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2010-11-23 13:57:01 UTC (rev 44387)
@@ -116,13 +116,23 @@
             # set default color table for raster data
             if UserSettings.Get(group='cmd', key='rasterColorTable', subkey='enabled') and \
                     args[0][0][:2] == 'r.':
-                moduleInterface = menuform.GUI().ParseCommand(args[0], show = None)
-                outputParam = moduleInterface.get_param(value = 'output', raiseError = False)
                 colorTable = UserSettings.Get(group='cmd', key='rasterColorTable', subkey='selection')
-                if outputParam and outputParam['prompt'] == 'raster':
+                mapName = None
+                if args[0][0] == 'r.mapcalc':
+                    try:
+                        mapName = args[0][1].split('=', 1)[0].strip()
+                    except KeyError:
+                        pass
+                else:
+                    moduleInterface = menuform.GUI().ParseCommand(args[0], show = None)
+                    outputParam = moduleInterface.get_param(value = 'output', raiseError = False)
+                    if outputParam and outputParam['prompt'] == 'raster':
+                        mapName = outputParam['value']
+                if mapName:
                     argsColor = list(args)
                     argsColor[0] = [ 'r.colors',
-                                     'map=%s' % outputParam['value'],
+                                     'map=%s' % mapName,
                                      'color=%s' % colorTable ]
                     self.requestCmdColor = callable(*argsColor, **kwds)
                     self.resultQ.put((requestId, self.requestCmdColor.run()))
@@ -480,7 +490,7 @@
                 else:
                     lname = None
-                if self.parent.GetName() == "LayerManager":
+                if self.parent.GetName() == "LayerManager":
                     self.parent.curr_page.maptree.AddLayer(ltype=layertype,
                                                            lname=lname,
                                                            lcmd=command)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py	2010-11-23 10:38:35 UTC (rev 44386)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py	2010-11-23 13:57:01 UTC (rev 44387)
@@ -451,10 +451,13 @@
         if not self.addbox.IsChecked():
             return
         name = self.newmaptxt.GetValue().strip() + '@' + grass.gisenv()['MAPSET']
-        self.parent.GetLayerTree().AddLayer(ltype = 'raster',
-                                            lname = name,
-                                            lcmd = ['d.rast', 'map=%s' % name],
-                                            multiple = False)
+        mapTree = self.parent.GetLayerTree()
+        if not mapTree.GetMap().GetListOfLayers(l_name = name):
+            mapTree.AddLayer(ltype = 'raster',
+                             lname = name,
+                             lcmd = ['d.rast', 'map=%s' % name],
+                             multiple = False)
         display = self.parent.GetLayerTree().GetMapDisplay()
         if display and display.IsAutoRendered():
             display.GetWindow().UpdateMap(render = True)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py	2010-11-23 10:38:35 UTC (rev 44386)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py	2010-11-23 13:57:01 UTC (rev 44387)
@@ -739,6 +739,8 @@
         if not self.cmdDesc or cmd != self.cmdDesc.get_name():
             if cmd in ('r.mapcalc', 'r3.mapcalc'):
                 self.parent.parent.OnMapCalculator(event = None, cmd = [cmd])
+                # add command to history & clean prompt
+                self.UpdateCmdHistory([cmd])
                 self.OnCmdErase(None)
             else:
                 try:
@@ -746,6 +748,19 @@
                 except IOError:
                     self.cmdDesc = None
+    def UpdateCmdHistory(self, cmd):
+        """!Update command history
+        @param cmd command given as a list
+        self.cmdbuffer.append(' '.join(cmd))
+        # keep command history to a managable size
+        if len(self.cmdbuffer) > 200:
+            del self.cmdbuffer[0]
+        self.cmdindex = len(self.cmdbuffer)
     def OnKeyPressed(self, event):
         """!Key press capture for autocompletion, calltips, and command history
@@ -902,20 +917,13 @@
                 cmd = utils.split(utils.EncodeString((line)))
             #  send the command list to the processor
-            if cmd[0] in ('r.mapcalc', 'r3.mapcalc'):
+            if cmd[0] in ('r.mapcalc', 'r3.mapcalc') and len(cmd) == 1:
                 self.parent.parent.OnMapCalculator(event = None, cmd = cmd)
             else:
                 self.parent.RunCmd(cmd)
-            # add command to history
-            self.cmdbuffer.append(' '.join(cmd))
-            # keep command history to a managable size
-            if len(self.cmdbuffer) > 200:
-                del self.cmdbuffer[0]
-            self.cmdindex = len(self.cmdbuffer)
-            # reset command-line
+            self.UpdateCmdHistory(cmd)
         elif event.GetKeyCode() == wx.WXK_SPACE:
