[GRASS-SVN] r44464 - grass/trunk/vector/v.out.ogr
Sun Nov 28 12:54:32 EST 2010
Author: mmetz
Date: 2010-11-28 09:54:31 -0800 (Sun, 28 Nov 2010)
New Revision: 44464
   grass/trunk/vector/v.out.ogr/main.c
format code
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2010-11-28 17:40:34 UTC (rev 44463)
+++ grass/trunk/vector/v.out.ogr/main.c	2010-11-28 17:54:31 UTC (rev 44464)
@@ -34,7 +34,7 @@
     int field;
     struct GModule *module;
     struct Options options;
-    struct Flags   flags;
+    struct Flags flags;
     char buf[2000];
     char key1[200], key2[200];
@@ -56,8 +56,8 @@
     dbString dbstring;
     dbColumn *Column;
-    int fout, fskip;		   /* features written/ skip */
-    int nocat, noatt, nocatskip;   /* number of features without cats/atts written/skip */
+    int fout, fskip;		/* features written/ skip */
+    int nocat, noatt, nocatskip;	/* number of features without cats/atts written/skip */
     /* OGR */
     int drn, ogr_ftype = OFTInteger;
@@ -80,14 +80,13 @@
     G_add_keyword(_("vector"));
     G_add_keyword(_("export"));
     G_add_keyword(_("ogr"));
     module->description =
 	_("Converts a vector map to any of the supported OGR vector formats.");
     /* parse & read options */
-    parse_args(argc, argv,
-	       &options, &flags);
+    parse_args(argc, argv, &options, &flags);
     /* parse dataset creation options */
     i = 0;
     while (options.dsco->answers[i]) {
@@ -109,73 +108,76 @@
-        If no output type specified: determine one automatically.
-        Centroids, Boundaries and Kernels always have to be exported
-        explicitely, using the "type=" option.
+       If no output type specified: determine one automatically.
+       Centroids, Boundaries and Kernels always have to be exported
+       explicitely, using the "type=" option.
     if (!flags.new->answer) {
 	/* open input vector (topology required) */
 	Vect_set_open_level(2);
 	Vect_open_old2(&In, options.input->answer, "", options.field->answer);
 	if (strcmp(options.type->answer, "auto") == 0) {
 	    G_debug(2, "Automatic type determination.");
-	    options.type->answers = G_malloc(sizeof(char*) * 10);
+	    options.type->answers = G_malloc(sizeof(char *) * 10);
 	    G_zero(options.type->answers, sizeof(char *) * 10);
 	    num_types = 0;
-	    if (Vect_get_num_primitives (&In, GV_POINT) > 0) {
+	    if (Vect_get_num_primitives(&In, GV_POINT) > 0) {
 		options.type->answers[num_types++] = G_store("point");
 		G_debug(3, "Adding points to export list.");
-	    if (Vect_get_num_primitives (&In, GV_LINE) > 0 ) {
+	    if (Vect_get_num_primitives(&In, GV_LINE) > 0) {
 		options.type->answers[num_types++] = G_store("line");
 		G_debug(3, "Adding lines to export list.");
-	    if (Vect_get_num_areas (&In) > 0) {
+	    if (Vect_get_num_areas(&In) > 0) {
 		options.type->answers[num_types++] = G_store("area");
 		G_debug(3, "Adding areas to export list.");
 	    /*  Faces and volumes:
-		For now, volumes will just be exported as sets of faces.
-	    if (Vect_get_num_primitives (&In, GV_FACE) > 0) {
+	       For now, volumes will just be exported as sets of faces.
+	    if (Vect_get_num_primitives(&In, GV_FACE) > 0) {
 		options.type->answers[num_types++] = G_store("face");
 		G_debug(3, "Adding faces to export list.");
 	    /* this check HAS TO FOLLOW RIGHT AFTER check for GV_FACE! */
-	    if ( Vect_get_num_volumes (&In) > 0) {
+	    if (Vect_get_num_volumes(&In) > 0) {
 		G_warning(_("Volumes will be exported as sets of faces"));
 		if (num_types == 0) {
 		    /* no other types yet? */
 		    options.type->answers[num_types++] = G_store("volume");
 		    G_debug(3, "Adding volumes to export list.");
-		} else {
-		    if (strcmp(options.type->answers[num_types-1], "face") != 0) {
+		else {
+		    if (strcmp(options.type->answers[num_types - 1], "face")
+			!= 0) {
 			/* only put faces on export list if that's not the case already */
-			options.type->answers[num_types++] = G_store("volume");
+			options.type->answers[num_types++] =
+			    G_store("volume");
 	    if (num_types == 0)
 		G_fatal_error(_("Unable to determine input map's vector feature type(s)."));
     field = Vect_get_field_number(&In, options.field->answer);
     /* check output feature type */
     otype = Vect_option_to_types(options.type);
     if (!options.layer->answer) {
-	char xname[GNAME_MAX],	xmapset[GMAPSET_MAX];
+	char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
 	if (G_name_is_fully_qualified(options.input->answer, xname, xmapset))
 	    options.layer->answer = G_store(xname);
@@ -234,11 +236,14 @@
     /* create new OGR layer in datasource */
     if (flags.new->answer) {
 	const char *name;
-	name = options.layer->answer ? options.layer->answer : options.input->answer;
+	name =
+	    options.layer->answer ? options.layer->answer : options.input->
+	    answer;
 	create_ogr_layer(options.dsn->answer, options.format->answer, name,
-			 wkbtype, (const char **) papszDSCO, (const char **) papszLCO);
+			 wkbtype, papszDSCO, papszLCO);
 	G_message(_("OGR layer <%s> created in datasource <%s> (format '%s')"),
 		  name, options.dsn->answer, options.format->answer);
 	exit(EXIT_SUCCESS);
@@ -252,9 +257,10 @@
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
-    if ((GV_AREA & otype) && Vect_get_num_islands(&In) > 0 && flags.cat->answer)
+    if ((GV_AREA & otype) && Vect_get_num_islands(&In) > 0 &&
+	flags.cat->answer)
 	G_warning(_("The map contains islands. With the -c flag, "
-	            "islands will appear as filled areas, not holes in the output map."));
+		    "islands will appear as filled areas, not holes in the output map."));
     /* Open OGR DSN */
     G_debug(2, "driver count = %d", OGRGetDriverCount());
@@ -274,13 +280,16 @@
 	G_fatal_error(_("OGR driver <%s> not found"), options.format->answer);
     Ogr_driver = OGRGetDriver(drn);
-    if (flags.update->answer)  {
-    	G_debug(1, "Update OGR data source");
-        Ogr_ds = OGR_Dr_Open(Ogr_driver, options.dsn->answer, TRUE);
-    } else {
-    	G_debug(1, "Create OGR data source");
-    	Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, options.dsn->answer, papszDSCO);
+    if (flags.update->answer) {
+	G_debug(1, "Update OGR data source");
+	Ogr_ds = OGR_Dr_Open(Ogr_driver, options.dsn->answer, TRUE);
+    else {
+	G_debug(1, "Create OGR data source");
+	Ogr_ds =
+	    OGR_Dr_CreateDataSource(Ogr_driver, options.dsn->answer,
+				    papszDSCO);
     CSLDestroy(papszDSCO);
     if (Ogr_ds == NULL)
@@ -299,7 +308,7 @@
 	    papszLCO = CSLSetNameValue(papszLCO, "OVERWRITE", "YES");
     /* check if the map is 3d */
     if (Vect_is_3d(&In)) {
 	/* specific check for ESRI ShapeFile */
@@ -336,8 +345,8 @@
     G_debug(1, "Create OGR layer");
     Ogr_layer =
-	OGR_DS_CreateLayer(Ogr_ds, options.layer->answer, Ogr_projection, wkbtype,
-			   papszLCO);
+	OGR_DS_CreateLayer(Ogr_ds, options.layer->answer, Ogr_projection,
+			   wkbtype, papszLCO);
     CSLDestroy(papszLCO);
     if (Ogr_layer == NULL)
 	G_fatal_error(_("Unable to create OGR layer"));
@@ -354,8 +363,8 @@
 	    /* if we have no more than a 'cat' column, then that has to
 	       be exported in any case */
 	    if (flags.nocat->answer) {
-	        G_warning(_("Exporting 'cat' anyway, as it is the only attribute table field"));
-	        flags.nocat->answer=0;
+		G_warning(_("Exporting 'cat' anyway, as it is the only attribute table field"));
+		flags.nocat->answer = 0;
 	    Ogr_field = OGR_Fld_Create("cat", OFTInteger);
 	    OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
@@ -368,7 +377,7 @@
 	    if (!Driver)
 		G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			      Fi->database, Fi->driver);
 	    db_set_string(&dbstring, Fi->table);
 	    if (db_describe_table(Driver, &dbstring, &Table) != DB_OK)
 		G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
@@ -407,17 +416,19 @@
 		    keycol = i;
 		G_debug(2, "%s x %s -> %s x %s -> keycol = %d", Fi->key,
 			db_get_column_name(Column), key1, key2, keycol);
 		if (!flags.nocat->answer) {
 		    Ogr_field =
-		        OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
+			OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
 		    OGR_Fld_Destroy(Ogr_field);
-		} else {
+		else {
 		    /* skip export of 'cat' field */
-		    if (strcmp (Fi->key, db_get_column_name(Column)) != 0) {
+		    if (strcmp(Fi->key, db_get_column_name(Column)) != 0) {
 			Ogr_field =
+					   ogr_ftype);
@@ -426,7 +437,6 @@
 	    if (keycol == -1)
 		G_fatal_error(_("Key column <%s> not found"), Fi->key);
     Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
@@ -453,8 +463,8 @@
     if (Vect_get_num_primitives(&In, GV_CENTROID) > 0 &&
 	!(otype & GV_CENTROID) && !(otype & GV_AREA))
 	G_warning(_("%d centroid(s) found, but not requested to be exported. "
-		   "Verify 'type' parameter."), Vect_get_num_primitives(&In,
-									GV_CENTROID));
+		    "Verify 'type' parameter."), Vect_get_num_primitives(&In,
+									 GV_CENTROID));
     if (Vect_get_num_areas(&In) > 0 && !(otype & GV_AREA))
 	G_warning(_("%d areas found, but not requested to be exported. "
@@ -472,73 +482,89 @@
     /* warn and eventually abort if there is nothing to be exported */
     num_to_export = 0;
     if (Vect_get_num_primitives(&In, GV_POINT) < 1 && (otype & GV_POINTS)) {
-        G_warning(_("No points found, but requested to be exported. "
+	G_warning(_("No points found, but requested to be exported. "
 		    "Will skip this feature type."));
-    } else {
-        if (otype & GV_POINT)
-            num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_POINT);
+    else {
+	if (otype & GV_POINT)
+	    num_to_export =
+		num_to_export + Vect_get_num_primitives(&In, GV_POINT);
     if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
-        G_warning(_("No lines found, but requested to be exported. "
+	G_warning(_("No lines found, but requested to be exported. "
-    } else {
-        if (otype & GV_LINE)
-            num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_LINE);
+    else {
+	if (otype & GV_LINE)
+	    num_to_export =
+		num_to_export + Vect_get_num_primitives(&In, GV_LINE);
-    if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 && (otype & GV_BOUNDARY)) {
-        G_warning(_("No boundaries found, but requested to be exported. "
-		    "Will skip this feature type."));
-    } else {
-        if (otype & GV_BOUNDARY)
-            num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
+    if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 &&
+	(otype & GV_BOUNDARY)) {
+	G_warning(_("No boundaries found, but requested to be exported. "
+		   "Will skip this feature type."));
+    else {
+	if (otype & GV_BOUNDARY)
+	    num_to_export =
+		num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
     if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
-        G_warning(_("No areas found, but requested to be exported. "
+	G_warning(_("No areas found, but requested to be exported. "
-    } else {
-        if (otype & GV_AREA)
-            num_to_export = num_to_export + Vect_get_num_areas(&In);
+    else {
+	if (otype & GV_AREA)
+	    num_to_export = num_to_export + Vect_get_num_areas(&In);
-    if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 && (otype & GV_CENTROID)) {
-        G_warning(_("No centroids found, but requested to be exported. "
-    } else {
-        if (otype & GV_CENTROID)
-            num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
+    if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 &&
+	(otype & GV_CENTROID)) {
+	G_warning(_("No centroids found, but requested to be exported. "
+    else {
+	if (otype & GV_CENTROID)
+	    num_to_export =
+		num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
     if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
-        G_warning(_("No faces found, but requested to be exported. "
+	G_warning(_("No faces found, but requested to be exported. "
-    } else {
-        if (otype & GV_FACE)
-            num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_FACE);
+    else {
+	if (otype & GV_FACE)
+	    num_to_export =
+		num_to_export + Vect_get_num_primitives(&In, GV_FACE);
     if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
-        G_warning(_("No kernels found, but requested to be exported. "
+	G_warning(_("No kernels found, but requested to be exported. "
-    } else {
-        if (otype & GV_KERNEL)
-            num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
+    else {
+	if (otype & GV_KERNEL)
+	    num_to_export =
+		num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
     if (Vect_get_num_volumes(&In) < 1 && (otype & GV_VOLUME)) {
-        G_warning(_("No volumes found, but requested to be exported. "
+	G_warning(_("No volumes found, but requested to be exported. "
-    } else {
-        if (otype & GV_VOLUME)
-            num_to_export = num_to_export + Vect_get_num_volumes(&In);
+    else {
+	if (otype & GV_VOLUME)
+	    num_to_export = num_to_export + Vect_get_num_volumes(&In);
     G_debug(1, "Requested to export %d features", num_to_export);
     if (num_to_export < 1) {
-        G_warning(_("Nothing to export"));
+	G_warning(_("Nothing to export"));
 	exit(EXIT_SUCCESS);
@@ -562,7 +588,7 @@
 		nocatskip++;
 		continue;
 	    /* Geometry */
 	    if (type == GV_LINE && flags.poly->answer) {
 		OGRGeometryH ring;
@@ -584,7 +610,8 @@
 		OGR_G_AddGeometryDirectly(Ogr_geometry, ring);
-	    else if ((type == GV_POINT) || ((type == GV_CENTROID) && (otype & GV_CENTROID))) {
+	    else if ((type == GV_POINT) ||
+		     ((type == GV_CENTROID) && (otype & GV_CENTROID))) {
 		Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
 		OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
 			       Points->z[0]);
@@ -613,7 +640,8 @@
 			continue;
-		mk_att(cat, Fi, Driver, ncol, doatt, flags.nocat->answer, Ogr_feature, &noatt, &fout);
+		mk_att(cat, Fi, Driver, ncol, doatt, flags.nocat->answer,
+		       Ogr_feature, &noatt, &fout);
 		OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
 	    OGR_G_DestroyGeometry(Ogr_geometry);
@@ -671,7 +699,7 @@
-        Ogr_feature = OGR_F_Create(Ogr_featuredefn);
+	    Ogr_feature = OGR_F_Create(Ogr_featuredefn);
 	    OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
 	    /* Output one feature for each category */
@@ -687,7 +715,8 @@
 			continue;
@@ -697,8 +726,7 @@
     /* Faces (run always to count features of different type)  - Faces are similar to lines */
     if (Vect_get_num_primitives(&In, GV_FACE) > 0 && otype & GV_FACE) {
-	G_message(_("Exporting %i faces..."),
-		  Vect_get_num_faces(&In));
+	G_message(_("Exporting %i faces..."), Vect_get_num_faces(&In));
 	for (i = 1; i <= Vect_get_num_faces(&In); i++) {
 	    OGRGeometryH ring;
@@ -718,7 +746,7 @@
 	    if (type & GV_FACE) {
 		/* Geometry */
 		Ogr_geometry = OGR_G_CreateGeometry(wkbPolygon25D);
@@ -747,14 +775,14 @@
 			    continue;
 		OGR_F_Destroy(Ogr_feature);
 	    }			/* if type & GV_FACE */
 	}			/* for */
@@ -779,48 +807,48 @@
 		continue;
 	    /* Geometry */
 	    if (type == GV_KERNEL) {
-            Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
-            OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
-                    Points->z[0]);
+		Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
+		OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
+			       Points->z[0]);
-            OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
+		OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
-            /* Output one feature for each category */
-            for (j = -1; j < Cats->n_cats; j++) {
-            if (j == -1) {
-                if (cat >= 0)
-                continue;	/* cat(s) exists */
-            else {
-                if (Cats->field[j] == field)
-                cat = Cats->cat[j];
-                else
-                continue;
+		/* Output one feature for each category */
+		for (j = -1; j < Cats->n_cats; j++) {
+		    if (j == -1) {
+			if (cat >= 0)
+			    continue;	/* cat(s) exists */
+		    else {
+			if (Cats->field[j] == field)
+			    cat = Cats->cat[j];
+			else
+			    continue;
-                OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
-            OGR_G_DestroyGeometry(Ogr_geometry);
-            OGR_F_Destroy(Ogr_feature);
+		    OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
+		OGR_G_DestroyGeometry(Ogr_geometry);
+		OGR_F_Destroy(Ogr_feature);
-        TODO:   Volumes. Do not export kernels here, that's already done.
-                We do need to worry about holes, though.
-        NOTE: We can probably just merge this with faces export function.
-              Except for GRASS, which output format would know the difference?
+       TODO:   Volumes. Do not export kernels here, that's already done.
+       We do need to worry about holes, though.
+       NOTE: We can probably just merge this with faces export function.
+       Except for GRASS, which output format would know the difference?
     if ((otype & GV_VOLUME)) {
-        G_message(_("Exporting %i volumes..."), Vect_get_num_volumes(&In));
-        G_warning(_("Export of volumes not implemented yet. Skipping."));
+	G_message(_("Exporting %i volumes..."), Vect_get_num_volumes(&In));
+	G_warning(_("Export of volumes not implemented yet. Skipping."));
     OGR_DS_Destroy(Ogr_ds);
@@ -839,7 +867,7 @@
 	G_warning(_("%d features without attributes were written"), noatt);
     if (nocatskip > 0)
 	G_message(_("%d features found without category were skipped"),
-		nocatskip);
+		  nocatskip);
     /* Enable this? May be confusing that for area type are not reported
      *    all boundaries/centroids.
@@ -851,6 +879,6 @@
     G_done_msg(_("%d features written to <%s> (%s)."), fout,
 	       options.layer->answer, options.format->answer);
     exit(EXIT_SUCCESS);
