[GRASS-SVN] r44472 - grass/branches/develbranch_6/imagery/i.ortho.photo/libes
Mon Nov 29 03:05:42 EST 2010
Author: mmetz
Date: 2010-11-29 00:05:42 -0800 (Mon, 29 Nov 2010)
New Revision: 44472
   grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_cameras.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_elev.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/libes/m_mult.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthophoto.h
   grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthoref.c
ortholib: optimize, simplify, fix bugs
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_cameras.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_cameras.c	2010-11-28 22:22:49 UTC (rev 44471)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_cameras.c	2010-11-29 08:05:42 UTC (rev 44472)
@@ -36,7 +36,7 @@
     strcat(buf, ";ls");
     if (!full)
 	strcat(buf, " -C");
-    if (ls = popen(buf, "r")) {
+    if ((ls = popen(buf, "r"))) {
 	while (G_getl(buf, sizeof buf, ls)) {
 	    any = 1;
 	    fprintf(temp, "%s", buf);
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_elev.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_elev.c	2010-11-28 22:22:49 UTC (rev 44471)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/libes/ls_elev.c	2010-11-29 08:05:42 UTC (rev 44472)
@@ -33,7 +33,7 @@
     G__file_name(buf + strlen(buf), element, " ", " ");
     strcat(buf, ";ls");
     strcat(buf, " -C");
 	    any = 1;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/libes/m_mult.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/libes/m_mult.c	2010-11-28 22:22:49 UTC (rev 44471)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/libes/m_mult.c	2010-11-29 08:05:42 UTC (rev 44472)
@@ -11,7 +11,6 @@
     register int i, j, k, nr, nc, ncols;
     char message[256];
-    static MATRIX m;
     if (a->nrows == 0)
 	return error("*: arg1 not defined\n");
@@ -31,13 +30,12 @@
     nc = b->ncols;
     for (i = 0; i < nr; i++)
 	for (j = 0; j < nc; j++) {
-	    m.x[i][j] = 0.0;
+	    c->x[i][j] = 0.0;
 	    for (k = 0; k < ncols; k++)
-		m.x[i][j] += (a->x[i][k] * b->x[k][j]);
+		c->x[i][j] += (a->x[i][k] * b->x[k][j]);
-    m.nrows = nr;
-    m.ncols = nc;
-    m_copy(c, &m);
+    c->nrows = nr;
+    c->ncols = nc;
     return 1;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthophoto.h
--- grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthophoto.h	2010-11-28 22:22:49 UTC (rev 44471)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthophoto.h	2010-11-29 08:05:42 UTC (rev 44472)
@@ -1,5 +1,6 @@
 #include <grass/gis.h>
 #include <grass/imagery.h>
+#include "mat.h"
 /* #define DEBUG  1 */
@@ -57,6 +58,8 @@
     int *status;
+/* Ortho_Control_Points is identical to Ortho_Photo_Points
+ * Why ? */
 struct Ortho_Control_Points
     int count;
@@ -104,6 +107,7 @@
     int con_equation_stat;
     double E12[3], N12[3], E21[3], N21[3], Z12[3], Z21[3];
     double XC, YC, ZC, omega, phi, kappa;
+    MATRIX M, MI;
 /* conz_points.c */
@@ -121,13 +125,13 @@
 			      struct Ortho_Camera_File_Ref *,
 			      struct Ortho_Camera_Exp_Init *, double *,
 			      double *, double *, double *, double *,
-			      double *);
+			      double *, MATRIX *, MATRIX *);
 int I_ortho_ref(double, double, double, double *, double *, double *,
 		struct Ortho_Camera_File_Ref *, double, double, double,
-		double, double, double);
+		MATRIX);
 int I_inverse_ortho_ref(double, double, double, double *, double *, double *,
-			double, double, double, double);
+			double, MATRIX);
 /* ref_points.c */
 int I_new_ref_point(struct Ortho_Photo_Points *, double, double, double,
 		    double, int);
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthoref.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthoref.c	2010-11-28 22:22:49 UTC (rev 44471)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/libes/orthoref.c	2010-11-29 08:05:42 UTC (rev 44472)
@@ -32,29 +32,26 @@
 #include <math.h>
 #include "orthophoto.h"
-#include "mat.h"
 #include "matrixdefs.h"
 #include "local_proto.h"
-#define MAX_ITERS   10		/* Max iteration is normal equation solution */
-#define CONV_LIMIT  1.0		/* meters */
+#define MAX_ITERS   1000	/* Max iteration is normal equation solution */
+#define CONV_LIMIT  0.1		/* meters */
 #ifdef DEBUG
 FILE *debug;
 char msg[120];
 #endif
-static int floating_exception;
-static void catch(int);
 /* Compute the ortho rectification parameters */
 /* XC,YC,ZC, Omega, Phi, Kappa */
 int I_compute_ortho_equations(struct Ortho_Control_Points *cpz,
 			      struct Ortho_Camera_File_Ref *cam_info,
 			      struct Ortho_Camera_Exp_Init *init_info,
 			      double *XC, double *YC, double *ZC,
-			      double *Omega, double *Phi, double *Kappa)
+			      double *Omega, double *Phi, double *Kappa,
+			      MATRIX *MO, MATRIX *MT)
     MATRIX delta, epsilon, B, BT, C, E, N, CC, NN, UVW, XYZ, M, WT1;
     double meanx, meany;
@@ -74,21 +71,16 @@
     Q1 = (double)1.0;
-     *  floating_exception = 0;
-     *  sigfpe = signal (SIGFPE, catch);
     /* DEBUG */
 #ifdef DEBUG
     debug = fopen("ortho_compute.rst", "w");
     if (debug == NULL) {
-	sprintf(msg, "Cant open debug file ortho_analyze.rst\n");
+	sprintf(msg, "Cant open debug file ortho_compute.rst\n");
 	G_fatal_error(msg);
 #endif
-    /*  Need 4 active control points */
+    /*  Need at least 4 active control points */
     active = 0;
     for (i = 0; i < cpz->count; i++) {
 	if (cpz->status[i] > 0)
@@ -148,7 +140,7 @@
     UVW.nrows = 3;
     UVW.ncols = 1;
     zero(&UVW);
-    /* Oreintaiton Matrix  M=[3,3] functions of (omega,phi,kappa) */
+    /*  Orientation Matrix  M=[3,3] functions of (omega,phi,kappa) */
     M.nrows = 3;
     M.ncols = 3;
     zero(&M);
@@ -160,7 +152,7 @@
 /******************** Start the solution *****************************/
-    /* set Xp, Yp, and CFL form cam_info */
+    /* set Xp, Yp, and CFL from cam_info */
     Xp = cam_info->Xp;
     Yp = cam_info->Yp;
     CFL = cam_info->CFL;
@@ -171,7 +163,7 @@
 #endif
     /* use initial estimates for XC,YC,ZC,omega,phi,kappa
-     * and initial standard deviations if proveded by i.ortho.photo
+     * and initial standard deviations if provided by i.ortho.photo
      * otherwise set from mean value of all active control points
      * - init_info is generated by photo.init (file INIT_EXP)
@@ -194,12 +186,15 @@
 	WT1.x[4][4] = (Q1 / (init_info->phi_var * init_info->phi_var));
 	WT1.x[5][5] = (Q1 / (init_info->kappa_var * init_info->kappa_var));
-    else {			/* set from mean values of active control points */
+    else {  /* set from mean values of active control points */
+	double meanX, meanY, meanZ;
+	int nz;
 	/* set intial XC and YC from mean values of control points */
 	meanx = meany = 0;
-	n = 0;
+	meanX = meanY = meanZ = 0;
+	*ZC = 0;
+	n = nz = 0;
 	first = 1;
 	    if (cpz->status[i] <= 0)
@@ -219,20 +214,37 @@
 		x2 = *(cpz->e1);
 		Y2 = *(cpz->n2);
 		y2 = *(cpz->n1);
+		Z1 = *(cpz->z2);
 		dist_photo =
 		    sqrt(((x1 - x2) * (x1 - x2)) + ((y1 - y2) * (y1 - y2)));
 		dist_grnd =
 		    sqrt(((X1 - X2) * (X1 - X2)) + ((Y1 - Y2) * (Y1 - Y2)));
+		/* set initial ZC from:                                  */
+		/*    scale ~= dist_photo/dist_grnd  ~= (CFL)/(Z1 - Zc)  */
+		/*       Zc ~= Z1 + CFL(dist_grnd)/(dist_photo)          */
+		if (dist_grnd != 0 && dist_photo != 0) {
+		    meanZ += Z1 + (CFL * (dist_grnd) / (dist_photo));
+		    nz++;
 	    n++;
-	    meanx += *((cpz->e2)++);
-	    meany += *((cpz->n2)++);
-	    ((cpz->e1)++);
-	    ((cpz->n1)++);
+	    meanx += *((cpz->e1)++);
+	    meany += *((cpz->n1)++);
+	    meanX += *((cpz->e2)++);
+	    meanY += *((cpz->n2)++);
+	    (cpz->z2)++;
-	*XC = meanx / n;
-	*YC = meany / n;
+	*XC = meanX / n;
+	*YC = meanY / n;
+	*ZC = meanZ / (nz - 1);
+	G_debug(2, "XC: %.2f, YC: %.2f, ZC: %.2f", *XC, *YC, *ZC);
+	meanx = (meanx - x1) / (n - 1);
+	meany = (meany - y1) / (n - 1);
+	meanX = (meanX - X1) / (n - 1);
+	meanY = (meany - Y1) / (n - 1);
 	/* reset pointers */
@@ -242,20 +254,19 @@
 	    (cpz->e2)--;
 	    (cpz->n1)--;
 	    (cpz->n2)--;
+	    (cpz->z2)--;
-	/* set initial ZC from:                                  */
-	/*    scale ~= dist_photo/dist_grnd  ~= (CFL)/(Z1 - Zc)  */
-	/*       Zc ~= Z1 + CFL(dist_grnd)/(dist_photo)          */
-	*ZC = Z1 + (CFL * (dist_grnd) / (dist_photo));
 	/* set initial rotations to zero (radians) */
 	*Omega = *Phi = 0.0;
 	/* find an initial kappa */
 	kappa1 = atan2((y2 - y1), (x2 - x1));
 	kappa2 = atan2((Y2 - Y1), (X2 - X1));
+	kappa1 = atan2((meany - y1), (meanx - x1));
+	kappa2 = atan2((meanY - Y1), (meanX - X1));
 	*Kappa = (kappa2 - kappa1);
 	/* set initial weights */
@@ -362,12 +373,12 @@
 	    fprintf(debug, "\n\t\t\tIn Summation count = %d \n", i);
 #endif
-	    x = *((cpz->e1))++;
-	    y = *((cpz->n1))++;
-	    z = *((cpz->z1))++;
-	    X = *((cpz->e2))++;
-	    Y = *((cpz->n2))++;
-	    Z = *((cpz->z2))++;
+	    x = *((cpz->e1)++);
+	    y = *((cpz->n1)++);
+	    z = *((cpz->z1)++);
+	    X = *((cpz->e2)++);
+	    Y = *((cpz->n2)++);
+	    Z = *((cpz->z2)++);
 		continue;
@@ -389,7 +400,7 @@
 	    mu = XYZ.x[1][0];
 	    nu = XYZ.x[2][0];
-	    /* Compute image space coordiantes */
+	    /* Compute image space coordinates */
 	    m_mult(&M, &XYZ, &UVW);
 	    /*  just an abbreviation */
@@ -397,7 +408,6 @@
 	    V = UVW.x[1][0];
 	    W = UVW.x[2][0];
 	    /* Form Partial derivatives of Normal Equations */
 	    xbar = x - Xp;
 	    ybar = y - Yp;
@@ -454,7 +464,7 @@
 	    m_mult(&BT, &E, &C);
 	    /* CC += C */
 	    m_add(&CC, &C, &CC);
-	}			/* end summation loop over all active control points */
+	}  /* end summation loop over all active control points */
@@ -479,7 +489,6 @@
 		CC.x[3][0], CC.x[4][0], CC.x[5][0]);
 #endif
 	/* Add weigth matrix of unknowns to NN */
 	m_add(&NN, &WT1, &NN);
 	/* Solve for delta */
@@ -503,7 +512,7 @@
 		delta.x[4][0], delta.x[5][0]);
 #endif
-    }				/* end ITERATION loop */
+    }  /* end ITERATION loop */
     /* This is the solution */
     *XC = epsilon.x[0][0];
@@ -513,6 +522,45 @@
     *Phi = epsilon.x[4][0];
     *Kappa = epsilon.x[5][0];
+    /*  Compute Orientation Matrix M from (Omega, Phi, Kappa); */
+    sw = sin(*Omega);
+    cw = cos(*Omega);
+    sp = sin(*Phi);
+    cp = cos(*Phi);
+    sk = sin(*Kappa);
+    ck = cos(*Kappa);
+    MO->nrows = 3;
+    MO->ncols = 3;
+    zero(MO);
+    MO->x[0][0] = cp * ck;
+    MO->x[0][1] = cw * sk + (sw * sp * ck);
+    MO->x[0][2] = sw * sk - (cw * sp * ck);
+    MO->x[1][0] = -(cp * sk);
+    MO->x[1][1] = cw * ck - (sw * sp * sk);
+    MO->x[1][2] = sw * ck + (cw * sp * sk);
+    MO->x[2][0] = sp;
+    MO->x[2][1] = -(sw * cp);
+    MO->x[2][2] = cw * cp;
+    /* Compute Transposed Orientation Matrix (Omega, Phi, Kappa); */
+    MT->nrows = 3;
+    MT->ncols = 3;
+    zero(MT);
+    /* M Transposed */
+    MT->x[0][0] = cp * ck;
+    MT->x[1][0] = cw * sk + (sw * sp * ck);
+    MT->x[2][0] = sw * sk - (cw * sp * ck);
+    MT->x[0][1] = -(cp * sk);
+    MT->x[1][1] = cw * ck - (sw * sp * sk);
+    MT->x[2][1] = sw * ck + (cw * sp * sk);
+    MT->x[0][2] = sp;
+    MT->x[1][2] = -(sw * cp);
+    MT->x[2][2] = cw * cp;
 #ifdef DEBUG
     fclose(debug);
 #endif
@@ -520,24 +568,16 @@
     return (1);
-static void catch(int n)
-    floating_exception = 1;
-    signal(n, catch);
 /* given ground coordinates (e1,n1,z1) and the solution from above */
 /* compute the photo coordinate (e2,n2) position */
 int I_ortho_ref(double e1, double n1, double z1,
 		double *e2, double *n2, double *z2,
-		double XC, double YC, double ZC,
-		double Omega, double Phi, double Kappa)
+		double XC, double YC, double ZC, MATRIX M)
-    MATRIX UVW, XYZ, M;
+    MATRIX UVW, XYZ;
     double U, V, W;
     double Xp, Yp, CFL;
-    double sw, cw, sp, cp, sk, ck;
     /*  Initialize and zero the matrices */
     /*  Object Space Coordinates */
@@ -548,35 +588,13 @@
     UVW.nrows = 3;
     UVW.ncols = 1;
     zero(&UVW);
-    /*  Orientation Matrix */
-    M.nrows = 3;
-    M.ncols = 3;
-    zero(&M);
     /************************ Start the work ******************************/
     Xp = cam_info->Xp;
     Yp = cam_info->Yp;
-    /*  Compute Orientation Matrix M from (Omega, Phi, Kappa); */
-    sw = sin(Omega);
-    cw = cos(Omega);
-    sp = sin(Phi);
-    cp = cos(Phi);
-    sk = sin(Kappa);
-    ck = cos(Kappa);
-    M.x[0][0] = cp * ck;
-    M.x[0][1] = cw * sk + (sw * sp * ck);
-    M.x[0][2] = sw * sk - (cw * sp * ck);
-    M.x[1][0] = -(cp * sk);
-    M.x[1][1] = cw * ck - (sw * sp * sk);
-    M.x[1][2] = sw * ck + (cw * sp * sk);
-    M.x[2][0] = sp;
-    M.x[2][1] = -(sw * cp);
-    M.x[2][2] = cw * cp;
     /* ObjSpace (&XYZ, XC,YC,ZC, X,Y,Z); */
     XYZ.x[0][0] = e1 - XC;
     XYZ.x[1][0] = n1 - YC;
@@ -601,13 +619,11 @@
 int I_inverse_ortho_ref(double e1, double n1, double z1,
+    MATRIX UVW, XYZ;
     double lam, mu, nu;
     double Xp, Yp, CFL;
     /*  Initialize and zero matrices */
@@ -618,36 +634,13 @@
     UVW.nrows = 3;
     UVW.ncols = 1;
     zero(&UVW);
-    M.nrows = 3;
-    M.ncols = 3;
-    zero(&M);
     /********************** Start the work ********************************/
     Xp = cam_info->Xp;
     Yp = cam_info->Yp;
-    /* Compute Orientation Matrix (Omega, Phi, Kappa); */
-    sw = sin(Omega);
-    cw = cos(Omega);
-    sp = sin(Phi);
-    cp = cos(Phi);
-    sk = sin(Kappa);
-    ck = cos(Kappa);
-    /* M Transposed */
-    M.x[1][0] = cw * sk + (sw * sp * ck);
-    M.x[2][0] = sw * sk - (cw * sp * ck);
-    M.x[0][1] = -(cp * sk);
-    M.x[2][1] = sw * ck + (cw * sp * sk);
-    M.x[0][2] = sp;
-    M.x[1][2] = -(sw * cp);
     /* ImageSpace */
     UVW.x[0][0] = e1 - Xp;
     UVW.x[1][0] = n1 - Yp;
