[GRASS-SVN] r43757 - grass-addons/grass7/raster/r.stream/r.stream.distance
Fri Oct 1 07:23:59 EDT 2010
Author: jarekj71
Date: 2010-10-01 11:23:59 +0000 (Fri, 01 Oct 2010)
New Revision: 43757
   grass-addons/grass7/raster/r.stream/r.stream.distance/distance_init.c
update
Modified: grass-addons/grass7/raster/r.stream/r.stream.distance/distance_init.c
--- grass-addons/grass7/raster/r.stream/r.stream.distance/distance_init.c	2010-10-01 11:21:56 UTC (rev 43756)
+++ grass-addons/grass7/raster/r.stream/r.stream.distance/distance_init.c	2010-10-01 11:23:59 UTC (rev 43757)
@@ -17,12 +17,13 @@
 			for (r = 0; r < nrows; ++r)
 		for (c = 0; c < ncols; ++c)
 	if (streams[r][c]>0) {
-			if (outlets_num > 2 * (out_max - 1))
-		G_fatal_error(_
-				("Stream and direction maps probably do not match"));
-			if (outlets_num > (out_max - 1))
-		outlets = (OUTLET *)G_realloc(outlets,out_max*2*sizeof(OUTLET));
+			if (outlets_num > (out_max - 1)) {
+				if (outlets_num > 4 * (out_max - 1))
+			G_fatal_error
+					("Stream and direction maps probably do not match");
+		out_max *= 4;
+		outlets =	(OUTLET *) G_realloc(outlets, (out_max) * sizeof(OUTLET));
 		d = abs(dirs[r][c]);	/* r.watershed */
@@ -79,12 +80,13 @@
 	segment_get(streams,&streams_cell,r,c);
 	if (streams_cell>0) {
-		G_fatal_error(_
+			G_fatal_error
+		out_max *= 4;
 		segment_get(dirs,&dirs_cell,r,c);
 		d = abs(dirs_cell);	/* r.watershed */
