[GRASS-SVN] r43786 - grass-addons/imagery/i.topo.corr
Tue Oct 5 04:29:26 EDT 2010
Author: ejtizado
Date: 2010-10-05 08:29:26 +0000 (Tue, 05 Oct 2010)
New Revision: 43786
   grass-addons/imagery/i.topo.corr/correction.c
   grass-addons/imagery/i.topo.corr/description.html
   grass-addons/imagery/i.topo.corr/illumination.c
a/m in c-correction insteed m/a
Modified: grass-addons/imagery/i.topo.corr/correction.c
--- grass-addons/imagery/i.topo.corr/correction.c	2010-10-05 08:14:33 UTC (rev 43785)
+++ grass-addons/imagery/i.topo.corr/correction.c	2010-10-05 08:29:26 UTC (rev 43786)
@@ -1,3 +1,13 @@
+/* File: correction.c
+ *  AUTHOR:    E. Jorge Tizado, Spain 2010
+ *  COPYRIGHT: (c) 2007-10 E. Jorge Tizado
+ *             This program is free software under the GNU General Public
+ *             License (>=v2). Read the file COPYING that comes with GRASS
+ *             for details.
 #include<stdio.h>
 #include<stdlib.h>
 #include<math.h>
@@ -56,7 +66,9 @@
 		    case MINNAERT:
 			if (cos_i > 0. && cos_z > 0. && ref_i > 0.) {
 			    n++;
-			    tx = log(cos_i / cos_z);
+                            /* tx = log(cos_i / cos_z) */
+                            /* cos_z is constant then m not changes */
+                            tx = log(cos_i);
 			    ty = log(ref_i);
 			    sx += tx;
 			    sxx += tx * tx;
@@ -88,7 +100,7 @@
 	G_message("Minnaert constant = %lf", kk);
 	break;
     case C_CORRECT:
-	cka = ckb = m / a;
+	cka = ckb = a / m; /* Richter changes to m/a */
 	kk = 1.;
 	G_message("C-factor constant = %lf (a=%.4f; m=%.4f)", cka, a, m);
 	break;
Modified: grass-addons/imagery/i.topo.corr/description.html
--- grass-addons/imagery/i.topo.corr/description.html	2010-10-05 08:14:33 UTC (rev 43785)
+++ grass-addons/imagery/i.topo.corr/description.html	2010-10-05 08:29:26 UTC (rev 43786)
@@ -4,7 +4,7 @@
 from imagery files, e.g. obtained with <EM>i.landsat.toar</EM>, using a
 sun illumination terrain model. This illumination model represents the
 cosine of the incident angle, i.e. the  angle between the normal to the
-ground and the sun rays. It can be obtained with <em>r.sun</em>
+ground and the sun rays. It can be obtained with <em>r.sun</em>
 (parameter incidout), and then calculating its cosine with float precision.</p>
 <p>Using flag -i and given an elevation map as basemap (UTM), <em>i.topo.corr</em>
@@ -37,7 +37,7 @@
 	<li>ref_c = ref_o * (cos_z / cos_i) ^ k</li>
 </ul>
 where,
-<em>k</em> is obtained by linear regression of ln(ref_o) = ln(ref_c) - k ln(cos_z/cos_i)</p>
+<em>k</em> is obtained by linear regression of ln(ref_o) = ln(ref_c) - k ln(cos_i/cos_z)</p>
 <H3>Method: c-factor</H3>
@@ -46,13 +46,13 @@
 	<li>ref_c = ref_o * (cos_z + c)/ (cos_i + c)</li>
 </ul>
 where,
-<em>c</em> is m/a from ref_o = a + m cos_i.</p>
+<em>c</em> is a/m from ref_o = a + m * cos_i</p>
 <H3>Method: percent</H3>
-<p>As cos_i varies from -1 to +1, then (cos_i + 1)/2 varied from 0
-(surface in the side in opposition to the sun: infinite correction) to 1
-(direct exhibition to the sun: no correction) and it can be calculated as
+<p>We can use cos_i to estimate the percent of solar incidence on the surface, then the transformation (cos_i + 1)/2 varied from 0
+(surface in the side in opposition to the sun: infinite correction) to 1
+(direct exhibition to the sun: no correction) and the corrected reflectance can be calculated as
 <ul>
 	<li>ref_c = ref_o * 2 / (cos_i + 1)</li>
 </ul>
@@ -64,7 +64,7 @@
 <ol>
 <li>The illumination model (cos_i) with flag -i uses the actual region
     as limits and the resolution of the elevation map.</li>
-<li>The topographic correction use the full reflectance file (null remain
+<li>The topographic correction use the full reflectance file (null remain
     null) and its resolution.</li>
 <!-- TODO: really UTM or just metric? -->
 <li>The elevation map to calculate the illumination model should be UTM.</li>
@@ -72,8 +72,8 @@
 <H2>EXAMPLES</H2>
-<p>First, make a illumination model from the elevation map (here, SRTM), and then make
-topographic correction of the bands toar.5, toar.4 and toar.3 with output
+<p>First, make a illumination model from the elevation map (here, SRTM), and then make
+topographic correction of the bands toar.5, toar.4 and toar.3 with output
 as tcor.toar.5, tcor.toar.4, and tcor.toar.3 using c-factor (= c-correction) method.</p>
 <div class="code">
@@ -85,19 +85,19 @@
 <H2>REFERENCES</H2>
 <ul>
-<li>Law K.H. and Nichol J, 2004. Topographic Correction For Differential
-    Illumination Effects On Ikonos Satellite Imagery. International Archives of
+<li>Law K.H. and Nichol J, 2004. Topographic Correction For Differential
+    Illumination Effects On Ikonos Satellite Imagery. International Archives of
     Photogrammetry Remote Sensing and Spatial Information, pp. 641-646.</li>
 <li>Meyer, P. and Itten, K.I. and Kellenberger, KJ and Sandmeier, S. and Sandmeier, R., 1993.
-    Radiometric corrections of topographically induced effects on Landsat TM data in
+    Radiometric corrections of topographically induced effects on Landsat TM data in
     alpine terrain. Photogrammetric Engineering and Remote Sensing 48(17).
 </li>
-<li>Ria&ntilde;o, D. and Chuvieco, E. and Salas, J. and Aguado, I., 2003.
-    Assessment of Different Topographic Corrections in Landsat-TM
-    Data for Mapping Vegetation Types. IEEE Transactions On Geoscience
+<li>Ria&ntilde;o, D. and Chuvieco, E. and Salas, J. and Aguado, I., 2003.
+    Assessment of Different Topographic Corrections in Landsat-TM
+    Data for Mapping Vegetation Types. IEEE Transactions On Geoscience
     And Remote Sensing, Vol. 41, No. 5</li>
-<li>Twele A. and Erasmi S, 2005. Evaluating topographic correction algorithms
-    for improved land cover discrimination in mountainous areas of
+<li>Twele A. and Erasmi S, 2005. Evaluating topographic correction algorithms
+    for improved land cover discrimination in mountainous areas of
     Central Sulawesi. G&ouml;ttinger Geographische Abhandlungen, vol. 113.</li>
 </ul>
Modified: grass-addons/imagery/i.topo.corr/illumination.c
--- grass-addons/imagery/i.topo.corr/illumination.c	2010-10-05 08:14:33 UTC (rev 43785)
+++ grass-addons/imagery/i.topo.corr/illumination.c	2010-10-05 08:29:26 UTC (rev 43786)
@@ -1,3 +1,13 @@
+/* File: illumination.c
+ *             for details.
 #include<stdio.h>
 #include<stdlib.h>
 #include<math.h>
