[GRASS-SVN] r43872 - grass/trunk/gui/wxpython/gui_modules
Mon Oct 11 14:55:45 EDT 2010
Author: martinl
Date: 2010-10-11 11:55:45 -0700 (Mon, 11 Oct 2010)
New Revision: 43872
   grass/trunk/gui/wxpython/gui_modules/colorrules.py
wxGUI: color rules dialog - re-render display on apply
(merge r43871 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py	2010-10-11 18:49:00 UTC (rev 43871)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py	2010-10-11 18:55:45 UTC (rev 43872)
@@ -1,14 +1,14 @@
 @package colorrules.py
- at brief Dialog for interactive management of raster color tables and vector
-rgb_column
+ at brief Dialog for interactive management of raster color tables and
+vector rgb_column
 Classes:
  - ColorTable
  - BuferedWindow
-(C) 2008 by the GRASS Development Team
+(C) 2008, 2010 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -36,24 +36,21 @@
 from preferences import globalSettings as UserSettings
 class ColorTable(wx.Frame):
-    def __init__(self, parent, id=wx.ID_ANY, title='',
-                 pos=wx.DefaultPosition, size=(-1, -1),
+    def __init__(self, parent, cmd, id=wx.ID_ANY, title = _("Set color table"),
                  style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
                  **kwargs):
-        wx.Frame.__init__(self, parent, id, title, pos, size, style)
-        Dialog for interactively entering rules for map management
+        """!Dialog for interactively entering rules for map management
         commands
         @param cmd command (given as list)
         self.parent = parent # GMFrame
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+        self.cmd    = cmd
-        # grass command
-        self.cmd = kwargs['cmd']
+        wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
         # input map to change
         self.inmap = ''
@@ -98,14 +95,7 @@
             self.SetTitle(_('Create new color table for vector map'))
             self.elem = 'vector'
             crlabel = _('Enter vector attribute values or ranges (n or n1 to n2)')
-        # Set the size & cursor
-        self.SetClientSize(size)
-        ### self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
         # top controls
         if self.cmd == 'r.colors':
             maplabel = _('Select raster map:')
@@ -195,7 +185,8 @@
         # layout
         self.__doLayout()
+        self.SetMinSize(self.GetSize())
         self.CentreOnScreen()
         self.Show()
@@ -220,7 +211,6 @@
         # body & preview
         bodySizer =  wx.GridBagSizer(hgap=5, vgap=5)
         row = 0
         bodySizer.Add(item=self.cr_label, pos=(row, 0), span=(1, 3),
                       flag=wx.ALL, border=5)
@@ -247,6 +237,7 @@
         bodySizer.Add(item=self.preview, pos=(row, 2),
                       flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=10)
+        bodySizer.AddGrowableRow(row)
         bodySizer.AddGrowableCol(2)
         row += 1
@@ -270,7 +261,7 @@
         sizer.Add(item=bodySizer, proportion=1,
                   flag=wx.ALL | wx.EXPAND, border=5)
         sizer.Add(item=wx.StaticLine(parent=self, id=wx.ID_ANY,
                                      style=wx.LI_HORIZONTAL),
                   proportion=0,
@@ -330,29 +321,21 @@
         self.cr_panel.SetupScrolling()
     def InitDisplay(self):
+        """!Initialize preview display, set dimensions and region
-        Initialize preview display, set dimensions and region
-        #self.width, self.height = self.GetClientSize()
         self.width = self.Map.width = 400
         self.height = self.Map.height = 300
         self.Map.geom = self.width, self.height
     def OnErase(self, event):
+        """!Erase the histogram display
-        Erase the histogram display
         self.PreviewWindow.Draw(self.HistWindow.pdc, pdctype='clear')
     def OnCloseWindow(self, event):
-        Window closed
+        """!Window closed
         Also remove associated rendered images
-        #try:
-        #    self.propwin.Close(True)
-        #except:
-        #    pass
         self.Map.Clean()
         self.Destroy()
@@ -503,7 +486,10 @@
     def OnApply(self, event):
         self.CreateColorTable()
+        display = self.parent.GetLayerTree().GetMapDisplay()
+        if display:
+            display.GetWindow().UpdateMap(render = True)
     def OnOK(self, event):
         self.OnApply(event)
         self.Destroy()
