[GRASS-SVN] r43927 - grass/trunk/raster/r.out.png
Fri Oct 15 06:18:16 EDT 2010
Author: glynn
Date: 2010-10-15 03:18:16 -0700 (Fri, 15 Oct 2010)
New Revision: 43927
   grass/trunk/raster/r.out.png/main.c
Use functions rather than direct acess to the info struct
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c	2010-10-15 09:59:25 UTC (rev 43926)
+++ grass/trunk/raster/r.out.png/main.c	2010-10-15 10:18:16 UTC (rev 43927)
@@ -233,10 +233,12 @@
     png_info_init(info_ptr);
 #endif
     png_init_io(png_ptr, fp);
-    info_ptr->width = win.cols;
-    info_ptr->height = win.rows;
-    info_ptr->bit_depth = depth;
+    png_set_IHDR(png_ptr, info_ptr, win.cols, win.rows, depth,
+		 do_alpha ? PNG_COLOR_TYPE_RGB_ALPHA : PNG_COLOR_TYPE_RGB,
+		 PNG_INTERLACE_NONE, PNG_COMPRESSION_TYPE_DEFAULT,
+		 PNG_FILTER_TYPE_DEFAULT);
     /* explicit filter-type (or none) required */
     if ((filter >= 0) && (filter <= 4)) {
 	png_set_filter(png_ptr, 0, filter);
@@ -244,7 +246,7 @@
     png_set_compression_level(png_ptr, png_compr);
-    if(do_alpha) {
+    if (do_alpha) {
 	png_color_16 background_color;
 	background_color.red = (png_uint_16)def_red;
 	background_color.green = (png_uint_16)def_grn;
@@ -274,11 +276,6 @@
 	/*if(!gscale->answer){ *//* 24BIT COLOR IMAGE */
 	if (TRUE) {
-	    if (do_alpha)
-		info_ptr->color_type = PNG_COLOR_TYPE_RGB_ALPHA;
-	    else
-		info_ptr->color_type = PNG_COLOR_TYPE_RGB;
 	    /* write the png-info struct */
 	    png_write_info(png_ptr, info_ptr);
