[GRASS-SVN] r44008 - grass/branches/releasebranch_6_4/general/g.mapsets
Sun Oct 24 03:46:53 EDT 2010
Author: martinl
Date: 2010-10-24 00:46:53 -0700 (Sun, 24 Oct 2010)
New Revision: 44008
   grass/branches/releasebranch_6_4/general/g.mapsets/main.c
g.mapsets: split module's description to label
(merge r44006 from trunk)
Modified: grass/branches/releasebranch_6_4/general/g.mapsets/main.c
--- grass/branches/releasebranch_6_4/general/g.mapsets/main.c	2010-10-24 07:45:31 UTC (rev 44007)
+++ grass/branches/releasebranch_6_4/general/g.mapsets/main.c	2010-10-24 07:46:53 UTC (rev 44008)
@@ -57,10 +57,10 @@
     module = G_define_module();
     module->keywords = _("general, settings");
-    module->description =
-	_("Modifies the user's current mapset "
-	  "search path, affecting the user's access to data existing "
-	  "under the other GRASS mapsets in the current location.");
+    G_add_keyword(_("search path"));
+    module->label = _("Modifies the user's current mapset search path.");
+    module->description = _("Affects the user's access to data existing "
+			    "under the other mapsets in the current location.");
     opt.mapset = G_define_option();
     opt.mapset->key = "mapset";
