[GRASS-SVN] r44076 - grass/trunk/gui/wxpython/gui_modules
Thu Oct 28 15:24:43 EDT 2010
Author: martinl
Date: 2010-10-28 12:24:43 -0700 (Thu, 28 Oct 2010)
New Revision: 44076
   grass/trunk/gui/wxpython/gui_modules/globalvar.py
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI: fix auto-rendering (cmdAutoRender)
(merge r44075 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/globalvar.py
--- grass/trunk/gui/wxpython/gui_modules/globalvar.py	2010-10-28 19:20:31 UTC (rev 44075)
+++ grass/trunk/gui/wxpython/gui_modules/globalvar.py	2010-10-28 19:24:43 UTC (rev 44076)
@@ -179,6 +179,3 @@
 """@Check version of wxPython, use agwStyle for 2.8.11+"""
 hasAgw = CheckWxVersion()
-"""@List of commands for auto-rendering"""
-cmdAutoRender = [ 'r.colors', 'i.landsat.rgb' ]
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-10-28 19:20:31 UTC (rev 44075)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-10-28 19:24:43 UTC (rev 44076)
@@ -712,11 +712,23 @@
         # set focus on prompt
         if self.parent.GetName() == "LayerManager":
             self.btn_abort.Enable(False)
-            if event.cmd[0] in globalvar.cmdAutoRender:
-                display = self.parent.GetLayerTree().GetMapDisplay()
-                if display and display.IsAutoRendered():
-                    display.GetWindow().UpdateMap(render = True)
+            display = self.parent.GetLayerTree().GetMapDisplay()
+            if display and display.IsAutoRendered():
+                mapLayers = map(lambda x: x.GetName(),
+                                display.GetRender().GetListOfLayers(l_type = 'raster') +
+                                display.GetRender().GetListOfLayers(l_type = 'vector'))
+                task = menuform.GUI().ParseCommand(event.cmd, show = None)
+                for p in task.get_options()['params']:
+                    if p.get('prompt', '') not in ('raster', 'vector'):
+                        continue
+                    mapName = p.get('value', '')
+                    if '@' not in mapName:
+                        mapName = mapName + '@' + grass.gisenv()['MAPSET']
+                    if mapName in mapLayers:
+                        display.GetWindow().UpdateMap(render = True)
+                        return
         else:
             # updated command dialog
             dialog = self.parent.parent
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-10-28 19:20:31 UTC (rev 44075)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-10-28 19:24:43 UTC (rev 44076)
@@ -890,18 +890,33 @@
         @param returncode command's return code (0 for success)
-        if self.parent and self.parent.GetName() not in ('LayerTree', 'LayerManager') or \
-                returncode != 0:
+        if not self.parent or returncode != 0:
             return
+        if self.parent.GetName() not in ('LayerTree', 'LayerManager'):
+            return
-        if cmd[0] in globalvar.cmdAutoRender:
-            if self.parent.GetName() == 'LayerTree':
-                display = self.parent.GetMapDisplay()
-            else: # Layer Manager
+        if self.parent.GetName() == 'LayerTree':
+            display = self.parent.GetMapDisplay()
+        else: # Layer Manager
+        if not display or not display.IsAutoRendered():
+            return
+        task = GUI().ParseCommand(cmd, show = None)
+                continue
+                return
     def OnOK(self, event):
         """!OK button pressed"""
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2010-10-28 19:20:31 UTC (rev 44075)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2010-10-28 19:24:43 UTC (rev 44076)
@@ -236,8 +236,11 @@
     def GetName(self, fullyQualified = True):
         """!Get map layer name
-        @param fullyQualified if True return 'name at mapset' otherwise
-        ('name', 'mapset')
+        @param fullyQualified True to return fully qualified name as a
+        string 'name at mapset' otherwise directory { 'name', 'mapset' }
+        is returned
+        @return string / directory
         if fullyQualified:
             return self.name
