[GRASS-SVN] r43434 - grass-addons/imagery/i.landsat.toar
Thu Sep 9 04:06:28 EDT 2010
Author: hamish
Date: 2010-09-09 08:06:28 +0000 (Thu, 09 Sep 2010)
New Revision: 43434
   grass-addons/imagery/i.landsat.toar/earth_sun.c
   grass-addons/imagery/i.landsat.toar/landsat.c
   grass-addons/imagery/i.landsat.toar/landsat.h
   grass-addons/imagery/i.landsat.toar/landsat_met.c
   grass-addons/imagery/i.landsat.toar/landsat_set.c
   grass-addons/imagery/i.landsat.toar/local_proto.h
   grass-addons/imagery/i.landsat.toar/main.c
run tools/grass_indent.sh
Modified: grass-addons/imagery/i.landsat.toar/earth_sun.c
--- grass-addons/imagery/i.landsat.toar/earth_sun.c	2010-09-09 07:51:43 UTC (rev 43433)
+++ grass-addons/imagery/i.landsat.toar/earth_sun.c	2010-09-09 08:06:28 UTC (rev 43434)
@@ -1065,8 +1065,8 @@
 	b = 2 - a + (a / 4);
-    return ((int)(365.25 * (year + 4716)) + (int)(30.6001 * (month + 1)) + day +
-	    b - 1524.5);
+    return ((int)(365.25 * (year + 4716)) + (int)(30.6001 * (month + 1)) +
+	    day + b - 1524.5);
 /* Get Julian day form Gregorian string yyyy-mm-dd */
Modified: grass-addons/imagery/i.landsat.toar/landsat.c
--- grass-addons/imagery/i.landsat.toar/landsat.c	2010-09-09 07:51:43 UTC (rev 43433)
+++ grass-addons/imagery/i.landsat.toar/landsat.c	2010-09-09 08:06:28 UTC (rev 43434)
@@ -49,117 +49,121 @@
 #define abs(x)	(((x)>0)?(x):(-x))
 void lsat_bandctes(lsat_data * lsat, int i, char method,
-				   double percent, int dos, double sat_zenith, double rayleigh)
+		   double percent, int dos, double sat_zenith,
+		   double rayleigh)
     double pi_d2, sin_e, cos_v, rad_sun;
-	/* TAUv  = at. transmittance surface-sensor */
-	/* TAUz  = at. transmittance sun-surface    */
-	/* Edown = diffuse sky spectral irradiance  */
-	double TAUv, TAUz, Edown;
-	pi_d2 = (double)(PI * lsat->dist_es * lsat->dist_es);
-	sin_e = (double)(sin(D2R * lsat->sun_elev));
-	cos_v = (double)(cos(D2R * sat_zenith));
+    /* TAUv  = at. transmittance surface-sensor */
+    /* TAUz  = at. transmittance sun-surface    */
+    /* Edown = diffuse sky spectral irradiance  */
+    double TAUv, TAUz, Edown;
+    pi_d2 = (double)(PI * lsat->dist_es * lsat->dist_es);
+    sin_e = (double)(sin(D2R * lsat->sun_elev));
+    cos_v = (double)(cos(D2R * sat_zenith));
 	/** Global irradiance on the sensor.
 		Radiance to reflectance coefficient, only NO thermal bands.
 		K1 and K2 variables are also utilized as thermal constants
-	if (lsat->band[i].thermal == 0)
-		switch( method )
-			case DOS2:
-				TAUv  = 1.;
-				TAUz  = (lsat->band[i].wavemax < 1.) ? sin_e : 1.;
-				Edown = 0.;
-				break;
-			case DOS2b:
-				TAUv  = (lsat->band[i].wavemax < 1.) ? cos_v : 1.;
-				Edown = 0.;
-				break;
-			case DOS3:
-				double t;
-				t = 2. / (lsat->band[i].wavemax + lsat->band[i].wavemin);
-				t = 0.008569 *t*t*t*t*(1+0.0113*t*t+0.000013*t*t*t*t);
-				TAUv  = exp( -t / cos_v );
-				TAUz  = exp( -t / sin_e );
-				Edown = rayleigh;
-				break;
-			case DOS4:
-				double Ro = (lsat->band[i].lmax - lsat->band[i].lmin) * (dos - lsat->band[i].qcalmin) /
-							(lsat->band[i].qcalmax - lsat->band[i].qcalmin) + lsat->band[i].lmin;
-				double tv, Tv = 1.;
-				double Tz = 1.;
-				double Lp = 0.;
- 				do
-					TAUz = Tz;
-					TAUv = Tv;
-					Lp = Ro - percent * TAUv * (lsat->band[i].esun * sin_e * TAUz + PI * Lp) / pi_d2;
-					Tz = 1 - (4 * pi_d2 * Lp) / (lsat->band[i].esun * sin_e);
-					Tv = exp( sin_e * log( Tz ) / cos_v );
-// 					G_message("TAUv = %.5f (%.5f), TAUz = %.5f (%.5f) and Edown = %.5f\n", TAUv, Tv, TAUz, Tz, PI * Lp );
-// 				} while( abs(TAUv - Tv) > 0.0000001 || abs(TAUz - Tz) > 0.0000001);
-				} while( TAUv != Tv && TAUz != Tz);
-				TAUz  = (Tz < 1. ? Tz : 1.);
-				TAUv  = (Tv < 1. ? Tv : 1.);
-				Edown = (Lp < 0. ? 0. : PI * Lp);
-				break;
-			default: /* DOS1 and Without atmosferic-correction */
-				TAUv  = 1.;
-				TAUz  = 1.;
-				Edown = 0.;
-				break;
-		rad_sun = TAUv * (lsat->band[i].esun * sin_e * TAUz + Edown) / pi_d2;
-		G_message("... TAUv = %.5f, TAUz = %.5f, Edown = %.5f\n", TAUv, TAUz, Edown);
+    if (lsat->band[i].thermal == 0) {
+	switch (method) {
+	case DOS2:
+		TAUv = 1.;
+		TAUz = (lsat->band[i].wavemax < 1.) ? sin_e : 1.;
+		Edown = 0.;
+		break;
+	case DOS2b:
+		TAUv = (lsat->band[i].wavemax < 1.) ? cos_v : 1.;
+		Edown = 0.;
+		break;
+	case DOS3:
+		double t;
-		lsat->band[i].K1 = 0.;
-		lsat->band[i].K2 = rad_sun;
+		t = 2. / (lsat->band[i].wavemax + lsat->band[i].wavemin);
+		t = 0.008569 * t * t * t * t * (1 + 0.0113 * t * t +
+						0.000013 * t * t * t * t);
+		TAUv = exp(-t / cos_v);
+		TAUz = exp(-t / sin_e);
+		Edown = rayleigh;
+		break;
+	case DOS4:
+		double Ro =
+		    (lsat->band[i].lmax - lsat->band[i].lmin) * (dos -
+								 lsat->
+								 band[i].
+								 qcalmin) /
+		    (lsat->band[i].qcalmax - lsat->band[i].qcalmin) +
+		double tv, Tv = 1.;
+		double Tz = 1.;
+		double Lp = 0.;
+		do {
+		    TAUz = Tz;
+		    TAUv = Tv;
+		    Lp = Ro -
+			percent * TAUv * (lsat->band[i].esun * sin_e * TAUz +
+					  PI * Lp) / pi_d2;
+		    Tz = 1 - (4 * pi_d2 * Lp) / (lsat->band[i].esun * sin_e);
+		    Tv = exp(sin_e * log(Tz) / cos_v);
+		    //                                      G_message("TAUv = %.5f (%.5f), TAUz = %.5f (%.5f) and Edown = %.5f\n", TAUv, Tv, TAUz, Tz, PI * Lp );
+		    //                              } while( abs(TAUv - Tv) > 0.0000001 || abs(TAUz - Tz) > 0.0000001);
+		} while (TAUv != Tv && TAUz != Tz);
+		TAUz = (Tz < 1. ? Tz : 1.);
+		TAUv = (Tv < 1. ? Tv : 1.);
+		Edown = (Lp < 0. ? 0. : PI * Lp);
+		break;
+	default:		/* DOS1 and Without atmosferic-correction */
+	    TAUv = 1.;
+	    TAUz = 1.;
+	    Edown = 0.;
+	    break;
+	rad_sun = TAUv * (lsat->band[i].esun * sin_e * TAUz + Edown) / pi_d2;
+	G_message("... TAUv = %.5f, TAUz = %.5f, Edown = %.5f\n", TAUv, TAUz,
+		  Edown);
+	lsat->band[i].K1 = 0.;
+	lsat->band[i].K2 = rad_sun;
 	/** Digital number to radiance coefficients.
 		Whitout atmosferic calibration for thermal bands.
-	lsat->band[i].gain = ((lsat->band[i].lmax - lsat->band[i].lmin) /
-						  (lsat->band[i].qcalmax - lsat->band[i].qcalmin));
+    lsat->band[i].gain = ((lsat->band[i].lmax - lsat->band[i].lmin) /
+			  (lsat->band[i].qcalmax - lsat->band[i].qcalmin));
-	if (method == UNCORRECTED || lsat->band[i].thermal)
-		/* L = G * (DN - Qmin) + Lmin
-		-> bias = Lmin - G * Qmin	*/
-		lsat->band[i].bias = (lsat->band[i].lmin - lsat->band[i].gain * lsat->band[i].qcalmin);
+    if (method == UNCORRECTED || lsat->band[i].thermal) {
+	/* L = G * (DN - Qmin) + Lmin
+	   -> bias = Lmin - G * Qmin    */
+	lsat->band[i].bias =
+	    (lsat->band[i].lmin - lsat->band[i].gain * lsat->band[i].qcalmin);
+    else {
+	if (method == CORRECTED) {
+	    /* L = G * (DN - Qmin) + Lmin - Lmin
+	       -> bias = - G * Qmin */
+		-(lsat->band[i].gain * lsat->band[i].qcalmin);
+	    /* Another possibility is cut when rad < 0 */
-	else
-		if (method == CORRECTED)
-			/* L = G * (DN - Qmin) + Lmin - Lmin
-			-> bias = - G * Qmin */
-			lsat->band[i].bias = - (lsat->band[i].gain * lsat->band[i].qcalmin);
-			/* Another possibility is cut when rad < 0 */
-		else if (method > DOS )
-			/* L = Lsat - Lpath =
-			   G * DNsat + B - (G * dark + B - p * rad_sun) =
-			   G * DNsat - G * dark + p * rad_sun
-			-> bias = p * rad_sun - G * dark */
-			lsat->band[i].bias = percent * rad_sun - lsat->band[i].gain * dos;
+	else if (method > DOS) {
+	    /* L = Lsat - Lpath =
+	       G * DNsat + B - (G * dark + B - p * rad_sun) =
+	       G * DNsat - G * dark + p * rad_sun
+	       -> bias = p * rad_sun - G * dark */
+	    lsat->band[i].bias = percent * rad_sun - lsat->band[i].gain * dos;
Modified: grass-addons/imagery/i.landsat.toar/landsat.h
--- grass-addons/imagery/i.landsat.toar/landsat.h	2010-09-09 07:51:43 UTC (rev 43433)
+++ grass-addons/imagery/i.landsat.toar/landsat.h	2010-09-09 08:06:28 UTC (rev 43434)
@@ -22,34 +22,34 @@
 typedef struct
-	int number;					/* Band number                   */
-	int code;					/* Band code                     */
+    int number;			/* Band number                   */
+    int code;			/* Band code                     */
-	double wavemax, wavemin;	/* Wavelength in µm              */
+    double wavemax, wavemin;	/* Wavelength in µm              */
-	double lmax, lmin;			/* Spectral radiance             */
-	double qcalmax, qcalmin;	/* Quantized calibrated pixel    */
-	double esun;				/* Mean solar irradiance         */
+    double lmax, lmin;		/* Spectral radiance             */
+    double qcalmax, qcalmin;	/* Quantized calibrated pixel    */
+    double esun;		/* Mean solar irradiance         */
-	char thermal;				/* Flag to thermal band          */
-	double gain, bias;			/* Gain and Bias of sensor       */
-	double K1, K2;				/* Thermal calibration constants,
-                                   or Rad2Ref constants          */
+    char thermal;		/* Flag to thermal band          */
+    double gain, bias;		/* Gain and Bias of sensor       */
+    double K1, K2;		/* Thermal calibration constants,
+				   or Rad2Ref constants          */
 } band_data;
 typedef struct
-	unsigned char number;		/* Landsat number                */
+    unsigned char number;	/* Landsat number                */
-	char creation[11];			/* Image production date         */
-	char date[11];				/* Image acquisition date        */
-	double dist_es;				/* Distance Earth-Sun            */
-	double sun_elev;			/* Solar elevation               */
+    char creation[11];		/* Image production date         */
+    char date[11];		/* Image acquisition date        */
+    double dist_es;		/* Distance Earth-Sun            */
+    double sun_elev;		/* Solar elevation               */
-	char sensor[5];				/* Type of sensor: MSS, TM, ETM+ */
-	int bands;					/* Total number of bands         */
-	band_data band[MAX_BANDS];	/* Data for each band            */
+    char sensor[5];		/* Type of sensor: MSS, TM, ETM+ */
+    int bands;			/* Total number of bands         */
+    band_data band[MAX_BANDS];	/* Data for each band            */
 } lsat_data;
@@ -58,7 +58,7 @@
 double lsat_qcal2rad(double, band_data *);
-double lsat_rad2ref (double, band_data *);
+double lsat_rad2ref(double, band_data *);
 double lsat_rad2temp(double, band_data *);
 void lsat_bandctes(lsat_data *, int, char, double, int, double, double);
Modified: grass-addons/imagery/i.landsat.toar/landsat_met.c
--- grass-addons/imagery/i.landsat.toar/landsat_met.c	2010-09-09 07:51:43 UTC (rev 43433)
+++ grass-addons/imagery/i.landsat.toar/landsat_met.c	2010-09-09 08:06:28 UTC (rev 43434)
@@ -8,15 +8,17 @@
 #include "local_proto.h"
 #include "earth_sun.h"
-#define ETM_MET_SIZE    5600    /* .met file size  5516 bytes */
-#define TM5_MET_SIZE    28700   /* .met file size 28686 bytes */
+#define ETM_MET_SIZE    5600	/* .met file size  5516 bytes */
+#define TM5_MET_SIZE    28700	/* .met file size 28686 bytes */
 #define MAX_STR      127
-inline void chrncpy(char * dest, char * src, int n)
+inline void chrncpy(char *dest, char *src, int n)
-    if (src == NULL)   n = 1;
-    else strncpy(dest,src,n);
-    dest[n-1] = '\0';
+    if (src == NULL)
+	n = 1;
+    else
+	strncpy(dest, src, n);
+    dest[n - 1] = '\0';
@@ -25,10 +27,12 @@
 void get_value_met7(const char mettext[], char *text, char value[])
     char *ptr;
     value[0] = 0;
     ptr = strstr(mettext, text);
-    if (ptr == NULL) return;
+    if (ptr == NULL)
+	return;
     while (*ptr++ != '=') ;
     sscanf(ptr, "%s", value);
@@ -43,10 +47,11 @@
     char name[MAX_STR], value[MAX_STR];
     int i, j;
-    static int band[] = { 1, 2, 3, 4, 5,  6,  6, 7, 8 };
+    static int band[] = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
     static int code[] = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
-    static double esun[] = { 1969., 1840., 1551., 1044., 225.7, 0., 82.07, 1368. };
+    static double esun[] =
+	{ 1969., 1840., 1551., 1044., 225.7, 0., 82.07, 1368. };
     if ((f = fopen(metfile, "r")) == NULL) {
 	G_fatal_error(_(".met file [%s] not found"), metfile);
@@ -57,11 +62,11 @@
     lsat->number = 7;
     get_value_met7(mettext, "SENSOR_ID", value);
-    chrncpy(lsat->sensor, value+1, 5);
+    chrncpy(lsat->sensor, value + 1, 5);
     if (lsat->creation[0] == 0) {
-        get_value_met7(mettext, "CREATION_TIME", value);
-        chrncpy(lsat->creation, value, 11);
+	get_value_met7(mettext, "CREATION_TIME", value);
+	chrncpy(lsat->creation, value, 11);
     get_value_met7(mettext, "ACQUISITION_DATE", value);
@@ -88,14 +93,14 @@
 	snprintf(name, MAX_STR, "QCALMIN_BAND%d", lsat->band[i].code);
 	get_value_met7(mettext, name, value);
 	lsat->band[i].qcalmin = atof(value);
-        if (lsat->band[i].number == 6) {
-            lsat->band[i].thermal = 1;
-            lsat->band[i].K1 = 666.09;
-            lsat->band[i].K2 = 1282.71;
-        else {
-            lsat->band[i].thermal = 0;
+	if (lsat->band[i].number == 6) {
+	    lsat->band[i].thermal = 1;
+	    lsat->band[i].K1 = 666.09;
+	    lsat->band[i].K2 = 1282.71;
+	else {
+	    lsat->band[i].thermal = 0;
     (void)fclose(f);
@@ -109,17 +114,21 @@
     char *ptr;
     int i;
     value[0] = 0;
+    if (ptr == NULL)
+	return;
     ptr = strstr(ptr, " VALUE ");
+    if (ptr == NULL)
+	return;
     i = 0;
     while (*ptr++ != '\"') ;
-    while( *ptr != '\"' && i < MAX_STR) value[i++]=*ptr++;
+    while (*ptr != '\"' && i < MAX_STR)
+	value[i++] = *ptr++;
     value[i] = '\0';
     return;
@@ -132,7 +141,7 @@
     char metdate[MAX_STR], value[MAX_STR];
-        G_fatal_error(_(".met file [%s] not found"), metfile);
+	G_fatal_error(_(".met file [%s] not found"), metfile);
     fread(mettext, 1, TM5_MET_SIZE, f);
@@ -141,36 +150,42 @@
     chrncpy(lsat->date, value, 11);
-        get_value_met(mettext, "PRODUCTIONDATETIME", value);
+	get_value_met(mettext, "PRODUCTIONDATETIME", value);
-    if (lsat->creation[0] == 0 )
-        G_fatal_error(_("Product creation date not in .met file [%s]"), metfile);
+    if (lsat->creation[0] == 0)
+	G_fatal_error(_("Product creation date not in .met file [%s]"),
+		      metfile);
     get_value_met(mettext, "SolarElevation", value);
     lsat->sun_elev = atof(value);
     get_value_met(mettext, "PLATFORMSHORTNAME", value);
-    switch(value[8])
-        case '1':
-            set_MSS1(lsat);
-            break;
-        case '2':
-            set_MSS2(lsat);
-            break;
-        case '3':
-            set_MSS3(lsat);
-            break;
-        case '4':
-            get_value_met(mettext, "SENSORSHORTNAME", value);
-            if (value[0] == 'M') set_MSS4(lsat); else set_TM4(lsat);
-            break;
-        case '5':
-            if (value[0] == 'M') set_MSS5(lsat); else set_TM5(lsat);
-            break;
+    switch (value[8]) {
+    case '1':
+	set_MSS1(lsat);
+	break;
+    case '2':
+	set_MSS2(lsat);
+	break;
+    case '3':
+	set_MSS3(lsat);
+	break;
+    case '4':
+	get_value_met(mettext, "SENSORSHORTNAME", value);
+	if (value[0] == 'M')
+	    set_MSS4(lsat);
+	else
+	    set_TM4(lsat);
+	break;
+    case '5':
+	    set_MSS5(lsat);
+	else
+	    set_TM5(lsat);
+	break;
     (void)fclose(f);
Modified: grass-addons/imagery/i.landsat.toar/landsat_set.c
--- grass-addons/imagery/i.landsat.toar/landsat_set.c	2010-09-09 07:51:43 UTC (rev 43433)
+++ grass-addons/imagery/i.landsat.toar/landsat_set.c	2010-09-09 08:06:28 UTC (rev 43434)
@@ -11,79 +11,79 @@
 void sensor_MSS(lsat_data * lsat)
-	int i;
+    int i;
-	/* green, red, near infrared, near infrared */
-	int band[]    = { 1, 2, 3, 4 };
-	int code[]    = { 4, 5, 6, 7 };
-	double wmax[] = { 0.6, 0.7, 0.8, 1.1 };
-	double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
-	/* 79-82, 79-82, 79-82, 79-82 */
+    /* green, red, near infrared, near infrared */
+    int band[] = { 1, 2, 3, 4 };
+    int code[] = { 4, 5, 6, 7 };
+    double wmax[] = { 0.6, 0.7, 0.8, 1.1 };
+    double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
+    /* 79-82, 79-82, 79-82, 79-82 */
-	strcpy(lsat->sensor, "MSS");
+    strcpy(lsat->sensor, "MSS");
-	lsat->bands = 4;
-	for (i = 0; i < lsat->bands; i++) {
-		lsat->band[i].number = *(band + i);
-		lsat->band[i].code = *(code + i);
-		lsat->band[i].wavemax = *(wmax + i);
-		lsat->band[i].wavemin = *(wmin + i);
-		lsat->band[i].qcalmax = 255.;
-		lsat->band[i].qcalmin = 0.;
-	return;
+    lsat->bands = 4;
+    for (i = 0; i < lsat->bands; i++) {
+	lsat->band[i].number = *(band + i);
+	lsat->band[i].code = *(code + i);
+	lsat->band[i].wavemax = *(wmax + i);
+	lsat->band[i].wavemin = *(wmin + i);
+	lsat->band[i].qcalmax = 255.;
+	lsat->band[i].qcalmin = 0.;
+    return;
 void sensor_TM(lsat_data * lsat)
-	int i;
+    int i;
-	/* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR */
-	int band[]    = { 1, 2, 3, 4, 5, 6, 7 };
-	double wmax[] = { 0.52, 0.60, 0.69, 0.90, 1.75, 12.50, 2.35 };
-	double wmin[] = { 0.45, 0.52, 0.63, 0.76, 1.55, 10.40, 2.08 };
-	/* 30, 30, 30, 30, 30, 120, 30 */
+    /* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR */
+    int band[] = { 1, 2, 3, 4, 5, 6, 7 };
+    double wmax[] = { 0.52, 0.60, 0.69, 0.90, 1.75, 12.50, 2.35 };
+    double wmin[] = { 0.45, 0.52, 0.63, 0.76, 1.55, 10.40, 2.08 };
+    /* 30, 30, 30, 30, 30, 120, 30 */
-	strcpy(lsat->sensor, "TM");
+    strcpy(lsat->sensor, "TM");
-	lsat->bands = 7;
-		lsat->band[i].code = *(band + i);
-		lsat->band[i].qcalmin = 0.;	/* Modified in set_TM5 by date */
-		lsat->band[i].thermal = (lsat->band[i].number == 6 ? 1 : 0);
-	return;
+    lsat->bands = 7;
+	lsat->band[i].code = *(band + i);
+	lsat->band[i].qcalmin = 0.;	/* Modified in set_TM5 by date */
+	lsat->band[i].thermal = (lsat->band[i].number == 6 ? 1 : 0);
+    return;
 void sensor_ETM(lsat_data * lsat)
-	int i;
+    int i;
-	/* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR, panchromatic */
-	int band[]    = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
-	int code[]    = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
-	double wmax[] = { 0.515, 0.605, 0.690, 0.90, 1.75, 12.50, 2.35, 0.90 };
-	double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 2.09, 0.52 };
-	/* 30, 30, 30, 30, 30, 60, 30, 15 */
+    /* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR, panchromatic */
+    int band[] = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
+    int code[] = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
+    double wmax[] = { 0.515, 0.605, 0.690, 0.90, 1.75, 12.50, 2.35, 0.90 };
+    double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 2.09, 0.52 };
+    /* 30, 30, 30, 30, 30, 60, 30, 15 */
-	strcpy(lsat->sensor, "ETM+");
+    strcpy(lsat->sensor, "ETM+");
-	lsat->bands = 9;
-		lsat->band[i].qcalmin = 1.;
-	return;
+    lsat->bands = 9;
+	lsat->band[i].qcalmin = 1.;
+    return;
@@ -107,20 +107,20 @@
         Chander, Markham and Helder. Remote Sensing of Environment, 113 (2009)*/
     /* Spectral radiances at detector */
     double lmax[] = { 248., 200., 176., 153. };
-    double lmin[] = {   0.,   0.,   0.,   0. };
+    double lmin[] = { 0., 0., 0., 0. };
     /* Solar exoatmospheric spectral irradiances */
     double esun[] = { 1823., 1559., 1276., 880.1 };
     lsat->number = 1;
-    sensor_MSS( lsat );
+    sensor_MSS(lsat);
     lsat->dist_es = earth_sun(lsat->date);
-        j = lsat->band[i].number - 1;
-        lsat->band[i].esun = *(esun + j);
-        lsat->band[i].lmax = *(lmax + j);
-        lsat->band[i].lmin = *(lmin + j);
+	j = lsat->band[i].number - 1;
+	lsat->band[i].esun = *(esun + j);
+	lsat->band[i].lmax = *(lmax + j);
+	lsat->band[i].lmin = *(lmin + j);
     return;
@@ -137,29 +137,33 @@
     /** Markham and Barker. EOSAT Landsat Technical Notes, No. 1, 1986;
-    double Lmax[][4] = { { 210., 156., 140., 138. },       /* before      July 16, 1975 */
-                         { 263., 176., 152., 130.333 } };  /* on or after July 16, 1975 */
-    double Lmin[][4] = { {  10.,   7.,   7.,   5. },
-                         {   8.,   6.,   6.,   3.667 } };
+    double Lmax[][4] = { {210., 156., 140., 138.},	/* before      July 16, 1975 */
+    {263., 176., 152., 130.333}
+    };				/* on or after July 16, 1975 */
+    double Lmin[][4] = { {10., 7., 7., 5.},
+    {8., 6., 6., 3.667}
     double esun[] = { 1829., 1539., 1268., 886.6 };
     julian = julian_char(lsat->creation);
-    if (julian < julian_char("1975-07-16")) i = 0;
-    else i = 1;
+    if (julian < julian_char("1975-07-16"))
+	i = 0;
+    else
+	i = 1;
     lmax = Lmax[i];
     lmin = Lmin[i];
     lsat->number = 2;
+    sensor_MSS(lsat);
     return;
@@ -178,29 +182,33 @@
-    double Lmax[][4] = { { 220., 175., 145., 147. },   /* before      June 1, 1978 */
-                         { 259., 179., 149., 128. } }; /* on or after June 1, 1978 */
-    double Lmin[][4] = { {   4.,   3.,   3.,   1. },
-                         {   4.,   3.,   3.,   1. } };
+    double Lmax[][4] = { {220., 175., 145., 147.},	/* before      June 1, 1978 */
+    {259., 179., 149., 128.}
+    };				/* on or after June 1, 1978 */
+    double Lmin[][4] = { {4., 3., 3., 1.},
+    {4., 3., 3., 1.}
     double esun[] = { 1839., 1555., 1291., 887.9 };
-    if (julian < julian_char("1978-06-01")) i = 0;
-    else i = 1;
+    if (julian < julian_char("1978-06-01"))
+	i = 0;
+    else
+	i = 1;
     lmax = Lmax[i];
     lmin = Lmin[i];
     lsat->number = 3;
+    sensor_MSS(lsat);
     return;
@@ -217,32 +225,37 @@
-    double Lmax[][4] = { { 250., 180., 150., 133. },     /* before      August 26, 1982 */
-                         { 230., 180., 130., 133. },     /* between                     */
-                         { 238., 164., 142., 116. } };   /* on or after April 1, 1983   */
-    double Lmin[][4] = { {   2.,   4.,   4.,   3. },
-                         {   2.,   4.,   4.,   3. },
-                         {   4.,   4.,   5.,   4. } };
+    double Lmax[][4] = { {250., 180., 150., 133.},	/* before      August 26, 1982 */
+    {230., 180., 130., 133.},	/* between                     */
+    {238., 164., 142., 116.}
+    };				/* on or after April 1, 1983   */
+    double Lmin[][4] = { {2., 4., 4., 3.},
+    {2., 4., 4., 3.},
+    {4., 4., 5., 4.}
     double esun[] = { 1827., 1569., 1260., 866.4 };
-    if (julian < julian_char("1982-08-26")) i = 0;
-    else if (julian < julian_char("1983-03-31")) i = 1;
-    else i = 2;
+    if (julian < julian_char("1982-08-26"))
+	i = 0;
+    else if (julian < julian_char("1983-03-31"))
+	i = 1;
+    else
+	i = 2;
     lmax = Lmax[i];
     lmin = Lmin[i];
     lsat->number = 4;
+    sensor_MSS(lsat);
     return;
@@ -255,38 +268,44 @@
     /** Brian L. Markham and John L. Barker.
         EOSAT Landsat Technical Notes, No. 1, 1986 */
-    double Lmax[][7] = { { 158.42, 308.17, 234.63, 224.32, 32.42, 15.64,  17.00 },   /* before August 1983      */
-                         { 142.86, 291.25, 225.00, 214.29, 30.00, 12.40,  15.93 },   /* before January 15, 1984 */
-                         { 152.10, 296.81, 204.30, 206.20, 27.19, 15.3032,  14.38 } }; /* after  Jaunary 15, 1984 */
-    double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  2.00,  -0.15 },
-                         {   0.00,   0.00,   0.00,   0.00,  0.00,  4.84,   0.00 },
-                         {  -1.50,  -2.80,  -1.20,  -1.50, -0.37,  1.2378, -0.15 } };
+    double Lmax[][7] = { {158.42, 308.17, 234.63, 224.32, 32.42, 15.64, 17.00},	/* before August 1983      */
+    {142.86, 291.25, 225.00, 214.29, 30.00, 12.40, 15.93},	/* before January 15, 1984 */
+    {152.10, 296.81, 204.30, 206.20, 27.19, 15.3032, 14.38}
+    };				/* after  Jaunary 15, 1984 */
+    double Lmin[][7] = { {-1.52, -2.84, -1.17, -1.51, -0.37, 2.00, -0.15},
+    {0.00, 0.00, 0.00, 0.00, 0.00, 4.84, 0.00},
+    {-1.50, -2.80, -1.20, -1.50, -0.37, 1.2378, -0.15}
     /** Chander, Markham and Helder. Remote Sensing of Environment, 113 (2009) */
     double esun[] = { 1983., 1795., 1539., 1028., 219.8, 0., 83.49 };
     /* Thermal band calibration constants: K1 = 671.62   K2 = 1284.30 */
-    if (julian < julian_char("1983-08-01")) i = 0;
-    else if (julian < julian_char("1984-01-15")) i = 1;
-    else i = 2;
+    if (julian < julian_char("1983-08-01"))
+	i = 0;
+    else if (julian < julian_char("1984-01-15"))
+	i = 1;
+    else
+	i = 2;
     lmax = Lmax[i];
     lmin = Lmin[i];
     lsat->number = 4;
-    sensor_TM( lsat );
+    sensor_TM(lsat);
-        if (lsat->band[i].thermal ) {
-            lsat->band[i].K1 = 671.62;
-            lsat->band[i].K2 = 1284.30;
+	if (lsat->band[i].thermal) {
+	    lsat->band[i].K1 = 671.62;
+	    lsat->band[i].K2 = 1284.30;
     return;
@@ -304,32 +323,37 @@
-    double Lmax[][4] = { { 240., 170., 150., 127. },    /* before   April 6, 1984    */
-                         { 268., 179., 159., 123. },    /* betweeen                  */
-                         { 268., 179., 148., 123. } };  /* after    November 9, 1984 */
-    double Lmin[][4] = { {   4.,   3.,   4.,   2. },
-                         {   3.,   3.,   4.,   3. },
-                         {   3.,   3.,   5.,   3. } };
+    double Lmax[][4] = { {240., 170., 150., 127.},	/* before   April 6, 1984    */
+    {268., 179., 159., 123.},	/* betweeen                  */
+    {268., 179., 148., 123.}
+    };				/* after    November 9, 1984 */
+    double Lmin[][4] = { {4., 3., 4., 2.},
+    {3., 3., 4., 3.},
+    {3., 3., 5., 3.}
     double esun[] = { 1824., 1570., 1249., 853.4 };
-    if (julian < julian_char("1984-04-06")) i = 0;
-    else if (julian < julian_char("1984-11-09")) i = 1;
-    else i = 2;
+    if (julian < julian_char("1984-04-06"))
+	i = 0;
+    else if (julian < julian_char("1984-11-09"))
+	i = 1;
+    else
+	i = 2;
     lmax = Lmax[i];
     lmin = Lmin[i];
     lsat->number = 5;
+    sensor_MSS(lsat);
     return;
@@ -342,49 +366,58 @@
     /** Gyanesh Chander and Brian Markham.
         IEEE Transactions On Geoscience And Remote Sensing, Vol. 41, No. 11, November 2003 */
-    double Lmax[][7] = { { 152.10, 296.81, 204.30, 206.20, 27.19, 15.303,  14.38 },    /* before May 4, 2003 */
-                         { 193.00, 365.00, 264.00, 221.00, 30.20, 15.303,  16.50 },    /* after May 4, 2003 */
-                         { 169.00, 333.00, 264.00, 221.00, 30.20, 15.303,  16.50 } };  /* after April 2, 2007 */
-    double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 },
-                         {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 },
-                         {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 } };
+    double Lmax[][7] = { {152.10, 296.81, 204.30, 206.20, 27.19, 15.303, 14.38},	/* before May 4, 2003 */
+    {193.00, 365.00, 264.00, 221.00, 30.20, 15.303, 16.50},	/* after May 4, 2003 */
+    {169.00, 333.00, 264.00, 221.00, 30.20, 15.303, 16.50}
+    };				/* after April 2, 2007 */
+    double Lmin[][7] = { {-1.52, -2.84, -1.17, -1.51, -0.37, 1.2378, -0.15},
+    {-1.52, -2.84, -1.17, -1.51, -0.37, 1.2378, -0.15},
     double esun[] = { 1983., 1796., 1536., 1031., 220.0, 0., 83.44 };
     /* Thermal band calibration constants: K1 = 607.76   K2 = 1260.56 */
-    if (julian < julian_char("2003-05-04")) i = 0;
-    else if (julian < julian_char("2007-04-02")) i = 1;
-    else i = 2;
+    if (julian < julian_char("2003-05-04"))
+	i = 0;
+    else if (julian < julian_char("2007-04-02"))
+	i = 1;
+    else
+	i = 2;
     lmax = Lmax[i];
     lmin = Lmin[i];
-    if ( i == 2 ) { /* in Chander, Markham and Barsi 2007 */
-        julian = julian_char(lsat->date); /* Yes, here acquisition date */
-        if (julian >= julian_char("1992-01-01")) {
-            lmax[0] = 193.0;
-            lmax[1] = 365.0;
+    if (i == 2) {		/* in Chander, Markham and Barsi 2007 */
+	julian = julian_char(lsat->date);	/* Yes, here acquisition date */
+	if (julian >= julian_char("1992-01-01")) {
+	    lmax[0] = 193.0;
+	    lmax[1] = 365.0;
-	jbuf = julian_char("2004-04-04");
-	if (julian >= jbuf) G_warning("Using QCalMin=1.0 as a NLAPS product processed after 4/4/2004");
+    jbuf = julian_char("2004-04-04");
+    if (julian >= jbuf)
+	G_warning
+	    ("Using QCalMin=1.0 as a NLAPS product processed after 4/4/2004");
     lsat->number = 5;
+    sensor_TM(lsat);
-		if (julian >= jbuf) lsat->band[i].qcalmin = 1.;
-            lsat->band[i].K1 = 607.76;
-            lsat->band[i].K2 = 1260.56;
+	    lsat->band[i].K1 = 607.76;
+	    lsat->band[i].K2 = 1260.56;
     return;
@@ -403,46 +436,54 @@
         Landsat 7. Science Data Users Handbook. Last update: February 17, 2007 */
     /* - LOW GAIN - */
-    double LmaxL[][8] = { { 297.5, 303.4, 235.5, 235.0, 47.70, 17.04, 16.60, 244.0 },      /* before      July 1, 2000 */
-                          { 293.7, 300.9, 234.4, 241.1, 47.57, 17.04, 16.54, 243.1 } };    /* on or after July 1, 2000 */
-    double LminL[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5,  -1.0,  0.0,  -0.35,   -5.0 },
-                          {  -6.2,  -6.4,  -5.0,  -5.1,  -1.0,  0.0,  -0.35,   -4.7 } };
+    double LmaxL[][8] = { {297.5, 303.4, 235.5, 235.0, 47.70, 17.04, 16.60, 244.0},	/* before      July 1, 2000 */
+    {293.7, 300.9, 234.4, 241.1, 47.57, 17.04, 16.54, 243.1}
+    };				/* on or after July 1, 2000 */
+    double LminL[][8] = { {-6.2, -6.0, -4.5, -4.5, -1.0, 0.0, -0.35, -5.0},
+    {-6.2, -6.4, -5.0, -5.1, -1.0, 0.0, -0.35, -4.7}
     /* - HIGH GAIN - */
-    double LmaxH[][8] = { { 194.3, 202.4, 158.6, 157.5, 31.76, 12.65, 10.932, 158.4 },
-                          { 191.6, 196.5, 152.9, 157.4, 31.06, 12.65, 10.80, 158.3 } };
-    double LminH[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5, -1.0,   3.2,  -0.35,   -5.0 },
-                          {  -6.2,  -6.4,  -5.0,  -5.1, -1.0,   3.2,  -0.35,   -4.7 } };
+    double LmaxH[][8] =
+	{ {194.3, 202.4, 158.6, 157.5, 31.76, 12.65, 10.932, 158.4},
+    {191.6, 196.5, 152.9, 157.4, 31.06, 12.65, 10.80, 158.3}
+    double LminH[][8] = { {-6.2, -6.0, -4.5, -4.5, -1.0, 3.2, -0.35, -5.0},
+    {-6.2, -6.4, -5.0, -5.1, -1.0, 3.2, -0.35, -4.7}
     double esun[] = { 1997., 1812., 1533., 1039., 230.8, 0., 84.90, 1362. };
     /*  Thermal band calibration constants: K1 = 666.09   K2 = 1282.71 */
-	julian = julian_char(lsat->creation);
-	if (julian < julian_char("2000-07-01")) k = 0;
-	else k = 1;
+    julian = julian_char(lsat->creation);
+    if (julian < julian_char("2000-07-01"))
+	k = 0;
+    else
+	k = 1;
-	lsat->number = 7;
-	sensor_ETM( lsat );
+    lsat->number = 7;
+    sensor_ETM(lsat);
-	lsat->dist_es = earth_sun(lsat->date);
+    lsat->dist_es = earth_sun(lsat->date);
-		if (gain[i] == 'H' || gain[i] == 'h') {
-			lmax = LmaxH[k];
-			lmin = LminH[k];
-		else {
-			lmax = LmaxL[k];
-			lmin = LminL[k];
-		if (lsat->band[i].thermal) {
+	if (gain[i] == 'H' || gain[i] == 'h') {
+	    lmax = LmaxH[k];
+	    lmin = LminH[k];
+	else {
+	    lmax = LmaxL[k];
+	    lmin = LminL[k];
     return;
Modified: grass-addons/imagery/i.landsat.toar/local_proto.h
--- grass-addons/imagery/i.landsat.toar/local_proto.h	2010-09-09 07:51:43 UTC (rev 43433)
+++ grass-addons/imagery/i.landsat.toar/local_proto.h	2010-09-09 08:06:28 UTC (rev 43434)
@@ -4,8 +4,8 @@
 #include <string.h>
 #include "landsat.h"
-void met_ETM (char *, lsat_data *);
-void met_TM5 (char *, lsat_data *);
+void met_ETM(char *, lsat_data *);
+void met_TM5(char *, lsat_data *);
 void set_MSS1(lsat_data *);
 void set_MSS2(lsat_data *);
@@ -13,8 +13,8 @@
 void set_MSS4(lsat_data *);
 void set_MSS5(lsat_data *);
-void set_TM4 (lsat_data *);
-void set_TM5 (lsat_data *);
-void set_ETM (lsat_data *, char []);
+void set_TM4(lsat_data *);
+void set_TM5(lsat_data *);
+void set_ETM(lsat_data *, char[]);
 #endif
Modified: grass-addons/imagery/i.landsat.toar/main.c
--- grass-addons/imagery/i.landsat.toar/main.c	2010-09-09 07:51:43 UTC (rev 43433)
+++ grass-addons/imagery/i.landsat.toar/main.c	2010-09-09 08:06:28 UTC (rev 43434)
@@ -25,553 +25,591 @@
 int main(int argc, char *argv[])
-	struct History history;
-	struct GModule *module;
+    struct History history;
+    struct GModule *module;
-	struct Cell_head cellhd, window;
-	char *mapset;
+    struct Cell_head cellhd, window;
+    char *mapset;
-	void *inrast, *outrast;
-	int infd, outfd;
-	void *ptr;
-	int nrows, ncols, row, col;
+    void *inrast, *outrast;
+    int infd, outfd;
+    void *ptr;
+    int nrows, ncols, row, col;
-	RASTER_MAP_TYPE in_data_type;
+    RASTER_MAP_TYPE in_data_type;
-	int verbose = 1;
-	struct Option *input, *metfn,
-				*adate, *pdate, *elev, *bgain, *metho, *perc, *dark,
-				*satz, *atmo;
-	char *name, *met;
-	struct Flag *sat1, *sat2, *sat3, *sat4, *sat5, *sat7, *msss,
-				*verbo, *frad;
+    int verbose = 1;
+    struct Option *input, *metfn,
+	*adate, *pdate, *elev, *bgain, *metho, *perc, *dark, *satz, *atmo;
+    char *name, *met;
+    struct Flag *sat1, *sat2, *sat3, *sat4, *sat5, *sat7, *msss,
+	*verbo, *frad;
-	lsat_data lsat;
-	char band_in[127], band_out[127];
-	int i, j, q, method, pixel, dn_dark[MAX_BANDS], dn_mode[MAX_BANDS];
-	double qcal, rad, ref, percent, ref_mode, sat_zenith, rayleigh;
+    lsat_data lsat;
+    char band_in[127], band_out[127];
+    int i, j, q, method, pixel, dn_dark[MAX_BANDS], dn_mode[MAX_BANDS];
+    double qcal, rad, ref, percent, ref_mode, sat_zenith, rayleigh;
-	unsigned long hist[256], h_max;
+    unsigned long hist[256], h_max;
     /* initialize GIS environment */
     G_gisinit(argv[0]);
     /* initialize module */
     module = G_define_module();
-    module->description = _("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+");
-    module->keywords = _("Top-Of-Atmosphere Radiance or Reflectance.\n Landsat-1 MSS, Landsat-2 MSS, Landsat-3 MSS, Landsat-4 MSS, Landsat-5 MSS,\n Landsat-4 TM, Landsat-5 TM,\n Landsat-7 ETM+");
+    module->description =
+	_("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+");
+    module->keywords =
+	_("Top-Of-Atmosphere Radiance or Reflectance.\n Landsat-1 MSS, Landsat-2 MSS, Landsat-3 MSS, Landsat-4 MSS, Landsat-5 MSS,\n Landsat-4 TM, Landsat-5 TM,\n Landsat-7 ETM+");
     /* It defines the different parameters */
     input = G_define_option();
-    input->key         = _("band_prefix");
-    input->type        = TYPE_STRING;
-    input->required    = YES;
-    input->gisprompt   = _("input,cell,raster");
+    input->key = _("band_prefix");
+    input->type = TYPE_STRING;
+    input->required = YES;
+    input->gisprompt = _("input,cell,raster");
     input->description = _("Base name of the landsat band rasters (.#)");
     metfn = G_define_option();
-    metfn->key         = _("metfile");
-    metfn->type        = TYPE_STRING;
-    metfn->required    = NO;
-    metfn->gisprompt   = _(".met file");
+    metfn->key = _("metfile");
+    metfn->type = TYPE_STRING;
+    metfn->required = NO;
+    metfn->gisprompt = _(".met file");
     metfn->description = _("Landsat ETM+ or TM5 header file (.met)");
     adate = G_define_option();
-    adate->key         = _("date");
-    adate->type        = TYPE_STRING;
-    adate->required    = NO;
-    adate->gisprompt   = _("image acquisition date");
+    adate->key = _("date");
+    adate->type = TYPE_STRING;
+    adate->required = NO;
+    adate->gisprompt = _("image acquisition date");
     adate->description = _("Image acquisition date (yyyy-mm-dd)");
     elev = G_define_option();
-    elev->key         = _("solar_elevation");
-    elev->type        = TYPE_DOUBLE;
-    elev->required    = NO;
-    elev->gisprompt   = _("solar elevation");
+    elev->key = _("solar_elevation");
+    elev->type = TYPE_DOUBLE;
+    elev->required = NO;
+    elev->gisprompt = _("solar elevation");
     elev->description = _("Solar elevation in degrees");
     bgain = G_define_option();
-    bgain->key         = _("gain");
-    bgain->type        = TYPE_STRING;
-    bgain->required    = NO;
-    bgain->gisprompt   = _("band gain");
-    bgain->description = _("Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)");
+    bgain->key = _("gain");
+    bgain->type = TYPE_STRING;
+    bgain->required = NO;
+    bgain->gisprompt = _("band gain");
+    bgain->description =
+	_("Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)");
     pdate = G_define_option();
-    pdate->key         = _("product_date");
-    pdate->type        = TYPE_STRING;
-    pdate->required    = NO;
-    pdate->gisprompt   = _("image production date");
+    pdate->key = _("product_date");
+    pdate->type = TYPE_STRING;
+    pdate->required = NO;
+    pdate->gisprompt = _("image production date");
     pdate->description = _("Image creation date (yyyy-mm-dd)");
     metho = G_define_option();
-    metho->key         = _("method");
-    metho->type        = TYPE_STRING;
-    metho->required    = NO;
-    metho->options     = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
-    metho->gisprompt   = _("atmosferic correction method");
+    metho->key = _("method");
+    metho->type = TYPE_STRING;
+    metho->required = NO;
+    metho->options = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
+    metho->gisprompt = _("atmosferic correction method");
     metho->description = _("Atmosferic correction method");
-    metho->answer      = "uncorrected";
+    metho->answer = "uncorrected";
-	perc = G_define_option();
-	perc->key         = _("percent");
-	perc->type        = TYPE_DOUBLE;
-	perc->required    = NO;
-	perc->gisprompt   = _("percent of solar radiance in path radiance");
-	perc->description = _("Percent of solar radiance in path radiance");
-	perc->answer      = "0.01";
+    perc = G_define_option();
+    perc->key = _("percent");
+    perc->type = TYPE_DOUBLE;
+    perc->required = NO;
+    perc->gisprompt = _("percent of solar radiance in path radiance");
+    perc->description = _("Percent of solar radiance in path radiance");
+    perc->answer = "0.01";
-	dark = G_define_option();
-	dark->key         = _("pixel");
-	dark->type        = TYPE_INTEGER;
-	dark->required    = NO;
-	dark->gisprompt   = _("pixels to dark object");
-	dark->description = _("Minimum pixels to consider digital number as dark object");
-	dark->answer      = "1000";
+    dark = G_define_option();
+    dark->key = _("pixel");
+    dark->type = TYPE_INTEGER;
+    dark->required = NO;
+    dark->gisprompt = _("pixels to dark object");
+    dark->description =
+	_("Minimum pixels to consider digital number as dark object");
+    dark->answer = "1000";
-	satz = G_define_option();
-	satz->key         = _("sat_zenith");
-	satz->type        = TYPE_DOUBLE;
-	satz->required    = NO;
-	satz->gisprompt   = _("satellite zenith");
-	satz->description = _("Satellite zenith in degrees");
-	satz->answer      = "8.2000";
+    satz = G_define_option();
+    satz->key = _("sat_zenith");
+    satz->type = TYPE_DOUBLE;
+    satz->required = NO;
+    satz->gisprompt = _("satellite zenith");
+    satz->description = _("Satellite zenith in degrees");
+    satz->answer = "8.2000";
-	atmo = G_define_option();
-	atmo->key         = _("rayleigh");
-	atmo->type        = TYPE_DOUBLE;
-	atmo->required    = NO;
-	atmo->gisprompt   = _("Rayleigh atmosphere");
-	atmo->description = _("Rayleigh atmosphere");
-	atmo->answer      = "0.0";
+    atmo = G_define_option();
+    atmo->key = _("rayleigh");
+    atmo->type = TYPE_DOUBLE;
+    atmo->required = NO;
+    atmo->gisprompt = _("Rayleigh atmosphere");
+    atmo->description = _("Rayleigh atmosphere");
+    atmo->answer = "0.0";
-	/* It defines the different flags */
+    /* It defines the different flags */
     frad = G_define_flag();
-    frad->key         = 'r';
+    frad->key = 'r';
     frad->description = _("Output at-sensor radiance for all bands");
-	frad->answer      = 0;
+    frad->answer = 0;
     sat1 = G_define_flag();
-	sat1->key         = '1';
+    sat1->key = '1';
     sat1->description = _("Landsat-1 MSS");
-	sat1->answer      = 0;
+    sat1->answer = 0;
     sat2 = G_define_flag();
-	sat2->key         = '2';
+    sat2->key = '2';
     sat2->description = _("Landsat-2 MSS");
-	sat2->answer      = 0;
+    sat2->answer = 0;
     sat3 = G_define_flag();
-	sat3->key         = '3';
+    sat3->key = '3';
     sat3->description = _("Landsat-3 MSS");
-	sat3->answer      = 0;
+    sat3->answer = 0;
     sat4 = G_define_flag();
-	sat4->key         = '4';
+    sat4->key = '4';
     sat4->description = _("Landsat-4 TM");
-	sat4->answer      = 0;
+    sat4->answer = 0;
     sat5 = G_define_flag();
-	sat5->key         = '5';
+    sat5->key = '5';
     sat5->description = _("Landsat-5 TM");
-	sat5->answer      = 0;
+    sat5->answer = 0;
     sat7 = G_define_flag();
-	sat7->key         = '7';
+    sat7->key = '7';
     sat7->description = _("Landsat-7 ETM+");
-	sat7->answer      = 0;
+    sat7->answer = 0;
     msss = G_define_flag();
-	msss->key         = 's';
+    msss->key = 's';
     msss->description = _("Set sensor of Landsat-4/5 to MSS");
-	msss->answer      = 0;
+    msss->answer = 0;
     verbo = G_define_flag();
-	verbo->key         = 'v';
+    verbo->key = 'v';
     verbo->description = _("Show parameters applied");
-    verbo->answer      = 0;
+    verbo->answer = 0;
     /* options and afters parser */
     if (G_parser(argc, argv))
-		exit(EXIT_FAILURE);
+	exit(EXIT_FAILURE);
      * ---------- START --------------------
      * Stores options and flag to variables
-	met = metfn->answer;
-	name = input->answer;
+    met = metfn->answer;
+    name = input->answer;
-	if (adate->answer != NULL) {
-		strncpy(lsat.date, adate->answer, 11);
-		lsat.date[10] = '\0';
-	else
-		lsat.date[0] = '\0';
+    if (adate->answer != NULL) {
+	strncpy(lsat.date, adate->answer, 11);
+	lsat.date[10] = '\0';
+    else
+	lsat.date[0] = '\0';
-	if (pdate->answer != NULL) {
-		strncpy(lsat.creation, pdate->answer, 11);
-		lsat.creation[10] = '\0';
-	else
-		lsat.creation[0] = '\0';
+    if (pdate->answer != NULL) {
+	strncpy(lsat.creation, pdate->answer, 11);
+	lsat.creation[10] = '\0';
+    else
+	lsat.creation[0] = '\0';
-	lsat.sun_elev = elev->answer == NULL ? 0. : atof(elev->answer);
-	percent       = atof(perc->answer);
-	pixel         = atoi(dark->answer);
-	sat_zenith    = atof(satz->answer);
-	rayleigh      = atof(atmo->answer);
+    lsat.sun_elev = elev->answer == NULL ? 0. : atof(elev->answer);
+    percent = atof(perc->answer);
+    pixel = atoi(dark->answer);
+    sat_zenith = atof(satz->answer);
+    rayleigh = atof(atmo->answer);
-	if (met == NULL &&
-		(sat1->answer + sat2->answer + sat3->answer +
-		 sat4->answer + sat5->answer + sat7->answer) != 1)
-		G_fatal_error(_("Select one and only one type of satellite"));
+    if (met == NULL &&
+	(sat1->answer + sat2->answer + sat3->answer +
+	 sat4->answer + sat5->answer + sat7->answer) != 1)
+	G_fatal_error(_("Select one and only one type of satellite"));
     /* Data from MET file: only Landsat-7 ETM+ and Landsat-5 TM  */
-	if (met != NULL) {
-		if (sat7->answer) met_ETM(met, &lsat); else met_TM5(met, &lsat);
-		G_message("Landsat-%d %s with data set in met file [%s]", lsat.number, lsat.sensor, met);
-		if (elev->answer != NULL)
-			lsat.sun_elev = atof(elev->answer);         /* Overwrite solar elevation of met file */
+    if (met != NULL) {
+	if (sat7->answer)
+	    met_ETM(met, &lsat);
+	else
+	    met_TM5(met, &lsat);
+	G_message("Landsat-%d %s with data set in met file [%s]", lsat.number,
+		  lsat.sensor, met);
+	if (elev->answer != NULL)
+	    lsat.sun_elev = atof(elev->answer);	/* Overwrite solar elevation of met file */
+    /* Data from date and solar elevation */
+    else if (adate->answer == NULL || elev->answer == NULL) {
+	G_fatal_error(_("Lacking date or solar elevation for this satellite"));
+    else {
+	if (sat7->answer) {	/* Need gain */
+	    if (bgain->answer != NULL && strlen(bgain->answer) == 9) {
+		set_ETM(&lsat, bgain->answer);
+		G_message("Landsat 7 ETM+");
+	    else {
+		G_fatal_error(_("For Landsat-7 is necessary band gain with 9 (H/L) data"));
-	/* Data from date and solar elevation */
-	else if (adate->answer == NULL || elev->answer == NULL) {
-		G_fatal_error(_("Lacking date or solar elevation for this satellite"));
+	else {			/* Not need gain */
+	    if (sat5->answer) {
+		if (msss->answer)
+		    set_MSS5(&lsat);
+		else
+		    set_TM5(&lsat);
+		G_message("Landsat-5 %s", lsat.sensor);
+	    else if (sat4->answer) {
+		if (msss->answer)
+		    set_MSS4(&lsat);
+		else
+		    set_TM4(&lsat);
+		G_message("Landsat-4 %s", lsat.sensor);
+	    else if (sat3->answer) {
+		set_MSS3(&lsat);
+		G_message("Landsat-3 MSS");
+	    else if (sat2->answer) {
+		set_MSS2(&lsat);
+		G_message("Landsat-2 MSS");
+	    else if (sat1->answer) {
+		set_MSS1(&lsat);
+		G_message("Landsat-1 MSS");
+	    else {
+		G_fatal_error(_("Lacking satellite type"));
-    else {
-		if (sat7->answer) { /* Need gain */
-	    	if (bgain->answer != NULL && strlen(bgain->answer) == 9) {
-				set_ETM(&lsat, bgain->answer);
-				G_message("Landsat 7 ETM+");
-	    	else {
-				G_fatal_error(_("For Landsat-7 is necessary band gain with 9 (H/L) data"));
-		else { /* Not need gain */
-			if (sat5->answer) {
-				if (msss->answer) set_MSS5(&lsat); else set_TM5 (&lsat);
-				G_message("Landsat-5 %s", lsat.sensor);
-			else if (sat4->answer) {
-				if (msss->answer) set_MSS4(&lsat); else set_TM4 (&lsat);
-				G_message("Landsat-4 %s", lsat.sensor);
-			else if (sat3->answer) {
-				set_MSS3(&lsat);
-				G_message("Landsat-3 MSS");
-			else if (sat2->answer) {
-				set_MSS2(&lsat);
-				G_message("Landsat-2 MSS");
-			else if (sat1->answer) {
-				set_MSS1(&lsat);
-				G_message("Landsat-1 MSS");
-			else {
-				G_fatal_error(_("Lacking satellite type"));
 	* ------------ PREPARATION --------------
-	if (G_strcasecmp(metho->answer, "corrected") == 0)	method = CORRECTED;
-	else if (G_strcasecmp(metho->answer, "dos1") == 0)	method = DOS1;
-	else if (G_strcasecmp(metho->answer, "dos2") == 0)	method = DOS2;
-	else if (G_strcasecmp(metho->answer, "dos2b") == 0)	method = DOS2b;
-	else if (G_strcasecmp(metho->answer, "dos3") == 0)	method = DOS3;
-	else if (G_strcasecmp(metho->answer, "dos4") == 0)	method = DOS4;
-	else method = UNCORRECTED;
+    if (G_strcasecmp(metho->answer, "corrected") == 0)
+	method = CORRECTED;
+    else if (G_strcasecmp(metho->answer, "dos1") == 0)
+	method = DOS1;
+    else if (G_strcasecmp(metho->answer, "dos2") == 0)
+	method = DOS2;
+    else if (G_strcasecmp(metho->answer, "dos2b") == 0)
+	method = DOS2b;
+    else if (G_strcasecmp(metho->answer, "dos3") == 0)
+	method = DOS3;
+    else if (G_strcasecmp(metho->answer, "dos4") == 0)
+	method = DOS4;
+    else
+	method = UNCORRECTED;
-// 	if (metho->answer[3] == 'r') 		method = CORRECTED;
-// 	else if (metho->answer[3] == '1')	method = DOS1;
-// 	else if (metho->answer[3] == '2')	method = (metho->answer[4] == '\0') ? DOS2 : DOS2b;
-// 	else if (metho->answer[3] == '3')	method = DOS3;
-// 	else if (metho->answer[3] == '4')	method = DOS4;
-// 	else method = UNCORRECTED;
+    //      if (metho->answer[3] == 'r')            method = CORRECTED;
+    //      else if (metho->answer[3] == '1')       method = DOS1;
+    //      else if (metho->answer[3] == '2')       method = (metho->answer[4] == '\0') ? DOS2 : DOS2b;
+    //      else if (metho->answer[3] == '3')       method = DOS3;
+    //      else if (metho->answer[3] == '4')       method = DOS4;
+    //      else method = UNCORRECTED;
-	for (i = 0; i < lsat.bands; i++)
-		dn_mode[i] = 0;
-		dn_dark[i] = (int)lsat.band[i].qcalmin;
-		/* Calculate dark pixel */
-		if (method > DOS && !lsat.band[i].thermal)
-			for (j = 0; j < 256; j++) hist[j] = 0L;
+    for (i = 0; i < lsat.bands; i++) {
+	dn_mode[i] = 0;
+	dn_dark[i] = (int)lsat.band[i].qcalmin;
+	/* Calculate dark pixel */
+	if (method > DOS && !lsat.band[i].thermal) {
+	    for (j = 0; j < 256; j++)
+		hist[j] = 0L;
-			snprintf(band_in, 127, "%s.%d", name, lsat.band[i].code);
-			mapset = G_find_cell2(band_in, "");
-			if (mapset == NULL) {
-				G_warning(_("Raster file [%s] not found"), band_in);
-				continue;
-			if ((infd = G_open_cell_old(band_in, mapset)) < 0)
-				G_fatal_error(_("Cannot open cell file [%s]"), band_in);
-			if (G_get_cellhd(band_in, mapset, &cellhd) < 0)
-				G_fatal_error(_("Cannot read file header of [%s]"), band_in);
-			if (G_set_window(&cellhd) < 0)
-				G_fatal_error(_("Unable to set region"));
+	    snprintf(band_in, 127, "%s.%d", name, lsat.band[i].code);
+	    mapset = G_find_cell2(band_in, "");
+	    if (mapset == NULL) {
+		G_warning(_("Raster file [%s] not found"), band_in);
+		continue;
+	    if ((infd = G_open_cell_old(band_in, mapset)) < 0)
+		G_fatal_error(_("Cannot open cell file [%s]"), band_in);
+	    if (G_get_cellhd(band_in, mapset, &cellhd) < 0)
+		G_fatal_error(_("Cannot read file header of [%s]"), band_in);
+	    if (G_set_window(&cellhd) < 0)
+		G_fatal_error(_("Unable to set region"));
-			in_data_type = G_raster_map_type(band_in, mapset);
-			inrast = G_allocate_raster_buf(in_data_type);
+	    in_data_type = G_raster_map_type(band_in, mapset);
+	    inrast = G_allocate_raster_buf(in_data_type);
-			nrows = G_window_rows();
-			ncols = G_window_cols();
+	    nrows = G_window_rows();
+	    ncols = G_window_cols();
-			G_message("Calculating dark pixel of [%s] ... ", band_in);
-			for (row = 0; row < nrows; row++)
-				G_get_raster_row(infd, inrast, row, in_data_type);
-				for (col = 0; col < ncols; col++)
-					switch(in_data_type)
-						case CELL_TYPE:
-							ptr = (void *)((CELL *)inrast + col);
-							q = (int)*((CELL *)ptr);
-							break;
-						case FCELL_TYPE:
-							ptr = (void *)((FCELL *)inrast + col);
-							q = (int)*((FCELL *)ptr);
-							break;
-						case DCELL_TYPE:
-							ptr = (void *)((DCELL *)inrast + col);
-							q = (int)*((DCELL *)ptr);
-							break;
-					if (!G_is_null_value(ptr, in_data_type) &&
-						q >= lsat.band[i].qcalmin && q < 256)
-						hist[q]++;
-			/* DN of dark object */
-			for (j = lsat.band[i].qcalmin; j < 256; j++)
-				if (hist[j] >= pixel)
-					dn_dark[i] = j;
-					break;
-			/* Mode of DN */
-			h_max = 0L;
-			for (j= lsat.band[i].qcalmin; j < 241; j++) /* Exclude ptentially saturated < 240 */
-// 				printf("%d-%ld\n", j, hist[j]);
-				if (hist[j] > h_max)
-					h_max = hist[j];
-					dn_mode[i] = j;
-			G_message("... DN = %.2d [%d] : mode %.2d [%d] %s",
-						dn_dark[i], hist[dn_dark[i]],
-						dn_mode[i], hist[dn_mode[i]],
-						hist[255] > hist[dn_mode[i]] ? ", excluding DN > 241" : "");
+	    G_message("Calculating dark pixel of [%s] ... ", band_in);
+	    for (row = 0; row < nrows; row++) {
+		G_get_raster_row(infd, inrast, row, in_data_type);
+		for (col = 0; col < ncols; col++) {
+		    switch (in_data_type) {
+		    case CELL_TYPE:
+			ptr = (void *)((CELL *) inrast + col);
+			q = (int)*((CELL *) ptr);
+			break;
+		    case FCELL_TYPE:
+			ptr = (void *)((FCELL *) inrast + col);
+			q = (int)*((FCELL *) ptr);
+			break;
+		    case DCELL_TYPE:
+			ptr = (void *)((DCELL *) inrast + col);
+			q = (int)*((DCELL *) ptr);
+			break;
+		    if (!G_is_null_value(ptr, in_data_type) &&
+			q >= lsat.band[i].qcalmin && q < 256)
+			hist[q]++;
+	    /* DN of dark object */
+	    for (j = lsat.band[i].qcalmin; j < 256; j++) {
+		if (hist[j] >= pixel) {
+		    dn_dark[i] = j;
+		    break;
+	    /* Mode of DN */
+	    h_max = 0L;
+	    for (j = lsat.band[i].qcalmin; j < 241; j++) {	/* Exclude ptentially saturated < 240 */
+		//                              printf("%d-%ld\n", j, hist[j]);
+		if (hist[j] > h_max) {
+		    h_max = hist[j];
+		    dn_mode[i] = j;
+	    G_message("... DN = %.2d [%d] : mode %.2d [%d] %s",
+		      dn_dark[i], hist[dn_dark[i]],
+		      dn_mode[i], hist[dn_mode[i]],
+		      hist[255] >
+		      hist[dn_mode[i]] ? ", excluding DN > 241" : "");
-			G_free(inrast);
-			G_close_cell(infd);
-		/* Calculate transformation constants */
-		lsat_bandctes(&lsat, i, method, percent, dn_dark[i], sat_zenith, rayleigh);
+	    G_free(inrast);
+	    G_close_cell(infd);
+	/* Calculate transformation constants */
+	lsat_bandctes(&lsat, i, method, percent, dn_dark[i], sat_zenith,
+		      rayleigh);
 	 * ------------ VERBOSE ------------------
-	if (verbo->answer)
-		fprintf(stdout, " ACQUISITION DATE %s [production date %s]\n", lsat.date, lsat.creation);
-		fprintf(stdout, "   earth-sun distance    = %.8lf\n", lsat.dist_es);
-		fprintf(stdout, "   solar elevation angle = %.8lf\n", lsat.sun_elev);
-		fprintf(stdout, "   Method of calculus = %s\n",
-				(method==CORRECTED ? "CORRECTED"
-								   : (method == UNCORRECTED ? "UNCORRECTED" : metho->answer)));
+    if (verbo->answer) {
+	fprintf(stdout, " ACQUISITION DATE %s [production date %s]\n",
+		lsat.date, lsat.creation);
+	fprintf(stdout, "   earth-sun distance    = %.8lf\n", lsat.dist_es);
+	fprintf(stdout, "   solar elevation angle = %.8lf\n", lsat.sun_elev);
+	fprintf(stdout, "   Method of calculus = %s\n",
+		(method == CORRECTED ? "CORRECTED"
+		 : (method == UNCORRECTED ? "UNCORRECTED" : metho->answer)));
+	if (method > DOS) {
+	    fprintf(stdout,
+		    "   percent of solar irradiance in path radiance = %.4lf\n",
+		    percent);
+	    fprintf(stdout, "-------------------\n");
+	    fprintf(stdout, " BAND %d %s (code %d)\n",
+		    lsat.band[i].number,
+		    (lsat.band[i].thermal ? "thermal " : ""),
+		    lsat.band[i].code);
+	    fprintf(stdout,
+		    "   calibrated digital number (DN): %.1lf to %.1lf\n",
+		    lsat.band[i].qcalmin, lsat.band[i].qcalmax);
+	    fprintf(stdout, "   calibration constants (L): %.3lf to %.3lf\n",
+		    lsat.band[i].lmin, lsat.band[i].lmax);
+	    fprintf(stdout, "   at-%s radiance = %.5lf · DN + %.5lf\n",
+		    (method > DOS ? "surface" : "sensor"), lsat.band[i].gain,
+		    lsat.band[i].bias);
+	    if (lsat.band[i].thermal) {
+		fprintf(stdout,
+			"   at-sensor temperature = %.3lf / log[(%.3lf / radiance) + 1.0]\n",
+			lsat.band[i].K2, lsat.band[i].K1);
+	    else {
+		fprintf(stdout,
+			"   mean solar exoatmospheric irradiance (ESUN): %.3lf\n",
+			lsat.band[i].esun);
+		fprintf(stdout, "   at-%s reflectance = radiance / %.5lf\n",
+			lsat.band[i].K2);
 		if (method > DOS) {
-			fprintf(stdout, "   percent of solar irradiance in path radiance = %.4lf\n", percent);
+		    fprintf(stdout,
+			    "   the darkness DN with a least %d pixels is %d\n",
+			    pixel, dn_dark[i]);
+		    fprintf(stdout, "   the mode of DN is %d\n", dn_mode[i]);
-			fprintf(stdout, "-------------------\n");
-			fprintf(stdout, " BAND %d %s (code %d)\n",
-					lsat.band[i].number, (lsat.band[i].thermal ? "thermal " : ""),
-					lsat.band[i].code);
-			fprintf(stdout, "   calibrated digital number (DN): %.1lf to %.1lf\n",
-					lsat.band[i].qcalmin, lsat.band[i].qcalmax);
-			fprintf(stdout, "   calibration constants (L): %.3lf to %.3lf\n",
-					lsat.band[i].lmin, lsat.band[i].lmax);
-			fprintf(stdout, "   at-%s radiance = %.5lf · DN + %.5lf\n",
-					(method > DOS ? "surface" : "sensor"),
-					lsat.band[i].gain, lsat.band[i].bias);
-			if (lsat.band[i].thermal) {
-				fprintf(stdout, "   at-sensor temperature = %.3lf / log[(%.3lf / radiance) + 1.0]\n",
-						lsat.band[i].K2, lsat.band[i].K1);
-			else {
-				fprintf(stdout, "   mean solar exoatmospheric irradiance (ESUN): %.3lf\n",
-						lsat.band[i].esun);
-				fprintf(stdout, "   at-%s reflectance = radiance / %.5lf\n",
-						lsat.band[i].K2);
-				if (method > DOS) {
-					fprintf(stdout, "   the darkness DN with a least %d pixels is %d\n", pixel, dn_dark[i] );
-					fprintf(stdout, "   the mode of DN is %d\n", dn_mode[i] );
-		fflush(stdout);
+	fflush(stdout);
 	 * ------------ CALCULUS -----------------
-		snprintf(band_out, 127, "%s.toar.%d", name, lsat.band[i].code);
+	snprintf(band_out, 127, "%s.toar.%d", name, lsat.band[i].code);
-	    	G_warning(_("raster file [%s] not found"), band_in);
-	    	continue; }
+	    G_warning(_("raster file [%s] not found"), band_in);
+	    continue;
-		/* set same size as original band raster */
+	/* set same size as original band raster */
-		/* controlling, if we can write the raster */
-		if (G_legal_filename(band_out) < 0)
-	    	G_fatal_error(_("[%s] is an illegal name"), band_out);
+	/* controlling, if we can write the raster */
+	if (G_legal_filename(band_out) < 0)
+	    G_fatal_error(_("[%s] is an illegal name"), band_out);
-		if ((outfd = G_open_raster_new(band_out, DCELL_TYPE)) < 0)
-			G_fatal_error(_("Could not open <%s>"), band_out);
+	if ((outfd = G_open_raster_new(band_out, DCELL_TYPE)) < 0)
+	    G_fatal_error(_("Could not open <%s>"), band_out);
-		/* Allocate input and output buffer */
-		outrast = G_allocate_raster_buf(DCELL_TYPE);
+	/* Allocate input and output buffer */
+	outrast = G_allocate_raster_buf(DCELL_TYPE);
-		G_message("%s of %s to %s",
-				  (frad->answer ? "Radiance"
-			                    : (lsat.band[i].thermal) ? "Temperature" : "Reflectance"),
-				   band_in, band_out);
+	G_message("%s of %s to %s",
+		  (frad->answer ? "Radiance"
+		   : (lsat.band[i].thermal) ? "Temperature" : "Reflectance"),
+		  band_in, band_out);
-			if (verbose)
-				G_percent(row, nrows, 2);
+	    if (verbose)
+		G_percent(row, nrows, 2);
-					case CELL_TYPE:
-							qcal = (double)((CELL *) inrast)[col];
-							break;
-					case FCELL_TYPE:
-							qcal = (double)((FCELL *) inrast)[col];
-							break;
-					case DCELL_TYPE:
-							qcal = (double)((DCELL *) inrast)[col];
-							break;
-				if (G_is_null_value(ptr, in_data_type) ||
-					qcal < lsat.band[i].qcalmin)
-					G_set_d_null_value((DCELL *)outrast + col, 1);
-				else
-					rad = lsat_qcal2rad(qcal, &lsat.band[i]);
-					if (frad->answer)
-						ref = rad;
-					else
-							ref = lsat_rad2temp(rad, &lsat.band[i]);
-						else
-							ref = lsat_rad2ref(rad, &lsat.band[i]);
-							if (ref < 0. && method > DOS) ref = 0.;
-					((DCELL *) outrast)[col] = ref;
+		case CELL_TYPE:
+		    qcal = (double)((CELL *) inrast)[col];
+		    break;
+		case FCELL_TYPE:
+		    qcal = (double)((FCELL *) inrast)[col];
+		    break;
+		case DCELL_TYPE:
+		    qcal = (double)((DCELL *) inrast)[col];
+		    break;
+		if (G_is_null_value(ptr, in_data_type) ||
+		    qcal < lsat.band[i].qcalmin) {
+		    G_set_d_null_value((DCELL *) outrast + col, 1);
+		else {
+		    rad = lsat_qcal2rad(qcal, &lsat.band[i]);
+		    if (frad->answer) {
+			ref = rad;
+		    else {
+			    ref = lsat_rad2temp(rad, &lsat.band[i]);
-			if (G_put_raster_row(outfd, outrast, DCELL_TYPE) < 0)
-				G_fatal_error(_("Cannot write to <%s>"), band_out);
+			else {
+			    ref = lsat_rad2ref(rad, &lsat.band[i]);
+			    if (ref < 0. && method > DOS)
+				ref = 0.;
+		    ((DCELL *) outrast)[col] = ref;
-		ref_mode = 0.;
-			ref_mode = lsat_qcal2rad(dn_mode[i], &lsat.band[i]);
-			ref_mode = lsat_rad2ref(ref_mode, &lsat.band[i]);
+	    if (G_put_raster_row(outfd, outrast, DCELL_TYPE) < 0)
+		G_fatal_error(_("Cannot write to <%s>"), band_out);
+	ref_mode = 0.;
+	    ref_mode = lsat_qcal2rad(dn_mode[i], &lsat.band[i]);
+	    ref_mode = lsat_rad2ref(ref_mode, &lsat.band[i]);
-		G_free(inrast);
-		G_free(outrast);
-		G_close_cell(outfd);
+	G_free(inrast);
+	G_free(outrast);
+	G_close_cell(outfd);
-		char command[300];
-		sprintf(command, "r.colors map=%s color=grey", band_out);
-		system(command);
+	char command[300];
-		G_short_history(band_out, "raster", &history);
+	sprintf(command, "r.colors map=%s color=grey", band_out);
+	system(command);
-		sprintf(history.edhist[0], " %s of Landsat-%d %s (method %s)", lsat.band[i].thermal ? "Temperature": "Reflectance",
-				lsat.number, lsat.sensor, metho->answer);
-		sprintf(history.edhist[1], "----------------------------------------------------------------");
-		sprintf(history.edhist[2], " Acquisition date ...................... %s", lsat.date);
-		sprintf(history.edhist[3], " Production date ....................... %s\n", lsat.creation);
-		sprintf(history.edhist[4], " Earth-sun distance (d) ................ %.8lf", lsat.dist_es);
-		sprintf(history.edhist[5], " Digital number (DN) range ............. %.0lf to %.0lf", lsat.band[i].qcalmin, lsat.band[i].qcalmax);
-		sprintf(history.edhist[6], " Calibration constants (Lmin to Lmax) .. %+.3lf to %+.3lf", lsat.band[i].lmin, lsat.band[i].lmax);
-		sprintf(history.edhist[7], " DN to Radiance (gain and bias) ........ %+.5lf and %+.5lf", lsat.band[i].gain, lsat.band[i].bias);
-			sprintf(history.edhist[8], " Temperature (K1 and K2) ............... %.3lf and %.3lf", lsat.band[i].K1, lsat.band[i].K2);
-            history.edlinecnt = 9;
-		} else {
-			sprintf(history.edhist[8], " Mean solar irradiance (ESUN) .......... %.3lf", lsat.band[i].esun);
-			sprintf(history.edhist[9], " Reflectance = Radiance divided by ..... %.5lf", lsat.band[i].K2);
-	        history.edlinecnt = 10;
-				sprintf(history.edhist[10], " ");
-				sprintf(history.edhist[11], " Dark object (%4d pixels) DN = ........ %d", pixel, dn_dark[i]);
-				sprintf(history.edhist[12], " Mode in reflectance histogram ......... %.5lf", ref_mode);
-				history.edlinecnt = 13;
-		sprintf (history.edhist[history.edlinecnt], "-----------------------------------------------------------------");
-		history.edlinecnt++;
+	G_short_history(band_out, "raster", &history);
-		G_command_history(&history);
-		G_write_history(band_out, &history);
+	sprintf(history.edhist[0], " %s of Landsat-%d %s (method %s)",
+		lsat.band[i].thermal ? "Temperature" : "Reflectance",
+		lsat.number, lsat.sensor, metho->answer);
+	sprintf(history.edhist[1],
+	sprintf(history.edhist[2],
+		" Acquisition date ...................... %s", lsat.date);
+	sprintf(history.edhist[3],
+		" Production date ....................... %s\n",
+		lsat.creation);
+	sprintf(history.edhist[4],
+		" Earth-sun distance (d) ................ %.8lf",
+		lsat.dist_es);
+	sprintf(history.edhist[5],
+		" Digital number (DN) range ............. %.0lf to %.0lf",
+	sprintf(history.edhist[6],
+		" Calibration constants (Lmin to Lmax) .. %+.3lf to %+.3lf",
+	sprintf(history.edhist[7],
+		" DN to Radiance (gain and bias) ........ %+.5lf and %+.5lf",
+		lsat.band[i].gain, lsat.band[i].bias);
+	    sprintf(history.edhist[8],
+		    " Temperature (K1 and K2) ............... %.3lf and %.3lf",
+		    lsat.band[i].K1, lsat.band[i].K2);
+	    history.edlinecnt = 9;
+	else {
+		    " Mean solar irradiance (ESUN) .......... %.3lf",
+	    sprintf(history.edhist[9],
+		    " Reflectance = Radiance divided by ..... %.5lf",
+		    lsat.band[i].K2);
+	    history.edlinecnt = 10;
+		sprintf(history.edhist[10], " ");
+		sprintf(history.edhist[11],
+			" Dark object (%4d pixels) DN = ........ %d", pixel,
+			dn_dark[i]);
+		sprintf(history.edhist[12],
+			" Mode in reflectance histogram ......... %.5lf",
+			ref_mode);
+		history.edlinecnt = 13;
+	sprintf(history.edhist[history.edlinecnt],
+	history.edlinecnt++;
-	exit(EXIT_SUCCESS);
+	G_command_history(&history);
+	G_write_history(band_out, &history);
+    exit(EXIT_SUCCESS);
