[GRASS-SVN] r43575 - grass/trunk/raster/r.neighbors
Tue Sep 21 08:47:44 EDT 2010
Author: neteler
Date: 2010-09-21 12:47:44 +0000 (Tue, 21 Sep 2010)
New Revision: 43575
   grass/trunk/raster/r.neighbors/main.c
   grass/trunk/raster/r.neighbors/r.neighbors.html
add range method
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c	2010-09-21 12:39:42 UTC (rev 43574)
+++ grass/trunk/raster/r.neighbors/main.c	2010-09-21 12:47:44 UTC (rev 43575)
@@ -50,6 +50,7 @@
     {c_mode, w_mode, NO_CATS, 1, 0, "mode", "most frequently occuring value"},
     {c_min, NULL, NO_CATS, 1, 0, "minimum", "lowest value"},
     {c_max, NULL, NO_CATS, 1, 0, "maximum", "highest value"},
+    {c_range, NULL, NO_CATS, 1, 0, "range", "range value"},
     {c_stddev, w_stddev, NO_CATS, 0, 1, "stddev", "standard deviation"},
     {c_sum, w_sum, NO_CATS, 1, 0, "sum", "sum of values"},
     {c_var, w_var, NO_CATS, 0, 1, "variance", "statistical variance"},
Modified: grass/trunk/raster/r.neighbors/r.neighbors.html
--- grass/trunk/raster/r.neighbors/r.neighbors.html	2010-09-21 12:39:42 UTC (rev 43574)
+++ grass/trunk/raster/r.neighbors/r.neighbors.html	2010-09-21 12:47:44 UTC (rev 43575)
@@ -131,6 +131,10 @@
 </pre>
+<dt><b>range</b>
+<dd>The range value within the neighborhood.
 <dt><b>stddev</b>
 <dd>The statistical standard deviation of values
